Apples Wo Ist? Integration in FHEM
Begonnen von Guybrush, 13 August 2026, 15:25:00
Jamo
#30
Deswegen heisst die sub ja auch 'getBlitzerORTE...'
Ich habe die sub um PLZ, Strasse und Hausnummer ergänzt.
sub getBlitzerOrteCallback($) {
    my ($param, $err, $data) = @_;
    my $hash = $param->{hash};
    my $BlitzerDev = $hash->{blitzerdev};
my $num = $hash->{num};
    if($err ne "")      # wenn ein Fehler bei der HTTP Abfrage aufgetreten ist
        Log3 "[getBlitzerOrte]", 3, "error while requesting ".$param->{url}." - $err";   # Eintrag fürs Log
#Log 1,"[getBlitzerOrte] $BlitzerDev ".$param->{data}." ".$param->{url}." ".$param->{httpheader}." ".$param->{code};
#Log 1,"$data";
my $Ort = "";
my $postcode     = ' ';
my $road         = ' ';
my $house_number = ' ';
my ($Ort) = $data =~ m/suburb":"([^"]+)"/;
if ((!defined $Ort) or ($Ort eq "")){
#Log 1, "[getBlitzerOrteCallback] search city_district";
        ($Ort) = $data =~ m/city_district":"([^"]+)"/;
#Log 1, "[getBlitzerOrteCallback] $Ort";
#Log 1, "[getBlitzerOrteCallback] search town $data";
        ($Ort) = $data =~ m/town":"([^"]+)"/;
#Log 1, "[getBlitzerOrteCallback] search village $data";
        ($Ort) = $data =~ m/village":"([^"]+)"/;
Log 5, "[getBlitzerOrteCallback] ".$param->{url};
Log 5, "[getBlitzerOrteCallback] $data";
        $Ort = ".";
    my ($building) = $data =~ m/building":"([^"]+)"/;
    if ((!defined $building) or ($building eq "")){
        $building = ".";
    ($postcode) = $data =~ m/postcode":"([^"]+)"/;
    if ((!defined $postcode) or ($postcode eq "")){
        $postcode = '';
    ($road) = $data =~ m/road":"([^"]+)"/;
    if ((!defined $road) or ($road eq '')){
        ($road) = $data =~ m/path":"([^"]+)"/;
        ($road) = $data =~ m/bridleway":"([^"]+)"/;
        ($road) = $data =~ m/pedestrian":"([^"]+)"/;
        ($road) = $data =~ m/footway":"([^"]+)"/;
        ($road) = $data =~ m/square":"([^"]+)"/;
        ($road) = $data =~ m/neighbourhood":"([^"]+)"/;
        ($road) = $data =~ m/city_block":"([^"]+)"/;
        $road = '';
    ($house_number) = $data =~ m/house_number":"([^"]+)"/;
    if ((!defined $house_number) or ($house_number eq "")){
        $house_number = '';
    Log 5,"[getBlitzerOrteCallback] $Ort $building";
    #Log 1,"[getBlitzerOrte] ".$decoded_json->{address}->{suburb}->[0];
    fhem("setreading $BlitzerDev ".$num."PLZ $postcode Ort $Ort Strasse $road Hausnummer $house_number");
    fhem("setreading $BlitzerDev ".$num."Building $building");
Bullseye auf iNUC, Homematic + HMIP(UART/HMUSB), Debmatic, HUEBridge, Zigbee2MQTT, Conbee III, FB7690, Signal, Alexa (fhem-lazy), Geotracking, LaCrosse JeeLink, LoRaWan (TTN / Chirpstack), Sonos, ESPresence, HomeAssistant via MQTT, Meshtastic
ironalf
Danke dir für die schnelle Anpassung der sub :D
Ich musste nur eine kleine Änderung vornehemen:
fhem("setreading $BlitzerDev ".$num."PLZ $postcode Ort $Ort Strasse $road Hausnummer $house_Number"); > fhem("setreading $BlitzerDev ".$num."PLZ $postcode Ort $Ort Strasse $road Hausnummer $house_number")
Jamo
Zitat von: ironalf am 23 August 2026, 12:01:45Danke dir für die schnelle Anpassung der sub :D
Danke, habs verbessert!
KyleK
bei mir funktioniert findmy2mqtt seit ein paar Tagen nicht mehr.
ich bekomme jetzt beim Versuch, mich zu authentifizieren folgende Fehlermeldung:
2026-09-24 11:13:18,058 ERROR findmy2mqtt: You must accept the updated terms of service to continue. Set --accept-terms to accept them
Das scheint eine Option von pyicloud zu sein, weil findmy2mqtt besitzt diesen Schalter nicht.
FHEM on Futro S940
CUL868
7x MAX! Thermostat, 8x MAX! Fensterkontakte
Conbee II + deConz, TradFri Lampen, Osram Smart+ Steckdosen
