WICHTIG: Bitte um Mithilfe an alle RFXtrx433-User
Begonnen von Willi, 01 Dezember 2013, 18:52:03
fruit
HE330S
Description: Wireless plug in adapter supplied as pack of three HE330S plug in devices and HE312Sv2 remote. On/off only, not dimmable.
Status: Working
Manufacturer: Homeeasy/C H Byron
Brand: Homeeasy
Max Load: 3000W
Current drain: approx 0.01A off/standby mode
Protocol: TRX_LIGHT AC
The adapters have no teach button. After initial power-on the LED lamp blinks and can be taught to the remote during this phase. The LED remains lit whilst powered.
HE312Sv2
Description: Remote control
Batteries: Button cell CR2032 (included)
Notes: Suitable for UK, ROI and possibly other regions using plugs similar to BS1363, IS401 and IS411
RFXTRX device setting, firmware=71, protocols enabled: LaCrosse Hideki OREGON HOMEEASY AC ARC X10
Documentation: http://www.homeeasy.eu/Support/
Feel free to follow up in German if you prefer
fruit
HE830S
Description: Wireless plug in adapter supplied as pack of three HE830S plug in devices and HE300 remote. On/off only, not dimmable.
Status: Working
Brand: Homeeasy
Max Load: 3000W
Teaching is by pressing the recessed LED button. The LED lamp blinks and can be taught to the remote during this phase. The LED remains lit whilst powered
For some reason these devices would not switch consistently from fhem at first. Subsequent attempts have switched consistently. Same behaviour for a second set
HE300
Batteries: Type 23 (included)
Protocol: TRX_LIGHT AC, TRX_LIGHT ARC, TRX_LIGHT HOMEEASY
Notes: Relevant for UK, ROI and possibly other regions using plugs similar to BS1363, IS401 and IS411
fruit
HE851
Description: Indoor motion detector
Status: Working
Manufacturer: Elro
Brand: Homeeasy
Batteries: 2 x AAA (included)
Protocol, two devices tested:
Device 1: TRX_LIGHT ARC, TRX_LIGHT AC, TRX_LIGHT HOMEEASY
Device 2: TRX_LIGHT ARC, TRX_LIGHT AC, TRX_LIGHT HOMEEASY
The PIR has switch settings for 1m, 3m, 6m distance, 5sec, 1min, 5min, 10min duration, H, M, L light level.
Notes: The backplate fixing holes will fit typical UK patress/backboxes.  Batteries are not retained securely when removing cover to adjust settings
Documentation: http://www.elro.eu/en/support/
fruit
HE861
Description: Outdoor motion detector
Status: Working
Manufacturer: Elro
Brand: Homeeasy
Device 1: TRX_LIGHT AC
Device 2: TRX_LIGHT HOMEEASY
The PIR has switch settings for 5sec, 1min, 5min, 10min duration, H, M, L light level, potentiometer for 3m - 12m distance.
Notes: An adjustable fixing bracket is included and two shields to restrict angle of view. Batteries are not retained securely when removing cover to adjust settings
Cruz
#19
Heyho!
So, nun möchte ich endlich auch mal mitmischen :) . BTW: Vielen Dank an die Entwickler - wirklich toll das FHEM. Und auch nochmal ein extra Dankeschön an Willi für die Module. Ich hab' vorhin mal ein wenig selbst experimentiert und recht schnell aufgegeben obwohl der Code zunächst nicht sooo kompliziert aussah.
Hier nun meine 4 Devices:
Cruz
Intertechno ITS-150
Funktioniert super. Reichweite etwas geringer als bei der ITZ-500 aber über ein Stockwerk noch zuverlässig. Vorteil gegenüber der ITZ-500 ist, dass Madame nicht immer aus Versehen den Empfangscode verstellt und die falschen Geräte bedient ;)
Technische Daten
Funktion
•Schaltet alle IT FUNK-Empfängertypen von Intertechno, auch den Funk-Gong SL-7000
•ergonomische, attraktive Formgebung
•inkl. Wandhalter (transparent)
•inkl. Batterie CR2032/ 3 Volt, ausreichend für ca. 3 Jahre oder ca. 20 000 Schaltungen
•Gruppenschalter für die gleichzeitige oder getrennte Schaltung von kompatiblen Empfängern
Reichweite bis 30m
Verpackung Blister
Batterie-Typ CR 2032
Kodierung SENDER mit Kodierrad
Cruz
Intertechno ITDS-50 Funk-Dämmerungsschalter (ganz vergessen - sind also 5 Devices ;)  )
Funktioniert super und wird direkt als ARC erkannt. Allerdings taugt er mir nicht viel, weil selbst ein Setzen des Levels bei völliger Dunkelheit immer schon/erst bei Zwielicht, also ca. 20 min später/früher als sunrise/sunset "civil" schaltet.
Technische Daten
Funktion
•Tägliche Registrierung der Dämmerungszeit
•Einschaltdauer wählbar von 2 bis 8 Stunden oder ,, AUTO".
•Täglich wiederkehrende Schaltung
•Automatisches Einsetzen der jeweiligen Zielapparate
•Individuell Einsetzbar
•Hohe Reichweite
•Hohe Sicherheit durch Zufallscode (Anm: Kein Rolling-Code)
Reichweite ca 30m
Verpackung Blister
Batterie-Typ 2 * AAA, Alkaline 1,5V (nicht im Lieferumfang enthalten)
Kodierung SENDER für selbstlernende EMPFÄNGER
Cruz
Intertechno CMR-500 Funkeinbauschalter für Jalousie-, Rollladen-, Markisen- und Torantriebe
Funktioniert super. Einfach Code mit den beiden Rädern einstellen und als ARC ansteuern. Vor 2 Wochen hatten wir 2 davon, nun sind es schon 8... ;) . Empfang ist recht sauber, auch wenn ich zur Sicherheit den Code mit Sleep 130 noch ein zweites Mal hinterher schicke, weil in ca. 2% ein Empfänger nicht schaltet.
Funktion Schalter EIN / AUS
Anwendungen Jalousie-, Rollladen-, Markisen- und Torantriebe. Durch die automatische Abschaltung nach 2 min. kann dieser Einbauschalter auch zur Schaltung von Treppenhauslicht oder Absaugventilatoren etc. verwendet werden.
Schaltleistung bis 1000 W, potentialfrei
Spannung 230 V
Empfangsfrequenz 433 MHz
Reichweite bis 30m
Schalterabstand 50cm
Verpackung Blister
Abmessungen (ø x H) ca. 63 x 33mm
Kodierung EMPFÄNGER mit Kodierrad
Cruz
Und nun die Sorgenkinder...
Funk-Türgong ME FR-60
Wird vom RFXMgr wie folgt erkannt:
0716000E00090F70
Packettype    = Chime
subtype       = Byron SX
Sequence nbr  = 14
ID            = 0009
Sound         = undefined sound:F
Signal level  = 7
Im FHEM taucht er dann leider als "unknown" auf. Gruppe 14 geht mutmaßlich in Richhtung TRX_LIGHT aber da hat mein Latein dann leider nicht weiter gereicht :( . Ihn einzubinden wäre schon verlockend, weil man den Taster zum Melden der Türklingel und den Empfänger als Signalgeber nutzen könnte.
Cruz
Und zu guter Letzt:
TEVION Funksteckdosen-Set 5-Teilig
alias
Funksteckdose: Globaltronics GT-FSI-07 und
Fernbedienung: Globaltronics GT-9000
Die Befehle kommen mit "undec on" im RFXMgr so an:
Taste 1 "on":
0703010516713CC0
Packettype        = UNDECODED RF Message
UNDECODED ARC:16713CC0
070301061113CC00
UNDECODED ARC:1113CC00
Taste 1 "on":
0703010714233400
UNDECODED ARC:14233400
070301081648CD00
UNDECODED ARC:1648CD00
Taste 1 "on":
07030109166F59C0
UNDECODED ARC:166F59C0
Taste 1 "off":
0703010A146AD100
UNDECODED ARC:146AD100
0703010B165AB440
UNDECODED ARC:165AB440
Taste 1 "off":
0703010C16543240
UNDECODED ARC:16543240
Taste 1 "off":
0703010D16516A80
UNDECODED ARC:16516A80
...Was mir Sorgen macht ist, dass mal ein Protokoll und mal zwei ankommen. Da sie IMHO auch Fixcodes haben stimmt mutmaßlich das Timing nicht ganz. Es gibt sogar ein Blog (http://itooktheredpill.dyndns.org/2013/funksteckdosen-hacken/), in dem sie detailliert analysiert wurden, jedoch steht auch hier noch mein knappes FHEM-Latein im Weg.
Warum ich sie gekauft bzw. dann trotzdem behalten habe? Weil sie auf 6,95€ runter gesetzt waren. Sie sind klein, die Reichweite ist gut und ich hoffe mal, dass sie über kurz oder lang den weg in die RFX-FW finden :)
Dennis
Cruz
Funksteckdose SD 401
Vertrieb durch OCSM GmbH, Essen
Schaltleistung 1000 W
...War ein Set mit 5 (!) Steckdosen und einer weißen FB mit flachen Tasten, die ich mangels Batterie aber noch nicht als Sender testen konnte.
Anlernen geht wie unter http://www.fhemwiki.de/wiki/Intertechno_Code_Berechnung beschrieben kinderleicht durch Umrechnung der DIP in den IT-Code.
ext23
Funktioniert alles:
HE301EU - Handsender für Schlüsselbund
(http://ecx.images-amazon.com/images/I/413EaZJy-xL._SL500_SS120_.jpg)
HE307EU - Wandtaster 2-fach
(http://ecx.images-amazon.com/images/I/31r4PQIZ6YL._SY300_.jpg)
HE302EU - Funksteckdose
(http://www.oh-s.ru/modules/icatalog/items/big/20091013112920.jpg)
HE300EU - Fernbedienung 16 Tasten (4x4 mit Schalter)
(http://www.homeeasy.eu/product_images_eu/lg/HE300EU.jpg)
HE304EU - Deckenschalter
(http://ecx.images-amazon.com/images/I/41ytIuaANcL._SX300_.jpg)
Daniel
HarryT
I use KaKu devices. This is a product sold at least in The Netherlands. In English the same devices and are sold as CoCo devices. The type numbers are identical.
I use besides the already in the wiki mentioned products:
Kaku ASUN-650 Sun blinds switch    http://www.coco-technology.com/shop/producten-1/ontvangers/asun-651/
it is recognized as a trx-light device
- Temperatur-/Luftffeuchtigkeitssensoren:
"TX3_TH": LaCrosse TX3, TX4, TX17
"TFATS34C": TFA TS34C (Kat. Nr. 30.3126)     http://www.weerstationkopen.nl/accessoires-weerstations/homewizard/wsp-433-3ch-groot-bereik
"TFATS34C": Cresta TX-320                                 http://www.weerstationkopen.nl/accessoires-weerstations/homewizard/tx-320-3-kan-sensor
and somebody in my neighberhood has a
TFA_303133_3
Dimmer
ACD-300 http://www.coco-technology.com/shop/producten-1/dimmers/ac-301/  it is recognized as a trx-light device
All products above work fine. I use also andFHEM so I can controle all devices from my smartphone.
And some chinees PT2262 pir sensors. The ranges are not so good and so is the battery live. At the moment they are switched off.
{HT}
FHEM 6.4 auf Raspberry Pi3  (1,2 Ghz)
RFXTRX433XL, ZWave, KFL200 and ConBeeIII
Raspberry Pi1 (0,7 Ghz), Raspberry Pi4 and RaspberryPi 5 for testing
German reading skills are good.
drdownload
Sollte man diesen Thread nicht oben anpinnen und mit eindeutigem Titel versehen? Ich hätte auch für einige Devices die bei mir rumgelegen sind inkl. Fotos und Erklärung. Ich glaube das wäre einfacher als Erläuterungen zu den einzelnen Devices ins Wiki zu geben.
CUL 868 Slow-RF (FS20 Aktoren, Sender, FHT8V), CUL 868 (WMBUS-Empfang), Jeelink (PCA301), WS3600 (WH3080 über USB-Basis), Bewässerung mit ESP-Easy und Proplanta, RFXTRX433 Home-Easy Empfang und Senden, Oregon TH, WS001 TH), Blackbean IR, Mopidy-Snapcast MR Audio, Kodi, Forum-LED-Controller,
Navigator
Funktioniert ebenfalls..
Die Dimmer sind klasse... absolut geräuschlos und winzig klein. Auch direkt dimmbar über 15 Stufen.
Gruß aus Sachsen. FHEM auf Cubietruck. Vormals EZControl XS1 User.
