Apples Wo Ist? Integration in FHEM
Begonnen von Guybrush, 13 August 2026, 15:25:00
Jamo
#30
Deswegen heisst die sub ja auch 'getBlitzerORTE...'
Ich habe die sub um PLZ, Strasse und Hausnummer ergänzt.
sub getBlitzerOrteCallback($) {
    my ($param, $err, $data) = @_;
    my $hash = $param->{hash};
    my $BlitzerDev = $hash->{blitzerdev};
my $num = $hash->{num};
    if($err ne "")      # wenn ein Fehler bei der HTTP Abfrage aufgetreten ist
        Log3 "[getBlitzerOrte]", 3, "error while requesting ".$param->{url}." - $err";   # Eintrag fürs Log
#Log 1,"[getBlitzerOrte] $BlitzerDev ".$param->{data}." ".$param->{url}." ".$param->{httpheader}." ".$param->{code};
#Log 1,"$data";
my $Ort = "";
my $postcode     = ' ';
my $road         = ' ';
my $house_number = ' ';
my ($Ort) = $data =~ m/suburb":"([^"]+)"/;
if ((!defined $Ort) or ($Ort eq "")){
#Log 1, "[getBlitzerOrteCallback] search city_district";
        ($Ort) = $data =~ m/city_district":"([^"]+)"/;
#Log 1, "[getBlitzerOrteCallback] $Ort";
#Log 1, "[getBlitzerOrteCallback] search town $data";
        ($Ort) = $data =~ m/town":"([^"]+)"/;
#Log 1, "[getBlitzerOrteCallback] search village $data";
        ($Ort) = $data =~ m/village":"([^"]+)"/;
Log 5, "[getBlitzerOrteCallback] ".$param->{url};
Log 5, "[getBlitzerOrteCallback] $data";
        $Ort = ".";
    my ($building) = $data =~ m/building":"([^"]+)"/;
    if ((!defined $building) or ($building eq "")){
        $building = ".";
    ($postcode) = $data =~ m/postcode":"([^"]+)"/;
    if ((!defined $postcode) or ($postcode eq "")){
        $postcode = '';
    ($road) = $data =~ m/road":"([^"]+)"/;
    if ((!defined $road) or ($road eq '')){
        ($road) = $data =~ m/path":"([^"]+)"/;
        ($road) = $data =~ m/bridleway":"([^"]+)"/;
        ($road) = $data =~ m/pedestrian":"([^"]+)"/;
        ($road) = $data =~ m/footway":"([^"]+)"/;
        ($road) = $data =~ m/square":"([^"]+)"/;
        ($road) = $data =~ m/neighbourhood":"([^"]+)"/;
        ($road) = $data =~ m/city_block":"([^"]+)"/;
        $road = '';
    ($house_number) = $data =~ m/house_number":"([^"]+)"/;
    if ((!defined $house_number) or ($house_number eq "")){
        $house_number = '';
    Log 5,"[getBlitzerOrteCallback] $Ort $building";
    #Log 1,"[getBlitzerOrte] ".$decoded_json->{address}->{suburb}->[0];
    fhem("setreading $BlitzerDev ".$num."PLZ $postcode Ort $Ort Strasse $road Hausnummer $house_number");
    fhem("setreading $BlitzerDev ".$num."Building $building");
ironalf
Danke dir für die schnelle Anpassung der sub :D
Ich musste nur eine kleine Änderung vornehemen:
fhem("setreading $BlitzerDev ".$num."PLZ $postcode Ort $Ort Strasse $road Hausnummer $house_Number"); > fhem("setreading $BlitzerDev ".$num."PLZ $postcode Ort $Ort Strasse $road Hausnummer $house_number")
Jamo
Zitat von: ironalf am 23 August 2026, 12:01:45Danke dir für die schnelle Anpassung der sub :D
Danke, habs verbessert!
KyleK
bei mir funktioniert findmy2mqtt seit ein paar Tagen nicht mehr.
ich bekomme jetzt beim Versuch, mich zu authentifizieren folgende Fehlermeldung:
2026-09-24 11:13:18,058 ERROR findmy2mqtt: You must accept the updated terms of service to continue. Set --accept-terms to accept them
Das scheint eine Option von pyicloud zu sein, weil findmy2mqtt besitzt diesen Schalter nicht.
FHEM on Futro S940
CUL868
7x MAX! Thermostat, 8x MAX! Fensterkontakte
Conbee II + deConz, TradFri Lampen, Osram Smart+ Steckdosen
Guybrush
Ich schau mir das an. Findmy2mqtt ist nur ein wrapper. Wenn das daran liegt bau ich das als Option aber ein, das man das per mqtt dann auch sieht/machen kann
KyleK
ich konnte das Problem lokal lösen, indem ich folgende Änderung vorgenommen hab:
diff --git a/lib/apple.py b/lib/apple.py
index 42f88fe..91d824f 100644
--- a/lib/apple.py
+++ b/lib/apple.py
@@ -64,6 +64,7 @@ def create_api(
         # bewusst seltener und dient nur als Fallback.
         refresh_interval=max(config.pollInterval * 2, 60),
         authenticate=authenticate,
+        accept_terms=True
FHEM on Futro S940
CUL868
ironalf
Apple hat die iCloud-Nutzungsbedingungen geändert und die müssen erst akzeptiert werden.
Entweder auf dem Gerät oder bei iCloud anmelden.
erwin
Hi Guybrush,
danke für das super Projekt!!!
Ich bin dabei, das in ein Docker Environment zu portieren, was sich bisher, danke deiner excellenten docu als einfach herausstellt.
Eine Änderung musste ich in install.sh machen, da in dem verwendeten image kein systemctl vorhanden ist. Daher wird auch da service file nicht verwendet...kein Problem!
Es funktioniert, einige Fragen hab ich dennoch:
in  config.yaml: parameter passwordfile - gehört dort der password string hin, oder ein filenamen ?
Wäre es möglich, einen verbose parameter dort unterzubringen, zb: Error, ..., INFO... Das log ist dzt. sehr gesprächig.
Auch ein parameter log-file wäre praktisch, dzt mach ich das via redirect...
zu lat/lon values: ich denke ein runden auf 6 Nachkommastellen wär ausreichend, (das enspricht ca. 11cm) , mehr Genauigkeit gibt das GPS im handy sicher nicht her. - vereinfacht move/stop erkennung, anzahl events...
gibts eine Möglichkeit, "auth" via mqtt zu triggern und den passcode evtl auch?
Hintergrund: dzt. muss ich interaktiv (um console zu haben) mit dem container verbinden, um passwort u. auth zu setzen. Anschließend container stoppen und als daemon neu starten...
Danke für das Projekt - sobald mein Docker-setup halbwegs foolproof ist, werde ich das gerne teilen!
l.g. erwin
FHEM aktuell auf RaspberryPI Mdl 1-4
Maintainer: 00_KNXIO.pm 10_KNX.pm
User: CUNO2 (868 SLOWRF) - HMS100xx, FS20, FHT, 1-Wire  - 2401(iButton), 18x20, 2406, 2413 (AVR), 2450,..,MQTT2, KNX, SONOFF, mySENSORS,....
Hardware:  Busware ROT, Weinzierl IP731, 1-Wire GW,...
