CMD: set <device> fwUpdate <filename> [<waittime>]
Begonnen von frank, 07 Mai 2014, 17:18:21
frank
hallo martin,
manchmal gibt es einen fehler mit den msgnummern. dann gibt es folgenden fehler in fhem.log:
2014.10.30 14:35:41.035 1: PERL WARNING: Use of uninitialized value $mNo in sprintf at ./FHEM/10_CUL_HM.pm line 5342.
2014.10.30 14:35:24.611 5: CUL_HM SwitchPBU02 protEvent:CMDs_FWupdate
2014.10.30 14:35:24.612 2: CUL_HM fwUpdate started for SwitchPBU02
2014.10.30 14:35:24.616 4: CUL_send:  cul868As 0A 0A 3011 1ACE1F 266E75 CA
2014.10.30 14:35:24.716 3: CUL_HM set SwitchPBU02 fwUpdate fwUpdates/switchpbu02/HM_LC_Sw1PBU_FM_2014-10-24_1v4.eq3 20
2014.10.30 14:35:24.770 4: CUL_Parse: cul868 A 09 82 A112 1ACE1F 1DFC2F 34 -48
2014.10.30 14:35:24.775 4: CUL_Parse: cul868 A 0A 82 8002 1DFC2F 1ACE1F 0019 -61.5
2014.10.30 14:35:24.781 4: CUL_Parse: cul868 A 0B 82 A258 B2B2B2 1DFC2F 03FA34 -48
2014.10.30 14:35:25.061 0: HMLAN_Parse: hmusb1 R:E1ACE1F   stat:0000 t:04BA74DB d:FF r:FFDD     m:0A 3011 1ACE1F 266E75 CA
2014.10.30 14:35:25.069 4: CUL_Parse: cul868 A 0A 0A 8002 266E75 1ACE1F 8037 -46.5
2014.10.30 14:35:32.670 4: CUL_Parse: cul868 A 14 45 805E 266EA5 1ACE1F 000000000000000000000013 -64.5
2014.10.30 14:35:35.234 4: CUL_Parse: cul868 A 14 00 0010 266E75 000000 004B45513131303937393737 -46.5
2014.10.30 14:35:35.240 2: CUL_HM fwUpdate SwitchPBU02 entered mode. IO-speed: fast
2014.10.30 14:35:35.337 4: CUL_send:  cul868As 0F 0B 00CB 1ACE1F 266E75 105B11F81547
2014.10.30 14:35:35.393 4: CUL_send:  cul868AR
2014.10.30 14:35:35.450 5: CUL_HM fwUpdate write block 1 of 224: 9 messages
2014.10.30 14:35:35.454 4: CUL_send:  cul868As 27 0D 00CA 1ACE1F 266E75 01000C94B5070C9459390C9486390C94B3390C9494370C94930B0C946E0B
2014.10.30 14:35:35.470 4: CUL_send:  cul868As 27 0E 00CA 1ACE1F 266E75 0C94490B0C94F8080C94DD070C94DD070C94DD070C94DD070C94DD070C94
2014.10.30 14:35:35.487 4: CUL_send:  cul868As 27 0F 00CA 1ACE1F 266E75 DD070C94DD070C94DD070C94DD070C94E0390C94DD070C94223D0C94703D
2014.10.30 14:35:35.503 4: CUL_send:  cul868As 27 10 00CA 1ACE1F 266E75 0C94DD070C94DD070C94DD070C94DD070C94DD070C94DD07290A00280029
2014.10.30 14:35:35.519 4: CUL_send:  cul868As 27 11 00CA 1ACE1F 266E75 0020286C3A004B6E6F776E20636F6D6D616E64733A00206279746573004E
2014.10.30 14:35:35.535 4: CUL_send:  cul868As 27 12 00CA 1ACE1F 266E75 6F7420656E6F75676820646174612C206E6565642000556E7265636F676E
2014.10.30 14:35:35.552 4: CUL_send:  cul868As 27 13 00CA 1ACE1F 266E75 697A6564206368617261637465723A20002C206E7874533A00524C3A6164
2014.10.30 14:35:35.568 4: CUL_send:  cul868As 27 14 00CA 1ACE1F 266E75 6A526C792C20637572533A002C204F666654696D653A002C204F6666446C
2014.10.30 14:35:35.584 4: CUL_send:  cul868As 1B 15 20CA 1ACE1F 266E75 793A002C204F6E54696D653A002C204F6E44
2014.10.30 14:35:35.622 5: CUL_HM fwUpdate write block 2 of 224: 9 messages
2014.10.30 14:35:35.626 4: CUL_send:  cul868As 27 16 00CA 1ACE1F 266E75 01006C793A002C206E7874533A00524C3A7472696767657234302C206375
2014.10.30 14:35:35.642 4: CUL_send:  cul868As 27 17 00CA 1ACE1F 266E75 72533A002C2064757261543A002C2072616D70543A002C206E7874533A00
2014.10.30 14:35:35.658 4: CUL_send:  cul868As 27 18 00CA 1ACE1F 266E75 524C3A7472696767657231312C2076616C3A002C2070496478323A20002C
2014.10.30 14:35:35.673 4: CUL_send:  cul868As 27 19 00CA 1ACE1F 266E75 2070496478313A200072656D6F76655065657246726F6D4D73672C20636E
2014.10.30 14:35:35.689 4: CUL_send:  cul868As 27 1A 00CA 1ACE1F 266E75 6C3A20006164645065657246726F6D4D73672C20636E6C3A200061646450
2014.10.30 14:35:35.705 4: CUL_send:  cul868As 27 1B 00CA 1ACE1F 266E75 65657246726F6D4D73672C20636E6C3A20002C20646174613A2000736574
2014.10.30 14:35:35.721 4: CUL_send:  cul868As 27 1C 00CA 1ACE1F 266E75 4C69737446726F6D4D73672C206C656E3A20002C20646174613A20006765
2014.10.30 14:35:35.737 4: CUL_send:  cul868As 27 1D 00CA 1ACE1F 266E75 744C697374466F724D7367322C206C656E3A20002C20736C635074723A20
2014.10.30 14:35:35.753 4: CUL_send:  cul868As 1B 1E 20CA 1ACE1F 266E75 00206F6620000A6765744C697374466F724D
2014.10.30 14:35:35.775 0: HMLAN_Parse: hmusb1 R:E266E75   stat:0000 t:04BA9CD6 d:FF r:FFBB     m:00 0010 266E75 000000 004B455131313039373937
2014.10.30 14:35:35.783 5: CUL_HM fwUpdate write block 3 of 224: 9 messages
2014.10.30 14:35:35.879 4: CUL_send:  cul868As 27 1F 00CA 1ACE1F 266E75 01007367322C206D73675074723A20002C20706565723A20004C6F616469
2014.10.30 14:35:35.896 4: CUL_send:  cul868As 27 20 00CA 1ACE1F 266E75 6E67206C6973743320666F7220636E6C3A20002C20646174613A20006765
2014.10.30 14:35:35.912 4: CUL_send:  cul868As 27 21 00CA 1ACE1F 266E75 745265672C206C656E3A20002C20706565724964783A20002C207068794C
2014.10.30 14:35:35.928 4: CUL_send:  cul868As 27 22 00CA 1ACE1F 266E75 656E3A20002C20706879416464723A20002C20736C634C656E3A20006765
2014.10.30 14:35:35.944 4: CUL_send:  cul868As 27 23 00CA 1ACE1F 266E75 74536C69636544657461696C2C20736C635074723A20002C2073697A6520
2014.10.30 14:35:35.960 4: CUL_send:  cul868As 27 24 00CA 1ACE1F 266E75 6F663A20004C6F6164696E67205065657244422C207374617274733A2000
2014.10.30 14:35:35.976 4: CUL_send:  cul868As 27 25 00CA 1ACE1F 266E75 646F6E650A0066697273742073746172742064657465637465642C20666F
2014.10.30 14:35:35.992 4: CUL_send:  cul868As 27 26 00CA 1ACE1F 266E75 726D6174696E6720656570726F6D2E2E2E0A000A0A00556E6B6E6F776E20
2014.10.30 14:35:36.008 4: CUL_send:  cul868As 1B 27 20CA 1ACE1F 266E75 4D6573736167652C20706C65617365207265
2014.10.30 14:35:36.023 0: HMLAN_Parse: hmusb1 R:E1ACE1F   stat:0000 t:04BA9D61 d:FF r:FFDD     m:0B 00CB 1ACE1F 266E75 105B11F81547
2014.10.30 14:35:36.044 4: CUL_Parse: cul868 A 0A 1E 8002 266E75 1ACE1F 803F -42.5
2014.10.30 14:35:36.057 4: CUL_Parse: cul868 A 0A 27 8002 266E75 1ACE1F 803F -42.5
2014.10.30 14:35:41.042 5: CUL_HM fwUpdate write block 3 of 224: 9 messages
2014.10.30 14:35:41.046 4: CUL_send:  cul868As 27 01 00CA 1ACE1F 266E75 01007367322C206D73675074723A20002C20706565723A20004C6F616469
2014.10.30 14:35:41.062 4: CUL_send:  cul868As 27 02 00CA 1ACE1F 266E75 6E67206C6973743320666F7220636E6C3A20002C20646174613A20006765
2014.10.30 14:35:41.078 4: CUL_send:  cul868As 27 03 00CA 1ACE1F 266E75 745265672C206C656E3A20002C20706565724964783A20002C207068794C
2014.10.30 14:35:41.094 4: CUL_send:  cul868As 27 04 00CA 1ACE1F 266E75 656E3A20002C20706879416464723A20002C20736C634C656E3A20006765
2014.10.30 14:35:41.110 4: CUL_send:  cul868As 27 05 00CA 1ACE1F 266E75 74536C69636544657461696C2C20736C635074723A20002C2073697A6520
2014.10.30 14:35:41.125 4: CUL_send:  cul868As 27 06 00CA 1ACE1F 266E75 6F663A20004C6F6164696E67205065657244422C207374617274733A2000
2014.10.30 14:35:41.142 4: CUL_send:  cul868As 27 07 00CA 1ACE1F 266E75 646F6E650A0066697273742073746172742064657465637465642C20666F
2014.10.30 14:35:41.157 4: CUL_send:  cul868As 27 08 00CA 1ACE1F 266E75 726D6174696E6720656570726F6D2E2E2E0A000A0A00556E6B6E6F776E20
2014.10.30 14:35:41.174 4: CUL_send:  cul868As 1B 09 20CA 1ACE1F 266E75 4D6573736167652C20706C65617365207265
2014.10.30 14:35:41.265 4: CUL_Parse: cul868 A 0A 09 8002 266E75 1ACE1F 803F -42.5
2014.10.30 14:35:46.198 1: PERL WARNING: Use of uninitialized value $mNo in sprintf at ./FHEM/10_CUL_HM.pm line 5342.
2014.10.30 14:35:46.204 5: CUL_HM fwUpdate write block 3 of 224: 9 messages
2014.10.30 14:35:46.207 4: CUL_send:  cul868As 27 01 00CA 1ACE1F 266E75 01007367322C206D73675074723A20002C20706565723A20004C6F616469
2014.10.30 14:35:46.224 4: CUL_send:  cul868As 27 02 00CA 1ACE1F 266E75 6E67206C6973743320666F7220636E6C3A20002C20646174613A20006765
2014.10.30 14:35:46.240 4: CUL_send:  cul868As 27 03 00CA 1ACE1F 266E75 745265672C206C656E3A20002C20706565724964783A20002C207068794C
2014.10.30 14:35:46.255 4: CUL_send:  cul868As 27 04 00CA 1ACE1F 266E75 656E3A20002C20706879416464723A20002C20736C634C656E3A20006765
2014.10.30 14:35:46.272 4: CUL_send:  cul868As 27 05 00CA 1ACE1F 266E75 74536C69636544657461696C2C20736C635074723A20002C2073697A6520
2014.10.30 14:35:46.288 4: CUL_send:  cul868As 27 06 00CA 1ACE1F 266E75 6F663A20004C6F6164696E67205065657244422C207374617274733A2000
2014.10.30 14:35:46.304 4: CUL_send:  cul868As 27 07 00CA 1ACE1F 266E75 646F6E650A0066697273742073746172742064657465637465642C20666F
2014.10.30 14:35:46.320 4: CUL_send:  cul868As 27 08 00CA 1ACE1F 266E75 726D6174696E6720656570726F6D2E2E2E0A000A0A00556E6B6E6F776E20
2014.10.30 14:35:46.336 4: CUL_send:  cul868As 1B 09 20CA 1ACE1F 266E75 4D6573736167652C20706C65617365207265
2014.10.30 14:35:46.398 4: CUL_Parse: cul868 A 0A 09 8002 266E75 1ACE1F 803F -42.5
2014.10.30 14:35:51.360 1: PERL WARNING: Use of uninitialized value $mNo in sprintf at ./FHEM/10_CUL_HM.pm line 5342.
2014.10.30 14:35:51.366 5: CUL_HM fwUpdate write block 3 of 224: 9 messages
2014.10.30 14:35:51.370 4: CUL_send:  cul868As 27 01 00CA 1ACE1F 266E75 01007367322C206D73675074723A20002C20706565723A20004C6F616469
2014.10.30 14:35:51.386 4: CUL_send:  cul868As 27 02 00CA 1ACE1F 266E75 6E67206C6973743320666F7220636E6C3A20002C20646174613A20006765
2014.10.30 14:35:51.403 4: CUL_send:  cul868As 27 03 00CA 1ACE1F 266E75 745265672C206C656E3A20002C20706565724964783A20002C207068794C
2014.10.30 14:35:51.419 4: CUL_send:  cul868As 27 04 00CA 1ACE1F 266E75 656E3A20002C20706879416464723A20002C20736C634C656E3A20006765
2014.10.30 14:35:51.436 4: CUL_send:  cul868As 27 05 00CA 1ACE1F 266E75 74536C69636544657461696C2C20736C635074723A20002C2073697A6520
2014.10.30 14:35:51.452 4: CUL_send:  cul868As 27 06 00CA 1ACE1F 266E75 6F663A20004C6F6164696E67205065657244422C207374617274733A2000
2014.10.30 14:35:51.468 4: CUL_send:  cul868As 27 07 00CA 1ACE1F 266E75 646F6E650A0066697273742073746172742064657465637465642C20666F
2014.10.30 14:35:51.484 4: CUL_send:  cul868As 27 08 00CA 1ACE1F 266E75 726D6174696E6720656570726F6D2E2E2E0A000A0A00556E6B6E6F776E20
2014.10.30 14:35:51.500 4: CUL_send:  cul868As 1B 09 20CA 1ACE1F 266E75 4D6573736167652C20706C65617365207265
2014.10.30 14:35:56.674 4: CUL_send:  cul868Ar
2014.10.30 14:35:56.794 5: CUL_HM SwitchPBU02 protEvent:CMDs_done_FWupdate
gruss frank
FHEM: 6.0(SVN) => Pi3(buster)
