HM-SEC-SCO nach Exclude neu anlernen nicht möglich
Begonnen von DeeSPe, 14 März 2026, 20:46:55
DeeSPe
Mit aesKey 1 ist er jetzt umgesprungen:
   CFGFN
   DEF        56ABA8
   FUUID      69b8299e-f33f-dd73-2b11-e514108bf717be9e
   HMWIFI2_MSGCNT 31
   HMWIFI2_RAWMSG 0500001BC2844156ABA80000000107C8
   HMWIFI2_RSSI -27
   HMWIFI2_TIME 2026-03-16 17:17:47
   IODev      HMWIFI2
   LASTInputDev HMWIFI2
   MSGCNT     31
   NAME       HM_56ABA8
   NR         132
   NTFY_ORDER 48-HM_56ABA8
   STATE      open
   TYPE       CUL_HM
   chanNo     01
   disableNotifyFn 1
   eventCount 46
   lastMsg    No:C2 - t:41 s:56ABA8 d:000000 0107C8
   protCmdDel 13
   protEvt_AESCom-ok 5 last_at:2026-03-16 17:17:08
   protLastRcv 2026-03-16 17:17:47
   protNack   1 last_at:2026-03-16 17:17:35
   protRcv    22 last_at:2026-03-16 17:17:47
   protResnd  3 last_at:2026-03-16 17:16:52
   protResndFail 1 last_at:2026-03-16 17:17:14
   protSnd    11 last_at:2026-03-16 17:17:34
   protState  CMDs_done_Errors:1
   rssi_at_HMWIFI2 cnt:27 min:-42 max:-22 avg:-29.03 lst:-27
   .attraggr:
   .attrminint:
     2026-03-16 17:17:30   .D-devInfo      810101
     2026-03-16 17:17:30   .D-stc          80
     2026-03-16 17:17:34   .R-cyclicInfoMsg on
     2026-03-16 17:17:34   .R-pairCentral  0x000000
     2026-03-16 17:17:34   .R-sabotageMsg  on
     2026-03-16 17:17:34   .R-transmDevTryMax 6
     2026-03-16 17:02:43   .associatedWith HM_56ABA8,HM_56ABA8
     2026-03-16 17:17:47   .protLastRcv    20260316171747
     2026-03-16 17:17:35   CommandAccepted no
     2026-03-16 17:17:30   D-firmware      1.0
     2026-03-16 17:17:30   D-serialNr      OEQ0221624
     2026-03-16 17:17:30   IODev           HMWIFI2
     2026-03-16 17:17:34   PairedTo        set_0x4F62FF
     2026-03-16 17:17:34   RegL_00.         00:00 02:00 09:01 0A:00 0B:00 0C:00 10:01 14:06
     2026-03-16 17:17:08   aesCommToDev    ok
     2026-03-16 17:17:08   aesKeyNbr       00
     2026-03-16 17:17:47   battery         ok
     2026-03-16 17:17:23   cfgState        updating
     2026-03-16 17:17:35   commState       CMDs_done_Errors:1
     2026-03-16 17:17:47   contact         open (to broadcast)
     2026-03-16 17:17:47   state           open
     2026-03-16 17:17:47   trigger_cnt     7
     RegL_01.:
       VAL
   helper:
     HM_CMDNR   194
     PONtest    1
     cSnd       014F62FF56ABA800040000000000,014F62FF56ABA801040000000001
     cfgStateUpdt 1
     getCfgList all
     getCfgListNo ,4
     lastMsgTm  1773677867.21597
     mId        00C7
     peerFriend peerAct,peerVirt
     peerOpt    4:threeStateSensor
     regLst     0,1,4p
     rxType     28
     supp_Pair_Rep 0
     cmds:
       TmplKey    :no:1773676963.85461
       TmplTs     1773676963.85461
       cmdKey     1:1:0::HM_56ABA8:00C7:01:
       cmdLst:
         assignHmKey noArg
         clear      [({msgErrors}|msgEvents|rssi|attack|trigger|register|oldRegs|readings|all)]
         deviceRename -newName-
         fwUpdate   -filename- [-bootTime-]
         getConfig  noArg
         getDevInfo noArg
         getRegRaw  (List0|List1|List2|List3|List4|List5|List6|List7) [-peerChn-]
         peerBulk   -peer1,peer2,...- [({set}|unset)]
         peerChan   -btnNumber- -actChn- [({single})] [({set}|unset)] [actor|remote|both]
         raw        -data- [...]
         regBulk    -list-.-peerChn- -addr1:data1- [-addr2:data2-]...
         regSet     [(prep|{exec})] -regName- -value- [-peerChn-]
         reset      noArg
         sign       [(on|{off})]
         tplDel     -tplDel-
         tplSet_0   -tplChan-
         trgEventL  -peer- -condition-
         trgEventS  -peer- -condition-
         trgPressL  [(-peer-|{all})]
         trgPressS  [(-peer-|{all})]
         unpair     noArg
       lst:
         condition  closed,open,tilted
         peer
         peerOpt
         tplChan
         tplDel
         tplPeer
       rtrvLst:
         cmdList    [({short}|long)]
         deviceInfo [({short}|long)]
         list       [({normal}|full)]
         param      -param-
         reg        -addr- -list- [-peerChn-]
         regList    noArg
         regTable   noArg
         regVal     -addr- -list- [-peerChn-]
         saveConfig [-filename-]
         tplInfo    noArg
     expert:
       def        0
       det        0
       raw        1
       tpl        0
     io:
       flgs       0
       newChn     +56ABA8,00,01,00
       nextSend   1773677854.69177
       rxt        2
       vccu       VCCU
       p:
         56ABA8
         00
         01
         00
       prefIO:
     mRssi:
       mNo        C2
       io:
         HMWIFI2:
           -19
           -19
     peerIDsH:
     prt:
       bErr       0
       sProc      0
       tryMsg:
     q:
       qReqConf
       qReqStat
     regCollect:
     role:
       chn        1
       dev        1
     rssi:
       at_HMWIFI2:
         avg        -29.037037037037
         cnt        27
         lst        -27
         max        -22
         min        -42
     shadowReg:
     shadowRegChn:
       RegL_00.   00
     tmpl:
   .mId       00C7
   IOgrp      VCCU:HMWIFI2
   aesKey     1
   autoReadReg 4_reqStatus
   expert     rawReg
   firmware   1.0
   model      HM-SEC-SCO
   room       CUL_HM
   serialNr   OEQ0221624
   subType    threeStateSensor
LED bestätigt weiterhin mit rotem Leuchten.
Dan
noansi
Und er hat etwas Register gelesen
2026-03-16 17:17:34   RegL_00.         00:00 02:00 09:01 0A:00 0B:00 0C:00 10:01 14:062026-03-16 17:17:34   .R-pairCentral  0x000000damit derzeit nicht gepairt.
Aber möglerweise hat er noch key 1 gesetzt. Das
2026-03-16 16:51:17   aesKeyNbr       02von vorhin ist merkwürdig.
Versuch nochmal mit hmPairForSec und Knöpfchen zu pairen.
DeeSPe
Zitat von: noansi am 16 März 2026, 17:36:47Versuch nochmal mit hmPairForSec und Knöpfchen zu pairen.
Gemacht und wieder rote LED zur Bestätigung.
Noch einmal getConfig und wieder rote LED:
   CFGFN
   DEF        56ABA8
   HMWIFI2_MSGCNT 81
   HMWIFI2_RAWMSG 050000123F840056ABA80000001000C74F45513032323136323480810101
   HMWIFI2_RSSI -18
   HMWIFI2_TIME 2026-03-16 18:22:01
   IODev      HMWIFI2
   MSGCNT     81
   NAME       HM_56ABA8
   NR         132
   STATE      Nack
   TYPE       CUL_HM
   chanNo     01
   disableNotifyFn 1
   eventCount 118
   lastMsg    No:3F - t:00 s:56ABA8 d:000000 1000C74F45513032323136323480810101
   protCmdDel 27
   protEvt_AESCom-ok 10 last_at:2026-03-16 18:21:05
   protLastRcv 2026-03-16 18:22:01
   protNack   3 last_at:2026-03-16 18:21:51
   protRcv    62 last_at:2026-03-16 18:22:01
   protResnd  11 last_at:2026-03-16 18:21:32
   protResndFail 3 last_at:2026-03-16 18:21:08
   protSnd    28 last_at:2026-03-16 18:21:50
   rssi_at_HMWIFI2 cnt:72 min:-42 max:-17 avg:-25.63 lst:-18
   .attraggr:
   .attrminint:
     2026-03-16 18:22:01   .D-devInfo      810101
     2026-03-16 18:22:01   .D-stc          80
     2026-03-16 18:21:50   .R-pairCentral  0x000000
     2026-03-16 18:20:17   .associatedWith HM_56ABA8,HM_56ABA8
     2026-03-16 18:22:01   .protLastRcv    20260316182201
     2026-03-16 18:21:51   CommandAccepted no
     2026-03-16 18:22:01   D-firmware      1.0
     2026-03-16 18:22:01   D-serialNr      OEQ0221624
     2026-03-16 18:21:50   IODev           HMWIFI2
     2026-03-16 18:21:50   PairedTo        set_0x4F62FF
     2026-03-16 18:21:50   RegL_00.         00:00 02:00 09:01 0A:00 0B:00 0C:00 10:01 14:06
     2026-03-16 18:21:05   aesCommToDev    ok
     2026-03-16 18:21:05   aesKeyNbr       00
     2026-03-16 17:53:08   alive           yes
     2026-03-16 17:53:08   battery         ok
     2026-03-16 18:22:50   cfgState        PairMism,PeerIncom,RegMiss
     2026-03-16 18:21:51   commState       CMDs_done_Errors:1
     2026-03-16 17:53:08   contact         open (to broadcast)
     2026-03-16 17:53:08   powerOn         2026-03-16 17:53:08
     2026-03-16 17:53:08   recentStateType info
     2026-03-16 17:53:08   sabotageError   on
     2026-03-16 18:21:51   state           Nack
     2026-03-16 17:35:10   trigger_cnt     19
     RegL_01.:
       VAL
   helper:
     HM_CMDNR   102
     PONtest    0
     cfgStateUpdt 0
     getCfgList all
     getCfgListNo ,4
     lastMsgTm  1773681721.02661
     mId        00C7
     regLst     0,1,4p
     rxType     28
     supp_Pair_Rep 1
     cfgChk:
       idPc02     paired:0x000000 IO attr: 4F62FF.
       idPz00     fail
       idRc01     RegL_01.
     cmds:
       TmplKey    :no:1773681617.49133
       TmplTs     1773681617.49133
       cmdLst:
         assignHmKey noArg
         getConfig  noArg
         getDevInfo noArg
         raw        -data- [...]
         reset      noArg
         sign       [(on|{off})]
         tplDel     -tplDel-
         tplSet_0   -tplChan-
         unpair     noArg
       lst:
         peer
         peerOpt
         tplChan
         tplDel
         tplPeer
       rtrvLst:
         param      -param-
         regList    noArg
         regTable   noArg
         tplInfo    noArg
     expert:
       def        0
       det        0
       raw        1
       tpl        0
     io:
       flgs       0
       nextSend   1773681711.13974
       rxt        2
       vccu       VCCU
       p:
         56ABA8
         00
         01
         00
       prefIO:
     mRssi:
       mNo        3F
       io:
         HMWIFI2:
           -10
           -10
     peerIDsH:
     prt:
       bErr       0
       sProc      0
       tryMsg:
     q:
       qReqConf
       qReqStat
     regCollect:
     role:
       chn        1
       dev        1
     rssi:
       at_HMWIFI2:
         avg        -25.6388888888889
         cnt        72
         lst        -18
         max        -17
         min        -42
     shadowReg:
     shadowRegChn:
       RegL_00.   00
     tmpl:
   .mId       00C7
   IOgrp      VCCU:HMWIFI2
   aesKey     1
   expert     rawReg
   firmware   1.0
   model      HM-SEC-SCO
   room       CUL_HM
   serialNr   OEQ0221624
Dan
noansi
Hallo Dan,
STATE      Nacketwas mag er nicht.
Versuch nochmal clear msgEvents, aesKey 0 und pairing mit hmPairForSec 600 und Knöpfchen.
Du kannst auch mal die Kommunikation mit logIDs 56ABA8 in der VCCU mitloggen.
Gruß, Ansgar.
DeeSPe
Danke für deine Hilfe Ansgar, aber leider wieder nur rotes Leuchten.
Hier mal das Log, daraus kann ich persönlich leider gar nichts erkennen.
2026.03.16 19:08:49 3: CUL_HM set HM_56ABA8 clear msgEvents
2026.03.16 19:10:29 0: HMUARTLGW HMWIFI2 send: 01 0656ABA8000000
2026.03.16 19:10:29 0: HMUARTLGW HMWIFI2 added peer: 56ABA8, aesChannels: FFFFFFFFFFFFFFFF
2026.03.16 19:10:47 3: CUL_HM set VCCU hmPairForSec 600
2026.03.16 19:10:52 3: saved ./backup/fhem.cfg.2026-03-16_19:10:52
2026.03.16 19:10:52 3: saved ./backup/fhem.state.2026-03-16_19:10:52
2026.03.16 19:10:58 0: HMUARTLGW HMWIFI2 recv: 01 05 00 00 13 msg: 41 84 00 56ABA8 000000 1000C74F45513032323136323480810101
2026.03.16 19:10:58 4: CUL_HM received config CCU:VCCU device: HM_56ABA8. PairForSec: on PairSerial:
2026.03.16 19:10:58 3: CUL_HM pair: HM_56ABA8 threeStateSensor, model HM-SEC-SCO serialNr OEQ0221624
2026.03.16 19:10:58 0: HMUARTLGW HMWIFI2 send: 01 0656ABA8000100
2026.03.16 19:10:58 3: CUL_HM set HM_56ABA8 getConfig noArg
2026.03.16 19:10:58 0: HMUARTLGW HMWIFI2 added peer: 56ABA8, aesChannels: FFFFFFFFFFFFFFFF
2026.03.16 19:11:01 1: HMUARTLGW HMWIFI2 did not respond for the 1. time, resending
2026.03.16 19:11:02 0: HMUARTLGW HMWIFI2 added peer: 56ABA8, aesChannels: FFFFFFFFFFFFFFFF
2026.03.16 19:11:02 0: HMUARTLGW HMWIFI2 send: 01 02 00 00 00 msg: 69 A0 01 4F62FF 56ABA8 00050000000000
2026.03.16 19:11:12 0: HMUARTLGW HMWIFI2 send: 01 02 00 00 00 msg: 69 A0 01 4F62FF 56ABA8 00050000000000
2026.03.16 19:11:12 0: HMUARTLGW HMWIFI2 recv: 01 04 0C 00 12 msg: 69 80 02 56ABA8 4F62FF 00ADF7287D
2026.03.16 19:11:12 0: HMUARTLGW HMWIFI2 send: 01 02 00 00 00 msg: 6A A0 01 4F62FF 56ABA8 00050000000000
2026.03.16 19:11:22 0: HMUARTLGW HMWIFI2 send: 01 02 00 00 00 msg: 6A A0 01 4F62FF 56ABA8 00050000000000
2026.03.16 19:11:23 0: HMUARTLGW HMWIFI2 send: 01 0656ABA8000100
2026.03.16 19:11:26 1: HMUARTLGW HMWIFI2 did not respond for the 1. time, resending
2026.03.16 19:11:26 0: HMUARTLGW HMWIFI2 added peer: 56ABA8, aesChannels: FFFFFFFFFFFFFFFF
2026.03.16 19:11:26 0: HMUARTLGW HMWIFI2 send: 01 0656ABA8000100
2026.03.16 19:11:28 0: HMUARTLGW HMWIFI2 recv: 01 05 00 00 12 msg: 6A 84 00 56ABA8 000000 1000C74F45513032323136323480810101
2026.03.16 19:11:28 4: CUL_HM received config CCU:VCCU device: HM_56ABA8. PairForSec: off PairSerial:
2026.03.16 19:11:29 1: HMUARTLGW HMWIFI2 did not respond for the 1. time, resending
2026.03.16 19:11:30 0: HMUARTLGW HMWIFI2 added peer: 56ABA8, aesChannels: FFFFFFFFFFFFFFFF
2026.03.16 19:11:30 0: HMUARTLGW HMWIFI2 send: 01 0656ABA8000100
2026.03.16 19:11:33 1: HMUARTLGW HMWIFI2 did not respond for the 1. time, resending
2026.03.16 19:11:33 0: HMUARTLGW HMWIFI2 added peer: 56ABA8, aesChannels: FFFFFFFFFFFFFFFF
2026.03.16 19:11:33 0: HMUARTLGW HMWIFI2 send: 01 0656ABA8000100
2026.03.16 19:11:36 1: HMUARTLGW HMWIFI2 did not respond for the 1. time, resending
2026.03.16 19:11:36 0: HMUARTLGW HMWIFI2 added peer: 56ABA8, aesChannels: FFFFFFFFFFFFFFFF
2026.03.16 19:11:36 0: HMUARTLGW HMWIFI2 send: 01 0656ABA8000100
2026.03.16 19:11:39 1: HMUARTLGW HMWIFI2 did not respond for the 1. time, resending
2026.03.16 19:11:40 0: HMUARTLGW HMWIFI2 added peer: 56ABA8, aesChannels: FFFFFFFFFFFFFFFF
2026.03.16 19:11:40 0: HMUARTLGW HMWIFI2 send: 01 0656ABA8000100
2026.03.16 19:11:40 0: HMUARTLGW HMWIFI2 recv: 01 05 00 00 13 msg: 6B 84 00 56ABA8 000000 1000C74F45513032323136323480810101
2026.03.16 19:11:43 1: HMUARTLGW HMWIFI2 did not respond for the 1. time, resending
2026.03.16 19:11:43 0: HMUARTLGW HMWIFI2 added peer: 56ABA8, aesChannels: FFFFFFFFFFFFFFFF
2026.03.16 19:11:43 0: HMUARTLGW HMWIFI2 send: 01 0656ABA8000100
2026.03.16 19:11:43 0: HMUARTLGW HMWIFI2 send: 01 02 00 00 00 msg: 92 A0 01 4F62FF 56ABA8 00050000000000
2026.03.16 19:11:53 0: HMUARTLGW HMWIFI2 send: 01 02 00 00 00 msg: 92 A0 01 4F62FF 56ABA8 00050000000000
2026.03.16 19:11:54 0: HMUARTLGW HMWIFI2 recv: 01 04 0C 00 13 msg: 92 80 02 56ABA8 4F62FF 000173F613
2026.03.16 19:11:54 0: HMUARTLGW HMWIFI2 send: 01 02 00 00 00 msg: 93 A0 01 4F62FF 56ABA8 00050000000000
2026.03.16 19:11:58 3: HMinfo hminfo get:configCheck :-f,^(HM_56ABA8|HM_56ABA8)$
2026.03.16 19:12:04 0: HMUARTLGW HMWIFI2 send: 01 02 00 00 00 msg: 93 A0 01 4F62FF 56ABA8 00050000000000
2026.03.16 19:12:15 3: CUL_HM set HM_56ABA8 clear msgEvents
2026.03.16 19:12:15 0: HMUARTLGW HMWIFI2 send: 01 0656ABA8000000
2026.03.16 19:12:15 0: HMUARTLGW HMWIFI2 added peer: 56ABA8, aesChannels: FFFFFFFFFFFFFFFF
2026.03.16 19:12:29 3: CUL_HM set VCCU hmPairForSec 600
2026.03.16 19:12:43 3: saved ./backup/fhem.cfg.2026-03-16_19:12:43
2026.03.16 19:12:43 3: saved ./backup/fhem.state.2026-03-16_19:12:43
2026.03.16 19:12:53 0: HMUARTLGW HMWIFI2 recv: 01 05 00 00 12 msg: 93 84 00 56ABA8 000000 1000C74F45513032323136323480810101
2026.03.16 19:12:53 4: CUL_HM received config CCU:VCCU device: HM_56ABA8. PairForSec: on PairSerial:
2026.03.16 19:12:53 3: CUL_HM pair: HM_56ABA8 threeStateSensor, model HM-SEC-SCO serialNr OEQ0221624
2026.03.16 19:12:53 0: HMUARTLGW HMWIFI2 send: 01 0656ABA8000100
2026.03.16 19:12:53 3: CUL_HM set HM_56ABA8 getConfig noArg
2026.03.16 19:12:54 0: HMUARTLGW HMWIFI2 added peer: 56ABA8, aesChannels: FFFFFFFFFFFFFFFF
2026.03.16 19:12:54 0: HMUARTLGW HMWIFI2 send: 01 0656ABA8000100
2026.03.16 19:12:57 1: HMUARTLGW HMWIFI2 did not respond for the 1. time, resending
2026.03.16 19:12:57 0: HMUARTLGW HMWIFI2 added peer: 56ABA8, aesChannels: FFFFFFFFFFFFFFFF
2026.03.16 19:12:57 0: HMUARTLGW HMWIFI2 send: 01 0656ABA8000100
2026.03.16 19:13:00 1: HMUARTLGW HMWIFI2 did not respond for the 1. time, resending
2026.03.16 19:13:00 0: HMUARTLGW HMWIFI2 added peer: 56ABA8, aesChannels: FFFFFFFFFFFFFFFF
2026.03.16 19:13:00 0: HMUARTLGW HMWIFI2 send: 01 0656ABA8000100
2026.03.16 19:13:03 1: HMUARTLGW HMWIFI2 did not respond for the 1. time, resending
2026.03.16 19:13:03 0: HMUARTLGW HMWIFI2 added peer: 56ABA8, aesChannels: FFFFFFFFFFFFFFFF
2026.03.16 19:13:03 0: HMUARTLGW HMWIFI2 send: 01 0656ABA8000100
2026.03.16 19:13:06 1: HMUARTLGW HMWIFI2 did not respond for the 1. time, resending
2026.03.16 19:13:07 0: HMUARTLGW HMWIFI2 added peer: 56ABA8, aesChannels: FFFFFFFFFFFFFFFF
2026.03.16 19:13:07 0: HMUARTLGW HMWIFI2 send: 01 0656ABA8000100
2026.03.16 19:13:10 1: HMUARTLGW HMWIFI2 did not respond for the 1. time, resending
2026.03.16 19:13:10 0: HMUARTLGW HMWIFI2 added peer: 56ABA8, aesChannels: FFFFFFFFFFFFFFFF
2026.03.16 19:13:10 0: HMUARTLGW HMWIFI2 send: 01 02 00 00 00 msg: BB A0 01 4F62FF 56ABA8 00050000000000
2026.03.16 19:13:20 0: HMUARTLGW HMWIFI2 send: 01 02 00 00 00 msg: BB A0 01 4F62FF 56ABA8 00050000000000
2026.03.16 19:13:43 3: CUL_HM set HM_56ABA8 getConfig noArg
2026.03.16 19:13:47 0: HMUARTLGW HMWIFI2 recv: 01 05 00 00 13 msg: 94 84 00 56ABA8 000000 1000C74F45513032323136323480810101
2026.03.16 19:14:05 0: HMUARTLGW HMWIFI2 recv: 01 05 00 00 13 msg: 95 84 00 56ABA8 000000 1000C74F45513032323136323480810101
2026.03.16 19:14:05 4: CUL_HM received config CCU:VCCU device: HM_56ABA8. PairForSec: off PairSerial:
2026.03.16 19:14:05 0: HMUARTLGW HMWIFI2 send: 01 02 00 00 00 msg: BD A0 01 4F62FF 56ABA8 00050000000000
2026.03.16 19:14:06 0: HMUARTLGW HMWIFI2 recv: 01 04 0C 00 13 msg: BD 80 02 56ABA8 4F62FF 003C658A68
2026.03.16 19:14:06 0: HMUARTLGW HMWIFI2 send: 01 02 00 00 00 msg: BE A0 01 4F62FF 56ABA8 000802010A4F0B620CFF
2026.03.16 19:14:06 0: HMUARTLGW HMWIFI2 recv: 01 04 0C 00 13 msg: BE 80 02 56ABA8 4F62FF 00E78AFBEA
2026.03.16 19:14:06 0: HMUARTLGW HMWIFI2 send: 01 02 00 00 00 msg: BF A0 01 4F62FF 56ABA8 0006
2026.03.16 19:14:16 0: HMUARTLGW HMWIFI2 send: 01 02 00 00 00 msg: BF A0 01 4F62FF 56ABA8 0006
2026.03.16 19:14:17 0: HMUARTLGW HMWIFI2 send: 01 0656ABA8000100
2026.03.16 19:14:19 0: HMUARTLGW HMWIFI2 recv: 01 05 00 00 14 msg: BF 84 00 56ABA8 000000 1000C74F45513032323136323480810101
2026.03.16 19:14:19 4: CUL_HM received config CCU:VCCU device: HM_56ABA8. PairForSec: off PairSerial:
2026.03.16 19:14:20 1: HMUARTLGW HMWIFI2 did not respond for the 1. time, resending
2026.03.16 19:14:21 0: HMUARTLGW HMWIFI2 added peer: 56ABA8, aesChannels: FFFFFFFFFFFFFFFF
2026.03.16 19:14:21 0: HMUARTLGW HMWIFI2 send: 01 0656ABA8000100
2026.03.16 19:14:21 0: HMUARTLGW HMWIFI2 send: 01 02 00 00 00 msg: E7 A0 01 4F62FF 56ABA8 00050000000000
2026.03.16 19:14:31 0: HMUARTLGW HMWIFI2 send: 01 02 00 00 00 msg: E7 A0 01 4F62FF 56ABA8 00050000000000
2026.03.16 19:14:31 0: HMUARTLGW HMWIFI2 recv: 01 04 0C 00 13 msg: E7 80 02 56ABA8 4F62FF 009934B9DE
2026.03.16 19:14:31 0: HMUARTLGW HMWIFI2 send: 01 02 00 00 00 msg: E8 A0 01 4F62FF 56ABA8 00050000000000
2026.03.16 19:14:41 0: HMUARTLGW HMWIFI2 send: 01 02 00 00 00 msg: E8 A0 01 4F62FF 56ABA8 00050000000000
2026.03.16 19:14:42 0: HMUARTLGW HMWIFI2 send: 01 0656ABA8000100
2026.03.16 19:14:45 1: HMUARTLGW HMWIFI2 did not respond for the 1. time, resending
2026.03.16 19:14:46 0: HMUARTLGW HMWIFI2 added peer: 56ABA8, aesChannels: FFFFFFFFFFFFFFFF
2026.03.16 19:14:46 0: HMUARTLGW HMWIFI2 send: 01 0656ABA8000100
2026.03.16 19:14:49 1: HMUARTLGW HMWIFI2 did not respond for the 1. time, resending
2026.03.16 19:14:49 0: HMUARTLGW HMWIFI2 added peer: 56ABA8, aesChannels: FFFFFFFFFFFFFFFF
2026.03.16 19:14:49 0: HMUARTLGW HMWIFI2 send: 01 0656ABA8000000
2026.03.16 19:14:52 1: HMUARTLGW HMWIFI2 did not respond for the 1. time, resending
2026.03.16 19:14:52 0: HMUARTLGW HMWIFI2 added peer: 56ABA8, aesChannels: FFFFFFFFFFFFFFFF
2026.03.16 19:14:52 0: HMUARTLGW HMWIFI2 send: 01 0656ABA8000000
2026.03.16 19:14:53 3: HMinfo hminfo get:configCheck :-f,^(HM_56ABA8|HM_56ABA8)$
2026.03.16 19:14:55 1: HMUARTLGW HMWIFI2 did not respond for the 1. time, resending
2026.03.16 19:14:55 0: HMUARTLGW HMWIFI2 added peer: 56ABA8, aesChannels: FFFFFFFFFFFFFFFF
2026.03.16 19:16:24 0: HMUARTLGW HMWIFI2 recv: 01 05 00 00 14 msg: E8 84 00 56ABA8 000000 1000C74F45513032323136323480810101
2026.03.16 19:16:24 4: CUL_HM received config CCU:VCCU device: HM_56ABA8. PairForSec: off PairSerial:
2026.03.16 19:16:56 3: CUL_HM set HM_56ABA8 getConfig noArg
2026.03.16 19:16:56 0: HMUARTLGW HMWIFI2 send: 01 0656ABA8000100
2026.03.16 19:16:56 0: HMUARTLGW HMWIFI2 added peer: 56ABA8, aesChannels: FFFFFFFFFFFFFFFF
2026.03.16 19:17:00 0: HMUARTLGW HMWIFI2 recv: 01 05 00 00 14 msg: E9 84 00 56ABA8 000000 1000C74F45513032323136323480810101
2026.03.16 19:17:41 0: HMUARTLGW HMWIFI2 recv: 01 05 00 00 21 msg: EA 84 00 56ABA8 000000 1000C74F45513032323136323480810101
2026.03.16 19:17:41 4: CUL_HM received config CCU:VCCU device: HM_56ABA8. PairForSec: off PairSerial:
2026.03.16 19:17:41 0: HMUARTLGW HMWIFI2 send: 01 02 00 00 00 msg: 12 A0 01 4F62FF 56ABA8 00040000000000
2026.03.16 19:17:42 0: HMUARTLGW HMWIFI2 recv: 01 05 01 00 23 msg: 12 A0 10 56ABA8 4F62FF 02020009010A000B000C00100114060000
2026.03.16 19:17:42 0: HMUARTLGW HMWIFI2 send: 01 02 00 00 00 msg: 22 A0 01 4F62FF 56ABA8 01040000000001
2026.03.16 19:17:42 0: HMUARTLGW HMWIFI2 recv: 01 04 03 00 23 msg: 22 80 02 56ABA8 4F62FF 80
2026.03.16 19:17:42 0: HMUARTLGW HMWIFI2 send: 01 0656ABA8000000
2026.03.16 19:17:42 0: HMUARTLGW HMWIFI2 added peer: 56ABA8, aesChannels: FFFFFFFFFFFFFFFF
2026.03.16 19:17:45 1: HMUARTLGW HMWIFI2 did not respond for the 1. time, resending
2026.03.16 19:17:46 0: HMUARTLGW HMWIFI2 added peer: 56ABA8, aesChannels: FFFFFFFFFFFFFFFF
2026.03.16 19:17:52 0: HMUARTLGW HMWIFI2 recv: 01 05 00 00 17 msg: 23 84 41 56ABA8 000000 011400
2026.03.16 19:17:53 0: HMUARTLGW HMWIFI2 recv: 01 05 00 00 1A msg: 24 84 41 56ABA8 000000 0115C8
2026.03.16 19:17:59 0: HMUARTLGW HMWIFI2 recv: 01 05 00 00 19 msg: 25 84 41 56ABA8 000000 011600
2026.03.16 19:18:00 0: HMUARTLGW HMWIFI2 recv: 01 05 00 00 19 msg: 26 84 41 56ABA8 000000 0117C8
2026.03.16 19:19:13 0: HMUARTLGW HMWIFI2 recv: 01 05 00 00 17 msg: 27 84 41 56ABA8 000000 011800
2026.03.16 19:20:27 0: HMUARTLGW HMWIFI2 recv: 01 05 00 00 1B msg: 28 84 41 56ABA8 000000 0119C8
Dan
