SMARTMON - ein Frontend für smartctl
Begonnen von hexenmeister, 15 Dezember 2014, 23:47:45
Michi1972
Moin hexenmeister,
das sieht schon mal nicht schlecht aus! Da sind noch kosmetische Dinge, aber der Ansatz scheint gut zu sein. Hier die Readings:
     2022-10-30 23:00:58   009_            Flag:  Val:  Worst:  Thresh:  Type:  Updated:  When_Failed:  Raw:
     2022-10-30 23:00:58   available_spare 100%
     2022-10-30 23:00:58   available_spare_threshold 1%
     2022-10-30 23:00:58   controller_busy_time 7
     2022-10-30 23:00:58   critical_comp_temperature_time 0
     2022-10-30 23:00:58   critical_warning 0x00
     2022-10-30 23:00:58   data_units_read 105.128 [53,8 GB]
     2022-10-30 23:00:58   data_units_written 297.869 [152 GB]
     2022-10-30 23:00:58   deviceCapacity  128.035.676.160 [128 GB]
     2022-10-30 23:00:58   deviceFirmware  SN09111
     2022-10-30 23:00:58   deviceModel     Patriot M.2 P300 128GB
     2022-10-30 23:00:58   deviceSerial    P300ED...xyz...
     2022-10-30 23:00:58   error_information_log_entries 69
     2022-10-30 23:00:58   host_read_commands 1.147.681
     2022-10-30 23:00:58   host_write_commands 22.584.057
     2022-10-30 23:00:58   last_exit_code  0
     2022-10-30 23:00:58   media_and_data_integrity_errors 0
     2022-10-30 23:00:58   overall_health_test PASSED
     2022-10-30 23:00:58   percentage_used 1%
     2022-10-30 23:00:58   power_cycle_count 45
     2022-10-30 23:00:58   power_on_hours  917
     2022-10-30 23:00:58   power_on_text   0 Jahre 0 Tage 0 Std.
     2022-10-30 23:00:58   temperature     39 Celsius
     2022-10-30 23:00:58   temperature1    50 Celsius
     2022-10-30 23:00:58   temperature2    51 Celsius
     2022-10-30 23:00:58   temperature3    52 Celsius
     2022-10-30 23:00:58   temperature4    53 Celsius
     2022-10-30 23:00:58   temperature5    54 Celsius
     2022-10-30 23:00:58   temperature6    55 Celsius
     2022-10-30 23:00:58   temperature7    56 Celsius
     2022-10-30 23:00:58   temperature8    57 Celsius
     2022-10-30 23:00:58   unsafe_shutdowns 39
     2022-10-30 23:00:58   warning_comp_temperature_time 0
     2022-10-30 23:00:58   warnings        Pre-fail: 0 Old_age: 0
Das Wort " Celsius" hinter den Temperaturen z.B. oder die power_on_text Berechnung. Wo kommt denn das 009_ her? Aber eins muss man Dir lassen: Du hast es echt drauf :)  8)
Danke und Gruß
Michael
hexenmeister
Michi1972
Moin hexenmeister,
wenn Du mein Grinsen im Gesicht sehen könntest! Es sieht hervorragend aus. Mann, Du hast es echt drauf! Vielen Dank!
Hier meine Readings mit der neuen Version, die Du gerne einchecken kannst:
     2022-10-31 17:28:31   available_spare 100%
     2022-10-31 17:28:31   available_spare_threshold 1%
     2022-10-31 17:28:31   controller_busy_time 8
     2022-10-31 17:28:31   critical_comp_temperature_time 0
     2022-10-31 17:28:31   critical_warning 0x00
     2022-10-31 17:28:31   data_units_read 105.178 [53,8 GB]
     2022-10-31 17:28:31   data_units_written 303.965 [155 GB]
     2022-10-31 17:28:31   deviceCapacity  128.035.676.160 [128 GB]
     2022-10-31 17:28:31   deviceFirmware  SN09111
     2022-10-31 17:28:31   deviceModel     Patriot M.2 P300 128GB
     2022-10-31 17:28:31   deviceSerial    P300ED...xyz....
     2022-10-31 17:28:31   error_information_log_entries 69
     2022-10-31 17:28:31   host_read_commands 1.148.733
     2022-10-31 17:28:31   host_write_commands 23.090.236
     2022-10-31 17:28:31   last_exit_code  0
     2022-10-31 17:28:31   media_and_data_integrity_errors 0
     2022-10-31 17:28:31   overall_health_test PASSED
     2022-10-31 17:28:31   percentage_used 1%
     2022-10-31 17:28:31   power_cycle_count 45
     2022-10-31 17:28:31   power_on_hours  936
     2022-10-31 17:28:31   power_on_text   0 Jahre 39 Tage 0 Std.
     2022-10-31 17:28:31   temperature     39
     2022-10-31 17:28:31   temperature1    50
     2022-10-31 17:28:31   temperature2    51
     2022-10-31 17:28:31   temperature3    52
     2022-10-31 17:28:31   temperature4    53
     2022-10-31 17:28:31   temperature5    54
     2022-10-31 17:28:31   temperature6    55
     2022-10-31 17:28:31   temperature7    56
     2022-10-31 17:28:31   temperature8    57
     2022-10-31 17:28:31   unsafe_shutdowns 39
     2022-10-31 17:28:31   warning_comp_temperature_time 0
     2022-10-31 17:28:31   warnings        Pre-fail: 0 Old_age: 0
Vielen Dank!
Michael
Michi1972
Moin hexenmeister,
mir ist noch ein Fehler aufgefallen, ab der 1000. Stunde passiert dies hier:
2022-11-03 16:19:29   power_on_hours  1.006
2022-11-03 16:19:29   power_on_text   0 Jahre 0 Tage 1 Std.
Michael
hexenmeister
Michi1972
jo, das passt nun:
2022-11-05 20:37:13   power_on_hours  1.059
2022-11-05 20:37:13   power_on_text   0 Jahre 44 Tage 3 Std.
Mir sind keine weiteren Fehler aufgefallen. Checkst Du diese Version nun ein?
Danke für Deine Mühe!
Michael
hexenmeister
