DbLog schreibt nicht laufend in die Datenbank
Begonnen von MartinD, 08 März 2026, 19:42:37
MartinD
ich habe hier DbLog, dass nicht so arbeitet wie ich es möchte.
list DbLog
   COLUMNS    field length used for Device: 64, Type: 64, Event: 512, Reading: 64, Value: 128, Unit: 32
   CONFIGURATION ./db.conf
   DEF        ./db.conf .*:(PV_DC|pvIn).*
   FD         5
   FUUID      6939d7ae-f33f-3e5d-3524-8475f9b5bfd5e436
   FVERSION   93_DbLog.pm:v5.11.0-s29401/2024-12-05
   MODE       asynchronous
   MODEL      MYSQL
   NAME       csl_debian_DbLog
   NR         2
   NTFY_ORDER 50-csl_debian_DbLog
   PID        164125
   REGEXP     .*:(PV_DC|pvIn).*
   SBP_PID    164126
   SBP_STATE  running
   STATE      connected
   TYPE       DbLog
   UTF8       1
   dbconn     mysql:database=fhem;host=localhost;port=3306
   dbuser     fhemuser
   eventCount 612
   HELPER:
     COLSET     1
     DEVICECOL  64
     EVENTCOL   512
     OLDSTATE   connected
     PACKAGE    main
     READINGCOL 64
     TC         current
     TH         history
     TYPECOL    64
     UNITCOL    32
     VALUECOL   128
     VERSION    5.11.0
   OLDREADINGS:
     2026-03-08 19:19:56   CacheOverflowLastNum 0
     2026-03-08 15:14:57   CacheOverflowLastState normal
     2026-03-08 19:20:07   CacheUsage      4
     2026-03-08 19:19:56   NextSync        2026-03-08 19:20:26 or when CacheUsage 500 is reached
     2026-03-08 19:20:07   notify_processing_time 0.0003
     2026-03-08 19:19:56   state           connected
   DbLogType  Current/History
   asyncMode  1
   room       LOG
   showNotifyTime 1
   verbose    2
eine Datenbank:
MariaDB [fhem]> SHOW GRANTS FOR 'fhemuser'@'localhost';
| Grants for fhemuser@localhost        |
| GRANT SELECT, INSERT, UPDATE, INDEX, CREATE VIEW, SHOW VIEW ON *.* TO `fhemuser`@`localhost` IDENTIFIED BY PASSWORD '*0A00846A5F41FFFFE0EAE0BFBF930679977C41F4' |
| GRANT SELECT, INSERT, UPDATE, DELETE, CREATE, DROP, INDEX, ALTER ON `fhem`.* TO `fhemuser`@`localhost`                                                          |
und ein device:
2026-03-08 19:23:36   I_AC-Power      0.28871
     2026-03-08 19:23:36   I_AC_Current    1.38
     2026-03-08 19:23:36   I_AC_Energy_WH  1374.734
     2026-03-08 19:23:36   I_DC_Power      0.2931
     2026-03-08 19:23:36   I_Status        On
     2026-03-08 19:23:36   I_Temp_SF       -2
     2026-03-08 19:23:36   I_Temp_Sink     39.06
     2026-03-08 19:23:36   M_AC_POWER      0.00
     2026-03-08 19:23:36   M_AC_POWER_FeedIn 0
     2026-03-08 19:23:36   M_AC_POWER_Purchased 0
     2026-03-08 19:23:36   M_Energy_W_SF   -3
     2026-03-08 19:23:36   M_Exported      186.17
     2026-03-08 19:23:36   M_Imported      951.46
     2026-03-08 19:23:36   NetzHaus        0.000
     2026-03-08 19:23:36   PV_DC           0.000
     2026-03-08 19:23:36   pvIn            0.000
     2026-03-08 19:23:36   pvOut           0.000
     2026-03-08 18:54:24   state           opened
der Event Monitor zeigt:
2026-03-08 19:28:21 ModbusAttr SE_10k PV_DC: 0.000
2026-03-08 19:28:21 ModbusAttr SE_10k BatNet: 0.360
2026-03-08 19:28:21 ModbusAttr SE_10k BatExport: 0.000
2026-03-08 19:28:21 ModbusAttr SE_10k BatHaus: 0.360
2026-03-08 19:28:21 ModbusAttr SE_10k PV_Export: 0.000
2026-03-08 19:28:21 ModbusAttr SE_10k PV_Haus: 0.005
2026-03-08 19:28:21 ModbusAttr SE_10k NetzHaus: 0.000
2026-03-08 19:28:21 DbLog csl_debian_DbLog notify_processing_time: 0.0021
2026-03-08 19:28:21 DbLog csl_debian_DbLog notify_processing_time: 0.0003
2026-03-08 19:30:34 ModbusAttr SE_10k WR_Effizienz: 0.985
2026-03-08 19:30:34 ModbusAttr SE_10k PV_DC: 0.000
2026-03-08 19:30:34 ModbusAttr SE_10k BatNet: 0.360
2026-03-08 19:31:31 ModbusAttr SE_10k PV_Haus: 0.000
2026-03-08 19:31:31 ModbusAttr SE_10k NetzHaus: 0.000
2026-03-08 19:31:32 DbLog csl_debian_DbLog notify_processing_time: 0.0018
2026-03-08 19:31:32 DbLog csl_debian_DbLog notify_processing_time: 0.0002
entgegen aller Erwartungen
ergibt SELECT TIMESTAMP, DEVICE, READING, VALUE FROM history ORDER BY TIMESTAMP DESC LIMIT 10;
| TIMESTAMP           | DEVICE              | READING          | VALUE     |
| 2026-03-08 18:38:35 | SE_10k              | state            | CONNECTED |
| 2026-03-08 14:58:00 | SE_10k              | vom_Dach         | 2.712     |
| 2026-03-08 14:58:00 | YieldDay_M_Imported | state            | 951.13    |
| 2026-03-08 14:58:00 | YieldDay_M_Exported | state            | 183.90    |
| 2026-03-08 14:58:00 | SE_10k              | pvOut            | 2.420     |
| 2026-03-08 14:58:00 | SE_10k              | etotal           | 646.419   |
| 2026-03-08 14:58:00 | SE_10k              | dc2ac            | 0.000     |
| 2026-03-08 14:58:00 | SE_10k              | ac2dc            | 0.000     |
| 2026-03-08 14:58:00 | SE_10k              | WR_Effizienz     | 0.985     |
| 2026-03-08 14:58:00 | SE_10k              | PV_Leistung-temp | 5.09      |
10 rows in set (0,001 sec)
Wenn man nun den timestamp betrachtet: es sind allesamt Einträge die _vor_ 2026-03-08 19:31:31 entstanden sind.
Diese Einträge kammen ausschließlich mit DbLog  DEF ./db.conf .*
Sobald ich einen Filter anlege (s.o.) werden:
1. Einmalig die Filterwerte in DB übertragen
2.danach gar keine events in DB geschrieben.
Weiß jemand einen Rat?
Martin
ergerd
FHEM auf RasPi 4, ZigBee, 1Wire2WLAN, DS2423, EMS-ESP, Button+, LaCrosseGateway, PCA301, ConBee III, LuftdatenInfo, OneWireGW, Div. ESPs u. Shellys
MartinD
betateilchen
Das bedeutet, dass DbLog auftretende events im Normalfall nicht sofort in die Datenbank schreibt, sondern diese "sammelt" und dann später wegschreibt. Dadurch werden die Datenbankzugriffe reduziert und die gesamte Performance des Loggings erhöht.
Erkannbar ist das z.B. in den von Dir geposteten readings:
Hier siehst Du, dass das nächste Schreiben in die Datenbank nach 30 Sekunden um 19:20:56 erfolgen wird.
Aber ich denke nicht, dass das etwas mit Deinem "Problem" zu tun hat.
Ehrlich gesagt, habe ich Dein Problem gestern beim Lesen schon nicht verstanden und ich verstehe es auch jetzt noch nicht ganz.
Wenn Du mit .* als regexp die gewünschten Werte ins Log bekommst und dann die regex ändert, wonach dann nix mehr gelogged wird, liegt die Vermutung nahe, dass Deine regex nicht wie gewünscht funktioniert.
Dann teste doch einfach mal Alternativen, z.B.:
DEF        ./db.conf .*PV_DC.*|.*pvIn.*
MartinD
Hallo betateilchen,
ja, es liegt nahe, dass regex nicht greift.
Ich habe es so gemeint:
REGEXP    .*:(PV_DC|pvIn).* --> alle devices:(in den folgende readings vorkommen) die Werte.
Nach Änderung
Zitat von: betateilchen am 09 März 2026, 14:04:19DEF        ./db.conf .*PV_DC.*|.*pvIn.*[/code]
bekomme ich weiter keine Einträge, auch nicht nach:
set csl_debian_DbLog commitCache
der CacheUsage  ist danach zwar "0" aber es wird nichts in die DB geschrieben.
Nach
setreading SE_10k PV_DC 9.99
müsste (und wird) ein event erzeugt, das in die Db rein müsste
DbLog vorbose 5 sagt dann:
2026.03.09 14:42:10 4: csl_debian_DbLog - ################################################################
2026.03.09 14:42:10 4: csl_debian_DbLog - ###              start of new Logcycle                       ###
2026.03.09 14:42:10 4: csl_debian_DbLog - number of events received: 1 of device: global
2026.03.09 14:42:10 4: csl_debian_DbLog - check Device: global , Event: ATTR csl_debian_DbLog verbose 5
2026.03.09 14:42:10 4: csl_debian_DbLog - number of events received: 1 of device: csl_debian_DbLog
2026.03.09 14:42:10 4: csl_debian_DbLog - check Device: csl_debian_DbLog , Event: notify_processing_time: 0.0018
2026.03.09 14:42:13 4: csl_debian_DbLog - ################################################################
2026.03.09 14:42:13 4: csl_debian_DbLog - ###              start of new Logcycle                       ###
2026.03.09 14:42:13 4: csl_debian_DbLog - number of events received: 30 of device: SE_10k
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: I_AC_Current: 11.38
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: I_AC-Power: 2.6963
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: I_AC_Energy_WH: 1392.633
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: I_DC_Power: 2.7374
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: I_Temp_Sink: 42.47
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: I_Temp_SF: -2
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: I_Status: On
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: BatIN_TOTAL_kWh: 978.10
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: BatOUT_TOTAL_kWh: 923.15
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: Leistungbezug_HM_Meter_kW: 0.00
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: Energiebezug_HM_Meter_kWh: 874.70
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: Leistung_FeedIN_HM_Meter_kW: 0.00
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: Energie_FeedIN_HM_Meter_kWh: 179.90
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: pvIn: 2.660
2026.03.09 14:42:13 5: csl_debian_DbLog - parsed Event: SE_10k , Event: pvIn: 2.660
2026.03.09 14:42:13 4: csl_debian_DbLog - added event - Timestamp: 2026-03-09 14:42:13, Device: SE_10k, Type: MODBUSATTR, Event: pvIn: 2.660, Reading: pvIn, Value: 2.660, Unit:
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: pvOut: 2.460
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: ac2dc: 0.000
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: etotal: 663.345
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: PV_Leistung-temp: 4.99
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: PV_Leistung: 4.99
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: Haus_Last_kW: 0.45
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: vom_Dach: 2.737
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: Hausverbrauch: 0.446
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: WR_Effizienz: 0.985
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: PV_DC: 2.737
2026.03.09 14:42:13 5: csl_debian_DbLog - parsed Event: SE_10k , Event: PV_DC: 2.737
2026.03.09 14:42:13 4: csl_debian_DbLog - added event - Timestamp: 2026-03-09 14:42:13, Device: SE_10k, Type: MODBUSATTR, Event: PV_DC: 2.737, Reading: PV_DC, Value: 2.737, Unit:
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: BatNet: 0.000
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: BatExport: 0.000
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: BatHaus: 0.000
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: PV_Export: 2.250
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: PV_Haus: 0.446
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: NetzHaus: 0.000
2026.03.09 14:42:13 4: csl_debian_DbLog - number of events received: 1 of device: csl_debian_DbLog
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: csl_debian_DbLog , Event: notify_processing_time: 0.0110
2026.03.09 14:42:13 4: csl_debian_DbLog - number of events received: 1 of device: YieldDay_M_Exported
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: YieldDay_M_Exported , Event: 196.46
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: csl_debian_DbLog , Event: notify_processing_time: 0.0016
2026.03.09 14:42:13 4: csl_debian_DbLog - number of events received: 1 of device: YieldDay_M_Imported
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: YieldDay_M_Imported , Event: 951.88
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: csl_debian_DbLog , Event: notify_processing_time: 0.0014
2026.03.09 14:42:13 4: csl_debian_DbLog - number of events received: 21 of device: SE_10k
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: M_AC_POWER: 2.42
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: M_Exported: 196.46
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: M_Imported: 951.88
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: M_Energy_W_SF: -3
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: M_AC_POWER_Purchased: 0
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: M_AC_POWER_FeedIn: 2.42
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: Haus_Last_kW: 0.28
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: Hausverbrauch: 0.276
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: PV_Export: 2.420
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: PV_Haus: 0.276
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: csl_debian_DbLog , Event: notify_processing_time: 0.0064
2026.03.09 14:42:13 4: csl_debian_DbLog - number of events received: 25 of device: SE_10k
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: B_Average_Temperature: 19.7
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: B_Instantaneous_Power: 0.00
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: B_Available_Energy: 9.53
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: B_State_of_Health: 99.0
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: B_State_of_Energy: 98.9
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: B_Status: TrickleCharge
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: BatIn: 0
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: BatOut: 0
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: B_State_of_Energy_in_kWh: 9.43
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: SE_10k , Event: dc2ac: 0.000
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: csl_debian_DbLog , Event: notify_processing_time: 0.0094
2026.03.09 14:42:13 4: csl_debian_DbLog - number of events received: 3 of device: NODERED_CSL
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: NODERED_CSL , Event: 1_1_Speicher-Leistung: 0
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: NODERED_CSL , Event: 1_1_time: 2026-03-09T13:42:13.505Z
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: NODERED_CSL , Event: 1_2_inverter: 1
2026.03.09 14:42:13 4: csl_debian_DbLog - check Device: csl_debian_DbLog , Event: notify_processing_time: 0.0017
2026.03.09 14:42:17 4: csl_debian_DbLog - ################################################################
2026.03.09 14:42:17 4: csl_debian_DbLog - ###              start of new Logcycle                       ###
2026.03.09 14:42:17 4: csl_debian_DbLog - number of events received: 15 of device: SE_10k
2026.03.09 14:42:17 4: csl_debian_DbLog - check Device: SE_10k , Event: PV_DC: 9.99
2026.03.09 14:42:17 5: csl_debian_DbLog - parsed Event: SE_10k , Event: PV_DC: 9.99
2026.03.09 14:42:17 4: csl_debian_DbLog - added event - Timestamp: 2026-03-09 14:42:17, Device: SE_10k, Type: MODBUSATTR, Event: PV_DC: 9.99, Reading: PV_DC, Value: 9.99, Unit:
2026.03.09 14:42:17 4: csl_debian_DbLog - check Device: SE_10k , Event: Leistungbezug_HM_Meter_kW: 0.00
2026.03.09 14:42:17 4: csl_debian_DbLog - check Device: SE_10k , Event: Energiebezug_HM_Meter_kWh: 874.70
2026.03.09 14:42:17 4: csl_debian_DbLog - check Device: SE_10k , Event: Leistung_FeedIN_HM_Meter_kW: 0.00
2026.03.09 14:42:17 4: csl_debian_DbLog - check Device: SE_10k , Event: Energie_FeedIN_HM_Meter_kWh: 179.90
2026.03.09 14:42:17 4: csl_debian_DbLog - check Device: SE_10k , Event: Haus_Last_kW: 0.28
2026.03.09 14:42:17 4: csl_debian_DbLog - check Device: SE_10k , Event: vom_Dach: 2.737
2026.03.09 14:42:17 4: csl_debian_DbLog - check Device: SE_10k , Event: Hausverbrauch: 0.276
2026.03.09 14:42:17 4: csl_debian_DbLog - check Device: SE_10k , Event: WR_Effizienz: 0.985
2026.03.09 14:42:17 4: csl_debian_DbLog - check Device: SE_10k , Event: BatNet: 0.000
2026.03.09 14:42:17 4: csl_debian_DbLog - check Device: SE_10k , Event: BatExport: 0.000
2026.03.09 14:42:17 4: csl_debian_DbLog - check Device: SE_10k , Event: BatHaus: 0.000
2026.03.09 14:42:17 4: csl_debian_DbLog - check Device: SE_10k , Event: PV_Export: 2.420
2026.03.09 14:42:17 4: csl_debian_DbLog - check Device: SE_10k , Event: PV_Haus: 0.276
2026.03.09 14:42:17 4: csl_debian_DbLog - check Device: SE_10k , Event: NetzHaus: 0.000
2026.03.09 14:42:17 4: csl_debian_DbLog - number of events received: 1 of device: csl_debian_DbLog
2026.03.09 14:42:17 4: csl_debian_DbLog - check Device: csl_debian_DbLog , Event: notify_processing_time: 0.0075
2026.03.09 14:42:27 4: csl_debian_DbLog - ################################################################
2026.03.09 14:42:27 4: csl_debian_DbLog - ###              start of new Logcycle                       ###
2026.03.09 14:42:27 4: csl_debian_DbLog - number of events received: 18 of device: SolCast_Debian
2026.03.09 14:42:27 4: csl_debian_DbLog - check Device: SolCast_Debian , Event: nextCycletime: 14:43:36
2026.03.09 14:42:27 4: csl_debian_DbLog - check Device: SolCast_Debian , Event: Current_PV: 9990 W
2026.03.09 14:42:27 4: csl_debian_DbLog - check Device: SolCast_Debian , Event: Today_Hour15_PVreal: 2101 Wh
2026.03.09 14:42:27 4: csl_debian_DbLog - check Device: SolCast_Debian , Event: Today_CONdeviation: -22.44 %
2026.03.09 14:42:27 4: csl_debian_DbLog - check Device: SolCast_Debian , Event: Current_GridFeedIn: 2420 W
2026.03.09 14:42:27 4: csl_debian_DbLog - check Device: SolCast_Debian , Event: Current_Consumption: 7570 W
2026.03.09 14:42:27 4: csl_debian_DbLog - check Device: SolCast_Debian , Event: Current_SelfConsumption: 7570 W
2026.03.09 14:42:27 4: csl_debian_DbLog - check Device: SolCast_Debian , Event: Current_SelfConsumptionRate: 76 %
2026.03.09 14:42:27 4: csl_debian_DbLog - check Device: SolCast_Debian , Event: Current_Surplus: 2420 W
2026.03.09 14:42:27 4: csl_debian_DbLog - check Device: SolCast_Debian , Event: NextHours_Sum01_PVforecast: 2517 Wh
2026.03.09 14:42:27 4: csl_debian_DbLog - check Device: SolCast_Debian , Event: NextHours_Sum02_PVforecast: 4091 Wh
2026.03.09 14:42:27 4: csl_debian_DbLog - check Device: SolCast_Debian , Event: NextHours_Sum03_PVforecast: 5042 Wh
2026.03.09 14:42:27 4: csl_debian_DbLog - check Device: SolCast_Debian , Event: NextHours_Sum04_PVforecast: 5314 Wh
2026.03.09 14:42:27 4: csl_debian_DbLog - check Device: SolCast_Debian , Event: RestOfDayPVforecast: 5330 Wh
2026.03.09 14:42:27 4: csl_debian_DbLog - check Device: SolCast_Debian , Event: Today_CONreal: 8220 Wh
2026.03.09 14:42:27 4: csl_debian_DbLog - check Device: SolCast_Debian , Event: Today_PVreal: 16355 Wh
2026.03.09 14:42:27 4: csl_debian_DbLog - check Device: SolCast_Debian , Event: NextHours_Sum04_ConsumptionForecast: 1903 Wh
2026.03.09 14:42:27 4: csl_debian_DbLog - check Device: SolCast_Debian , Event: RestOfDayConsumptionForecast: 6227 Wh
2026.03.09 14:42:27 4: csl_debian_DbLog - number of events received: 1 of device: csl_debian_DbLog
2026.03.09 14:42:27 4: csl_debian_DbLog - check Device: csl_debian_DbLog , Event: notify_processing_time: 0.0044
2026.03.09 14:42:27 4: csl_debian_DbLog - ###      New database processing cycle - SBP asynchronous    ###
2026.03.09 14:42:27 4: csl_debian_DbLog - MemCache contains 5 entries to process
2026.03.09 14:42:27 4: csl_debian_DbLog - DbLogType is: Current/History
2026.03.09 14:42:27 4: csl_debian_DbLog - check Device: csl_debian_DbLog , Event: CacheOverflowLastNum: 0
2026.03.09 14:42:27 5: csl_debian_DbLog - MemCache contains:  201 -> 2026-03-09 14:42:13|SE_10k|MODBUSATTR|pvIn: 2.660|pvIn|2.660|
2026.03.09 14:42:27 5: csl_debian_DbLog - MemCache contains:  202 -> 2026-03-09 14:42:13|SE_10k|MODBUSATTR|PV_DC: 2.737|PV_DC|2.737|
2026.03.09 14:42:27 5: csl_debian_DbLog - MemCache contains:  203 -> 2026-03-09 14:42:13|SE_10k|MODBUSATTR|PV_DC: 2.737|PV_DC|2.737|
2026.03.09 14:42:27 5: csl_debian_DbLog - MemCache contains:  204 -> 2026-03-09 14:42:13|SE_10k|MODBUSATTR|PV_DC: 2.737|PV_DC|2.737|
2026.03.09 14:42:27 5: csl_debian_DbLog - MemCache contains:  205 -> 2026-03-09 14:42:17|SE_10k|MODBUSATTR|PV_DC: 9.99|PV_DC|9.99|
2026.03.09 14:42:27 4: csl_debian_DbLog - Operation: log_asynch
2026.03.09 14:42:27 5: csl_debian_DbLog - DbLogType: Current/History
2026.03.09 14:42:27 4: csl_debian_DbLog - AutoCommit: ON, Transaction: ON
2026.03.09 14:42:27 4: csl_debian_DbLog - Insert mode: Array
2026.03.09 14:42:27 4: csl_debian_DbLog - Primary Key used in history: DEVICE,READING
2026.03.09 14:42:27 4: csl_debian_DbLog - Primary Key used in current: DEVICE,READING
2026.03.09 14:42:27 5: csl_debian_DbLog - processing 201 -> TS: 2026-03-09 14:42:13, Dev: SE_10k, Type: MODBUSATTR, Event: pvIn: 2.660, Reading: pvIn, Val: 2.660, Unit:
2026.03.09 14:42:27 5: csl_debian_DbLog - processing 202 -> TS: 2026-03-09 14:42:13, Dev: SE_10k, Type: MODBUSATTR, Event: PV_DC: 2.737, Reading: PV_DC, Val: 2.737, Unit:
2026.03.09 14:42:27 5: csl_debian_DbLog - processing 203 -> TS: 2026-03-09 14:42:13, Dev: SE_10k, Type: MODBUSATTR, Event: PV_DC: 2.737, Reading: PV_DC, Val: 2.737, Unit:
2026.03.09 14:42:27 5: csl_debian_DbLog - processing 204 -> TS: 2026-03-09 14:42:13, Dev: SE_10k, Type: MODBUSATTR, Event: PV_DC: 2.737, Reading: PV_DC, Val: 2.737, Unit:
2026.03.09 14:42:27 5: csl_debian_DbLog - processing 205 -> TS: 2026-03-09 14:42:17, Dev: SE_10k, Type: MODBUSATTR, Event: PV_DC: 9.99, Reading: PV_DC, Val: 9.99, Unit:
2026.03.09 14:42:27 4: csl_debian_DbLog - begin Transaction
2026.03.09 14:42:27 4: csl_debian_DbLog - 5 of 5 events inserted into table history using PK on columns DEVICE,READING
2026.03.09 14:42:27 4: csl_debian_DbLog - commit inserted data table >history<
2026.03.09 14:42:27 4: csl_debian_DbLog - 5 of 5 events updated in table current using PK on columns DEVICE,READING
2026.03.09 14:42:27 4: csl_debian_DbLog - commit inserted data table >current<
2026.03.09 14:42:28 4: csl_debian_DbLog - ################################################################
2026.03.09 14:42:28 4: csl_debian_DbLog - ###              start of new Logcycle                       ###
2026.03.09 14:42:28 4: csl_debian_DbLog - number of events received: 1 of device: SolCast_Debian
2026.03.09 14:42:28 4: csl_debian_DbLog - check Device: SolCast_Debian , Event: state: updated
2026.03.09 14:42:28 4: csl_debian_DbLog - number of events received: 1 of device: csl_debian_DbLog
2026.03.09 14:42:28 4: csl_debian_DbLog - check Device: csl_debian_DbLog , Event: notify_processing_time: 0.0019
und in der Db keine Spur vom    SE_10k PV_DC 9.99
Etwas ratlos
Martin
betateilchen
Zeig doch mal bitte ein vollständiges list von dem device, das Du gerne loggen möchtest.
MartinD
Danke für deine Zeit!
list SE_10k:
   DEF        1 19 192.168.2.40 TCP
   DeviceName 192.168.2.40:502
   EXPECT     idle
   FD         16
   FUUID      69a041c3-f33f-3e5d-aa24-15098763127d2b28
   IODev      SE_10k
   Interval   19
   LASTOPEN   1773034548.98278
   MODBUSID   1
   MODE       master
   MODULEVERSION Modbus 5.0.1 - 7.12.2025
   NAME       SE_10k
   NOTIFYDEV  global
   NR         59
   NTFY_ORDER 50-SE_10k
   PARTIAL
   PROTOCOL   TCP
   STATE      vom Dach:0.583 kW, zum Speicher: 0 kW, ins Netz: 0.320 kW, ins Haus: 0.254 kW, vom Speicher: 0 kW, im Speicher ist noch: 9.43 kWh
   TCPConn    1
   TYPE       ModbusAttr
   devioLoglevel 3
   devioNoSTATE 1
   eventCount 12479
   nextOpenDelay 60
   DICACHE:
     3:
       UNPACK
       EXPRS:
       EXTRAS:
       FNAMES:
   Helper:
     DBLOG:
       B_Available_Energy:
         csl_debian_DbLog:
           TIME       1772993969.49062
           VALUE      9.53
         csl_debian_DbLog:
           VALUE      19.3
         csl_debian_DbLog:
           VALUE      -0.37
       B_State_of_Energy:
         csl_debian_DbLog:
           VALUE      92.6
         csl_debian_DbLog:
           VALUE      8.82
       B_State_of_Health:
         csl_debian_DbLog:
           VALUE      99.0
       B_Status:
         csl_debian_DbLog:
           VALUE      Discharge
       BatExport:
         csl_debian_DbLog:
           VALUE      0.010
       BatHaus:
         csl_debian_DbLog:
           VALUE      0.360
       BatIN_TOTAL_kWh:
         csl_debian_DbLog:
           TIME       1772993969.1459
           VALUE      971.86
       BatIn:
         csl_debian_DbLog:
           VALUE      0
       BatNet:
         csl_debian_DbLog:
           VALUE      0.370
       BatOUT_TOTAL_kWh:
         csl_debian_DbLog:
           VALUE      917.53
       BatOut:
         csl_debian_DbLog:
           VALUE      0.37
         csl_debian_DbLog:
           VALUE      169.70
         csl_debian_DbLog:
           VALUE      874.20
       Haus_Last_kW:
         csl_debian_DbLog:
           VALUE      0.29
       Hausverbrauch:
         csl_debian_DbLog:
           VALUE      0.288
       I_AC-Power:
         csl_debian_DbLog:
           VALUE      0.29793
       I_AC_Current:
         csl_debian_DbLog:
           VALUE      1.43
       I_AC_Energy_WH:
         csl_debian_DbLog:
           VALUE      1374.713
       I_DC_Power:
         csl_debian_DbLog:
           VALUE      0.3024
       I_Status:
         csl_debian_DbLog:
           VALUE      On
       I_Temp_SF:
         csl_debian_DbLog:
           VALUE      -2
       I_Temp_Sink:
         csl_debian_DbLog:
           VALUE      39
         csl_debian_DbLog:
           VALUE      0.00
         csl_debian_DbLog:
           VALUE      0.00
       M_AC_POWER:
         csl_debian_DbLog:
           TIME       1772993969.36704
           VALUE      0.01
       M_AC_POWER_FeedIn:
         csl_debian_DbLog:
           VALUE      0.01
         csl_debian_DbLog:
           VALUE      0
       M_Energy_W_SF:
         csl_debian_DbLog:
           VALUE      -3
       M_Exported:
         csl_debian_DbLog:
           VALUE      186.17
       M_Imported:
         csl_debian_DbLog:
           VALUE      951.46
       NetzHaus:
         csl_debian_DbLog:
           VALUE      0.000
       PV_DC:
         csl_debian_DbLog:
           TIME       1773071775.31023
           VALUE      0.583
       PV_Export:
         csl_debian_DbLog:
           VALUE      0.000
       PV_Haus:
         csl_debian_DbLog:
           VALUE      0.004
       PV_Leistung:
         csl_debian_DbLog:
           VALUE      0
       PV_Leistung-temp:
         csl_debian_DbLog:
           VALUE      0.02
       WR_Effizienz:
         csl_debian_DbLog:
           VALUE      0.985
       ac2dc:
         csl_debian_DbLog:
           VALUE      0.000
       dc2ac:
         csl_debian_DbLog:
           VALUE      0.292
       etotal:
         csl_debian_DbLog:
           VALUE      649.864
       pvIn:
         csl_debian_DbLog:
           TIME       1773071775.02316
           VALUE      0.485
       pvOut:
         csl_debian_DbLog:
           VALUE      0.000
       state:
         csl_debian_DbLog:
           TIME       1772992464.90796
           VALUE      CONNECTED
       vom_Dach:
         csl_debian_DbLog:
           VALUE      -0.068
   OICACHE:
   QUEUE:
   READ:
     BUFFER
     2026-03-09 16:56:15   B_Available_Energy 9.53
     2026-03-09 16:56:15   B_Average_Temperature 19.2
     2026-03-09 16:56:15   B_Instantaneous_Power 0.00
     2026-03-09 16:56:15   B_State_of_Energy 98.9
     2026-03-09 16:56:15   B_State_of_Energy_in_kWh 9.43
     2026-03-09 16:56:15   B_State_of_Health 99.0
     2026-03-09 16:56:15   B_Status        TrickleCharge
     2026-03-09 16:56:15   BatExport       0.000
     2026-03-09 16:56:15   BatHaus         0.000
     2026-03-09 16:56:15   BatIN_TOTAL_kWh 978.10
     2026-03-09 16:56:15   BatIn           0
     2026-03-09 16:56:15   BatNet          0.000
     2026-03-09 16:56:15   BatOUT_TOTAL_kWh 923.16
     2026-03-09 16:56:15   BatOut          0
     2026-03-09 16:56:15   Energie_FeedIN_HM_Meter_kWh 182.70
     2026-03-09 16:56:15   Energiebezug_HM_Meter_kWh 874.70
     2026-03-09 16:56:15   Haus_Last_kW    0.25
     2026-03-09 16:56:15   Hausverbrauch   0.254
     2026-03-09 16:56:15   I_AC-Power      0.5743
     2026-03-09 16:56:15   I_AC_Current    2.53
     2026-03-09 16:56:15   I_AC_Energy_WH  1396.35
     2026-03-09 16:56:15   I_DC_Power      0.5831
     2026-03-09 16:56:15   I_Status        On
     2026-03-09 16:56:15   I_Temp_SF       -2
     2026-03-09 16:56:15   I_Temp_Sink     40.56
     2026-03-09 16:56:15   Leistung_FeedIN_HM_Meter_kW 0.00
     2026-03-09 16:56:15   Leistungbezug_HM_Meter_kW 0.00
     2026-03-09 16:56:15   M_AC_POWER      0.32
     2026-03-09 16:56:15   M_AC_POWER_FeedIn 0.32
     2026-03-09 16:56:15   M_AC_POWER_Purchased 0
     2026-03-09 16:56:15   M_Energy_W_SF   -3
     2026-03-09 16:56:15   M_Exported      199.30
     2026-03-09 16:56:15   M_Imported      951.88
     2026-03-09 16:56:15   NetzHaus        0.000
     2026-03-09 16:56:15   PV_DC           0.583
     2026-03-09 16:56:15   PV_Export       0.320
     2026-03-09 16:56:15   PV_Haus         0.254
     2026-03-09 16:56:15   PV_Leistung     0.90
     2026-03-09 16:56:15   PV_Leistung-temp 0.90
     2026-03-09 16:56:15   WR_Effizienz    0.985
     2026-03-09 16:56:15   ac2dc           0.000
     2026-03-09 16:56:15   dc2ac           0.000
     2026-03-09 16:56:15   etotal          667.054
     2026-03-09 16:56:15   pvIn            0.485
     2026-03-09 16:56:15   pvOut           0.350
     2026-03-09 06:35:48   state           opened
     2026-03-09 16:56:15   vom_Dach        0.583
   REMEMBER:
     lid        1
     lname      SE_10k
     lrecv      1773071775.29285
     lsend      1773071775.2368
   UPDATECACHE:
     h40071:
       adr        40071
       combine    h40071 len 5 I_AC_Current with h40083 len 2 I_AC-Power and h40093 len 3 I_AC_Energy_WH and h40100 len 2 I_DC_Power and h40103 len 1 I_Temp_Sink and h40106 len 1 I_Temp_SF and h40107 len 1 I_Status
       len        5
       objCombi   h40071
       reading    I_AC_Current
       span       37
       type       h
     h40206:
       adr        40206
       combine    h40206 len 5 M_AC_POWER with h40226 len 2 M_Exported and h40234 len 2 M_Imported and h40242 len 1 M_Energy_W_SF
       len        5
       objCombi   h40206
       reading    M_AC_POWER
       span       37
       type       h
     h62828:
       adr        62828
       combine    h62828 len 2 B_Average_Temperature with h62836 len 2 B_Instantaneous_Power and h62848 len 2 B_Available_Energy and h62850 len 2 B_State_of_Health and h62852 len 2 B_State_of_Energy and h62854 len 2 B_Status
       len        2
       objCombi   h62828
       reading    B_Average_Temperature
       span       28
       type       h
   defptr:
     SE_10k     1
   gotReadings:
   hmccu:
   lastRead:
     h40071     1773071775.00384
     h40083     1773071775.00444
     h40093     1773071775.00492
     h40100     1773071775.00534
     h40103     1773071775.00585
     h40106     1773071775.00597
     h40107     1773071775.00632
     h40206     1773071775.15331
     h40226     1773071775.15394
     h40234     1773071775.15451
     h40242     1773071775.15459
     h62828     1773071775.303
     h62836     1773071775.30338
     h62848     1773071775.30363
     h62850     1773071775.30374
     h62852     1773071775.30385
     h62854     1773071775.30403
   dev-h-combine 105
   dev-h-defPoll 1
   dev-h-defShowGet 1
   enableControlSet 1
   icon       measure_power@green
   maxTimeoutsToReconnect 3
   obj-h40071-expr ($val[0] * (10 ** $val[4]))
   obj-h40071-len 5
   obj-h40071-reading I_AC_Current
   obj-h40071-unpack s>s>s>s>s>
   obj-h40083-expr ($val * (10 ** $val[1]))/1000
   obj-h40083-len 2
   obj-h40083-reading I_AC-Power
   obj-h40083-unpack s>s>
   obj-h40093-expr $val * (10 ** $val[1])/1000
   obj-h40093-len 3
   obj-h40093-reading I_AC_Energy_WH
   obj-h40093-unpack l>s>
   obj-h40100-expr $val * (10 ** $val[1])/1000
   obj-h40100-len 2
   obj-h40100-reading I_DC_Power
   obj-h40100-unpack s>s>
   obj-h40103-expr $val * (10 ** ReadingsNum ($name ,'I_Temp_SF',0))
   obj-h40103-len 1
   obj-h40103-reading I_Temp_Sink
   obj-h40103-unpack s>
   obj-h40106-reading I_Temp_SF
   obj-h40106-unpack s>
   obj-h40107-map 1:Off, 2:Sleeping, 3:Starting, 4:On, 5:Throttled, 6:ShuttingDown, 7:Fault, 8:Maintenance
   obj-h40107-reading I_Status
   obj-h40206-expr ($val[0] * (10 ** $val[4]))/1000
   obj-h40206-format %.2f
   obj-h40206-len 5
   obj-h40206-reading M_AC_POWER
   obj-h40206-unpack s>s>s>s>s>
   obj-h40226-expr $val * (10 ** ReadingsNum ($name ,'M_Energy_W_SF',0))/1000
   obj-h40226-format %.2f
   obj-h40226-len 2
   obj-h40226-reading M_Exported
   obj-h40226-unpack N
   obj-h40234-expr $val * (10 ** ReadingsNum ($name ,'M_Energy_W_SF',0))/1000
   obj-h40234-format %.2f
   obj-h40234-len 2
   obj-h40234-reading M_Imported
   obj-h40234-unpack N
   obj-h40242-reading M_Energy_W_SF
   obj-h40242-unpack s>
   obj-h62828-format %.1f
   obj-h62828-len 2
   obj-h62828-reading B_Average_Temperature
   obj-h62828-revRegs 1
   obj-h62828-unpack f>
   obj-h62836-expr $val / 1000
   obj-h62836-format %.2f
   obj-h62836-len 2
   obj-h62836-reading B_Instantaneous_Power
   obj-h62836-revRegs 1
   obj-h62836-unpack f>
   obj-h62848-expr $val / 1000
   obj-h62848-format %.2f
   obj-h62848-len 2
   obj-h62848-reading B_Available_Energy
   obj-h62848-revRegs 1
   obj-h62848-unpack f>
   obj-h62850-format %.1f
   obj-h62850-len 2
   obj-h62850-reading B_State_of_Health
   obj-h62850-revRegs 1
   obj-h62850-unpack f>
   obj-h62852-format %.1f
   obj-h62852-len 2
   obj-h62852-reading B_State_of_Energy
   obj-h62852-revRegs 1
   obj-h62852-unpack f>
   obj-h62854-len 2
   obj-h62854-map 0:Off, 1:Standby, 2:Init, 3:Charge, 4:Discharge, 5:Fault, 6:TrickleCharge,7:Idle, 10: PowerSaving
   obj-h62854-reading B_Status
   room       Solar
   stateFormat vom Dach:PV_DC kW, zum Speicher: BatIn kW, ins Netz: PV_Export kW, ins Haus: PV_Haus kW, vom Speicher: BatOut kW, im Speicher ist noch: B_State_of_Energy_in_kWh kWh
   userReadings BatIn:B_Instantaneous_Power.* {
                   my $pwr = ReadingsNum ($name, 'B_Instantaneous_Power', 0);
                   $pwr    = $pwr > 0 ? $pwr : 0;
                   $pwr;
BatOut:B_Instantaneous_Power.* {
                   $pwr    = $pwr < 0 ? abs $pwr : 0;
                  $pwr;
B_State_of_Energy_in_kWh:B_State_of_Energy.* {
sprintf("%.2f", ReadingsNum ($name,'B_State_of_Energy',0)*(ReadingsNum ($name,'B_Available_Energy',0)/100))
BatIN_TOTAL_kWh:I_AC-Power.* {
           my $batIN = ReadingsNum ('MD_SolarEdge','storage-7B083F14-lifeTimeEnergyCharged',0)/1000;
           my $result =0;
           $result= $batIN;
        return sprintf("%.2f",$batIN);
BatOUT_TOTAL_kWh:I_AC-Power.* {
           my $batOUT = ReadingsNum ('MD_SolarEdge','storage-7B083F14-lifeTimeEnergyDischarged',0)/1000;
           my $result =0;
        $result= $batOUT;
        return sprintf("%.2f",$batOUT);
M_AC_POWER_Purchased:M_AC_POWER.* {
                 my $pwr = ReadingsNum ($name, 'M_AC_POWER', 0);
                  return $pwr;
M_AC_POWER_FeedIn:M_AC_POWER.* {
                   return $pwr;
Leistungbezug_HM_Meter_kW {
           my $power = ReadingsNum ('Energiemessung_Smart_Bezug','Leistung_Verbrauch',0)/1000;
           my $result = 0;
       $result = $power;
   return sprintf("%.2f", $result);
Energiebezug_HM_Meter_kWh {
           my $energie = ReadingsNum ('Energiemessung_Smart_Bezug','IEC_ENERGY_COUNTER',0);
           my $result = 0;
       $result = $energie;
Leistung_FeedIN_HM_Meter_kW {
          my $power = ReadingsNum ('Energiemessung_Smart_Einspeisung','Leistung_Einspeisung',0)/1000;
          my $result = 0;
     $result = $power;
Energie_FeedIN_HM_Meter_kWh {
       my $energie = ReadingsNum ('Energiemessung_Smart_Einspeisung','IEC_ENERGY_COUNTER',0);
       my $result = 0;
    $result = $energie;
pvIn:I_DC_Power.* {
    my $capacity = 10;
    my $wr_self  = 0.12;
    my $dc       = ReadingsNum($name,"I_DC_Power",0);
    my $house    = ReadingsNum($name,"Haus_Last_kW",0);
    my $gridin   = ReadingsNum($name,"M_AC_POWER_Purchased",0);
    my $gridout  = ReadingsNum($name,"M_AC_POWER_FeedIn",0);
    my $batout   = ReadingsNum($name,"BatOut",0);
    my $bat_eta = 0.79;
    my $bat_ac  = $batout * $bat_eta;
    my $pv_ac = $house - $gridin + $gridout - $bat_ac;
    $pv_ac = 0 if $pv_ac < 0;
    $pv_ac -= $wr_self if $pv_ac > $wr_self;
    my $pv_dc = $pv_ac / 0.97;
    # Clipping
    $pv_dc = $capacity if $pv_dc > $capacity;
    # Nachtfilter
    $pv_dc = 0 if $pv_dc < 0.08;
    return sprintf("%.3f",$pv_dc);
pvOut:I_DC_Power.* {
    my $wr_self = 0.12;
    my $pvin  = ReadingsNum($name,"pvIn",0);
    my $batin = ReadingsNum($name,"BatIn",0);
    my $pv_to_ac = $pvin - $batin;
    $pv_to_ac = 0 if $pv_to_ac < 0;
    my $pv_ac = ($pv_to_ac * 0.97) - $wr_self;
    return sprintf("%.3f",$pv_ac);
dc2ac:BatOut.* {
    # Wirkungsgradbereich
    my $eta = 0.79;
    my $ac = $batout * $eta;
    $ac = 0 if $ac < 0.05;
    return sprintf("%.3f",$ac);
ac2dc:I_AC-Power.* {
    # Batterie lädt direkt DC von PV
    # daher kein AC->DC
    return sprintf("%.3f",0);
etotal:I_AC_Energy_WH.* {
    my $ac_total  = ReadingsNum($name,"I_AC_Energy_WH",0);
    my $bat_total = ReadingsNum($name,"BatOUT_TOTAL_kWh",0);
    my $bat_ac = $bat_total * 0.79;
    my $pv_total = $ac_total - $bat_ac;
    $pv_total = 0 if $pv_total < 0;
    return sprintf("%.3f",$pv_total);
PV_Leistung-temp:I_DC_Power.* {
my $i_dc_power = ReadingsNum ($name, 'I_DC_Power', 0);
my $bat_power = ReadingsNum ($name, 'BatIn', 0);
my $bat_out = ReadingsNum ($name, 'BatOut', 0);
my $i_ac_feedin = ReadingsNum ($name, 'M_AC_POWER_FeedIn', 0);
my $pow_faktor = 0.79;
my $result = 0;
     $result = $i_dc_power + $bat_power + $i_ac_feedin - ($bat_out * $pow_faktor) ;
   if ($result < 0) {
      $result = 0;
PV_Leistung:PV_Leistung-temp.* {
          my $pwr = ReadingsNum ($name, 'PV_Leistung-temp', 0);
        if (ReadingsVal ('Tag_Nacht', 'state', '0') ne "Tag"){
            $pwr = 0;
          elsif ($pwr < 0.01){
            $pwr = 0;
                  return $pwr;
Haus_Last_kW:.* {
       my $inv_ac = ReadingsNum ($name, 'I_AC-Power', 0);
       my $feedin_ac = ReadingsNum ($name,'M_AC_POWER_FeedIn',0);
       my $result = 0;
    $result = $inv_ac - $feedin_ac;
vom_Dach:.* {
my $dc=ReadingsNum("SE_10k","I_DC_Power",0);
my $bin=ReadingsNum("SE_10k","BatIn",0);
my $bout=ReadingsNum("SE_10k","BatOut",0);
sprintf("%.3f",$dc-$bout+$bin)
Hausverbrauch:.* {
my $ac=ReadingsNum($name,'I_AC-Power',0);
my $buy=ReadingsNum($name,'M_AC_POWER_Purchased',0);
my $sell=ReadingsNum($name,'M_AC_POWER_FeedIn',0);
sprintf("%.3f",$ac+$buy-$sell)
WR_Effizienz:.* {
my $ac=ReadingsNum("SE_10k","I_AC-Power",0);
return 0 if $dc==0;
sprintf("%.3f",$ac/$dc)
PV_DC:.*  {
my $dc=ReadingsNum($name,'I_DC_Power',0);
my $bin=ReadingsNum($name,'BatIn',0);
my $bout=ReadingsNum($name,'BatOut',0);
my $result = $dc-$bout+$bin;
$result = $result > 0.08 ? $result : 0;
sprintf("%.3f",$result)
BatNet:.* {
  my $out = ReadingsNum($name,'BatOut',0);
  my $in  = ReadingsNum($name,'BatIn',0);
  my $net = $out - $in;
  $net = 0 if $net < 0;
  sprintf("%.3f",$net)
BatExport:.* {
my $feed=ReadingsNum($name,'M_AC_POWER_FeedIn',0);
my $exp=($bout<$feed)?$bout:$feed;
sprintf("%.3f",$exp)
BatHaus:.* {
sprintf("%.3f",$bout-$exp)
PV_Export:.* {
sprintf("%.3f",$feed-$exp)
PV_Haus:.* {
my $eta=0.79;
my $haus=$ac+$buy-$sell;
my $batExport = ($bout<$sell)?$bout:$sell;
my $batHaus = ($bout-$batExport)*$eta;
my $pv=$haus-$batHaus-$buy;
$pv=0 if $pv<0;
sprintf("%.3f",$pv)
NetzHaus:.* {
sprintf("%.3f",$buy)
Ich möchte _nu_ PV_DC und pvIn logen.
Martin
