THZ Tecalor (LWZ Stiebel Eltron) module support and code improvement.
Begonnen von immi, 02 Februar 2015, 11:42:16
immi
Zitat von: mwuerr am 14 Juli 2025, 23:46:17...
0C0613 for COOLING SYSTEM HC2
can you send me a test version?
sorry for the late reply
just add the line in a txt-editor like below, test it.
After you positive feedback, I can commit it to the repository
immi
my %sets539only =(
"p75passiveCooling"           => {cmd2=>"0A0575", argMin =>   "0",    argMax =>  "4",         type =>"1clean", unit =>""},
"p99PumpRateHC"               => {cmd2=>"0A02CB", argMin =>   "0",    argMax =>  "100",       type =>"5temp",  unit =>" %"},
"p99PumpRateDHW"              => {cmd2=>"0A02CC", argMin =>   "0",    argMax =>  "100",       type =>"5temp",  unit =>" %"} ,
"p99CoolingHC1Switch"         => {cmd2=>"0B0287", argMin =>   "0",    argMax =>  "1",         type =>"1clean", unit =>""},
"p99CoolingHC1AreaFan"        => {cmd2=>"0B0613", argMin =>   "0",    argMax =>  "1",         type =>"1clean", unit =>""},
takoda
Hi Immi,
I'm having an issue with the values outputVentilatorPower and inputVentilatorPower in sGlobal. I have an LWZ 304 Trend with firmware 7.09. Both values are being reported as 6538.6, while mainVentilatorPower is showing plausible readings. I received a tip in the other Thread and tried experimenting a bit with the firmware attribute, but it didn't make any difference.
Do you have any other ideas?
Thanks in advance!
sGlobal
outsideTemp: 12.7 flowTemp: 31.5 returnTemp: 30 hotGasTemp: 36.9 dhwTemp: 48 flowTempHC2: -60
evaporatorTemp: 31.8 condenserTemp: 30.2 mixerOpen: 0 mixerClosed: 0 heatPipeValve: 0
diverterValve: 0 dhwPump: 0 heatingCircuitPump: 0 solarPump: 0 compressor: 0 boosterStage3: 0
boosterStage2: 0 boosterStage1: 0 highPressureSensor: 0 lowPressureSensor: 0 evaporatorIceMonitor: 0
signalAnode: 0 evuRelease: 1 ovenFireplace: 1 STB: 0 outputVentilatorPower: 6538.6 inputVentilatorPower: 6538.6
mainVentilatorPower: 0 outputVentilatorSpeed: 26 inputVentilatorSpeed: 24 mainVentilatorSpeed: 0
outside_tempFiltered: 13.1 relHumidity: 0 dewPoint: 0 P_Nd: 8.41 P_Hd: 14.91 actualPower_Qc: 0.000
 actualPower_Pel: 0.000 collectorTemp: -60 insideTemp: -60 windowOpen: 0 quickAirVent: 0 flowRate: 0 p_HCw: 1.46 humidityAirOut: 35.92
immi
Hi takoda
example of decoding
set attribute for thz "verbose 5", read sGlobal, you find in log the raw register, something like
2025.09.29 08:21:17.609 5: THZ_ReadAnswer: uc unpack: '01003EFBFDA8006A00EB00DB013D01DEFDA800F600CB00E3000011010E010E0000002500260000006600000000037503AC00000000000000001003'
look at position 50    --> 010E  -->  270 --> outputVentilatorPower: 27
which is interpreted as
outsideTemp: 10.7 flowTemp: 23.8 returnTemp: 21.9 hotGasTemp: 30.8 dhwTemp: 47.7 flowTempHC2: -60 evaporatorTemp: 20.5 condenserTemp: 22.8 mixerOpen: 0 mixerClosed: 0 heatPipeValve: 0 diverterValve: 0 dhwPump: 0 heatingCircuitPump: 0 solarPump: 0 compressor: 0 boosterStage3: 0 boosterStage2: 0 boosterStage1: 0 highPressureSensor: 0 lowPressureSensor: 1 evaporatorIceMonitor: 0 signalAnode: 0 evuRelease: 1 ovenFireplace: 0 STB: 0 outputVentilatorPower: 27 inputVentilatorPower: 27 mainVentilatorPower: 0 outputVentilatorSpeed: 37 inputVentilatorSpeed: 38 mainVentilatorSpeed: 0 outside_tempFiltered: 10.2 relHumidity: 0 dewPoint: 0 P_Nd: 8.98 P_Hd: 8.89 actualPower_Qc: 0.000 actualPower_Pel: 0.000 collectorTemp: -60 insideTemp: 24.7 windowOpen: 0 quickAirVent: 0
explanation
https://github.com/fhem/fhem-mirror/blob/master/fhem/FHEM/00_THZ.pm
if  you read in the code at about line 297, it is written what (outputVentilatorPower), where (position 50), and how to interprete the values (hex 4long to be divided by 10)
[" outputVentilatorPower: ",50, 4, "hex", 10],    [" inputVentilatorPower: ",54, 4, "hex", 10],    [" mainVentilatorPower: ",    58, 4, "hex", 10],
Solution
there are two possibilities for your finrmware: the position of the information you try to interprete is moved in the tecalor-register or the format (e.g. maybe you have to divide by 100 and not by 10)
please share the raw register for sGlobal and SFan; they should have similar fan values
b.r. immi
takoda
Hi immi, thanks for your response.
Here are the raw registers of sGlobal and sFan:
sGlobal:
2025.09.29 13:03:38 5: THZ_Get: Try to get 'sGlobal'
2025.09.29 13:03:38 5: THZ_Get_Comunication: Check if port is open. State = '(opened)'
2025.09.29 13:03:38 5: Mythz sending 02
2025.09.29 13:03:38 5: DevIo_SimpleWrite Mythz: 02
2025.09.29 13:03:38 5: Mythz start Function THZ_ReadAnswer
2025.09.29 13:03:38 5: THZ_ReadAnswer: uc unpack: '10'
2025.09.29 13:03:38 5: Mythz sending 0100FCFB1003
2025.09.29 13:03:38 5: DevIo_SimpleWrite Mythz: 0100FCFB1003
2025.09.29 13:03:38 5: THZ_ReadAnswer: uc unpack: '02'
2025.09.29 13:03:38 5: Mythz sending 10
2025.09.29 13:03:38 5: DevIo_SimpleWrite Mythz: 10
2025.09.29 13:03:38 5: THZ_ReadAnswer: uc unpack: '010001FBFDA800B000FC00F400E901B7FDA8FDA800E000F5000033FF6AFF6A0000001B001A000000AE00000000037404B20000000000000000000000900000000000F400F300E600D500E6000000000EC51003'
2025.09.29 13:03:38 5: Parse message: 01FBFDA800B000FC00F400E901B7FDA8FDA800E000F5000033FF6AFF6A0000001B001A000000AE00000000037404B20000000000000000000000900000000000F400F300E600D500E6000000000EC5
2025.09.29 13:03:38 5: Message length: 158
sFan:
2025.09.29 13:06:29 5: THZ_Get: Try to get 'sFan'
2025.09.29 13:06:29 5: THZ_Get_Comunication: Check if port is open. State = '(opened)'
2025.09.29 13:06:29 5: Mythz sending 02
2025.09.29 13:06:29 5: DevIo_SimpleWrite Mythz: 02
2025.09.29 13:06:29 5: Mythz start Function THZ_ReadAnswer
2025.09.29 13:06:29 5: THZ_ReadAnswer: uc unpack: '10'
2025.09.29 13:06:29 5: Mythz sending 0100E9E81003
2025.09.29 13:06:29 5: DevIo_SimpleWrite Mythz: 0100E9E81003
2025.09.29 13:06:29 5: THZ_ReadAnswer: uc unpack: '02'
2025.09.29 13:06:29 5: Mythz sending 10
2025.09.29 13:06:29 5: DevIo_SimpleWrite Mythz: 10
2025.09.29 13:06:29 5: THZ_ReadAnswer: uc unpack: '010017E8000000000000000000000000000000000000000000000000000000191B008C008CF1F1001003'
2025.09.29 13:06:29 5: Parse message: 17E8000000000000000000000000000000000000000000000000000000191B008C008CF1F100
2025.09.29 13:06:29 5: Message length: 76
Thank You!
immi
Zitat von: takoda am 29 September 2025, 13:43:42Hi immi, thanks for your response.
sGlobal:'010001FBFDA800B000FC00F400E901B7FDA8FDA800E000F5000033FF6AFF6A0000001B001A000000AE00000000037404B20000000000000000000000900000000000F400F300E600D500E6000000000EC51003'
sFan:'010017E8000000000000000000000000000000000000000000000000000000191B008C008CF1F1001003'
I do not know how to interprete FF6A and F1 and get the same number in base10.
can you please read on your physical tecalor display the value of outputVentilatorPower?
and at the same time, confirm the raw data of sFan and sGlobal ?
sunrise
Can someone confirm that for THZ firmware 2.06 / 02.16 the readings
`hcOpMode` and `dhwOpMode` behave as follows?
- `hcOpMode`: switches between *normal* (day) and *setback* (night) according to the heating schedule (`pHeatProg`)
- `dhwOpMode`: almost always stays at *normal*, even outside the DHW program (`pDHWProg`)
- both may also show *standby*, *manual* or *holiday* in other situations
Is this interpretation correct, or does someone see different behavior on newer firmware?
Viele Grüße/kind regards
sunrise
_________________
Tecalor THZ 303 (SOL, 2006/09-2008/08), FW 2.16 | FHEM THZ module testing with FW 2.06 (INTEGRAL, 2006/12-2008/08) & FW 2.14 (SOL, 2002/10-2004/08) on Raspberry Pi 2
