DbLog schreibt nicht laufend in die Datenbank
Begonnen von MartinD, 08 März 2026, 19:42:37
MartinD
ich habe hier DbLog, dass nicht so arbeitet wie ich es möchte.
list DbLog
   COLUMNS    field length used for Device: 64, Type: 64, Event: 512, Reading: 64, Value: 128, Unit: 32
   CONFIGURATION ./db.conf
   DEF        ./db.conf .*:(PV_DC|pvIn).*
   FD         5
   FUUID      6939d7ae-f33f-3e5d-3524-8475f9b5bfd5e436
   FVERSION   93_DbLog.pm:v5.11.0-s29401/2024-12-05
   MODE       asynchronous
   MODEL      MYSQL
   NAME       csl_debian_DbLog
   NR         2
   NTFY_ORDER 50-csl_debian_DbLog
   PID        164125
   REGEXP     .*:(PV_DC|pvIn).*
   SBP_PID    164126
   SBP_STATE  running
   STATE      connected
   TYPE       DbLog
   UTF8       1
   dbconn     mysql:database=fhem;host=localhost;port=3306
   dbuser     fhemuser
   eventCount 612
   HELPER:
     COLSET     1
     DEVICECOL  64
     EVENTCOL   512
     OLDSTATE   connected
     PACKAGE    main
     READINGCOL 64
     TC         current
     TH         history
     TYPECOL    64
     UNITCOL    32
     VALUECOL   128
     VERSION    5.11.0
   OLDREADINGS:
     2026-03-08 19:19:56   CacheOverflowLastNum 0
     2026-03-08 15:14:57   CacheOverflowLastState normal
     2026-03-08 19:20:07   CacheUsage      4
     2026-03-08 19:19:56   NextSync        2026-03-08 19:20:26 or when CacheUsage 500 is reached
     2026-03-08 19:20:07   notify_processing_time 0.0003
     2026-03-08 19:19:56   state           connected
   DbLogType  Current/History
   asyncMode  1
   room       LOG
   showNotifyTime 1
   verbose    2
eine Datenbank:
MariaDB [fhem]> SHOW GRANTS FOR 'fhemuser'@'localhost';
| Grants for fhemuser@localhost        |
| GRANT SELECT, INSERT, UPDATE, INDEX, CREATE VIEW, SHOW VIEW ON *.* TO `fhemuser`@`localhost` IDENTIFIED BY PASSWORD '*0A00846A5F41FFFFE0EAE0BFBF930679977C41F4' |
| GRANT SELECT, INSERT, UPDATE, DELETE, CREATE, DROP, INDEX, ALTER ON `fhem`.* TO `fhemuser`@`localhost`                                                          |
und ein device:
2026-03-08 19:23:36   I_AC-Power      0.28871
     2026-03-08 19:23:36   I_AC_Current    1.38
     2026-03-08 19:23:36   I_AC_Energy_WH  1374.734
     2026-03-08 19:23:36   I_DC_Power      0.2931
     2026-03-08 19:23:36   I_Status        On
     2026-03-08 19:23:36   I_Temp_SF       -2
     2026-03-08 19:23:36   I_Temp_Sink     39.06
     2026-03-08 19:23:36   M_AC_POWER      0.00
     2026-03-08 19:23:36   M_AC_POWER_FeedIn 0
     2026-03-08 19:23:36   M_AC_POWER_Purchased 0
     2026-03-08 19:23:36   M_Energy_W_SF   -3
     2026-03-08 19:23:36   M_Exported      186.17
     2026-03-08 19:23:36   M_Imported      951.46
     2026-03-08 19:23:36   NetzHaus        0.000
     2026-03-08 19:23:36   PV_DC           0.000
     2026-03-08 19:23:36   pvIn            0.000
     2026-03-08 19:23:36   pvOut           0.000
     2026-03-08 18:54:24   state           opened
der Event Monitor zeigt:
2026-03-08 19:28:21 ModbusAttr SE_10k PV_DC: 0.000
2026-03-08 19:28:21 ModbusAttr SE_10k BatNet: 0.360
2026-03-08 19:28:21 ModbusAttr SE_10k BatExport: 0.000
2026-03-08 19:28:21 ModbusAttr SE_10k BatHaus: 0.360
2026-03-08 19:28:21 ModbusAttr SE_10k PV_Export: 0.000
2026-03-08 19:28:21 ModbusAttr SE_10k PV_Haus: 0.005
2026-03-08 19:28:21 ModbusAttr SE_10k NetzHaus: 0.000
2026-03-08 19:28:21 DbLog csl_debian_DbLog notify_processing_time: 0.0021
2026-03-08 19:28:21 DbLog csl_debian_DbLog notify_processing_time: 0.0003
2026-03-08 19:30:34 ModbusAttr SE_10k WR_Effizienz: 0.985
2026-03-08 19:30:34 ModbusAttr SE_10k PV_DC: 0.000
2026-03-08 19:30:34 ModbusAttr SE_10k BatNet: 0.360
2026-03-08 19:31:31 ModbusAttr SE_10k PV_Haus: 0.000
2026-03-08 19:31:31 ModbusAttr SE_10k NetzHaus: 0.000
2026-03-08 19:31:32 DbLog csl_debian_DbLog notify_processing_time: 0.0018
2026-03-08 19:31:32 DbLog csl_debian_DbLog notify_processing_time: 0.0002
entgegen aller Erwartungen
ergibt SELECT TIMESTAMP, DEVICE, READING, VALUE FROM history ORDER BY TIMESTAMP DESC LIMIT 10;
| TIMESTAMP           | DEVICE              | READING          | VALUE     |
| 2026-03-08 18:38:35 | SE_10k              | state            | CONNECTED |
| 2026-03-08 14:58:00 | SE_10k              | vom_Dach         | 2.712     |
| 2026-03-08 14:58:00 | YieldDay_M_Imported | state            | 951.13    |
| 2026-03-08 14:58:00 | YieldDay_M_Exported | state            | 183.90    |
| 2026-03-08 14:58:00 | SE_10k              | pvOut            | 2.420     |
| 2026-03-08 14:58:00 | SE_10k              | etotal           | 646.419   |
| 2026-03-08 14:58:00 | SE_10k              | dc2ac            | 0.000     |
| 2026-03-08 14:58:00 | SE_10k              | ac2dc            | 0.000     |
| 2026-03-08 14:58:00 | SE_10k              | WR_Effizienz     | 0.985     |
| 2026-03-08 14:58:00 | SE_10k              | PV_Leistung-temp | 5.09      |
10 rows in set (0,001 sec)
Wenn man nun den timestamp betrachtet: es sind allesamt Einträge die _vor_ 2026-03-08 19:31:31 entstanden sind.
Diese Einträge kammen ausschließlich mit DbLog  DEF ./db.conf .*
Sobald ich einen Filter anlege (s.o.) werden:
1. Einmalig die Filterwerte in DB übertragen
2.danach gar keine events in DB geschrieben.
Weiß jemand einen Rat?
Martin
ergerd
FHEM auf RasPi 4, ZigBee, 1Wire2WLAN, DS2423, EMS-ESP, Button+, LaCrosseGateway, PCA301, ConBee III, LuftdatenInfo, OneWireGW, Div. ESPs u. Shellys
