Frage zum richtigen Anlernen - Probleme CMDs_Pending
Begonnen von hpk007, 05 September 2015, 13:12:15
hpk007
Hallo hab jetzt einen Fhem neustart gemacht und danach den Aktor mit Seriennummer gepaired - nachfolgend ein Auszug aus dem Logfile:
2015.09.07 19:44:18.813 0: Server shutdown
2015.09.07 19:44:22.645 1: Including fhem.cfg
2015.09.07 19:44:24.344 1: HMLAN_Parse: HMLANHPK new condition disconnected
2015.09.07 19:44:24.389 1: HMLAN_Parse: HMLANHPK new condition init
2015.09.07 19:44:27.466 1: Including ./log/fhem.save
2015.09.07 19:44:27.509 1: usb create starting
2015.09.07 19:44:34.820 1: usb create end
2015.09.07 19:44:34.863 0: Featurelevel: 5.6
2015.09.07 19:44:34.864 0: Server started with 14 defined entities (version $Id: fhem.pl 9195 2015-09-03 07:23:40Z rudolfkoenig $, os linux, user fhem, pid 3697)
2015.09.07 19:44:34.872 0: HMLAN_Parse: HMLANHPK V:03C4 sNo:KEQ0852418 d:23A6E1 O:23A6E1 t:022602A4 IDcnt:0001 L:0 %
2015.09.07 19:44:34.885 0: HMLAN_Parse: HMLANHPK R:RA8E8AB98 stat:0002 t:00000000 d:FF r:7FFF     m:99 8112 999999 000000
2015.09.07 19:44:34.886 1: HMLAN_Parse: HMLANHPK new condition ok
2015.09.07 19:44:49.399 0: HMLAN_Send:  HMLANHPK I:K
2015.09.07 19:44:49.425 0: HMLAN_Parse: HMLANHPK V:03C4 sNo:KEQ0852418 d:23A6E1 O:23A6E1 t:0226647B IDcnt:0000 L:1 %
2015.09.07 19:45:14.406 0: HMLAN_Send:  HMLANHPK I:K
2015.09.07 19:45:14.411 0: HMLAN_Parse: HMLANHPK V:03C4 sNo:KEQ0852418 d:23A6E1 O:23A6E1 t:0226C62E IDcnt:0000 L:1 %
2015.09.07 19:45:15.130 0: HMLAN_Send:  HMLANHPK S:SA8E971C8 stat:  00 t:00000000 d:01 r:A8E971C8 m:01 8401 23A6E1 000000 010A4d455130303033313338
2015.09.07 19:45:15.200 0: HMLAN_Parse: HMLANHPK R:RA8E971C8 stat:0002 t:00000000 d:FF r:7FFF     m:01 8401 23A6E1 000000 010A4D455130303033313338
2015.09.07 19:45:15.309 0: HMLAN_Parse: HMLANHPK R:E34FDBA   stat:0000 t:0226C9A1 d:FF r:FFE1     m:01 8000 34FDBA 23A6E1 2500044D45513030303331333810010100
2015.09.07 19:45:20.418 0: HMLAN_Send:  HMLANHPK I:+34FDBA,00,00,00
2015.09.07 19:45:21.438 0: HMLAN_Send:  HMLANHPK S:+34FDBA,00,00,00
2015.09.07 19:45:21.439 0: HMLAN_Send:  HMLANHPK S:SA8E98A6C stat:  00 t:00000000 d:01 r:A8E98A6C m:02 A001 23A6E1 34FDBA 010E
2015.09.07 19:45:21.606 0: HMLAN_Parse: HMLANHPK R:E34FDBA   stat:0000 t:0226E23D d:FF r:FFE0     m:02 A410 34FDBA 23A6E1 0601000026
2015.09.07 19:45:21.739 0: HMLAN_Parse: HMLANHPK R:RA8E98A6C stat:0001 t:0226E242 d:FF r:FFE0     m:02 A410 34FDBA 23A6E1 0601000026
2015.09.07 19:45:23.172 0: HMLAN_Send:  HMLANHPK S:+34FDBA,00,00,00
2015.09.07 19:45:23.173 0: HMLAN_Send:  HMLANHPK S:SA8E99132 stat:  00 t:00000000 d:01 r:A8E99132 m:03 A011 23A6E1 34FDBA 0201C80000
2015.09.07 19:45:23.782 0: HMLAN_Parse: HMLANHPK R:RA8E99132 stat:0008 t:00000000 d:FF r:7FFF     m:03 A011 23A6E1 34FDBA 0201C80000
2015.09.07 19:45:23.783 0: HMLAN_Parse: HMLANHPK no ACK from 34FDBA
2015.09.07 19:45:26.518 0: HMLAN_Send:  HMLANHPK S:SA8E99E43 stat:  00 t:00000000 d:01 r:A8E99E43 m:03 A011 23A6E1 34FDBA 0201C80000
2015.09.07 19:45:27.141 0: HMLAN_Parse: HMLANHPK R:RA8E99E43 stat:0008 t:00000000 d:FF r:7FFF     m:03 A011 23A6E1 34FDBA 0201C80000
2015.09.07 19:45:27.143 0: HMLAN_Parse: HMLANHPK no ACK from 34FDBA
2015.09.07 19:45:32.273 0: HMLAN_Send:  HMLANHPK S:SA8E9B4BF stat:  00 t:00000000 d:01 r:A8E9B4BF m:03 A011 23A6E1 34FDBA 0201C80000
2015.09.07 19:45:32.881 0: HMLAN_Parse: HMLANHPK R:RA8E9B4BF stat:0008 t:00000000 d:FF r:7FFF     m:03 A011 23A6E1 34FDBA 0201C80000
2015.09.07 19:45:32.882 0: HMLAN_Parse: HMLANHPK no ACK from 34FDBA
2015.09.07 19:45:37.191 0: HMLAN_Send:  HMLANHPK S:SA8E9C7F4 stat:  00 t:00000000 d:01 r:A8E9C7F4 m:03 A011 23A6E1 34FDBA 0201C80000
2015.09.07 19:45:37.799 0: HMLAN_Parse: HMLANHPK R:RA8E9C7F4 stat:0008 t:00000000 d:FF r:7FFF     m:03 A011 23A6E1 34FDBA 0201C80000
2015.09.07 19:45:37.802 0: HMLAN_Parse: HMLANHPK no ACK from 34FDBA
2015.09.07 19:45:39.410 0: HMLAN_Send:  HMLANHPK I:K
2015.09.07 19:45:39.415 0: HMLAN_Parse: HMLANHPK V:03C4 sNo:KEQ0852418 d:23A6E1 O:23A6E1 t:022727DD IDcnt:0001 L:1 %
2015.09.07 19:45:45.474 0: HMLAN_Send:  HMLANHPK S:+34FDBA,00,00,00
2015.09.07 19:45:45.476 0: HMLAN_Send:  HMLANHPK S:SA8E9E850 stat:  00 t:00000000 d:01 r:A8E9E850 m:04 A001 23A6E1 34FDBA 00040000000000
2015.09.07 19:45:46.085 0: HMLAN_Parse: HMLANHPK R:RA8E9E850 stat:0008 t:00000000 d:FF r:7FFF     m:04 A001 23A6E1 34FDBA 00040000000000
2015.09.07 19:45:46.086 0: HMLAN_Parse: HMLANHPK no ACK from 34FDBA
2015.09.07 19:45:49.749 0: HMLAN_Send:  HMLANHPK S:SA8E9F903 stat:  00 t:00000000 d:01 r:A8E9F903 m:04 A001 23A6E1 34FDBA 00040000000000
2015.09.07 19:45:50.357 0: HMLAN_Parse: HMLANHPK R:RA8E9F903 stat:0008 t:00000000 d:FF r:7FFF     m:04 A001 23A6E1 34FDBA 00040000000000
2015.09.07 19:45:50.358 0: HMLAN_Parse: HMLANHPK no ACK from 34FDBA
2015.09.07 19:45:54.757 0: HMLAN_Send:  HMLANHPK S:SA8EA0C93 stat:  00 t:00000000 d:01 r:A8EA0C93 m:04 A001 23A6E1 34FDBA 00040000000000
2015.09.07 19:45:54.759 0: HMLAN_Send:  HMLANHPK I:K
2015.09.07 19:45:54.789 0: HMLAN_Parse: HMLANHPK V:03C4 sNo:KEQ0852418 d:23A6E1 O:23A6E1 t:022763EE IDcnt:0001 L:2 %
2015.09.07 19:45:55.365 0: HMLAN_Parse: HMLANHPK R:RA8EA0C93 stat:0008 t:00000000 d:FF r:7FFF     m:04 A001 23A6E1 34FDBA 00040000000000
2015.09.07 19:45:55.367 0: HMLAN_Parse: HMLANHPK no ACK from 34FDBA
2015.09.07 19:45:59.522 0: HMLAN_Send:  HMLANHPK S:SA8EA1F30 stat:  00 t:00000000 d:01 r:A8EA1F30 m:04 A001 23A6E1 34FDBA 00040000000000
2015.09.07 19:46:00.130 0: HMLAN_Parse: HMLANHPK R:RA8EA1F30 stat:0008 t:00000000 d:FF r:7FFF     m:04 A001 23A6E1 34FDBA 00040000000000
2015.09.07 19:46:00.132 0: HMLAN_Parse: HMLANHPK no ACK from 34FDBA
mfg
hpk
martinp876
Das sieht nicht gut aus. Das eigentliche pairen wird nicht ausgelöst.
Kann es aktuell nicht nachstellen.. Dauert ein paar wochen..... Seltsames verhalten
hpk007
Gibt es schon irgendeine Idee voran das Problem liegen könnte?
mfg
martinp876
Gepairt scheint schon zu sein, es sendet bereits die ID der zentrale.
Da sehe ich nichts.
Mache doch ein clear msgevents und dann schicke ein statusrequest. Prüfen ob es antwortet.
AES ist nicht zufällig ein?
hpk007
Hallo hab es so gemacht wie Du geschrieben hast ( clear msgevents / schicke ein statusrequest)
Leider ohne Erfolg.
2015.10.13 23:33:56.549 5: CUL_HM Bad_1_AK protEvent:Info_Cleared
2015.10.13 23:33:56.550 3: CUL_HM set Bad_1_AK clear msgEvents
2015.10.13 23:33:59.579 0: HMLAN_Parse: HMLAN1 R:E261CF7   stat:0000 t:037B3AD9 d:FF r:FFB7     m:85 8470 261CF7 000000 00CB43
2015.10.13 23:34:03.112 0: HMLAN_Parse: HMLAN1 R:E261D00   stat:0000 t:037B48A7 d:FF r:FFB5     m:7A 865A 261D00 000000 98D540
2015.10.13 23:34:11.760 0: HMLAN_Parse: HMLAN1 R:E261D7B   stat:0000 t:037B6A71 d:FF r:FFB3     m:80 865A 261D7B 000000 8CC143
2015.10.13 23:34:12.915 5: CUL_HM Bad_1_AK protEvent:CMDs_pending pending:1
2015.10.13 23:34:12.917 3: CUL_HM set Bad_1_AK statusRequest
2015.10.13 23:34:12.920 0: HMLAN_Send:  HMLAN1 S:+2B8A7D,00,00,00
2015.10.13 23:34:12.921 0: HMLAN_Send:  HMLAN1 S:S63200107 stat:  00 t:00000000 d:01 r:63200107 m:02 A001 F11234 2B8A7D 010E
2015.10.13 23:34:12.924 5: CUL_HM Bad_1_AK protEvent:CMDs_processing... pending:0
2015.10.13 23:34:13.529 0: HMLAN_Parse: HMLAN1 R:R63200107 stat:0008 t:00000000 d:FF r:7FFF     m:02 A001 F11234 2B8A7D 010E
2015.10.13 23:34:13.531 0: HMLAN_Parse: HMLAN1 no ACK from 2B8A7D
2015.10.13 23:34:16.649 4: CUL_HM_Resend: Bad_1_AK nr 2
2015.10.13 23:34:16.651 0: HMLAN_Send:  HMLAN1 S:S63200F9A stat:  00 t:00000000 d:01 r:63200F9A m:02 A001 F11234 2B8A7D 010E
2015.10.13 23:34:17.259 0: HMLAN_Parse: HMLAN1 R:R63200F9A stat:0008 t:00000000 d:FF r:7FFF     m:02 A001 F11234 2B8A7D 010E
2015.10.13 23:34:17.263 0: HMLAN_Parse: HMLAN1 no ACK from 2B8A7D
2015.10.13 23:34:17.650 0: HMLAN_Send:  HMLAN1 I:K
2015.10.13 23:34:17.656 0: HMLAN_Parse: HMLAN1 V:03C4 sNo:LEQ0383959 d:29A3DF O:F11234 t:037B8183 IDcnt:001F L:4 %
2015.10.13 23:34:17.848 0: HMLAN_Parse: HMLAN1 R:E321733   stat:0000 t:037B823A d:FF r:FFCF     m:7E 865A 321733 000000 A0C84A
2015.10.13 23:34:21.895 4: CUL_HM_Resend: Bad_1_AK nr 3
2015.10.13 23:34:21.897 0: HMLAN_Send:  HMLAN1 S:S63202418 stat:  00 t:00000000 d:01 r:63202418 m:02 A001 F11234 2B8A7D 010E
2015.10.13 23:34:22.506 0: HMLAN_Parse: HMLAN1 R:R63202418 stat:0008 t:00000000 d:FF r:7FFF     m:02 A001 F11234 2B8A7D 010E
2015.10.13 23:34:22.513 0: HMLAN_Parse: HMLAN1 no ACK from 2B8A7D
2015.10.13 23:34:23.113 0: HMLAN_Parse: HMLAN1 R:E261D00   stat:0000 t:037B96CB d:FF r:FFB5     m:7A 8470 261D00 000000 00D540
2015.10.13 23:34:27.510 4: CUL_HM_Resend: Bad_1_AK nr 4
2015.10.13 23:34:27.514 0: HMLAN_Send:  HMLAN1 S:S63203A09 stat:  00 t:00000000 d:01 r:63203A09 m:02 A001 F11234 2B8A7D 010E
2015.10.13 23:34:28.123 0: HMLAN_Parse: HMLAN1 R:R63203A09 stat:0008 t:00000000 d:FF r:7FFF     m:02 A001 F11234 2B8A7D 010E
2015.10.13 23:34:28.124 0: HMLAN_Parse: HMLAN1 no ACK from 2B8A7D
2015.10.13 23:34:31.761 0: HMLAN_Parse: HMLAN1 R:E261D7B   stat:0000 t:037BB895 d:FF r:FFB4     m:80 8470 261D7B 000000 00C143
2015.10.13 23:34:32.774 5: CUL_HM Bad_1_AK protEvent:CMDs_done_Errors:1
AES ist aus (Thermostate funktionieren ja auch)
martinp876
Ist das ein statusrequest auf einen RT?
Ist fhem aktuell?
hpk007
Hallo das ist ein Statusrequest auf einen Aktor (die sich eben nicht über Seriennummer richtig einbinden lassen)
Fhem ist aktuell!
martinp876
Das gibt es bei mir nicht mehr.
Mache einen update force
hpk007
Hallo habe update force durchgeführt.
Leider keine Besserung.
Die Aktore antworten leider immer noch nicht.
mfg
martinp876
RTS funktionieren problemlos.
Logge die rohmessages
