PERL WARNING: Argument "...../FHEM/10_ZWave.pm line 4785.
Begonnen von Damu, 29 Dezember 2025, 19:18:45
Damu
So habs nochmal gemacht, aber vorher den ZWave Uart 1 Minute vom Strom genommen.
Zitat2026.01.16 16:00:04 0: Server shutdown
2026.01.16 16:01:36 1: Including fhem.cfg
2026.01.16 16:01:36 3: telnetPort: port 7072 opened
2026.01.16 16:01:36 3: WEB: port 9083 opened
2026.01.16 16:01:36 3: WEBphone: port 8083 opened
2026.01.16 16:01:36 3: WEBtablet: port 9085 opened
2026.01.16 16:01:36 3: WEBaxis: port 9086 opened
2026.01.16 16:01:36 2: eventTypes: loaded 12225 lines from ./log/eventTypes.txt
2026.01.16 16:01:37 3: Opening Fritzbox_Callmonitor device 192.168.178.1:1012
2026.01.16 16:01:38 3: T25_http: URL is none, periodic updates will be limited to explicit GetXXPoll attribues (if defined)
2026.01.16 16:01:38 3: T25_http: interval is 0, no periodic updates will done.
2026.01.16 16:01:38 3: T25_http: Defined without URL featurelevel 6.4
2026.01.16 16:01:58 3: C26_http: URL is none, periodic updates will be limited to explicit GetXXPoll attribues (if defined)
2026.01.16 16:01:58 3: C26_http: interval is 0, no periodic updates will done.
2026.01.16 16:01:58 3: C26_http: Defined without URL featurelevel 6.4
2026.01.16 16:02:23 3: Opening POE_ZW_Prim_OG device 192.168.178.15:5003
2026.01.16 16:02:24 3: POE_ZW_Prim_OG device opened
2026.01.16 16:02:25 3: Opening POE_EnOcean_UG device 192.168.178.7:5001
2026.01.16 16:02:25 3: POE_EnOcean_UG device opened
2026.01.16 16:02:25 2: EnOcean Cryptographic functions available.
2026.01.16 16:02:25 2: EnOcean XML functions available.
2026.01.16 16:02:26 3: AutoShuttersControl (ASC) - defined
2026.01.16 16:02:26 3: BOSEST: BOSE SoundTouch v2.2.1
2026.01.16 16:02:26 3: Opening POE_EnOcean_OG device 192.168.178.15:5000
2026.01.16 16:02:26 3: POE_EnOcean_OG device opened
2026.01.16 16:02:27 3: WEBapi: port 8088 opened
2026.01.16 16:02:27 3: T26_brightness: Defined with URL http://fhem:dcmoss456479@192.168.178.11:80/control/rcontrol?action=gettext&message=$(SEN.LXR) and interval 3600 featurelevel 6.4
2026.01.16 16:02:27 3: T26_temp: Defined with URL http://fhem:dcmoss456479@192.168.178.11:80/control/rcontrol?action=gettext&message=$(SEN.TIN.CELSIUS) and interval 3600 featurelevel 6.4
2026.01.16 16:02:27 1: Including ./log/fhem.save
2026.01.16 16:02:28 3: TCM POE_EnOcean_OG set reset
2026.01.16 16:02:29 3: TCM POE_EnOcean_OG get version
2026.01.16 16:02:29 2: TCM POE_EnOcean_OG EVENT RESET_CAUSE: sw_reset SECURE_MODE: standard
2026.01.16 16:02:29 2: TCM POE_EnOcean_OG RESPONSE: APIVersion: 010501E7 APPVersion: 01060100 ChipID: 0425BA22 ChipVersion: 454F0103 Desc: TCM515
2026.01.16 16:02:29 3: TCM POE_EnOcean_OG set repeater 0000
2026.01.16 16:02:29 2: TCM POE_EnOcean_OG repeater 0000 restored
2026.01.16 16:02:29 3: TCM POE_EnOcean_OG set mode 00
2026.01.16 16:02:29 2: TCM POE_EnOcean_OG RESPONSE: NOT_SUPPORTED
2026.01.16 16:02:29 3: TCM POE_EnOcean_OG set maturity 01
2026.01.16 16:02:29 2: TCM POE_EnOcean_OG maturity 01 restored
2026.01.16 16:02:29 3: TCM POE_EnOcean_OG set smartAckMailboxMax 10
2026.01.16 16:02:29 2: TCM POE_EnOcean_OG smartAckMailboxMax 10 restored
2026.01.16 16:02:29 2: TCM POE_EnOcean_OG initialized
2026.01.16 16:02:29 2: TCM registered transceiver BaseID: FFFCB080 ChipID: 0425BA22
2026.01.16 16:02:29 3: TCM POE_EnOcean_UG set reset
2026.01.16 16:02:30 3: TCM POE_EnOcean_UG get version
2026.01.16 16:02:30 2: TCM POE_EnOcean_UG EVENT RESET_CAUSE: sw_reset SECURE_MODE: standard
2026.01.16 16:02:30 2: TCM POE_EnOcean_UG RESPONSE: APIVersion: 010501E7 APPVersion: 01060100 ChipID: 0425BA20 ChipVersion: 454F0103 Desc: TCM515
2026.01.16 16:02:30 3: TCM POE_EnOcean_UG set mode 00
2026.01.16 16:02:30 2: TCM POE_EnOcean_UG RESPONSE: NOT_SUPPORTED
2026.01.16 16:02:30 3: TCM POE_EnOcean_UG set repeater 0000
2026.01.16 16:02:30 2: TCM POE_EnOcean_UG repeater 0000 restored
2026.01.16 16:02:30 3: TCM POE_EnOcean_UG set smartAckMailboxMax 10
2026.01.16 16:02:30 2: TCM POE_EnOcean_UG smartAckMailboxMax 10 restored
2026.01.16 16:02:30 3: TCM POE_EnOcean_UG set maturity 01
2026.01.16 16:02:30 2: TCM POE_EnOcean_UG maturity 01 restored
2026.01.16 16:02:30 2: TCM POE_EnOcean_UG initialized
2026.01.16 16:02:30 2: TCM registered transceiver BaseID: FFFCB080 ChipID: 0425BA22:0425BA20
2026.01.16 16:02:30 3: Opening HM_POE_OG device 192.168.178.15:5002
2026.01.16 16:02:30 3: Opening HM_POE_UG device 192.168.178.7:5000
2026.01.16 16:02:34 3: [Fritzbox_Callmonitor | readPhonebook.1410] - EVENT: read 1203 contacts from remote phonebook "Telefonbuch"
2026.01.16 16:02:37 3: [Fritzbox_Callmonitor | readPhonebook.1410] - EVENT: read 1523 contacts from remote phonebook "ICloud"
2026.01.16 16:02:40 0: Featurelevel: 6.4
2026.01.16 16:02:40 0: Server started with 540 defined entities (fhem.pl:30719/2026-01-11 perl:5.038002 os:linux user:fhem pid:719841)
2026.01.16 16:02:40 3: telnetForBlockingFn_1768575760.39208: port 46583 opened
2026.01.16 16:02:40 2: ZWDongle_ProcessSendStack: no ACK, resending message 0105000b800170
2026.01.16 16:02:40 5: DevIo_SimpleWrite POE_ZW_Prim_OG: 0105000b800170
2026.01.16 16:02:40 3: Fritzbox_Callmonitor device opened
2026.01.16 16:02:40 3: HM_POE_UG device opened
2026.01.16 16:02:40 3: HM_POE_OG device opened
2026.01.16 16:02:40 5: ACK received, removing 0105000b800170 from dongle sendstack
2026.01.16 16:02:40 4: ZWDongle_Read POE_ZW_Prim_OG: rcvd 010b8001 (answer SERIAL_API_SETUP), sending ACK
2026.01.16 16:02:40 5: DevIo_SimpleWrite POE_ZW_Prim_OG: 06
2026.01.16 16:02:40 5: POE_ZW_Prim_OG: dispatch 010b8001
2026.01.16 16:02:40 4: POE_ZW_Prim_OG unhandled ANSWER: SERIAL_API_SETUP 8001
2026.01.16 16:02:43 3: Infratec_UG: Error -> 192.168.178.17: No route to host (113)
2026.01.16 16:02:50 3: [FritzBox | 7583 | 167.08.20 | Readout_API_Check.10025] - BASIC:Response -> luaQuery:200 luaData:200 TR064:200
2026.01.16 16:03:21 4: ZWDongle_Read POE_ZW_Prim_OG: rcvd 000400380a32022134000000000000a6000116 (request APPLICATION_COMMAND_HANDLER), sending ACK
2026.01.16 16:03:21 5: DevIo_SimpleWrite POE_ZW_Prim_OG: 06
2026.01.16 16:03:21 5: POE_ZW_Prim_OG: dispatch 000400380a32022134000000000000a6000116
2026.01.16 16:03:21 4: CMD:APPLICATION_COMMAND_HANDLER ID:38 ARG:0a32022134000000000000a6000116 CB:00
2026.01.16 16:03:23 4: ZWDongle_Read POE_ZW_Prim_OG: rcvd 000400aa0a600d02003105030a0036ad00018a (request APPLICATION_COMMAND_HANDLER), sending ACK
2026.01.16 16:03:23 5: DevIo_SimpleWrite POE_ZW_Prim_OG: 06
2026.01.16 16:03:23 5: POE_ZW_Prim_OG: dispatch 000400aa0a600d02003105030a0036ad00018a
2026.01.16 16:03:23 4: CMD:APPLICATION_COMMAND_HANDLER ID:aa ARG:0a600d02003105030a0036ad00018a CB:00
2026.01.16 16:03:32 4: ZWDongle_Read POE_ZW_Prim_OG: rcvd 000400a30a600d03003105030a07d0b1000137 (request APPLICATION_COMMAND_HANDLER), sending ACK
2026.01.16 16:03:32 5: DevIo_SimpleWrite POE_ZW_Prim_OG: 06
2026.01.16 16:03:32 5: POE_ZW_Prim_OG: dispatch 000400a30a600d03003105030a07d0b1000137
2026.01.16 16:03:32 4: CMD:APPLICATION_COMMAND_HANDLER ID:a3 ARG:0a600d03003105030a07d0b1000137 CB:00
2026.01.16 16:03:36 3: CUL_HM start Queues
2026.01.16 16:03:37 3: CUL_HM set Licht_Estrich statusRequest noArg
Danke fuers Log#1
Jörgs Aenderung prueft, ob $hash->{lastMessageSent} definiert ist.
Das darf im erwaehnten Fall gar nicht helfen, weil laut Meldung das Problem ist, dass einer der Werte "POE_ZW_Prim_OG" ist (und nicht undef).
Da ich nach lesen des Logs auch nicht schlauer geworden bin, habe ich eine Version mit einer zusaetzlichen debug Ausgabe (Log 1) eingebaut.
@Damu: kannst du bitte das Experiment wiederholen, und diese Ausgabe hier zeigen?
Damu
Zitat2026.01.16 17:46:40 0: Server shutdown
2026.01.16 17:46:42 1: Including fhem.cfg
2026.01.16 17:46:42 3: telnetPort: port 7072 opened
2026.01.16 17:46:42 3: WEB: port 9083 opened
2026.01.16 17:46:42 3: WEBphone: port 8083 opened
2026.01.16 17:46:42 3: WEBtablet: port 9085 opened
2026.01.16 17:46:42 3: WEBaxis: port 9086 opened
2026.01.16 17:46:43 2: eventTypes: loaded 12226 lines from ./log/eventTypes.txt
2026.01.16 17:46:43 3: Opening Fritzbox_Callmonitor device 192.168.178.1:1012
2026.01.16 17:46:45 3: T25_http: URL is none, periodic updates will be limited to explicit GetXXPoll attribues (if defined)
2026.01.16 17:46:45 3: T25_http: interval is 0, no periodic updates will done.
2026.01.16 17:46:45 3: T25_http: Defined without URL featurelevel 6.4
2026.01.16 17:47:05 3: C26_http: URL is none, periodic updates will be limited to explicit GetXXPoll attribues (if defined)
2026.01.16 17:47:05 3: C26_http: interval is 0, no periodic updates will done.
2026.01.16 17:47:05 3: C26_http: Defined without URL featurelevel 6.4
2026.01.16 17:47:29 3: Opening POE_ZW_Prim_OG device 192.168.178.15:5003
2026.01.16 17:47:30 3: POE_ZW_Prim_OG device opened
2026.01.16 17:47:31 3: Opening POE_EnOcean_UG device 192.168.178.7:5001
2026.01.16 17:47:31 3: POE_EnOcean_UG device opened
2026.01.16 17:47:32 2: EnOcean Cryptographic functions available.
2026.01.16 17:47:32 2: EnOcean XML functions available.
2026.01.16 17:47:32 3: AutoShuttersControl (ASC) - defined
2026.01.16 17:47:33 3: BOSEST: BOSE SoundTouch v2.2.1
2026.01.16 17:47:33 3: Opening POE_EnOcean_OG device 192.168.178.15:5000
2026.01.16 17:47:33 3: POE_EnOcean_OG device opened
2026.01.16 17:47:33 3: WEBapi: port 8088 opened
2026.01.16 17:47:34 3: T26_brightness: Defined with URL http://fhem:dcmoss456479@192.168.178.11:80/control/rcontrol?action=gettext&message=$(SEN.LXR) and interval 3600 featurelevel 6.4
2026.01.16 17:47:34 3: T26_temp: Defined with URL http://fhem:dcmoss456479@192.168.178.11:80/control/rcontrol?action=gettext&message=$(SEN.TIN.CELSIUS) and interval 3600 featurelevel 6.4
2026.01.16 17:47:34 1: Including ./log/fhem.save
2026.01.16 17:47:34 3: TCM POE_EnOcean_OG set reset
2026.01.16 17:47:35 3: TCM POE_EnOcean_OG get version
2026.01.16 17:47:35 2: TCM POE_EnOcean_OG EVENT RESET_CAUSE: sw_reset SECURE_MODE: standard
2026.01.16 17:47:35 2: TCM POE_EnOcean_OG RESPONSE: APIVersion: 010501E7 APPVersion: 01060100 ChipID: 0425BA22 ChipVersion: 454F0103 Desc: TCM515
2026.01.16 17:47:35 3: TCM POE_EnOcean_OG set repeater 0000
2026.01.16 17:47:35 2: TCM POE_EnOcean_OG repeater 0000 restored
2026.01.16 17:47:35 3: TCM POE_EnOcean_OG set maturity 01
2026.01.16 17:47:35 2: TCM POE_EnOcean_OG maturity 01 restored
2026.01.16 17:47:35 3: TCM POE_EnOcean_OG set smartAckMailboxMax 10
2026.01.16 17:47:35 2: TCM POE_EnOcean_OG smartAckMailboxMax 10 restored
2026.01.16 17:47:35 3: TCM POE_EnOcean_OG set mode 00
2026.01.16 17:47:35 2: TCM POE_EnOcean_OG RESPONSE: NOT_SUPPORTED
2026.01.16 17:47:35 2: TCM POE_EnOcean_OG initialized
2026.01.16 17:47:35 2: TCM registered transceiver BaseID: FFFCB080 ChipID: 0425BA22
2026.01.16 17:47:35 3: TCM POE_EnOcean_UG set reset
2026.01.16 17:47:36 3: TCM POE_EnOcean_UG get version
2026.01.16 17:47:36 2: TCM POE_EnOcean_UG EVENT RESET_CAUSE: sw_reset SECURE_MODE: standard
2026.01.16 17:47:36 2: TCM POE_EnOcean_UG RESPONSE: APIVersion: 010501E7 APPVersion: 01060100 ChipID: 0425BA20 ChipVersion: 454F0103 Desc: TCM515
2026.01.16 17:47:36 3: TCM POE_EnOcean_UG set maturity 01
2026.01.16 17:47:36 2: TCM POE_EnOcean_UG maturity 01 restored
2026.01.16 17:47:36 3: TCM POE_EnOcean_UG set repeater 0000
2026.01.16 17:47:36 2: TCM POE_EnOcean_UG repeater 0000 restored
2026.01.16 17:47:36 3: TCM POE_EnOcean_UG set mode 00
2026.01.16 17:47:36 2: TCM POE_EnOcean_UG RESPONSE: NOT_SUPPORTED
2026.01.16 17:47:36 3: TCM POE_EnOcean_UG set smartAckMailboxMax 10
2026.01.16 17:47:36 2: TCM POE_EnOcean_UG smartAckMailboxMax 10 restored
2026.01.16 17:47:36 2: TCM POE_EnOcean_UG initialized
2026.01.16 17:47:36 2: TCM registered transceiver BaseID: FFFCB080 ChipID: 0425BA22:0425BA20
2026.01.16 17:47:36 3: Opening HM_POE_OG device 192.168.178.15:5002
2026.01.16 17:47:36 3: Opening HM_POE_UG device 192.168.178.7:5000
2026.01.16 17:47:40 3: [Fritzbox_Callmonitor | readPhonebook.1410] - EVENT: read 1203 contacts from remote phonebook "Telefonbuch"
2026.01.16 17:47:44 3: [Fritzbox_Callmonitor | readPhonebook.1410] - EVENT: read 1523 contacts from remote phonebook "ICloud"
2026.01.16 17:47:46 0: Featurelevel: 6.4
2026.01.16 17:47:46 0: Server started with 540 defined entities (fhem.pl:30719/2026-01-11 perl:5.038002 os:linux user:fhem pid:720104)
2026.01.16 17:47:46 3: telnetForBlockingFn_1768582066.56591: port 43001 opened
2026.01.16 17:47:46 2: ZWDongle_ProcessSendStack: no ACK, resending message 0105000b800170
2026.01.16 17:47:46 5: DevIo_SimpleWrite POE_ZW_Prim_OG: 0105000b800170
2026.01.16 17:47:46 3: HM_POE_OG device opened
2026.01.16 17:47:46 3: Fritzbox_Callmonitor device opened
2026.01.16 17:47:46 3: HM_POE_UG device opened
2026.01.16 17:47:46 5: ACK received, removing 0105000b800170 from dongle sendstack
2026.01.16 17:47:46 4: ZWDongle_Read POE_ZW_Prim_OG: rcvd 010b8001 (answer SERIAL_API_SETUP), sending ACK
2026.01.16 17:47:46 5: DevIo_SimpleWrite POE_ZW_Prim_OG: 06
2026.01.16 17:47:46 5: POE_ZW_Prim_OG: dispatch 010b8001
2026.01.16 17:47:46 4: POE_ZW_Prim_OG unhandled ANSWER: SERIAL_API_SETUP 8001
2026.01.16 17:47:50 3: Infratec_OG: Error -> connect to http://192.168.178.16:80 timed out
2026.01.16 17:47:50 3: Infratec_UG: Error -> connect to http://192.168.178.17:80 timed out
2026.01.16 17:47:56 3: [FritzBox | 7583 | 167.08.20 | Readout_API_Check.10025] - BASIC:Response -> luaQuery:200 luaData:200 TR064:200
2026.01.16 17:48:28 4: ZWDongle_Read POE_ZW_Prim_OG: rcvd 000400380a32022134000000000000a6000116 (request APPLICATION_COMMAND_HANDLER), sending ACK
2026.01.16 17:48:28 5: DevIo_SimpleWrite POE_ZW_Prim_OG: 06
2026.01.16 17:48:28 5: POE_ZW_Prim_OG: dispatch 000400380a32022134000000000000a6000116
2026.01.16 17:48:28 4: CMD:APPLICATION_COMMAND_HANDLER ID:38 ARG:0a32022134000000000000a6000116 CB:00
2026.01.16 17:48:43 3: CUL_HM start Queues
@Damu: bitte laengere Logs immer als Anhang: Zitate werden abgeschnitten.
Und ich brauche die Logs nur dann, wenn die WARNING Meldung auftaucht, und das finde ich hier nicht (vmtl. abgeschnitten).
