war: Techem HKV (ok) -> war Wasserzähler (ok) -> war Wärmemengenzähler (ok)
Begonnen von herrmannj, 14 Oktober 2015, 02:34:36
mircoby
Hi Jörg,
habe das update geladen, bekomme jedoch folgende Fehlermeldungen (für jedes device) im log:
2016.01.16 12:37:46 1: Including ./config/techem.cfg
"my" variable @m masks earlier declaration in same scope at ./FHEM/32_TechemWZ.pm line 308, <> line 8.
"state" variable @_ masks earlier declaration in same scope at ./FHEM/32_TechemWZ.pm line 308, <> line 8.
"my" variable @m masks earlier declaration in same scope at ./FHEM/32_TechemWZ.pm line 314, <> line 8.
"state" variable @_ masks earlier declaration in same scope at ./FHEM/32_TechemWZ.pm line 314, <> line 8.
"my" variable @m masks earlier declaration in same scope at ./FHEM/32_TechemWZ.pm line 320, <> line 8.
"state" variable @_ masks earlier declaration in same scope at ./FHEM/32_TechemWZ.pm line 320, <> line 8.
2016.01.16 12:37:46 1: reload: Error:Modul 32_TechemWZ deactivated:
syntax error at ./FHEM/32_TechemWZ.pm line 244, near "if defined"
syntax error at ./FHEM/32_TechemWZ.pm line 246, near "} else"
Can't use global @_ in "my" at ./FHEM/32_TechemWZ.pm line 254, near "= @_"
syntax error at ./FHEM/32_TechemWZ.pm line 304, near "}"
Can't use global @_ in "my" at ./FHEM/32_TechemWZ.pm line 308, near "= @_"
syntax error at ./FHEM/32_TechemWZ.pm line 310, near "}"
Can't use global @_ in "my" at ./FHEM/32_TechemWZ.pm line 314, near "= @_"
syntax error at ./FHEM/32_TechemWZ.pm line 316, near "}"
Can't use global @_ in "my" at ./FHEM/32_TechemWZ.pm line 320, near "= @_"
syntax error at ./FHEM/32_TechemWZ.pm line 322, near "}"
./FHEM/32_TechemWZ.pm has too many errors.
Ich habe das aktuelle file mit dem Stand von gestern mal verglichen. das ist die Stelle an der es klemmt:
  if defined($d[0]) {
    return (@d);
  } else {
    return (''); # discard neighbor devices
Die Klammer bei if defined scheint verrutscht zu sein, so läufts wieder, allerdings kommen immer noch "WMBUS Unknown device" Nachrichten im Log:
  if (defined $d[0]) {
    return (@d);
  } else {
Kannst Du da bitte noch mal reinschauen?
Danke & Gruß
Mirko
FHEM 6.2 auf Intel NUC mit Ubuntu 20.04 LTS
BUSWARE CUL, HM-RC-12, HM-SEC-RHS, HM-WDS30-OT2-SM, HM-ES-PMSw1-DR, CCU3, Sourceforge/hausbus (Beleuchtung + Rolläden + Audio), YAMAHA_AVR
herrmannj
herrmannj
done.
bevor ich das einchecke, magst Du das mal testen ?
WMBUS Unknown device können weiterhin kommen, aber neben nur für device die nicht von WZ behandelt werde wie HKV und so. Wenn ich die unterdrücken würde wäre das auch nicht korrekt - die "gehören" mir ja nicht. Wenn Du welche bekommst poste mal bitte, dann schaue ich.
Danke vg
joerg
pechnase
Hallo Jörg,
ich setze TechemHKV und TechemWZ ein mit ca. 52 HKV und 26 Kalt- und Warmwasserzähler. Hat bis jetzt alles gut funktioniert und die kleinen Bugs sind mit den Updates in den letzten Tagen auch mehr und mehr verschwunden, soweit ich das beurteilen kann.
Jetzt habe ich heute Nachmittag ein update von FHEM gemacht und da waren TechemHKV und TechemWZ auch wieder dabei. Allerdings gab es danach keine Wasserzähler mehr bei mir. Aus der fhem.cfg waren alle define wasserzaehler TechemWZ ... verschwunden. Das verstehe ich überhaupt nicht. Also TechemWZ gehen die letzte Datei ausgetauscht und fhem.cfg auf Backup zurückgespielt. Danach lief alles wieder.
Dann habe ich nochmals update check gemacht und da kam dann wie erwartet wieder TechemWZ als update. Ich wollte jetzt prüfen, ob der Fehler wieder auftritt. Also Update durchgeführt. Nach shutdown restart war wieder die fhem.cfg zerstört und keine Wasserzaähler mehr vorhanden. Dafür sind wieder WMBUS Devices erschienen, die ich in den letzten zwei Wochen aber alle weg hatte, nachdem ich nach und nach die Wasserzähler mit define ... TechemWZ .. definiert hatte.
Was passiert da? Kann das mit dem Thema zu haben, das hier gestern und heute diskutiert wurde?
Hier ein paar Ausschnitte aus dem fhem log:
2016.01.16 20:07:39 2: Error messages while initializing FHEM: configfile: Cannot load module TechemWZ Cannot load module TechemWZ Cannot load module TechemWZ Cannot load module TechemWZ Cannot load module TechemWZ Cannot load module TechemWZ Cannot load module TechemWZ Cannot load module TechemWZ Cannot load module TechemWZ Cannot load module TechemWZ Cannot load module TechemWZ Cannot load module TechemWZ Cannot load module TechemWZ Cannot load module TechemWZ Cannot load module TechemWZ Cannot load module TechemWZ Cannot load module TechemWZ Cannot load module TechemWZ Cannot load module TechemWZ Cannot load module TechemWZ Cannot load module TechemWZ Cannot load module TechemWZ Cannot load module TechemWZ Cannot load module TechemWZ Cannot load module TechemWZ Cannot load module TechemWZ Cannot load module TechemWZ Cannot load module TechemWZstatefile: Please define HM0919 first Please define HM0919 first Please define WZKW0012 first Please define WZKW0012 first Please define WZKW0012 first Please define WZKW0012 first Please define WZKW0012 first Please define WZKW0013 first Please define WZKW0013 first Please define WZKW0013 first Please define WZKW0013 first Please define WZKW0013 first Please define WZKW0018 first Please define WZKW0018 first Please define WZKW0019 first Please define WZKW0019 first Please define WZKW0019 first Please define WZKW0019 first Please define WZKW0019 first Please define WZKW0470 first Please define WZKW0470 first Please define WZKW0470 first Please define WZKW0470 first Please define WZKW0470 first Please define WZKW3172 first Please define WZKW3172 first Please define WZKW3172 first Please define WZKW3172 first Please define WZKW3172 first Please define WZKW4068 first Please define WZKW4068 first Please define WZKW4068 first Please define WZKW4068 first Please define WZKW4068 first Please define WZKW9726 first Please define WZKW9726 first Please define WZKW9726 first Please define WZKW9726 first Please define WZKW9726 first Please define WZKW9819 first Please define WZKW9819 first Please define WZKW9819 first Please define WZKW9819 first Please define WZKW9819 first Please define WZKW9820 first Please define WZKW9820 first Please define WZKW9820 first Please define WZKW9820 first Please define WZKW9820 first Please define WZKW9821 first Please define WZKW9821 first Please define WZKW9821 first Please define WZKW9821 first Please define WZKW9821 first Please define WZKW9829 first Please define WZKW9829 first Please define WZKW9829 first Please define WZKW9829 first Please define WZKW9829 first Please define WZK_BA first Please define WZK_BA first Please define WZK_BA first Please define WZK_BA first Please define WZK_BA first Please define
2016.01.16 20:07:40 3: WMBUS Unknown device b2F4468500376354174627CBCA2069F1F070100030800000000080C0AC1E5090B09090805010609080A0A060B080581630A0909090B0A982280E7, please define it
2016.01.16 20:07:40 2: autocreate: define WMBUS_TCH_41357603_116_98 WMBUS b2F4468500376354174627CBCA2069F1F070100030800000000080C0AC1E5090B09090805010609080A0A060B080581630A0909090B0A982280E7
2016.01.16 20:07:40 3: WMBUS_TCH_41357603_116_98: I/O device is nanoCUL
2016.01.16 20:07:40 2: autocreate: define FileLog_WMBUS_TCH_41357603_116_98 FileLog ./log/WMBUS_TCH_41357603_116_98-%Y-%m.log WMBUS_TCH_41357603_116_98
2016.01.16 20:07:40 2: WMBUS Error during LinkLayer parse:message too short, expected 56, got 55 bytes
2016.01.16 20:07:40 3: nanoCUL: Unknown code b2F44685098114541746208EDA2069F1F7100000303000000000307036B3603040503030205030302040505050203A3AE030403050402A, help me!
2016.01.16 20:07:41 3: WMBUS Unknown device b2F446850684036347472941DA2069F1FB40000030500000000050706CB4706060706060402060A09070704060503CF55060505060606AB1980E4, please define it
2016.01.16 20:07:41 2: autocreate: define WMBUS_TCH_34364068_116_114 WMBUS b2F446850684036347472941DA2069F1FB40000030500000000050706CB4706060706060402060A09070704060503CF55060505060606AB1980E4
2016.01.16 20:07:41 3: WMBUS_TCH_34364068_116_114: I/O device is nanoCUL
2016.01.16 20:07:41 2: autocreate: define FileLog_WMBUS_TCH_34364068_116_114 FileLog ./log/WMBUS_TCH_34364068_116_114-%Y-%m.log WMBUS_TCH_34364068_116_114
2016.01.16 20:07:42 2: WMBUS Error during LinkLayer parse:message too short, expected 56, got 43 bytes
Ich weiß nicht, ob das in irgend einer Form weiterhilft. Die SW Version, die Du heute hier im Forum eingestellt hast, habe ich noch nicht ausprobiert.
Wolfgang
- 1 x NUC mit FHEM VM, 1 x RPI 2B mit FHEM 6.3 verbunden über FHEM2FHEM
- HM Fensterkontakte, Rauchmelder, Fernbedienung, Schalter
- Optolink (Selbstbau) Vitotronic 200KW2
- 1-wire DS1820 Temp.Sensoren, TX29DT-IT
- CUL (busware), nanoCUL433, Jeelink (Nachbau), nanoCUL868 WMbus, Zigbee Sensoren
herrmannj
Hi
sorry
ZitatDie SW Version, die Du heute hier im Forum eingestellt hast, habe ich noch nicht ausprobiert.
Probier mal bitte. Die ist genau dafür.
vg
joerg
pechnase
Hallo Jörg,
habe eben die neue Version von heute eingespielt. Es gab keine Fehlermeldungen im fhem global log mehr und die fhem.cfg 'lebt' auch noch. Hat offensichtlich das Problem gelöst. Ich werde mal weiter beobachten, ob mir noch etwas auffällt.
Im FileLog ist mir noch aufgefallen:
2016-01-16_20:20:17 WasserZ WZW_WC.current_period: <div style="text-align:right">0.2 m3</div>
2016-01-16_20:20:17 WasserZpreviousP WZW_WC.previous_period: <div style="text-align:right">5.3 m3</div>
2016-01-16_20:20:17 Wasserzaehler WZW_WC.current_period: <div style="text-align:right">0.2 m3</div>
2016-01-16_20:20:17 Wasserzaehler WZW_WC.previous_period: <div style="text-align:right">5.3 m3</div>
2016-01-16_20:20:17 Wasserzaehler WZW_WC.meter: <div style="text-align:right">5.5 m3</div>
Das gab es in einer der letzten Versionen meine ich schon mal. Das letzte mal finde ich es in meinem Log am 8.1.2016.
Danke.
VG Wolfgang
herrmannj
kann ich nicht unterbringen. Irgendeine Erweiterung ? Logproxy, Tablet UI whatever ?
vg
joerg
pechnase
Hallo Jörg,
das kommt wohl von readingsGroup, zumindest ist WasserZ und Wasserzaehler je eine readingsGroup, die Zähler zusammenfassen. Muss ich mal suchen, woran das liegen könnte. Aber dann eher nicht am Modul TechemWZ.
VG Wolfgang
mircoby
Hallo Jörg,
habe das update getestet, funktioniert wieder. Ich bekomme allerdings weiterhin jede Menge "WMBUS Unknown device" Meldungen ins log, bei verbose 3:
2016.01.17 16:40:06 3: WMBUS Unknown device b32446850972298426980AE4DA0119F1F2B0010030400F203F30300043EEB000D00000000000000000000000000006D2700000000000B01070B96C085D9, please define it
2016.01.17 16:40:08 3: WMBUS Unknown device b2E446850901171436180E0EFA0019E1EF90E10039F0502024F4F595814EC482055120000000000000000000F214531C16583869BB3FEFD80E4, please define it
2016.01.17 16:40:08 3: WMBUS Unknown device b324468500623984269809DB7A0119F1F140410036F00D909EF0E18578401004E0075001B0000000000000000000095CD000003006663EBD8A7B1EA81E0, please define it
2016.01.17 16:40:13 3: WMBUS Unknown device b2E4468509384016364802B14A0113E1FF00210037F0100005C5C272673654333392700000000000000000B04031803253E54462779C1F785D4, please define it
2016.01.17 16:40:17 3: WMBUS Unknown device b2E4468500430515464803E20A011BF1ECA0A10030901010F28280C0C10C82E0E0000000000000000000000000016DA3D385E91AEB4AD0D88D6, please define it
2016.01.17 16:40:17 3: WMBUS Unknown device b2E4468508804714361805E9CA0019E1EC50110031A0000010A0A0301D762050600000000000000000000000000004AB30000000205E3DB80DF, please define it
2016.01.17 16:40:21 3: WMBUS Unknown device b32446850152398426980D913A0119F1F180410034800B305D1050444E06F00323C6234470D0000000000000000000AA602013B677546777B6E71DC84D7, please define it
2016.01.17 16:40:26 3: WMBUS Unknown device b324468501723984269806766A0119F1F6F051003A7007C048D041394969F00425C6D0C0000000000000000000000120B00002E74B5AFE7D7949C2483E9, please define it
2016.01.17 16:40:33 3: WMBUS Unknown device b3244685013239842698026E9A0119F1FE20410034C005308990A022489260128604C1606070300000000000000006FEE1000093720862E3A1951B881DB, please define it
2016.01.17 16:40:39 3: WMBUS Unknown device b324468500623984269809DB7A0119F1F140410036F00D909EF0E18578401004E0075001B0000000000000000000095CD000003006663EBD8A7B1EA84DE, please define it
2016.01.17 16:40:51 3: WMBUS Unknown device b2E446850990471436180A44DA0019E1E280310032C020024ABAB593E1E8D54273D0D000000000000000000010036BB4444506B1B63E86180E0, please define it
2016.01.17 16:40:52 3: WMBUS Unknown device b32446850152398426980D913A0119F1F180410034800B305D1050444E06F00323C6234470D0000000000000000000AA602013B677546777B6E71DC80D8, please define it
2016.01.17 16:40:53 3: WMBUS Unknown device b2E446850253051546480891AA011BF1EBD251003C8100313ACAC824051A97B74988A5C30000000001B00121A468FB3BDB4C0B0E4D28AE495D0, please define it
2016.01.17 16:40:57 3: WMBUS Unknown device b32446850972298426980AE4DA0119F1F2B0010030400F203F30300043EEB000D00000000000000000000000000006D2700000000000B01070B96C080D9, please define it
2016.01.17 16:40:58 3: WMBUS Unknown device b324468501723984269806766A0119F1F6F051003A7007C048D041394969F00425C6D0C0000000000000000000000120B00002E74B5AFE7D7949C2483E8, please define it
2016.01.17 16:41:01 3: WMBUS Unknown device b32446850112398426980989CA0119F1F05001003000063040F050000A7EB00000000000000000000000000000000FFFF000000000000010202B44A81DB, please define it
2016.01.17 16:41:06 3: WMBUS Unknown device b3244685013239842698026E9A0119F1FE20410034C005208950A0224408B0128604C1606070300000000000000006FEE1000093720862E3A1951B882DD, please define it
2016.01.17 16:41:19 3: WMBUS Unknown device b2E4468500112714361808E19A0019E1E080110035B0000052929090BA51F0D070401000000000000000000000011D951061F1F00275BD589D4, please define it
2016.01.17 16:41:24 3: WMBUS Unknown device b32446850152398426980D913A0119F1F180410034800B305D1050444E06F00323C6234470D0000000000000000000AA602013B677546777B6E71DC86DA, please define it
2016.01.17 16:41:27 3: WMBUS Unknown device b32446850972298426980AE4DA0119F1F2B0010030400F303F40300045EF3000D00000000000000000000000000006D2700000000000B01070B96C081D6, please define it
2016.01.17 16:41:28 3: WMBUS Unknown device b2E446850740471436180DB2FA0019E1E05031003700100010000256F112A3D162E342600000000000000000000076F1629293C8236677080D3, please define it
2016.01.17 16:41:32 3: WMBUS Unknown device b324468501723984269806766A0119F1F6F051003A7007B048C04139493DD00425C6D0C0000000000000000000000120B00002E74B5AFE7D7949C2484E9, please define it
2016.01.17 16:41:34 3: WMBUS Unknown device b32446850112398426980989CA0119F1F05001003000063040F050000A7EB00000000000000000000000000000000FFFF000000000000010202B44A82DB, please define it
2016.01.17 16:41:38 3: WMBUS Unknown device b3244685013239842698026E9A0119F1FE20410034C005208950A0224408B0128604C1606070300000000000000006FEE1000093720862E3A1951B880DB, please define it
2016.01.17 16:41:45 3: WMBUS Unknown device b324468500623984269809DB7A0119F1F140410036F00DA09F70E1857EBB6004E0075001B0000000000000000000095CD000003006663EBD8A7B1EA82E1, please define it
2016.01.17 16:42:02 3: WMBUS Unknown device b32446850152398426980D913A0119F1F180410034800AE05CC0504441F9500323C6234470D0000000000000000000AA602013B677546777B6E71DC8ADA, please define it
2016.01.17 16:42:05 3: WMBUS Unknown device b32446850112398426980989CA0119F1F05001003000063040F050000A7EB00000000000000000000000000000000FFFF000000000000010202B44A80DB, please define it
2016.01.17 16:42:05 3: WMBUS Unknown device b32446850972298426980AE4DA0119F1F2B0010030400F303F40300045EF3000D00000000000000000000000000006D2700000000000B01070B96C088D8, please define it
2016.01.17 16:42:09 3: WMBUS Unknown device b3244685013239842698026E9A0119F1FE20410034C005208950A0224408B0128604C1606070300000000000000006FEE1000093720862E3A1951B880DC, please define it
2016.01.17 16:42:11 3: WMBUS Unknown device b2E4468508653704361807212A0019E1E000010030000000000000000034000000000000000000000000000000000FFFF0000000000FFFF80EB, please define it
2016.01.17 16:42:18 3: WMBUS Unknown device b324468500623984269809DB7A0119F1F140410036F00DA09F70E1857EBB6004E0075001B0000000000000000000095CD000003006663EBD8A7B1EA85E1, please define it
2016.01.17 16:42:27 3: WMBUS Unknown device b2E446850031271436180306CA0019E1E360110033300001E08080D00A53E00000000000000000000000000000000FFFF000035853D4C9D80E7, please define it
2016.01.17 16:42:32 3: WMBUS Unknown device b32446850152398426980D913A0119F1F180410034800AE05CC0504441F9500323C6234470D0000000000000000000AA602013B677546777B6E71DC81DA, please define it
2016.01.17 16:42:37 3: WMBUS Unknown device b32446850112398426980989CA0119F1F05001003000060041005000069CC00000000000000000000000000000000FFFF000000000000010202B44A86D8, please define it
2016.01.17 16:42:38 3: WMBUS Unknown device b32446850972298426980AE4DA0119F1F2B0010030400F303F40300045EF3000D00000000000000000000000000006D2700000000000B01070B96C081D7, please define it
2016.01.17 16:42:39 3: WMBUS Unknown device b3244685013239842698026E9A0119F1FE20410034C005208950A0224408B0128604C1606070300000000000000006FEE1000093720862E3A1951B880DD, please define it
2016.01.17 16:42:44 3: WMBUS Unknown device b324468501723984269806766A0119F1F6F051003A7007B048C04139493DD00425C6D0C0000000000000000000000120B00002E74B5AFE7D7949C2482E8, please define it
2016.01.17 16:42:56 3: WMBUS Unknown device b324468500623984269809DB7A0119F1F140410036F00DA09F70E1857EBB6004E0075001B0000000000000000000095CD000003006663EBD8A7B1EA83E0, please define it
2016.01.17 16:43:02 3: WMBUS Unknown device b32446850152398426980D913A0119F1F180410034800AE05CC0504441F9500323C6234470D0000000000000000000AA602013B677546777B6E71DC84DA, please define it
2016.01.17 16:43:07 3: WMBUS Unknown device b2E44685053047143618093EFA0019E1E8A0B1003E503010D7676534979B85B19321000020000000000031009004323B25A7799BBF642CA80DF, please define it
2016.01.17 16:43:10 3: WMBUS Unknown device b2E446850428401636480DB0CA0113E1FD900100316000000111100005D770000050000000000000000000000021E0FD90A0607080B368385D5, please define it
2016.01.17 16:43:12 3: WMBUS Unknown device b32446850972298426980AE4DA0119F1F2B0010030400F303F40300045EF3000D00000000000000000000000000006D2700000000000B01070B96C082D8, please define it
2016.01.17 16:43:15 3: WMBUS Unknown device b324468501723984269806766A0119F1F6F051003A7007B048C04139493DD00425C6D0C0000000000000000000000120B00002E74B5AFE7D7949C2482E8, please define it
2016.01.17 16:43:15 3: WMBUS Unknown device b2E446850110571436180EE78A0019E1EFD001003DE0000000000181795D4A0000F0000000000000000000000000055D7000D023100B41980D7, please define it
2016.01.17 16:43:17 3: WMBUS Unknown device b3244685013239842698026E9A0119F1FE20410034C005208910A0224AC4B0128604C1606070300000000000000006FEE1000093720862E3A1951B881DC, please define it
2016.01.17 16:43:26 3: WMBUS Unknown device b324468500623984269809DB7A0119F1F140410036F00DD09FE0E18570A11004E0075001B0000000000000000000095CD000003006663EBD8A7B1EA86DF, please define it
2016.01.17 16:43:33 3: WMBUS Unknown device b32446850152398426980D913A0119F1F180410034800AE05CC0504441F9500323C6234470D0000000000000000000AA602013B677546777B6E71DC84D9, please define it
2016.01.17 16:43:34 3: WMBUS Unknown device b2E446850895370436180CF7EA0019E1E560010038D00000006060000017450250000120000000000000000000000DF280000000000FFFF82E1, please define it
2016.01.17 16:43:44 3: WMBUS Unknown device b32446850972298426980AE4DA0119F1F2B0010030400F203F30300043EEB000D00000000000000000000000000006D2700000000000B01070B96C080DA, please define it
2016.01.17 16:43:47 3: WMBUS Unknown device b32446850112398426980989CA0119F1F05001003000060041005000069CC00000000000000000000000000000000FFFF000000000000010202B44A83DC, please define it
2016.01.17 16:43:48 3: WMBUS Unknown device b324468501723984269806766A0119F1F6F051003A7007B048B041394324D00425C6D0C0000000000000000000000120B00002E74B5AFE7D7949C2482E8, please define it
2016.01.17 16:43:50 3: WMBUS Unknown device b3244685013239842698026E9A0119F1FE20410034C005208910A0224AC4B0128604C1606070300000000000000006FEE1000093720862E3A1951B880DD, please define it
2016.01.17 16:43:53 3: WMBUS Unknown device b2E446850991171436180A279A0019E1E1B0410037C0200149898513904786E445C260B000000000000000304113C9129545960006334EE80DA, please define it
2016.01.17 16:44:00 3: WMBUS Unknown device b324468500623984269809DB7A0119F1F140410036F00DD09FE0E18570A11004E0075001B0000000000000000000095CD000003006663EBD8A7B1EA80DE, please define it
2016.01.17 16:44:00 3: WMBUS Unknown device b2E446850061271436180B06BA0019E1E4C011003C800000835351C22BE09280A1704000000000000000000000019AB451E2C24002DC94C80D9, please define it
2016.01.17 16:44:01 3: WMBUS Unknown device b2E446850570471436180D260A0019E1ED70310035E040011DDDD7B99F8F9AD537A534716000000001203120B1C02F06C0603081307711080E5, please define it
2016.01.17 16:44:05 3: WMBUS Unknown device b32446850152398426980D913A0119F1F180410034800AA05C7050444F7AF00323C6234470D0000000000000000000AA602013B677546777B6E71DC86DA, please define it
2016.01.17 16:44:12 3: WMBUS Unknown device b2E446850901171436180E0EFA0019E1EF90E10039F0502024F4F595814EC482055120000000000000000000F214531C16583869BB3FEFD80E5, please define it
2016.01.17 16:44:15 3: WMBUS Unknown device b2E4468509384016364802B14A0113E1FF00210037F0100005C5C272673654333392700000000000000000B04031803253E54462779C1F783D4, please define it
2016.01.17 16:44:15 3: WMBUS Unknown device b32446850972298426980AE4DA0119F1F2B0010030400F203F30300043EEB000D00000000000000000000000000006D2700000000000B01070B96C081DA, please define it
2016.01.17 16:44:19 3: WMBUS Unknown device b2E4468500430515464803E20A011BF1ECA0A10030901010F28280C0C10C82E0E0000000000000000000000000016DA3D385E91AEB4AD0D87D4, please define it
2016.01.17 16:44:20 3: WMBUS Unknown device b32446850112398426980989CA0119F1F05001003000060041005000069CC00000000000000000000000000000000FFFF000000000000010202B44A81DA, please define it
2016.01.17 16:44:21 3: WMBUS Unknown device b324468501723984269806766A0119F1F6F051003A7007B048B041394324D00425C6D0C0000000000000000000000120B00002E74B5AFE7D7949C2485E9, please define it
2016.01.17 16:44:22 3: WMBUS Unknown device b3244685013239842698026E9A0119F1FE20410034C005208910A0224AC4B0128604C1606070300000000000000006FEE1000093720862E3A1951B881DC, please define it
2016.01.17 16:44:43 3: WMBUS Unknown device b32446850152398426980D913A0119F1F180410034800AA05C7050444F7AF00323C6234470D0000000000000000000AA602013B677546777B6E71DC85D9, please define it
2016.01.17 16:44:51 3: WMBUS Unknown device b2E446850990471436180A44DA0019E1E280310032C020024ABAB593E1E8D54273D0D000000000000000000010036BB4444506B1B63E86180E0, please define it
2016.01.17 16:44:51 3: WMBUS Unknown device b32446850112398426980989CA0119F1F0500100300006304130500005B6100000000000000000000000000000000FFFF000000000000010202B44A80DA, please define it
2016.01.17 16:44:52 3: WMBUS Unknown device b3244685013239842698026E9A0119F1FE20410034C005208910A0224AC4B0128604C1606070300000000000000006FEE1000093720862E3A1951B880DD, please define it
2016.01.17 16:44:53 3: WMBUS Unknown device b32446850972298426980AE4DA0119F1F2B0010030400F203F30300043EEB000D00000000000000000000000000006D2700000000000B01070B96C085D9, please define it
2016.01.17 16:44:55 3: WMBUS Unknown device b324468501723984269806766A0119F1F6F051003A7007B048B041394324D00425C6D0C0000000000000000000000120B00002E74B5AFE7D7949C2481E9, please define it
2016.01.17 16:45:05 3: WMBUS Unknown device b324468500623984269809DB7A0119F1F140410036F00E309050F1857D5C5004E0075001B0000000000000000000095CD000003006663EBD8A7B1EA83E1, please define it
2016.01.17 16:45:13 3: WMBUS Unknown device b32446850152398426980D913A0119F1F180410034800AA05C7050444F7AF00323C6234470D0000000000000000000AA602013B677546777B6E71DC83D9, please define it
2016.01.17 16:45:19 3: WMBUS Unknown device b2E4468500112714361808E19A0019E1E080110035B0000052929090BA51F0D070401000000000000000000000011D951061F1F00275BD584D4, please define it
2016.01.17 16:45:22 3: WMBUS Unknown device b3244685013239842698026E9A0119F1FE20410034C0052088B0A0224CA610128604C1606070300000000000000006FEE1000093720862E3A1951B880DB, please define it
2016.01.17 16:45:23 3: WMBUS Unknown device b32446850112398426980989CA0119F1F0500100300006304130500005B6100000000000000000000000000000000FFFF000000000000010202B44A82D9, please define it
2016.01.17 16:45:26 3: WMBUS Unknown device b32446850972298426980AE4DA0119F1F2B0010030400F303F3030004FF63000D00000000000000000000000000006D2700000000000B01070B96C081D7, please define it
2016.01.17 16:45:33 3: WMBUS Unknown device b324468501723984269806766A0119F1F6F051003A7007A048B041394F3C500425C6D0C0000000000000000000000120B00002E74B5AFE7D7949C2483E9, please define it
2016.01.17 16:45:42 3: WMBUS Unknown device b2E446850223051546480B768A011BF1E5605100393020012A5A596934BD08E1F000D000000000000000000000000F90688BCADE3D028ED8ED3, please define it
2016.01.17 16:45:43 3: WMBUS Unknown device b324468500623984269809DB7A0119F1F140410036F00E309050F1857D5C5004E0075001B0000000000000000000095CD000003006663EBD8A7B1EA83E0, please define it
2016.01.17 16:45:44 3: WMBUS Unknown device b32446850152398426980D913A0119F1F180410034800AA05C7050444F7AF00323C6234470D0000000000000000000AA602013B677546777B6E71DC82D8, please define it
2016.01.17 16:45:55 3: WMBUS Unknown device b32446850112398426980989CA0119F1F0500100300006304130500005B6100000000000000000000000000000000FFFF000000000000010202B44A82DB, please define it
2016.01.17 16:45:57 3: WMBUS Unknown device b32446850262298426980C583A0119F1F2400100304006D068E0600040B93000A0B000500000000000000000000007A3A0000020000040400001B23A1D2, please define it
2016.01.17 16:45:59 3: WMBUS Unknown device b32446850972298426980AE4DA0119F1F2B0010030400F303F3030004FF63000D00000000000000000000000000006D2700000000000B01070B96C083D8, please define it
2016.01.17 16:46:00 3: WMBUS Unknown device b3244685013239842698026E9A0119F1FE20410034C0052088B0A0224CA610128604C1606070300000000000000006FEE1000093720862E3A1951B880DC, please define it
2016.01.17 16:46:04 3: WMBUS Unknown device b324468501723984269806766A0119F1F6F051003A7007A048B041394F3C500425C6D0C0000000000000000000000120B00002E74B5AFE7D7949C2484E9, please define it
2016.01.17 16:46:13 3: WMBUS Unknown device b2E4468508653704361807212A0019E1E000010030000000000000000034000000000000000000000000000000000FFFF0000000000FFFF80EB, please define it
2016.01.17 16:46:29 3: WMBUS Unknown device b2E446850031271436180306CA0019E1E360110033300001E08080D00A53E00000000000000000000000000000000FFFF000035853D4C9D80E8, please define it
2016.01.17 16:46:32 3: WMBUS Unknown device b32446850972298426980AE4DA0119F1F2B0010030400F303F3030004FF63000D00000000000000000000000000006D2700000000000B01070B96C082DA, please define it
2016.01.17 16:46:33 3: WMBUS Unknown device b32446850112398426980989CA0119F1F0500100300006304130500005B6100000000000000000000000000000000FFFF000000000000010202B44A84DD, please define it
2016.01.17 16:46:33 3: WMBUS Unknown device b3244685013239842698026E9A0119F1FE20410034C0052088B0A0224CA610128604C1606070300000000000000006FEE1000093720862E3A1951B883DB, please define it
2016.01.17 16:46:35 3: WMBUS Unknown device b324468507923984269808054A0119F1FA00110031100B504CF04020F96890002070C010102000000000000000000A3C70000020E266188442485D697D3, please define it
2016.01.17 16:46:37 3: WMBUS Unknown device b324468501723984269806766A0119F1F6F051003A7007A048B041394F3C500425C6D0C0000000000000000000000120B00002E74B5AFE7D7949C2481EA, please define it
2016.01.17 16:46:37 3: WMBUS Unknown device b2E4468502654704361802A9FA0019E1EEB0110030900000000000000C59000000900000000000000000000000000AA7202002C394E15E580DF, please define it
2016.01.17 16:46:47 3: WMBUS Unknown device b32446850152398426980D913A0119F1F180410034800A505C20504449D3300323C6234470D0000000000000000000AA602013B677546777B6E71DC86D9, please define it
2016.01.17 16:46:52 3: WMBUS Unknown device b2E4468505084016364805E20A0113E1FD70110038A01000030301956C3915355340F01000000000000000000001BDBE21A2618311441E683D7, please define it
2016.01.17 16:47:02 3: WMBUS Unknown device b32446850972298426980AE4DA0119F1F2B0010030400F303F3030004FF63000D00000000000000000000000000006D2700000000000B01070B96C083DA, please define it
2016.01.17 16:47:05 3: WMBUS Unknown device b3244685013239842698026E9A0119F1FE20410034C004F08840A0224B7540128604C1606070300000000000000006FEE1000093720862E3A1951B882DB, please define it
2016.01.17 16:47:10 3: WMBUS Unknown device b2E44685053047143618093EFA0019E1E8A0B1003E503010D7676534979B85B19321000020000000000031009004323B25A7799BBF642CA80DE, please define it
2016.01.17 16:47:20 3: WMBUS Unknown device b324468500623984269809DB7A0119F1F140410036F00E609100F1857769D004E0075001B0000000000000000000095CD000003006663EBD8A7B1EA82E1, please define it
2016.01.17 16:47:36 3: WMBUS Unknown device b3244685013239842698026E9A0119F1FE20410034C004F08840A0224B7540128604C1606070300000000000000006FEE1000093720862E3A1951B882D9, please define it
2016.01.17 16:47:36 3: WMBUS Unknown device b2E446850895370436180CF7EA0019E1E560010038D00000006060000017450250000120000000000000000000000DF280000000000FFFF81E2, please define it
2016.01.17 16:47:37 3: WMBUS Unknown device b32446850112398426980989CA0119F1F050010030000630414050000FAF100000000000000000000000000000000FFFF000000000000010202B44A82DB, please define it
2016.01.17 16:47:44 3: WMBUS Unknown device b324468501723984269806766A0119F1F6F051003A7007A048A041394C8F500425C6D0C0000000000000000000000120B00002E74B5AFE7D7949C2486E9, please define it
2016.01.17 16:47:56 3: WMBUS Unknown device b2E446850991171436180A279A0019E1E1B0410037C0200149898513904786E445C260B000000000000000304113C9129545960006334EE80DB, please define it
2016.01.17 16:48:05 3: WMBUS Unknown device b2E446850570471436180D260A0019E1ED70310035E040011DDDD7B99F8F9AD537A534716000000001203120B1C02F06C0603081307711080E4, please define it
2016.01.17 16:48:06 3: WMBUS Unknown device b32446850712398426980034AA0119F1F120710038E00EC0AC60D0787110F00666B684F6A22141A0000000027001D36DB64E75562636691A28EE11D86DA, please define it
2016.01.17 16:48:06 3: WMBUS Unknown device b3244685013239842698026E9A0119F1FE20410034C004F08840A0224B7540128604C1606070300000000000000006FEE1000093720862E3A1951B880DC, please define it
2016.01.17 16:48:08 3: WMBUS Unknown device b2E446850061271436180B06BA0019E1E4C011003C800000835351C22BE09280A1704000000000000000000000019AB451E2C24002DC94C81D9, please define it
2016.01.17 16:48:08 3: WMBUS Unknown device b32446850112398426980989CA0119F1F050010030000630414050000FAF100000000000000000000000000000000FFFF000000000000010202B44A82DA, please define it
2016.01.17 16:48:11 3: WMBUS Unknown device b32446850152398426980D913A0119F1F180410034800A105BD0504442C4E00323C6234470D0000000000000000000AA602013B677546777B6E71DC86D8, please define it
2016.01.17 16:48:12 3: WMBUS Unknown device b2E446850901171436180E0EFA0019E1EF90E10039F0502024F4F595814EC482055120000000000000000000F214531C16583869BB3FEFD80E6, please define it
2016.01.17 16:48:16 3: WMBUS Unknown device b2E4468509384016364802B14A0113E1FF00210037F0100005C5C272673654333392700000000000000000B04031803253E54462779C1F783D1, please define it
2016.01.17 16:48:22 3: WMBUS Unknown device b324468501723984269806766A0119F1F6F051003A7007A048A041394C8F500425C6D0C0000000000000000000000120B00002E74B5AFE7D7949C2484E9, please define it
2016.01.17 16:48:23 3: WMBUS Unknown device b2E4468508804714361805E9CA0019E1EC50110031A0000010A0A0301D762050600000000000000000000000000004AB30000000205E3DB80DF, please define it
2016.01.17 16:48:31 3: WMBUS Unknown device b324468500623984269809DB7A0119F1F140410036F00E609100F1857769D004E0075001B0000000000000000000095CD000003006663EBD8A7B1EA83E1, please define it
2016.01.17 16:48:40 3: WMBUS Unknown device b32446850112398426980989CA0119F1F0500100300006304160500008C9100000000000000000000000000000000FFFF000000000000010202B44A81DB, please define it
2016.01.17 16:48:42 3: WMBUS Unknown device b32446850152398426980D913A0119F1F180410034800A105BD0504442C4E00323C6234470D0000000000000000000AA602013B677546777B6E71DC81D8, please define it
2016.01.17 16:48:44 3: WMBUS Unknown device b3244685013239842698026E9A0119F1FE20410034C004F08840A0224B7540128604C1606070300000000000000006FEE1000093720862E3A1951B880DC, please define it
2016.01.17 16:48:47 3: WMBUS Unknown device b32446850972298426980AE4DA0119F1F2B0010030400F203F30300043EEB000D00000000000000000000000000006D2700000000000B01070B96C082DA, please define it
2016.01.17 16:48:48 3: WMBUS Unknown device b324468507923984269808054A0119F1FA00110031100B204CB04020F443B0002070C010102000000000000000000A3C70000020E266188442485D68DD0, please define it
2016.01.17 16:48:49 3: WMBUS Unknown device b324468502422984269807BF6A0119F1F4D0010030200AB0679060101E92E00000702030000000000000000000000E6C1000000040012220504586B8ED4, please define it
2016.01.17 16:48:51 3: WMBUS Unknown device b2E446850990471436180A44DA0019E1E280310032C020024ABAB593E1E8D54273D0D000000000000000000010036BB4444506B1B63E86180DF, please define it
2016.01.17 16:48:53 3: WMBUS Unknown device b324468501723984269806766A0119F1F6F051003A7007A048A041394C8F500425C6D0C0000000000000000000000120B00002E74B5AFE7D7949C2482E9, please define it
2016.01.17 16:48:58 3: WMBUS Unknown device b2E446850253051546480891AA011BF1EBD251003C8100313ACAC824051A97B74988A5C30000000001B00121A468FB3BDB4C0B0E4D28AE484D1, please define it
2016.01.17 16:49:01 3: WMBUS Unknown device b324468500623984269809DB7A0119F1F140410036F00E609100F1857769D004E0075001B0000000000000000000095CD000003006663EBD8A7B1EA85DE, please define it
2016.01.17 16:49:14 3: WMBUS Unknown device b32446850152398426980D913A0119F1F180410034800A105BD0504442C4E00323C6234470D0000000000000000000AA602013B677546777B6E71DC85D9, please define it
2016.01.17 16:49:17 3: WMBUS Unknown device b3244685013239842698026E9A0119F1FE20410034C004E087F0A02247DAD0128604C1606070300000000000000006FEE1000093720862E3A1951B880DD, please define it
2016.01.17 16:49:18 3: WMBUS Unknown device b32446850112398426980989CA0119F1F0500100300006304160500008C9100000000000000000000000000000000FFFF000000000000010202B44A81DB, please define it
2016.01.17 16:49:19 3: WMBUS Unknown device b32446850972298426980AE4DA0119F1F2B0010030400F203F30300043EEB000D00000000000000000000000000006D2700000000000B01070B96C080DB, please define it
2016.01.17 16:49:21 3: WMBUS Unknown device b2E4468500112714361808E19A0019E1E080110035B0000052929090BA51F0D070401000000000000000000000011D951061F1F00275BD583D2, please define it
2016.01.17 16:49:26 3: WMBUS Unknown device b324468501723984269806766A0119F1F6F051003A7007A048A041394C8F500425C6D0C0000000000000000000000120B00002E74B5AFE7D7949C2484EA, please define it
2016.01.17 16:49:43 3: WMBUS Unknown device b2E446850223051546480B768A011BF1E5605100393020012A5A596934BD08E1F000D000000000000000000000000F90688BCADE3D028ED8ED5, please define it
2016.01.17 16:49:48 3: WMBUS Unknown device b3244685013239842698026E9A0119F1FE20410034C004E087F0A02247DAD0128604C1606070300000000000000006FEE1000093720862E3A1951B880DD, please define it
2016.01.17 16:49:50 3: WMBUS Unknown device b32446850972298426980AE4DA0119F1F2B0010030400F203F30300043EEB000D00000000000000000000000000006D2700000000000B01070B96C086D9, please define it
2016.01.17 16:49:52 3: WMBUS Unknown device b32446850112398426980989CA0119F1F0500100300006304160500008C9100000000000000000000000000000000FFFF000000000000010202B44A81DB, please define it
2016.01.17 16:49:52 3: WMBUS Unknown device b32446850152398426980D913A0119F1F180410034800A105BD0504442C4E00323C6234470D0000000000000000000AA602013B677546777B6E71DC83D6, please define it
2016.01.17 16:50:00 3: WMBUS Unknown device b324468501723984269806766A0119F1F6F051003A700790488041394C16800425C6D0C0000000000000000000000120B00002E74B5AFE7D7949C2485EA, please define it
2016.01.17 16:50:06 3: WMBUS Unknown device b2E4468500412714361800E1EA0019E1E02051003C90200148B8B5C6A1E4A6A39652E210600000000000002051847A6B64856638A798C6484D1, please define it
2016.01.17 16:50:07 3: WMBUS Unknown device b324468500623984269809DB7A0119F1F140410036F00E9091C0F1857C3D4004E0075001B0000000000000000000095CD000003006663EBD8A7B1EA81E0, please define it
2016.01.17 16:50:14 3: WMBUS Unknown device b2E4468508653704361807212A0019E1E000010030000000000000000034000000000000000000000000000000000FFFF0000000000FFFF80EB, please define it
2016.01.17 16:50:19 3: WMBUS Unknown device b3244685013239842698026E9A0119F1FE20410034C004E087F0A02247DAD0128604C1606070300000000000000006FEE1000093720862E3A1951B881DE, please define it
2016.01.17 16:50:22 3: WMBUS Unknown device b32446850152398426980D913A0119F1F1804100348009C05B8050444B54C00323C6234470D0000000000000000000AA602013B677546777B6E71DC85DB, please define it
2016.01.17 16:50:28 3: WMBUS Unknown device b32446850972298426980AE4DA0119F1F2B0010030400F203F30300043EEB000D00000000000000000000000000006D2700000000000B01070B96C083D9, please define it
2016.01.17 16:50:31 3: WMBUS Unknown device b324468507923984269808054A0119F1FA00110031100B204CB04020F443B0002070C010102000000000000000000A3C70000020E266188442485D687D4, please define it
2016.01.17 16:50:33 3: WMBUS Unknown device b324468501723984269806766A0119F1F6F051003A700790488041394C16800425C6D0C0000000000000000000000120B00002E74B5AFE7D7949C2482EA, please define it
2016.01.17 16:50:37 3: WMBUS Unknown device b2E446850031271436180306CA0019E1E360110033300001E08080D00A53E00000000000000000000000000000000FFFF000035853D4C9D80E8, please define it
2016.01.17 16:50:40 3: WMBUS Unknown device b324468500623984269809DB7A0119F1F140410036F00E9091C0F1857C3D4004E0075001B0000000000000000000095CD000003006663EBD8A7B1EA85E0, please define it
2016.01.17 16:50:53 3: WMBUS Unknown device b32446850112398426980989CA0119F1F050010030000640418050000CCA600000000000000000000000000000000FFFF000000000000010202B44A82DB, please define it
2016.01.17 16:51:01 3: WMBUS Unknown device b32446850972298426980AE4DA0119F1F2B0010030400F203F30300043EEB000D00000000000000000000000000006D2700000000000B01070B96C080DB, please define it
2016.01.17 16:51:02 3: WMBUS Unknown device b324468507923984269808054A0119F1FA00110031100B104CB04020F3BC60002070C010102000000000000000000A3C70000020E266188442485D685D2, please define it
2016.01.17 16:51:11 3: WMBUS Unknown device b2E44685053047143618093EFA0019E1E8A0B1003E503010D7676534979B85B19321000020000000000031009004323B25A7799BBF642CA80DE, please define it
2016.01.17 16:51:11 3: WMBUS Unknown device b324468501723984269806766A0119F1F6F051003A700790488041394C16800425C6D0C0000000000000000000000120B00002E74B5AFE7D7949C2483EA, please define it
2016.01.17 16:51:23 3: WMBUS Unknown device b2E446850110571436180EE78A0019E1EFD001003DE0000000000181795D4A0000F0000000000000000000000000055D7000D023100B41980D5, please define it
2016.01.17 16:51:24 3: WMBUS Unknown device b32446850152398426980D913A0119F1F1804100348009C05B8050444B54C00323C6234470D0000000000000000000AA602013B677546777B6E71DC85DB, please define it
2016.01.17 16:51:25 3: WMBUS Unknown device b32446850112398426980989CA0119F1F050010030000640418050000CCA600000000000000000000000000000000FFFF000000000000010202B44A82DC, please define it
2016.01.17 16:51:27 3: WMBUS Unknown device b3244685013239842698026E9A0119F1FE20410034C004C08760A02241C0D0128604C1606070300000000000000006FEE1000093720862E3A1951B883DD, please define it
2016.01.17 16:51:30 3: WMBUS Unknown device b324468500623984269809DB7A0119F1F140410036F00EC09270F1857CAF2004E0075001B0000000000000000000095CD000003006663EBD8A7B1EA83E1, please define it
2016.01.17 16:51:34 3: WMBUS Unknown device b32446850972298426980AE4DA0119F1F2B0010030400F103F20300047A26000D00000000000000000000000000006D2700000000000B01070B96C080D7, please define it
2016.01.17 16:51:36 3: WMBUS Unknown device b2E446850895370436180CF7EA0019E1E560010038D00000006060000017450250000120000000000000000000000DF280000000000FFFF81E2, please define it
2016.01.17 16:51:40 3: WMBUS Unknown device b32446850262298426980C583A0119F1F2400100304006E0691060004C5B4000A0B000500000000000000000000007A3A0000020000040400001B238DCE, please define it
2016.01.17 16:51:43 3: WMBUS Unknown device b324468501723984269806766A0119F1F6F051003A700780487041394459500425C6D0C0000000000000000000000120B00002E74B5AFE7D7949C2483E9, please define it
2016.01.17 16:51:55 3: WMBUS Unknown device b32446850152398426980D913A0119F1F1804100348009C05B8050444B54C00323C6234470D0000000000000000000AA602013B677546777B6E71DC81D9, please define it
2016.01.17 16:52:00 3: WMBUS Unknown device b3244685013239842698026E9A0119F1FE20410034C004C08760A02241C0D0128604C1606070300000000000000006FEE1000093720862E3A1951B882DC, please define it
2016.01.17 16:52:03 3: WMBUS Unknown device b32446850112398426980989CA0119F1F050010030000640418050000CCA600000000000000000000000000000000FFFF000000000000010202B44A84DC, please define it
2016.01.17 16:52:04 3: WMBUS Unknown device b324468500623984269809DB7A0119F1F140410036F00EC09270F1857CAF2004E0075001B0000000000000000000095CD000003006663EBD8A7B1EA81DD, please define it
2016.01.17 16:52:06 3: WMBUS Unknown device b2E446850570471436180D260A0019E1ED70310035E040011DDDD7B99F8F9AD537A534716000000001203120B1C02F06C0603081307711080E6, please define it
2016.01.17 16:52:11 3: WMBUS Unknown device b2E446850061271436180B06BA0019E1E4C011003C800000835351C22BE09280A1704000000000000000000000019AB451E2C24002DC94C80D7, please define it
2016.01.17 16:52:12 3: WMBUS Unknown device b2E446850901171436180E0EFA0019E1EF90E10039F0502024F4F595814EC482055120000000000000000000F214531C16583869BB3FEFD80E5, please define it
2016.01.17 16:52:15 3: WMBUS Unknown device b324468501723984269806766A0119F1F6F051003A700780487041394459500425C6D0C0000000000000000000000120B00002E74B5AFE7D7949C2483EA, please define it
2016.01.17 16:52:24 3: WMBUS Unknown device b2E4468508804714361805E9CA0019E1EC50110031A0000010A0A0301D762050600000000000000000000000000004AB30000000205E3DB80E0, please define it
Wenn dies keine der TechemWZ / HKV devices sind, wäre es in Ordung.
Gruß Mirko
herrmannj
Stichprobenartig sehe ich nur HKV, interessanterweise auch einen bisher unbekannten Typ.
Das ZechemWZ filter nur Wasserzähler und Wärmemengenzähler. Hast Du das TechemHKV modul auch installiert ?
vg
joerg
mircoby
Das Modul HKV habe ich nicht konfiguriert, das ist für die Heizkostenverteiler an den Heizkörpern, richtig? Soweit ich informiert bin, gibt es diese hier im Haus nicht.
Wie kann ich das prüfen, einen Techem HKV im Listen Modus anlegen, kucken was passiert?
Der Unbekannte Typ könnte vielleicht ein "Techem Ultra s3" sein? Den gibt es hier noch im Heizraum....
herrmannj
sind HKV, vmtl von Nachbarhäusern.
Installiere einen HKV mit irgendeiner (fake) ID, zb 0000. Dann "schluckt" das HKV modul die "unknown device".
Sollte dann noch was übrig sein finden wir den "Ultra s3"
vg
joerg
mircoby
Habe  jetzt folgenden HKV angelegt:
define HKV_ext1 TechemHKV 0000
Internals
CFGFN
DEF    0000
NAME HKV_ext1
NR 1865
NTFY_ORDER 50-HKV_ext1
STATE listening
TYPE TechemHKV
Readings
state listening 2016-01-17 17:29:48
Anschließend verbose wieder auf 3:
2016.01.17 17:52:27 3: WMBUS Unknown device b2E446850895370436180CF7EA0019E1E560010038D00000006060000017450250000120000000000000000000000DF280000000000FFFF81E3, please define it
2016.01.17 17:52:50 3: WMBUS Unknown device b2E446850901171436180E0EFA0019E1EF90E10039F0502024F4F595814EC482055120000000000000000000F214531C16583869BB3FEFD80E4, please define it
2016.01.17 17:52:58 3: WMBUS Unknown device b2E446850991171436180A279A0019E1E1B0410037E020016989851397FF96E445C260B000000000000000304113C9129545960006334EE86D8, please define it
2016.01.17 17:53:04 3: WMBUS Unknown device b2E446850570471436180D260A0019E1ED70310035F040012DDDD7B990687AD537A534716000000001203120B1C02F06C0603081307711080E7, please define it
2016.01.17 17:53:09 3: WMBUS Unknown device b2E446850061271436180B06BA0019E1E4C011003C800000835351C22BE09280A1704000000000000000000000019AB451E2C24002DC94C81D3, please define it
2016.01.17 17:53:17 3: WMBUS Unknown device b2E4468500430515464803E20A011BF1ECA0A10030901011028280C0C02A52E0E0000000000000000000000000016DA3D385E91AEB4AD0D87D8, please define it
2016.01.17 17:53:19 3: WMBUS Unknown device b2E4468508804714361805E9CA0019E1EC50110031A0000010A0A0301D762050600000000000000000000000000004AB30000000205E3DB80E1, please define it
2016.01.17 17:53:40 3: WMBUS Unknown device b2E446850990471436180A44DA0019E1E280310032E020026ABAB593E650C54273D0D000000000000000000010036BB4444506B1B63E86180E5, please define it
2016.01.17 17:54:54 3: WMBUS Unknown device b2E4468508653704361807212A0019E1E000010030000000000000000034000000000000000000000000000000000FFFF0000000000FFFF80E9, please define it
2016.01.17 17:55:26 3: WMBUS Unknown device b2E446850031271436180306CA0019E1E360110033400001F08080D006DDB00000000000000000000000000000000FFFF000035853D4C9D80E8, please define it
2016.01.17 17:55:34 3: WMBUS Unknown device b2E4468505084016364805E20A0113E1FD70110038A01000030301956C3915355340F01000000000000000000001BDBE21A2618311441E684D8, please define it
2016.01.17 17:55:41 3: WMBUS Unknown device b2E4468502654704361802A9FA0019E1EEB0110030900000000000000C59000000900000000000000000000000000AA7202002C394E15E582E0, please define it
2016.01.17 17:56:05 3: WMBUS Unknown device b2E446850428401636480DB0CA0113E1FD900100316000000111100005D770000050000000000000000000000021E0FD90A0607080B368388D6, please define it
2016.01.17 17:56:06 3: WMBUS Unknown device b2E44685053047143618093EFA0019E1E8A0B1003E703010E767653492CBF5B19321000020000000000031009004323B25A7799BBF642CA80DD, please define it
2016.01.17 17:56:14 3: WMBUS Unknown device b2E446850110571436180EE78A0019E1EFD001003DE0000000000181795D4A0000F0000000000000000000000000055D7000D023100B41980D3, please define it
2016.01.17 17:56:25 3: WMBUS Unknown device b2E4468507004714361809AA0A0019E1E77211003990D0313A0A06E77DA97854B67432B0A0000000007020A0C5C9CEF5CAFB8B2E0E1D9C680D2, please define it
2016.01.17 17:56:30 3: WMBUS Unknown device b2E446850895370436180CF7EA0019E1E560010038D00000006060000017450250000120000000000000000000000DF280000000000FFFF80E3, please define it
2016.01.17 17:56:58 3: WMBUS Unknown device b2E446850901171436180E0EFA0019E1EF90E10039F0502024F4F595814EC482055120000000000000000000F214531C16583869BB3FEFD80E3, please define it
2016.01.17 17:57:00 3: WMBUS Unknown device b2E446850991171436180A279A0019E1E1B0410037E020016989851397FF96E445C260B000000000000000304113C9129545960006334EE80D6, please define it
2016.01.17 17:57:08 3: WMBUS Unknown device b2E446850570471436180D260A0019E1ED70310035F040012DDDD7B990687AD537A534716000000001203120B1C02F06C0603081307711080E4, please define it
2016.01.17 17:57:18 3: WMBUS Unknown device b2E4468509384016364802B14A0113E1FF00210037F0100005C5C272673654333392700000000000000000B04031803253E54462779C1F780D2, please define it
2016.01.17 17:57:20 3: WMBUS Unknown device b2E4468500430515464803E20A011BF1ECA0A10030901011028280C0C02A52E0E0000000000000000000000000016DA3D385E91AEB4AD0D83D5, please define it
2016.01.17 17:57:27 3: WMBUS Unknown device b2E4468508804714361805E9CA0019E1EC50110031A0000010A0A0301D762050600000000000000000000000000004AB30000000205E3DB80E0, please define it
2016.01.17 17:58:00 3: WMBUS Unknown device b2E446850253051546480891AA011BF1EBD251003C8100314ACAC8240983B7B74988A5C30000000001B00121A468FB3BDB4C0B0E4D28AE48AD1, please define it
2016.01.17 17:58:02 3: WMBUS Unknown device b2E4468508053704361808DE8A0019E1E50041003D2020010929272735FB951373B4928000000000000000017322910944235676F4DD94481D4, please define it
2016.01.17 17:58:38 3: WMBUS Unknown device b2E446850223051546480B768A011BF1E5605100393020012A5A596934BD08E1F000D000000000000000000000000F90688BCADE3D028ED81D2, please define it
2016.01.17 17:59:02 3: WMBUS Unknown device b2E4468508653704361807212A0019E1E000010030000000000000000034000000000000000000000000000000000FFFF0000000000FFFF80EB, please define it
2016.01.17 17:59:26 3: WMBUS Unknown device b2E446850031271436180306CA0019E1E360110033400001F08080D006DDB00000000000000000000000000000000FFFF000035853D4C9D80E8, please define it
2016.01.17 18:00:06 3: WMBUS Unknown device b2E446850428401636480DB0CA0113E1FD900100316000000111100005D770000050000000000000000000000021E0FD90A0607080B368387D6, please define it
2016.01.17 18:00:14 3: WMBUS Unknown device b2E44685053047143618093EFA0019E1E8A0B1003E703010E767653492CBF5B19321000020000000000031009004323B25A7799BBF642CA80DD, please define it
2016.01.17 18:00:16 3: WMBUS Unknown device b2E446850110571436180EE78A0019E1EFD001003DE0000000000181795D4A0000F0000000000000000000000000055D7000D023100B41981D4, please define it
2016.01.17 18:00:29 3: WMBUS Unknown device b2E4468507004714361809AA0A0019E1E77211003990D0313A0A06E77DA97854B67432B0A0000000007020A0C5C9CEF5CAFB8B2E0E1D9C681D2, please define it
2016.01.17 18:00:38 3: WMBUS Unknown device b2E446850895370436180CF7EA0019E1E560010038D00000006060000017450250000120000000000000000000000DF280000000000FFFF80E3, please define it
2016.01.17 18:00:59 3: WMBUS Unknown device b2E446850901171436180E0EFA0019E1EF90E10039F0502024F4F595814EC482055120000000000000000000F214531C16583869BB3FEFD80E4, please define it
2016.01.17 18:01:15 3: WMBUS Unknown device b2E446850061271436180B06BA0019E1E4C011003C800000835351C22BE09280A1704000000000000000000000019AB451E2C24002DC94C84D3, please define it
2016.01.17 18:01:16 3: WMBUS Unknown device b2E446850570471436180D260A0019E1ED70310035F040012DDDD7B990687AD537A534716000000001203120B1C02F06C0603081307711080E6, please define it
2016.01.17 18:01:21 3: WMBUS Unknown device b2E4468500430515464803E20A011BF1ECA0A10030901011028280C0C02A52E0E0000000000000000000000000016DA3D385E91AEB4AD0D83D6, please define it
2016.01.17 18:01:21 3: WMBUS Unknown device b2E4468509384016364802B14A0113E1FF00210037F0100005C5C272673654333392700000000000000000B04031803253E54462779C1F789D5, please define it
2016.01.17 18:01:30 3: WMBUS Unknown device b2E4468508804714361805E9CA0019E1EC50110031A0000010A0A0301D762050600000000000000000000000000004AB30000000205E3DB80E2, please define it
2016.01.17 18:01:44 3: WMBUS Unknown device b2E446850990471436180A44DA0019E1E280310032E020026ABAB593E650C54273D0D000000000000000000010036BB4444506B1B63E86181E3, please define it
2016.01.17 18:02:02 3: WMBUS Unknown device b2E4468508053704361808DE8A0019E1E50041003D2020010929272735FB951373B4928000000000000000017322910944235676F4DD94481D4, please define it
2016.01.17 18:02:17 3: WMBUS Unknown device b2E4468500112714361808E19A0019E1E080110035B0000052929090BA51F0D070401000000000000000000000011D951061F1F00275BD588CD, please define it
2016.01.17 18:02:39 3: WMBUS Unknown device b2E446850223051546480B768A011BF1E5605100393020012A5A596934BD08E1F000D000000000000000000000000F90688BCADE3D028ED93D4, please define it
2016.01.17 18:02:59 3: WMBUS Unknown device b2E4468500412714361800E1EA0019E1E02051003CA0200158B8B5C6A9BB56A39652E210600000000000002051847A6B64856638A798C6482D2, please define it
2016.01.17 18:03:04 3: WMBUS Unknown device b2E4468508653704361807212A0019E1E000010030000000000000000034000000000000000000000000000000000FFFF0000000000FFFF80EA, please define it
2016.01.17 18:04:08 3: WMBUS Unknown device b2E446850428401636480DB0CA0113E1FD900100316000000111100005D770000050000000000000000000000021E0FD90A0607080B368383D7, please define it
2016.01.17 18:04:16 3: WMBUS Unknown device b2E44685053047143618093EFA0019E1E8A0B1003E703010E767653492CBF5B19321000020000000000031009004323B25A7799BBF642CA82DC, please define it
2016.01.17 18:04:18 3: WMBUS Unknown device b2E446850110571436180EE78A0019E1EFD001003DE0000000000181795D4A0000F0000000000000000000000000055D7000D023100B41980D9, please define it
2016.01.17 18:04:42 3: WMBUS Unknown device b2E446850895370436180CF7EA0019E1E560010038D00000006060000017450250000120000000000000000000000DF280000000000FFFF81E4, please define it
2016.01.17 18:05:03 3: WMBUS Unknown device b2E446850901171436180E0EFA0019E1EF90E10039F0502024F4F595814EC482055120000000000000000000F214531C16583869BB3FEFD80E4, please define it
2016.01.17 18:05:17 3: WMBUS Unknown device b2E446850570471436180D260A0019E1ED703100360040013DDDD7B994F41AD537A534716000000001203120B1C02F06C0603081307711080E5, please define it
2016.01.17 18:05:18 3: WMBUS Unknown device b2E446850061271436180B06BA0019E1E4C011003C800000835351C22BE09280A1704000000000000000000000019AB451E2C24002DC94C80D1, please define it
2016.01.17 18:05:23 3: WMBUS Unknown device b2E4468500430515464803E20A011BF1ECA0A10030901011028280C0C02A52E0E0000000000000000000000000016DA3D385E91AEB4AD0D89D8, please define it
2016.01.17 18:05:23 3: WMBUS Unknown device b2E4468509384016364802B14A0113E1FF00210037F0100005C5C272673654333392700000000000000000B04031803253E54462779C1F784D2, please define it
2016.01.17 18:05:33 3: WMBUS Unknown device b2E4468508804714361805E9CA0019E1EC50110031A0000010A0A0301D762050600000000000000000000000000004AB30000000205E3DB80E1, please define it
2016.01.17 18:05:44 3: WMBUS Unknown device b2E446850990471436180A44DA0019E1E280310032E020026ABAB593E650C54273D0D000000000000000000010036BB4444506B1B63E86180E3, please define it
2016.01.17 18:06:04 3: WMBUS Unknown device b2E4468508053704361808DE8A0019E1E50041003D2020010929272735FB951373B4928000000000000000017322910944235676F4DD94481D5, please define it
2016.01.17 18:06:05 3: WMBUS Unknown device b2E446850253051546480891AA011BF1EBD251003C8100314ACAC8240983B7B74988A5C30000000001B00121A468FB3BDB4C0B0E4D28AE486D2, please define it
2016.01.17 18:06:42 3: WMBUS Unknown device b2E446850223051546480B768A011BF1E5605100393020012A5A596934BD08E1F000D000000000000000000000000F90688BCADE3D028ED8ED5, please define it
2016.01.17 18:07:00 3: WMBUS Unknown device b2E4468500412714361800E1EA0019E1E02051003CA0200158B8B5C6A9BB56A39652E210600000000000002051847A6B64856638A798C6481D0, please define it
2016.01.17 18:07:07 3: WMBUS Unknown device b2E4468508653704361807212A0019E1E000010030000000000000000034000000000000000000000000000000000FFFF0000000000FFFF80E9, please define it
2016.01.17 18:07:30 3: WMBUS Unknown device b2E446850031271436180306CA0019E1E360110033400001F08080D006DDB00000000000000000000000000000000FFFF000035853D4C9D80E8, please define it
2016.01.17 18:07:44 3: WMBUS Unknown device b2E4468505084016364805E20A0113E1FD70110038A01000030301956C3915355340F01000000000000000000001BDBE21A2618311441E683D9, please define it
2016.01.17 18:07:48 3: WMBUS Unknown device b2E4468502654704361802A9FA0019E1EEB0110030900000000000000C59000000900000000000000000000000000AA7202002C394E15E580E0, please define it
2016.01.17 18:08:19 3: WMBUS Unknown device b2E44685053047143618093EFA0019E1E8A0B1003E703010E767653492CBF5B19321000020000000000031009004323B25A7799BBF642CA80DD, please define it
2016.01.17 18:08:26 3: WMBUS Unknown device b2E446850110571436180EE78A0019E1EFD001003DE0000000000181795D4A0000F0000000000000000000000000055D7000D023100B41983D2, please define it
2016.01.17 18:08:43 3: WMBUS Unknown device b2E446850895370436180CF7EA0019E1E560010038D00000006060000017450250000120000000000000000000000DF280000000000FFFF82E2, please define it
2016.01.17 18:08:51 3: WMBUS Unknown device b2E4468509484016364801566A0113E1F71011003720000011414050C8E7A19181C000202000000000200050607154240000C584314867080CF, please define it
2016.01.17 18:09:03 3: WMBUS Unknown device b2E446850901171436180E0EFA0019E1EF90E10039F0502024F4F595814EC482055120000000000000000000F214531C16583869BB3FEFD80E5, please define it
2016.01.17 18:09:21 3: WMBUS Unknown device b2E446850570471436180D260A0019E1ED703100360040013DDDD7B994F41AD537A534716000000001203120B1C02F06C0603081307711081E4, please define it
2016.01.17 18:09:25 3: WMBUS Unknown device b2E4468500430515464803E20A011BF1ECA0A10030901011028280C0C02A52E0E0000000000000000000000000016DA3D385E91AEB4AD0D84D4, please define it
2016.01.17 18:09:37 3: WMBUS Unknown device b2E4468508804714361805E9CA0019E1EC50110031A0000010A0A0301D762050600000000000000000000000000004AB30000000205E3DB80E1, please define it
2016.01.17 18:10:44 3: WMBUS Unknown device b2E446850223051546480B768A011BF1E5605100393020013A5A5969365568E1F000D000000000000000000000000F90688BCADE3D028ED87D3, please define it
2016.01.17 18:11:07 3: WMBUS Unknown device b2E4468508653704361807212A0019E1E000010030000000000000000034000000000000000000000000000000000FFFF0000000000FFFF80EA, please define it
2016.01.17 18:11:38 3: WMBUS Unknown device b2E446850031271436180306CA0019E1E360110033400001F08080D006DDB00000000000000000000000000000000FFFF000035853D4C9D80E9, please define it
2016.01.17 18:11:50 3: WMBUS Unknown device b2E4468502654704361802A9FA0019E1EEB0110030900000000000000C59000000900000000000000000000000000AA7202002C394E15E580DF, please define it
2016.01.17 18:12:17 3: WMBUS Unknown device b2E446850428401636480DB0CA0113E1FD900100316000000111100005D770000050000000000000000000000021E0FD90A0607080B368386D6, please define it
2016.01.17 18:12:20 3: WMBUS Unknown device b2E44685053047143618093EFA0019E1E8A0B1003E703010E767653492CBF5B19321000020000000000031009004323B25A7799BBF642CA80DF, please define it
2016.01.17 18:12:43 3: WMBUS Unknown device b2E4468507004714361809AA0A0019E1E77211003990D0313A0A06E77DA97854B67432B0A0000000007020A0C5C9CEF5CAFB8B2E0E1D9C682D6, please define it
2016.01.17 18:12:44 3: WMBUS Unknown device b2E446850895370436180CF7EA0019E1E560010038D00000006060000017450250000120000000000000000000000DF280000000000FFFF80E2, please define it
2016.01.17 18:13:03 3: WMBUS Unknown device b2E446850901171436180E0EFA0019E1EF90E10039F0502024F4F595814EC482055120000000000000000000F214531C16583869BB3FEFD82E2, please define it
2016.01.17 18:13:16 3: WMBUS Unknown device b2E446850991171436180A279A0019E1E1B0410037E020016989851397FF96E445C260B000000000000000304113C9129545960006334EE80D8, please define it
2016.01.17 18:13:23 3: WMBUS Unknown device b2E446850570471436180D260A0019E1ED703100360040013DDDD7B994F41AD537A534716000000001203120B1C02F06C0603081307711080E6, please define it
HKV filtert scheinbar einiges weg. Die verbleibenden devices starten alle mit "b2E446850..."
herrmannj
das sind immer noch noch HKV, allerdings eben Versionen die bisher unbekannt aber auch schon älter sind.
Soweit ich sehe sind die bis auf die T1 und T2 kompatibel. Es sei denn Du hast Nachbarn mit Temperaturen von 572° ... Celsius *fg
Ich nehme die neuen mal mit auf. Sind morgen im update. Dann verschwinden die Meldungen dazu. Mal schauen ob dann Dein "ultra" übrigbleibt.
vg
joerg
mircoby
So, update ist gemacht, läuft alles nach Plan. Seit 1,5 Stunden, noch keine unbekannten Geräte im Log aufgetaucht... Falls noch was kommt werde ich posten.
Vielen Dank nochmal!
Gruß Mirko
