Neue Version von HTTPMOD mit neuen Features zum Testen
Begonnen von StefanStrobel, 05 Dezember 2015, 08:31:32
Burny4600
#255
@StefanStrobel
Anbei das gewünschte Config
### Resol DL2 HTML Auswertungen   ###
define DL2 HTTPMOD http://192.168.xxx.xxx/dlx/download/live?&outputType=json&source=current 15
attr DL2 devStateIcon !SZ:it_network@green SZ:it_network@red
attr DL2 event-on-change-reading headersets_01_packets_01_field_values_(01|02|03|04|05|06|07|08|09|10|11|12|13|14|15|16|17|18|19|20|21|22|23|24|25|26|27|28|29|30|31|32)_value,headersets_01_packets_02_field_values_(01|02|03|04)_value,(F|W)M,headersets_01_packets_03_field_values_(01|02|03|04)_value,T_0(1|2|3|4|5|6|7|8|9),T_1(0|1|2),CS10,IMP0(1|2),S(BRM|KSM|BEM|Z),R_(1|2|3|4|5|6|7|8|9),RBEM,RV,VT_(1|2),RT_(1|2),W_(1|2)_(Wh|kWh|MWh),VS_(1|2)_(lph|lpmin|m3ph)
attr DL2 extractAllJSON 1
attr DL2 group Schnittstellen
attr DL2 icon sani_solar_temp
attr DL2 room _RxTx
attr DL2 stateFormat SZ
attr DL2 userReadings T_01:headersets_01_packets_01_field_values_01_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_01_value",0)},\
T_02:headersets_01_packets_01_field_values_02_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_02_value",0)},\
T_03:headersets_01_packets_01_field_values_03_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_03_value",0)},\
T_04:headersets_01_packets_01_field_values_04_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_04_value",0)},\
T_05:headersets_01_packets_01_field_values_05_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_05_value",0)},\
T_06:headersets_01_packets_01_field_values_06_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_06_value",0)},\
T_07:headersets_01_packets_01_field_values_07_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_07_value",0)},\
T_08:headersets_01_packets_01_field_values_08_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_08_value",0)},\
T_09:headersets_01_packets_01_field_values_09_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_09_value",0)},\
T_10:headersets_01_packets_01_field_values_10_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_10_value",0)},\
T_11:headersets_01_packets_01_field_values_11_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_11_value",0)},\
T_12:headersets_01_packets_01_field_values_12_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_12_value",0)},\
CS10:headersets_01_packets_01_field_values_13_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_13_value",0)},\
IMP01:headersets_01_packets_01_field_values_14_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_14_value",0)},\
IMP02:headersets_01_packets_01_field_values_15_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_15_value",0)},\
SBRM:headersets_01_packets_01_field_values_16_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_16_value",0)},\
SKSM:headersets_01_packets_01_field_values_17_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_17_value",0)},\
SBEM:headersets_01_packets_01_field_values_18_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_18_value",0)},\
R_1:headersets_01_packets_01_field_values_19_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_19_value",0)},\
R_2:headersets_01_packets_01_field_values_20_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_20_value",0)},\
R_3:headersets_01_packets_01_field_values_21_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_21_value",0)},\
R_4:headersets_01_packets_01_field_values_22_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_22_value",0)},\
R_5:headersets_01_packets_01_field_values_23_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_23_value",0)},\
R_6:headersets_01_packets_01_field_values_24_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_24_value",0)},\
R_7:headersets_01_packets_01_field_values_25_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_25_value",0)},\
R_8:headersets_01_packets_01_field_values_26_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_26_value",0)},\
R_9:headersets_01_packets_01_field_values_27_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_27_value",0)},\
RBEM:headersets_01_packets_01_field_values_28_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_28_value",0)},\
FM:headersets_01_packets_01_field_values_29_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_29_value",0)},\
WM:headersets_01_packets_01_field_values_30_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_30_value",0)},\
RV:headersets_01_packets_01_field_values_31_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_31_value",0)},\
SZ:headersets_01_packets_01_field_values_32_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_32_value",0)},\
VT_1:headersets_01_packets_02_field_values_01_value.* {ReadingsVal("DL2","headersets_01_packets_02_field_values_01_value",0)},\
RT_1:headersets_01_packets_02_field_values_02_value.* {ReadingsVal("DL2","headersets_01_packets_02_field_values_02_value",0)},\
VS_1_lph:headersets_01_packets_02_field_values_03_value.* {ReadingsVal("DL2","headersets_01_packets_02_field_values_03_value",0)},\
W_1_Wh:headersets_01_packets_02_field_values_04_value.* {ReadingsVal("DL2","headersets_01_packets_02_field_values_04_value",0)},\
VT_2:headersets_01_packets_03_field_values_01_value.* {ReadingsVal("DL2","headersets_01_packets_03_field_values_01_value",0)},\
RT_2:headersets_01_packets_03_field_values_02_value.* {ReadingsVal("DL2","headersets_01_packets_03_field_values_02_value",0)},\
VS_2_lph:headersets_01_packets_03_field_values_03_value.* {ReadingsVal("DL2","headersets_01_packets_03_field_values_03_value",0)},\
W_2_Wh:headersets_01_packets_03_field_values_04_value.* {ReadingsVal("DL2","headersets_01_packets_03_field_values_04_value",0)},\
W_1_kWh:W_1_Wh.* {ReadingsVal("DL2","W_1_Wh",0)/1000},\
W_1_MWh:W_1_Wh.* {ReadingsVal("DL2","W_1_Wh",0)/1000000},\
W_2_kWh:W_2_Wh.* {ReadingsVal("DL2","W_2_Wh",0)/1000},\
W_2_MWh:W_2_Wh.* {ReadingsVal("DL2","W_2_Wh",0)/1000000},\
VS_1_lpmin:VS_1_lph.* {ReadingsVal("DL2","VS_1_lph",0)/60},\
VS_1_m3ph:VS_1_lph.* {ReadingsVal("DL2","VS_1_lph",0)/1000},\
VS_2_lpmin:VS_2_lph.* {ReadingsVal("DL2","VS_2_lph",0)/60},\
VS_2_m3ph:VS_2_lph.* {ReadingsVal("DL2","VS_2_lph",0)/1000}
attr DL2 verbose 1
# attr DL2 event-on-change-reading (T_0(1|2|3|4|5|6|7|8|9)),(T_1(0|1|2)),CS10,(IMP0(1|2)),(S(BRM|KSM|BEM)),(R_(1|2|3|4|5|6|7|8|9)),RBEM,RV,(VT_(1|2)),(F|W)M,(RT_(1|2)),(W_(1|2)),(W_(1|2)_(kWh|MWh)),(VS_(1|2)_(lph|lpmin|m3ph))
# attr DL2 event-on-change-reading T_0(1|2|3|4|5|6|7|8|9),T_1(0|1|2),CS10,IMP0(1|2),S(BRM|KSM|BEM|Z),R_(1|2|3|4|5|6|7|8|9),RBEM,(F|W)M,RV,VT_(1|2),RT_(1|2),VS_(1|2),W_(1|2),W_1_(kWh|MWh),W_2_(kWh|MWh),VS_1_(lpmin|m3ph),VS_2_(lpmin|m3ph)
# attr DL2 event-on-change-reading headersets_01_packets_01_field_values_01_value,headersets_01_packets_01_field_values_02_value,headersets_01_packets_01_field_values_03_value,headersets_01_packets_01_field_values_04_value,headersets_01_packets_01_field_values_05_value,headersets_01_packets_01_field_values_06_value,headersets_01_packets_01_field_values_07_value,headersets_01_packets_01_field_values_08_value,headersets_01_packets_01_field_values_09_value,headersets_01_packets_01_field_values_10_value,headersets_01_packets_01_field_values_11_value,headersets_01_packets_01_field_values_12_value,headersets_01_packets_01_field_values_13_value,headersets_01_packets_01_field_values_14_value,headersets_01_packets_01_field_values_15_value,headersets_01_packets_01_field_values_16_value,headersets_01_packets_01_field_values_17_value,headersets_01_packets_01_field_values_18_value,headersets_01_packets_01_field_values_19_value,headersets_01_packets_01_field_values_20_value,headersets_01_packets_01_field_values_21_value,headersets_01_packets_01_field_values_22_value,headersets_01_packets_01_field_values_23_value,headersets_01_packets_01_field_values_24_value,headersets_01_packets_01_field_values_25_value,headersets_01_packets_01_field_values_26_value,headersets_01_packets_01_field_values_27_value,headersets_01_packets_01_field_values_28_value,headersets_01_packets_01_field_values_29_value,headersets_01_packets_01_field_values_30_value,headersets_01_packets_01_field_values_31_value,headersets_01_packets_01_field_values_32_value,headersets_01_packets_02_field_values_01_value,headersets_01_packets_02_field_values_02_value,headersets_01_packets_02_field_values_03_value,headersets_01_packets_02_field_values_04_value,headersets_01_packets_03_field_values_01_value,headersets_01_packets_03_field_values_02_value,headersets_01_packets_03_field_values_03_value,headersets_01_packets_03_field_values_04_value
###       Anzeigenwerte für       ###
###      Floorplan definieren     ###
define DL2_T01 readingsProxy DL2:T_01
attr DL2_T01 alias S01 Kollektortemperatur
attr DL2_T01 fp_SolarThermie 20,472,5,,
attr DL2_T01 group Sensoren
attr DL2_T01 icon sani_solar_temp
attr DL2_T01 room SolarThermie
attr DL2_T01 stateFormat {sprintf(\
"%.1f °C",\
ReadingsVal("$name","state",0))}
define DL2_T02 readingsProxy DL2:T_02
attr DL2_T02 alias S02 Speichertemperatur unten
attr DL2_T02 fp_SolarThermie 524,691,5, ,DL2_T02
attr DL2_T02 group Sensoren
attr DL2_T02 icon sani_buffer_temp_down
attr DL2_T02 room SolarThermie
attr DL2_T02 stateFormat {sprintf(\
"%.1f °C",\
define DL2_T03 readingsProxy DL2:T_03
attr DL2_T03 alias S03 Speichertemperatur oben
attr DL2_T03 fp_SolarThermie 397,693,5,,
attr DL2_T03 group Sensoren
attr DL2_T03 icon sani_buffer_temp_up
attr DL2_T03 room SolarThermie
attr DL2_T03 stateFormat {sprintf(\
"%.1f °C",\
define DL2_T04 readingsProxy DL2:T_04
attr DL2_T04 alias S04 Pooltemperatur
attr DL2_T04 event-min-interval .*:60
attr DL2_T04 event-on-change-reading state
attr DL2_T04 fp_SolarThermie 646,308,5, ,DL2_T04
attr DL2_T04 group Sensoren
attr DL2_T04 icon temp_temperature
attr DL2_T04 room AB-Pool,SolarThermie
attr DL2_T04 stateFormat {sprintf(\
"%.1f °C",\
define DL2_T05 readingsProxy DL2:T_05
attr DL2_T05 alias S05 Wärmetauscher Rücklauftemperatur
attr DL2_T05 fp_SolarThermie 519,419,5,,
attr DL2_T05 group Sensoren
attr DL2_T05 icon sani_buffer_temp_up
attr DL2_T05 room SolarThermie
attr DL2_T05 stateFormat {sprintf(\
"%.1f °C",\
define DL2_T06 readingsProxy DL2:T_06
attr DL2_T06 alias S06 Boilertemperatur
attr DL2_T06 fp_SolarThermie 446,876,5,,
attr DL2_T06 group Sensoren
attr DL2_T06 icon sani_boiler_temp
attr DL2_T06 room SolarThermie
attr DL2_T06 stateFormat {sprintf(\
"%.1f °C",\
define DL2_T07 readingsProxy DL2:T_07
attr DL2_T07 alias S07 Heizung Rücklauftemperatur
attr DL2_T07 fp_SolarThermie 173,1086,5,,
attr DL2_T07 group Sensoren
attr DL2_T07 icon sani_return_temp
attr DL2_T07 room SolarThermie
attr DL2_T07 stateFormat {sprintf(\
"%.1f °C",\
define DL2_T08 readingsProxy DL2:T_08
attr DL2_T08 alias S08 Speichertemperatur mitte
attr DL2_T08 fp_SolarThermie 458,691,5,,
attr DL2_T08 group Sensoren
attr DL2_T08 icon sani_buffer_temp_all
attr DL2_T08 room SolarThermie
attr DL2_T08 stateFormat {sprintf(\
"%.1f °C",\
define DL2_T09 readingsProxy DL2:T_09
attr DL2_T09 alias S09 Kollektor Vorlauftemperatur
attr DL2_T09 fp_SolarThermie 194,522,5,,
attr DL2_T09 group Sensoren
attr DL2_T09 icon sani_supply_temp
attr DL2_T09 room SolarThermie
attr DL2_T09 stateFormat {sprintf(\
"%.1f °C",\
define DL2_T10 readingsProxy DL2:T_10
attr DL2_T10 alias S10 Kollektor Rücklauftemperatur
attr DL2_T10 fp_SolarThermie 194,425,5,,
attr DL2_T10 group Sensoren
attr DL2_T10 icon sani_return_temp
attr DL2_T10 room SolarThermie
attr DL2_T10 stateFormat {sprintf(\
"%.1f °C",\
define DL2_T11 readingsProxy DL2:T_11
attr DL2_T11 alias S11 Aussentemperatur
attr DL2_T11 fp_SolarThermie 134,273,5,DL2_T11,
attr DL2_T11 group Sensoren
attr DL2_T11 icon temp_outside
attr DL2_T11 room AB,OG1-Balkon,SolarThermie,Wetterstation
attr DL2_T11 stateFormat {sprintf("%.1f °C",\
define DL2_T12 readingsProxy DL2:T_12
attr DL2_T12 alias S12 Heizung Vorlauftemperatur
attr DL2_T12 fp_SolarThermie 106,1106,5,,
attr DL2_T12 group Sensoren
attr DL2_T12 icon sani_supply_temp
attr DL2_T12 room SolarThermie
attr DL2_T12 stateFormat {sprintf(\
"%.1f °C",\
define DL2_CS10 readingsProxy DL2:CS10
attr DL2_CS10 alias CS10 Strahlungsenergie
attr DL2_CS10 fp_SolarThermie 61,326,5, ,DL2_CS10
attr DL2_CS10 group Sensoren
attr DL2_CS10 icon sani_solar
attr DL2_CS10 room AB-Pool,OG1,OG1-Balkon,OG1-Wohnzimmer,SolarThermie
attr DL2_CS10 stateFormat state W/m²
define DL2_R1 readingsProxy DL2:R_1
attr DL2_R1 alias R1 Schichtspeicherpumpe
attr DL2_R1 fp_SolarThermie 437,481,5,
attr DL2_R1 group Geräte
attr DL2_R1 icon sani_pump
attr DL2_R1 room SolarThermie
attr DL2_R1 stateFormat state %
define DL2_R2 readingsProxy DL2:R_2
attr DL2_R2 alias R2 Reserve
attr DL2_R2 group Geräte
attr DL2_R2 icon sani_pump
attr DL2_R2 room SolarThermie
attr DL2_R2 stateFormat state %
define DL2_R3 readingsProxy DL2:R_3
attr DL2_R3 alias R3 Kessel Vorlaufpumpe
attr DL2_R3 fp_SolarThermie 380,967,5,DL2_R3,
attr DL2_R3 group Geräte
attr DL2_R3 icon sani_pump
attr DL2_R3 room SolarThermie
attr DL2_R3 stateFormat state %
define DL2_R4 readingsProxy DL2:R_4
attr DL2_R4 alias R4 Poolpumpe primär
attr DL2_R4 fp_SolarThermie 439,422,5,
attr DL2_R4 group Geräte
attr DL2_R4 icon sani_pump
attr DL2_R4 room AB-Pool,SolarThermie
attr DL2_R4 stateFormat state %
define DL2_R5 readingsProxy DL2:R_5
attr DL2_R5 alias R5 Bypasspumpe
attr DL2_R5 fp_SolarThermie 456,422,5,,
attr DL2_R5 group Geräte
attr DL2_R5 icon sani_pump
attr DL2_R5 room SolarThermie
attr DL2_R5 stateFormat state %
define DL2_R6 readingsProxy DL2:R_6
attr DL2_R6 alias R6 Zirkulationspumpe WW
attr DL2_R6 fp_SolarThermie 428,762,5,,
attr DL2_R6 group Geräte
attr DL2_R6 icon sani_pump
attr DL2_R6 room SolarThermie
attr DL2_R6 stateFormat state %
define DL2_R7 readingsProxy DL2:R_7
attr DL2_R7 alias R7 Heizung Vorlaufpumpe
attr DL2_R7 fp_SolarThermie 376,1095,5,,
attr DL2_R7 group Geräte
attr DL2_R7 icon sani_pump
attr DL2_R7 room SolarThermie
attr DL2_R7 stateFormat state %
define DL2_R8 readingsProxy DL2:R_8
attr DL2_R8 alias R8 Poolpumpe sekundär
attr DL2_R8 fp_SolarThermie 597,321,5,,
attr DL2_R8 group Geräte
attr DL2_R8 icon sani_pump
attr DL2_R8 room AB-Pool,SolarThermie
attr DL2_R8 stateFormat state %
define DL2_R9 readingsProxy DL2:R_9
attr DL2_R9 alias R9 Reserve
attr DL2_R9 group Geräte
attr DL2_R9 icon sani_pump
attr DL2_R9 room SolarThermie
attr DL2_R9 stateFormat state %
define DL2_WMZ1IP readingsProxy DL2:IMP01
attr DL2_WMZ1IP alias WMZ1 Impulszähler
attr DL2_WMZ1IP group Wärmemengenzähler 1 - DeltaSol M
attr DL2_WMZ1IP icon vent_ventilation_level_3
attr DL2_WMZ1IP room SolarThermie
define DL2_WMZ2IP readingsProxy DL2:IMP02
attr DL2_WMZ2IP alias WMZ2 Impulszähler
attr DL2_WMZ2IP group Wärmemengenzähler 2 - DeltaSol M
attr DL2_WMZ2IP icon vent_ventilation_level_3
attr DL2_WMZ2IP room SolarThermie
define DL2_WMZ1RT readingsProxy DL2:RT_1
attr DL2_WMZ1RT alias WMZ1 Rücklauftemperatur
attr DL2_WMZ1RT group Wärmemengenzähler 1 - DeltaSol M
attr DL2_WMZ1RT icon sani_return_temp
attr DL2_WMZ1RT room SolarThermie
attr DL2_WMZ1RT stateFormat {sprintf(\
"%.1f °C",\
define DL2_WMZ1VS readingsProxy DL2:VS_1_lph
attr DL2_WMZ1VS alias WMZ1 Volumenstrom
attr DL2_WMZ1VS fp_SolarThermie 217,352,5, ,DL2_WMZ1VS
attr DL2_WMZ1VS group Wärmemengenzähler 1 - DeltaSol M
attr DL2_WMZ1VS icon vent_ventilation_level_3
attr DL2_WMZ1VS room AB-Pool,SolarThermie
attr DL2_WMZ1VS stateFormat state l/h
define DL2_WMZ1VT readingsProxy DL2:VT_1
attr DL2_WMZ1VT alias WMZ1 Vorlauftemperatur
attr DL2_WMZ1VT group Wärmemengenzähler 1 - DeltaSol M
attr DL2_WMZ1VT icon sani_supply_temp
attr DL2_WMZ1VT room SolarThermie
attr DL2_WMZ1VT stateFormat {sprintf(\
"%.1f °C",\
define DL2_WMZ1W readingsProxy DL2:W_1_MWh
attr DL2_WMZ1W alias WMZ1 Wärmeenergie
attr DL2_WMZ1W fp_SolarThermie 234,333,5,DL2_WMZ1W,
attr DL2_WMZ1W group Wärmemengenzähler 1 - DeltaSol M
attr DL2_WMZ1W icon sani_measure_power
attr DL2_WMZ1W room SolarThermie
attr DL2_WMZ1W stateFormat state MWh
attr DL2_WMZ1W valueFn {sprintf("%.1f", $VALUE)}
define DL2_WMZ2RT readingsProxy DL2:RT_2
attr DL2_WMZ2RT alias WMZ2 Rücklauftemperatur
attr DL2_WMZ2RT group Wärmemengenzähler 2 - DeltaSol M
attr DL2_WMZ2RT icon sani_return_temp
attr DL2_WMZ2RT room AB-Pool,SolarThermie
attr DL2_WMZ2RT stateFormat {sprintf(\
"%.1f °C",\
define DL2_WMZ2VS readingsProxy DL2:VS_2_lph
attr DL2_WMZ2VS alias WMZ2 Volumenstrom
attr DL2_WMZ2VS group Wärmemengenzähler 2 - DeltaSol M
attr DL2_WMZ2VS icon vent_ventilation_level_3
attr DL2_WMZ2VS room SolarThermie
attr DL2_WMZ2VS stateFormat state l/h
define DL2_WMZ2VT readingsProxy DL2:VT_2
attr DL2_WMZ2VT alias WMZ2 Vorlauftemperatur
attr DL2_WMZ2VT group Wärmemengenzähler 2 - DeltaSol M
attr DL2_WMZ2VT icon sani_supply_temp
attr DL2_WMZ2VT room AB-Pool,SolarThermie
attr DL2_WMZ2VT stateFormat {sprintf(\
"%.1f °C",\
define DL2_WMZ2W readingsProxy DL2:W_2_MWh
attr DL2_WMZ2W alias WMZ2 Wärmeenergie
attr DL2_WMZ2W fp_SolarThermie 453,282,5,,
attr DL2_WMZ2W group Wärmemengenzähler 2 - DeltaSol M
attr DL2_WMZ2W icon sani_measure_power
attr DL2_WMZ2W room AB-Pool,SolarThermie
attr DL2_WMZ2W stateFormat state MWh
attr DL2_WMZ2W valueFn {sprintf("%.1f", $VALUE)}
define DL2_SZ readingsProxy DL2:SZ
attr DL2_SZ alias DeltaSol M
attr DL2_SZ group Geräte
attr DL2_SZ icon time_clock
attr DL2_SZ room SolarThermie
###       Trend Definitionen      ###
define FileLog_DL2 FileLog /media/hdd/fhem/log01/resol/DL2-%Y-%m.log DL2
attr FileLog_DL2 alias Solaranlage
attr FileLog_DL2 logtype :,text
attr FileLog_DL2 room _LOG
# attr FileLog_DL2 logtype Temp4Einst4:Temp/Einst,text
define FileLog_DL2_T04k FileLog /media/hdd/fhem/log01/resol/DL2_T04k-%Y-%m.log DL2_T04k
attr FileLog_DL2_T04k alias S04 Pooltemperatur korrigiert
attr FileLog_DL2_T04k logtype temp4:Temp,text
attr FileLog_DL2_T04k room _LOG
define SVG_DL2Solar01 SVG FileLog_DL2:SVG_DL2Solar01:CURRENT
attr SVG_DL2Solar01 alias Heizung Solar Schichtspeicher
attr SVG_DL2Solar01 room SolarThermie
define SVG_DL2Solar02 SVG FileLog_DL2:SVG_DL2Solar02:CURRENT
attr SVG_DL2Solar02 alias Heizung Gaskessel
attr SVG_DL2Solar02 room SolarThermie
define SVG_DL2Solar03 SVG FileLog_DL2:SVG_DL2Solar03:CURRENT
attr SVG_DL2Solar03 alias Heizung Solar Pool
attr SVG_DL2Solar03 room SolarThermie
define SVG_DL2Solar04 SVG FileLog_DL2:SVG_DL2Solar04:CURRENT
attr SVG_DL2Solar04 alias Heizung Warmwasser
attr SVG_DL2Solar04 room SolarThermie
Das mit verbose 5 lasse ich gerade laufen und liefer das log nach.
Siehe Anhang LOG.
Da es auf einer Testumgebung getestet wurde befinden sich zusätzliche Fehler im Log die mit dem Perl Warning des betreffend Config Auszug nichts zu tun haben.
LG Chris
Devices: APC, Eastron, FS20, IT, Homematic, MQTT, PV-(DEYE, EPEVER, FRONIUS), Resol-VBUS, S.USV, TEK603, WMR200, YouLess
StefanStrobel
Hallo Chris,
die Warnungen, nach denen Du suchst, kommen in dem Log leider gar nicht vor.
Gruss
    Stefan
Burny4600
#257
Ein aktueller Logauschnitt mit den Perl Warnungen.
2016.07.25 15:01:52 2: autocreate: define FileLog_THGR810_6 FileLog /media/hdd/fhem/log01/THGR810_6-%Y.log THGR810_6
2016.07.25 15:01:52 2: autocreate: define SVG_THGR810_6 SVG FileLog_THGR810_6:temp4hum4:CURRENT
2016.07.25 15:03:11 2: autocreate: define FileLog_THGR810_6 FileLog /media/hdd/fhem/log01/THGR810_6-%Y.log THGR810_6
2016.07.25 15:03:11 2: autocreate: define SVG_THGR810_6 SVG FileLog_THGR810_6:temp4hum4:CURRENT
2016.07.25 15:03:17 1: PERL WARNING: Useless use of private variable in void context at (eval 27895) line 1.
2016.07.25 15:03:17 1: PERL WARNING: Useless use of private variable in void context at (eval 27896) line 1.
2016.07.25 15:03:47 1: PERL WARNING: Useless use of private variable in void context at (eval 28230) line 1.
2016.07.25 15:03:47 1: PERL WARNING: Useless use of private variable in void context at (eval 28231) line 1.
2016.07.25 15:05:02 1: PERL WARNING: Useless use of private variable in void context at (eval 28944) line 1.
2016.07.25 15:05:02 1: PERL WARNING: Useless use of private variable in void context at (eval 28945) line 1.
2016.07.25 15:08:27 2: autocreate: define FileLog_THGR810_6 FileLog /media/hdd/fhem/log01/THGR810_6-%Y.log THGR810_6
2016.07.25 15:08:27 2: autocreate: define SVG_THGR810_6 SVG FileLog_THGR810_6:temp4hum4:CURRENT
2016.07.25 15:08:32 1: PERL WARNING: Useless use of private variable in void context at (eval 30999) line 1.
2016.07.25 15:08:32 1: PERL WARNING: Useless use of private variable in void context at (eval 31000) line 1.
2016.07.25 15:09:02 1: PERL WARNING: Useless use of private variable in void context at (eval 31289) line 1.
2016.07.25 15:09:02 1: PERL WARNING: Useless use of private variable in void context at (eval 31290) line 1.
2016.07.25 15:09:46 2: autocreate: define FileLog_THGR810_6 FileLog /media/hdd/fhem/log01/THGR810_6-%Y.log THGR810_6
2016.07.25 15:09:46 2: autocreate: define SVG_THGR810_6 SVG FileLog_THGR810_6:temp4hum4:CURRENT
2016.07.25 15:10:02 1: PERL WARNING: Useless use of private variable in void context at (eval 31853) line 1.
2016.07.25 15:10:02 1: PERL WARNING: Useless use of private variable in void context at (eval 31854) line 1.
2016.07.25 15:11:32 1: PERL WARNING: Useless use of private variable in void context at (eval 32624) line 1.
2016.07.25 15:11:32 1: PERL WARNING: Useless use of private variable in void context at (eval 32625) line 1.
2016.07.25 15:12:32 1: PERL WARNING: Useless use of private variable in void context at (eval 33098) line 1.
2016.07.25 15:12:32 1: PERL WARNING: Useless use of private variable in void context at (eval 33099) line 1.
2016.07.25 15:13:43 2: autocreate: define FileLog_THGR810_6 FileLog /media/hdd/fhem/log01/THGR810_6-%Y.log THGR810_6
2016.07.25 15:13:43 2: autocreate: define SVG_THGR810_6 SVG FileLog_THGR810_6:temp4hum4:CURRENT
2016.07.25 15:14:17 1: PERL WARNING: Useless use of private variable in void context at (eval 34065) line 1.
2016.07.25 15:14:17 1: PERL WARNING: Useless use of private variable in void context at (eval 34066) line 1.
2016.07.25 15:14:32 1: PERL WARNING: Useless use of private variable in void context at (eval 34143) line 1.
2016.07.25 15:14:32 1: PERL WARNING: Useless use of private variable in void context at (eval 34144) line 1.
2016.07.25 15:14:47 1: PERL WARNING: Useless use of private variable in void context at (eval 34374) line 1.
2016.07.25 15:14:47 1: PERL WARNING: Useless use of private variable in void context at (eval 34375) line 1.
2016.07.25 15:14:56 2: CUL_TX F CUL_TX_127 127 (XFFFFFFFFFFC) unknown type
2016.07.25 15:15:00 2: IT set Freigabe_HZ_Pool off
2016.07.25 15:15:32 3: FS20 set L_OG1_WZ_Blume on
2016.07.25 15:16:21 2: autocreate: define FileLog_THGR810_6 FileLog /media/hdd/fhem/log01/THGR810_6-%Y.log THGR810_6
2016.07.25 15:16:21 2: autocreate: define SVG_THGR810_6 SVG FileLog_THGR810_6:temp4hum4:CURRENT
2016.07.25 15:17:17 1: PERL WARNING: Useless use of private variable in void context at (eval 35638) line 1.
2016.07.25 15:17:17 1: PERL WARNING: Useless use of private variable in void context at (eval 35639) line 1.
2016.07.25 15:17:40 2: autocreate: define FileLog_THGR810_6 FileLog /media/hdd/fhem/log01/THGR810_6-%Y.log THGR810_6
2016.07.25 15:17:40 2: autocreate: define SVG_THGR810_6 SVG FileLog_THGR810_6:temp4hum4:CURRENT
2016.07.25 15:18:02 1: PERL WARNING: Useless use of private variable in void context at (eval 35957) line 1.
2016.07.25 15:18:02 1: PERL WARNING: Useless use of private variable in void context at (eval 35958) line 1.
2016.07.25 15:18:51 3: IT_11011001 Unknown, Please learn codes!->Unknown, Please learn codes!
2016.07.25 15:18:52 3: IT_F00F000F0F off->on
2016.07.25 15:18:52 3: IT_11000111100011110001111000101101100110011011001001011 off->on
2016.07.25 15:18:58 3: IT_11011001 Unknown, Please learn codes!->Unknown, Please learn codes!
2016.07.25 15:18:58 3: IT_F00F000F0F on->off
2016.07.25 15:18:59 3: IT_11000111100011110001111000101101100110011011001001011 on->off
2016.07.25 15:19:35 1: PERL WARNING: Useless use of private variable in void context at (eval 36719) line 1.
2016.07.25 15:19:35 1: PERL WARNING: Useless use of private variable in void context at (eval 36723) line 1.
2016.07.25 15:21:52 1: Hideki: UNDEFINED sensor 30 detected, code Hideki_30_6
2016.07.25 15:22:57 3: IT_11011001 Unknown, Please learn codes!->Unknown, Please learn codes!
2016.07.25 15:22:57 3: IT_0000000000010010110101010000001 on->on
2016.07.25 15:22:58 3: IT_0000000000010010110101010000001 on->on
2016.07.25 15:22:58 3: IT_11000111100011110010111001101100100110101011001001011 off->on
2016.07.25 15:22:58 3: IT_11011001 Unknown, Please learn codes!->Unknown, Please learn codes!
2016.07.25 15:22:58 3: IT_F00F000F0F off->on
2016.07.25 15:22:59 3: IT_F00F000F0F on->on
2016.07.25 15:22:59 3: IT_11000111100011110001111000101101100110011011001001011 off->on
2016.07.25 15:23:23 3: IT_F000000F0F off->on
2016.07.25 15:23:24 3: IT_11000111100011110001111001110100111010001111001001011 off->on
2016.07.25 15:23:32 1: PERL WARNING: Useless use of private variable in void context at (eval 38643) line 1.
2016.07.25 15:23:32 1: PERL WARNING: Useless use of private variable in void context at (eval 38644) line 1.
2016.07.25 15:24:02 1: PERL WARNING: Useless use of private variable in void context at (eval 38888) line 1.
2016.07.25 15:24:02 1: PERL WARNING: Useless use of private variable in void context at (eval 38889) line 1.
2016.07.25 15:24:18 1: PERL WARNING: Useless use of private variable in void context at (eval 39164) line 1.
2016.07.25 15:24:18 1: PERL WARNING: Useless use of private variable in void context at (eval 39165) line 1.
2016.07.25 15:25:34 2: autocreate: define FileLog_THGR810_6 FileLog /media/hdd/fhem/log01/THGR810_6-%Y.log THGR810_6
2016.07.25 15:25:34 2: autocreate: define SVG_THGR810_6 SVG FileLog_THGR810_6:temp4hum4:CURRENT
2016.07.25 15:28:07 2: autocreate: define FileLog_THWR800_3 FileLog /media/hdd/fhem/log01/THWR800_3-%Y.log THWR800_3
2016.07.25 15:30:48 3: FS20 set L_OG1_WZ_Blume off
2016.07.25 15:31:09 2: autocreate: define FileLog_THGR810_1 FileLog /media/hdd/fhem/log01/THGR810_1-%Y.log THGR810_1
2016.07.25 15:31:09 2: autocreate: define SVG_THGR810_1 SVG FileLog_THGR810_1:temp4hum4:CURRENT
2016.07.25 15:31:48 1: PERL WARNING: Useless use of private variable in void context at (eval 42937) line 1.
2016.07.25 15:31:48 1: PERL WARNING: Useless use of private variable in void context at (eval 42938) line 1.
2016.07.25 15:36:06 2: autocreate: define FileLog_THGR810_6 FileLog /media/hdd/fhem/log01/THGR810_6-%Y.log THGR810_6
2016.07.25 15:36:06 2: autocreate: define SVG_THGR810_6 SVG FileLog_THGR810_6:temp4hum4:CURRENT
2016.07.25 15:38:17 2: autocreate: define FileLog_THWR800_3 FileLog /media/hdd/fhem/log01/THWR800_3-%Y.log THWR800_3
2016.07.25 15:40:38 2: autocreate: define FileLog_THGR810_2 FileLog /media/hdd/fhem/log01/THGR810_2-%Y.log THGR810_2
2016.07.25 15:40:38 2: autocreate: define SVG_THGR810_2 SVG FileLog_THGR810_2:temp4hum4:CURRENT
2016.07.25 15:42:18 1: PERL WARNING: Useless use of private variable in void context at (eval 48150) line 1.
2016.07.25 15:42:18 1: PERL WARNING: Useless use of private variable in void context at (eval 48151) line 1.
2016.07.25 15:43:08 1: PERL WARNING: Useless use of private variable in void context at (eval 48571) line 1.
2016.07.25 15:43:09 1: PERL WARNING: Useless use of private variable in void context at (eval 48575) line 1.
2016.07.25 15:44:18 1: PERL WARNING: Useless use of private variable in void context at (eval 49231) line 1.
2016.07.25 15:44:18 1: PERL WARNING: Useless use of private variable in void context at (eval 49232) line 1.
2016.07.25 15:45:33 1: PERL WARNING: Useless use of private variable in void context at (eval 49881) line 1.
2016.07.25 15:45:33 1: PERL WARNING: Useless use of private variable in void context at (eval 49882) line 1.
2016.07.25 15:46:38 2: autocreate: define FileLog_THGR810_6 FileLog /media/hdd/fhem/log01/THGR810_6-%Y.log THGR810_6
2016.07.25 15:46:38 2: autocreate: define SVG_THGR810_6 SVG FileLog_THGR810_6:temp4hum4:CURRENT
2016.07.25 15:50:35 2: autocreate: define FileLog_THGR810_6 FileLog /media/hdd/fhem/log01/THGR810_6-%Y.log THGR810_6
2016.07.25 15:50:35 2: autocreate: define SVG_THGR810_6 SVG FileLog_THGR810_6:temp4hum4:CURRENT
2016.07.25 15:53:04 1: PERL WARNING: Useless use of private variable in void context at (eval 53756) line 1.
2016.07.25 15:53:04 1: PERL WARNING: Useless use of private variable in void context at (eval 53757) line 1.
2016.07.25 15:53:19 1: PERL WARNING: Useless use of private variable in void context at (eval 53978) line 1.
2016.07.25 15:53:19 1: PERL WARNING: Useless use of private variable in void context at (eval 53979) line 1.
2016.07.25 15:53:34 1: PERL WARNING: Useless use of private variable in void context at (eval 54096) line 1.
2016.07.25 15:53:34 1: PERL WARNING: Useless use of private variable in void context at (eval 54097) line 1.
2016.07.25 15:53:49 1: PERL WARNING: Useless use of private variable in void context at (eval 54315) line 1.
2016.07.25 15:53:49 1: PERL WARNING: Useless use of private variable in void context at (eval 54316) line 1.
2016.07.25 15:54:04 1: PERL WARNING: Useless use of private variable in void context at (eval 54408) line 1.
2016.07.25 15:54:04 1: PERL WARNING: Useless use of private variable in void context at (eval 54409) line 1.
2016.07.25 15:54:19 1: PERL WARNING: Useless use of private variable in void context at (eval 54621) line 1.
2016.07.25 15:54:19 1: PERL WARNING: Useless use of private variable in void context at (eval 54622) line 1.
2016.07.25 15:54:32 2: autocreate: define FileLog_THGR810_6 FileLog /media/hdd/fhem/log01/THGR810_6-%Y.log THGR810_6
2016.07.25 15:54:32 2: autocreate: define SVG_THGR810_6 SVG FileLog_THGR810_6:temp4hum4:CURRENT
2016.07.25 15:55:04 1: PERL WARNING: Useless use of private variable in void context at (eval 54965) line 1.
2016.07.25 15:55:04 1: PERL WARNING: Useless use of private variable in void context at (eval 54966) line 1.
2016.07.25 15:57:10 2: autocreate: define FileLog_THGR810_6 FileLog /media/hdd/fhem/log01/THGR810_6-%Y.log THGR810_6
2016.07.25 15:57:10 2: autocreate: define SVG_THGR810_6 SVG FileLog_THGR810_6:temp4hum4:CURRENT
2016.07.25 16:00:00 3: FS20 set L_OG1_WZ_Aqua on
2016.07.25 16:00:04 1: PERL WARNING: Useless use of private variable in void context at (eval 57691) line 1.
2016.07.25 16:00:04 1: PERL WARNING: Useless use of private variable in void context at (eval 57692) line 1.
2016.07.25 16:03:15 2: autocreate: define FileLog_THGR810_2 FileLog /media/hdd/fhem/log01/THGR810_2-%Y.log THGR810_2
2016.07.25 16:03:15 2: autocreate: define SVG_THGR810_2 SVG FileLog_THGR810_2:temp4hum4:CURRENT
2016.07.25 16:04:22 1: PERL WARNING: Useless use of private variable in void context at (eval 60630) line 1.
2016.07.25 16:04:23 1: PERL WARNING: Useless use of private variable in void context at (eval 60634) line 1.
2016.07.25 16:05:04 2: autocreate: define FileLog_THGR810_6 FileLog /media/hdd/fhem/log01/THGR810_6-%Y.log THGR810_6
2016.07.25 16:05:04 2: autocreate: define SVG_THGR810_6 SVG FileLog_THGR810_6:temp4hum4:CURRENT
2016.07.25 16:05:19 1: PERL WARNING: Useless use of private variable in void context at (eval 61264) line 1.
2016.07.25 16:05:19 1: PERL WARNING: Useless use of private variable in void context at (eval 61265) line 1.
2016.07.25 16:05:34 1: PERL WARNING: Useless use of private variable in void context at (eval 61418) line 1.
2016.07.25 16:05:34 1: PERL WARNING: Useless use of private variable in void context at (eval 61419) line 1.
2016.07.25 16:05:49 1: PERL WARNING: Useless use of private variable in void context at (eval 61611) line 1.
2016.07.25 16:05:49 1: PERL WARNING: Useless use of private variable in void context at (eval 61612) line 1.
2016.07.25 16:06:23 2: autocreate: define FileLog_THGR810_6 FileLog /media/hdd/fhem/log01/THGR810_6-%Y.log THGR810_6
2016.07.25 16:06:23 2: autocreate: define SVG_THGR810_6 SVG FileLog_THGR810_6:temp4hum4:CURRENT
2016.07.25 16:07:42 2: autocreate: define FileLog_THGR810_6 FileLog /media/hdd/fhem/log01/THGR810_6-%Y.log THGR810_6
2016.07.25 16:07:42 2: autocreate: define SVG_THGR810_6 SVG FileLog_THGR810_6:temp4hum4:CURRENT
2016.07.25 16:09:19 1: PERL WARNING: Useless use of private variable in void context at (eval 63857) line 1.
2016.07.25 16:09:19 1: PERL WARNING: Useless use of private variable in void context at (eval 63858) line 1.
2016.07.25 16:10:49 1: PERL WARNING: Useless use of private variable in void context at (eval 64860) line 1.
2016.07.25 16:10:49 1: PERL WARNING: Useless use of private variable in void context at (eval 64861) line 1.
2016.07.25 16:12:58 2: autocreate: define FileLog_THGR810_6 FileLog /media/hdd/fhem/log01/THGR810_6-%Y.log THGR810_6
2016.07.25 16:12:58 2: autocreate: define SVG_THGR810_6 SVG FileLog_THGR810_6:temp4hum4:CURRENT
2016.07.25 16:13:50 1: PERL WARNING: Useless use of private variable in void context at (eval 66791) line 1.
2016.07.25 16:13:50 1: PERL WARNING: Useless use of private variable in void context at (eval 66792) line 1.
2016.07.25 16:15:50 1: PERL WARNING: Useless use of private variable in void context at (eval 68021) line 1.
2016.07.25 16:15:50 1: PERL WARNING: Useless use of private variable in void context at (eval 68022) line 1.
2016.07.25 16:17:50 1: PERL WARNING: Useless use of private variable in void context at (eval 69277) line 1.
2016.07.25 16:17:50 1: PERL WARNING: Useless use of private variable in void context at (eval 69278) line 1.
2016.07.25 16:18:14 2: autocreate: define FileLog_THGR810_6 FileLog /media/hdd/fhem/log01/THGR810_6-%Y.log THGR810_6
2016.07.25 16:18:14 2: autocreate: define SVG_THGR810_6 SVG FileLog_THGR810_6:temp4hum4:CURRENT
2016.07.25 16:20:20 1: PERL WARNING: Useless use of private variable in void context at (eval 70875) line 1.
2016.07.25 16:20:20 1: PERL WARNING: Useless use of private variable in void context at (eval 70876) line 1.
2016.07.25 16:20:35 1: PERL WARNING: Useless use of private variable in void context at (eval 71007) line 1.
2016.07.25 16:20:35 1: PERL WARNING: Useless use of private variable in void context at (eval 71008) line 1.
2016.07.25 16:20:52 2: autocreate: define FileLog_THGR810_6 FileLog /media/hdd/fhem/log01/THGR810_6-%Y.log THGR810_6
2016.07.25 16:20:52 2: autocreate: define SVG_THGR810_6 SVG FileLog_THGR810_6:temp4hum4:CURRENT
2016.07.25 16:21:05 1: PERL WARNING: Useless use of private variable in void context at (eval 71328) line 1.
2016.07.25 16:21:05 1: PERL WARNING: Useless use of private variable in void context at (eval 71329) line 1.
2016.07.25 16:25:09 1: PERL WARNING: Useless use of private variable in void context at (eval 73736) line 1.
2016.07.25 16:25:09 1: PERL WARNING: Useless use of private variable in void context at (eval 73740) line 1.
2016.07.25 16:25:20 1: sendEmail RCP: christian.schmidt@ccs-media.at
2016.07.25 16:25:20 1: sendEmail Subject: FHEM - Solaranlage R5 keine Strömung: R5A
2016.07.25 16:25:20 1: sendEmail Text:
2016.07.25 16:25:20 1: sendEmail Anhang:
2016.07.25 16:25:21 1: sendEmail returned: Reading message body from STDIN because the '-m' option was not used.If you are manually typing in a message:  - First line must be received within 60 seconds.  - End manual input with a CTRL-D on its own line.Jul 25 16:25:21 ccs-ht-rasp01 sendEmail[19334]: Message input complete.Jul 25 16:25:21 ccs-ht-rasp01 sendEmail[19334]: Email was sent successfully!
2016.07.25 16:25:50 1: PERL WARNING: Useless use of private variable in void context at (eval 74225) line 1.
2016.07.25 16:25:50 1: PERL WARNING: Useless use of private variable in void context at (eval 74226) line 1.
2016.07.25 16:27:20 1: PERL WARNING: Useless use of private variable in void context at (eval 75190) line 1.
2016.07.25 16:27:20 1: PERL WARNING: Useless use of private variable in void context at (eval 75191) line 1.
2016.07.25 16:27:35 1: PERL WARNING: Useless use of private variable in void context at (eval 75363) line 1.
2016.07.25 16:27:35 1: PERL WARNING: Useless use of private variable in void context at (eval 75364) line 1.
2016.07.25 16:29:35 1: PERL WARNING: Useless use of private variable in void context at (eval 76612) line 1.
2016.07.25 16:29:35 1: PERL WARNING: Useless use of private variable in void context at (eval 76613) line 1.
2016.07.25 16:30:35 1: PERL WARNING: Useless use of private variable in void context at (eval 77214) line 1.
2016.07.25 16:30:35 1: PERL WARNING: Useless use of private variable in void context at (eval 77215) line 1.
2016.07.25 16:32:55 3: FS20 set L_OG1_WZ_EN off
2016.07.25 16:33:07 3: FS20 set R_OG1_WZ on
2016.07.25 16:33:36 3: FS20 set R_OG1_WZ off
2016.07.25 16:33:45 3: FS20 set R_OG1_WZ off
2016.07.25 16:34:02 2: autocreate: define FileLog_THGR810_6 FileLog /media/hdd/fhem/log01/THGR810_6-%Y.log THGR810_6
2016.07.25 16:34:02 2: autocreate: define SVG_THGR810_6 SVG FileLog_THGR810_6:temp4hum4:CURRENT
2016.07.25 16:35:00 1: PERL WARNING: Useless use of private variable in void context at (eval 80001) line 1.
2016.07.25 16:36:06 1: PERL WARNING: Useless use of private variable in void context at (eval 80621) line 1.
2016.07.25 16:36:06 1: PERL WARNING: Useless use of private variable in void context at (eval 80622) line 1.
2016.07.25 16:36:40 2: autocreate: define FileLog_THGR810_6 FileLog /media/hdd/fhem/log01/THGR810_6-%Y.log THGR810_6
2016.07.25 16:36:40 2: autocreate: define SVG_THGR810_6 SVG FileLog_THGR810_6:temp4hum4:CURRENT
2016.07.25 16:39:06 1: PERL WARNING: Useless use of private variable in void context at (eval 82628) line 1.
2016.07.25 16:39:06 1: PERL WARNING: Useless use of private variable in void context at (eval 82629) line 1.
2016.07.25 16:40:06 1: PERL WARNING: Useless use of private variable in void context at (eval 83337) line 1.
2016.07.25 16:40:06 1: PERL WARNING: Useless use of private variable in void context at (eval 83338) line 1.
2016.07.25 16:41:19 2: autocreate: define FileLog_THWR800_3 FileLog /media/hdd/fhem/log01/THWR800_3-%Y.log THWR800_3
2016.07.25 16:41:21 1: PERL WARNING: Useless use of private variable in void context at (eval 84167) line 1.
2016.07.25 16:41:21 1: PERL WARNING: Useless use of private variable in void context at (eval 84168) line 1.
2016.07.25 16:42:37 1: sendEmail RCP: christian.schmidt@ccs-media.at
2016.07.25 16:42:37 1: sendEmail Subject: FHEM - Solaranlage R5 keine Strömung: R5A
2016.07.25 16:42:37 1: sendEmail Text:
2016.07.25 16:42:37 1: sendEmail Anhang:
2016.07.25 16:42:38 1: sendEmail returned: Reading message body from STDIN because the '-m' option was not used.If you are manually typing in a message:  - First line must be received within 60 seconds.  - End manual input with a CTRL-D on its own line.Jul 25 16:42:37 ccs-ht-rasp01 sendEmail[19502]: Message input complete.Jul 25 16:42:38 ccs-ht-rasp01 sendEmail[19502]: Email was sent successfully!
2016.07.25 16:43:15 1: PERL WARNING: Use of uninitialized value $model in string eq at ./FHEM/14_SD_AS.pm line 168.
2016.07.25 16:43:15 1: PERL WARNING: Use of uninitialized value $model in string eq at ./FHEM/14_SD_AS.pm line 171.
2016.07.25 16:43:15 1: PERL WARNING: Use of uninitialized value $model in string eq at ./FHEM/14_SD_AS.pm line 174.
2016.07.25 16:43:15 1: PERL WARNING: Use of uninitialized value $model in string eq at ./FHEM/14_SD_AS.pm line 179.
2016.07.25 16:43:15 1: PERL WARNING: Use of uninitialized value $model in string eq at ./FHEM/14_SD_AS.pm line 182.
2016.07.25 16:43:15 1: PERL WARNING: Use of uninitialized value $model in string eq at ./FHEM/14_SD_AS.pm line 185.
2016.07.25 16:43:15 1: PERL WARNING: Use of uninitialized value $model in string eq at ./FHEM/14_SD_AS.pm line 191.
2016.07.25 16:43:15 1: PERL WARNING: Use of uninitialized value $model in string eq at ./FHEM/14_SD_AS.pm line 196.
2016.07.25 16:43:15 1: PERL WARNING: Use of uninitialized value $model in concatenation (.) or string at ./FHEM/14_SD_AS.pm line 199.
2016.07.25 16:45:27 1: PERL WARNING: Useless use of private variable in void context at (eval 86661) line 1.
2016.07.25 16:45:27 1: PERL WARNING: Useless use of private variable in void context at (eval 86665) line 1.
2016.07.25 16:45:53 2: autocreate: define FileLog_THGR810_6 FileLog /media/hdd/fhem/log01/THGR810_6-%Y.log THGR810_6
2016.07.25 16:45:53 2: autocreate: define SVG_THGR810_6 SVG FileLog_THGR810_6:temp4hum4:CURRENT
2016.07.25 16:47:12 2: autocreate: define FileLog_THGR810_6 FileLog /media/hdd/fhem/log01/THGR810_6-%Y.log THGR810_6
2016.07.25 16:47:12 2: autocreate: define SVG_THGR810_6 SVG FileLog_THGR810_6:temp4hum4:CURRENT
2016.07.25 16:48:06 1: PERL WARNING: Useless use of private variable in void context at (eval 88288) line 1.
2016.07.25 16:48:06 1: PERL WARNING: Useless use of private variable in void context at (eval 88289) line 1.
2016.07.25 16:48:22 1: PERL WARNING: Useless use of private variable in void context at (eval 88473) line 1.
2016.07.25 16:48:22 1: PERL WARNING: Useless use of private variable in void context at (eval 88474) line 1.
2016.07.25 16:48:22 1: sendEmail RCP: christian.schmidt@ccs-media.at
2016.07.25 16:48:22 1: sendEmail Subject: FHEM - Solaranlage R5 keine Strömung: R5A
2016.07.25 16:48:22 1: sendEmail Text:
2016.07.25 16:48:22 1: sendEmail Anhang:
2016.07.25 16:48:23 1: sendEmail returned: Reading message body from STDIN because the '-m' option was not used.If you are manually typing in a message:  - First line must be received within 60 seconds.  - End manual input with a CTRL-D on its own line.Jul 25 16:48:22 ccs-ht-rasp01 sendEmail[19567]: Message input complete.Jul 25 16:48:23 ccs-ht-rasp01 sendEmail[19567]: Email was sent successfully!
2016.07.25 16:49:52 1: PERL WARNING: Useless use of private variable in void context at (eval 89328) line 1.
2016.07.25 16:49:52 1: PERL WARNING: Useless use of private variable in void context at (eval 89329) line 1.
2016.07.25 16:51:07 1: PERL WARNING: Useless use of private variable in void context at (eval 90098) line 1.
2016.07.25 16:51:07 1: PERL WARNING: Useless use of private variable in void context at (eval 90099) line 1.
2016.07.25 16:51:22 1: PERL WARNING: Useless use of private variable in void context at (eval 90311) line 1.
2016.07.25 16:51:22 1: PERL WARNING: Useless use of private variable in void context at (eval 90312) line 1.
2016.07.25 16:54:52 1: PERL WARNING: Useless use of private variable in void context at (eval 92328) line 1.
2016.07.25 16:54:52 1: PERL WARNING: Useless use of private variable in void context at (eval 92329) line 1.
2016.07.25 16:55:05 2: autocreate: define FileLog_WGR800 FileLog /media/hdd/fhem/log01/WGR800-%Y.log WGR800
2016.07.25 16:55:05 2: autocreate: define SVG_WGR800 SVG FileLog_WGR800:wind4windDir4:CURRENT
2016.07.25 16:55:07 1: PERL WARNING: Useless use of private variable in void context at (eval 92500) line 1.
2016.07.25 16:55:07 1: PERL WARNING: Useless use of private variable in void context at (eval 92501) line 1.
2016.07.25 16:55:22 1: PERL WARNING: Useless use of private variable in void context at (eval 92680) line 1.
2016.07.25 16:55:22 1: PERL WARNING: Useless use of private variable in void context at (eval 92681) line 1.
2016.07.25 16:55:33 2: autocreate: define FileLog_THWR800_3 FileLog /media/hdd/fhem/log01/THWR800_3-%Y.log THWR800_3
2016.07.25 16:55:37 1: PERL WARNING: Useless use of private variable in void context at (eval 92852) line 1.
2016.07.25 16:55:37 1: PERL WARNING: Useless use of private variable in void context at (eval 92853) line 1.
2016.07.25 16:56:25 2: autocreate: define FileLog_THGR810_6 FileLog /media/hdd/fhem/log01/THGR810_6-%Y.log THGR810_6
2016.07.25 16:56:25 2: autocreate: define SVG_THGR810_6 SVG FileLog_THGR810_6:temp4hum4:CURRENT
2016.07.25 16:57:20 2: autocreate: define FileLog_THGR810_2 FileLog /media/hdd/fhem/log01/THGR810_2-%Y.log THGR810_2
2016.07.25 16:57:20 2: autocreate: define SVG_THGR810_2 SVG FileLog_THGR810_2:temp4hum4:CURRENT
2016.07.25 16:57:44 2: autocreate: define FileLog_THGR810_6 FileLog /media/hdd/fhem/log01/THGR810_6-%Y.log THGR810_6
2016.07.25 16:57:44 2: autocreate: define SVG_THGR810_6 SVG FileLog_THGR810_6:temp4hum4:CURRENT
2016.07.25 16:58:22 1: PERL WARNING: Useless use of private variable in void context at (eval 94766) line 1.
2016.07.25 16:58:22 1: PERL WARNING: Useless use of private variable in void context at (eval 94767) line 1.
2016.07.25 16:58:38 1: PERL WARNING: Useless use of private variable in void context at (eval 94959) line 1.
2016.07.25 16:58:38 1: PERL WARNING: Useless use of private variable in void context at (eval 94960) line 1.
2016.07.25 16:58:41 3: R_EG_WZ AUF->on
2016.07.25 16:59:02 3: R_EG_KUE AUF->on
2016.07.25 16:59:03 3: R_EG_KUE_TER AUF->on
2016.07.25 16:59:03 3: R_EG_WI AUF->on
2016.07.25 16:59:15 3: R_EG_KUE_TER AUF->on
2016.07.25 16:59:27 3: R_EG_WZ AUF->on
2016.07.25 16:59:27 3: R_EG_KUE AUF->on
2016.07.25 16:59:28 3: R_EG_KUE_TER AUF->on
2016.07.25 16:59:28 3: R_EG_WI AUF->on
2016.07.25 16:59:44 2: autocreate: define TRX_ARC_A14 TRX_LIGHT ARC A14 light
2016.07.25 16:59:44 2: autocreate: define FileLog_TRX_ARC_A14 FileLog /media/hdd/fhem/log01/TRX_ARC_A14-%Y.log TRX_ARC_A14
2016.07.25 16:59:44 2: autocreate: define IT_0000F0FF0F IT 0000F0FF0F FF F0
2016.07.25 16:59:45 2: autocreate: define FileLog_IT_0000F0FF0F FileLog /media/hdd/fhem/log01/IT_0000F0FF0F-%Y.log IT_0000F0FF0F
2016.07.25 16:59:45 3: IT_0000F0FF0F ???->on
2016.07.25 16:59:45 2: autocreate: define TRX_ARC_A13 TRX_LIGHT ARC A13 light
2016.07.25 16:59:46 2: autocreate: define FileLog_TRX_ARC_A13 FileLog /media/hdd/fhem/log01/TRX_ARC_A13-%Y.log TRX_ARC_A13
2016.07.25 16:59:46 2: autocreate: define IT_000000FF0F IT 000000FF0F FF F0
2016.07.25 16:59:46 2: autocreate: define FileLog_IT_000000FF0F FileLog /media/hdd/fhem/log01/IT_000000FF0F-%Y.log IT_000000FF0F
2016.07.25 16:59:47 3: IT_0000F0FF0F on->on
2016.07.25 16:59:47 2: autocreate: define IT_00000FFF0F IT 00000FFF0F FF F0
2016.07.25 16:59:47 2: autocreate: define FileLog_IT_00000FFF0F FileLog /media/hdd/fhem/log01/IT_00000FFF0F-%Y.log IT_00000FFF0F
2016.07.25 16:59:48 2: autocreate: define TRX_ARC_A16 TRX_LIGHT ARC A16 light
2016.07.25 16:59:48 2: autocreate: define FileLog_TRX_ARC_A16 FileLog /media/hdd/fhem/log01/TRX_ARC_A16-%Y.log TRX_ARC_A16
2016.07.25 16:59:48 2: autocreate: define TRX_ARC_A15 TRX_LIGHT ARC A15 light
2016.07.25 16:59:48 2: autocreate: define FileLog_TRX_ARC_A15 FileLog /media/hdd/fhem/log01/TRX_ARC_A15-%Y.log TRX_ARC_A15
2016.07.25 16:59:49 2: autocreate: define IT_0000FFFF0F IT 0000FFFF0F FF F0
2016.07.25 16:59:49 2: autocreate: define FileLog_IT_0000FFFF0F FileLog /media/hdd/fhem/log01/IT_0000FFFF0F-%Y.log IT_0000FFFF0F
2016.07.25 16:59:50 3: IT_000000FF0F ???->on
2016.07.25 16:59:50 3: IT_0000F0FF0F on->on
2016.07.25 16:59:50 3: IT_00000FFF0F ???->on
2016.07.25 16:59:50 3: IT_0000FFFF0F ???->on
2016.07.25 16:59:54 3: IT_000000FF0F on->off
2016.07.25 17:00:23 2: autocreate: define FileLog_THGR810_1 FileLog /media/hdd/fhem/log01/THGR810_1-%Y.log THGR810_1
2016.07.25 17:00:23 2: autocreate: define SVG_THGR810_1 SVG FileLog_THGR810_1:temp4hum4:CURRENT
2016.07.25 17:01:23 1: PERL WARNING: Useless use of private variable in void context at (eval 96599) line 1.
2016.07.25 17:01:23 1: PERL WARNING: Useless use of private variable in void context at (eval 96600) line 1.
2016.07.25 17:01:23 1: sendEmail RCP: christian.schmidt@ccs-media.at
2016.07.25 17:01:23 1: sendEmail Subject: FHEM - Solaranlage R5 keine Strömung: R5A
2016.07.25 17:01:23 1: sendEmail Text:
2016.07.25 17:01:23 1: sendEmail Anhang:
2016.07.25 17:01:24 1: sendEmail returned: Reading message body from STDIN because the '-m' option was not used.If you are manually typing in a message:  - First line must be received within 60 seconds.  - End manual input with a CTRL-D on its own line.Jul 25 17:01:23 ccs-ht-rasp01 sendEmail[19684]: Message input complete.Jul 25 17:01:24 ccs-ht-rasp01 sendEmail[19684]: Email was sent successfully!
2016.07.25 17:01:38 1: PERL WARNING: Useless use of private variable in void context at (eval 96760) line 1.
2016.07.25 17:01:38 1: PERL WARNING: Useless use of private variable in void context at (eval 96761) line 1.
2016.07.25 17:01:53 1: PERL WARNING: Useless use of private variable in void context at (eval 96960) line 1.
2016.07.25 17:01:53 1: PERL WARNING: Useless use of private variable in void context at (eval 96961) line 1.
2016.07.25 17:02:07 1: PERL WARNING: Useless use of private variable in void context at (eval 97082) line 1.
2016.07.25 17:02:07 1: PERL WARNING: Useless use of private variable in void context at (eval 97083) line 1.
2016.07.25 17:02:46 3: FS20 set Freigabe_OG1_GS off
2016.07.25 17:05:45 1: PERL WARNING: Useless use of private variable in void context at (eval 99432) line 1.
2016.07.25 17:05:45 1: PERL WARNING: Useless use of private variable in void context at (eval 99436) line 1.
2016.07.25 17:06:11 2: autocreate: define FileLog_THGR810_2 FileLog /media/hdd/fhem/log01/THGR810_2-%Y.log THGR810_2
2016.07.25 17:06:11 2: autocreate: define SVG_THGR810_2 SVG FileLog_THGR810_2:temp4hum4:CURRENT
2016.07.25 17:06:38 1: PERL WARNING: Useless use of private variable in void context at (eval 99986) line 1.
2016.07.25 17:06:38 1: PERL WARNING: Useless use of private variable in void context at (eval 99987) line 1.
2016.07.25 17:06:57 2: autocreate: define FileLog_THGR810_6 FileLog /media/hdd/fhem/log01/THGR810_6-%Y.log THGR810_6
2016.07.25 17:06:57 2: autocreate: define SVG_THGR810_6 SVG FileLog_THGR810_6:temp4hum4:CURRENT
2016.07.25 17:07:27 2: autocreate: define FileLog_WGR800 FileLog /media/hdd/fhem/log01/WGR800-%Y.log WGR800
2016.07.25 17:07:27 2: autocreate: define SVG_WGR800 SVG FileLog_WGR800:wind4windDir4:CURRENT
2016.07.25 17:08:16 2: autocreate: define FileLog_THGR810_6 FileLog /media/hdd/fhem/log01/THGR810_6-%Y.log THGR810_6
2016.07.25 17:08:16 2: autocreate: define SVG_THGR810_6 SVG FileLog_THGR810_6:temp4hum4:CURRENT
2016.07.25 17:08:38 1: PERL WARNING: Useless use of private variable in void context at (eval 101129) line 1.
2016.07.25 17:08:38 1: PERL WARNING: Useless use of private variable in void context at (eval 101130) line 1.
2016.07.25 17:08:53 1: PERL WARNING: Useless use of private variable in void context at (eval 101325) line 1.
2016.07.25 17:08:53 1: PERL WARNING: Useless use of private variable in void context at (eval 101326) line 1.
2016.07.25 17:10:53 1: PERL WARNING: Useless use of private variable in void context at (eval 102438) line 1.
2016.07.25 17:10:53 1: PERL WARNING: Useless use of private variable in void context at (eval 102439) line 1.
2016.07.25 17:11:08 1: PERL WARNING: Useless use of private variable in void context at (eval 102594) line 1.
2016.07.25 17:11:08 1: PERL WARNING: Useless use of private variable in void context at (eval 102595) line 1.
2016.07.25 17:11:39 2: autocreate: define FileLog_PCR800 FileLog /media/hdd/fhem/log01/PCR800-%Y.log PCR800
2016.07.25 17:11:39 2: autocreate: define SVG_PCR800 SVG FileLog_PCR800:rain4:CURRENT
2016.07.25 17:14:03 2: autocreate: define FileLog_THGR810_2 FileLog /media/hdd/fhem/log01/THGR810_2-%Y.log THGR810_2
2016.07.25 17:14:03 2: autocreate: define SVG_THGR810_2 SVG FileLog_THGR810_2:temp4hum4:CURRENT
2016.07.25 17:17:23 1: PERL WARNING: Useless use of private variable in void context at (eval 106029) line 1.
2016.07.25 17:17:23 1: PERL WARNING: Useless use of private variable in void context at (eval 106030) line 1.
2016.07.25 17:20:08 1: PERL WARNING: Useless use of private variable in void context at (eval 107445) line 1.
2016.07.25 17:20:08 1: PERL WARNING: Useless use of private variable in void context at (eval 107446) line 1.
2016.07.25 17:21:49 1: PERL WARNING: Use of uninitialized value $newstate in concatenation (.) or string at ./FHEM/98_Dooya.pm line 320.
2016.07.25 17:22:38 1: PERL WARNING: Useless use of private variable in void context at (eval 108707) line 1.
2016.07.25 17:22:38 1: PERL WARNING: Useless use of private variable in void context at (eval 108708) line 1.
2016.07.25 17:23:08 1: PERL WARNING: Useless use of private variable in void context at (eval 108982) line 1.
2016.07.25 17:23:08 1: PERL WARNING: Useless use of private variable in void context at (eval 108983) line 1.
2016.07.25 17:24:23 1: PERL WARNING: Useless use of private variable in void context at (eval 109732) line 1.
2016.07.25 17:24:23 1: PERL WARNING: Useless use of private variable in void context at (eval 109733) line 1.
2016.07.25 17:25:48 1: PERL WARNING: Useless use of private variable in void context at (eval 110377) line 1.
2016.07.25 17:25:49 1: PERL WARNING: Useless use of private variable in void context at (eval 110383) line 1.
2016.07.25 17:26:03 2: autocreate: define FileLog_THWR800_3 FileLog /media/hdd/fhem/log01/THWR800_3-%Y.log THWR800_3
2016.07.25 17:26:53 1: PERL WARNING: Useless use of private variable in void context at (eval 110985) line 1.
2016.07.25 17:26:53 1: PERL WARNING: Useless use of private variable in void context at (eval 110986) line 1.
2016.07.25 17:27:11 1: PERL WARNING: Useless use of private variable in void context at (eval 111134) line 1.
2016.07.25 17:27:11 1: PERL WARNING: Useless use of private variable in void context at (eval 111135) line 1.
2016.07.25 17:27:12 1: PERL WARNING: Useless use of private variable in void context at (eval 111179) line 1.
2016.07.25 17:27:12 1: PERL WARNING: Useless use of private variable in void context at (eval 111180) line 1.
2016.07.25 17:27:41 1: PERL WARNING: Useless use of private variable in void context at (eval 111448) line 1.
2016.07.25 17:27:41 1: PERL WARNING: Useless use of private variable in void context at (eval 111449) line 1.
2016.07.25 17:27:42 1: PERL WARNING: Useless use of private variable in void context at (eval 111519) line 1.
2016.07.25 17:27:42 1: PERL WARNING: Useless use of private variable in void context at (eval 111520) line 1.
2016.07.25 17:27:45 2: autocreate: define FileLog_THGR810_1 FileLog /media/hdd/fhem/log01/THGR810_1-%Y.log THGR810_1
2016.07.25 17:27:45 2: autocreate: define SVG_THGR810_1 SVG FileLog_THGR810_1:temp4hum4:CURRENT
2016.07.25 17:28:05 1: PERL WARNING: Useless use of private variable in void context at (eval 111791) line 1.
2016.07.25 17:28:05 1: PERL WARNING: Useless use of private variable in void context at (eval 111792) line 1.
2016.07.25 17:28:06 1: PERL WARNING: Useless use of private variable in void context at (eval 111862) line 1.
2016.07.25 17:28:06 1: PERL WARNING: Useless use of private variable in void context at (eval 111863) line 1.
2016.07.25 17:28:23 1: PERL WARNING: Useless use of private variable in void context at (eval 112090) line 1.
2016.07.25 17:28:23 1: PERL WARNING: Useless use of private variable in void context at (eval 112091) line 1.
2016.07.25 17:28:29 1: PERL WARNING: Useless use of private variable in void context at (eval 112155) line 1.
2016.07.25 17:28:29 1: PERL WARNING: Useless use of private variable in void context at (eval 112156) line 1.
2016.07.25 17:28:30 1: PERL WARNING: Useless use of private variable in void context at (eval 112226) line 1.
2016.07.25 17:28:30 1: PERL WARNING: Useless use of private variable in void context at (eval 112227) line 1.
2016.07.25 17:28:53 1: PERL WARNING: Useless use of private variable in void context at (eval 112500) line 1.
2016.07.25 17:28:53 1: PERL WARNING: Useless use of private variable in void context at (eval 112501) line 1.
2016.07.25 17:28:54 1: PERL WARNING: Useless use of private variable in void context at (eval 112571) line 1.
2016.07.25 17:28:54 1: PERL WARNING: Useless use of private variable in void context at (eval 112572) line 1.
2016.07.25 17:29:08 1: PERL WARNING: Useless use of private variable in void context at (eval 112715) line 1.
2016.07.25 17:29:08 1: PERL WARNING: Useless use of private variable in void context at (eval 112716) line 1.
2016.07.25 17:29:17 1: PERL WARNING: Useless use of private variable in void context at (eval 112790) line 1.
2016.07.25 17:29:17 1: PERL WARNING: Useless use of private variable in void context at (eval 112791) line 1.
2016.07.25 17:29:18 1: PERL WARNING: Useless use of private variable in void context at (eval 112861) line 1.
2016.07.25 17:29:18 1: PERL WARNING: Useless use of private variable in void context at (eval 112862) line 1.
2016.07.25 17:29:23 1: PERL WARNING: Useless use of private variable in void context at (eval 113022) line 1.
2016.07.25 17:29:23 1: PERL WARNING: Useless use of private variable in void context at (eval 113023) line 1.
2016.07.25 17:29:41 1: PERL WARNING: Useless use of private variable in void context at (eval 113165) line 1.
2016.07.25 17:29:41 1: PERL WARNING: Useless use of private variable in void context at (eval 113166) line 1.
2016.07.25 17:29:42 1: PERL WARNING: Useless use of private variable in void context at (eval 113236) line 1.
2016.07.25 17:29:42 1: PERL WARNING: Useless use of private variable in void context at (eval 113237) line 1.
2016.07.25 17:30:05 1: PERL WARNING: Useless use of private variable in void context at (eval 113498) line 1.
2016.07.25 17:30:05 1: PERL WARNING: Useless use of private variable in void context at (eval 113499) line 1.
2016.07.25 17:30:06 1: PERL WARNING: Useless use of private variable in void context at (eval 113569) line 1.
2016.07.25 17:30:06 1: PERL WARNING: Useless use of private variable in void context at (eval 113570) line 1.
2016.07.25 17:30:29 1: PERL WARNING: Useless use of private variable in void context at (eval 113803) line 1.
2016.07.25 17:30:29 1: PERL WARNING: Useless use of private variable in void context at (eval 113804) line 1.
2016.07.25 17:30:30 1: PERL WARNING: Useless use of private variable in void context at (eval 113874) line 1.
2016.07.25 17:30:30 1: PERL WARNING: Useless use of private variable in void context at (eval 113875) line 1.
2016.07.25 17:30:53 1: PERL WARNING: Useless use of private variable in void context at (eval 114105) line 1.
2016.07.25 17:30:53 1: PERL WARNING: Useless use of private variable in void context at (eval 114106) line 1.
2016.07.25 17:30:54 1: PERL WARNING: Useless use of private variable in void context at (eval 114176) line 1.
2016.07.25 17:30:54 1: PERL WARNING: Useless use of private variable in void context at (eval 114177) line 1.
2016.07.25 17:31:17 1: PERL WARNING: Useless use of private variable in void context at (eval 114400) line 1.
2016.07.25 17:31:17 1: PERL WARNING: Useless use of private variable in void context at (eval 114401) line 1.
2016.07.25 17:31:18 1: PERL WARNING: Useless use of private variable in void context at (eval 114471) line 1.
2016.07.25 17:31:18 1: PERL WARNING: Useless use of private variable in void context at (eval 114472) line 1.
2016.07.25 17:31:41 1: PERL WARNING: Useless use of private variable in void context at (eval 114784) line 1.
2016.07.25 17:31:41 1: PERL WARNING: Useless use of private variable in void context at (eval 114785) line 1.
2016.07.25 17:31:42 1: PERL WARNING: Useless use of private variable in void context at (eval 114855) line 1.
2016.07.25 17:31:42 1: PERL WARNING: Useless use of private variable in void context at (eval 114856) line 1.
2016.07.25 17:32:05 1: PERL WARNING: Useless use of private variable in void context at (eval 115130) line 1.
2016.07.25 17:32:05 1: PERL WARNING: Useless use of private variable in void context at (eval 115131) line 1.
2016.07.25 17:32:06 1: PERL WARNING: Useless use of private variable in void context at (eval 115201) line 1.
2016.07.25 17:32:06 1: PERL WARNING: Useless use of private variable in void context at (eval 115202) line 1.
2016.07.25 17:32:24 1: PERL WARNING: Useless use of private variable in void context at (eval 115433) line 1.
2016.07.25 17:32:24 1: PERL WARNING: Useless use of private variable in void context at (eval 115434) line 1.
2016.07.25 17:32:29 1: PERL WARNING: Useless use of private variable in void context at (eval 115495) line 1.
2016.07.25 17:32:29 1: PERL WARNING: Useless use of private variable in void context at (eval 115496) line 1.
2016.07.25 17:32:30 1: PERL WARNING: Useless use of private variable in void context at (eval 115566) line 1.
2016.07.25 17:32:30 1: PERL WARNING: Useless use of private variable in void context at (eval 115567) line 1.
2016.07.25 17:32:39 1: PERL WARNING: Useless use of private variable in void context at (eval 115708) line 1.
2016.07.25 17:32:39 1: PERL WARNING: Useless use of private variable in void context at (eval 115709) line 1.
2016.07.25 17:32:53 1: PERL WARNING: Useless use of private variable in void context at (eval 115888) line 1.
2016.07.25 17:32:53 1: PERL WARNING: Useless use of private variable in void context at (eval 115889) line 1.
2016.07.25 17:32:54 1: PERL WARNING: Useless use of private variable in void context at (eval 115960) line 1.
2016.07.25 17:32:54 1: PERL WARNING: Useless use of private variable in void context at (eval 115961) line 1.
2016.07.25 17:33:17 1: PERL WARNING: Useless use of private variable in void context at (eval 116160) line 1.
2016.07.25 17:33:17 1: PERL WARNING: Useless use of private variable in void context at (eval 116161) line 1.
2016.07.25 17:33:18 1: PERL WARNING: Useless use of private variable in void context at (eval 116231) line 1.
2016.07.25 17:33:18 1: PERL WARNING: Useless use of private variable in void context at (eval 116232) line 1.
2016.07.25 17:33:39 1: PERL WARNING: Useless use of private variable in void context at (eval 116475) line 1.
2016.07.25 17:33:39 1: PERL WARNING: Useless use of private variable in void context at (eval 116476) line 1.
2016.07.25 17:33:41 1: PERL WARNING: Useless use of private variable in void context at (eval 116526) line 1.
2016.07.25 17:33:41 1: PERL WARNING: Useless use of private variable in void context at (eval 116527) line 1.
2016.07.25 17:33:42 1: PERL WARNING: Useless use of private variable in void context at (eval 116597) line 1.
2016.07.25 17:33:42 1: PERL WARNING: Useless use of private variable in void context at (eval 116598) line 1.
2016.07.25 17:34:05 1: PERL WARNING: Useless use of private variable in void context at (eval 116879) line 1.
2016.07.25 17:34:05 1: PERL WARNING: Useless use of private variable in void context at (eval 116880) line 1.
2016.07.25 17:34:06 1: PERL WARNING: Useless use of private variable in void context at (eval 116950) line 1.
2016.07.25 17:34:06 1: PERL WARNING: Useless use of private variable in void context at (eval 116951) line 1.
2016.07.25 17:34:29 1: PERL WARNING: Useless use of private variable in void context at (eval 117179) line 1.
2016.07.25 17:34:29 1: PERL WARNING: Useless use of private variable in void context at (eval 117180) line 1.
2016.07.25 17:34:30 1: PERL WARNING: Useless use of private variable in void context at (eval 117250) line 1.
2016.07.25 17:34:30 1: PERL WARNING: Useless use of private variable in void context at (eval 117251) line 1.
2016.07.25 17:34:53 1: PERL WARNING: Useless use of private variable in void context at (eval 117534) line 1.
2016.07.25 17:34:53 1: PERL WARNING: Useless use of private variable in void context at (eval 117535) line 1.
2016.07.25 17:34:54 1: PERL WARNING: Useless use of private variable in void context at (eval 117605) line 1.
2016.07.25 17:34:54 1: PERL WARNING: Useless use of private variable in void context at (eval 117606) line 1.
2016.07.25 17:35:17 1: PERL WARNING: Useless use of private variable in void context at (eval 117815) line 1.
2016.07.25 17:35:17 1: PERL WARNING: Useless use of private variable in void context at (eval 117816) line 1.
2016.07.25 17:35:18 1: PERL WARNING: Useless use of private variable in void context at (eval 117886) line 1.
2016.07.25 17:35:18 1: PERL WARNING: Useless use of private variable in void context at (eval 117887) line 1.
2016.07.25 17:35:41 1: PERL WARNING: Useless use of private variable in void context at (eval 118174) line 1.
2016.07.25 17:35:41 1: PERL WARNING: Useless use of private variable in void context at (eval 118175) line 1.
2016.07.25 17:35:42 1: PERL WARNING: Useless use of private variable in void context at (eval 118245) line 1.
2016.07.25 17:35:42 1: PERL WARNING: Useless use of private variable in void context at (eval 118246) line 1.
2016.07.25 17:36:05 1: PERL WARNING: Useless use of private variable in void context at (eval 118541) line 1.
2016.07.25 17:36:05 1: PERL WARNING: Useless use of private variable in void context at (eval 118542) line 1.
2016.07.25 17:36:06 1: PERL WARNING: Useless use of private variable in void context at (eval 118612) line 1.
2016.07.25 17:36:06 1: PERL WARNING: Useless use of private variable in void context at (eval 118613) line 1.
2016.07.25 17:36:29 1: PERL WARNING: Useless use of private variable in void context at (eval 118847) line 1.
2016.07.25 17:36:29 1: PERL WARNING: Useless use of private variable in void context at (eval 118848) line 1.
2016.07.25 17:36:30 1: PERL WARNING: Useless use of private variable in void context at (eval 118918) line 1.
2016.07.25 17:36:30 1: PERL WARNING: Useless use of private variable in void context at (eval 118919) line 1.
2016.07.25 17:36:53 1: PERL WARNING: Useless use of private variable in void context at (eval 119195) line 1.
2016.07.25 17:36:53 1: PERL WARNING: Useless use of private variable in void context at (eval 119196) line 1.
2016.07.25 17:36:54 1: PERL WARNING: Useless use of private variable in void context at (eval 119266) line 1.
2016.07.25 17:36:54 1: PERL WARNING: Useless use of private variable in void context at (eval 119267) line 1.
2016.07.25 17:37:11 1: PERL WARNING: Useless use of private variable in void context at (eval 119439) line 1.
2016.07.25 17:37:11 1: PERL WARNING: Useless use of private variable in void context at (eval 119440) line 1.
2016.07.25 17:37:17 1: PERL WARNING: Useless use of private variable in void context at (eval 119505) line 1.
2016.07.25 17:37:17 1: PERL WARNING: Useless use of private variable in void context at (eval 119506) line 1.
2016.07.25 17:37:18 1: PERL WARNING: Useless use of private variable in void context at (eval 119576) line 1.
2016.07.25 17:37:18 1: PERL WARNING: Useless use of private variable in void context at (eval 119577) line 1.
2016.07.25 17:37:41 1: PERL WARNING: Useless use of private variable in void context at (eval 119865) line 1.
2016.07.25 17:37:41 1: PERL WARNING: Useless use of private variable in void context at (eval 119866) line 1.
2016.07.25 17:37:42 1: PERL WARNING: Useless use of private variable in void context at (eval 119936) line 1.
2016.07.25 17:37:42 1: PERL WARNING: Useless use of private variable in void context at (eval 119937) line 1.
2016.07.25 17:38:05 1: PERL WARNING: Useless use of private variable in void context at (eval 120212) line 1.
2016.07.25 17:38:05 1: PERL WARNING: Useless use of private variable in void context at (eval 120213) line 1.
2016.07.25 17:38:06 1: PERL WARNING: Useless use of private variable in void context at (eval 120283) line 1.
2016.07.25 17:38:06 1: PERL WARNING: Useless use of private variable in void context at (eval 120284) line 1.
2016.07.25 17:38:29 1: PERL WARNING: Useless use of private variable in void context at (eval 120515) line 1.
2016.07.25 17:38:29 1: PERL WARNING: Useless use of private variable in void context at (eval 120516) line 1.
2016.07.25 17:38:30 1: PERL WARNING: Useless use of private variable in void context at (eval 120586) line 1.
2016.07.25 17:38:30 1: PERL WARNING: Useless use of private variable in void context at (eval 120587) line 1.
2016.07.25 17:38:33 2: autocreate: define FileLog_THGR810_6 FileLog /media/hdd/fhem/log01/THGR810_6-%Y.log THGR810_6
2016.07.25 17:38:33 2: autocreate: define SVG_THGR810_6 SVG FileLog_THGR810_6:temp4hum4:CURRENT
2016.07.25 17:38:53 1: PERL WARNING: Useless use of private variable in void context at (eval 120771) line 1.
2016.07.25 17:38:53 1: PERL WARNING: Useless use of private variable in void context at (eval 120772) line 1.
2016.07.25 17:38:54 1: PERL WARNING: Useless use of private variable in void context at (eval 120842) line 1.
2016.07.25 17:38:54 1: PERL WARNING: Useless use of private variable in void context at (eval 120843) line 1.
2016.07.25 17:39:17 1: PERL WARNING: Useless use of private variable in void context at (eval 121116) line 1.
2016.07.25 17:39:17 1: PERL WARNING: Useless use of private variable in void context at (eval 121117) line 1.
2016.07.25 17:39:18 1: PERL WARNING: Useless use of private variable in void context at (eval 121187) line 1.
2016.07.25 17:39:18 1: PERL WARNING: Useless use of private variable in void context at (eval 121188) line 1.
2016.07.25 17:39:41 1: PERL WARNING: Useless use of private variable in void context at (eval 121452) line 1.
2016.07.25 17:39:41 1: PERL WARNING: Useless use of private variable in void context at (eval 121453) line 1.
2016.07.25 17:39:42 1: PERL WARNING: Useless use of private variable in void context at (eval 121523) line 1.
2016.07.25 17:39:42 1: PERL WARNING: Useless use of private variable in void context at (eval 121524) line 1.
2016.07.25 17:39:53 2: IT set R_OG1_BA on
2016.07.25 17:39:54 2: IT set R_OG1_SL on
2016.07.25 17:39:54 3: FS20 set R_OG1_WZ on
2016.07.25 17:39:55 3: FS20 set R_OG2_BUE_NO on
2016.07.25 17:40:05 1: PERL WARNING: Useless use of private variable in void context at (eval 121766) line 1.
2016.07.25 17:40:05 1: PERL WARNING: Useless use of private variable in void context at (eval 121767) line 1.
2016.07.25 17:40:06 1: PERL WARNING: Useless use of private variable in void context at (eval 121836) line 1.
2016.07.25 17:40:06 1: PERL WARNING: Useless use of private variable in void context at (eval 121837) line 1.
2016.07.25 17:40:11 1: PERL WARNING: Useless use of private variable in void context at (eval 121978) line 1.
2016.07.25 17:40:11 1: PERL WARNING: Useless use of private variable in void context at (eval 121979) line 1.
2016.07.25 17:40:29 1: PERL WARNING: Useless use of private variable in void context at (eval 122151) line 1.
2016.07.25 17:40:29 1: PERL WARNING: Useless use of private variable in void context at (eval 122152) line 1.
2016.07.25 17:40:30 1: PERL WARNING: Useless use of private variable in void context at (eval 122221) line 1.
2016.07.25 17:40:30 1: PERL WARNING: Useless use of private variable in void context at (eval 122222) line 1.
2016.07.25 17:40:31 3: FS20 set Freigabe_OG1_WS off
2016.07.25 17:40:53 1: PERL WARNING: Useless use of private variable in void context at (eval 122473) line 1.
2016.07.25 17:40:53 1: PERL WARNING: Useless use of private variable in void context at (eval 122474) line 1.
2016.07.25 17:40:54 1: PERL WARNING: Useless use of private variable in void context at (eval 122543) line 1.
2016.07.25 17:40:54 1: PERL WARNING: Useless use of private variable in void context at (eval 122544) line 1.
2016.07.25 17:41:02 3: IT_11011001 Unknown, Please learn codes!->Unknown, Please learn codes!
2016.07.25 17:41:02 3: IT_F00F000F0F on->off
2016.07.25 17:41:03 3: IT_11000111100011110001111000101101100110011011001001011 on->off
2016.07.25 17:41:04 3: IT_F00F000F0F off->on
2016.07.25 17:41:05 3: IT_11000111100011110001111000101101100110011011001001011 off->on
2016.07.25 17:41:11 2: autocreate: define FileLog_THGR810_6 FileLog /media/hdd/fhem/log01/THGR810_6-%Y.log THGR810_6
2016.07.25 17:41:11 2: autocreate: define SVG_THGR810_6 SVG FileLog_THGR810_6:temp4hum4:CURRENT
2016.07.25 17:41:17 1: PERL WARNING: Useless use of private variable in void context at (eval 122741) line 1.
2016.07.25 17:41:17 1: PERL WARNING: Useless use of private variable in void context at (eval 122742) line 1.
2016.07.25 17:41:18 1: PERL WARNING: Useless use of private variable in void context at (eval 122811) line 1.
2016.07.25 17:41:18 1: PERL WARNING: Useless use of private variable in void context at (eval 122812) line 1.
2016.07.25 17:41:41 1: PERL WARNING: Useless use of private variable in void context at (eval 123070) line 1.
2016.07.25 17:41:41 1: PERL WARNING: Useless use of private variable in void context at (eval 123071) line 1.
2016.07.25 17:41:42 1: PERL WARNING: Useless use of private variable in void context at (eval 123140) line 1.
2016.07.25 17:41:42 1: PERL WARNING: Useless use of private variable in void context at (eval 123141) line 1.
2016.07.25 17:42:05 1: PERL WARNING: Useless use of private variable in void context at (eval 123446) line 1.
2016.07.25 17:42:05 1: PERL WARNING: Useless use of private variable in void context at (eval 123447) line 1.
2016.07.25 17:42:06 1: PERL WARNING: Useless use of private variable in void context at (eval 123516) line 1.
2016.07.25 17:42:06 1: PERL WARNING: Useless use of private variable in void context at (eval 123517) line 1.
2016.07.25 17:42:29 1: PERL WARNING: Useless use of private variable in void context at (eval 123759) line 1.
2016.07.25 17:42:29 1: PERL WARNING: Useless use of private variable in void context at (eval 123760) line 1.
2016.07.25 17:42:30 1: PERL WARNING: Useless use of private variable in void context at (eval 123829) line 1.
2016.07.25 17:42:30 1: PERL WARNING: Useless use of private variable in void context at (eval 123830) line 1.
2016.07.25 17:42:53 1: PERL WARNING: Useless use of private variable in void context at (eval 124070) line 1.
2016.07.25 17:42:53 1: PERL WARNING: Useless use of private variable in void context at (eval 124071) line 1.
2016.07.25 17:42:54 1: PERL WARNING: Useless use of private variable in void context at (eval 124140) line 1.
2016.07.25 17:42:54 1: PERL WARNING: Useless use of private variable in void context at (eval 124141) line 1.
2016.07.25 17:43:17 1: PERL WARNING: Useless use of private variable in void context at (eval 124362) line 1.
2016.07.25 17:43:17 1: PERL WARNING: Useless use of private variable in void context at (eval 124363) line 1.
2016.07.25 17:43:18 1: PERL WARNING: Useless use of private variable in void context at (eval 124432) line 1.
2016.07.25 17:43:18 1: PERL WARNING: Useless use of private variable in void context at (eval 124433) line 1.
2016.07.25 17:43:41 1: PERL WARNING: Useless use of private variable in void context at (eval 124707) line 1.
2016.07.25 17:43:41 1: PERL WARNING: Useless use of private variable in void context at (eval 124708) line 1.
2016.07.25 17:43:42 1: PERL WARNING: Useless use of private variable in void context at (eval 124777) line 1.
2016.07.25 17:43:42 1: PERL WARNING: Useless use of private variable in void context at (eval 124778) line 1.
2016.07.25 17:43:56 1: PERL WARNING: Useless use of private variable in void context at (eval 124952) line 1.
2016.07.25 17:43:56 1: PERL WARNING: Useless use of private variable in void context at (eval 124953) line 1.
2016.07.25 17:44:05 1: PERL WARNING: Useless use of private variable in void context at (eval 125072) line 1.
2016.07.25 17:44:05 1: PERL WARNING: Useless use of private variable in void context at (eval 125073) line 1.
2016.07.25 17:44:06 1: PERL WARNING: Useless use of private variable in void context at (eval 125142) line 1.
2016.07.25 17:44:06 1: PERL WARNING: Useless use of private variable in void context at (eval 125143) line 1.
2016.07.25 17:44:26 1: PERL WARNING: Useless use of private variable in void context at (eval 125346) line 1.
2016.07.25 17:44:26 1: PERL WARNING: Useless use of private variable in void context at (eval 125347) line 1.
2016.07.25 17:44:29 1: PERL WARNING: Useless use of private variable in void context at (eval 125401) line 1.
2016.07.25 17:44:29 1: PERL WARNING: Useless use of private variable in void context at (eval 125402) line 1.
2016.07.25 17:44:30 1: PERL WARNING: Useless use of private variable in void context at (eval 125471) line 1.
2016.07.25 17:44:30 1: PERL WARNING: Useless use of private variable in void context at (eval 125472) line 1.
2016.07.25 17:45:08 2: autocreate: define FileLog_THGR810_6 FileLog /media/hdd/fhem/log01/THGR810_6-%Y.log THGR810_6
2016.07.25 17:45:08 2: autocreate: define SVG_THGR810_6 SVG FileLog_THGR810_6:temp4hum4:CURRENT
2016.07.25 17:45:12 1: PERL WARNING: Useless use of private variable in void context at (eval 125812) line 1.
2016.07.25 17:45:12 1: PERL WARNING: Useless use of private variable in void context at (eval 125813) line 1.
2016.07.25 17:45:17 1: PERL WARNING: Useless use of private variable in void context at (eval 125872) line 1.
2016.07.25 17:45:17 1: PERL WARNING: Useless use of private variable in void context at (eval 125873) line 1.
2016.07.25 17:45:18 1: PERL WARNING: Useless use of private variable in void context at (eval 125942) line 1.
2016.07.25 17:45:18 1: PERL WARNING: Useless use of private variable in void context at (eval 125943) line 1.
2016.07.25 17:45:41 1: PERL WARNING: Useless use of private variable in void context at (eval 126209) line 1.
2016.07.25 17:45:41 1: PERL WARNING: Useless use of private variable in void context at (eval 126210) line 1.
2016.07.25 17:45:42 1: PERL WARNING: Useless use of private variable in void context at (eval 126279) line 1.
2016.07.25 17:45:42 1: PERL WARNING: Useless use of private variable in void context at (eval 126280) line 1.
2016.07.25 17:46:05 1: PERL WARNING: Useless use of private variable in void context at (eval 126544) line 1.
2016.07.25 17:46:05 1: PERL WARNING: Useless use of private variable in void context at (eval 126545) line 1.
2016.07.25 17:46:06 1: PERL WARNING: Useless use of private variable in void context at (eval 126614) line 1.
2016.07.25 17:46:06 1: PERL WARNING: Useless use of private variable in void context at (eval 126615) line 1.
2016.07.25 17:46:21 1: PERL WARNING: Useless use of private variable in void context at (eval 126685) line 1.
2016.07.25 17:46:21 1: PERL WARNING: Useless use of private variable in void context at (eval 126689) line 1.
2016.07.25 17:46:29 1: PERL WARNING: Useless use of private variable in void context at (eval 126859) line 1.
2016.07.25 17:46:29 1: PERL WARNING: Useless use of private variable in void context at (eval 126860) line 1.
2016.07.25 17:46:30 1: PERL WARNING: Useless use of private variable in void context at (eval 126929) line 1.
2016.07.25 17:46:30 1: PERL WARNING: Useless use of private variable in void context at (eval 126930) line 1.
2016.07.25 17:46:53 1: PERL WARNING: Useless use of private variable in void context at (eval 127183) line 1.
2016.07.25 17:46:53 1: PERL WARNING: Useless use of private variable in void context at (eval 127184) line 1.
2016.07.25 17:46:54 1: PERL WARNING: Useless use of private variable in void context at (eval 127253) line 1.
2016.07.25 17:46:54 1: PERL WARNING: Useless use of private variable in void context at (eval 127254) line 1.
2016.07.25 17:47:12 2: IT set R_OG1_BA off
2016.07.25 17:47:12 2: IT set R_OG1_SL off
2016.07.25 17:47:13 3: FS20 set R_OG1_WZ on
2016.07.25 17:47:13 3: FS20 set R_OG2_BUE_NO off
2016.07.25 17:47:17 1: PERL WARNING: Useless use of private variable in void context at (eval 127523) line 1.
2016.07.25 17:47:17 1: PERL WARNING: Useless use of private variable in void context at (eval 127524) line 1.
2016.07.25 17:47:17 2: IT set R_OG1_BA off
2016.07.25 17:47:17 2: IT set R_OG1_SL off
2016.07.25 17:47:18 3: FS20 set R_OG1_WZ on
2016.07.25 17:47:19 1: PERL WARNING: Useless use of private variable in void context at (eval 127595) line 1.
2016.07.25 17:47:19 1: PERL WARNING: Useless use of private variable in void context at (eval 127596) line 1.
2016.07.25 17:47:19 2: IT set R_OG1_BA off
2016.07.25 17:47:19 2: IT set R_OG1_SL off
2016.07.25 17:47:19 3: FS20 set R_OG1_WZ on
2016.07.25 17:47:21 3: FS20 set R_OG1_WZ on
2016.07.25 17:47:22 2: IT set R_OG1_BA off
2016.07.25 17:47:22 2: IT set R_OG1_SL off
2016.07.25 17:47:41 1: PERL WARNING: Useless use of private variable in void context at (eval 127921) line 1.
2016.07.25 17:47:41 1: PERL WARNING: Useless use of private variable in void context at (eval 127922) line 1.
2016.07.25 17:47:42 1: PERL WARNING: Useless use of private variable in void context at (eval 127993) line 1.
2016.07.25 17:47:42 1: PERL WARNING: Useless use of private variable in void context at (eval 127994) line 1.
2016.07.25 17:48:05 1: PERL WARNING: Useless use of private variable in void context at (eval 128295) line 1.
2016.07.25 17:48:05 1: PERL WARNING: Useless use of private variable in void context at (eval 128296) line 1.
2016.07.25 17:48:06 1: PERL WARNING: Useless use of private variable in void context at (eval 128367) line 1.
2016.07.25 17:48:06 1: PERL WARNING: Useless use of private variable in void context at (eval 128368) line 1.
2016.07.25 17:48:29 1: PERL WARNING: Useless use of private variable in void context at (eval 128624) line 1.
2016.07.25 17:48:29 1: PERL WARNING: Useless use of private variable in void context at (eval 128625) line 1.
2016.07.25 17:48:30 1: PERL WARNING: Useless use of private variable in void context at (eval 128696) line 1.
2016.07.25 17:48:30 1: PERL WARNING: Useless use of private variable in void context at (eval 128697) line 1.
2016.07.25 17:48:53 1: PERL WARNING: Useless use of private variable in void context at (eval 128946) line 1.
LG Chris
Devices: APC, Eastron, FS20, IT, Homematic, MQTT, PV-(DEYE, EPEVER, FRONIUS), Resol-VBUS, S.USV, TEK603, WMR200, YouLess
StefanStrobel
Hallo Chris,
jetzt fehlen die Debug-Meldungen Deines HTTPMOD-Geräts im Log. So sehe ich keinen Zusammenhang zwischen HTTPMOD und den Warn-Meldungen.
Wenn Du einen Log-Ausschnitt postest, der für den gleichen Zeitraum sowohl die Meldungen Deines HTTPMOD-Gerätes als auch die Warnungen enthält, sollte man erkennen können, ob zu dem Zeitpunkt der Warnung eine Aktion des Geräts läuft und falls ja welche ...
Bist Du sicher, dass die überhaupt etwas mit HTTPMOD zu tun haben?
Gruss
    Stefan
Skusi
ich beschäftige mich nun schon seit Tagen mit HTTPMOD, und versuche die Regex Syntax zu lernen.
Ich frage die Biowetter Seite von Donnerwetter.de ab, finde aber einfach nicht heraus wie ich folgende RegEx ändern muß das statt "keine" auch auf nichts reagiert wird.
Also Donnerwetter hat seine Seite so geändert das es einfach nix zwischen den strongs anzeigt, wenn es keine Gefahr gibt. Es steht dann also so da:
<strong></strong>
Wie kann ich erreichen das dann mein reading mit nix, oder besser noch mit "keine" gefüllt wird ?
Nun ist es so das das reading nicht aktualisiert wird, wenn keines der oder verknüpften strings gefunden wird. Dann steht solange der letzte Wert drin bis ein anderer gefunden wird. Also habe ich bei aktueller nichts Meldung immer dem letzten alten wert im Reading.
Ich hoffe ich hab mich einigermaßen verständlich ausgedrückt.
Kann jemand helfen ???
(?s)Herzinsuffizienz<\/td>.*?<strong>(sehr stark|stark|schwach|keine)?<\/strong>
HP ThinClient 630, SIGNALduino, NanoCul868 (a-culfw), JeeLink Clone (LaCrosse), Firmata  für FB Heizung,Wasser+Gas+Klingel+Lux, Somfy Rolladen, Pollin Steckd.,TX29DTH,Tasmota+IR Lesekopf an Stromz., MAX Fensterkontakte, IButton, Fingerprint, SonOff Tasmota, ESP LED Controler, WLed,zigbee2mqtt...
Burny4600
#260
@StefanStrobel
Dieser Perl Warning Meldung tritt nur auf wenn ich die DL2 cfg lade.
Es ist nur eigenartig, wenn ich stacktrace aktiviere tritt diese Warnung nicht auf.
LG Chris
StefanStrobel
Hallo Skusi,
Probier doch mal das deleteIfUnmatched Attribut von HTTPMOD aus.
      Stefan
Burny4600
#262
Wo finde ich eine Erklärung zu diesem Parameter.
deleteIfUnmatched HTTPMOD finde ich nicht im Wiki noch im Commandref.
LG Chris
frank
deleteIfUnmatched HTTPMOD finde ich nicht im Wiki nochim Commandref.
dann ist dein fhem nicht up-to-date.
commandref:
Zitatget|reading[0-9]*DeleteIfUnmatched
If set to 1 this attribute causes certain readings to be deleted when the parsing of the website does not match the specified reading. Internally HTTPMOD remembers which kind of operation created a reading (update, Get01, Get02 and so on). Specified readings will only be deleted if the same operation does not parse this reading again. This is especially useful for parsing that creates several matches / readings and ths number of matches can vary from request to request. For example if reading01Regex creates 4 readings in one update cycle and in the next cycle it only matches two times the the readings containing the remaining values from the last round will be deleted.
Please note that this mechanism will not work in all cases after a restart. Especially when a get definition does not contain its own parsing definition but ExtractAllJSON or relies on HTTPMOD to use all defined reading.* attributes to parse the responsee to a get command, old readings might not be deleted after a restart of fhem.
FHEM: 6.0(SVN) => Pi3(buster)
Burny4600
#264
Wo ich dieses Attribut verwenden soll ist mir dennoch noch nicht ganz klar.
Zur Auswahl steht dies bei den HTTPMOD Gerät auch nicht obwohl mein FHEM aktuell ist.
define DL2 HTTPMOD http://192.xxx.xxx.xxx/dlx/download/live?&outputType=json&source=current 15
attr DL2 event-on-change-reading headersets_01_packets_01_field_values_(01|02|03|04|05|06|07|08|09|10|11|12|13|14|15|16|17|18|19|20|21|22|23|24|25|26|27|28|29|30|31|32)_value,headersets_01_packets_02_field_values_(01|02|03|04)_value,(F|W)M,headersets_01_packets_03_field_values_(01|02|03|04)_value,T_0(1|2|3|4|5|6|7|8|9),T_1(0|1|2),CS10,IMP0(1|2),S(BRM|KSM|BEM|Z),R_(1|2|3|4|5|6|7|8|9),RBEM,RV,VT_(1|2),RT_(1|2),W_(1|2)_(Wh|kWh|MWh),VS_(1|2)_(lph|lpmin|m3ph)
attr DL2 extractAllJSON 1
attr DL2 userReadings T_01:headersets_01_packets_01_field_values_01_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_01_value",0)},\
T_02:headersets_01_packets_01_field_values_02_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_02_value",0)},\
T_03:headersets_01_packets_01_field_values_03_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_03_value",0)},\
T_04:headersets_01_packets_01_field_values_04_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_04_value",0)},\
T_05:headersets_01_packets_01_field_values_05_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_05_value",0)},\
T_06:headersets_01_packets_01_field_values_06_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_06_value",0)},\
T_07:headersets_01_packets_01_field_values_07_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_07_value",0)},\
T_08:headersets_01_packets_01_field_values_08_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_08_value",0)},\
T_09:headersets_01_packets_01_field_values_09_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_09_value",0)},\
T_10:headersets_01_packets_01_field_values_10_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_10_value",0)},\
T_11:headersets_01_packets_01_field_values_11_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_11_value",0)},\
T_12:headersets_01_packets_01_field_values_12_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_12_value",0)},\
CS10:headersets_01_packets_01_field_values_13_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_13_value",0)},\
IMP01:headersets_01_packets_01_field_values_14_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_14_value",0)},\
IMP02:headersets_01_packets_01_field_values_15_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_15_value",0)},\
SBRM:headersets_01_packets_01_field_values_16_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_16_value",0)},\
SKSM:headersets_01_packets_01_field_values_17_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_17_value",0)},\
SBEM:headersets_01_packets_01_field_values_18_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_18_value",0)},\
R_1:headersets_01_packets_01_field_values_19_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_19_value",0)},\
R_2:headersets_01_packets_01_field_values_20_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_20_value",0)},\
R_3:headersets_01_packets_01_field_values_21_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_21_value",0)},\
R_4:headersets_01_packets_01_field_values_22_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_22_value",0)},\
R_5:headersets_01_packets_01_field_values_23_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_23_value",0)},\
R_6:headersets_01_packets_01_field_values_24_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_24_value",0)},\
R_7:headersets_01_packets_01_field_values_25_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_25_value",0)},\
R_8:headersets_01_packets_01_field_values_26_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_26_value",0)},\
R_9:headersets_01_packets_01_field_values_27_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_27_value",0)},\
RBEM:headersets_01_packets_01_field_values_28_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_28_value",0)},\
FM:headersets_01_packets_01_field_values_29_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_29_value",0)},\
WM:headersets_01_packets_01_field_values_30_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_30_value",0)},\
RV:headersets_01_packets_01_field_values_31_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_31_value",0)},\
SZ:headersets_01_packets_01_field_values_32_value.* {ReadingsVal("DL2","headersets_01_packets_01_field_values_32_value",0)},\
VT_1:headersets_01_packets_02_field_values_01_value.* {ReadingsVal("DL2","headersets_01_packets_02_field_values_01_value",0)},\
RT_1:headersets_01_packets_02_field_values_02_value.* {ReadingsVal("DL2","headersets_01_packets_02_field_values_02_value",0)},\
VS_1_lph:headersets_01_packets_02_field_values_03_value.* {ReadingsVal("DL2","headersets_01_packets_02_field_values_03_value",0)},\
W_1_Wh:headersets_01_packets_02_field_values_04_value.* {ReadingsVal("DL2","headersets_01_packets_02_field_values_04_value",0)},\
VT_2:headersets_01_packets_03_field_values_01_value.* {ReadingsVal("DL2","headersets_01_packets_03_field_values_01_value",0)},\
RT_2:headersets_01_packets_03_field_values_02_value.* {ReadingsVal("DL2","headersets_01_packets_03_field_values_02_value",0)},\
VS_2_lph:headersets_01_packets_03_field_values_03_value.* {ReadingsVal("DL2","headersets_01_packets_03_field_values_03_value",0)},\
W_2_Wh:headersets_01_packets_03_field_values_04_value.* {ReadingsVal("DL2","headersets_01_packets_03_field_values_04_value",0)},\
W_1_kWh:W_1_Wh.* {ReadingsVal("DL2","W_1_Wh",0)/1000},\
W_1_MWh:W_1_Wh.* {ReadingsVal("DL2","W_1_Wh",0)/1000000},\
W_2_kWh:W_2_Wh.* {ReadingsVal("DL2","W_2_Wh",0)/1000},\
W_2_MWh:W_2_Wh.* {ReadingsVal("DL2","W_2_Wh",0)/1000000},\
VS_1_lpmin:VS_1_lph.* {ReadingsVal("DL2","VS_1_lph",0)/60},\
VS_1_m3ph:VS_1_lph.* {ReadingsVal("DL2","VS_1_lph",0)/1000},\
VS_2_lpmin:VS_2_lph.* {ReadingsVal("DL2","VS_2_lph",0)/60},\
VS_2_m3ph:VS_2_lph.* {ReadingsVal("DL2","VS_2_lph",0)/1000}
attr DL2 verbose 1
LG Chris
frank
Burny4600
Ist bei mir auch die gleiche Version.
98_HTTPMOD.pm         11692 2016-06-19 09:08:31Z ststrobel
LG Chris
StefanStrobel
Hallo Chris,
meine Empfehlung für deleteIfUnmatched bezog sich auf die Frage von Skusi.
Normalerweise würde es zusammen mit manuell definierten Readings definiert. Man gibt jedem Reading in HTTPMOD einen Namen und konkrete Parsing- bzw. Format-Anweisungen,
z.B. reading01Name Spannung,
reading01JSON meinJSONPFAD etc.
reading01DeleteIfUnmatched würde dann das Reading entfernen wenn es beim Lesen nicht mehr gefunden wird.
Man kann es auch allgemeiner als readingDeleteIfUnmatched schreiben, dann gilt es für alle Readings (wie bei den anderen Attributen für die Nachbearbeitung der Readings etc.)
In Deiner Konfig nutzt Du userReadings anstelle der Features von HTTPMOD. Kann man machen - muss man aber nicht ;-)
Die Logs, die Du gepostet hast, enthalten zwar viele Daten, aber ich sehe keine HTTPMOD Logs mit Level 5. Vermutlich fehlt immer noch das attr DL2 verbose 5.
Die Perl-Warnung, nach der Du suchst, scheint laut StackTrace aber auch in einem DOIF zu stecken...
Gruss
    Stefan
Burny4600
Woraus sehe ich das im LOG ob es mit dem  HTTPMOD liegt oder von wo anders?
ZitatIn Deiner Konfig nutzt Du userReadings anstelle der Features von HTTPMOD. Kann man machen - muss man aber nicht
Wie sieht das genau aus anders zu machen? Bringt das etwas für FHEM?
LG Chris
Ralf Kruppa
Hallo ich bin recht neue hier und wolte mal fragen wie ich die neue Version updaten kann bzw installieren kann ?
