Fehler bei allen SVG-Plots seit heutigem update
Begonnen von Urga, 10 Januar 2015, 22:29:15
Kannst du bitte die Rohdaten beider Versionen (erreichbar ueber "Show preprocessed Input" im PlotEditor) hier anhaengen?
stromer-12
fehlende Ventildarstellung:
get myLogProxy CURRENT INT 2015-01-11_11:15:00 2015-01-12_11:15:01 DbLog:myDbLog:FHT_1a38:measured-temp:0: DbLog:myDbLog,extend=44000,predict:FHT_1a38:desired-temp:0::$val=~s/.*(on).*/27/eg;$val=~s/.*(off).*/5/eg DbLog:myDbLog,extend=3600,predict:FHT_1a38:actuator:0:int:
2015-01-11_11:28:04 18.2
2015-01-11_11:41:28 18.3
2015-01-11_12:10:13 18.4
2015-01-11_12:27:28 18.1
2015-01-11_12:41:14 18.0
2015-01-11_12:58:08 18.3
2015-01-11_13:09:38 18.4
2015-01-11_13:26:53 18.6
2015-01-11_13:42:14 18.6
2015-01-11_13:57:33 18.3
2015-01-11_14:09:14 18.1
2015-01-11_14:26:18 18.3
2015-01-11_14:41:38 18.5
2015-01-11_14:57:14 18.5
2015-01-11_15:09:15 18.4
2015-01-11_15:27:38 18.5
2015-01-11_15:41:14 18.6
2015-01-11_15:57:14 18.3
2015-01-11_16:09:48 18.1
2015-01-11_16:27:03 18.3
2015-01-11_16:41:14 18.4
2015-01-11_16:57:43 18.5
2015-01-11_17:09:14 18.3
2015-01-11_17:26:28 18.4
2015-01-11_17:41:48 18.4
2015-01-11_17:57:14 18.4
2015-01-11_18:09:14 18.7
2015-01-11_18:27:48 19.0
2015-01-11_18:41:14 18.7
2015-01-11_18:57:15 18.8
2015-01-11_19:09:59 19.2
2015-01-11_19:27:13 19.7
2015-01-11_19:41:15 19.7
2015-01-11_19:57:53 19.6
2015-01-11_20:26:39 19.4
2015-01-11_20:41:58 19.5
2015-01-11_20:57:18 19.5
2015-01-11_21:09:14 19.3
2015-01-11_21:27:58 18.9
2015-01-11_21:41:23 18.6
2015-01-11_21:57:14 18.2
2015-01-11_22:10:08 17.9
2015-01-11_22:27:23 17.6
2015-01-11_22:42:44 17.3
2015-01-11_22:58:03 17.1
2015-01-11_23:09:33 16.9
2015-01-11_23:26:48 16.6
2015-01-11_23:42:09 16.5
2015-01-11_23:57:28 16.4
2015-01-12_00:09:14 16.2
2015-01-12_00:28:08 16.1
2015-01-12_00:41:34 16.1
2015-01-12_00:57:14 16.0
2015-01-12_01:10:18 15.9
2015-01-12_01:27:33 15.8
2015-01-12_01:41:14 15.8
2015-01-12_01:58:13 15.7
2015-01-12_02:11:39 15.6
2015-01-12_02:26:58 15.6
2015-01-12_02:41:14 15.5
2015-01-12_02:57:38 15.4
2015-01-12_03:09:14 15.3
2015-01-12_03:26:23 15.3
2015-01-12_03:40:14 15.3
2015-01-12_03:57:03 15.2
2015-01-12_04:27:44 15.1
2015-01-12_04:41:08 15.1
2015-01-12_04:58:23 15.2
2015-01-12_05:08:14 15.6
2015-01-12_05:27:08 16.0
2015-01-12_05:42:29 16.1
2015-01-12_05:50:08 16.2
2015-01-12_05:56:14 16.3
2015-01-12_06:08:14 16.4
2015-01-12_06:26:33 16.6
2015-01-12_06:40:14 17.0
2015-01-12_06:57:13 17.8
2015-01-12_07:08:43 18.2
2015-01-12_07:25:58 18.6
2015-01-12_07:40:14 18.8
2015-01-12_07:56:38 18.3
2015-01-12_08:08:14 18.4
2015-01-12_08:25:23 18.3
2015-01-12_08:40:43 18.7
2015-01-12_08:56:14 19.0
2015-01-12_09:26:43 18.9
2015-01-12_09:40:14 18.7
2015-01-12_09:56:14 18.5
2015-01-12_10:08:53 18.4
2015-01-12_10:26:08 18.4
2015-01-12_10:40:14 18.4
2015-01-12_10:56:48 18.2
#FHT_1a38:measured-temp:::
2015-01-11_11:15:00 18.5
2015-01-11_13:07:43 18.5
2015-01-11_15:58:18 19.0
2015-01-11_20:26:38 19.0
2015-01-11_20:38:09 17.0
2015-01-11_21:03:04 16.0
2015-01-11_22:33:08 19.0
2015-01-11_22:38:53 16.0
2015-01-12_04:27:43 16.0
2015-01-12_06:03:33 19.0
2015-01-12_10:51:04 8.0
2015-01-12_10:52:58 19.0
2015-01-12_11:02:42 19.0
#FHT_1a38:desired-temp:::$val=~s/.*(on).*/27/eg
Mit Ventildarstellung:
get myLogProxy CURRENT INT 2015-01-12_05:05:00 2015-01-12_11:05:01 DbLog:myDbLog:FHT_1a38:measured-temp:0: DbLog:myDbLog,extend=3600,predict:FHT_1a38:actuator:0:int: DbLog:myDbLog,extend=44000,predict:FHT_1a38:desired-temp:0::$val=~s/.*(on).*/27/eg;$val=~s/.*(off).*/5/eg
2015-01-12_05:05:00 48
2015-01-12_05:06:02 42
2015-01-12_05:13:43 36
2015-01-12_05:17:32 34
2015-01-12_05:25:12 33
2015-01-12_05:32:52 31
2015-01-12_05:42:27 30
2015-01-12_05:46:17 28
2015-01-12_05:53:57 26
2015-01-12_06:05:27 82
2015-01-12_06:20:47 82
2015-01-12_06:47:37 82
2015-01-12_07:02:57 59
2015-01-12_07:10:37 54
2015-01-12_07:22:07 48
2015-01-12_07:37:27 44
2015-01-12_07:39:22 45
2015-01-12_07:50:52 51
2015-01-12_08:13:52 56
2015-01-12_08:36:52 51
2015-01-12_08:42:37 47
2015-01-12_08:48:22 45
2015-01-12_08:56:02 43
2015-01-12_09:22:52 43
2015-01-12_09:24:47 45
2015-01-12_09:28:37 47
2015-01-12_09:51:37 53
2015-01-12_10:18:27 53
2015-01-12_10:29:57 53
2015-01-12_10:51:03 0
2015-01-12_10:52:57 58
2015-01-12_11:00:53 58
#FHT_1a38:actuator::int:
2015-01-12_05:05:00 16.0
2015-01-12_11:00:53 19.0
FHEM (SVN) auf RPi1B mit HMser | ESPLink
FHEM (SVN) virtuell mit HMLAN | HMUSB | CUL
MadCat
Leider hat das Update das Problem bei mir auch nicht behoben, seit dem Update werden keine Temperaturwerte mehr geloggt.
stromer-12
Nicht mehr gelogt oder nicht mehr geplottet?
MadCat
Plott funktioniert mit den alten Daten einwandfrei. Es werden seit dem Zeitpunkt des Updates keine Temperaturen mehr geloggt. Schaltzustand der Pumpen wird weiterhin geloggt.
@MadCat: Dann ist das hier der falsche Thread.
Und die obligatorischen Fragen:
- mit welchen Mechanismus speicherst du die Daten, bitte definition posten
- bekommst du die Events (bitte Event-Monitor oder inform timer Abschnitt posten).
MadCat
#21
Ich hatte für mein Problem keinen Thread gefunden und einen eigenen aufgemacht, da aber keine Hilfe bekommen und mich hier mit dran gehangen.
Die meisteh hier haben zwar von SVG Problemen geschrieben, aber dort kann es ja auch an den Loggs liegen.
Mein define sieht so aus
define FileLog_Heizung FileLog ./log/Heizung-%Y-%m-%d.log Heizkreis_Ruecklauf.T.*|Heizkreis_Vorlauf.T.*|Heizkreispumpe:.*|Heizkreisventil:.*|Kesselmisch_temp.T.*|Kesselpumpe..*|Kesselpumpe:off.*|Kesselpumpe:on.*|Kesselrueck_temp.T.*|Kesseltemp.T.*|Kesselvor_temp.T.*|Kollektor1_Ruecklauf.T.*|Kollektor1_Vorlauf.T.*|Kollektor2_Ruecklauf.T.*|Kollektor2_Vorlauf.T.*|Puffer1_100.T.*|Puffer1_25.T.*|Puffer1_50.T.*|Puffer1_75.T.*|Rauchgas_Temp.T.*|Solar_Ruecklauf.T.*|Solar_Vorlauf.T.*|Solarkreispumpe.*|Solarkreispumpe:state:.*|Solarkreisventil.*
attr FileLog_Heizung logtype text
define SVG_FileLog_Heizung_1 SVG FileLog_Heizung:SVG_FileLog_Heizung_1:CURRENT
attr SVG_FileLog_Heizung_1 plotsize 800,400
define SVG_FileLog_Heizung_2 SVG FileLog_Heizung:SVG_FileLog_Heizung_2:CURRENT
attr SVG_FileLog_Heizung_2 plotsize 800,400
Und auszug aus meinem Event
2015-01-12 15:22:09 THRESHOLD Ofensteuerung sensor_value: 20.44
2015-01-12 15:22:09 ECMDDevice Kesseltemp temperature: 20.44
2015-01-12 15:22:13 ECMDDevice Kollektor2_Ruecklauf temperature: 25.44
2015-01-12 15:22:13 ECMDDevice Puffer1_50 temperature: 26.25
2015-01-12 15:22:14 ECMDDevice Puffer1_75 temperature: 26.19
2015-01-12 15:22:15 ECMDDevice Kesselvor_temp temperature: 17.38
2015-01-12 15:22:18 ECMDDevice Puffer1_75 temperature: 26.13
2015-01-12 15:22:18 ECMDDevice Kollektor1_Ruecklauf temperature: 21.63
2015-01-12 15:22:18 ECMDDevice Kollektor2_Ruecklauf temperature: 25.50
2015-01-12 15:22:19 ECMDDevice Kesselvor_temp temperature: 17.31
2015-01-12 15:22:19 THRESHOLD Solarsteuerung sensor_value: 21.38
2015-01-12 15:22:19 ECMDDevice Kollektor2_Vorlauf temperature: 21.38
2015-01-12 15:22:20 ECMDDevice Rauchgas_Temp temperature: 20.94
2015-01-12 15:22:23 ECMDDevice Puffer1_75 temperature: 26.19
2015-01-12 15:22:24 THRESHOLD Ofensteuerung sensor_value: 20.38
2015-01-12 15:22:24 THRESHOLD Ofensteuerung sensor2_state: T state: 20.94
2015-01-12 15:22:24 ECMDDevice Kesseltemp temperature: 20.38
2015-01-12 15:22:24 ECMDDevice Rauchgas_Temp temperature: 21.00
2015-01-12 15:22:24 ECMDDevice Kollektor2_Ruecklauf temperature: 25.44
2015-01-12 15:22:28 ECMDDevice Kollektor2_Ruecklauf temperature: 25.50
2015-01-12 15:22:29 THRESHOLD Ofensteuerung sensor_value: 20.44
2015-01-12 15:22:29 THRESHOLD Ofensteuerung sensor2_state: T state: 21.00
2015-01-12 15:22:29 ECMDDevice Kesseltemp temperature: 20.44
2015-01-12 15:22:30 ECMDDevice Solar_Vorlauf temperature: 12.50
2015-01-12 15:22:33 ECMDDevice Puffer1_75 temperature: 26.13
2015-01-12 15:22:34 THRESHOLD Ofensteuerung sensor_value: 20.38
2015-01-12 15:22:34 ECMDDevice Kesseltemp temperature: 20.38
2015-01-12 15:22:34 ECMDDevice Solar_Vorlauf temperature: 12.56
2015-01-12 15:22:34 ECMDDevice Kollektor2_Ruecklauf temperature: 25.44
2015-01-12 15:22:35 ECMDDevice Puffer1_100 temperature: 25.56
2015-01-12 15:22:39 ECMDDevice Puffer1_100 temperature: 25.50
2015-01-12 15:22:40 THRESHOLD Ofensteuerung sensor_value: 20.44
2015-01-12 15:22:40 ECMDDevice Kesseltemp temperature: 20.44
2015-01-12 15:22:40 ECMDDevice Heizkreis_Vorlauf temperature: 24.81
2015-01-12 15:22:44 ECMDDevice Heizkreis_Vorlauf temperature: 24.88
2015-01-12 15:22:44 ECMDDevice Puffer1_50 temperature: 26.19
2015-01-12 15:22:45 THRESHOLD Solarsteuerung sensor_value: 21.44
2015-01-12 15:22:45 ECMDDevice Kollektor2_Vorlauf temperature: 21.44
2015-01-12 15:22:49 THRESHOLD Solarsteuerung sensor_value: 21.38
2015-01-12 15:22:49 ECMDDevice Kollektor2_Vorlauf temperature: 21.38
2015-01-12 15:22:49 THRESHOLD Ofensteuerung sensor_value: 20.38
2015-01-12 15:22:49 ECMDDevice Kesseltemp temperature: 20.38
2015-01-12 15:22:50 ECMDDevice Heizkreis_Vorlauf temperature: 24.81
2015-01-12 15:22:50 ECMDDevice Solar_Vorlauf temperature: 12.50
#22
Der gezeigte Regexp trifft auf keinen der gezeigten Events zu, deswegen landet davon nichts im Logfile.
Welches der Regexp-Teile soll auf welches Event zutreffen? Oder ist das gewuenschte Event gar nicht in der Liste?
@stromer-12:
Der Datensatztrenner ist # am Anfang der Zeile, immer am Ende der Daten.
myLogProxy hat im ersten Fall nur zwei Datensaetze zuerueckgeliefert, obwohl im get eindeutig 3 Datensaetze angefordert werden, da drei leerzeichen getrennte Parameter nach dem zwei Dateumsfeldern.
Dazu sollte andre was sagen.
stromer-12
Ich habe mal bei mir in der Eingabeaufforderung die get Anweisung eingegeben, da gibt es eine Fehlermeldung.
SVG oder logProxy selber geben keinen Fehler zurück.
Unknown command $val=~s/.*(off).*/5/eg, try help.
Mal sehen was da gemacht werden kann.
Bitte ; mit ;; schuetzen.
Ich glaube das ist auch dein Problem. Und ich behaupte, es hat mit dem Umbau bzw. update nichts zu tun.
tiroso
Bei mir funktioniert das SVg longpolling leider nach wie vor nicht.
Wie kann ich hier am besten die Fehlerquelle lokalisieren?
Punkt
nach einem vorhin durchgeführten Update funktioniert longpollsvg bei mir auch nicht mehr....die Plots werden nicht mehr aktualisiert - direkt vor dem Update wurden alle Plots bei Datenänderungen neu geladen...
Michael
FHEM auf LXD-Container (Ubuntu 24.04) mit 1wire-Bus und I2C-Extensions
Datenbank: influxdb
verschiedene "Satellitensysteme" mit ESP-8266
Bennemannc
heute 20.01.2015 sind nach dem Update manchmal die Icons verschwunden. Bei Räumen ohne Grafik werden die Icons angezeigt (Menue und Geräte) bei Räumen mit SVG Grafik werden die Icons nicht mehr angezeigt. Was mich verwundert ist, das alle Icon dann verschwunden sind (Räume und Geräte).
Ich vermute den Fehler in der SVG.pm
Gruß Christoph
Cubietruck, Fhem 5.8
tiroso
Hallo zusammen.
Ich denke das kann ja jetzt geschlossen werden.
Das Longpolling und die Anzeige der SVGs klappt wieder ohne Probleme
