HM virtual CCU
Begonnen von martinp876, 28 April 2014, 20:28:12
frank
hallo martin,
hier nun mal das gewünschte log.
müsste man den logeinbau nicht besser an anderer stelle einbauen, da er bei der betreffenden kommunikation gar nicht zum tragen kommt?
[code]2014.06.04 11:08:36.929 0: Server shutdown
2014.06.04 11:08:36.946 4: CUL_send:  cul868X0 0
2014.06.04 11:08:44 2: Perfmon: ready to watch out for delays greater than one second
2014.06.04 11:08:44.487 1: Including fhem.cfg
2014.06.04 11:08:47.445 1: HMLAN_Parse: hmusb1 new condition disconnected
2014.06.04 11:08:47.508 1: HMLAN_Parse: hmusb1 new condition init
2014.06.04 11:08:47.539 1: HMLAN_Parse: hmlan1 new condition disconnected
2014.06.04 11:09:02.706 1: Including ./log/fhem.save
2014.06.04 11:09:06.766 1: HCS BROETJE monitoring of devices started
2014.06.04 11:09:07.217 3: n_global_init return value: Please define cul433 first
2014.06.04 11:09:07.246 0: Server started with 245 defined entities (version $Id: fhem.pl 6001 2014-05-29 10:25:01Z rudolfkoenig $, os linux, user root, pid 2247)
2014.06.04 11:09:07.253 1: Perfmon: possible freeze starting at 11:08:45, delay is 22.252
2014.06.04 11:09:07.852 1: HMLAN_Parse: hmusb1 new condition ok
2014.06.04 11:09:07.930 0: HMLAN_Parse: hmusb1 R:E1D252E   stat:0000 t:001306EF d:FF r:FFC6     m:62 A258 1D252E D1D1D1 0000
2014.06.04 11:09:08.129 0: HMLAN_Send:  hmusb1 S:+1D252E,00,01,00
2014.06.04 11:09:08.131 0: HMLAN_Send:  hmusb1 S:S66239CE5 stat:  00 t:00000000 d:01 r:66239CE5 m:62 8002 D1D1D1 1D252E 0101000000
2014.06.04 11:09:08.346 4: CUL_Parse: cul868 A 0C 67 8670 1936FF 000000 00AE44FA -77
2014.06.04 11:09:08.586 4: RCV L:0C N:67 F:86 CMD:70 SRC:Thermostat.Bad DST:broadcast 00AE44 (WeatherEvent TEMP:17.4 HUM:68) (,WAKEMEUP,CFG,RPTEN)
2014.06.04 11:09:08.660 4: CUL_Parse: cul868 A 0E 62 8002 D1D1D1 1D252E 010100000060 -26
2014.06.04 11:09:08.675 4: RCV L:0E N:62 F:80 CMD:02 SRC:TCControler.Kueche DST:Thermostat.Kueche 0101000000 (ACK_STATUS CHANNEL:0x01 STATUS:0x00 UP:0 DOWN:0 LOWBAT:0 RSSI:0) (,RPTEN)
2014.06.04 11:09:08.790 1: #### start parser
2014.06.04 11:09:08.808 1: #### start parser
2014.06.04 11:09:08.829 1: #### start parser
2014.06.04 11:09:08.842 1: #### start parser
2014.06.04 11:09:08.863 1: #### start parser
2014.06.04 11:09:08.878 1: #### start parser
2014.06.04 11:09:08.890 1: #### start parser
2014.06.04 11:09:08.904 1: #### start parser
2014.06.04 11:09:08.924 1: #### start parser
2014.06.04 11:09:08.937 1: #### start parser
2014.06.04 11:09:08.957 1: #### start parser
2014.06.04 11:09:09.032 1: #### start parser
2014.06.04 11:09:09.044 1: #### start parser
2014.06.04 11:09:09.128 1: #### start parser
2014.06.04 11:09:09.137 1: #### start parser
2014.06.04 11:09:09.148 1: #### start parser
2014.06.04 11:09:09.166 1: #### start parser
2014.06.04 11:09:09.177 1: #### start parser
2014.06.04 11:09:09.196 1: #### start parser
2014.06.04 11:09:09.207 1: #### start parser
2014.06.04 11:09:09.227 1: #### start parser
2014.06.04 11:09:09.241 1: #### start parser
2014.06.04 11:09:09.261 1: #### start parser
2014.06.04 11:09:09.272 1: #### start parser
2014.06.04 11:09:09.294 1: #### start parser
2014.06.04 11:09:09.306 1: #### start parser
2014.06.04 11:09:09.328 1: #### start parser
2014.06.04 11:09:09.338 1: #### start parser
2014.06.04 11:09:09.348 1: #### start parser
2014.06.04 11:09:09.356 1: #### start parser
2014.06.04 11:09:09.386 1: #### start parser
2014.06.04 11:09:09.397 1: #### start parser
2014.06.04 11:09:09.421 1: #### start parser
2014.06.04 11:09:09.429 1: #### start parser
2014.06.04 11:09:09.450 1: #### start parser
2014.06.04 11:09:09.458 1: #### start parser
2014.06.04 11:09:09.478 1: #### start parser
2014.06.04 11:09:09.491 1: #### start parser
2014.06.04 11:09:09.501 1: #### start parser
2014.06.04 11:09:09.512 1: #### start parser
2014.06.04 11:09:09.530 1: #### start parser
2014.06.04 11:09:09.541 1: #### start parser
2014.06.04 11:09:09.559 1: #### start parser
2014.06.04 11:09:09.571 1: #### start parser
2014.06.04 11:09:09.593 1: #### start parser
2014.06.04 11:09:09.606 1: #### start parser
2014.06.04 11:09:09.628 1: #### start parser
2014.06.04 11:09:09.646 1: #### start parser
2014.06.04 11:09:09.659 1: #### start parser
2014.06.04 11:09:09.672 1: #### start parser
2014.06.04 11:09:09.682 1: #### start parser
2014.06.04 11:09:09.699 1: #### start parser
2014.06.04 11:09:09.712 1: #### start parser
2014.06.04 11:09:09.724 1: #### start parser
2014.06.04 11:09:09.734 1: #### start parser
2014.06.04 11:09:09.753 1: #### start parser
2014.06.04 11:09:09.767 1: #### start parser
2014.06.04 11:09:09.781 1: #### start parser
2014.06.04 11:09:09.790 1: #### start parser
2014.06.04 11:09:09.807 1: #### start parser
2014.06.04 11:09:09.820 1: #### start parser
2014.06.04 11:09:09.832 1: #### start parser
2014.06.04 11:09:09.842 1: #### start parser
2014.06.04 11:09:10.024 1: #### start parser
2014.06.04 11:09:10.114 1: #### start parser
2014.06.04 11:09:10.206 1: #### start parser
2014.06.04 11:09:10.311 1: #### start parser
2014.06.04 11:09:10.357 1: #### start parser
2014.06.04 11:09:10.417 1: #### start parser
2014.06.04 11:09:10.431 1: #### start parser
2014.06.04 11:09:10.445 1: #### start parser
2014.06.04 11:09:10.524 1: #### start parser
2014.06.04 11:09:10.546 1: #### start parser
2014.06.04 11:09:10.570 1: #### start parser
2014.06.04 11:09:10.594 1: #### start parser
2014.06.04 11:09:10.606 1: #### start parser
2014.06.04 11:09:10.620 1: #### start parser
2014.06.04 11:09:10.633 1: #### start parser
2014.06.04 11:09:10.647 1: #### start parser
2014.06.04 11:09:10.730 1: #### start parser
2014.06.04 11:09:10.753 1: #### start parser
2014.06.04 11:09:10.776 1: #### start parser
2014.06.04 11:09:10.801 1: #### start parser
2014.06.04 11:09:10.814 1: #### start parser
2014.06.04 11:09:10.827 1: #### start parser
2014.06.04 11:09:10.840 1: #### start parser
2014.06.04 11:09:10.854 1: #### start parser
2014.06.04 11:09:10.959 1: #### start parser
2014.06.04 11:09:10.982 1: #### start parser
2014.06.04 11:09:11.005 1: #### start parser
2014.06.04 11:09:11.028 1: #### start parser
2014.06.04 11:09:11.040 1: #### start parser
2014.06.04 11:09:11.053 1: #### start parser
2014.06.04 11:09:11.067 1: #### start parser
2014.06.04 11:09:11.082 1: #### start parser
2014.06.04 11:09:11.169 1: #### start parser
2014.06.04 11:09:11.182 1: #### start parser
2014.06.04 11:09:11.262 1: #### start parser
2014.06.04 11:09:11.279 1: #### start parser
2014.06.04 11:09:11.372 1: #### start parser
2014.06.04 11:09:11.405 1: #### start parser
2014.06.04 11:09:11.500 1: #### start parser
2014.06.04 11:09:11.527 1: #### start parser
2014.06.04 11:09:11.622 1: #### start parser
2014.06.04 11:09:11.649 1: #### start parser
2014.06.04 11:09:11.776 1: #### start parser
2014.06.04 11:09:11.845 1: #### start parser
2014.06.04 11:09:12.068 1: #### start parser
2014.06.04 11:09:12.111 1: #### start parser
2014.06.04 11:09:12.141 1: #### start parser
2014.06.04 11:09:12.161 1: #### start parser
2014.06.04 11:09:12.235 1: #### start parser
2014.06.04 11:09:12.425 1: #### start parser
2014.06.04 11:09:12.438 1: #### start parser
2014.06.04 11:09:12.549 1: #### start parser
2014.06.04 11:09:12.568 1: #### start parser
2014.06.04 11:09:12.582 1: #### start parser
2014.06.04 11:09:12.599 1: #### start parser
2014.06.04 11:09:12.633 1: #### start parser
2014.06.04 11:09:12.810 1: #### start parser
2014.06.04 11:09:12.823 1: #### start parser
2014.06.04 11:09:12.932 1: #### start parser
2014.06.04 11:09:12.951 1: #### start parser
2014.06.04 11:09:12.965 1: #### start parser
2014.06.04 11:09:12.982 1: #### start parser
2014.06.04 11:09:13.015 1: #### start parser
2014.06.04 11:09:13.201 1: #### start parser
2014.06.04 11:09:13.213 1: #### start parser
2014.06.04 11:09:13.322 1: #### start parser
2014.06.04 11:09:13.341 1: #### start parser
2014.06.04 11:09:13.356 1: #### start parser
2014.06.04 11:09:13.372 1: #### start parser
2014.06.04 11:09:13.417 1: #### start parser
2014.06.04 11:09:13.595 1: #### start parser
2014.06.04 11:09:13.609 1: #### start parser
2014.06.04 11:09:13.716 1: #### start parser
2014.06.04 11:09:13.736 1: #### start parser
2014.06.04 11:09:13.750 1: #### start parser
2014.06.04 11:09:13.767 1: #### start parser
2014.06.04 11:09:13.801 1: #### start parser
2014.06.04 11:09:13.981 1: #### start parser
2014.06.04 11:09:13.993 1: #### start parser
2014.06.04 11:09:14.102 1: #### start parser
2014.06.04 11:09:14.121 1: #### start parser
2014.06.04 11:09:14.192 1: #### start parser
2014.06.04 11:09:14.201 1: Perfmon: possible freeze starting at 11:09:08, delay is 6.2
2014.06.04 11:09:15.760 0: HMLAN_Parse: hmusb1 R:E1936FF   stat:0000 t:00133840 d:FF r:FFC9     m:67 8670 1936FF 000000 00AE44
2014.06.04 11:09:15.876 0: HMLAN_Parse: hmusb1 R:R66239CE5 stat:0002 t:00000000 d:FF r:7FFF     m:62 8002 D1D1D1 1D252E 0101000000
2014.06.04 11:09:16.385 1: #### start parser
2014.06.04 11:09:16.636 1: #### start parser
2014.06.04 11:09:16.876 1: #### start parser
2014.06.04 11:09:17.141 1: #### start parser
2014.06.04 11:09:17.520 1: #### start parser
2014.06.04 11:09:17.668 1: Perfmon: possible freeze starting at 11:09:15, delay is 2.667
2014.06.04 11:09:17.770 4: CUL_Parse: cul868 A 0B 01 A001 1ACE1F 266A86 010E60 -26
2014.06.04 11:09:17.781 4: RCV L:0B N:01 F:A0 CMD:01 SRC:ccu DST:DimPBU01 010E (CONFIG_STATUS_REQUEST CHANNEL:0x01) (,BIDI,RPTEN)
2014.06.04 11:09:17.924 4: CUL_Parse: cul868 A 0F 01 A410 266A86 1ACE1F 060100003F0016 -63
2014.06.04 11:09:17.937 4: RCV L:0F N:01 F:A4 CMD:10 SRC:DimPBU01 DST:ccu 060100003F00 (INFO_ACTUATOR_STATUS RSSI:-63 CHANNEL:0x01 STATUS:0x00 UNKNOWN:0x00) (,CFG,BIDI,RPTEN)
2014.06.04 11:09:18.422 4: CUL_Parse: cul868 A 0A 01 8002 1ACE1F 266A86 0061 -25.5
2014.06.04 11:09:18.431 4: RCV L:0A N:01 F:80 CMD:02 SRC:ccu DST:DimPBU01 00 (ACK) (,RPTEN)
2014.06.04 11:09:18.682 1: #### start parser
2014.06.04 11:09:18.717 4: CUL_Parse: cul868 A 0B 02 A001 1ACE1F 266A86 020E60 -26
2014.06.04 11:09:18.727 4: RCV L:0B N:02 F:A0 CMD:01 SRC:ccu DST:DimPBU01 020E (CONFIG_STATUS_REQUEST CHANNEL:0x02) (,BIDI,RPTEN)
2014.06.04 11:09:19.284 4: CUL_Parse: cul868 A 0F 02 A410 266A86 1ACE1F 060200003F0016 -63
2014.06.04 11:09:19.295 4: CUL_Parse: cul868 A 0A 02 8002 1ACE1F 266A86 0060 -26
2014.06.04 11:09:19.304 4: RCV L:0A N:02 F:80 CMD:02 SRC:ccu DST:DimPBU01 00 (ACK) (,RPTEN)
2014.06.04 11:09:19.692 4: CUL_Parse: cul868 A 0B 03 A001 1ACE1F 266A86 030E60 -26
2014.06.04 11:09:19.702 4: RCV L:0B N:03 F:A0 CMD:01 SRC:ccu DST:DimPBU01 030E (CONFIG_STATUS_REQUEST CHANNEL:0x03) (,BIDI,RPTEN)
2014.06.04 11:09:19.786 1: #### start parser
2014.06.04 11:09:19.856 4: CUL_Parse: cul868 A 0F 03 A410 266A86 1ACE1F 06030000400015 -63.5
2014.06.04 11:09:19.868 4: RCV L:0F N:03 F:A4 CMD:10 SRC:DimPBU01 DST:ccu 060300004000 (INFO_ACTUATOR_STATUS RSSI:-64 CHANNEL:0x03 STATUS:0x00 UNKNOWN:0x00) (,CFG,BIDI,RPTEN)
2014.06.04 11:09:20.316 4: CUL_Parse: cul868 A 0A 03 8002 1ACE1F 266A86 0060 -26
2014.06.04 11:09:20.325 4: RCV L:0A N:03 F:80 CMD:02 SRC:ccu DST:DimPBU01 00 (ACK) (,RPTEN)
2014.06.04 11:09:20.556 4: CUL_Parse: cul868 A 0B 04 A001 1ACE1F 1F64D8 010E61 -25.5
2014.06.04 11:09:20.567 4: RCV L:0B N:04 F:A0 CMD:01 SRC:ccu DST:DimUP01 010E (CONFIG_STATUS_REQUEST CHANNEL:0x01) (,BIDI,RPTEN)
2014.06.04 11:09:20.699 4: CUL_Parse: cul868 A 0E 04 A410 1F64D8 1ACE1F 060100003C23 -56.5
2014.06.04 11:09:20.711 4: RCV L:0E N:04 F:A4 CMD:10 SRC:DimUP01 DST:ccu 060100003C (INFO_ACTUATOR_STATUS RSSI:-60 CHANNEL:0x01 STATUS:0x00 UNKNOWN:0x00) (,CFG,BIDI,RPTEN)
2014.06.04 11:09:20.860 1: #### start parser
2014.06.04 11:09:21.004 4: CUL_Parse: cul868 A 0A 04 8002 1ACE1F 1F64D8 0060 -26
2014.06.04 11:09:21.013 4: RCV L:0A N:04 F:80 CMD:02 SRC:ccu DST:DimUP01 00 (ACK) (,RPTEN)
2014.06.04 11:09:21.221 0: HMLAN_Parse: hmusb1 R:E1936FF   stat:0000 t:0013865E d:FF r:FFC8     m:67 A258 1936FF D3D3D3 0000
2014.06.04 11:09:21.402 0: HMLAN_Send:  hmusb1 S:+1936FF,00,01,00
2014.06.04 11:09:21.404 0: HMLAN_Send:  hmusb1 S:S6623D0BE stat:  00 t:00000000 d:01 r:6623D0BE m:67 8002 D3D3D3 1936FF 0101000000
2014.06.04 11:09:21.614 4: CUL_Parse: cul868 A 0B 67 A258 1936FF D3D3D3 0000F9 -77.5
2014.06.04 11:09:21.629 4: CUL_Parse: cul868 A 0B 05 A001 1ACE1F 24AF1D 010E60 -26
2014.06.04 11:09:21.638 4: RCV L:0B N:05 F:A0 CMD:01 SRC:ccu DST:SwitchES01 010E (CONFIG_STATUS_REQUEST CHANNEL:0x01) (,BIDI,RPTEN)
2014.06.04 11:09:21.703 4: CUL_Parse: cul868 A 0E 05 A410 24AF1D 1ACE1F 0601C800350C -68
2014.06.04 11:09:21.713 4: RCV L:0E N:05 F:A4 CMD:10 SRC:SwitchES01 DST:ccu 0601C80035 (INFO_ACTUATOR_STATUS RSSI:-53 CHANNEL:0x01 STATUS:0xC8 UNKNOWN:0x00) (,CFG,BIDI,RPTEN)
2014.06.04 11:09:21.853 4: CUL_Parse: cul868 A 0A 05 8002 1ACE1F 24AF1D 0060 -26
2014.06.04 11:09:21.862 4: RCV L:0A N:05 F:80 CMD:02 SRC:ccu DST:SwitchES01 00 (ACK) (,RPTEN)
2014.06.04 11:09:21.923 4: CUL_Parse: cul868 A 0E 67 8002 D3D3D3 1936FF 010100000060 -26
2014.06.04 11:09:21.937 4: RCV L:0E N:67 F:80 CMD:02 SRC:TCControler.Bad DST:Thermostat.Bad 0101000000 (ACK_STATUS CHANNEL:0x01 STATUS:0x00 UP:0 DOWN:0 LOWBAT:0 RSSI:0) (,RPTEN)
2014.06.04 11:09:22.164 0: HMLAN_Parse: hmusb1 R:R6623D0BE stat:0002 t:00000000 d:FF r:7FFF     m:67 8002 D3D3D3 1936FF 0101000000
2014.06.04 11:09:22.433 4: CUL_Parse: cul868 A 0B 06 A001 1ACE1F 24AF1D 020E60 -26
2014.06.04 11:09:22.848 4: RCV L:0B N:06 F:A0 CMD:01 SRC:ccu DST:SwitchES01 020E (CONFIG_STATUS_REQUEST CHANNEL:0x02) (,BIDI,RPTEN)
2014.06.04 11:09:23.390 4: CUL_Parse: cul868 A 14 06 A45F 24AF1D 1ACE1F 804E9E0001AF0018095FFF0D -67.5
2014.06.04 11:09:23.401 4: CUL_Parse: cul868 A 0A 06 8002 1ACE1F 24AF1D 0060 -26
2014.06.04 11:09:23.410 4: RCV L:0A N:06 F:80 CMD:02 SRC:ccu DST:SwitchES01 00 (ACK) (,RPTEN)
2014.06.04 11:09:53.762 1: Perfmon: possible freeze starting at 11:09:51, delay is 2.761
2014.06.04 11:09:58.141 4: CUL_Parse: cul868 A 14 6D 845E 24AF1D 000000 804E9F0001AE0018095DFF09 -69.5
2014.06.04 11:09:58.385 4: RCV L:14 N:6D F:84 CMD:5E SRC:SwitchES01 DST:broadcast 804E9F0001AE0018095DFF (powerEvntCyc energy:840873.5 power:4.3 current:24 voltage:239.7 frequency:52.55) (,CFG,RPTEN)
2014.06.04 11:09:58.961 4: CUL_Parse: cul868 A 0C 9B 8670 1BF81B 000000 00C43B24 -56
2014.06.04 11:09:59.201 4: RCV L:0C N:9B F:86 CMD:70 SRC:Thermostat.WZ DST:broadcast 00C43B (WeatherEvent TEMP:19.6 HUM:59) (,WAKEMEUP,CFG,RPTEN)
2014.06.04 11:09:59.263 1: #### start parser
2014.06.04 11:09:59.272 0: HMLAN_Send:  hmusb1 S:S662464AC stat:  00 t:00000000 d:01 r:662464AC m:07 A112 1ACE1F 1BF81B
2014.06.04 11:09:59.481 0: HMLAN_Parse: hmusb1 R:E1BF81B   stat:0000 t:001419F5 d:FF r:FFC3     m:9B 8670 1BF81B 000000 00C43B
2014.06.04 11:09:59.503 4: CUL_Parse: cul868 A 09 07 A112 1ACE1F 1BF81B 60 -26
2014.06.04 11:09:59.512 4: RCV L:09 N:07 F:A1 CMD:12 SRC:ccu DST:Thermostat.WZ  (HAVE_DATA) (,WAKEUP,BIDI,RPTEN)
2014.06.04 11:09:59.577 4: CUL_Parse: cul868 A 09 07 A112 1ACE1F 1BF81B 61 -25.5
2014.06.04 11:09:59.713 4: CUL_Parse: cul868 A 09 07 A112 1ACE1F 1BF81B 60 -26
2014.06.04 11:09:59.902 0: HMLAN_Parse: hmusb1 R:R662464AC stat:0008 t:00000000 d:FF r:7FFF     m:07 A112 1ACE1F 1BF81B
2014.06.04 11:09:59.906 0: HMLAN_Parse: hmusb1 no ACK from 1BF81B
2014.06.04 11:10:18.962 4: CUL_Parse: cul868 A 0B 9B A258 1BF81B D4D4D4 000024 -56
2014.06.04 11:10:19.216 4: RCV L:0B N:9B F:A2 CMD:58 SRC:Thermostat.WZ DST:TCControler.WZ 0000 (ClimateEvent CMD:0x00 ValvePos:0) (,WAKEMEUP,BIDI,RPTEN)
2014.06.04 11:10:19.290 0: HMLAN_Send:  hmusb1 S:+1BF81B,02,01,00
2014.06.04 11:10:19.294 0: HMLAN_Send:  hmusb1 S:S6624B2DD stat:  00 t:00000000 d:01 r:6624B2DD m:9B 8002 D4D4D4 1BF81B 0101000000
2014.06.04 11:10:19.526 0: HMLAN_Parse: hmusb1 R:E1BF81B   stat:0000 t:00146814 d:FF r:FFC4     m:9B A258 1BF81B D4D4D4 0000
2014.06.04 11:10:19.645 0: HMLAN_Parse: hmusb1 R:R6624B2DD stat:0002 t:00000000 d:FF r:7FFF     m:9B 8002 D4D4D4 1BF81B 0101000000
2014.06.04 11:10:19.648 4: CUL_Parse: cul868 A 0E 9B 8002 D4D4D4 1BF81B 010100000061 -25.5
2014.06.04 11:10:19.889 4: RCV L:0E N:9B F:80 CMD:02 SRC:TCControler.WZ DST:Thermostat.WZ 0101000000 (ACK_STATUS CHANNEL:0x01 STATUS:0x00 UP:0 DOWN:0 LOWBAT:0 RSSI:0) (,RPTEN)
2014.06.04 11:10:57.082 1: Perfmon: possible freeze starting at 11:10:54, delay is 3.081
2014.06.04 11:11:09.105 4: CUL_Parse: cul868 A 0C 38 8670 1DFDA5 000000 00C83F18 -62
2014.06.04 11:11:09.347 4: RCV L:0C N:38 F:86 CMD:70 SRC:Thermostat.SZ DST:broadcast 00C83F (WeatherEvent TEMP:20 HUM:63) (,WAKEMEUP,CFG,RPTEN)
2014.06.04 11:11:09.406 1: #### start parser
2014.06.04 11:11:09.416 0: HMLAN_Send:  hmusb1 S:S662576AC stat:  00 t:00000000 d:01 r:662576AC m:08 A112 1ACE1F 1DFDA5
2014.06.04 11:11:09.502 0: HMLAN_Parse: hmusb1 R:E1DFDA5   stat:0000 t:00152BF3 d:FF r:FFC3     m:38 8670 1DFDA5 000000 00C83F
2014.06.04 11:11:09.521 4: CUL_Parse: cul868 A 09 08 A112 1ACE1F 1DFDA5 60 -26
2014.06.04 11:11:09.532 4: RCV L:09 N:08 F:A1 CMD:12 SRC:ccu DST:Thermostat.SZ  (HAVE_DATA) (,WAKEUP,BIDI,RPTEN)
2014.06.04 11:11:09.657 4: CUL_Parse: cul868 A 09 08 A112 1ACE1F 1DFDA5 60 -26
2014.06.04 11:11:09.857 4: CUL_Parse: cul868 A 09 08 A112 1ACE1F 1DFDA5 60 -26
2014.06.04 11:11:10.041 0: HMLAN_Parse: hmusb1 R:R662576AC stat:0008 t:00000000 d:FF r:7FFF     m:08 A112 1ACE1F 1DFDA5
2014.06.04 11:11:10.046 0: HMLAN_Parse: hmusb1 no ACK from 1DFDA5
2014.06.04 11:11:17.060 4: CUL_Parse: cul868 A 0C 63 8670 1D252E 000000 00BA3F0D -67.5
2014.06.04 11:11:17.303 4: RCV L:0C N:63 F:86 CMD:70 SRC:Thermostat.Kueche DST:broadcast 00BA3F (WeatherEvent TEMP:18.6 HUM:63) (,WAKEMEUP,CFG,RPTEN)
2014.06.04 11:11:17.363 1: #### start parser
2014.06.04 11:11:17.378 0: HMLAN_Send:  hmusb1 S:S662595C0 stat:  00 t:00000000 d:01 r:662595C0 m:09 A112 1ACE1F 1D252E
2014.06.04 11:11:17.534 0: HMLAN_Parse: hmusb1 R:E1D252E   stat:0000 t:00154B05 d:FF r:FFC3     m:63 8670 1D252E 000000 00BA3F
2014.06.04 11:11:17.548 4: CUL_Parse: cul868 A 09 09 A112 1ACE1F 1D252E 60 -26
2014.06.04 11:11:17.557 4: RCV L:09 N:09 F:A1 CMD:12 SRC:ccu DST:Thermostat.Kueche  (HAVE_DATA) (,WAKEUP,BIDI,RPTEN)
2014.06.04 11:11:17.625 4: CUL_Parse: cul868 A 09 09 A112 1ACE1F 1D252E 60 -26
2014.06.04 11:11:17.825 4: CUL_Parse: cul868 A 09 09 A112 1ACE1F 1D252E 60 -26
2014.06.04 11:11:18.015 0: HMLAN_Parse: hmusb1 R:R662595C0 stat:0008 t:00000000 d:FF r:7FFF     m:09 A112 1ACE1F 1D252E
2014.06.04 11:11:18.020 0: HMLAN_Parse: hmusb1 no ACK from 1D252E
2014.06.04 11:11:29.105 4: CUL_Parse: cul868 A 0B 38 A258 1DFDA5 D2D2D2 000018 -62
2014.06.04 11:11:29.349 4: RCV L:0B N:38 F:A2 CMD:58 SRC:Thermostat.SZ DST:TCControler.SZ 0000 (ClimateEvent CMD:0x00 ValvePos:0) (,WAKEMEUP,BIDI,RPTEN)
2014.06.04 11:11:29.415 0: HMLAN_Send:  hmusb1 S:+1DFDA5,02,01,00
2014.06.04 11:11:29.418 0: HMLAN_Send:  hmusb1 S:S6625C4CB stat:  00 t:00000000 d:01 r:6625C4CB m:38 8002 D2D2D2 1DFDA5 0101000000
2014.06.04 11:11:29.643 0: HMLAN_Parse: hmusb1 R:E1DFDA5   stat:0000 t:00157A12 d:FF r:FFC2     m:38 A258 1DFDA5 D2D2D2 0000
2014.06.04 11:11:29.775 0: HMLAN_Parse: hmusb1 R:R6625C4CB stat:0002 t:00000000 d:FF r:7FFF     m:38 8002 D2D2D2 1DFDA5 0101000000
2014.06.04 11:11:29.792 4: CUL_Parse: cul868 A 0E 38 8002 D2D2D2 1DFDA5 010100000060 -26
2014.06.04 11:11:30.035 4: RCV L:0E N:38 F:80 CMD:02 SRC:TCControler.SZ DST:Thermostat.SZ 0101000000 (ACK_STATUS CHANNEL:0x01 STATUS:0x00 UP:0 DOWN:0 LOWBAT:0 RSSI:0) (,RPTEN)
2014.06.04 11:11:37.058 4: CUL_Parse: cul868 A 0B 63 A258 1D252E D1D1D1 00000E -67
2014.06.04 11:11:37.324 4: RCV L:0B N:63 F:A2 CMD:58 SRC:Thermostat.Kueche DST:TCControler.Kueche 0000 (ClimateEvent CMD:0x00 ValvePos:0) (,WAKEMEUP,BIDI,RPTEN)
2014.06.04 11:11:37.410 0: HMLAN_Send:  hmusb1 S:S6625E406 stat:  00 t:00000000 d:01 r:6625E406 m:63 8002 D1D1D1 1D252E 0101000000
2014.06.04 11:11:37.634 0: HMLAN_Parse: hmusb1 R:E1D252E   stat:0000 t:00159924 d:FF r:FFC1     m:63 A258 1D252E D1D1D1 0000
2014.06.04 11:11:37.755 0: HMLAN_Parse: hmusb1 R:R6625E406 stat:0002 t:00000000 d:FF r:7FFF     m:63 8002 D1D1D1 1D252E 0101000000
2014.06.04 11:11:37.783 4: CUL_Parse: cul868 A 0E 63 8002 D1D1D1 1D252E 010100000060 -26
2014.06.04 11:11:37.798 4: RCV L:0E N:63 F:80 CMD:02 SRC:TCControler.Kueche DST:Thermostat.Kueche 0101000000 (ACK_STATUS CHANNEL:0x01 STATUS:0x00 UP:0 DOWN:0 LOWBAT:0 RSSI:0) (,RPTEN)
2014.06.04 11:12:00.016 1: Perfmon: possible freeze starting at 11:11:57, delay is 3.015
2014.06.04 11:12:00.026 0: HMLAN_Parse: hmusb1 R:E1936FF   stat:0000 t:0015ED99 d:FF r:FFC8     m:68 8670 1936FF 000000 00AE44
2014.06.04 11:12:00.098 1: #### start parser
2014.06.04 11:12:00.130 0: HMLAN_Send:  hmusb1 S:S66263CB0 stat:  00 t:00000000 d:01 r:66263CB0 m:0A A112 1ACE1F 1936FF
2014.06.04 11:12:00.210 4: CUL_Parse: cul868 A 0C 68 8670 1936FF 000000 00AE4401 -73.5
2014.06.04 11:12:00.448 4: CUL_Parse: cul868 A 09 0A A112 1ACE1F 1936FF 60 -26
2014.06.04 11:12:00.458 4: RCV L:09 N:0A F:A1 CMD:12 SRC:ccu DST:Thermostat.Bad  (HAVE_DATA) (,WAKEUP,BIDI,RPTEN)
2014.06.04 11:12:00.524 4: CUL_Parse: cul868 A 09 0A A112 1ACE1F 1936FF 60 -26
2014.06.04 11:12:00.576 4: CUL_Parse: cul868 A 09 0A A112 1ACE1F 1936FF 60 -26
2014.06.04 11:12:00.760 0: HMLAN_Parse: hmusb1 R:R66263CB0 stat:0008 t:00000000 d:FF r:7FFF     m:0A A112 1ACE1F 1936FF
2014.06.04 11:12:00.766 0: HMLAN_Parse: hmusb1 no ACK from 1936FF
2014.06.04 11:12:18.680 4: CUL_Parse: cul868 A 0B 68 A258 1936FF D3D3D3 0000FD -75.5
2014.06.04 11:12:18.920 4: RCV L:0B N:68 F:A2 CMD:58 SRC:Thermostat.Bad DST:TCControler.Bad 0000 (ClimateEvent CMD:0x00 ValvePos:0) (,WAKEMEUP,BIDI,RPTEN)
2014.06.04 11:12:18.983 0: HMLAN_Send:  hmusb1 S:S6626866A stat:  00 t:00000000 d:01 r:6626866A m:68 8002 D3D3D3 1936FF 0101000000
2014.06.04 11:12:19.200 0: HMLAN_Parse: hmusb1 R:E1936FF   stat:0000 t:00163BB8 d:FF r:FFC8     m:68 A258 1936FF D3D3D3 0000
2014.06.04 11:12:19.318 0: HMLAN_Parse: hmusb1 R:R6626866A stat:0002 t:00000000 d:FF r:7FFF     m:68 8002 D3D3D3 1936FF 0101000000
2014.06.04 11:12:19.321 4: CUL_Parse: cul868 A 0E 68 8002 D3D3D3 1936FF 010100000060 -26
2014.06.04 11:12:19.336 4: RCV L:0E N:68 F:80 CMD:02 SRC:TCControler.Bad DST:Thermostat.Bad 0101000000 (ACK_STATUS CHANNEL:0x01 STATUS:0x00 UP:0 DOWN:0 LOWBAT:0 RSSI:0) (,RPTEN)
2014.06.04 11:12:51.142 4: CUL_Parse: cul868 A 14 6E 845E 24AF1D 000000 804EA10001A60017094BFF0C -68
2014.06.04 11:12:51.383 4: RCV L:14 N:6E F:84 CMD:5E SRC:SwitchES01 DST:broadcast 804EA10001A60017094BFF (powerEvntCyc energy:840873.7 power:4.22 current:23 voltage:237.9 frequency:52.55) (,CFG,RPTEN)
2014.06.04 11:12:58.717 4: CUL_Parse: cul868 A 0C 9C 8670 1BF81B 000000 00C43A24 -56
2014.06.04 11:12:58.958 4: RCV L:0C N:9C F:86 CMD:70 SRC:Thermostat.WZ DST:broadcast 00C43A (WeatherEvent TEMP:19.6 HUM:58) (,WAKEMEUP,CFG,RPTEN)
2014.06.04 11:12:59.023 0: HMLAN_Send:  hmusb1 S:S662722D2 stat:  00 t:00000000 d:01 r:662722D2 m:0B A112 1ACE1F 1BF81B
2014.06.04 11:12:59.234 0: HMLAN_Parse: hmusb1 R:E1BF81B   stat:0000 t:0016D81C d:FF r:FFC2     m:9C 8670 1BF81B 000000 00C43A
2014.06.04 11:12:59.249 0: HMLAN_Parse: hmusb1 R:R6626866A stat:0081 t:0016D91F d:FF r:FFC2     m:9C 8002 1BF81B 1ACE1F 00
2014.06.04 11:12:59.326 0: HMLAN_Parse: hmusb1 R:R662722D2 stat:0001 t:0016D9F7 d:FF r:FFC2     m:0B 8002 1BF81B 1ACE1F 00
2014.06.04 11:12:59.430 0: HMLAN_Send:  hmusb1 S:S6627244A stat:  00 t:00000000 d:01 r:6627244A m:0C A001 1ACE1F 1BF81B 010E
2014.06.04 11:12:59.541 4: CUL_Parse: cul868 A 09 9C A112 1ACE1F 1BF81B 60 -26
2014.06.04 11:13:00.020 4: RCV L:09 N:9C F:A1 CMD:12 SRC:ccu DST:Thermostat.WZ  (HAVE_DATA) (,WAKEUP,BIDI,RPTEN)
2014.06.04 11:13:00.083 4: CUL_Parse: cul868 A 0A 9C 8002 1BF81B 1ACE1F 0024 -56
2014.06.04 11:13:00.095 4: RCV L:0A N:9C F:80 CMD:02 SRC:Thermostat.WZ DST:ccu 00 (ACK) (,RPTEN)
2014.06.04 11:13:00.157 4: CUL_Parse: cul868 A 09 0B A112 1ACE1F 1BF81B 60 -26
2014.06.04 11:13:00.166 4: RCV L:09 N:0B F:A1 CMD:12 SRC:ccu DST:Thermostat.WZ  (HAVE_DATA) (,WAKEUP,BIDI,RPTEN)
2014.06.04 11:13:00.228 4: CUL_Parse: cul868 A 0A 0B 8002 1BF81B 1ACE1F 0024 -56
2014.06.04 11:13:00.238 4: RCV L:0A N:0B F:80 CMD:02 SRC:Thermostat.WZ DST:ccu 00 (ACK) (,RPTEN)
2014.06.04 11:13:00.304 4: CUL_Parse: cul868 A 0B 0C A001 1ACE1F 1BF81B 010E60 -26
2014.06.04 11:13:00.313 4: RCV L:0B N:0C F:A0 CMD:01 SRC:ccu DST:Thermostat.WZ 010E (CONFIG_STATUS_REQUEST CHANNEL:0x01) (,BIDI,RPTEN)
2014.06.04 11:13:03.492 1: Perfmon: possible freeze starting at 11:13:00, delay is 3.491
2014.06.04 11:13:03.514 0: HMLAN_Parse: hmusb1 R:R6627244A stat:0001 t:0016DB9A d:FF r:FFC2     m:0C 8002 1BF81B 1ACE1F 01020C003C
2014.06.04 11:13:03.620 0: HMLAN_Send:  hmusb1 S:S662734B6 stat:  00 t:00000000 d:01 r:662734B6 m:0D A001 1ACE1F 1BF81B 010E
2014.06.04 11:13:03.701 4: CUL_Parse: cul868 A 0E 0C 8002 1BF81B 1ACE1F 01020C003C24 -56
2014.06.04 11:13:03.940 4: CUL_Parse: cul868 A 0B 0D A001 1ACE1F 1BF81B 010E60 -26
2014.06.04 11:13:03.950 4: RCV L:0B N:0D F:A0 CMD:01 SRC:ccu DST:Thermostat.WZ 010E (CONFIG_STATUS_REQUEST CHANNEL:0x01) (,BIDI,RPTEN)
2014.06.04 11:13:04.029 4: CUL_Parse: cul868 A 0B 0D A001 1ACE1F 1BF81B 010E60 -26
2014.06.04 11:13:04.064 4: CUL_Parse: cul868 A 0B 0D A001 1ACE1F 1BF81B 010E60 -26
2014.06.04 11:13:04.247 0: HMLAN_Parse: hmusb1 R:R662734B6 stat:0008 t:00000000 d:FF r:7FFF     m:0D A001 1ACE1F 1BF81B 010E
2014.06.04 11:13:04.251 0: HMLAN_Parse: hmusb1 no ACK from 1BF81B
2014.06.04 11:13:18.717 4: CUL_Parse: cul868 A 0B 9C A258 1BF81B D4D4D4 000024 -56
2014.06.04 11:13:18.955 4: RCV L:0B N:9C F:A2 CMD:58 SRC:Thermostat.WZ DST:TCControler.WZ 0000 (ClimateEvent CMD:0x00 ValvePos:0) (,WAKEMEUP,BIDI,RPTEN)
2014.06.04 11:13:19.021 0: HMLAN_Send:  hmusb1 S:S662770F0 stat:  00 t:00000000 d:01 r:662770F0 m:9C 8002 D4D4D4 1BF81B 0101000000
2014.06.04 11:13:19.235 0: HMLAN_Parse: hmusb1 R:E1BF81B   stat:0000 t:0017263C d:FF r:FFC1     m:9C A258 1BF81B D4D4D4 0000
2014.06.04 11:13:19.351 0: HMLAN_Parse: hmusb1 R:R662770F0 stat:0002 t:00000000 d:FF r:7FFF     m:9C 8002 D4D4D4 1BF81B 0101000000
2014.06.04 11:13:19.355 4: CUL_Parse: cul868 A 0E 9C 8002 D4D4D4 1BF81B 010100000060 -26
2014.06.04 11:13:19.370 4: RCV L:0E N:9C F:80 CMD:02 SRC:TCControler.WZ DST:Thermostat.WZ 0101000000 (ACK_STATUS CHANNEL:0x01 STATUS:0x00 UP:0 DOWN:0 LOWBAT:0 RSSI:0) (,RPTEN)
2014.06.04 11:13:50.612 4: CUL_Parse: cul868 A 0C 39 8670 1DFDA5 000000 00C93F17 -62.5
2014.06.04 11:13:50.856 4: RCV L:0C N:39 F:86 CMD:70 SRC:Thermostat.SZ DST:broadcast 00C93F (WeatherEvent TEMP:20.1 HUM:63) (,WAKEMEUP,CFG,RPTEN)
2014.06.04 11:13:50.922 0: HMLAN_Send:  hmusb1 S:S6627ED8D stat:  00 t:00000000 d:01 r:6627ED8D m:0E A112 1ACE1F 1DFDA5
2014.06.04 11:13:51.136 0: HMLAN_Parse: hmusb1 R:E1DFDA5   stat:0000 t:0017A2D2 d:FF r:FFC3     m:39 8670 1DFDA5 000000 00C93F
2014.06.04 11:13:51.149 0: HMLAN_Parse: hmusb1 R:R662770F0 stat:0081 t:0017A3D5 d:FF r:FFC3     m:39 8002 1DFDA5 1ACE1F 00
2014.06.04 11:13:51.223 0: HMLAN_Parse: hmusb1 R:R6627ED8D stat:0001 t:0017A4B7 d:FF r:FFC3     m:0E 8002 1DFDA5 1ACE1F 00
2014.06.04 11:13:51.394 0: HMLAN_Send:  hmusb1 S:S6627EF66 stat:  00 t:00000000 d:01 r:6627EF66 m:0F A001 1ACE1F 1DFDA5 010E
2014.06.04 11:13:51.574 4: CUL_Parse: cul868 A 09 39 A112 1ACE1F 1DFDA5 60 -26
2014.06.04 11:13:51.890 4: RCV L:09 N:39 F:A1 CMD:12 SRC:ccu DST:Thermostat.SZ  (HAVE_DATA) (,WAKEUP,BIDI,RPTEN)
2014.06.04 11:13:51.952 4: CUL_Parse: cul868 A 0A 39 8002 1DFDA5 1ACE1F 0017 -62.5
2014.06.04 11:13:51.963 4: RCV L:0A N:39 F:80 CMD:02 SRC:Thermostat.SZ DST:ccu 00 (ACK) (,RPTEN)
2014.06.04 11:13:52.025 4: CUL_Parse: cul868 A 09 0E A112 1ACE1F 1DFDA5 60 -26
2014.06.04 11:13:52.034 4: RCV L:09 N:0E F:A1 CMD:12 SRC:ccu DST:Thermostat.SZ  (HAVE_DATA) (,WAKEUP,BIDI,RPTEN)
2014.06.04 11:13:52.097 4: CUL_Parse: cul868 A 0A 0E 8002 1DFDA5 1ACE1F 0017 -62.5
2014.06.04 11:13:52.108 4: RCV L:0A N:0E F:80 CMD:02 SRC:Thermostat.SZ DST:ccu 00 (ACK) (,RPTEN)
2014.06.04 11:13:52.169 4: CUL_Parse: cul868 A 0C 64 8670 1D252E 000000 00BA3F0E -67
2014.06.04 11:13:52.183 4: RCV L:0C N:64 F:86 CMD:70 SRC:Thermostat.Kueche DST:broadcast 00BA3F (WeatherEvent TEMP:18.6 HUM:63) (,WAKEMEUP,CFG,RPTEN)
2014.06.04 11:13:52.272 4: CUL_send:  cul868As 09 01 A112 1ACE1F 1D252E
2014.06.04 11:13:52.288 4: SND L:09 N:01 F:A1 CMD:12 SRC:ccu DST:Thermostat.Kueche  (HAVE_DATA) (,WAKEUP,BIDI,RPTEN)
2014.06.04 11:13:52.359 4: CUL_Parse: cul868 A 09 64 A112 1ACE1F 1D252E 60 -26
2014.06.04 11:13:52.368 4: RCV L:09 N:64 F:A1 CMD:12 SRC:ccu DST:Thermostat.Kueche  (HAVE_DATA) (,WAKEUP,BIDI,RPTEN)
2014.06.04 11:13:52.430 4: CUL_Parse: cul868 A 0B 0F A001 1ACE1F 1DFDA5 010E60 -26
2014.06.04 11:13:52.440 4: RCV L:0B N:0F F:A0 CMD:01 SRC:ccu DST:Thermostat.SZ 010E (CONFIG_STATUS_REQUEST CHANNEL:0x01) (,BIDI,RPTEN)
2014.06.04 11:13:52.518 0: HMLAN_Parse: hmusb1 R:E1D252E   stat:0000 t:0017A591 d:FF r:FFC4     m:64 8670 1D252E 000000 00BA3F
2014.06.04 11:13:52.532 0: HMLAN_Parse: hmusb1 R:R6627ED8D stat:0081 t:0017A69A d:FF r:FFC3     m:64 8002 1D252E 1ACE1F 00
2014.06.04 11:13:52.617 0: HMLAN_Parse: hmusb1 R:R6627EF66 stat:0001 t:0017A774 d:FF r:FFC3     m:0F 8002 1DFDA5 1ACE1F 01020C003C
2014.06.04 11:13:52.722 0: HMLAN_Send:  hmusb1 S:+1DFDA5,02,01,00
2014.06.04 11:13:52.725 0: HMLAN_Send:  hmusb1 S:S6627F481 stat:  00 t:00000000 d:01 r:6627F481 m:10 A001 1ACE1F 1DFDA5 020E
2014.06.04 11:13:52.803 0: HMLAN_Parse: hmusb1 R:E1ACE1F   stat:0000 t:0017A96C d:FF r:FFE6     m:01 A112 1ACE1F 1D252E
2014.06.04 11:13:52.929 4: CUL_Parse: cul868 A 0E 0F 8002 1DFDA5 1ACE1F 01020C003C17 -62.5
2014.06.04 11:13:53.174 4: CUL_Parse: cul868 A 0B 0F A001 1ACE1F 1DFDA5 010E60 -26
2014.06.04 11:13:53.185 4: RCV L:0B N:0F F:A0 CMD:01 SRC:ccu DST:Thermostat.SZ 010E (CONFIG_STATUS_REQUEST CHANNEL:0x01) (,BIDI,RPTEN)
2014.06.04 11:13:53.307 4: CUL_Parse: cul868 A 0E 0F 8002 1DFDA5 1ACE1F 01020C003C18 -62
2014.06.04 11:13:53.320 4: CUL_Parse: cul868 A 0A 01 8002 1D252E 1ACE1F 000D -67.5
2014.06.04 11:13:53.331 4: RCV L:0A N:01 F:80 CMD:02 SRC:Thermostat.Kueche DST:ccu 00 (ACK) (,RPTEN)
2014.06.04 11:13:53.422 4: CUL_send:  cul868As 0B 02 A001 1ACE1F 1D252E 010E
2014.06.04 11:13:53.438 4: SND L:0B N:02 F:A0 CMD:01 SRC:ccu DST:Thermostat.Kueche 010E (CONFIG_STATUS_REQUEST CHANNEL:0x01) (,BIDI,RPTEN)
2014.06.04 11:13:53.502 4: CUL_Parse: cul868 A 0B 10 A001 1ACE1F 1DFDA5 020E60 -26
2014.06.04 11:13:53.512 4: RCV L:0B N:10 F:A0 CMD:01 SRC:ccu DST:Thermostat.SZ 020E (CONFIG_STATUS_REQUEST CHANNEL:0x02) (,BIDI,RPTEN)
2014.06.04 11:13:53.595 0: HMLAN_Parse: hmusb1 R:E1D252E   stat:0000 t:0017A9F6 d:FF r:FFC4     m:01 8002 1D252E 1ACE1F 00
2014.06.04 11:13:53.609 0: HMLAN_Parse: hmusb1 R:R6627F481 stat:0008 t:00000000 d:FF r:7FFF     m:10 A001 1ACE1F 1DFDA5 020E
2014.06.04 11:13:53.626 0: HMLAN_Parse: hmusb1 no ACK from 1DFDA5
2014.06.04 11:13:53.629 0: HMLAN_Parse: hmusb1 R:E1ACE1F   stat:0000 t:0017ADEC d:FF r:FFE6     m:02 A001 1ACE1F 1D252E 010E
2014.06.04 11:13:53.705 4: CUL_Parse: cul868 A 0B 10 A001 1ACE1F 1DFDA5 020E61 -25.5
2014.06.04 11:13:53.942 4: RCV L:0B N:10 F:A0 CMD:01 SRC:ccu DST:Thermostat.SZ 020E (CONFIG_STATUS_REQUEST CHANNEL:0x02) (,BIDI,RPTEN)
2014.06.04 11:13:54.056 4: CUL_Parse: cul868 A 0B 10 A001 1ACE1F 1DFDA5 020E60 -26
2014.06.04 11:13:54.121 4: CUL_Parse: cul868 A 0E 02 8002 1D252E 1ACE1F 01020C00410D -67.5
2014.06.04 11:13:54.136 4: RCV L:0E N:02 F:80 CMD:02 SRC:Thermostat.Kueche DST:ccu 01020C0041 (ACK_STATUS CHANNEL:0x02 STATUS:0x0C UP:0 DOWN:0 LOWBAT:0 RSSI:-65) (,RPTEN)
2014.06.04 11:13:54.223 4: CUL_send:  cul868As 0B 03 A001 1ACE1F 1D252E 020E
2014.06.04 11:13:54.239 4: SND L:0B N:03 F:A0 CMD:01 SRC:ccu DST:Thermostat.Kueche 020E (CONFIG_STATUS_REQUEST CHANNEL:0x02) (,BIDI,RPTEN)
2014.06.04 11:13:54.333 0: HMLAN_Parse: hmusb1 R:E1D252E   stat:0000 t:0017AE78 d:FF r:FFC4     m:02 8002 1D252E 1ACE1F 01020C0041
2014.06.04 11:13:54.346 0: HMLAN_Parse: hmusb1 R:E1ACE1F   stat:0000 t:0017B10D d:FF r:FFE6     m:03 A001 1ACE1F 1D252E 020E
2014.06.04 11:13:54.425 0: HMLAN_Parse: hmusb1 R:E1D252E   stat:0000 t:0017B199 d:FF r:FFC4     m:03 8002 1D252E 1ACE1F 01020C0041
2014.06.04 11:13:54.529 4: CUL_send:  cul868As 0B 04 A001 1ACE1F 1D252E 030E
2014.06.04 11:13:54.544 4: SND L:0B N:04 F:A0 CMD:01 SRC:ccu DST:Thermostat.Kueche 030E (CONFIG_STATUS_REQUEST CHANNEL:0x03) (,BIDI,RPTEN)
2014.06.04 11:13:54.617 4: CUL_Parse: cul868 A 0E 03 8002 1D252E 1ACE1F 01020C00410E -67
2014.06.04 11:13:54.655 0: HMLAN_Parse: hmusb1 R:E1ACE1F   stat:0000 t:0017B23E d:FF r:FFE6     m:04 A001 1ACE1F 1D252E 030E
2014.06.04 11:13:54.732 0: HMLAN_Parse: hmusb1 R:E1D252E   stat:0000 t:0017B2CA d:FF r:FFC4     m:04 8002 1D252E 1ACE1F 01020C0041
2014.06.04 11:13:54.828 4: CUL_Parse: cul868 A 0E 04 8002 1D252E 1ACE1F 01020C00410D -67.5
2014.06.04 11:14:06.441 1: Perfmon: possible freeze starting at 11:14:04, delay is 2.44
2014.06.04 11:14:10.611 4: CUL_Parse: cul868 A 0B 39 A258 1DFDA5 D2D2D2 000018 -62
2014.06.04 11:14:10.855 4: RCV L:0B N:39 F:A2 CMD:58 SRC:Thermostat.SZ DST:TCControler.SZ 0000 (ClimateEvent CMD:0x00 ValvePos:0) (,WAKEMEUP,BIDI,RPTEN)
2014.06.04 11:14:10.918 0: HMLAN_Send:  hmusb1 S:+1DFDA5,02,01,00
2014.06.04 11:14:10.920 0: HMLAN_Send:  hmusb1 S:S66283BAA stat:  00 t:00000000 d:01 r:66283BAA m:39 8002 D2D2D2 1DFDA5 0101000000
2014.06.04 11:14:11.140 0: HMLAN_Parse: hmusb1 R:E1DFDA5   stat:0000 t:0017F0F1 d:FF r:FFC2     m:39 A258 1DFDA5 D2D2D2 0000
2014.06.04 11:14:11.255 0: HMLAN_Parse: hmusb1 R:R66283BAA stat:0002 t:00000000 d:FF r:7FFF     m:39 8002 D2D2D2 1DFDA5 0101000000
2014.06.04 11:14:11.259 4: CUL_Parse: cul868 A 0E 39 8002 D2D2D2 1DFDA5 010100000060 -26
2014.06.04 11:14:11.273 4: RCV L:0E N:39 F:80 CMD:02 SRC:TCControler.SZ DST:Thermostat.SZ 0101000000 (ACK_STATUS CHANNEL:0x01 STATUS:0x00 UP:0 DOWN:0 LOWBAT:0 RSSI:0) (,RPTEN)
2014.06.04 11:14:11.361 0: HMLAN_Parse: hmusb1 R:E1D252E   stat:0000 t:0017F3B0 d:FF r:FFC3     m:64 A258 1D252E D1D1D1 0000
2014.06.04 11:14:11.464 0: HMLAN_Send:  hmusb1 S:+1D252E,00,01,00
2014.06.04 11:14:11.466 0: HMLAN_Send:  hmusb1 S:S66283DB1 stat:  00 t:00000000 d:01 r:66283DB1 m:64 8002 D1D1D1 1D252E 0101000000
2014.06.04 11:14:11.686 4: CUL_Parse: cul868 A 0B 64 A258 1D252E D1D1D1 00000E -67
2014.06.04 11:14:11.699 4: CUL_Parse: cul868 A 0E 64 8002 D1D1D1 1D252E 010100000060 -26
2014.06.04 11:14:11.713 4: RCV L:0E N:64 F:80 CMD:02 SRC:TCControler.Kueche DST:Thermostat.Kueche 0101000000 (ACK_STATUS CHANNEL:0x01 STATUS:0x00 UP:0 DOWN:0 LOWBAT:0 RSSI:0) (,RPTEN)
2014.06.04 11:14:11.800 0: HMLAN_Parse: hmusb1 R:R66283DB1 stat:0002 t:00000000 d:FF r:7FFF     m:64 8002 D1D1D1 1D252E 0101000000
2014.06.04 11:14:41.695 4: CUL_Parse: cul868 A 0C 69 8670 1936FF 000000 00AE4402 -73
2014.06.04 11:14:41.965 4: RCV L:0C N:69 F:86 CMD:70 SRC:Thermostat.Bad DST:broadcast 00AE44 (WeatherEvent TEMP:17.4 HUM:68) (,WAKEMEUP,CFG,RPTEN)
2014.06.04 11:14:42.061 0: HMLAN_Send:  hmusb1 S:S6628B550 stat:  00 t:00000000 d:01 r:6628B550 m:11 A112 1ACE1F 1936FF
2014.06.04 11:14:42.157 0: HMLAN_Parse: hmusb1 R:E1936FF   stat:0000 t:00186A51 d:FF r:FFC8     m:69 8670 1936FF 000000 00AE44
2014.06.04 11:14:42.276 0: HMLAN_Parse: hmusb1 R:R66283DB1 stat:0081 t:00186B53 d:FF r:FFC8     m:69 8002 1936FF 1ACE1F 00
2014.06.04 11:14:42.378 4: CUL_Parse: cul868 A 09 69 A112 1ACE1F 1936FF 60 -26
2014.06.04 11:14:42.613 4: RCV L:09 N:69 F:A1 CMD:12 SRC:ccu DST:Thermostat.Bad  (HAVE_DATA) (,WAKEUP,BIDI,RPTEN)
2014.06.04 11:14:42.680 4: CUL_Parse: cul868 A 0A 69 8002 1936FF 1ACE1F 0000 -74
2014.06.04 11:14:42.693 4: CUL_Parse: cul868 A 09 11 A112 1ACE1F 1936FF 60 -26
2014.06.04 11:14:42.702 4: RCV L:09 N:11 F:A1 CMD:12 SRC:ccu DST:Thermostat.Bad  (HAVE_DATA) (,WAKEUP,BIDI,RPTEN)
2014.06.04 11:14:42.825 4: CUL_Parse: cul868 A 0A 11 8002 1936FF 1ACE1F 0002 -73
2014.06.04 11:14:42.835 4: RCV L:0A N:11 F:80 CMD:02 SRC:Thermostat.Bad DST:ccu 00 (ACK) (,RPTEN)
2014.06.04 11:14:42.930 0: HMLAN_Send:  hmusb1 S:S6628B896 stat:  00 t:00000000 d:01 r:6628B896 m:12 A001 1ACE1F 1936FF 010E
2014.06.04 11:14:43.099 0: HMLAN_Parse: hmusb1 R:R6628B550 stat:0001 t:00186C72 d:FF r:FFC8     m:11 8002 1936FF 1ACE1F 00
2014.06.04 11:14:43.131 4: CUL_Parse: cul868 A 0B 12 A001 1ACE1F 1936FF 010E60 -26
2014.06.04 11:14:43.141 4: RCV L:0B N:12 F:A0 CMD:01 SRC:ccu DST:Thermostat.Bad 010E (CONFIG_STATUS_REQUEST CHANNEL:0x01) (,BIDI,RPTEN)
2014.06.04 11:14:43.329 0: HMLAN_Parse: hmusb1 R:R6628B896 stat:0001 t:00186FF5 d:FF r:FFC8     m:12 8002 1936FF 1ACE1F 01020C0038
2014.06.04 11:14:43.542 0: HMLAN_Send:  hmusb1 S:+1936FF,02,01,00
2014.06.04 11:14:43.544 0: HMLAN_Send:  hmusb1 S:S6628BB07 stat:  00 t:00000000 d:01 r:6628BB07 m:13 A001 1ACE1F 1936FF 020E
2014.06.04 11:14:43.639 4: CUL_Parse: cul868 A 0E 12 8002 1936FF 1ACE1F 01020C003801 -73.5
2014.06.04 11:14:43.932 0: HMLAN_Parse: hmusb1 R:R6628BB07 stat:0001 t:00187295 d:FF r:FFC7     m:13 8002 1936FF 1ACE1F 01020C0038
2014.06.04 11:14:44.086 0: HMLAN_Send:  hmusb1 S:+1936FF,02,01,00
2014.06.04 11:14:44.088 0: HMLAN_Send:  hmusb1 S:S6628BD39 stat:  00 t:00000000 d:01 r:6628BD39 m:14 A001 1ACE1F 1936FF 030E
2014.06.04 11:14:44.168 4: CUL_Parse: cul868 A 0B 13 A001 1ACE1F 1936FF 020E60 -26
2014.06.04 11:14:44.178 4: RCV L:0B N:13 F:A0 CMD:01 SRC:ccu DST:Thermostat.Bad 020E (CONFIG_STATUS_REQUEST CHANNEL:0x02) (,BIDI,RPTEN)
2014.06.04 11:14:44.246 4: CUL_Parse: cul868 A 0E 13 8002 1936FF 1ACE1F 01020C0038FF -74.5
2014.06.04 11:14:44.276 4: CUL_Parse: cul868 A 0B 14 A001 1ACE1F 1936FF 030E60 -26
2014.06.04 11:14:44.286 4: RCV L:0B N:14 F:A0 CMD:01 SRC:ccu DST:Thermostat.Bad 030E (CONFIG_STATUS_REQUEST CHANNEL:0x03) (,BIDI,RPTEN)
2014.06.04 11:14:44.399 0: HMLAN_Parse: hmusb1 R:R6628BD39 stat:0001 t:001874B4 d:FF r:FFC8     m:14 8002 1936FF 1ACE1F 01020C0038
2014.06.04 11:14:44.500 4: CUL_Parse: cul868 A 0E 14 8002 1936FF 1ACE1F 01020C0038FE -75
2014.06.04 11:15:01.683 4: CUL_Parse: cul868 A 0B 69 A258 1936FF D3D3D3 0000FE -75
2014.06.04 11:15:01.920 4: RCV L:0B N:69 F:A2 CMD:58 SRC:Thermostat.Bad DST:TCControler.Bad 0000 (ClimateEvent CMD:0x00 ValvePos:0) (,WAKEMEUP,BIDI,RPTEN)
2014.06.04 11:15:01.983 0: HMLAN_Send:  hmusb1 S:+1936FF,00,01,00
2014.06.04 11:15:01.986 0: HMLAN_Send:  hmusb1 S:S66290323 stat:  00 t:00000000 d:01 r:66290323 m:69 8002 D3D3D3 1936FF 0101000000
2014.06.04 11:15:02.202 0: HMLAN_Parse: hmusb1 R:E1936FF   stat:0000 t:0018B86F d:FF r:FFC8     m:69 A258 1936FF D3D3D3 0000
2014.06.04 11:15:02.318 0: HMLAN_Parse: hmusb1 R:R66290323 stat:0002 t:00000000 d:FF r:7FFF     m:69 8002 D3D3D3 1936FF 0101000000
2014.06.04 11:15:02.321 4: CUL_Parse: cul868 A 0E 69 8002 D3D3D3 1936FF 010100000060 -26
2014.06.04 11:15:02.336 4: RCV L:0E N:69 F:80 CMD:02 SRC:TCControler.Bad DST:Thermostat.Bad 0101000000 (ACK_STATUS CHANNEL:0x01 STATUS:0x00 UP:0 DOWN:0 LOWBAT:0 RSSI:0) (,RPTEN)
2014.06.04 11:15:09.602 1: Perfmon: possible freeze starting at 11:15:07, delay is 2.601
2014.06.04 11:15:29.893 4: CUL_Parse: cul868 A 14 6F 845E 24AF1D 000000 804EA30001AF00180965FE0D -67.5
2014.06.04 11:15:30.136 4: RCV L:14 N:6F F:84 CMD:5E SRC:SwitchES01 DST:broadcast 804EA30001AF00180965FE (powerEvntCyc energy:840873.9 power:4.31 current:24 voltage:240.5 frequency:52.54) (,CFG,RPTEN)
2014.06.04 11:15:43.973 4: CUL_Parse: cul868 A 0C 9D 8670 1BF81B 000000 00C63B23 -56.5
2014.06.04 11:15:44.217 4: RCV L:0C N:9D F:86 CMD:70 SRC:Thermostat.WZ DST:broadcast 00C63B (WeatherEvent TEMP:19.8 HUM:59) (,WAKEMEUP,CFG,RPTEN)
2014.06.04 11:15:44.281 0: HMLAN_Send:  hmusb1 S:S6629A85D stat:  00 t:00000000 d:01 r:6629A85D m:15 A112 1ACE1F 1BF81B
2014.06.04 11:15:44.501 0: HMLAN_Parse: hmusb1 R:E1BF81B   stat:0000 t:00195DA0 d:FF r:FFC1     m:9D 8670 1BF81B 000000 00C63B
2014.06.04 11:15:44.514 0: HMLAN_Parse: hmusb1 R:R66290323 stat:0081 t:00195EA3 d:FF r:FFC1     m:9D 8002 1BF81B 1ACE1F 00
2014.06.04 11:15:44.589 0: HMLAN_Parse: hmusb1 R:R6629A85D stat:0001 t:00195F90 d:FF r:FFC1     m:15 8002 1BF81B 1ACE1F 00
2014.06.04 11:15:44.693 0: HMLAN_Send:  hmusb1 S:S6629A9DD stat:  00 t:00000000 d:01 r:6629A9DD m:16 A001 1ACE1F 1BF81B 010E
2014.06.04 11:15:44.767 4: CUL_Parse: cul868 A 09 9D A112 1ACE1F 1BF81B 60 -26
2014.06.04 11:15:44.777 4: RCV L:09 N:9D F:A1 CMD:12 SRC:ccu DST:Thermostat.WZ  (HAVE_DATA) (,WAKEUP,BIDI,RPTEN)
2014.06.04 11:15:44.840 4: CUL_Parse: cul868 A 0A 9D 8002 1BF81B 1ACE1F 0023 -56.5
2014.06.04 11:15:44.850 4: RCV L:0A N:9D F:80 CMD:02 SRC:Thermostat.WZ DST:ccu 00 (ACK) (,RPTEN)
2014.06.04 11:15:44.912 4: CUL_Parse: cul868 A 09 15 A112 1ACE1F 1BF81B 60 -26
2014.06.04 11:15:44.923 4: RCV L:09 N:15 F:A1 CMD:12 SRC:ccu DST:Thermostat.WZ  (HAVE_DATA) (,WAKEUP,BIDI,RPTEN)
2014.06.04 11:15:44.983 4: CUL_Parse: cul868 A 0A 15 8002 1BF81B 1ACE1F 0023 -56.5
2014.06.04 11:15:44.994 4: RCV L:0A N:15 F:80 CMD:02 SRC:Thermostat.WZ DST:ccu 00 (ACK) (,RPTEN)
2014.06.04 11:15:45.056 4: CUL_Parse: cul868 A 0B 16 A001 1ACE1F 1BF81B 010E60 -26
2014.06.04 11:15:45.066 4: RCV L:0B N:16 F:A0 CMD:01 SRC:ccu DST:Thermostat.WZ 010E (CONFIG_STATUS_REQUEST CHANNEL:0x01) (,BIDI,RPTEN)
2014.06.04 11:15:45.154 0: HMLAN_Parse: hmusb1 R:R6629A9DD stat:0001 t:00196133 d:FF r:FFC1     m:16 8002 1BF81B 1ACE1F 01020C003E
2014.06.04 11:15:45.298 0: HMLAN_Send:  hmusb1 S:+1BF81B,02,01,00
2014.06.04 11:15:45.323 0: HMLAN_Send:  hmusb1 S:S6629AC56 stat:  00 t:00000000 d:01 r:6629AC56 m:17 A001 1ACE1F 1BF81B 020E
2014.06.04 11:15:45.505 4: CUL_Parse: cul868 A 0E 16 8002 1BF81B 1ACE1F 01020C003E23 -56.5
2014.06.04 11:15:45.849 4: CUL_Parse: cul868 A 0B 17 A001 1ACE1F 1BF81B 020E60 -26
2014.06.04 11:15:45.859 4: RCV L:0B N:17 F:A0 CMD:01 SRC:ccu DST:Thermostat.WZ 020E (CONFIG_STATUS_REQUEST CHANNEL:0x02) (,BIDI,RPTEN)
2014.06.04 11:15:45.937 0: HMLAN_Parse: hmusb1 R:R6629AC56 stat:0001 t:001963D3 d:FF r:FFC1     m:17 8002 1BF81B 1ACE1F 01020C003E
2014.06.04 11:15:46.043 0: HMLAN_Send:  hmusb1 S:+1BF81B,02,01,00
2014.06.04 11:15:46.046 0: HMLAN_Send:  hmusb1 S:S6629AF28 stat:  00 t:00000000 d:01 r:6629AF28 m:18 A001 1ACE1F 1BF81B 030E
2014.06.04 11:15:46.126 4: CUL_Parse: cul868 A 0E 17 8002 1BF81B 1ACE1F 01020C003E24 -56
2014.06.04 11:15:46.157 4: CUL_Parse: cul868 A 0B 18 A001 1ACE1F 1BF81B 030E60 -26
2014.06.04 11:15:46.396 4: RCV L:0B N:18 F:A0 CMD:01 SRC:ccu DST:Thermostat.WZ 030E (CONFIG_STATUS_REQUEST CHANNEL:0x03) (,BIDI,RPTEN)
2014.06.04 11:15:46.473 0: HMLAN_Parse: hmusb1 R:R6629AF28 stat:0001 t:001966B3 d:FF r:FFC1     m:18 8002 1BF81B 1ACE1F 01020C003E
2014.06.04 11:15:46.575 4: CUL_Parse: cul868 A 0E 18 8002 1BF81B 1ACE1F 01020C003E23 -56.5
2014.06.04 11:16:03.972 4: CUL_Parse: cul868 A 0B 9D A258 1BF81B D4D4D4 000023 -56.5
2014.06.04 11:16:04.211 4: RCV L:0B N:9D F:A2 CMD:58 SRC:Thermostat.WZ DST:TCControler.WZ 0000 (ClimateEvent CMD:0x00 ValvePos:0) (,WAKEMEUP,BIDI,RPTEN)
2014.06.04 11:16:04.276 0: HMLAN_Send:  hmusb1 S:+1BF81B,00,01,00
2014.06.04 11:16:04.279 0: HMLAN_Send:  hmusb1 S:S6629F678 stat:  00 t:00000000 d:01 r:6629F678 m:9D 8002 D4D4D4 1BF81B 0101000000
2014.06.04 11:16:04.499 0: HMLAN_Parse: hmusb1 R:E1BF81B   stat:0000 t:0019ABBF d:FF r:FFC1     m:9D A258 1BF81B D4D4D4 0000
2014.06.04 11:16:04.616 0: HMLAN_Parse: hmusb1 R:R6629F678 stat:0002 t:00000000 d:FF r:7FFF     m:9D 8002 D4D4D4 1BF81B 0101000000
2014.06.04 11:16:04.619 4: CUL_Parse: cul868 A 0E 9D 8002 D4D4D4 1BF81B 010100000060 -26
2014.06.04 11:16:04.872 4: RCV L:0E N:9D F:80 CMD:02 SRC:TCControler.WZ DST:Thermostat.WZ 0101000000 (ACK_STATUS CHANNEL:0x01 STATUS:0x00 UP:0 DOWN:0 LOWBAT:0 RSSI:0) (,RPTEN)
2014.06.04 11:16:12.941 1: Perfmon: possible freeze starting at 11:16:10, delay is 2.94
2014.06.04 11:16:12.954 0: HMLAN_Parse: hmusb1 R:E1D252E   stat:0000 t:0019C778 d:FF r:FFC5     m:65 8670 1D252E 000000 00BB3F
2014.06.04 11:16:13.161 4: CUL_Parse: cul868 A 0C 65 8670 1D252E 000000 00BB3F0E -67
2014.06.04 11:16:17.617 4: CUL_Parse: cul868 A 0C 3A 8670 1DFDA5 000000 00C93F17 -62.5
2014.06.04 11:16:17.859 4: RCV L:0C N:3A F:86 CMD:70 SRC:Thermostat.SZ DST:broadcast 00C93F (WeatherEvent TEMP:20.1 HUM:63) (,WAKEMEUP,CFG,RPTEN)
2014.06.04 11:16:17.923 0: HMLAN_Send:  hmusb1 S:S662A2BC7 stat:  00 t:00000000 d:01 r:662A2BC7 m:19 A112 1ACE1F 1DFDA5
2014.06.04 11:16:18.074 0: HMLAN_Parse: hmusb1 R:E1DFDA5   stat:0000 t:0019E10B d:FF r:FFC3     m:3A 8670 1DFDA5 000000 00C93F
2014.06.04 11:16:18.089 0: HMLAN_Parse: hmusb1 R:R6629F678 stat:0081 t:0019E20E d:FF r:FFC3     m:3A 8002 1DFDA5 1ACE1F 00
2014.06.04 11:16:18.166 4: CUL_Parse: cul868 A 09 3A A112 1ACE1F 1DFDA5 60 -26
2014.06.04 11:16:18.402 4: RCV L:09 N:3A F:A1 CMD:12 SRC:ccu DST:Thermostat.SZ  (HAVE_DATA) (,WAKEUP,BIDI,RPTEN)
2014.06.04 11:16:18.463 4: CUL_Parse: cul868 A 0A 3A 8002 1DFDA5 1ACE1F 0018 -62
2014.06.04 11:16:18.475 4: CUL_Parse: cul868 A 09 19 A112 1ACE1F 1DFDA5 61 -25.5
2014.06.04 11:16:18.486 4: RCV L:09 N:19 F:A1 CMD:12 SRC:ccu DST:Thermostat.SZ  (HAVE_DATA) (,WAKEUP,BIDI,RPTEN)
2014.06.04 11:16:18.600 4: CUL_Parse: cul868 A 0A 19 8002 1DFDA5 1ACE1F 0018 -62
2014.06.04 11:16:18.611 4: RCV L:0A N:19 F:80 CMD:02 SRC:Thermostat.SZ DST:ccu 00 (ACK) (,RPTEN)
2014.06.04 11:16:18.707 0: HMLAN_Send:  hmusb1 S:+1DFDA5,02,01,00
2014.06.04 11:16:18.713 0: HMLAN_Send:  hmusb1 S:S662A2EB6 stat:  00 t:00000000 d:01 r:662A2EB6 m:1A A001 1ACE1F 1DFDA5 020E
2014.06.04 11:16:18.787 0: HMLAN_Parse: hmusb1 R:R662A2BC7 stat:0001 t:0019E2EF d:FF r:FFC3     m:19 8002 1DFDA5 1ACE1F 00
2014.06.04 11:16:18.828 4: CUL_Parse: cul868 A 0B 1A A001 1ACE1F 1DFDA5 020E60 -26
2014.06.04 11:16:18.839 4: RCV L:0B N:1A F:A0 CMD:01 SRC:ccu DST:Thermostat.SZ 020E (CONFIG_STATUS_REQUEST CHANNEL:0x02) (,BIDI,RPTEN)
2014.06.04 11:16:18.964 4: CUL_Parse: cul868 A 0E 1A 8002 1DFDA5 1ACE1F 01020C003C17 -62.5
2014.06.04 11:16:18.979 4: RCV L:0E N:1A F:80 CMD:02 SRC:Thermostat.SZ DST:ccu 01020C003C (ACK_STATUS CHANNEL:0x02 STATUS:0x0C UP:0 DOWN:0 LOWBAT:0 RSSI:-60) (,RPTEN)
2014.06.04 11:16:19.068 0: HMLAN_Send:  hmusb1 S:+1DFDA5,02,01,00
2014.06.04 11:16:19.070 0: HMLAN_Send:  hmusb1 S:S662A302D stat:  00 t:00000000 d:01 r:662A302D m:1B A001 1ACE1F 1DFDA5 030E
2014.06.04 11:16:19.164 0: HMLAN_Parse: hmusb1 R:R662A2EB6 stat:0001 t:0019E652 d:FF r:FFC3     m:1A 8002 1DFDA5 1ACE1F 01020C003C
2014.06.04 11:16:19.182 4: CUL_Parse: cul868 A 0B 1B A001 1ACE1F 1DFDA5 030E60 -26
2014.06.04 11:16:19.419 4: RCV L:0B N:1B F:A0 CMD:01 SRC:ccu DST:Thermostat.SZ 030E (CONFIG_STATUS_REQUEST CHANNEL:0x03) (,BIDI,RPTEN)
2014.06.04 11:16:19.486 0: HMLAN_Parse: hmusb1 R:R662A302D stat:0001 t:0019E7B3 d:FF r:FFC3     m:1B 8002 1DFDA5 1ACE1F 01020C003C
2014.06.04 11:16:19.588 4: CUL_Parse: cul868 A 0E 1B 8002 1DFDA5 1ACE1F 01020C003C17 -62.5
2014.06.04 11:16:31.069 4: CUL_Parse: cul868 A 0B 65 A258 1D252E D1D1D1 00000F -66.5
2014.06.04 11:16:31.309 4: RCV L:0B N:65 F:A2 CMD:58 SRC:Thermostat.Kueche DST:TCControler.Kueche 0000 (ClimateEvent CMD:0x00 ValvePos:0) (,WAKEMEUP,BIDI,RPTEN)
2014.06.04 11:16:31.373 0: HMLAN_Send:  hmusb1 S:S662A6051 stat:  00 t:00000000 d:01 r:662A6051 m:65 8002 D1D1D1 1D252E 0101000000
2014.06.04 11:16:31.597 0: HMLAN_Parse: hmusb1 R:E1D252E   stat:0000 t:001A1597 d:FF r:FFC4     m:65 A258 1D252E D1D1D1 0000
2014.06.04 11:16:31.719 0: HMLAN_Parse: hmusb1 R:R662A6051 stat:0002 t:00000000 d:FF r:7FFF     m:65 8002 D1D1D1 1D252E 0101000000
2014.06.04 11:16:31.722 4: CUL_Parse: cul868 A 0E 65 8002 D1D1D1 1D252E 010100000060 -26
2014.06.04 11:16:31.960 4: RCV L:0E N:65 F:80 CMD:02 SRC:TCControler.Kueche DST:Thermostat.Kueche 0101000000 (ACK_STATUS CHANNEL:0x01 STATUS:0x00 UP:0 DOWN:0 LOWBAT:0 RSSI:0) (,RPTEN)
2014.06.04 11:16:37.619 4: CUL_Parse: cul868 A 0B 3A A258 1DFDA5 D2D2D2 000018 -62
2014.06.04 11:16:37.876 4: RCV L:0B N:3A F:A2 CMD:58 SRC:Thermostat.SZ DST:TCControler.SZ 0000 (ClimateEvent CMD:0x00 ValvePos:0) (,WAKEMEUP,BIDI,RPTEN)
2014.06.04 11:16:37.951 0: HMLAN_Send:  hmusb1 S:+1DFDA5,00,01,00
2014.06.04 11:16:37.954 0: HMLAN_Send:  hmusb1 S:S662A7A02 stat:  00 t:00000000 d:01 r:662A7A02 m:3A 8002 D2D2D2 1DFDA5 0101000000
2014.06.04 11:16:38.194 0: HMLAN_Parse: hmusb1 R:E1DFDA5   stat:0000 t:001A2F2C d:FF r:FFC3     m:3A A258 1DFDA5 D2D2D2 0000
2014.06.04 11:16:38.313 0: HMLAN_Parse: hmusb1 R:R662A7A02 stat:0002 t:00000000 d:FF r:7FFF     m:3A 8002 D2D2D2 1DFDA5 0101000000
2014.06.04 11:16:38.320 4: CUL_Parse: cul868 A 0E 3A 8002 D2D2D2 1DFDA5 010100000060 -26
2014.06.04 11:16:38.961 4: RCV L:0E N:3A F:80 CMD:02 SRC:TCControler.SZ DST:Thermostat.SZ 0101000000 (ACK_STATUS CHANNEL:0x01 STATUS:0x00 UP:0 DOWN:0 LOWBAT:0 RSSI:0) (,RPTEN)
2014.06.04 11:17:10.186 4: CUL_Parse: cul868 A 0C 6A 8670 1936FF 000000 00AE4400 -74
2014.06.04 11:17:10.425 4: RCV L:0C N:6A F:86 CMD:70 SRC:Thermostat.Bad DST:broadcast 00AE44 (WeatherEvent TEMP:17.4 HUM:68) (,WAKEMEUP,CFG,RPTEN)
2014.06.04 11:17:10.513 0: HMLAN_Parse: hmusb1 R:E1936FF   stat:0000 t:001AAE64 d:FF r:FFC7     m:6A 8670 1936FF 000000 00AE44
2014.06.04 11:17:15.869 1: Perfmon: possible freeze starting at 11:17:13, delay is 2.868
2014.06.04 11:17:30.185 4: CUL_Parse: cul868 A 0B 6A A258 1936FF D3D3D3 000004 -72
2014.06.04 11:17:30.427 4: RCV L:0B N:6A F:A2 CMD:58 SRC:Thermostat.Bad DST:TCControler.Bad 0000 (ClimateEvent CMD:0x00 ValvePos:0) (,WAKEMEUP,BIDI,RPTEN)
2014.06.04 11:17:30.491 0: HMLAN_Send:  hmusb1 S:S662B473F stat:  00 t:00000000 d:01 r:662B473F m:6A 8002 D3D3D3 1936FF 0101000000
2014.06.04 11:17:30.706 0: HMLAN_Parse: hmusb1 R:E1936FF   stat:0000 t:001AFC84 d:FF r:FFC8     m:6A A258 1936FF D3D3D3 0000
2014.06.04 11:17:30.829 0: HMLAN_Parse: hmusb1 R:R662B473F stat:0002 t:00000000 d:FF r:7FFF     m:6A 8002 D3D3D3 1936FF 0101000000
2014.06.04 11:17:30.833 4: CUL_Parse: cul868 A 0E 6A 8002 D3D3D3 1936FF 010100000061 -25.5
2014.06.04 11:17:30.849 4: RCV L:0E N:6A F:80 CMD:02 SRC:TCControler.Bad DST:Thermostat.Bad 0101000000 (ACK_STATUS CHANNEL:0x01 STATUS:0x00 UP:0 DOWN:0 LOWBAT:0 RSSI:0) (,RPTEN)
2014.06.04 11:17:54.144 4: CUL_Parse: cul868 A 14 70 845E 24AF1D 000000 804EA40001AE00180963FD0B -68.5
2014.06.04 11:17:54.390 4: RCV L:14 N:70 F:84 CMD:5E SRC:SwitchES01 DST:broadcast 804EA40001AE00180963FD (powerEvntCyc energy:840874 power:4.3 current:24 voltage:240.3 frequency:52.53) (,CFG,RPTEN)
2014.06.04 11:18:14.727 4: CUL_Parse: cul868 A 0C 9E 8670 1BF81B 000000 00C53B24 -56
2014.06.04 11:18:14.971 4: RCV L:0C N:9E F:86 CMD:70 SRC:Thermostat.WZ DST:broadcast 00C53B (WeatherEvent TEMP:19.7 HUM:59) (,WAKEMEUP,CFG,RPTEN)
2014.06.04 11:18:15.181 0: HMLAN_Parse: hmusb1 R:E1BF81B   stat:0000 t:001BAA83 d:FF r:FFC1     m:9E 8670 1BF81B 000000 00C53B
2014.06.04 11:18:18.972 1: Perfmon: possible freeze starting at 11:18:16, delay is 2.971
2014.06.04 11:18:19.093 0: HMLAN_Parse: hmusb1 R:E1D252E   stat:0000 t:001BB0BF d:FF r:FFC5     m:66 8670 1D252E 000000 00BB3F
2014.06.04 11:18:19.179 4: CUL_Parse: cul868 A 0C 66 8670 1D252E 000000 00BB3F0D -67.5
2014.06.04 11:18:30.373 4: CUL_Parse: cul868 A 0C 3B 8670 1DFDA5 000000 00C93F18 -62
2014.06.04 11:18:30.615 4: RCV L:0C N:3B F:86 CMD:70 SRC:Thermostat.SZ DST:broadcast 00C93F (WeatherEvent TEMP:20.1 HUM:63) (,WAKEMEUP,CFG,RPTEN)
2014.06.04 11:18:30.823 0: HMLAN_Parse: hmusb1 R:E1DFDA5   stat:0000 t:001BE7A0 d:FF r:FFC3     m:3B 8670 1DFDA5 000000 00C93F
2014.06.04 11:18:34.727 4: CUL_Parse: cul868 A 0B 9E A258 1BF81B D4D4D4 000025 -55.5
2014.06.04 11:18:34.972 4: RCV L:0B N:9E F:A2 CMD:58 SRC:Thermostat.WZ DST:TCControler.WZ 0000 (ClimateEvent CMD:0x00 ValvePos:0) (,WAKEMEUP,BIDI,RPTEN)
2014.06.04 11:18:35.036 0: HMLAN_Send:  hmusb1 S:S662C4360 stat:  00 t:00000000 d:01 r:662C4360 m:9E 8002 D4D4D4 1BF81B 0101000000
2014.06.04 11:18:35.260 0: HMLAN_Parse: hmusb1 R:E1BF81B   stat:0000 t:001BF8A2 d:FF r:FFC4     m:9E A258 1BF81B D4D4D4 0000
2014.06.04 11:18:35.381 0: HMLAN_Parse: hmusb1 R:R662C4360 stat:0002 t:00000000 d:FF r:7FFF     m:9E 8002 D4D4D4 1BF81B 0101000000
2014.06.04 11:18:35.384 4: CUL_Parse: cul868 A 0E 9E 8002 D4D4D4 1BF81B 010100000060 -26
2014.06.04 11:18:35.624 4: RCV L:0E N:9E F:80 CMD:02 SRC:TCControler.WZ DST:Thermostat.WZ 0101000000 (ACK_STATUS CHANNEL:0x01 STATUS:0x00 UP:0 DOWN:0 LOWBAT:0 RSSI:0) (,RPTEN)
2014.06.04 11:18:36.324 4: CUL_Parse: cul868 A 0B 66 A258 1D252E D1D1D1 000006 -71
2014.06.04 11:18:36.564 4: RCV L:0B N:66 F:A2 CMD:58 SRC:Thermostat.Kueche DST:TCControler.Kueche 0000 (ClimateEvent CMD:0x00 ValvePos:0) (,WAKEMEUP,BIDI,RPTEN)
2014.06.04 11:18:36.629 0: HMLAN_Send:  hmusb1 S:S662C4998 stat:  00 t:00000000 d:01 r:662C4998 m:66 8002 D1D1D1 1D252E 0101000000
2014.06.04 11:18:36.854 0: HMLAN_Parse: hmusb1 R:E1D252E   stat:0000 t:001BFEDF d:FF r:FFC3     m:66 A258 1D252E D1D1D1 0000
2014.06.04 11:18:36.972 0: HMLAN_Parse: hmusb1 R:R662C4998 stat:0002 t:00000000 d:FF r:7FFF     m:66 8002 D1D1D1 1D252E 0101000000
2014.06.04 11:18:36.976 4: CUL_Parse: cul868 A 0E 66 8002 D1D1D1 1D252E 010100000060 -26
2014.06.04 11:18:36.990 4: RCV L:0E N:66 F:80 CMD:02 SRC:TCControler.Kueche DST:Thermostat.Kueche 0101000000 (ACK_STATUS CHANNEL:0x01 STATUS:0x00 UP:0 DOWN:0 LOWBAT:0 RSSI:0) (,RPTEN)
2014.06.04 11:18:50.373 4: CUL_Parse: cul868 A 0B 3B A258 1DFDA5 D2D2D2 000018 -62
2014.06.04 11:18:50.618 4: RCV L:0B N:3B F:A2 CMD:58 SRC:Thermostat.SZ DST:TCControler.SZ 0000 (ClimateEvent CMD:0x00 ValvePos:0) (,WAKEMEUP,BIDI,RPTEN)
2014.06.04 11:18:50.686 0: HMLAN_Send:  hmusb1 S:S662C8082 stat:  00 t:00000000 d:01 r:662C8082 m:3B 8002 D2D2D2 1DFDA5 0101000000
2014.06.04 11:18:50.934 0: HMLAN_Parse: hmusb1 R:E1DFDA5   stat:0000 t:001C35BF d:FF r:FFC3     m:3B A258 1DFDA5 D2D2D2 0000
2014.06.04 11:18:51.052 0: HMLAN_Parse: hmusb1 R:R662C8082 stat:0002 t:00000000 d:FF r:7FFF     m:3B 8002 D2D2D2 1DFDA5 0101000000
2014.06.04 11:18:51.056 4: CUL_Parse: cul868 A 0E 3B 8002 D2D2D2 1DFDA5 010100000060 -26
2014.06.04 11:18:51.298 4: RCV L:0E N:3B F:80 CMD:02 SRC:TCControler.SZ DST:Thermostat.SZ 0101000000 (ACK_STATUS CHANNEL:0x01 STATUS:0x00 UP:0 DOWN:0 LOWBAT:0 RSSI:0) (,RPTEN)
2014.06.04 11:19:22.018 1: Perfmon: possible freeze starting at 11:19:19, delay is 3.017
2014.06.04 11:19:24.439 4: CUL_Parse: cul868 A 0C 6B 8670 1936FF 000000 00AF44FE -75
2014.06.04 11:19:24.681 4: RCV L:0C N:6B F:86 CMD:70 SRC:Thermostat.Bad DST:broadcast 00AF44 (WeatherEvent TEMP:17.5 HUM:68) (,WAKEMEUP,CFG,RPTEN)
2014.06.04 11:19:24.894 0: HMLAN_Parse: hmusb1 R:E1936FF   stat:0000 t:001CBAD0 d:FF r:FFC8     m:6B 8670 1936FF 000000 00AF44
2014.06.04 11:19:44.438 4: CUL_Parse: cul868 A 0B 6B A258 1936FF D3D3D3 000003 -72.5
2014.06.04 11:19:44.679 4: RCV L:0B N:6B F:A2 CMD:58 SRC:Thermostat.Bad DST:TCControler.Bad 0000 (ClimateEvent CMD:0x00 ValvePos:0) (,WAKEMEUP,BIDI,RPTEN)
2014.06.04 11:19:44.744 0: HMLAN_Send:  hmusb1 S:S662D53AC stat:  00 t:00000000 d:01 r:662D53AC m:6B 8002 D3D3D3 1936FF 0101000000
2014.06.04 11:19:44.970 0: HMLAN_Parse: hmusb1 R:E1936FF   stat:0000 t:001D08EF d:FF r:FFC8     m:6B A258 1936FF D3D3D3 0000
2014.06.04 11:19:45.089 0: HMLAN_Parse: hmusb1 R:R662D53AC stat:0002 t:00000000 d:FF r:7FFF     m:6B 8002 D3D3D3 1936FF 0101000000
2014.06.04 11:19:45.094 4: CUL_Parse: cul868 A 0E 6B 8002 D3D3D3 1936FF 010100000061 -25.5
2014.06.04 11:19:45.335 4: RCV L:0E N:6B F:80 CMD:02 SRC:TCControler.Bad DST:Thermostat.Bad 0101000000 (ACK_STATUS CHANNEL:0x01 STATUS:0x00 UP:0 DOWN:0 LOWBAT:0 RSSI:0) (,RPTEN)
2014.06.04 11:20:03.893 4: CUL_Parse: cul868 A 14 71 845E 24AF1D 000000 804EA60001AE00180961FE0D -67.5
2014.06.04 11:20:04.214 4: RCV L:14 N:71 F:84 CMD:5E SRC:SwitchES01 DST:broadcast 804EA60001AE00180961FE (powerEvntCyc energy:840874.2 power:4.3 current:24 voltage:240.1 frequency:52.54) (,CFG,RPTEN)
2014.06.04 11:20:24.928 1: Perfmon: possible freeze starting at 11:20:22, delay is 2.927
2014.06.04 11:20:27.580 1: Perfmon: possible freeze starting at 11:20:25, delay is 2.579
2014.06.04 11:20:31.233 4: CUL_Parse: cul868 A 0C 9F 8670 1BF81B 000000 00C63B23 -56.5
2014.06.04 11:20:31.478 4: RCV L:0C N:9F F:86 CMD:70 SRC:Thermostat.WZ DST:broadcast 00C63B (WeatherEvent TEMP:19.8 HUM:59) (,WAKEMEUP,CFG,RPTEN)
2014.06.04 11:20:31.719 0: HMLAN_Parse: hmusb1 R:E1BF81B   stat:0000 t:001DBFB8 d:FF r:FFC2     m:9F 8670 1BF81B 000000 00C63B
2014.06.04 11:20:51.233 4: CUL_Parse: cul868 A 0B 9F A258 1BF81B D4D4D4 000025 -55.5
2014.06.04 11:20:51.493 4: RCV L:0B N:9F F:A2 CMD:58 SRC:Thermostat.WZ DST:TCControler.WZ 0000 (ClimateEvent CMD:0x00 ValvePos:0) (,WAKEMEUP,BIDI,RPTEN)
2014.06.04 11:20:51.568 0: HMLAN_Send:  hmusb1 S:S662E58B2 stat:  00 t:00000000 d:01 r:662E58B2 m:9F 8002 D4D4D4 1BF81B 0101000000
2014.06.04 11:20:51.780 0: HMLAN_Parse: hmusb1 R:E1BF81B   stat:0000 t:001E0DD8 d:FF r:FFC1     m:9F A258 1BF81B D4D4D4 0000
2014.06.04 11:20:51.901 0: HMLAN_Parse: hmusb1 R:R662E58B2 stat:0002 t:00000000 d:FF r:7FFF     m:9F 8002 D4D4D4 1BF81B 0101000000
2014.06.04 11:20:51.905 4: CUL_Parse: cul868 A 0E 9F 8002 D4D4D4 1BF81B 010100000060 -26
2014.06.04 11:20:51.920 4: RCV L:0E N:9F F:80 CMD:02 SRC:TCControler.WZ DST:Thermostat.WZ 0101000000 (ACK_STATUS CHANNEL:0x01 STATUS:0x00 UP:0 DOWN:0 LOWBAT:0 RSSI:0) (,RPTEN)
2014.06.04 11:21:11.330 4: CUL_Parse: cul868 A 0C 67 8670 1D252E 000000 00BB3F0E -67
2014.06.04 11:21:11.578 4: RCV L:0C N:67 F:86 CMD:70 SRC:Thermostat.Kueche DST:broadcast 00BB3F (WeatherEvent TEMP:18.7 HUM:63) (,WAKEMEUP,CFG,RPTEN)
2014.06.04 11:21:11.654 0: HMLAN_Parse: hmusb1 R:E1D252E   stat:0000 t:001E5C5A d:FF r:FFC3     m:67 8670 1D252E 000000 00BB3F
2014.06.04 11:21:28.080 1: Perfmon: possible freeze starting at 11:21:25, delay is 3.078
2014.06.04 11:21:31.329 4: CUL_Parse: cul868 A 0B 67 A258 1D252E D1D1D1 00000E -67
2014.06.04 11:21:31.567 4: RCV L:0B N:67 F:A2 CMD:58 SRC:Thermostat.Kueche DST:TCControler.Kueche 0000 (ClimateEvent CMD:0x00 ValvePos:0) (,WAKEMEUP,BIDI,RPTEN)
2014.06.04 11:21:31.631 0: HMLAN_Send:  hmusb1 S:S662EF533 stat:  00 t:00000000 d:01 r:662EF533 m:67 8002 D1D1D1 1D252E 0101000000
2014.06.04 11:21:31.859 0: HMLAN_Parse: hmusb1 R:E1D252E   stat:0000 t:001EAA79 d:FF r:FFC3     m:67 A258 1D252E D1D1D1 0000
2014.06.04 11:21:31.977 0: HMLAN_Parse: hmusb1 R:R662EF533 stat:0002 t:00000000 d:FF r:7FFF     m:67 8002 D1D1D1 1D252E 0101000000
2014.06.04 11:21:31.981 4: CUL_Parse: cul868 A 0E 67 8002 D1D1D1 1D252E 010100000060 -26
2014.06.04 11:21:31.995 4: RCV L:0E N:67 F:80 CMD:02 SRC:TCControler.Kueche DST:Thermostat.Kueche 0101000000 (ACK_STATUS CHANNEL:0x01 STATUS:0x00 UP:0 DOWN:0 LOWBAT:0 RSSI:0) (,RPTEN)
2014.06.04 11:21:32.629 4: CUL_Parse: cul868 A 0C 3C 8670 1DFDA5 000000 00C93F18 -62
2014.06.04 11:21:32.875 4: RCV L:0C N:3C F:86 CMD:70 SRC:Thermostat.SZ DST:broadcast 00C93F (WeatherEvent TEMP:20.1 HUM:63) (,WAKEMEUP,CFG,RPTEN)
2014.06.04 11:21:32.961 0: HMLAN_Parse: hmusb1 R:E1DFDA5   stat:0000 t:001EAF8C d:FF r:FFC3     m:3C 8670 1DFDA5 000000 00C93F
2014.06.04 11:21:52.644 4: CUL_Parse: cul868 A 0B 3C A258 1DFDA5 D2D2D2 000018 -62
2014.06.04 11:21:52.898 4: RCV L:0B N:3C F:A2 CMD:58 SRC:Thermostat.SZ DST:TCControler.SZ 0000 (ClimateEvent CMD:0x00 ValvePos:0) (,WAKEMEUP,BIDI,RPTEN)
2014.06.04 11:21:52.975 0: HMLAN_Send:  hmusb1 S:S662F4891 stat:  00 t:00000000 d:01 r:662F4891 m:3C 8002 D2D2D2 1DFDA5 0101000000
2014.06.04 11:21:53.207 0: HMLAN_Parse: hmusb1 R:E1DFDA5   stat:0000 t:001EFDAB d:FF r:FFC2     m:3C A258 1DFDA5 D2D2D2 0000
2014.06.04 11:21:53.326 0: HMLAN_Parse: hmusb1 R:R662F4891 stat:0002 t:00000000 d:FF r:7FFF     m:3C 8002 D2D2D2 1DFDA5 0101000000
2014.06.04 11:21:53.329 4: CUL_Parse: cul868 A 0E 3C 8002 D2D2D2 1DFDA5 010100000060 -26
2014.06.04 11:21:53.345 4: RCV L:0E N:3C F:80 CMD:02 SRC:TCControler.SZ DST:Thermostat.SZ 0101000000 (ACK_STATUS CHANNEL:0x01 STATUS:0x00 UP:0 DOWN:0 LOWBAT:0 RSSI:0) (,RPTEN)
2014.06.04 11:22:30.813 1: Perfmon: possible freeze starting at 11:22:28, delay is 2.812
2014.06.04 11:22:31.126 0: HMLAN_Parse: hmusb1 R:E1936FF   stat:0000 t:001F8895 d:FF r:FFC8     m:6C 8670 1936FF 000000 00AF44
2014.06.04 11:22:31.210 4: CUL_Parse: cul868 A 0C 6C 8670 1936FF 000000 00AF44FF -74.5
2014.06.04 11:22:33.236 4: CUL_Parse: cul868 A 0C A0 8670 1BF81B 000000 00C53B24 -56
2014.06.04 11:22:33.475 4: RCV L:0C N:A0 F:86 CMD:70 SRC:Thermostat.WZ DST:broadcast 00C53B (WeatherEvent TEMP:19.7 HUM:59) (,WAKEMEUP,CFG,RPTEN)
2014.06.04 11:22:33.671 0: HMLAN_Parse: hmusb1 R:E1BF81B   stat:0000 t:001F9C49 d:FF r:FFC1     m:A0 8670 1BF81B 000000 00C53B
2014.06.04 11:22:48.191 4: CUL_Parse: cul868 A 0B 6C A258 1936FF D3D3D3 0000FC -76
2014.06.04 11:22:48.430 4: RCV L:0B N:6C F:A2 CMD:58 SRC:Thermostat.Bad DST:TCControler.Bad 0000 (ClimateEvent CMD:0x00 ValvePos:0) (,WAKEMEUP,BIDI,RPTEN)
2014.06.04 11:22:48.494 0: HMLAN_Send:  hmusb1 S:S66302172 stat:  00 t:00000000 d:01 r:66302172 m:6C 8002 D3D3D3 1936FF 0101000000
2014.06.04 11:22:48.710 0: HMLAN_Parse: hmusb1 R:E1936FF   stat:0000 t:001FD6B4 d:FF r:FFC8     m:6C A258 1936FF D3D3D3 0000
2014.06.04 11:22:48.918 0: HMLAN_Parse: hmusb1 R:R66302172 stat:0002 t:00000000 d:FF r:7FFF     m:6C 8002 D3D3D3 1936FF 0101000000
2014.06.04 11:22:48.922 4: CUL_Parse: cul868
FHEM: 6.0(SVN) => Pi3(buster)
martinp876
hm...
ist in dieser Zeit ein Fehler aufgetreten? D1 bis D4 haben immer geantwortet.
frank
#92
am ende des log zur vollen stunde haben die tc gepeept. demzufolge müssen die tc zu diesem zeitpunkt mindestens seit 15min keine antwort registriert haben.
seit dem update vor 5-6 tagen gab es gefühlt jede stunde konzert. auch bei jedem blick auf das display der tc, haben die antennensymbole geblinkt. sozusagen permanente kommunikationsstörung.
edit:
ich habe gerade gesehen, dass das log wohl zu lang war. also hier nochmal im anhang. ab 11 uhr 50 muss es sicher fehler gegeben haben.
frank
#93
bei der der kommunikation zwischen realem tc und virtuellem vd ist es noch so, dass das senden des vvd vom attr IODev/IOgrp des vvd bestimmt wird. kann dieser umstand mit den starken verzögerungen zu tun haben?
bei der kombination vtc <=> vd hattest du dies umgebaut. hier sind die attr IODev/IOgrp des realen device (vd) für das senden verantwortlich.
edit:
auf alle fälle scheint der cul eine entscheidende rolle zu spielen. ich habe ihn gerade aus der fritzbox gezogen, wodurch bei allen tc das blinken des antennensymbols verschwunden ist.
martinp876
Ich habe beim Assign des IO noch etwas nachgebessert. Probiere noch einmal .
frank
hallo martin,
funktioniert prächtig. danke.
vom ersten empfangen (meist cul) bis zum senden vergehen jetzt nach den timestamps in fhem.log gute 100ms. wahrscheinlich 100% trefferquote. noch kein blinken oder peepen wahrgenommen.
nun ist aber weiterer wunschbedarf angefallen.
vor gut 4 wochen hatte ich den wunsch, die virtuellen devices unter assignedIDs beim jeweiligen io mit aufzulisten. das war damals nicht ganz nach deinem sinn. darauf hin hast du grössere umbauten vorgenommen, um das senden eines virtuellen tc nicht durch sein eigenes attr IODev festzulegen, sondern vom attr IODev des realen vd. wie bereits in diesem thread ausführlich geschildert, funktioniert seitdem ein getconfig auf den realen vd nicht mehr "automatisch" beim aufwachen des vd und verursacht erhebliche probleme. nur noch sicher über configtaste. dafür bleibt man aber fit beim rennen durch die hütte.
eben habe ich nun gesehen, dass die virtuellen devices doch den weg in die liste der assignedIDs der io gefunden haben. sehr schön. ausserdem ist das io zum senden eines virtuellen vd immer noch abhängig vom attr IODev/IOgrp des virtuellen devices selber. auch schön.
daraus erwächst bei mir der wunsch diesen mechanismus auch wieder bei der kombination vtc <=> vd wiederzubeleben/zurückzubauen. hierbei ist das attr IODev/IOgrp des virtuellen tc zur zeit ohne funktion. dann funktioniert eventuell auch wieder ein "automatisches" getconfig.
gruss frank
martinp876
#96
werde ich mir ansehen
kaum habe ich nachgedacht ... folgende aussagen
- das mit dem VD werde ich einbauen - wenn der vtc genutzt wird werden kommandos an das VD abgearbeitet werden (noch nicht fertig... hat nichts mit dem IO zu tun, sondern der fehlenden Message des TC...)
- assignedIDs: Virtuelle Devices sollten da nicht drin stehen. Die Liste wird im HMLAN gespeichert und bearbeitet. Es wird von diesem genutzt um ACK u.ä. zu senden. Von einem Virtuellen Device kommen keine messages rein, es gehen nur welche raus. Würde man diese dort einstellen kostet das Performance im HMLAN. Da ich keine Grenzen kenne werde ich diese unnötige Last vermeiden. Muss ich also beheben.
- Liste der IOs: Wenn du assignedIDs dazu nutzen wolltest, zu sehen, wer welches IO nutzt empfehle ich vccu kommando get vccu listDevice
Gruss Martin
justme1968
hallo martin,
ich schaue mir gerade dir vccu an habe gesehen das sie unter assignedIOs alle IODevs im system anzeigt. auch alle die nichts mit homematic zu tun haben. also OWServer, HUEBridge, panStamp, JeeLink. die IODevs tauchen auch alle im STATE auf.
soll das wirklich so sein ?
  andre
list ccu
   CFGFN
   DEF        F10000
   IODev      cul2
   LASTInputDev hmlan
   MSGCNT     3
   NAME       ccu
   NR         1245
   STATE      bridge:UAS,cul:UAS,cul2:UAS,hmlan:UAS,jeelink:UAS,owserver:UAS,owserver2:UAS,panStamp:UAS,
   TYPE       CUL_HM
   assignedIOs bridge,cul,cul2,hmlan,jeelink,owserver,owserver2,panStamp
   cul2_MSGCNT 1
   cul2_RAWMSG A0A068002F100001C805600::-85.5:cul2
   cul2_RSSI  -85.5
   cul2_TIME  2014-06-18 13:07:48
   hmlan_MSGCNT 2
   hmlan_RAWMSG EF10000,0000,4C80EF42,FF,FFAE,0BA011F100001D4B0B801001
   hmlan_RSSI -82
   hmlan_TIME 2014-06-18 13:07:48
   lastMsg    No:0B - t:11 s:F10000 d:1D4B0B 801001
   protLastRcv 2014-06-18 13:07:48
   rssi_at_cul2 avg:-85.5 min:-85.5 max:-85.5 lst:-85.5 cnt:1
   rssi_at_hmlan avg:-82.5 min:-83 max:-82 lst:-82 cnt:2
   Readings:
     2014-06-18 13:07:48   CommandAccepted yes
   Helper:
     mId        FFF0
     rxType     1
     Io:
       newChn     +F10000,00,01,00
       nextSend   1403089668.30746
       rxt        0
       p:
         F10000
         00
         01
         00
     Mrssi:
       mNo        0B
       Io:
         hmlan      -82
     Prt:
       bErr       0
       sProc      0
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       chn        1
       dev        1
       vrt        1
     Rssi:
       At_cul2:
         avg        -85.5
         cnt        1
         lst        -85.5
         max        -85.5
         min        -85.5
       At_hmlan:
         avg        -82.5
         cnt        2
         lst        -82
         max        -82
         min        -83
   IODev      cul2
   IOgrp      cul2,hmlan
   autoReadReg 4_reqStatus
   expert     2_full
   model      CCU-FHEM
   room       CUL_HM
   subType    virtual
   webCmd     virtual:update
hexenmeister
Zitathabe gesehen das sie unter assignedIOs alle IODevs im system anzeigt. auch alle die nichts mit homematic zu tun haben.
Kann ich nicht bestätigen, bei mir tauchen da nur HMLAN und HMUSB auf. Meine JeeLink, Firmata- und 1Wire-Controller bleiben außen vor.
Grüße,
Alexander
marvin78
Bei mir tauchen auch nur 2 HM IODevs auf (Jeelink, CUL, RFTRX nicht). Allerdings fehlt ein entfernter HMUSB (über hmland) obwohl er im STATE als ok angezeigt wird und von der CCU auch als IODev verwendet wird.
   CUL_HM_MSGCNT 13
   CUL_HM_RAWMSG EF14C23,0000,386D79E6,FF,FFC7,088002F14C232516E100
   CUL_HM_RSSI -57
   CUL_HM_TIME 2014-06-18 15:02:09
   DEF        F14C23
   HMLAN_Wz_MSGCNT 147
   HMLAN_Wz_RAWMSG EF14C23,0000,066840AC,FF,FFC4,3B8002F14C2324CC6B0101C800
   HMLAN_Wz_RSSI -60
   HMLAN_Wz_TIME 2014-06-18 15:40:32
   HMUSB_Bad_MSGCNT 164
   HMUSB_Bad_RAWMSG EF14C23,0000,06986BEF,FF,FFBD,3B8002F14C2324CC6B0101C800
   HMUSB_Bad_RSSI -67
   HMUSB_Bad_TIME 2014-06-18 15:40:32
   IODev      CUL_HM
   LASTInputDev HMUSB_Bad
   MSGCNT     324
   NAME       CCU
   NR         705
   STATE      CUL_HM:ok,HMLAN_Wz:ok,HMUSB_Bad:ok,
   TYPE       CUL_HM
   assignedIOs CUL_HM,HMLAN_Wz
   lastMsg    No:3B - t:02 s:F14C23 d:24CC6B 0101C800
   protLastRcv 2014-06-18 15:40:32
   rssi_at_CUL_HM avg:-56.53 min:-57 max:-55 lst:-57 cnt:13
   rssi_at_HMLAN_Wz avg:-59.93 min:-61 max:-58 lst:-60 cnt:147
   rssi_at_HMUSB_Bad avg:-68.82 min:-83 max:-66 lst:-67 cnt:164
   Readings:
     2014-06-18 15:40:32   CommandAccepted yes
     2014-06-18 15:40:32   recentStateType ack
   Helper:
     mId        FFF0
     rxType     1
     Io:
       nextSend   1403098832.57167
     Mrssi:
       mNo        3B
       Io:
         HMLAN_Wz   -60
         HMUSB_Bad  -67
     Prt:
       bErr       0
       sProc      0
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       chn        1
       dev        1
       vrt        1
     Rssi:
       At_cul_hm:
         avg        -56.5384615384615
         cnt        13
         lst        -57
         max        -55
         min        -57
       At_hmlan_wz:
         avg        -59.9387755102041
         cnt        147
         lst        -60
         max        -58
         min        -61
       At_hmusb_bad:
         avg        -68.8231707317074
         cnt        164
         lst        -67
         max        -66
         min        -83
     Shadowreg:
   DbLogExclude .*
   IODev      CUL_HM
   IOList     CUL_HM,HMLAN_Wz,HMUSB_Bad
   IOgrp      CCU
   expert     2_full
   group      Funkmodule
   icon       cul
   model      CCU-FHEM
   room       Server
   subType    virtual
justme1968
gerade wollte ich schauen ob ein modify vielleicht die assignedIOs neu bestimmt aber modify geht leider nicht. es kommt nur die meldung das die hmid schon definiert ist. da fehlt vermutlich noch die Unterscheidung zwischen define und modiy.
  andre
marvin78
Was mit auffällt, ist dass du das Attribut IOList nicht verwendet hast. Dort kommen die HM-IOs rein.
justme1968
du hast recht. das ist es vermutlich. hab beim copy&paste nicht aufgepasst und IOgrp statt IOList gesetzt.
scheinbar reicht ein nachträgliches setzen aber auch nicht. starte heute abend mal neu...
danke
  andre
justme1968
auch nach dem neustart habe ich noch die nicht-hm IODevs in der assignedIOs list und in STATE. der einzige unterschied ist das mit richtig gesetzter IOList jetzt cul2 und hmlan im STATE ok sind. die anderen sind immer noch UAS (unassigned ?).
  andre
   DEF        F10000
   IODev      cul2
   LASTInputDev hmlan
   MSGCNT     1
   NAME       ccu
   NR         437
   STATE      bridge:UAS,jeelink:UAS,owserver:UAS,owserver2:UAS,panStamp:UAS,cul2:ok,hmlan:ok,
   TYPE       CUL_HM
   hmlan_MSGCNT 1
   hmlan_RAWMSG EF10000,0000,4D9F0547,FF,FFAE,04A011F100001AECC90201000000
   hmlan_RSSI -82
   hmlan_TIME 2014-06-18 18:20:14
   lastMsg    No:04 - t:11 s:F10000 d:1AECC9 0201000000
   protLastRcv 2014-06-18 18:20:14
   rssi_at_hmlan avg:-82 min:-82 max:-82 lst:-82 cnt:1
   Readings:
     2014-06-18 17:53:24   CommandAccepted yes
   Helper:
     mId        FFF0
     rxType     1
     Io:
       nextSend   1403108414.67271
     Mrssi:
       mNo        04
       Io:
         hmlan      -82
     Prt:
       bErr       0
       sProc      0
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       chn        1
       dev        1
       vrt        1
     Rssi:
       At_hmlan:
         avg        -82
         cnt        1
         lst        -82
         max        -82
         min        -82
   IODev      cul2
   IOList     cul2,hmlan
   expert     2_full
   model      CCU-FHEM
   room       CUL_HM
   subType    virtual
martinp876
UAS ist unassigned.
ich habe die suche nach IOs verbessert
Gruss Martin
