SetTempList HM-CC-TC
Begonnen von AbeamStart, 13 Oktober 2013, 12:50:59
zilli
es hatte ja ursprünglich mal mit dem prep|exec problem Bad format, use HH:MM TEMP ..... an. Ich habe leider das gleiche Problem:
Mein code:
SetTempList_HM_CC_TC_WZ()
   { fhem ("set HM_CC_TC_Climate.WZ controlMode prep auto")};
   { fhem ("set HM_CC_TC_Climate.WZ tempListMon prep 05:30 17.0 08:30 20.5 16:30 18.0 21:30 21.5 24:00 17.0")};
   { fhem ("set HM_CC_TC_Climate.WZ tempListTue prep 05:30 17.0 08:30 20.5 16:30 18.0 21:30 21.5 24:00 17.0")};
   { fhem ("set HM_CC_TC_Climate.WZ tempListWed prep 05:30 17.0 08:30 20.5 16:30 18.0 21:30 21.5 24:00 17.0")};
   { fhem ("set HM_CC_TC_Climate.WZ tempListThu prep 05:30 17.0 08:30 20.5 16:30 18.0 21:30 21.5 24:00 17.0")};
   { fhem ("set HM_CC_TC_Climate.WZ tempListFri prep 05:30 17.0 08:30 20.5 16:30 18.0 21:30 21.5 24:00 17.0")};
   { fhem ("set HM_CC_TC_Climate.WZ tempListSat prep 07:30 17.0 13:30 21.5 16:30 19.0 21:30 21.5 24:00 17.0")};
   { fhem ("set HM_CC_TC_Climate.WZ tempListSun exec 07:30 17.0 13:30 21.5 16:30 19.0 21:30 21.5 24:00 17.0")};
Fehler ist:
2013.12.03 21:53:00 3: set HM_CC_TC_Climate.WZ controlMode prep auto : controlMode requires parameter: [manual|auto|central|party]
2013.12.03 21:53:00 3: set HM_CC_TC_Climate.WZ tempListMon prep 05:30 17.0 08:30 20.5 16:30 18.0 21:30 21.5 24:00 17.0 : Bad format, use HH:MM TEMP ...
2013.12.03 21:53:00 3: set HM_CC_TC_Climate.WZ tempListTue prep 05:30 17.0 08:30 20.5 16:30 18.0 21:30 21.5 24:00 17.0 : Bad format, use HH:MM TEMP ...
2013.12.03 21:53:00 3: set HM_CC_TC_Climate.WZ tempListWed prep 05:30 17.0 08:30 20.5 16:30 18.0 21:30 21.5 24:00 17.0 : Bad format, use HH:MM TEMP ...
2013.12.03 21:53:00 3: set HM_CC_TC_Climate.WZ tempListThu prep 05:30 17.0 08:30 20.5 16:30 18.0 21:30 21.5 24:00 17.0 : Bad format, use HH:MM TEMP ...
2013.12.03 21:53:00 3: set HM_CC_TC_Climate.WZ tempListFri prep 05:30 17.0 08:30 20.5 16:30 18.0 21:30 21.5 24:00 17.0 : Bad format, use HH:MM TEMP ...
2013.12.03 21:53:00 3: set HM_CC_TC_Climate.WZ tempListSat prep 07:30 17.0 13:30 21.5 16:30 19.0 21:30 21.5 24:00 17.0 : Bad format, use HH:MM TEMP ...
2013.12.03 21:53:00 3: set HM_CC_TC_Climate.WZ tempListSun exec 07:30 17.0 13:30 21.5 16:30 19.0 21:30 21.5 24:00 17.0 : Bad format, use HH:MM TEMP ...
Kann mir einer helfen? Bin absoluter Neuling.
Rohan
Hallo zilli,
dein letztes Fhem-Update ist wie lange her?
Gib mal bitte in der Web-Oberflache "version" ein und poste hier (als Code, also vorher das Raute-/Sharp-Zeichen klicken) das Ergebnis.
Thomas
Fhem auf Mini-ITX mit Celeron 2-Core, HMLAN (> 55 Devices), CUL (FS20 und EM), RFXtrx 433E, Arduino (einige DS18B20), RPi mit 1-Wire (DS2423 für S0-Signale, DS18B20+), RPi/Arduino mit MQ-5 und MQ-9 (CO- und CNG/LPG-Sensor), CO-20 IAQ Sensor
zilli
Hallo Rohan,
das ging ja schnell, hier das Ergebnis bei "version"
# $Id: fhem.pl 3872 2013-09-07 11:58:33Z rudolfkoenig $
# $Id: 10_CUL_HM.pm 4288 2013-11-25 09:40:18Z martinp876 $
# $Id: 57_Calendar.pm 4194 2013-11-09 18:58:18Z borisneubert $
# $Id: 01_FHEMWEB.pm 4292 2013-11-27 20:50:06Z rudolfkoenig $
# $Id: 92_FileLog.pm 3759 2013-08-21 08:13:08Z rudolfkoenig $
# $Id: 00_HMLAN.pm 4257 2013-11-21 18:17:30Z martinp876 $
# $Id: 99_SUNRISE_EL.pm 3738 2013-08-18 14:13:59Z rudolfkoenig $
# $Id: 98_SVG.pm 4275 2013-11-23 14:25:15Z rudolfkoenig $
# $Id: 99_Utils.pm 3595 2013-08-05 05:38:48Z tobiasfaust $
# $Id: 98_XmlList.pm 2895 2013-03-11 19:48:01Z rudolfkoenig $
# $Id: 98_autocreate.pm 4234 2013-11-17 10:19:41Z rudolfkoenig $
# $Id: 91_eventTypes.pm 2982 2013-03-24 17:47:28Z rudolfkoenig $
# $Id: 98_notice.pm 2647 2013-02-04 21:43:52Z mfr69bs $
# $Id: 91_notify.pm 3738 2013-08-18 14:13:59Z rudolfkoenig $
# $Id: 98_telnet.pm 3738 2013-08-18 14:13:59Z rudolfkoenig $
# $Id: 98_update.pm 4070 2013-10-19 11:22:17Z rudolfkoenig $
# $Id: 98_weblink.pm 3770 2013-08-23 13:29:58Z rudolfkoenig $
Hoffe das ist das richtige. Update hatte ich erst die Tage gemacht.
Danke schon mal für die Hilfe.
Rohan
Hi zilli,
meins sieht so aus
# $Id: fhem.pl 4294 2013-11-28 18:27:42Z rudolfkoenig $
# $Id: 00_CUL.pm 4232 2013-11-16 14:00:26Z martinp876 $
# $Id: 15_CUL_EM.pm 4229 2013-11-15 17:29:55Z rudolfkoenig $
# $Id: 09_CUL_FHTTK.pm 4229 2013-11-15 17:29:55Z rudolfkoenig $
# $Id: 10_CUL_HM.pm 4310 2013-12-02 17:54:19Z martinp876 $
# $Id: 11_FHT.pm 4229 2013-11-15 17:29:55Z rudolfkoenig $
# $Id: 95_FLOORPLAN.pm 3971 2013-09-29 08:16:39Z ulimaass $
# $Id: 10_FS20.pm 3764 2013-08-22 07:09:38Z rudolfkoenig $
# $Id: 12_HMS.pm 4229 2013-11-15 17:29:55Z rudolfkoenig $
# $Id: 98_HMinfo.pm 4101 2013-10-23 14:25:19Z martinp876 $
# $Id: 11_OWDevice.pm 4285 2013-11-25 07:24:28Z justme1968 $
# $Id: 10_OWServer.pm 4287 2013-11-25 09:12:40Z justme1968 $
# $Id: 98_SVG.pm 4315 2013-12-02 22:07:27Z rudolfkoenig $
# $Id: 32_SYSSTAT.pm 3840 2013-09-02 19:28:43Z justme1968 $
# $Id: 90_at.pm 4246 2013-11-18 20:35:20Z rudolfkoenig $
# $Id: 98_dummy.pm 3738 2013-08-18 14:13:59Z rudolfkoenig $
# $Id: 98_fheminfo.pm 3775 2013-08-24 08:31:39Z rudolfkoenig $
Gibt schon Unterschiede  :o
Ein "update" deinerseits schadet nicht. Und danach ein neuer Versuch.
Thomas
zilli
habe grad auch noch mal einen check gemacht und gesehen das es Neues gibt. Mache grad ein Update und danach direkt einen "update check". Vielleicht hatte das Update ja letztes mal nicht geklappt. Das hatte ich nicht kontrolliert. Dann probier ich noch mal. Ich poste hier auf jedenfall, falls es dann funktioniert.
Danke noch mal!
zilli
also ich habe jetzt das Update gemacht und danach nochmal den update check der sagt es gibt nicht zu tun.
leider funktioniert es trotzdem noch nicht, gleiches verhalten. Meine Version ist jetzt ein wenig neuer das die von dir Rohan.
Habt ihr noch ne Idee? Kann es am HMLAN liegen?
martinp876
Hallo Zilli,
mache bitte noch einmal einen update forced. Prüfen, dass alles funktioniert hat.
Dann noch einmal, welche Feher noch auftreten - und was sich geändert hat
Martin
zilli
Hallo martinp876,
habe jetzt update forced gemacht und folgende Rückmeldungen bekommen:
2013-12-04 21:41:26 Global global update get http://fhem.de/fhemupdate4/svn/FHEM/FhemUtils/release.pm
2013-12-04 21:41:26 Global global update check Releases => local: Fhem 5.5 (DEVELOPMENT) remote: Fhem 5.5 (DEVELOPMENT)
2013-12-04 21:41:26 Global global update get http://fhem.de/fhemupdate4/svn/controls_fhem.txt
2013-12-04 21:41:28 Global global update nothing to do...
nach update check bekomme ich aber folgendes:
List of new / modified files since last update:
UPD ./CHANGED
UPD ./fhem.pl
UPD FHEM/10_CUL_HM.pm
UPD FHEM/10_FBDECT.pm
UPD FHEM/33_readingsGroup.pm
UPD FHEM/59_Weather.pm
UPD FHEM/72_FB_CALLMONITOR.pm
UPD FHEM/73_PRESENCE.pm
UPD docs/commandref.html
UPD docs/commandref_DE.html
UPD www/jscolor/jscolor.js
Grüße, zilli
martinp876
es sollte heißen
update force
mein fehler sorry. Dann sollte immer ein komplett update gemacht werden
Gruss Martin
zilli
Hallo martinp876,
jetzt funktioniert es.
Vielen Dank!
blu
zunächst hatte ich beim Ausführen von {SetTempList_UG_Treppe_Heizung} auch die Fehlermeldung Bad format, use HH:MM TEMP ......
Nach einem update von FHEM verschwand diese. Vielleicht könnte man auf http://www.fhemwiki.de/wiki/HM-CC-RT-DN_Funk-Heizkörperthermostat einen Hinweis auf die Fehlermeldung und das nötige Update geben (hätte mir eine Stunde Zeit gespart). Auf Wunsch kann ich das erledigen, ich bin allerdings noch nicht registriert und wollte nicht extra einen Wiki-Admin kontaktieren.
lg blu
RasPi2, FHEM 5.6, HM-LAN-CFG
HM-CC-RT-DN, HM-LC-SW1-FM, HM-LC-SW1-PL2, HM-LC-Sw1PBU-FM, HM-Sen-MDIR-O,  HM-SEC-SCo, HM-PB-2-WM55-2, HM-PB-6-WM55, HM-ES-TX-WM (+ Ferraris)
Rohan
Hi blu,
Zitat von: blu am 26 Januar 2014, 21:03:10... Vielleicht könnte man auf http://www.fhemwiki.de/wiki/HM-CC-RT-DN_Funk-Heizkörperthermostat einen Hinweis auf die Fehlermeldung und das nötige Update geben (hätte mir eine Stunde Zeit gespart). ...
Erledigt.
Danke für den Hinweis.
Thomas
