Alexa Verbindung fehlerhaft nach Neuinstallation Trixie 64Bit
Begonnen von Burny4600, 25 März 2026, 13:18:53
Burny4600
Ich habe den Pi5 neu mit Trixie installiert.
Nun habe ich aber Verbindungsproblem mit Alexa Geräte.
Amazon ACCOUNT läuft
alexaFHEM.ProxyConnection
error; Reverse Proxy replied with neither registered nor unregistered status: out:  err:/etc/ssh/ssh_config line 55: Bad key types 'ssh-rsa,ssh-dss'.
/etc/ssh/ssh_config line 56: Bad key types 'ssh-rsa,ssh-dss'.
/etc/ssh/ssh_config: terminating, 2 bad configuration options
list ALEXA
   CFGFN      /media/hdd/fhem/mycfg/alexa/alexa_rasp01.cfg
   FD         34
   FUUID      67801573-f33f-f4d2-f362-f4e19f2f72f9d3ed
   FVERSION   39_alexa.pm:0.238200/2021-02-24
   LAST_START 2026-03-25 12:39:50
   LAST_STOP  2026-03-25 12:39:50
   NAME       ALEXA
   NOTIFYDEV  global,global:npmjs.*alexa-fhem.*
   NR         937
   NTFY_ORDER 50-ALEXA
   PARTIAL
   PID        140517
   STARTS     70
   STATE      running /usr/bin/alexa-fhem
   TYPE       alexa
   active     0
   alexa-fhem version 0.5.65
   currentlogfile /media/hdd/fhem/log01/alexa/alexa-2026-03-25.log
   eventCount 145
   logfile    %L/alexa/alexa-%Y-%m-%d.log
   CoProcess:
     cmdFn      alexa_getCMD
     name       alexaFHEM
     state      running /usr/bin/alexa-fhem
     2026-03-25 12:39:50   alexaFHEM       running /usr/bin/alexa-fhem
     2026-03-25 12:39:56   alexaFHEM.ProxyConnection error; Reverse Proxy replied with neither registered nor unregistered status: out:  err:/etc/ssh/ssh_config line 55: Bad key types 'ssh-rsa,ssh-dss'.
     2026-01-19 08:20:58   alexaFHEM.bearerToken crypt:0a5d035f570670017358267306060601
     2026-01-19 08:20:58   alexaFHEM.skillRegKey crypt:0a500655230e05771d525703740574005607045375070e060c1f0b5d510055537756775f227102050753
   helper:
   alexaFHEM-auth crypt:710c460f120d76400552530c0209
   alexaFHEM-config ./alexa-fhem.cfg
   alexaFHEM-log %L/alexa/alexa-%Y-%m-%d.log
   alexaMapping #Characteristic=<name>=<value>,...
On=verb=schalte,valueOn=an;ein,valueOff=aus,valueToggle=um
Brightness=verb=stelle,property=helligkeit,valuePrefix=auf,values=AMAZON.NUMBER,valueSuffix=prozent
Hue=verb=stelle,valuePrefix=auf,values=rot:0;grün:128;blau:200
Hue=verb=färbe,values=rot:0;grün:120;blau:220
Saturation=verb=stelle,property=sättigung,valuePrefix=auf,values=AMAZON.NUMBER
Saturation=verb=sättige,values=AMAZON.NUMBER
TargetPosition=verb=mach,articles=den;die,values=auf:0;zu:100
TargetPosition=verb=stelle,valuePrefix=auf,values=AMAZON.NUMBER,valueSuffix=prozent
TargetTemperature=verb=stelle,valuePrefix=auf,values=AMAZON.NUMBER,valueSuffix=grad
Volume:verb=stelle,valuePrefix=auf,values=AMAZON.NUMBER,valueSuffix=prozent
Weckzeit=verb=stelle,valuePrefix=auf;für,values=AMAZON.TIME,valueSuffix=uhr
   alexaProactiveEvents 1
   alexaRoom  EG_Stiegenhaus,OG1_Schlafzimmer,OG1_Wohnzimmer
   alexaTypes #Type=<alias>[,<alias2>[,...]]
blind=jalousie,jalousien,rolladen,rolläden,rollo,rollos
light=aquariumlicht,beleuchtung,blumenlampe,globus,kastenlicht,licht,lampe,lampen,leselicht,stehlampe,vitrinenlicht
outlet=brunnen,luftbefeuchter,steckdose
switch=ventilator,raumlicht
thermometer=
thermostat=
   alias      Alexa
   articles   der,die,das,den
   comment    Neue Geräte an Alexa übergaben:
get Amazon.Account devices
set ALEXA restart
ALEXA, suche smarte Geräte
   devStateIcon stopped:control_home@red:start stopping:control_on_off@orange running.*:control_on_off@0CFB0C:stop
   devStateStyle style="text-align:left;;font-weight:bold;;"
   echoRooms  #<deviceId>=<room>   entspricht der Seriennummer auf der Amazon Geräteübersicht des Echo Gerätes
GN42ML05425201LT=OG1_Schlafzimmer
G071R20721550LPE=OG1_Wohnzimmer
G8M2DB05419602J3=OG2_Buero1
   fhemIntents #IntentName=<sample utterance>
gutenMorgen=guten morgen
guteNacht=gute nacht
   group      Alexa Verteilung
   icon       alexa2@cyan
   persons    #<personId>=<name>
   prepositions in,im,in der
   room       _AMAZON
   sortby     01.02
   stateFormat alexaFHEM
Ich finde aber nicht heraus wie ich diesen Fehler beheben kann.
Liegt das nun an Trixie 64Bit?
LG Chris
Raspberry Pi 2-5 => Jessie, Bullseye, Bookworm, Trixie
Schnittstellen: 1-Wire, FHEM2FEHEM, HM-MOD-UART, LAN, Modbus, MQTT, nanoCUL, RFXtrx433E, SIGNALduino, ser2net
Devices: APC, Eastron, FS20, IT, Homematic, MQTT, PV-(DEYE, EPEVER, FRONIUS), Resol-VBUS, S.USV, TEK603, WMR200, YouLess
MadMax-FHEM
#1
Ja, liegt an Trixie (nicht 64Bit).
Zu neue Verschlüsselung, wie es in der Fehlermeldung ja auch heißt ;)
Schon mal danach gesucht?
Sollte was zu finden sein...
Bin grad nur am Handy, daher schwer mit Suchen und so...
EDIT: https://forum.fhem.de/index.php?topic=142996.msg1351424#msg1351424
Ob man das nun "systemweit" ändern/anpassen sollte? Es gibt auch weitere "Anleitungen", die das auf Alexa einschränken (so meine ich)...
EDIT: warum in diesem Unterforum und nicht da?
Zitat von: help AlexaModule: 39_alexa.pm Maintainer: justme1968 Forum: Frontends/Sprachsteuerung
Gruß, Joachim
FHEM PI3 Buster (Test)
Burny4600
#2
Zitat von: MadMax-FHEM am 25 März 2026, 21:08:43EDIT: https://forum.fhem.de/index.php?topic=142996.msg1351424#msg1351424
Zielführend war die Änderung in der /etc/ssh/ssh_config.
Der ursprüngliche Eintrag
HostKeyAlgorithms ssh-rsa,ssh-dss
PubkeyAcceptedKeyTypes ssh-rsa,ssh-dss
darf nicht mehr verwendet werden und muss durch
HostKeyAlgorithms +ssh-rsa
PubkeyAcceptedKeyTypes +ssh-rsa
ersetzt werden.
Trotzdem bekomme ich keine Verbindung mit dem FHEM Connector.
Ich habe nun auch noch unter den Amazon Alexa ioBroker Definitionen alles gelöscht um vom Anfang alles zu definieren, nur wird die FHEM-Skill Konfiguration nicht gestartet. Ich bekomme zwar mit dem get ALEXA proxyKey einen neuen Key, aber nach dem aktiviertem vom FHEM Connector öffnet sich kein Browser-Tab.
Hat jemand dazu schon Erfahrungen über den korrekten Ablauf der Konfiguration unter Trixie ?
LG Chris
Burny4600
#3
Ich komme mit der Konfiguration für ALEXA nicht weiter. Ich schaffe es nicht eine Verbindung aufzubauen.
Verzeichnisse die Lese/Schreibrechte haben werden unter FHEM mit
alexaFHEM.ProxyConnection           error; user homedir writable by group/other ('chmod 755 /home/fhem' required)Fehler angeben.
Es gibt so viele Alexa Konfiguration.
Ich habe die Konfiguration nach dieser Anleitung durchgeführt.
https://wiki.fhem.de/wiki/FHEM_Connector_f%C3%BCr_Amazon_Alexa
Hat jemand etwas aktuelles, was auch unter Trixie funktioniert?
LG Chris
MadMax-FHEM
#4
Was kommt denn bei:
ls -la /home/fhem
Wie hast du fhem installiert?
Weil "Standard" ist /opt/fhem und nicht /home/fhem
Wenn du alexa-fhem wie im Wiki beschrieben installiert hast, wird eine Standard alexa-fhem Config angelegt.
Zu sehen unter Edit Files.
Wenn alexa-fhem und fhem auf demselben Rechner und "Standard" (also user fhem und fhem in /opt/fhem) installiert sind sollte die passen.
Gruß, Joachim
Burny4600
Das ganze unter Trixie mit Alexa/Fhem weist viele Rechteprobleme auf, die aber nicht nachvollziehbar sind.
Siehe Anhang.
Warum ist ein Zugriff möglich obwohl die Alexa unter FHEM ständig irgendwelche Dateien, Verzeichnisse, usw. nicht findet.
Es wird wohl das Beste sein alles wieder rückgängig auf Bookworm zu installieren.
LG Chris
MadMax-FHEM
#6
Sorry: Schreibkorrektur... :\
Zwischen "Minus" und "la" gehört kein Leerzeichen...
...hab's korrigiert.
Gruß, Joachim
MadMax-FHEM
Trotzdem bleiben Fragen unbeantwortet:
Weil: /home/fhem vs. /opt/fhem
Wie alexa-fhem?
Laut Connector Wiki?
(weil im anderen Thread die Frage nach tar.gz)
Gruß,Joachim
Burny4600
Hast du mich gemeint?
Alles zurück um Start und nach wiki FHEM_Connector installiert.
Morgen werde ich nochmals zur Sicherheit einen Neuanfang mit dem Pi machen.
Ich bin mir nur noch nicht sicher ob ich es nochmals mit Trixie probiere. Da gab es viele Änderungen die nicht dokumentiert waren.
GPIO Änderungen nochmals gegenüber Bookworm, Berechtigungen, Schnittstellen. Das ist nur das worüber ich mit Trixie gestolpert bin.
Darum mein Frage ob jemand mit Trixie und Alexa ein fehlerfrei Lösung dokumentiert hat, nach der man vorgehen kann.
Im WEB sind so viele Alexa Wikis wo nicht das aktuellste daraus erkennbar ist. Möglicherweise habe ich durch die diversen Test schon so einen Mist auf dieser Trixie Umgebung, dass nur eine Neuinstallation sinnvoll ist.
LG Chris
MadMax-FHEM
#9
Ja, war "für dich" gemeint.
Is ja sonst niemand hier ;)
Mein ls -la war "verkehrt" wegen Schreibkorrektur der Tastatur...
Bleibt trotzdem: wie hast du fhem installiert?
Mag irrelevant sein aber wenn du mit apt (the easy way <- geht nun auch wieder unter Trixie, wenn ich andere Threads richtig deute), wird der User fhem inkl. Berechtigungen usw. angelegt.
Home ist da eben /opt/fhem
Verm. gibt es keine 0->100 Anleitung f. Trixie weil es entweder noch nicht so viele gemacht haben oder es bei denen keine Probleme gab...
EDIT: bei mir wird es noch ein Weilchen dauern, bevor ich umsteige...
Gruß, Joachim
Burny4600
#10
Ich habe das System neu aufgesetzt und bin mit der Alexa Installation nach dieser Anleitung https://wiki.fhem.de/wiki/FHEM_Connector_f%C3%BCr_Amazon_Alexa vorgegangen.
Die Echo Geräte werden aktiv unter FHEM angezeigt.
Die SSH überprüfung ergabe das mir das Verzeichnis /opt/fhem/.ssh fehlt. Wird das durch die Installation von Alexa nicht eingerichtet?
Irgendetwas fehlt noch vor der Skill Verknüpfung.
Ich denke in der Anleitung passt mit der Reihenfolge der Konfigurationsabläufe etwas nicht zusammen, was SSH betrifft.
Jedenfalls fehlt hier ein weiterer Schritt laut dem Log-File.
[1.4.2026, 18:43:31] using config from ./alexa-fhem.cfg
[1.4.2026, 18:43:31] Couldn't find a config file at './alexa-fhem.cfg'. Look at config-sample.json for an example.
[1.4.2026, 18:44:16] using config from ./alexa-fhem.cfg
[1.4.2026, 18:44:17] Couldn't find a config file at './alexa-fhem.cfg'. Look at config-sample.json for an example.
[1.4.2026, 18:44:39] using config from ./alexa-fhem.cfg
[1.4.2026, 18:44:39] Couldn't find a config file at './alexa-fhem.cfg'. Look at config-sample.json for an example.
[1.4.2026, 18:45:01] using config from ./alexa-fhem.cfg
Dazu finde ich keine Beschreibung im wikiFHEM-Verzeichnis.
LG Chris
MadMax-FHEM
Willst du nicht antworten?
WIE hast du fhem installiert?
Weil eben: /opf/fhem vs. /home/fhem
/opt/fhem/.ssh kann es ja nur geben, wenn fhem eben unter /opt/fhem installiert wurde bzw. das Home-Verzeichnis des Users fhem dort liegt.
Bei dir scheint es aber unter /home/fhem installiert zu sein?
Zumindest steht das in einem Logauszug von dir...
Gruß, Joachim
Burny4600
#12
FHEM ist standartmässig installiert.
cd &&
sudo wget http://fhem.de/fhem-6.4.deb -O /tmp/fhem-6.4.deb &&
sudo dpkg -i /tmp/fhem-6.4.deb
Also unter /opt/fhem
Unter unter home ist nur der Benutzer mit dem ich die Pi und FHEM Installation gemacht habe.
Legt das Verzeichnis /opt/fhem/.ssh FHEM an?
Rufe ich ps -ef | egrep '(alexa|ssh)' auf fehlt darin auch der fhem Eintrag.
root         896       1  0 19:31 ?        00:00:00 sshd: /usr/sbin/sshd -D [listener] 0 of 10-100 startups
root        1042     896  0 19:32 ?        00:00:00 sshd-session: admin [priv]
admin       1078    1042  0 19:32 ?        00:00:00 sshd-session: admin@pts/0
admin       1219    1079  0 19:34 pts/0    00:00:00 grep -E --color=auto (alexa|ssh)
Irgendetwas läuft unter Trixie nicht so ab wie unter Bookworm.
LG Chris
MadMax-FHEM
Warum das Paket geladen und selbst installiert und nicht per apt/the easy way?
Soweit ich das im anderen Thread (zu Probleme apt/Trixie meine ich war's) gelesen hab wird bei Installation mittels apt mehr gemacht...
Mag mich aber täuschen...
Komisch, dass aber in einer Logausgabe von dir was bzgl. /home/fhem steht.
Ja, normalerweise wird /opt/fhem/.ssh von alexa-fhem (oder dem Alexa Device) angelegt, sofern nicht (aus anderen Gründen, z.B. ssh Zugang ohne PW) schon vorhanden...
Gut, wenn fhem unter /opt/fhem installiert ist, dann den ls -la Befehl halt mal für /opt/fhem
Gruß, Joachim
