Neue Version von HTTPMOD mit neuen Features zum Testen
Begonnen von StefanStrobel, 05 Dezember 2015, 08:31:32
ch.eick
#495
hier kommt ein Update zu den readings für den MODBUS mit einigen Mappings
Stand 11.01.2019 Hier aktualisiere ich die readings
attr vallox_cloud reading00017JSON data_17_value
attr vallox_cloud reading00017Name A_CYC_MACHINE_MODEL
attr vallox_cloud reading04353JSON data_4353_value
attr vallox_cloud reading04353Name A_CYC_FAN_SPEED
attr vallox_cloud reading04354JSON data_4354_value
attr vallox_cloud reading04354Name A_CYC_TEMP_EXTRACT_AIR
attr vallox_cloud reading04355JSON data_4355_value
attr vallox_cloud reading04355Name A_CYC_TEMP_EXHAUST_AIR
attr vallox_cloud reading04356JSON data_4356_value
attr vallox_cloud reading04356Name A_CYC_TEMP_OUTDOOR_AIR
attr vallox_cloud reading04357JSON data_4357_value
attr vallox_cloud reading04357Name A_CYC_TEMP_SUPPLY_CELL_AIR
attr vallox_cloud reading04358JSON data_4358_value
attr vallox_cloud reading04358Name A_CYC_TEMP_SUPPLY_AIR
attr vallox_cloud reading04359JSON data_4359_value
attr vallox_cloud reading04359Name A_CYC_RH_LEVEL
attr vallox_cloud reading04360JSON data_4360_value
attr vallox_cloud reading04360Name A_CYC_CO2_LEVEL
attr vallox_cloud reading04363JSON data_4363_value
attr vallox_cloud reading04363Name A_CYC_RH_VALUE
attr vallox_cloud reading04364JSON data_4364_value
attr vallox_cloud reading04364Name A_CYC_CO2_VALUE
attr vallox_cloud reading04609JSON data_4609_value
attr vallox_cloud reading04609Name A_CYC_STATE
attr vallox_cloud reading04615JSON data_4615_value
attr vallox_cloud reading04615Name A_CYC_WEEKLY_TIMER_ENABLED
attr vallox_cloud reading04615OMap 0:no, 1:yes
attr vallox_cloud reading04616JSON data_4616_value
attr vallox_cloud reading04616Name A_CYC_CELL_STATE
attr vallox_cloud reading04616OMap 0:heat recovery, 1:cool recovery, 2:bypass, 3:defrosting
attr vallox_cloud reading05121JSON data_5121_value
attr vallox_cloud reading05121Name A_CYC_IN_EXTRACT_FAN
attr vallox_cloud reading05122JSON data_5122_value
attr vallox_cloud reading05122Name A_CYC_IN_SUPPLY_FAN
attr vallox_cloud reading05124JSON data_5124_value
attr vallox_cloud reading05124Name A_CYC_IN_HEATER
attr vallox_cloud reading05125JSON data_5125_value
attr vallox_cloud reading05125Name A_CYC_IN_EXTRA_HEATER
attr vallox_cloud reading05126JSON data_5126_value
attr vallox_cloud reading05126Name A_CYC_IN_BYPASS
attr vallox_cloud reading05126OMap 0:no, 1:yes
attr vallox_cloud reading20482JSON data_20482_value
attr vallox_cloud reading20482Name A_CYC_MODBUS_ADDRESS
attr vallox_cloud reading20483JSON data_20483_value
attr vallox_cloud reading20483Name A_CYC_MODBUS_BAUD_X100
attr vallox_cloud reading20483OMap 96:9600, 192:19200, 384:38400, 576:57600, 1152:115200
attr vallox_cloud reading20487JSON data_20487_value
attr vallox_cloud reading20487Name A_CYC_FIREPLACE_EXTR_FAN
attr vallox_cloud reading20488JSON data_20488_value
attr vallox_cloud reading20488Name A_CYC_FIREPLACE_SUPP_FAN
attr vallox_cloud reading20490JSON data_20490_value
attr vallox_cloud reading20490Name A_CYC_RH_BASIC_LEVEL
attr vallox_cloud reading20491JSON data_20491_value
attr vallox_cloud reading20491Name A_CYC_CO2_THRESHOLD
attr vallox_cloud reading20499JSON data_20499_value
attr vallox_cloud reading20499Name A_CYC_AWAY_RH_CTRL_ENABLED
attr vallox_cloud reading20499OMap 0:no, 1:yes
attr vallox_cloud reading20500JSON data_20500_value
attr vallox_cloud reading20500Name A_CYC_AWAY_CO2_CTRL_ENABLED
attr vallox_cloud reading20500OMap 0:no, 1:yes
attr vallox_cloud reading20501JSON data_20501_value
attr vallox_cloud reading20501Name A_CYC_AWAY_SPEED_SETTING
attr vallox_cloud reading20505JSON data_20505_value
attr vallox_cloud reading20505Name A_CYC_HOME_RH_CTRL_ENABLED
attr vallox_cloud reading20505OMap 0:no, 1:yes
attr vallox_cloud reading20506JSON data_20506_value
attr vallox_cloud reading20506Name A_CYC_HOME_CO2_CTRL_ENABLED
attr vallox_cloud reading20506OMap 0:no, 1:yes
attr vallox_cloud reading20507JSON data_20507_value
attr vallox_cloud reading20507Name A_CYC_HOME_SPEED_SETTING
attr vallox_cloud reading20511JSON data_20511_value
attr vallox_cloud reading20511Name A_CYC_BOOST_RH_CTRL_ENABLED
attr vallox_cloud reading20511OMap 0:no, 1:yes
attr vallox_cloud reading20512JSON data_20512_value
attr vallox_cloud reading20512Name A_CYC_BOOST_CO2_CTRL_ENABLED
attr vallox_cloud reading20512OMap 0:no, 1:yes
attr vallox_cloud reading20513JSON data_20513_value
attr vallox_cloud reading20513Name A_CYC_BOOST_SPEED_SETTING
attr vallox_cloud reading20517JSON data_20517_value
attr vallox_cloud reading20517Name A_CYC_RELAY_MODE
attr vallox_cloud reading20524JSON data_20524_value
attr vallox_cloud reading20524Name A_CYC_DEFROST_MODE
attr vallox_cloud reading20542JSON data_20542_value
attr vallox_cloud reading20542Name A_CYC_SIDEDNESS
attr vallox_cloud reading20542OMap 0:left, 1:right
attr vallox_cloud reading20543JSON data_20543_value
attr vallox_cloud reading20543Name A_CYC_RH_LEVEL_MODE
attr vallox_cloud reading20545JSON data_20545_value
attr vallox_cloud reading20545Name A_CYC_FIREPLACE_TIME
attr vallox_cloud reading20549JSON data_20549_value
attr vallox_cloud reading20549Name A_CYC_SUPPLY_HEATING_ADJUST_MODE
attr vallox_cloud reading20553JSON data_20553_value
attr vallox_cloud reading20553Name A_CYC_OPT_TEMP_SENSOR_MODE
attr vallox_cloud reading21765JSON data_21765_value
attr vallox_cloud reading21765Name A_CYC_PARENTAL_CTRL_ENABLED
attr vallox_cloud reading21767JSON data_21767_value
attr vallox_cloud reading21767Name A_CYC_FIREPLACE_TIMER_ENABLED
attr vallox_cloud reading21767OMap 0:no, 1:yes
attr vallox_cloud reading21768JSON data_21768_value
attr vallox_cloud reading21768Name A_CYC_SUMMER_TIME_AUTO_ENAB
attr vallox_cloud reading21768OMap 0:no, 1:yes
attr vallox_cloud reading21769JSON data_21769_value
attr vallox_cloud reading21769Name A_CYC_12_HOUR_CLOCK_ENABLED
attr vallox_cloud reading21769OMap 0:12h, 1:24h
attr vallox_cloud reading32771JSON data_32771_value
attr vallox_cloud reading32771Name A_CYC_BY_PASS_TEST
attr vallox_cloud reading32772JSON data_32772_value
attr vallox_cloud reading32772Name A_CYC_HEATER_TEST
attr vallox_cloud reading32773JSON data_32773_value
attr vallox_cloud reading32773Name A_CYC_EXTRA_HEATER_TEST
attr vallox_cloud reading32774JSON data_32774_value
attr vallox_cloud reading32774Name A_CYC_EFFICIENCY_TEST
attr vallox_cloud reading65537JSON data_65537_value
attr vallox_cloud reading65537Name EXT_NUM_OF_RH_SENSORS
attr vallox_cloud reading65538JSON data_65538_value
attr vallox_cloud reading65538Name EXT_NUM_OF_CO2_SENSORS
attr vallox_cloud reading65539JSON data_65539_value
attr vallox_cloud reading65539Name EXT_CYC_APPL_SW_VERSION
attr vallox_cloud reading65540JSON data_65540_value
attr vallox_cloud reading65540Name EXT_TEMP_NOW_EXTRACT_AIR
attr vallox_cloud reading65541JSON data_65541_value
attr vallox_cloud reading65541Name EXT_TEMP_NOW_SUPPLY_AIR
attr vallox_cloud reading65542JSON data_65542_value
attr vallox_cloud reading65542Name EXT_TEMP_NOW_OUTDOOR_AIR
attr vallox_cloud reading65543JSON data_65543_value
attr vallox_cloud reading65543Name EXT_TEMP_NOW_EXHAUST_AIR
attr vallox_cloud reading65544JSON data_65544_value
attr vallox_cloud reading65544Name EXT_MODBUS_STOPBIT
attr vallox_cloud reading65545OMap 0:none, 1:even, 2:odd
attr vallox_cloud reading65545JSON data_65545_value
attr vallox_cloud reading65545Name EXT_MODBUS_PARITY
attr vallox_cloud reading65548JSON data_65548_value
attr vallox_cloud reading65548Name EXT_CYC_SERIAL_NUMBER
attr vallox_cloud reading65549JSON data_65549_value
attr vallox_cloud reading65549Name EXT_CYC_FILTER_CHANGED_DATE
attr vallox_cloud reading65550JSON data_65550_value
attr vallox_cloud reading65550Name EXT_CYC_ACTIVE_PROFILE
attr vallox_cloud reading65550OMap 0:home, 1:away, 2:boost, 3:fireplace
attr vallox_cloud reading65553JSON data_65553_value
attr vallox_cloud reading65553Name EXT_CYC_CURRENT_UP_TIME
attr vallox_cloud reading655541JSON data_65554_value_hours
attr vallox_cloud reading655541Name EXT_CYC_TOTAL_UP_TIME_HOURS
attr vallox_cloud reading655542JSON data_65554_value_years
attr vallox_cloud reading655542Name EXT_CYC_TOTAL_UP_TIME_YEARS
# Das sind die neuen Kalender readings
attr vallox_cloud reading65557000JSON data_65557_marks_00:00 1
attr vallox_cloud reading65557000Name EXT_CYC_WEEKLY_EVENTS_MONDAY_00
attr vallox_cloud reading65557001JSON data_65557_marks_01:00 1
attr vallox_cloud reading65557001Name EXT_CYC_WEEKLY_EVENTS_MONDAY_01
attr vallox_cloud reading65557002JSON data_65557_marks_02:00 1
attr vallox_cloud reading65557002Name EXT_CYC_WEEKLY_EVENTS_MONDAY_02
attr vallox_cloud reading65557003JSON data_65557_marks_03:00 1
attr vallox_cloud reading65557003Name EXT_CYC_WEEKLY_EVENTS_MONDAY_03
attr vallox_cloud reading65557004JSON data_65557_marks_04:00 1
attr vallox_cloud reading65557004Name EXT_CYC_WEEKLY_EVENTS_MONDAY_04
attr vallox_cloud reading65557005JSON data_65557_marks_05:00 1
attr vallox_cloud reading65557005Name EXT_CYC_WEEKLY_EVENTS_MONDAY_05
attr vallox_cloud reading65557006JSON data_65557_marks_06:00 1
attr vallox_cloud reading65557006Name EXT_CYC_WEEKLY_EVENTS_MONDAY_06
attr vallox_cloud reading65557007JSON data_65557_marks_07:00 1
attr vallox_cloud reading65557007Name EXT_CYC_WEEKLY_EVENTS_MONDAY_07
attr vallox_cloud reading65557008JSON data_65557_marks_08:00 1
attr vallox_cloud reading65557008Name EXT_CYC_WEEKLY_EVENTS_MONDAY_08
attr vallox_cloud reading65557009JSON data_65557_marks_09:00 1
attr vallox_cloud reading65557009Name EXT_CYC_WEEKLY_EVENTS_MONDAY_09
attr vallox_cloud reading65557010JSON data_65557_marks_10:00 1
attr vallox_cloud reading65557010Name EXT_CYC_WEEKLY_EVENTS_MONDAY_10
attr vallox_cloud reading65557011JSON data_65557_marks_11:00 1
attr vallox_cloud reading65557011Name EXT_CYC_WEEKLY_EVENTS_MONDAY_11
attr vallox_cloud reading65557012JSON data_65557_marks_12:00 1
attr vallox_cloud reading65557012Name EXT_CYC_WEEKLY_EVENTS_MONDAY_12
attr vallox_cloud reading65557013JSON data_65557_marks_13:00 1
attr vallox_cloud reading65557013Name EXT_CYC_WEEKLY_EVENTS_MONDAY_13
attr vallox_cloud reading65557014JSON data_65557_marks_14:00 1
attr vallox_cloud reading65557014Name EXT_CYC_WEEKLY_EVENTS_MONDAY_14
attr vallox_cloud reading65557015JSON data_65557_marks_15:00 1
attr vallox_cloud reading65557015Name EXT_CYC_WEEKLY_EVENTS_MONDAY_15
attr vallox_cloud reading65557016JSON data_65557_marks_16:00 1
attr vallox_cloud reading65557016Name EXT_CYC_WEEKLY_EVENTS_MONDAY_16
attr vallox_cloud reading65557017JSON data_65557_marks_17:00 1
attr vallox_cloud reading65557017Name EXT_CYC_WEEKLY_EVENTS_MONDAY_17
attr vallox_cloud reading65557018JSON data_65557_marks_18:00 1
attr vallox_cloud reading65557018Name EXT_CYC_WEEKLY_EVENTS_MONDAY_18
attr vallox_cloud reading65557019JSON data_65557_marks_19:00 1
attr vallox_cloud reading65557019Name EXT_CYC_WEEKLY_EVENTS_MONDAY_19
attr vallox_cloud reading65557020JSON data_65557_marks_20:00 1
attr vallox_cloud reading65557020Name EXT_CYC_WEEKLY_EVENTS_MONDAY_20
attr vallox_cloud reading65557021JSON data_65557_marks_21:00 1
attr vallox_cloud reading65557021Name EXT_CYC_WEEKLY_EVENTS_MONDAY_21
attr vallox_cloud reading65557022JSON data_65557_marks_22:00 1
attr vallox_cloud reading65557022Name EXT_CYC_WEEKLY_EVENTS_MONDAY_22
attr vallox_cloud reading65557023JSON data_65557_marks_23:00 1
attr vallox_cloud reading65557023Name EXT_CYC_WEEKLY_EVENTS_MONDAY_23
attr vallox_cloud reading65557024JSON data_65557_marks_00:00 2
attr vallox_cloud reading65557024Name EXT_CYC_WEEKLY_EVENTS_TUESDAY_00
attr vallox_cloud reading65557025JSON data_65557_marks_01:00 2
attr vallox_cloud reading65557025Name EXT_CYC_WEEKLY_EVENTS_TUESDAY_01
attr vallox_cloud reading65557026JSON data_65557_marks_02:00 2
attr vallox_cloud reading65557026Name EXT_CYC_WEEKLY_EVENTS_TUESDAY_02
attr vallox_cloud reading65557027JSON data_65557_marks_03:00 2
attr vallox_cloud reading65557027Name EXT_CYC_WEEKLY_EVENTS_TUESDAY_03
attr vallox_cloud reading65557028JSON data_65557_marks_04:00 2
attr vallox_cloud reading65557028Name EXT_CYC_WEEKLY_EVENTS_TUESDAY_04
attr vallox_cloud reading65557029JSON data_65557_marks_05:00 2
attr vallox_cloud reading65557029Name EXT_CYC_WEEKLY_EVENTS_TUESDAY_05
attr vallox_cloud reading65557030JSON data_65557_marks_06:00 2
attr vallox_cloud reading65557030Name EXT_CYC_WEEKLY_EVENTS_TUESDAY_06
attr vallox_cloud reading65557031JSON data_65557_marks_07:00 2
attr vallox_cloud reading65557031Name EXT_CYC_WEEKLY_EVENTS_TUESDAY_07
attr vallox_cloud reading65557032JSON data_65557_marks_08:00 2
attr vallox_cloud reading65557032Name EXT_CYC_WEEKLY_EVENTS_TUESDAY_08
attr vallox_cloud reading65557033JSON data_65557_marks_09:00 2
attr vallox_cloud reading65557033Name EXT_CYC_WEEKLY_EVENTS_TUESDAY_09
attr vallox_cloud reading65557034JSON data_65557_marks_10:00 2
attr vallox_cloud reading65557034Name EXT_CYC_WEEKLY_EVENTS_TUESDAY_10
attr vallox_cloud reading65557035JSON data_65557_marks_11:00 2
attr vallox_cloud reading65557035Name EXT_CYC_WEEKLY_EVENTS_TUESDAY_11
attr vallox_cloud reading65557036JSON data_65557_marks_12:00 2
attr vallox_cloud reading65557036Name EXT_CYC_WEEKLY_EVENTS_TUESDAY_12
attr vallox_cloud reading65557037JSON data_65557_marks_13:00 2
attr vallox_cloud reading65557037Name EXT_CYC_WEEKLY_EVENTS_TUESDAY_13
attr vallox_cloud reading65557038JSON data_65557_marks_14:00 2
attr vallox_cloud reading65557038Name EXT_CYC_WEEKLY_EVENTS_TUESDAY_14
attr vallox_cloud reading65557039JSON data_65557_marks_15:00 2
attr vallox_cloud reading65557039Name EXT_CYC_WEEKLY_EVENTS_TUESDAY_15
attr vallox_cloud reading65557040JSON data_65557_marks_16:00 2
attr vallox_cloud reading65557040Name EXT_CYC_WEEKLY_EVENTS_TUESDAY_16
attr vallox_cloud reading65557041JSON data_65557_marks_17:00 2
attr vallox_cloud reading65557041Name EXT_CYC_WEEKLY_EVENTS_TUESDAY_17
attr vallox_cloud reading65557042JSON data_65557_marks_18:00 2
attr vallox_cloud reading65557042Name EXT_CYC_WEEKLY_EVENTS_TUESDAY_18
attr vallox_cloud reading65557043JSON data_65557_marks_19:00 2
attr vallox_cloud reading65557043Name EXT_CYC_WEEKLY_EVENTS_TUESDAY_19
attr vallox_cloud reading65557044JSON data_65557_marks_20:00 2
attr vallox_cloud reading65557044Name EXT_CYC_WEEKLY_EVENTS_TUESDAY_20
attr vallox_cloud reading65557045JSON data_65557_marks_21:00 2
attr vallox_cloud reading65557045Name EXT_CYC_WEEKLY_EVENTS_TUESDAY_21
attr vallox_cloud reading65557046JSON data_65557_marks_22:00 2
attr vallox_cloud reading65557046Name EXT_CYC_WEEKLY_EVENTS_TUESDAY_22
attr vallox_cloud reading65557047JSON data_65557_marks_23:00 2
attr vallox_cloud reading65557047Name EXT_CYC_WEEKLY_EVENTS_TUESDAY_23
attr vallox_cloud reading65557048JSON data_65557_marks_00:00 3
attr vallox_cloud reading65557048Name EXT_CYC_WEEKLY_EVENTS_WEDNESDAY_00
attr vallox_cloud reading65557049JSON data_65557_marks_01:00 3
attr vallox_cloud reading65557049Name EXT_CYC_WEEKLY_EVENTS_WEDNESDAY_01
attr vallox_cloud reading65557050JSON data_65557_marks_02:00 3
attr vallox_cloud reading65557050Name EXT_CYC_WEEKLY_EVENTS_WEDNESDAY_02
attr vallox_cloud reading65557051JSON data_65557_marks_03:00 3
attr vallox_cloud reading65557051Name EXT_CYC_WEEKLY_EVENTS_WEDNESDAY_03
attr vallox_cloud reading65557052JSON data_65557_marks_04:00 3
attr vallox_cloud reading65557052Name EXT_CYC_WEEKLY_EVENTS_WEDNESDAY_04
attr vallox_cloud reading65557053JSON data_65557_marks_05:00 3
attr vallox_cloud reading65557053Name EXT_CYC_WEEKLY_EVENTS_WEDNESDAY_05
attr vallox_cloud reading65557054JSON data_65557_marks_06:00 3
attr vallox_cloud reading65557054Name EXT_CYC_WEEKLY_EVENTS_WEDNESDAY_06
attr vallox_cloud reading65557055JSON data_65557_marks_07:00 3
attr vallox_cloud reading65557055Name EXT_CYC_WEEKLY_EVENTS_WEDNESDAY_07
attr vallox_cloud reading65557056JSON data_65557_marks_08:00 3
attr vallox_cloud reading65557056Name EXT_CYC_WEEKLY_EVENTS_WEDNESDAY_08
attr vallox_cloud reading65557057JSON data_65557_marks_09:00 3
attr vallox_cloud reading65557057Name EXT_CYC_WEEKLY_EVENTS_WEDNESDAY_09
attr vallox_cloud reading65557058JSON data_65557_marks_10:00 3
attr vallox_cloud reading65557058Name EXT_CYC_WEEKLY_EVENTS_WEDNESDAY_10
attr vallox_cloud reading65557059JSON data_65557_marks_11:00 3
attr vallox_cloud reading65557059Name EXT_CYC_WEEKLY_EVENTS_WEDNESDAY_11
attr vallox_cloud reading65557060JSON data_65557_marks_12:00 3
attr vallox_cloud reading65557060Name EXT_CYC_WEEKLY_EVENTS_WEDNESDAY_12
attr vallox_cloud reading65557061JSON data_65557_marks_13:00 3
attr vallox_cloud reading65557061Name EXT_CYC_WEEKLY_EVENTS_WEDNESDAY_13
attr vallox_cloud reading65557062JSON data_65557_marks_14:00 3
attr vallox_cloud reading65557062Name EXT_CYC_WEEKLY_EVENTS_WEDNESDAY_14
attr vallox_cloud reading65557063JSON data_65557_marks_15:00 3
attr vallox_cloud reading65557063Name EXT_CYC_WEEKLY_EVENTS_WEDNESDAY_15
attr vallox_cloud reading65557064JSON data_65557_marks_16:00 3
attr vallox_cloud reading65557064Name EXT_CYC_WEEKLY_EVENTS_WEDNESDAY_16
attr vallox_cloud reading65557065JSON data_65557_marks_17:00 3
attr vallox_cloud reading65557065Name EXT_CYC_WEEKLY_EVENTS_WEDNESDAY_17
attr vallox_cloud reading65557066JSON data_65557_marks_18:00 3
attr vallox_cloud reading65557066Name EXT_CYC_WEEKLY_EVENTS_WEDNESDAY_18
attr vallox_cloud reading65557067JSON data_65557_marks_19:00 3
attr vallox_cloud reading65557067Name EXT_CYC_WEEKLY_EVENTS_WEDNESDAY_19
attr vallox_cloud reading65557068JSON data_65557_marks_20:00 3
attr vallox_cloud reading65557068Name EXT_CYC_WEEKLY_EVENTS_WEDNESDAY_20
attr vallox_cloud reading65557069JSON data_65557_marks_21:00 3
attr vallox_cloud reading65557069Name EXT_CYC_WEEKLY_EVENTS_WEDNESDAY_21
attr vallox_cloud reading65557070JSON data_65557_marks_22:00 3
attr vallox_cloud reading65557070Name EXT_CYC_WEEKLY_EVENTS_WEDNESDAY_22
attr vallox_cloud reading65557071JSON data_65557_marks_23:00 3
attr vallox_cloud reading65557071Name EXT_CYC_WEEKLY_EVENTS_WEDNESDAY_23
attr vallox_cloud reading65557072JSON data_65557_marks_00:00 4
attr vallox_cloud reading65557072Name EXT_CYC_WEEKLY_EVENTS_THURSDAY_00
attr vallox_cloud reading65557073JSON data_65557_marks_01:00 4
attr vallox_cloud reading65557073Name EXT_CYC_WEEKLY_EVENTS_THURSDAY_01
attr vallox_cloud reading65557074JSON data_65557_marks_02:00 4
attr vallox_cloud reading65557074Name EXT_CYC_WEEKLY_EVENTS_THURSDAY_02
attr vallox_cloud reading65557075JSON data_65557_marks_03:00 4
attr vallox_cloud reading65557075Name EXT_CYC_WEEKLY_EVENTS_THURSDAY_03
attr vallox_cloud reading65557076JSON data_65557_marks_04:00 4
attr vallox_cloud reading65557076Name EXT_CYC_WEEKLY_EVENTS_THURSDAY_04
attr vallox_cloud reading65557077JSON data_65557_marks_05:00 4
attr vallox_cloud reading65557077Name EXT_CYC_WEEKLY_EVENTS_THURSDAY_05
attr vallox_cloud reading65557078JSON data_65557_marks_06:00 4
attr vallox_cloud reading65557078Name EXT_CYC_WEEKLY_EVENTS_THURSDAY_06
attr vallox_cloud reading65557079JSON data_65557_marks_07:00 4
attr vallox_cloud reading65557079Name EXT_CYC_WEEKLY_EVENTS_THURSDAY_07
attr vallox_cloud reading65557080JSON data_65557_marks_08:00 4
attr vallox_cloud reading65557080Name EXT_CYC_WEEKLY_EVENTS_THURSDAY_08
attr vallox_cloud reading65557081JSON data_65557_marks_09:00 4
attr vallox_cloud reading65557081Name EXT_CYC_WEEKLY_EVENTS_THURSDAY_09
attr vallox_cloud reading65557082JSON data_65557_marks_10:00 4
attr vallox_cloud reading65557082Name EXT_CYC_WEEKLY_EVENTS_THURSDAY_10
attr vallox_cloud reading65557083JSON data_65557_marks_11:00 4
attr vallox_cloud reading65557083Name EXT_CYC_WEEKLY_EVENTS_THURSDAY_11
attr vallox_cloud reading65557084JSON data_65557_marks_12:00 4
attr vallox_cloud reading65557084Name EXT_CYC_WEEKLY_EVENTS_THURSDAY_12
attr vallox_cloud reading65557085JSON data_65557_marks_13:00 4
attr vallox_cloud reading65557085Name EXT_CYC_WEEKLY_EVENTS_THURSDAY_13
attr vallox_cloud reading65557086JSON data_65557_marks_14:00 4
attr vallox_cloud reading65557086Name EXT_CYC_WEEKLY_EVENTS_THURSDAY_14
attr vallox_cloud reading65557087JSON data_65557_marks_15:00 4
attr vallox_cloud reading65557087Name EXT_CYC_WEEKLY_EVENTS_THURSDAY_15
attr vallox_cloud reading65557088JSON data_65557_marks_16:00 4
attr vallox_cloud reading65557088Name EXT_CYC_WEEKLY_EVENTS_THURSDAY_16
attr vallox_cloud reading65557089JSON data_65557_marks_17:00 4
attr vallox_cloud reading65557089Name EXT_CYC_WEEKLY_EVENTS_THURSDAY_17
attr vallox_cloud reading65557090JSON data_65557_marks_18:00 4
attr vallox_cloud reading65557090Name EXT_CYC_WEEKLY_EVENTS_THURSDAY_18
attr vallox_cloud reading65557091JSON data_65557_marks_19:00 4
attr vallox_cloud reading65557091Name EXT_CYC_WEEKLY_EVENTS_THURSDAY_19
attr vallox_cloud reading65557092JSON data_65557_marks_20:00 4
attr vallox_cloud reading65557092Name EXT_CYC_WEEKLY_EVENTS_THURSDAY_20
attr vallox_cloud reading65557093JSON data_65557_marks_21:00 4
attr vallox_cloud reading65557093Name EXT_CYC_WEEKLY_EVENTS_THURSDAY_21
attr vallox_cloud reading65557094JSON data_65557_marks_22:00 4
attr vallox_cloud reading65557094Name EXT_CYC_WEEKLY_EVENTS_THURSDAY_22
attr vallox_cloud reading65557095JSON data_65557_marks_23:00 4
attr vallox_cloud reading65557095Name EXT_CYC_WEEKLY_EVENTS_THURSDAY_23
attr vallox_cloud reading65557096JSON data_65557_marks_00:00 5
attr vallox_cloud reading65557096Name EXT_CYC_WEEKLY_EVENTS_FRIDAY_00
attr vallox_cloud reading65557097JSON data_65557_marks_01:00 5
attr vallox_cloud reading65557097Name EXT_CYC_WEEKLY_EVENTS_FRIDAY_01
attr vallox_cloud reading65557098JSON data_65557_marks_02:00 5
attr vallox_cloud reading65557098Name EXT_CYC_WEEKLY_EVENTS_FRIDAY_02
attr vallox_cloud reading65557099JSON data_65557_marks_03:00 5
attr vallox_cloud reading65557099Name EXT_CYC_WEEKLY_EVENTS_FRIDAY_03
attr vallox_cloud reading65557100JSON data_65557_marks_04:00 5
attr vallox_cloud reading65557100Name EXT_CYC_WEEKLY_EVENTS_FRIDAY_04
attr vallox_cloud reading65557101JSON data_65557_marks_05:00 5
attr vallox_cloud reading65557101Name EXT_CYC_WEEKLY_EVENTS_FRIDAY_05
attr vallox_cloud reading65557102JSON data_65557_marks_06:00 5
attr vallox_cloud reading65557102Name EXT_CYC_WEEKLY_EVENTS_FRIDAY_06
attr vallox_cloud reading65557103JSON data_65557_marks_07:00 5
attr vallox_cloud reading65557103Name EXT_CYC_WEEKLY_EVENTS_FRIDAY_07
attr vallox_cloud reading65557104JSON data_65557_marks_08:00 5
attr vallox_cloud reading65557104Name EXT_CYC_WEEKLY_EVENTS_FRIDAY_08
attr vallox_cloud reading65557105JSON data_65557_marks_09:00 5
attr vallox_cloud reading65557105Name EXT_CYC_WEEKLY_EVENTS_FRIDAY_09
attr vallox_cloud reading65557106JSON data_65557_marks_10:00 5
attr vallox_cloud reading65557106Name EXT_CYC_WEEKLY_EVENTS_FRIDAY_10
attr vallox_cloud reading65557107JSON data_65557_marks_11:00 5
attr vallox_cloud reading65557107Name EXT_CYC_WEEKLY_EVENTS_FRIDAY_11
attr vallox_cloud reading65557108JSON data_65557_marks_12:00 5
attr vallox_cloud reading65557108Name EXT_CYC_WEEKLY_EVENTS_FRIDAY_12
attr vallox_cloud reading65557109JSON data_65557_marks_13:00 5
attr vallox_cloud reading65557109Name EXT_CYC_WEEKLY_EVENTS_FRIDAY_13
attr vallox_cloud reading65557110JSON data_65557_marks_14:00 5
attr vallox_cloud reading65557110Name EXT_CYC_WEEKLY_EVENTS_FRIDAY_14
attr vallox_cloud reading65557111JSON data_65557_marks_15:00 5
attr vallox_cloud reading65557111Name EXT_CYC_WEEKLY_EVENTS_FRIDAY_15
attr vallox_cloud reading65557112JSON data_65557_marks_16:00 5
attr vallox_cloud reading65557112Name EXT_CYC_WEEKLY_EVENTS_FRIDAY_16
attr vallox_cloud reading65557113JSON data_65557_marks_17:00 5
attr vallox_cloud reading65557113Name EXT_CYC_WEEKLY_EVENTS_FRIDAY_17
attr vallox_cloud reading65557114JSON data_65557_marks_18:00 5
attr vallox_cloud reading65557114Name EXT_CYC_WEEKLY_EVENTS_FRIDAY_18
attr vallox_cloud reading65557115JSON data_65557_marks_19:00 5
attr vallox_cloud reading65557115Name EXT_CYC_WEEKLY_EVENTS_FRIDAY_19
attr vallox_cloud reading65557116JSON data_65557_marks_20:00 5
attr vallox_cloud reading65557116Name EXT_CYC_WEEKLY_EVENTS_FRIDAY_20
attr vallox_cloud reading65557117JSON data_65557_marks_21:00 5
attr vallox_cloud reading65557117Name EXT_CYC_WEEKLY_EVENTS_FRIDAY_21
attr vallox_cloud reading65557118JSON data_65557_marks_22:00 5
attr vallox_cloud reading65557118Name EXT_CYC_WEEKLY_EVENTS_FRIDAY_22
attr vallox_cloud reading65557119JSON data_65557_marks_23:00 5
attr vallox_cloud reading65557119Name EXT_CYC_WEEKLY_EVENTS_FRIDAY_23
attr vallox_cloud reading65557120JSON data_65557_marks_00:00 6
attr vallox_cloud reading65557120Name EXT_CYC_WEEKLY_EVENTS_SATURDAY_00
attr vallox_cloud reading65557121JSON data_65557_marks_01:00 6
attr vallox_cloud reading65557121Name EXT_CYC_WEEKLY_EVENTS_SATURDAY_01
attr vallox_cloud reading65557122JSON data_65557_marks_02:00 6
attr vallox_cloud reading65557122Name EXT_CYC_WEEKLY_EVENTS_SATURDAY_02
attr vallox_cloud reading65557123JSON data_65557_marks_03:00 6
attr vallox_cloud reading65557123Name EXT_CYC_WEEKLY_EVENTS_SATURDAY_03
attr vallox_cloud reading65557124JSON data_65557_marks_04:00 6
attr vallox_cloud reading65557124Name EXT_CYC_WEEKLY_EVENTS_SATURDAY_04
attr vallox_cloud reading65557125JSON data_65557_marks_05:00 6
attr vallox_cloud reading65557125Name EXT_CYC_WEEKLY_EVENTS_SATURDAY_05
attr vallox_cloud reading65557126JSON data_65557_marks_06:00 6
attr vallox_cloud reading65557126Name EXT_CYC_WEEKLY_EVENTS_SATURDAY_06
attr vallox_cloud reading65557127JSON data_65557_marks_07:00 6
attr vallox_cloud reading65557127Name EXT_CYC_WEEKLY_EVENTS_SATURDAY_07
attr vallox_cloud reading65557128JSON data_65557_marks_08:00 6
attr vallox_cloud reading65557128Name EXT_CYC_WEEKLY_EVENTS_SATURDAY_08
attr vallox_cloud reading65557129JSON data_65557_marks_09:00 6
attr vallox_cloud reading65557129Name EXT_CYC_WEEKLY_EVENTS_SATURDAY_09
attr vallox_cloud reading65557130JSON data_65557_marks_10:00 6
attr vallox_cloud reading65557130Name EXT_CYC_WEEKLY_EVENTS_SATURDAY_10
attr vallox_cloud reading65557131JSON data_65557_marks_11:00 6
attr vallox_cloud reading65557131Name EXT_CYC_WEEKLY_EVENTS_SATURDAY_11
attr vallox_cloud reading65557132JSON data_65557_marks_12:00 6
attr vallox_cloud reading65557132Name EXT_CYC_WEEKLY_EVENTS_SATURDAY_12
attr vallox_cloud reading65557133JSON data_65557_marks_13:00 6
attr vallox_cloud reading65557133Name EXT_CYC_WEEKLY_EVENTS_SATURDAY_13
attr vallox_cloud reading65557134JSON data_65557_marks_14:00 6
attr vallox_cloud reading65557134Name EXT_CYC_WEEKLY_EVENTS_SATURDAY_14
attr vallox_cloud reading65557135JSON data_65557_marks_15:00 6
attr vallox_cloud reading65557135Name EXT_CYC_WEEKLY_EVENTS_SATURDAY_15
attr vallox_cloud reading65557136JSON data_65557_marks_16:00 6
attr vallox_cloud reading65557136Name EXT_CYC_WEEKLY_EVENTS_SATURDAY_16
attr vallox_cloud reading65557137JSON data_65557_marks_17:00 6
attr vallox_cloud reading65557137Name EXT_CYC_WEEKLY_EVENTS_SATURDAY_17
attr vallox_cloud reading65557138JSON data_65557_marks_18:00 6
attr vallox_cloud reading65557138Name EXT_CYC_WEEKLY_EVENTS_SATURDAY_18
attr vallox_cloud reading65557139JSON data_65557_marks_19:00 6
attr vallox_cloud reading65557139Name EXT_CYC_WEEKLY_EVENTS_SATURDAY_19
attr vallox_cloud reading65557140JSON data_65557_marks_20:00 6
attr vallox_cloud reading65557140Name EXT_CYC_WEEKLY_EVENTS_SATURDAY_20
attr vallox_cloud reading65557141JSON data_65557_marks_21:00 6
attr vallox_cloud reading65557141Name EXT_CYC_WEEKLY_EVENTS_SATURDAY_21
attr vallox_cloud reading65557142JSON data_65557_marks_22:00 6
attr vallox_cloud reading65557142Name EXT_CYC_WEEKLY_EVENTS_SATURDAY_22
attr vallox_cloud reading65557143JSON data_65557_marks_23:00 6
attr vallox_cloud reading65557143Name EXT_CYC_WEEKLY_EVENTS_SATURDAY_23
attr vallox_cloud reading65557144JSON data_65557_marks_00:00 0
attr vallox_cloud reading65557144Name EXT_CYC_WEEKLY_EVENTS_SUNDAY_00
attr vallox_cloud reading65557145JSON data_65557_marks_01:00 0
attr vallox_cloud reading65557145Name EXT_CYC_WEEKLY_EVENTS_SUNDAY_01
attr vallox_cloud reading65557146JSON data_65557_marks_02:00 0
attr vallox_cloud reading65557146Name EXT_CYC_WEEKLY_EVENTS_SUNDAY_02
attr vallox_cloud reading65557147JSON data_65557_marks_03:00 0
attr vallox_cloud reading65557147Name EXT_CYC_WEEKLY_EVENTS_SUNDAY_03
attr vallox_cloud reading65557148JSON data_65557_marks_04:00 0
attr vallox_cloud reading65557148Name EXT_CYC_WEEKLY_EVENTS_SUNDAY_04
attr vallox_cloud reading65557149JSON data_65557_marks_05:00 0
attr vallox_cloud reading65557149Name EXT_CYC_WEEKLY_EVENTS_SUNDAY_05
attr vallox_cloud reading65557150JSON data_65557_marks_06:00 0
attr vallox_cloud reading65557150Name EXT_CYC_WEEKLY_EVENTS_SUNDAY_06
attr vallox_cloud reading65557151JSON data_65557_marks_07:00 0
attr vallox_cloud reading65557151Name EXT_CYC_WEEKLY_EVENTS_SUNDAY_07
attr vallox_cloud reading65557152JSON data_65557_marks_08:00 0
attr vallox_cloud reading65557152Name EXT_CYC_WEEKLY_EVENTS_SUNDAY_08
attr vallox_cloud reading65557153JSON data_65557_marks_09:00 0
attr vallox_cloud reading65557153Name EXT_CYC_WEEKLY_EVENTS_SUNDAY_09
attr vallox_cloud reading65557154JSON data_65557_marks_10:00 0
attr vallox_cloud reading65557154Name EXT_CYC_WEEKLY_EVENTS_SUNDAY_10
attr vallox_cloud reading65557155JSON data_65557_marks_11:00 0
attr vallox_cloud reading65557155Name EXT_CYC_WEEKLY_EVENTS_SUNDAY_11
attr vallox_cloud reading65557156JSON data_65557_marks_12:00 0
attr vallox_cloud reading65557156Name EXT_CYC_WEEKLY_EVENTS_SUNDAY_12
attr vallox_cloud reading65557157JSON data_65557_marks_13:00 0
attr vallox_cloud reading65557157Name EXT_CYC_WEEKLY_EVENTS_SUNDAY_13
attr vallox_cloud reading65557158JSON data_65557_marks_14:00 0
attr vallox_cloud reading65557158Name EXT_CYC_WEEKLY_EVENTS_SUNDAY_14
attr vallox_cloud reading65557159JSON data_65557_marks_15:00 0
attr vallox_cloud reading65557159Name EXT_CYC_WEEKLY_EVENTS_SUNDAY_15
attr vallox_cloud reading65557160JSON data_65557_marks_16:00 0
attr vallox_cloud reading65557160Name EXT_CYC_WEEKLY_EVENTS_SUNDAY_16
attr vallox_cloud reading65557161JSON data_65557_marks_17:00 0
attr vallox_cloud reading65557161Name EXT_CYC_WEEKLY_EVENTS_SUNDAY_17
attr vallox_cloud reading65557162JSON data_65557_marks_18:00 0
attr vallox_cloud reading65557162Name EXT_CYC_WEEKLY_EVENTS_SUNDAY_18
attr vallox_cloud reading65557163JSON data_65557_marks_19:00 0
attr vallox_cloud reading65557163Name EXT_CYC_WEEKLY_EVENTS_SUNDAY_19
attr vallox_cloud reading65557164JSON data_65557_marks_20:00 0
attr vallox_cloud reading65557164Name EXT_CYC_WEEKLY_EVENTS_SUNDAY_20
attr vallox_cloud reading65557165JSON data_65557_marks_21:00 0
attr vallox_cloud reading65557165Name EXT_CYC_WEEKLY_EVENTS_SUNDAY_21
attr vallox_cloud reading65557166JSON data_65557_marks_22:00 0
attr vallox_cloud reading65557166Name EXT_CYC_WEEKLY_EVENTS_SUNDAY_22
attr vallox_cloud reading65557167JSON data_65557_marks_23:00 0
attr vallox_cloud reading65557167Name EXT_CYC_WEEKLY_EVENTS_SUNDAY_23
attr vallox_cloud reading65559JSON data_65559_value
attr vallox_cloud reading65559Map 0:no, 1:yes
attr vallox_cloud reading65559Name EXT_CYC_START_SELFTEST
attr vallox_cloud reading65559OMap 0:no, 1:yes
attr vallox_cloud reading65560JSON data_65560_value
attr vallox_cloud reading65560Name EXT_CYC_POWER
attr vallox_cloud reading65561JSON data_65561_value
attr vallox_cloud reading65561Name EXT_CYC_TIME
attr vallox_cloud reading65562JSON data_65562_value
attr vallox_cloud reading65562Name EXT_CYC_DATE
attr vallox_cloud reading65564JSON data_65564_value
attr vallox_cloud reading65564Name EXT_SHOW_WIZARD
# Hierzu habe ich keine modbus Namen gefunden
attr vallox_cloud reading65565JSON data_65565_
attr vallox_cloud reading65568JSON data_65568_value
attr vallox_cloud reading65568Name EXT_CYC_SUPP_FAN_SPEED
attr vallox_cloud reading65569JSON data_65569_value
attr vallox_cloud reading65569Name EXT_CYC_EXTR_FAN_SPEED
attr vallox_cloud reading65572JSON data_65572_value
attr vallox_cloud reading65572Name EXT_TEST_MODE_SWITCH
attr vallox_cloud reading65579JSON data_65579_value
attr vallox_cloud reading65579Name EXT_HOME_AIR_TEMP_TARGET
attr vallox_cloud reading65580JSON data_65580_value
attr vallox_cloud reading65580Name EXT_AWAY_AIR_TEMP_TARGET
attr vallox_cloud reading65581JSON data_65581_value
attr vallox_cloud reading65581Name EXT_BOOST_AIR_TEMP_TARGET
attr vallox_cloud reading65590000JSON data_65590_00:00 1
attr vallox_cloud reading65590000Name EXT_CYC_OLD_WEEKLY_EVENTS_MONDAY_00
attr vallox_cloud reading65590001JSON data_65590_01:00 1
attr vallox_cloud reading65590001Name EXT_CYC_OLD_WEEKLY_EVENTS_MONDAY_01
attr vallox_cloud reading65590002JSON data_65590_02:00 1
attr vallox_cloud reading65590002Name EXT_CYC_OLD_WEEKLY_EVENTS_MONDAY_02
attr vallox_cloud reading65590003JSON data_65590_03:00 1
attr vallox_cloud reading65590003Name EXT_CYC_OLD_WEEKLY_EVENTS_MONDAY_03
attr vallox_cloud reading65590004JSON data_65590_04:00 1
attr vallox_cloud reading65590004Name EXT_CYC_OLD_WEEKLY_EVENTS_MONDAY_04
attr vallox_cloud reading65590005JSON data_65590_05:00 1
attr vallox_cloud reading65590005Name EXT_CYC_OLD_WEEKLY_EVENTS_MONDAY_05
attr vallox_cloud reading65590006JSON data_65590_06:00 1
attr vallox_cloud reading65590006Name EXT_CYC_OLD_WEEKLY_EVENTS_MONDAY_06
attr vallox_cloud reading65590007JSON data_65590_07:00 1
attr vallox_cloud reading65590007Name EXT_CYC_OLD_WEEKLY_EVENTS_MONDAY_07
attr vallox_cloud reading65590008JSON data_65590_08:00 1
attr vallox_cloud reading65590008Name EXT_CYC_OLD_WEEKLY_EVENTS_MONDAY_08
attr vallox_cloud reading65590009JSON data_65590_09:00 1
attr vallox_cloud reading65590009Name EXT_CYC_OLD_WEEKLY_EVENTS_MONDAY_09
attr vallox_cloud reading65590010JSON data_65590_10:00 1
attr vallox_cloud reading65590010Name EXT_CYC_OLD_WEEKLY_EVENTS_MONDAY_10
attr vallox_cloud reading65590011JSON data_65590_11:00 1
attr vallox_cloud reading65590011Name EXT_CYC_OLD_WEEKLY_EVENTS_MONDAY_11
attr vallox_cloud reading65590012JSON data_65590_12:00 1
attr vallox_cloud reading65590012Name EXT_CYC_OLD_WEEKLY_EVENTS_MONDAY_12
attr vallox_cloud reading65590013JSON data_65590_13:00 1
attr vallox_cloud reading65590013Name EXT_CYC_OLD_WEEKLY_EVENTS_MONDAY_13
attr vallox_cloud reading65590014JSON data_65590_14:00 1
attr vallox_cloud reading65590014Name EXT_CYC_OLD_WEEKLY_EVENTS_MONDAY_14
attr vallox_cloud reading65590015JSON data_65590_15:00 1
attr vallox_cloud reading65590015Name EXT_CYC_OLD_WEEKLY_EVENTS_MONDAY_15
attr vallox_cloud reading65590016JSON data_65590_16:00 1
attr vallox_cloud reading65590016Name EXT_CYC_OLD_WEEKLY_EVENTS_MONDAY_16
attr vallox_cloud reading65590017JSON data_65590_17:00 1
attr vallox_cloud reading65590017Name EXT_CYC_OLD_WEEKLY_EVENTS_MONDAY_17
attr vallox_cloud reading65590018JSON data_65590_18:00 1
attr vallox_cloud reading65590018Name EXT_CYC_OLD_WEEKLY_EVENTS_MONDAY_18
attr vallox_cloud reading65590019JSON data_65590_19:00 1
attr vallox_cloud reading65590019Name EXT_CYC_OLD_WEEKLY_EVENTS_MONDAY_19
attr vallox_cloud reading65590020JSON data_65590_20:00 1
attr vallox_cloud reading65590020Name EXT_CYC_OLD_WEEKLY_EVENTS_MONDAY_20
attr vallox_cloud reading65590021JSON data_65590_21:00 1
attr vallox_cloud reading65590021Name EXT_CYC_OLD_WEEKLY_EVENTS_MONDAY_21
attr vallox_cloud reading65590022JSON data_65590_22:00 1
attr vallox_cloud reading65590022Name EXT_CYC_OLD_WEEKLY_EVENTS_MONDAY_22
attr vallox_cloud reading65590023JSON data_65590_23:00 1
attr vallox_cloud reading65590023Name EXT_CYC_OLD_WEEKLY_EVENTS_MONDAY_23
attr vallox_cloud reading65590024JSON data_65590_00:00 2
attr vallox_cloud reading65590024Name EXT_CYC_OLD_WEEKLY_EVENTS_TUESDAY_00
attr vallox_cloud reading65590025JSON data_65590_01:00 2
attr vallox_cloud reading65590025Name EXT_CYC_OLD_WEEKLY_EVENTS_TUESDAY_01
attr vallox_cloud reading65590026JSON data_65590_02:00 2
attr vallox_cloud reading65590026Name EXT_CYC_OLD_WEEKLY_EVENTS_TUESDAY_02
attr vallox_cloud reading65590027JSON data_65590_03:00 2
attr vallox_cloud reading65590027Name EXT_CYC_OLD_WEEKLY_EVENTS_TUESDAY_03
attr vallox_cloud reading65590028JSON data_65590_04:00 2
attr vallox_cloud reading65590028Name EXT_CYC_OLD_WEEKLY_EVENTS_TUESDAY_04
attr vallox_cloud reading65590029JSON data_65590_05:00 2
attr vallox_cloud reading65590029Name EXT_CYC_OLD_WEEKLY_EVENTS_TUESDAY_05
attr vallox_cloud reading65590030JSON data_65590_06:00 2
attr vallox_cloud reading65590030Name EXT_CYC_OLD_WEEKLY_EVENTS_TUESDAY_06
attr vallox_cloud reading65590031JSON data_65590_07:00 2
attr vallox_cloud reading65590031Name EXT_CYC_OLD_WEEKLY_EVENTS_TUESDAY_07
attr vallox_cloud reading65590032JSON data_65590_08:00 2
attr vallox_cloud reading65590032Name EXT_CYC_OLD_WEEKLY_EVENTS_TUESDAY_08
attr vallox_cloud reading65590033JSON data_65590_09:00 2
attr vallox_cloud reading65590033Name EXT_CYC_OLD_WEEKLY_EVENTS_TUESDAY_09
attr vallox_cloud reading65590034JSON data_65590_10:00 2
attr vallox_cloud reading65590034Name EXT_CYC_OLD_WEEKLY_EVENTS_TUESDAY_10
attr vallox_cloud reading65590035JSON data_65590_11:00 2
attr vallox_cloud reading65590035Name EXT_CYC_OLD_WEEKLY_EVENTS_TUESDAY_11
attr vallox_cloud reading65590036JSON data_65590_12:00 2
attr vallox_cloud reading65590036Name EXT_CYC_OLD_WEEKLY_EVENTS_TUESDAY_12
attr vallox_cloud reading65590037JSON data_65590_13:00 2
attr vallox_cloud reading65590037Name EXT_CYC_OLD_WEEKLY_EVENTS_TUESDAY_13
attr vallox_cloud reading65590038JSON data_65590_14:00 2
attr vallox_cloud reading65590038Name EXT_CYC_OLD_WEEKLY_EVENTS_TUESDAY_14
attr vallox_cloud reading65590039JSON data_65590_15:00 2
attr vallox_cloud reading65590039Name EXT_CYC_OLD_WEEKLY_EVENTS_TUESDAY_15
attr vallox_cloud reading65590040JSON data_65590_16:00 2
attr vallox_cloud reading65590040Name EXT_CYC_OLD_WEEKLY_EVENTS_TUESDAY_16
attr vallox_cloud reading65590041JSON data_65590_17:00 2
attr vallox_cloud reading65590041Name EXT_CYC_OLD_WEEKLY_EVENTS_TUESDAY_17
attr vallox_cloud reading65590042JSON data_65590_18:00 2
attr vallox_cloud reading65590042Name EXT_CYC_OLD_WEEKLY_EVENTS_TUESDAY_18
attr vallox_cloud reading65590043JSON data_65590_19:00 2
attr vallox_cloud reading65590043Name EXT_CYC_OLD_WEEKLY_EVENTS_TUESDAY_19
attr vallox_cloud reading65590044JSON data_65590_20:00 2
attr vallox_cloud reading65590044Name EXT_CYC_OLD_WEEKLY_EVENTS_TUESDAY_20
attr vallox_cloud reading65590045JSON data_65590_21:00 2
attr vallox_cloud reading65590045Name EXT_CYC_OLD_WEEKLY_EVENTS_TUESDAY_21
attr vallox_cloud reading65590046JSON data_65590_22:00 2
attr vallox_cloud reading65590046Name EXT_CYC_OLD_WEEKLY_EVENTS_TUESDAY_22
attr vallox_cloud reading65590047JSON data_65590_23:00 2
attr vallox_cloud reading65590047Name EXT_CYC_OLD_WEEKLY_EVENTS_TUESDAY_23
attr vallox_cloud reading65590048JSON data_65590_00:00 3
attr vallox_cloud reading65590048Name EXT_CYC_OLD_WEEKLY_EVENTS_WEDNESDAY_00
attr vallox_cloud reading65590049JSON data_65590_01:00 3
attr vallox_cloud reading65590049Name EXT_CYC_OLD_WEEKLY_EVENTS_WEDNESDAY_01
attr vallox_cloud reading65590050JSON data_65590_02:00 3
attr vallox_cloud reading65590050Name EXT_CYC_OLD_WEEKLY_EVENTS_WEDNESDAY_02
attr vallox_cloud reading65590051JSON data_65590_03:00 3
attr vallox_cloud reading65590051Name EXT_CYC_OLD_WEEKLY_EVENTS_WEDNESDAY_03
attr vallox_cloud reading65590052JSON data_65590_04:00 3
attr vallox_cloud reading65590052Name EXT_CYC_OLD_WEEKLY_EVENTS_WEDNESDAY_04
attr vallox_cloud reading65590053JSON data_65590_05:00 3
attr vallox_cloud reading65590053Name EXT_CYC_OLD_WEEKLY_EVENTS_WEDNESDAY_05
attr vallox_cloud reading65590054JSON data_65590_06:00 3
attr vallox_cloud reading65590054Name EXT_CYC_OLD_WEEKLY_EVENTS_WEDNESDAY_06
attr vallox_cloud reading65590055JSON data_65590_07:00 3
attr vallox_cloud reading65590055Name EXT_CYC_OLD_WEEKLY_EVENTS_WEDNESDAY_07
attr vallox_cloud reading65590056JSON data_65590_08:00 3
attr vallox_cloud reading65590056Name EXT_CYC_OLD_WEEKLY_EVENTS_WEDNESDAY_08
attr vallox_cloud reading65590057JSON data_65590_09:00 3
attr vallox_cloud reading65590057Name EXT_CYC_OLD_WEEKLY_EVENTS_WEDNESDAY_09
attr vallox_cloud reading65590058JSON data_65590_10:00 3
attr vallox_cloud reading65590058Name EXT_CYC_OLD_WEEKLY_EVENTS_WEDNESDAY_10
attr vallox_cloud reading65590059JSON data_65590_11:00 3
attr vallox_cloud reading65590059Name EXT_CYC_OLD_WEEKLY_EVENTS_WEDNESDAY_11
attr vallox_cloud reading65590060JSON data_65590_12:00 3
attr vallox_cloud reading65590060Name EXT_CYC_OLD_WEEKLY_EVENTS_WEDNESDAY_12
attr vallox_cloud reading65590061JSON data_65590_13:00 3
attr vallox_cloud reading65590061Name EXT_CYC_OLD_WEEKLY_EVENTS_WEDNESDAY_13
attr vallox_cloud reading65590062JSON data_65590_14:00 3
attr vallox_cloud reading65590062Name EXT_CYC_OLD_WEEKLY_EVENTS_WEDNESDAY_14
attr vallox_cloud reading65590063JSON data_65590_15:00 3
attr vallox_cloud reading65590063Name EXT_CYC_OLD_WEEKLY_EVENTS_WEDNESDAY_15
attr vallox_cloud reading65590064JSON data_65590_16:00 3
attr vallox_cloud reading65590064Name EXT_CYC_OLD_WEEKLY_EVENTS_WEDNESDAY_16
attr vallox_cloud reading65590065JSON data_65590_17:00 3
attr vallox_cloud reading65590065Name EXT_CYC_OLD_WEEKLY_EVENTS_WEDNESDAY_17
attr vallox_cloud reading65590066JSON data_65590_18:00 3
attr vallox_cloud reading65590066Name EXT_CYC_OLD_WEEKLY_EVENTS_WEDNESDAY_18
attr vallox_cloud reading65590067JSON data_65590_19:00 3
attr vallox_cloud reading65590067Name EXT_CYC_OLD_WEEKLY_EVENTS_WEDNESDAY_19
attr vallox_cloud reading65590068JSON data_65590_20:00 3
attr vallox_cloud reading65590068Name EXT_CYC_OLD_WEEKLY_EVENTS_WEDNESDAY_20
attr vallox_cloud reading65590069JSON data_65590_21:00 3
attr vallox_cloud reading65590069Name EXT_CYC_OLD_WEEKLY_EVENTS_WEDNESDAY_21
attr vallox_cloud reading65590070JSON data_65590_22:00 3
attr vallox_cloud reading65590070Name EXT_CYC_OLD_WEEKLY_EVENTS_WEDNESDAY_22
attr vallox_cloud reading65590071JSON data_65590_23:00 3
attr vallox_cloud reading65590071Name EXT_CYC_OLD_WEEKLY_EVENTS_WEDNESDAY_23
attr vallox_cloud reading65590072JSON data_65590_00:00 4
attr vallox_cloud reading65590072Name EXT_CYC_OLD_WEEKLY_EVENTS_THURSDAY_00
attr vallox_cloud reading65590073JSON data_65590_01:00 4
attr vallox_cloud reading65590073Name EXT_CYC_OLD_WEEKLY_EVENTS_THURSDAY_01
attr vallox_cloud reading65590074JSON data_65590_02:00 4
attr vallox_cloud reading65590074Name EXT_CYC_OLD_WEEKLY_EVENTS_THURSDAY_02
attr vallox_cloud reading65590075JSON data_65590_03:00 4
attr vallox_cloud reading65590075Name EXT_CYC_OLD_WEEKLY_EVENTS_THURSDAY_03
attr vallox_cloud reading65590076JSON data_65590_04:00 4
attr vallox_cloud reading65590076Name EXT_CYC_OLD_WEEKLY_EVENTS_THURSDAY_04
attr vallox_cloud reading65590077JSON data_65590_05:00 4
attr vallox_cloud reading65590077Name EXT_CYC_OLD_WEEKLY_EVENTS_THURSDAY_05
attr vallox_cloud reading65590078JSON data_65590_06:00 4
attr vallox_cloud reading65590078Name EXT_CYC_OLD_WEEKLY_EVENTS_THURSDAY_06
attr vallox_cloud reading65590079JSON data_65590_07:00 4
attr vallox_cloud reading65590079Name EXT_CYC_OLD_WEEKLY_EVENTS_THURSDAY_07
attr vallox_cloud reading65590080JSON data_65590_08:00 4
attr vallox_cloud reading65590080Name EXT_CYC_OLD_WEEKLY_EVENTS_THURSDAY_08
attr vallox_cloud reading65590081JSON data_65590_09:00 4
attr vallox_cloud reading65590081Name EXT_CYC_OLD_WEEKLY_EVENTS_THURSDAY_09
attr vallox_cloud reading65590082JSON data_65590_10:00 4
attr vallox_cloud reading65590082Name EXT_CYC_OLD_WEEKLY_EVENTS_THURSDAY_10
attr vallox_cloud reading65590083JSON data_65590_11:00 4
attr vallox_cloud reading65590083Name EXT_CYC_OLD_WEEKLY_EVENTS_THURSDAY_11
attr vallox_cloud reading65590084JSON data_65590_12:00 4
attr vallox_cloud reading65590084Name EXT_CYC_OLD_WEEKLY_EVENTS_THURSDAY_12
attr vallox_cloud reading65590085JSON data_65590_13:00 4
attr vallox_cloud reading65590085Name EXT_CYC_OLD_WEEKLY_EVENTS_THURSDAY_13
attr vallox_cloud reading65590086JSON data_65590_14:00 4
attr vallox_cloud reading65590086Name EXT_CYC_OLD_WEEKLY_EVENTS_THURSDAY_14
attr vallox_cloud reading65590087JSON data_65590_15:00 4
attr vallox_cloud reading65590087Name EXT_CYC_OLD_WEEKLY_EVENTS_THURSDAY_15
attr vallox_cloud reading65590088JSON data_65590_16:00 4
attr vallox_cloud reading65590088Name EXT_CYC_OLD_WEEKLY_EVENTS_THURSDAY_16
attr vallox_cloud reading65590089JSON data_65590_17:00 4
attr vallox_cloud reading65590089Name EXT_CYC_OLD_WEEKLY_EVENTS_THURSDAY_17
attr vallox_cloud reading65590090JSON data_65590_18:00 4
attr vallox_cloud reading65590090Name EXT_CYC_OLD_WEEKLY_EVENTS_THURSDAY_18
attr vallox_cloud reading65590091JSON data_65590_19:00 4
attr vallox_cloud reading65590091Name EXT_CYC_OLD_WEEKLY_EVENTS_THURSDAY_19
attr vallox_cloud reading65590092JSON data_65590_20:00 4
attr vallox_cloud reading65590092Name EXT_CYC_OLD_WEEKLY_EVENTS_THURSDAY_20
attr vallox_cloud reading65590093JSON data_65590_21:00 4
attr vallox_cloud reading65590093Name EXT_CYC_OLD_WEEKLY_EVENTS_THURSDAY_21
attr vallox_cloud reading65590094JSON data_65590_22:00 4
attr vallox_cloud reading65590094Name EXT_CYC_OLD_WEEKLY_EVENTS_THURSDAY_22
attr vallox_cloud reading65590095JSON data_65590_23:00 4
attr vallox_cloud reading65590095Name EXT_CYC_OLD_WEEKLY_EVENTS_THURSDAY_23
attr vallox_cloud reading65590096JSON data_65590_00:00 5
attr vallox_cloud reading65590096Name EXT_CYC_OLD_WEEKLY_EVENTS_FRIDAY_00
attr vallox_cloud reading65590097JSON data_65590_01:00 5
attr vallox_cloud reading65590097Name EXT_CYC_OLD_WEEKLY_EVENTS_FRIDAY_01
attr vallox_cloud reading65590098JSON data_65590_02:00 5
attr vallox_cloud reading65590098Name EXT_CYC_OLD_WEEKLY_EVENTS_FRIDAY_02
attr vallox_cloud reading65590099JSON data_65590_03:00 5
attr vallox_cloud reading65590099Name EXT_CYC_OLD_WEEKLY_EVENTS_FRIDAY_03
attr vallox_cloud reading65590100JSON data_65590_04:00 5
attr vallox_cloud reading65590100Name EXT_CYC_OLD_WEEKLY_EVENTS_FRIDAY_04
attr vallox_cloud reading65590101JSON data_65590_05:00 5
attr vallox_cloud reading65590101Name EXT_CYC_OLD_WEEKLY_EVENTS_FRIDAY_05
attr vallox_cloud reading65590102JSON data_65590_06:00 5
attr vallox_cloud reading65590102Name EXT_CYC_OLD_WEEKLY_EVENTS_FRIDAY_06
attr vallox_cloud reading65590103JSON data_65590_07:00 5
attr vallox_cloud reading65590103Name EXT_CYC_OLD_WEEKLY_EVENTS_FRIDAY_07
attr vallox_cloud reading65590104JSON data_65590_08:00 5
attr vallox_cloud reading65590104Name EXT_CYC_OLD_WEEKLY_EVENTS_FRIDAY_08
attr vallox_cloud reading65590105JSON data_65590_09:00 5
attr vallox_cloud reading65590105Name EXT_CYC_OLD_WEEKLY_EVENTS_FRIDAY_09
attr vallox_cloud reading65590106JSON data_65590_10:00 5
attr vallox_cloud reading65590106Name EXT_CYC_OLD_WEEKLY_EVENTS_FRIDAY_10
attr vallox_cloud reading65590107JSON data_65590_11:00 5
attr vallox_cloud reading65590107Name EXT_CYC_OLD_WEEKLY_EVENTS_FRIDAY_11
attr vallox_cloud reading65590108JSON data_65590_12:00 5
attr vallox_cloud reading65590108Name EXT_CYC_OLD_WEEKLY_EVENTS_FRIDAY_12
attr vallox_cloud reading65590109JSON data_65590_13:00 5
attr vallox_cloud reading65590109Name EXT_CYC_OLD_WEEKLY_EVENTS_FRIDAY_13
attr vallox_cloud reading65590110JSON data_65590_14:00 5
attr vallox_cloud reading65590110Name EXT_CYC_OLD_WEEKLY_EVENTS_FRIDAY_14
attr vallox_cloud reading65590111JSON data_65590_15:00 5
attr vallox_cloud reading65590111Name EXT_CYC_OLD_WEEKLY_EVENTS_FRIDAY_15
attr vallox_cloud reading65590112JSON data_65590_16:00 5
attr vallox_cloud reading65590112Name EXT_CYC_OLD_WEEKLY_EVENTS_FRIDAY_16
attr vallox_cloud reading65590113JSON data_65590_17:00 5
attr vallox_cloud reading65590113Name EXT_CYC_OLD_WEEKLY_EVENTS_FRIDAY_17
attr vallox_cloud reading65590114JSON data_65590_18:00 5
attr vallox_cloud reading65590114Name EXT_CYC_OLD_WEEKLY_EVENTS_FRIDAY_18
attr vallox_cloud reading65590115JSON data_65590_19:00 5
attr vallox_cloud reading65590115Name EXT_CYC_OLD_WEEKLY_EVENTS_FRIDAY_19
attr vallox_cloud reading65590116JSON data_65590_20:00 5
attr vallox_cloud reading65590116Name EXT_CYC_OLD_WEEKLY_EVENTS_FRIDAY_20
attr vallox_cloud reading65590117JSON data_65590_21:00 5
attr vallox_cloud reading65590117Name EXT_CYC_OLD_WEEKLY_EVENTS_FRIDAY_21
attr vallox_cloud reading65590118JSON data_65590_22:00 5
attr vallox_cloud reading65590118Name EXT_CYC_OLD_WEEKLY_EVENTS_FRIDAY_22
attr vallox_cloud reading65590119JSON data_65590_23:00 5
attr vallox_cloud reading65590119Name EXT_CYC_OLD_WEEKLY_EVENTS_FRIDAY_23
attr vallox_cloud reading65590120JSON data_65590_00:00 6
attr vallox_cloud reading65590120Name EXT_CYC_OLD_WEEKLY_EVENTS_SATURDAY_00
attr vallox_cloud reading65590121JSON data_65590_01:00 6
attr vallox_cloud reading65590121Name EXT_CYC_OLD_WEEKLY_EVENTS_SATURDAY_01
attr vallox_cloud reading65590122JSON data_65590_02:00 6
attr vallox_cloud reading65590122Name EXT_CYC_OLD_WEEKLY_EVENTS_SATURDAY_02
attr vallox_cloud reading65590123JSON data_65590_03:00 6
attr vallox_cloud reading65590123Name EXT_CYC_OLD_WEEKLY_EVENTS_SATURDAY_03
attr vallox_cloud reading65590124JSON data_65590_04:00 6
attr vallox_cloud reading65590124Name EXT_CYC_OLD_WEEKLY_EVENTS_SATURDAY_04
attr vallox_cloud reading65590125JSON data_65590_05:00 6
attr vallox_cloud reading65590125Name EXT_CYC_OLD_WEEKLY_EVENTS_SATURDAY_05
attr vallox_cloud reading65590126JSON data_65590_06:00 6
attr vallox_cloud reading65590126Name EXT_CYC_OLD_WEEKLY_EVENTS_SATURDAY_06
attr vallox_cloud reading65590127JSON data_65590_07:00 6
attr vallox_cloud reading65590127Name EXT_CYC_OLD_WEEKLY_EVENTS_SATURDAY_07
attr vallox_cloud reading65590128JSON data_65590_08:00 6
attr vallox_cloud reading65590128Name EXT_CYC_OLD_WEEKLY_EVENTS_SATURDAY_08
attr vallox_cloud reading65590129JSON data_65590_09:00 6
attr vallox_cloud reading65590129Name EXT_CYC_OLD_WEEKLY_EVENTS_SATURDAY_09
attr vallox_cloud reading65590130JSON data_65590_10:00 6
attr vallox_cloud reading65590130Name EXT_CYC_OLD_WEEKLY_EVENTS_SATURDAY_10
attr vallox_cloud reading65590131JSON data_65590_11:00 6
attr vallox_cloud reading65590131Name EXT_CYC_OLD_WEEKLY_EVENTS_SATURDAY_11
attr vallox_cloud reading65590132JSON data_65590_12:00 6
attr vallox_cloud reading65590132Name EXT_CYC_OLD_WEEKLY_EVENTS_SATURDAY_12
attr vallox_cloud reading65590133JSON data_65590_13:00 6
attr vallox_cloud reading65590133Name EXT_CYC_OLD_WEEKLY_EVENTS_SATURDAY_13
attr vallox_cloud reading65590134JSON data_65590_14:00 6
attr vallox_cloud reading65590134Name EXT_CYC_OLD_WEEKLY_EVENTS_SATURDAY_14
attr vallox_cloud reading65590135JSON data_65590_15:00 6
attr vallox_cloud reading65590135Name EXT_CYC_OLD_WEEKLY_EVENTS_SATURDAY_15
attr vallox_cloud reading65590136JSON data_65590_16:00 6
attr vallox_cloud reading65590136Name EXT_CYC_OLD_WEEKLY_EVENTS_SATURDAY_16
attr vallox_cloud reading65590137JSON data_65590_17:00 6
attr vallox_cloud reading65590137Name EXT_CYC_OLD_WEEKLY_EVENTS_SATURDAY_17
attr vallox_cloud reading65590138JSON data_65590_18:00 6
attr vallox_cloud reading65590138Name EXT_CYC_OLD_WEEKLY_EVENTS_SATURDAY_18
attr vallox_cloud reading65590139JSON data_65590_19:00 6
attr vallox_cloud reading65590139Name EXT_CYC_OLD_WEEKLY_EVENTS_SATURDAY_19
attr vallox_cloud reading65590140JSON data_65590_20:00 6
attr vallox_cloud reading65590140Name EXT_CYC_OLD_WEEKLY_EVENTS_SATURDAY_20
attr vallox_cloud reading65590141JSON data_65590_21:00 6
attr vallox_cloud reading65590141Name EXT_CYC_OLD_WEEKLY_EVENTS_SATURDAY_21
attr vallox_cloud reading65590142JSON data_65590_22:00 6
attr vallox_cloud reading65590142Name EXT_CYC_OLD_WEEKLY_EVENTS_SATURDAY_22
attr vallox_cloud reading65590143JSON data_65590_23:00 6
attr vallox_cloud reading65590143Name EXT_CYC_OLD_WEEKLY_EVENTS_SATURDAY_23
attr vallox_cloud reading65590144JSON data_65590_00:00 0
attr vallox_cloud reading65590144Name EXT_CYC_OLD_WEEKLY_EVENTS_SUNDAY_00
attr vallox_cloud reading65590145JSON data_65590_01:00 0
attr vallox_cloud reading65590145Name EXT_CYC_OLD_WEEKLY_EVENTS_SUNDAY_01
attr vallox_cloud reading65590146JSON data_65590_02:00 0
attr vallox_cloud reading65590146Name EXT_CYC_OLD_WEEKLY_EVENTS_SUNDAY_02
attr vallox_cloud reading65590147JSON data_65590_03:00 0
attr vallox_cloud reading65590147Name EXT_CYC_OLD_WEEKLY_EVENTS_SUNDAY_03
attr vallox_cloud reading65590148JSON data_65590_04:00 0
attr vallox_cloud reading65590148Name EXT_CYC_OLD_WEEKLY_EVENTS_SUNDAY_04
attr vallox_cloud reading65590149JSON data_65590_05:00 0
attr vallox_cloud reading65590149Name EXT_CYC_OLD_WEEKLY_EVENTS_SUNDAY_05
attr vallox_cloud reading65590150JSON data_65590_06:00 0
attr vallox_cloud reading65590150Name EXT_CYC_OLD_WEEKLY_EVENTS_SUNDAY_06
attr vallox_cloud reading65590151JSON data_65590_07:00 0
attr vallox_cloud reading65590151Name EXT_CYC_OLD_WEEKLY_EVENTS_SUNDAY_07
attr vallox_cloud reading65590152JSON data_65590_08:00 0
attr vallox_cloud reading65590152Name EXT_CYC_OLD_WEEKLY_EVENTS_SUNDAY_08
attr vallox_cloud reading65590153JSON data_65590_09:00 0
attr vallox_cloud reading65590153Name EXT_CYC_OLD_WEEKLY_EVENTS_SUNDAY_09
attr vallox_cloud reading65590154JSON data_65590_10:00 0
attr vallox_cloud reading65590154Name EXT_CYC_OLD_WEEKLY_EVENTS_SUNDAY_10
attr vallox_cloud reading65590155JSON data_65590_11:00 0
attr vallox_cloud reading65590155Name EXT_CYC_OLD_WEEKLY_EVENTS_SUNDAY_11
attr vallox_cloud reading65590156JSON data_65590_12:00 0
attr vallox_cloud reading65590156Name EXT_CYC_OLD_WEEKLY_EVENTS_SUNDAY_12
attr vallox_cloud reading65590157JSON data_65590_13:00 0
attr vallox_cloud reading65590157Name EXT_CYC_OLD_WEEKLY_EVENTS_SUNDAY_13
attr vallox_cloud reading65590158JSON data_65590_14:00 0
attr vallox_cloud reading65590158Name EXT_CYC_OLD_WEEKLY_EVENTS_SUNDAY_14
attr vallox_cloud reading65590159JSON data_65590_15:00 0
attr vallox_cloud reading65590159Name EXT_CYC_OLD_WEEKLY_EVENTS_SUNDAY_15
attr vallox_cloud reading65590160JSON data_65590_16:00 0
attr vallox_cloud reading65590160Name EXT_CYC_OLD_WEEKLY_EVENTS_SUNDAY_16
attr vallox_cloud reading65590161JSON data_65590_17:00 0
attr vallox_cloud reading65590161Name EXT_CYC_OLD_WEEKLY_EVENTS_SUNDAY_17
attr vallox_cloud reading65590162JSON data_65590_18:00 0
attr vallox_cloud reading65590162Name EXT_CYC_OLD_WEEKLY_EVENTS_SUNDAY_18
attr vallox_cloud reading65590163JSON data_65590_19:00 0
attr vallox_cloud reading65590163Name EXT_CYC_OLD_WEEKLY_EVENTS_SUNDAY_19
attr vallox_cloud reading65590164JSON data_65590_20:00 0
attr vallox_cloud reading65590164Name EXT_CYC_OLD_WEEKLY_EVENTS_SUNDAY_20
attr vallox_cloud reading65590165JSON data_65590_21:00 0
attr vallox_cloud reading65590165Name EXT_CYC_OLD_WEEKLY_EVENTS_SUNDAY_21
attr vallox_cloud reading65590166JSON data_65590_22:00 0
attr vallox_cloud reading65590166Name EXT_CYC_OLD_WEEKLY_EVENTS_SUNDAY_22
attr vallox_cloud reading65590167JSON data_65590_23:00 0
attr vallox_cloud reading65590167Name EXT_CYC_OLD_WEEKLY_EVENTS_SUNDAY_23
attr vallox_cloud reading65591JSON data_65591_value
attr vallox_cloud reading65591Name EXT_DIGITAL_INPUT_1_MODE
attr vallox_cloud reading65592JSON data_65592_value
attr vallox_cloud reading65592Name EXT_DIGITAL_INPUT_2_MODE
attr vallox_cloud reading65593JSON data_65593_value
attr vallox_cloud reading65593Name EXT_ANALOG_INPUT_MODE
attr vallox_cloud reading65594JSON data_65594_value
attr vallox_cloud reading65594Name EXT_EXTRA_AIR_TEMP_TARGET
attr vallox_cloud reading65595JSON data_65595_value
attr vallox_cloud reading65595Name EXT_EXTRA_EXTR_FAN
attr vallox_cloud reading65596JSON data_65596_value
attr vallox_cloud reading65596Name EXT_EXTRA_SUPP_FAN
attr vallox_cloud reading655971JSON data_65597_value_hours
attr vallox_cloud reading655971Name EXT_EXTRA_TIME_HOURS
attr vallox_cloud reading655972JSON data_65597_value_minutes
attr vallox_cloud reading655972Name EXT_EXTRA_TIME_MINUTES
attr vallox_cloud reading65598JSON data_65598_value
attr vallox_cloud reading65598Map 0:no, 1:yes
attr vallox_cloud reading65598Name EXT_EXTRA_TIMER_ENABLED
attr vallox_cloud reading65598OMap 0:no, 1:yes
attr vallox_cloud reading65599JSON data_65599_value
attr vallox_cloud reading65599Name EXT_MACHINE_TYPE
attr vallox_cloud reading65600JSON data_65600_value
attr vallox_cloud reading65600Map 0:no, 1:yes
attr vallox_cloud reading65600Name EXT_DEFROST_ON
attr vallox_cloud reading65601JSON data_65601_value
attr vallox_cloud reading65601Name EXT_FILTER_CHANGE_INTERVAL
attr vallox_cloud reading65602JSON data_65602_value
attr vallox_cloud reading65602Map 0:no, 1:yes
attr vallox_cloud reading65602Name EXT_BOOST_TIMER_ENABLED
attr vallox_cloud reading65602OMap 0:no, 1:yes
attr vallox_cloud reading65603JSON data_65603_value
attr vallox_cloud reading65603Name EXT_BOOST_TIME
attr vallox_cloud reading65604JSON data_65604_value
attr vallox_cloud reading65604Name EXT_CYC_DEFROST_TEMP_PARAM
attr vallox_cloud reading65605JSON data_65605_value
attr vallox_cloud reading65605Name EXT_CYC_DEFROST_RH_OFFSET
attr vallox_cloud reading65607JSON data_65607_value
attr vallox_cloud reading65607Name EXT_CYC_EXTRA_HEATER_TYPE
attr vallox_cloud reading65608JSON data_65608_value
attr vallox_cloud reading65608Name EXT_CYC_POST_HEATER_TYPE
attr vallox_cloud reading65615JSON data_65615_value
attr vallox_cloud reading65615Name EXT_USERNAME
# Das sind die Device readings, ohne speziellen modbus Namen
attr vallox_cloud reading90001JSON devices_01___v
attr vallox_cloud reading90002JSON devices_01__id
attr vallox_cloud reading90003JSON devices_01_created
attr vallox_cloud reading90004JSON devices_01_deviceid
attr vallox_cloud reading90005JSON devices_01_lastseen
attr vallox_cloud reading90007JSON devices_01_limpMode_count
attr vallox_cloud reading90008JSON devices_01_logs_0
attr vallox_cloud reading90009JSON devices_01_logs_1
attr vallox_cloud reading90010JSON devices_01_logs_2
attr vallox_cloud reading90011JSON devices_01_logs_3
attr vallox_cloud reading90012JSON devices_01_logs_4
attr vallox_cloud reading90013JSON devices_01_logs_5
attr vallox_cloud reading90014JSON devices_01_name
attr vallox_cloud reading90015JSON devices_01_owner
attr vallox_cloud reading90016JSON devices_01_serial_number
attr vallox_cloud reading90017JSON devices_01_state
attr vallox_cloud reading90018JSON devices_01_sw_version_0
attr vallox_cloud reading90019JSON devices_01_sw_version_1
attr vallox_cloud reading90020JSON devices_01_sw_version_2
ch.eick
Einen schöne Abend wünsche ich allen.
Ich möchte nun noch das set Statement für die Ansteuerung der Vallox 270 über die Vallox Cloud nachliefern und ein stateformat ergänzen.
Das set01 ermöglicht es nach der Anmeldung in der Vallox Cloud die voreingestellten Profile aus zu wählen. Nach kurzer Zeit werden diese dann auf der ebenfalls in der Vallox Cloud angemeldeten KWL aktiviert.
attr vallox_cloud set01Name KWL_Set_Profil
# Das Input Mapping zeigt im FHEM die sprechenden Namen für die einzelnen Profile als pulldown Menü
attr vallox_cloud set01IMap 0:Anwesend, 1:Abwesend, 2:Stosslueften, 3:Kaminfunktion
# Die URL habe ich bereits minimiert
attr vallox_cloud set01URL https://cloud.vallox.com:443/api/devicestate/<Gerätekennung>
# setHeader1-4 sind für alle weiteren set[0-9] gültig, wobei ich momentan noch keine weiteren ausprobiert habe.
attr vallox_cloud setHeader1 Referer: https://cloud.vallox.com:443/cloudui/index.html?deviceid=<Gerätekennung>
attr vallox_cloud setHeader2 Content-Type: application/json
attr vallox_cloud setHeader3 X-XSRF-TOKEN: %%_csrfToken%%
attr vallox_cloud setHeader4 X-Requested-With: XMLHttpRequest
# In der $val Variablen wird die Profilnummer übergeben.
attr vallox_cloud set01Data {"20545":{"value":15,"minutesflag":true,"modbus":20545,"disabled":false},"65550":{"value":$val,"modbus":65550},"65603":{"value":30,"minutesflag":true,"modbus":65603,"disabled":false}}
Modbus:
20545 - A_CYC_FIREPLACE_TIME
65550 - EXT_CYC_ACTIVE_PROFILE
65603 - EXT_BOOST_TIME
Für eine Kurzübersicht habe ich folgendes stateFormat erstellt, was dann diesen Geräteüberblick im FHEM erzeugt
DeviceOverview
vallox_cloud      innen 20 °C, Zuluft 19 °C, Abluf 10 °C, außen 7 °C Profil: home
attr vallox_cloud stateFormat {sprintf("innen %d °C, Zuluft %d °C, Abluf %d °C, außen %d °C  Profil: %s" , ReadingsVal("vallox_cloud","EXT_TEMP_NOW_EXTRACT_AIR","?"),ReadingsVal("vallox_cloud","EXT_TEMP_NOW_SUPPLY_AIR","?"),ReadingsVal("vallox_cloud","EXT_TEMP_NOW_EXHAUST_AIR","?"),ReadingsVal("vallox_cloud","EXT_TEMP_NOW_OUTDOOR_AIR","?"),ReadingsVal("vallox_cloud","EXT_CYC_ACTIVE_PROFILE","?"))}
Viel Spaß beim Testen
     Christian
ch.eick
ich habe mal ein "shutdown restart" im FHEM gemacht und bekomme beim restart folgende Meldungen
2019.01.09 18:53:39 1: PERL WARNING: Use of uninitialized value in split at ./FHEM/98_HTTPMOD.pm line 2497.
2019.01.09 18:53:39 1: PERL WARNING: Use of uninitialized value in split at ./FHEM/98_HTTPMOD.pm line 2498.
2019.01.09 18:53:39 1: PERL WARNING: Use of uninitialized value $code in concatenation (.) or string at ./FHEM/98_HTTPMOD.pm line 2500.
2019.01.09 18:53:39 1: PERL WARNING: Use of uninitialized value $code in numeric eq (==) at ./FHEM/98_HTTPMOD.pm line 2501.
wenn jemand eine Idee hat...
   Christian
StefanStrobel
das ist die Funktion, die nach einem Read nach Redirects sucht. Offenbar wird die aufgerufen, obwohl gar kein erfolgreicher Read stattgefunden hat und der Header undef ist.
Anbei eine neue Version zum Testen, in der das abgefangen werden sollte.
Zudem ist ein neues Attribut useSetExtensions drin. Als Default werden setExtensions verwendet, wenn es aber mal stören sollte, kann man das Attribut auf 0 setzen und die setExtensions so abschalten.
Wenn es keine Probleme gibt, würde ich die neue Version in den nächsten Tagen einchecken.
Gruss
   Stefan
Habe eben auch noch ein paar templates dazu eingecheckt für hp und Epson Drucker sowie Blitzer. Quellen sind jeweils dabei, leider kann ich mangels hardware nicht alles testen ;) .
ch.eick
Hallo Ihr zwei.
Ich habe das HTTPMOD 09.01.2019 aktualisiert.
Die PERL Warnings beim "shutdown reboot" sind jetzt weg.
Nach dem Ausführen meiner HTTPMOD devices konnte ich keine Probleme feststellen.
Eine weitere Frage zum Auslesen von JSON Daten habe ich da noch.
Das JSON array sieht wie folgt aus:
"devices":[{"_id":"5881d8e294d6c1fc04038a1b","deviceid":"432C7775-3FDA-430A-920A-97B591B5F2C4","name":"Vallox 270","owner":"5881d8e294d6c1fc04038a1d","__v":5,"logs":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0},"limpMode":{"emailCount":0,"count":0},"serial_number":"0x5b5feca0","sw_version":[1,8,8],"state":"normal","lastseen":"2019-01-10T09:36:06.833Z","created":"2017-01-20T09:31:14.181Z","online":true}],"accessdevices":[],"data_created":"2019-01-10T09:36:06.828Z"}
Mein reading ist so definiert
reading00001JSON     devices
reading00001Name    A_CYC_DEVICE._ID
Und im Log finde ich das:
2019.01.10 10:55:27 5: vallox_cloud: ExtractReading A_CYC_DEVICE._ID with json devices ...
2019.01.10 10:55:27 5: vallox_cloud: ExtractReading A_CYC_DEVICE._ID with json devices did not match a key directly - trying regex match to create a list
2019.01.10 10:55:27 5: vallox_cloud: ExtractReading A_CYC_DEVICE._ID with json /^devices/ got keylist devices_01___v devices_01__id devices_01_created devices_01_deviceid devices_01_lastseen devices_01_limpMode_count devices_01_limpMode_emailCount devices_01_logs_0 devices_01_logs_1 devices_01_logs_2 devices_01_logs_3 devices_01_logs_4 devices_01_logs_5 devices_01_name devices_01_online devices_01_owner devices_01_serial_number devices_01_state devices_01_sw_version_0 devices_01_sw_version_1 devices_01_sw_version_2
2019.01.10 10:55:27 4: vallox_cloud: ExtractReading for reading00001-1 sets A_CYC_DEVICE._ID-1 to 5
2019.01.10 10:55:27 4: vallox_cloud: ExtractReading for reading00001-2 sets A_CYC_DEVICE._ID-2 to 5881d8e294d6c1fc04038a1b
2019.01.10 10:55:27 4: vallox_cloud: ExtractReading for reading00001-3 sets A_CYC_DEVICE._ID-3 to 2017-01-20T09:31:14.181Z
2019.01.10 10:55:27 4: vallox_cloud: ExtractReading for reading00001-4 sets A_CYC_DEVICE._ID-4 to 432C7775-3FDA-430A-920A-97B591B5F2C4
2019.01.10 10:55:27 4: vallox_cloud: ExtractReading for reading00001-5 sets A_CYC_DEVICE._ID-5 to 2019-01-10T09:40:26.367Z
2019.01.10 10:55:27 4: vallox_cloud: ExtractReading for reading00001-6 sets A_CYC_DEVICE._ID-6 to 0
2019.01.10 10:55:27 4: vallox_cloud: ExtractReading for reading00001-7 sets A_CYC_DEVICE._ID-7 to 0
2019.01.10 10:55:27 4: vallox_cloud: ExtractReading for reading00001-8 sets A_CYC_DEVICE._ID-8 to 0
2019.01.10 10:55:27 4: vallox_cloud: ExtractReading for reading00001-9 sets A_CYC_DEVICE._ID-9 to 0
2019.01.10 10:55:27 4: vallox_cloud: ExtractReading for reading00001-10 sets A_CYC_DEVICE._ID-10 to 0
2019.01.10 10:55:27 4: vallox_cloud: ExtractReading for reading00001-11 sets A_CYC_DEVICE._ID-11 to 0
2019.01.10 10:55:27 4: vallox_cloud: ExtractReading for reading00001-12 sets A_CYC_DEVICE._ID-12 to 0
2019.01.10 10:55:27 4: vallox_cloud: ExtractReading for reading00001-13 sets A_CYC_DEVICE._ID-13 to 0
2019.01.10 10:55:27 4: vallox_cloud: ExtractReading for reading00001-14 sets A_CYC_DEVICE._ID-14 to Vallox 270
2019.01.10 10:55:27 4: vallox_cloud: ExtractReading for reading00001-15 sets A_CYC_DEVICE._ID-15 to 1
2019.01.10 10:55:27 4: vallox_cloud: ExtractReading for reading00001-16 sets A_CYC_DEVICE._ID-16 to 5881d8e294d6c1fc04038a1d
2019.01.10 10:55:27 4: vallox_cloud: ExtractReading for reading00001-17 sets A_CYC_DEVICE._ID-17 to 0x5b5feca0
2019.01.10 10:55:27 4: vallox_cloud: ExtractReading for reading00001-18 sets A_CYC_DEVICE._ID-18 to normal
2019.01.10 10:55:27 4: vallox_cloud: ExtractReading for reading00001-19 sets A_CYC_DEVICE._ID-19 to 1
2019.01.10 10:55:27 4: vallox_cloud: ExtractReading for reading00001-20 sets A_CYC_DEVICE._ID-20 to 8
2019.01.10 10:55:27 4: vallox_cloud: ExtractReading for reading00001-21 sets A_CYC_DEVICE._ID-21 to 8
Nun habe ich ja bereits fiele readings mit den sxacten Namen definiert, jedoch habe ich den Syntax für diese arrays nicht verstanden. Kann mir da bitte mal einer auf die Sprünge helfen?
Mit meinem reading werden die Werte ja einfach fortlaufend nummeriert und für die bessere Lesbarkeit müsste ich ja, nach meinem Lernstand, jeden einzelnen Wert definieren.
Für einzelne andere readings habe ich das dann ja auch schon gemacht.
reading00017JSON   data.17.value
reading00017Name   A_CYC_MACHINE_MODEL
liefert dann
A_CYC_MACHINE_MODEL          ValloPlus 270 MV
Ich komme halt nur nicht in die arrays rein :-)
    Christian
ch.eick
#501
Und noch eins ;-)
reading
reading65608JSON    data.65608.value
Daten
"65608":{"value":1,"modbus":65608}
reading
EXT_CYC_POST_HEATER_TYPE     1
Log verbose 5
2019.01.10 11:10:28 5: vallox_cloud: ExtractReading EXT_CYC_POST_HEATER_TYPE with json data.65608.value ...
2019.01.10 11:10:28 5: vallox_cloud: ExtractReading EXT_CYC_POST_HEATER_TYPE with json data.65608.value did not match a key directly - trying regex match to create a list
2019.01.10 11:10:28 5: vallox_cloud: ExtractReading EXT_CYC_POST_HEATER_TYPE with json /^data.65608.value/ got keylist data_65608_value
2019.01.10 11:10:28 4: vallox_cloud: ExtractReading for reading65608-1 sets EXT_CYC_POST_HEATER_TYPE to 1
Ist hierbei die Meldung "did not match a key directly - trying regex match to create a list" richtig, oder ist mein reading nicht korrekt? Das Ergebnis stimmt ja soweit.
   Christian
StefanStrobel
Hallo Christian,
ich empfehle eigentlich immer zunächst mal extractAllJSON zu verwenden. Dann erzeugt HTTPMOD für jeden Eintrag ein Reading und der Name des Readings entspricht dem String, der auch für ein direktes Abfragen verwendet werden kann. Damit tut man sich leichter.
Deine Readings sind tatsächlich nicht so definiert, wie HTTPMOD es erwartet. Dass es trotzdem klappt, liegt daran, dass auch als regex die richtigen Werte getroffen werden.
HTTPMOD verkettet die JSON-Namen einer Hierarchie mit einem "_", nicht mit einem Punkt.
Du müsstest also Readings z.B. als devices_01_deviceid definieren. Verwirrend ist dabei, dass der Unterstich auch schon als Teil der Namen verwendet wird.
Wenn HTTPMOD Deinen JSON-Namen nicht kennt, versucht es ihn als regulären Ausdruck zu verwenden und mit allen tatsächlich bekannten Namen zu vergleichen. Das ergebnis der passenden Namen siehst Du in Deinem Log:
ExtractReading A_CYC_DEVICE._ID with json /^devices/ got keylist ...
Gruss
   Stefan
ch.eick
#503
Okay, das klappt besser. Jedoch hatte ich auch schon so gestartet, aber die Umsetzung durch "enforceGoodReadingNames 1" nicht berücksichtigt.
Die Unterstriche im reading Name habe ich von hier https://github.com/yozik04/vallox_websocket_api/blob/master/vallox_websocket_api/constants.py übernommen.
Noch verwirrender ist für mich folgendes, was ich durch ausprobieren ermittelt habe.
Der JSON Name lautet mit "enforceGoodReadingNames 1" so "data_65590_22_00_5", kann jedoch nicht als reading65590118JSON angegeben werden, da es dann nicht gefunden wird.  Trage ich jedoch folgendes ein, wird es direkt zugeordnet.
Was dann folgendes im Log ergibt und für mich gut aussieht
2019.01.11 15:04:44 5: vallox_cloud: ExtractReading EXT_CYC_OLD_WEEKLY_EVENTS_FRIDAY_22 with json data_65590_22:00 5 ...
2019.01.11 15:04:44 4: vallox_cloud: ExtractReading for reading65590118-1 sets EXT_CYC_OLD_WEEKLY_EVENTS_FRIDAY_22 to away
Bei dem Auslesen von JSON für devices gibt es tatsächlich Namen wie "__v" und "_id", was das soll kann sicherlich nur der Hersteller sagen.
Die neuen readings habe ich hier aktualisiert
Zitat von: ch.eick am 03 Januar 2019, 11:12:41
Gruß und Dank
    Christian
StefanStrobel
Hallo Christian,
ja das mit JSON Strings, die keine gültigen Reading-Namen sind, ist verwirrend.
HTTPMOD verwendet die Namen so wie sie die JSON-Bibliothek liefert und verkettet sie mit einem Unterstrich.
Deshalb muss es z.B.
attr vallox_cloud reading01JSON data_65590_22:00 5
attr vallox_cloud reading01Name EXT_CYC_OLD_WEEKLY_EVENTS_FRIDAY_22
lauten. Das entsteht direkt aus der Verkettung der JSON-Namen in einer Hierarchie, so wie es im JSON-Text eben drinsteht.
Da data_65590_22:00 5 aber kein gültiger Name für ein Reading ist, macht die Fhem-Funktion, die bei enforceGoodReadingNames aufgerufen wird daraus ein Reading mit Namen data_65590_22_00_5.
Hier werden einfach alle unerlaubten Zeichen durch einen _ ersetzt.
Gruss
   Stefan
StefanStrobel
ich hatte da noch eine Idee um das mit komplexeren JSON Daten einfacher zu machen:
wenn man extractAllReadings oder get01ExtractAllReadings nicht auf 1 sondern auf 2 setzt, dann erzeugt HTTPMOD beim ersten Lesen die readingXXName und readingXXJSON attribute und löscht dann das extractAllJSON attribut automatisch.
Das sollte die Arbiet in solchen Fällen erleichtern.
Anbei eine neue Version zum Testen.
Gruss
   Stefan
ch.eick
Hallo Stefan,
mein erster Test ergibt folgendes:
1) ModuleVersion    3.5.7 - 9.1.2019
2) Unter userattr habe ich für get**ExtractAllReadings noch :0,1,2 ergänzt
3) beim Testlauf wurden dann fast alle JSON readings angelegt. Es fehlen nur noch die readings für den value.
TestDaten
httpbody
{"errors":null,"data":{"17":{"value":"ValloPlus 270 MV","modbus":17},"4353":{"value":30,"modbus":4353},"4354":{"value":20,"modbus":4354},"4355":{"value":9,"modbus":4355},"4356":{"value":7,"modbus":4356},"4357":{"value":16,"modbus":4357},"4358":{"value":17,"modbus":4358},"4359":{"value":1,"modbus":4359},"4360":{"value":0,"modbus":4360},"4363":{"value":57,"modbus":4363},"4364":{"value":0,"modbus":4364},"4609":{"value":0,"modbus":4609},"4615":{"value":1,"modbus":4615},"4616":{"value":0,"modbus":4616},"5121":{"value":50,"modbus":5121},"5122":{"value":50,"modbus":5122},"5124":{"value":0,"modbus":5124},"5125":{"value":0,"modbus":5125},"5126":{"value":0,"modbus":5126},"20482":{"value":1,"modbus":20482},"20483":{"value":192,"modbus":20483},"20487":{"value":50,"modbus":20487},"20488":{"value":50,"modbus":20488},"20490":{"value":58,"modbus":20490},"20491":{"value":900,"modbus":20491},"20499":{"value":1,"modbus":20499},"20500":{"value":0,"modbus":20500},"20501":{"value":20,"modbus":20501},"20505":{"value":1,"modbus":20505},"20506":{"value":0,"modbus":20506},"20507":{"value":30,"modbus":20507},"20511":{"value":1,"modbus":20511},"20512":{"value":0,"modbus":20512},"20513":{"value":75,"modbus":20513},"20517":{"value":0,"modbus":20517},"20524":{"value":1,"modbus":20524},"20542":{"value":1,"modbus":20542},"20543":{"value":0,"modbus":20543},"20545":{"value":15,"modbus":20545},"20549":{"value":0,"modbus":20549},"20553":{"value":0,"modbus":20553},"21765":{"value":0,"modbus":21765},"21767":{"value":1,"modbus":21767},"21768":{"value":1,"modbus":21768},"21769":{"value":true,"modbus":21769},"32771":{"value":0,"modbus":32771},"32772":{"value":0,"modbus":32772},"32773":{"value":0,"modbus":32773},"32774":{"value":0,"modbus":32774},"65537":{"value":1,"modbus":65537},"65538":{"value":0,"modbus":65538},"65539":{"value":"1.8.8","modbus":65539},"65540":{"value":20,"modbus":65540},"65541":{"value":17,"modbus":65541},"65542":{"value":7,"modbus":65542},"65543":{"value":9,"modbus":65543},"65544":{"value":1,"modbus":65544},"65545":{"value":1,"modbus":65545},"65548":{"value":1533013152,"modbus":65548},"65549":{"value":"2018-10-19T21:00:00.000Z"},"65550":{"value":0,"modbus":65550},"65553":{"value":1164},"65554":{"value":{"years":2,"hours":74}},"65557":{"value":1,"marks":{"05:00 1":"home","06:00 1":"home","07:00 1":"boost","08:00 1":"home","09:00 1":"away","18:00 1":"home","22:00 1":"away","05:00 2":"home","06:00 2":"home","07:00 2":"boost","08:00 2":"home","09:00 2":"away","18:00 2":"home","22:00 2":"away","05:00 3":"home","06:00 3":"home","07:00 3":"boost","08:00 3":"home","09:00 3":"away","18:00 3":"home","22:00 3":"away","05:00 4":"home","06:00 4":"home","07:00 4":"boost","08:00 4":"home","09:00 4":"away","18:00 4":"home","22:00 4":"away","05:00 5":"home","06:00 5":"home","07:00 5":"boost","08:00 5":"home","09:00 5":"away","18:00 5":"home","22:00 5":"away","05:00 6":"away","09:00 6":"boost","10:00 6":"boost","11:00 6":"home","14:00 6":"away","18:00 6":"home","22:00 6":"away","05:00 0":"away","09:00 0":"boost","10:00 0":"boost","11:00 0":"home","14:00 0":"away","18:00 0":"home","22:00 0":"away"}},"65558":{"value":[]},"65559":{"value":false,"modbus":65559},"65560":{"value":true,"modbus":65560},"65561":{"value":"2019-01-13T11:38+00:00"},"65562":{"value":"2019-01-13"},"65564":{"value":false,"modbus":65564},"65565":[23391,60576,5,1,8255,47889,3097,110],"65568":{"value":50,"amount":1170},"65569":{"value":37,"amount":977},"65572":{"value":0,"modbus":65572},"65579":{"value":15,"modbus":65579},"65580":{"value":15,"modbus":65580},"65581":{"value":15,"modbus":65581},"65590":{"05:00 1":"home","06:00 1":"home","07:00 1":"boost","08:00 1":"home","09:00 1":"away","18:00 1":"home","22:00 1":"away","05:00 2":"home","06:00 2":"home","07:00 2":"boost","08:00 2":"home","09:00 2":"away","18:00 2":"home","22:00 2":"away","05:00 3":"home","06:00 3":"home","07:00 3":"boost","08:00 3":"home","09:00 3":"away","18:00 3":"home","22:00 3":"away","05:00 4":"home","06:00 4":"home","07:00 4":"boost","08:00 4":"home","09:00 4":"away","18:00 4":"home","22:00 4":"away","05:00 5":"home","06:00 5":"home","07:00 5":"boost","08:00 5":"home","09:00 5":"away","18:00 5":"home","22:00 5":"away","05:00 6":"away","09:00 6":"boost","10:00 6":"boost","11:00 6":"home","14:00 6":"away","18:00 6":"home","22:00 6":"away","05:00 0":"away","09:00 0":"boost","10:00 0":"boost","11:00 0":"home","14:00 0":"away","18:00 0":"home","22:00 0":"away"},"65591":{"value":0,"modbus":65591},"65592":{"value":0,"modbus":65592},"65593":{"value":0,"modbus":65593},"65594":{"value":15,"modbus":65594},"65595":{"value":50,"modbus":65595},"65596":{"value":50,"modbus":65596},"65597":{"value":{"hours":0,"minutes":10},"modbus":65597},"65598":{"value":1,"modbus":65598},"65599":{"value":"3722","modbus":65599},"65600":{"value":false,"modbus":65600},"65601":{"value":12,"modbus":65601},"65602":{"value":1,"modbus":65602},"65603":{"value":30,"modbus":65603},"65604":{"value":8,"modbus":65604},"65605":{"value":0,"modbus":65605},"65607":{"value":0,"modbus":65607},"65608":{"value":1,"modbus":65608},"65609":{"value":null,"modbus":65609},"65615":{"value":"<meine Mail Adresse>","modbus":65615},"131082":{"value":0,"modbus":131082},"200980":{"value":57,"modbus":200980}},"devices":[{"_id":"5881d8e294d6c1fc04038a1b","deviceid":"432C7775-3FDA-430A-920A-97B591B5F2C4","name":"Vallox 270","owner":"5881d8e294d6c1fc04038a1d","__v":5,"logs":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0},"limpMode":{"emailCount":0,"count":0},"serial_number":"0x5b5feca0","sw_version":[1,8,8],"state":"normal","lastseen":"2019-01-13T10:36:43.224Z","created":"2017-01-20T09:31:14.181Z","online":true}],"accessdevices":[],"data_created":"2019-01-13T10:36:43.215Z"}
erkannte readings
attr vallox_cloud reading100JSON data_20501_modbus
attr vallox_cloud reading100Name data_20501_modbus
attr vallox_cloud reading101JSON data_17_modbus
attr vallox_cloud reading101Name data_17_modbus
attr vallox_cloud reading102JSON data_65608_modbus
attr vallox_cloud reading102Name data_65608_modbus
attr vallox_cloud reading103JSON data_20543_modbus
attr vallox_cloud reading103Name data_20543_modbus
attr vallox_cloud reading104JSON data_created
attr vallox_cloud reading104Name data_created
attr vallox_cloud reading105JSON data_4354_modbus
attr vallox_cloud reading105Name data_4354_modbus
attr vallox_cloud reading106JSON data_4355_modbus
attr vallox_cloud reading106Name data_4355_modbus
attr vallox_cloud reading107JSON data_21769_modbus
attr vallox_cloud reading107Name data_21769_modbus
attr vallox_cloud reading108JSON data_131082_modbus
attr vallox_cloud reading108Name data_131082_modbus
attr vallox_cloud reading109JSON data_65597_modbus
attr vallox_cloud reading109Name data_65597_modbus
attr vallox_cloud reading110JSON data_65542_modbus
attr vallox_cloud reading110Name data_65542_modbus
attr vallox_cloud reading111JSON data_131082_value
attr vallox_cloud reading111Name data_131082_value
attr vallox_cloud reading112JSON data_65545_modbus
attr vallox_cloud reading112Name data_65545_modbus
attr vallox_cloud reading113JSON data_20483_modbus
attr vallox_cloud reading113Name data_20483_modbus
attr vallox_cloud reading114JSON data_4356_modbus
attr vallox_cloud reading114Name data_4356_modbus
attr vallox_cloud reading115JSON data_65565_1
attr vallox_cloud reading115Name data_65565_1
attr vallox_cloud reading116JSON data_65565_7
attr vallox_cloud reading116Name data_65565_7
attr vallox_cloud reading117JSON data_20513_modbus
attr vallox_cloud reading117Name data_20513_modbus
attr vallox_cloud reading118JSON data_4358_modbus
attr vallox_cloud reading118Name data_4358_modbus
attr vallox_cloud reading119JSON data_20482_modbus
attr vallox_cloud reading119Name data_20482_modbus
attr vallox_cloud reading120JSON data_21768_modbus
attr vallox_cloud reading120Name data_21768_modbus
attr vallox_cloud reading121JSON data_5124_modbus
attr vallox_cloud reading121Name data_5124_modbus
attr vallox_cloud reading122JSON data_20511_modbus
attr vallox_cloud reading122Name data_20511_modbus
attr vallox_cloud reading123JSON data_65564_modbus
attr vallox_cloud reading123Name data_65564_modbus
attr vallox_cloud reading124JSON data_20507_modbus
attr vallox_cloud reading124Name data_20507_modbus
attr vallox_cloud reading125JSON data_65543_modbus
attr vallox_cloud reading125Name data_65543_modbus
attr vallox_cloud reading126JSON data_20491_modbus
attr vallox_cloud reading126Name data_20491_modbus
attr vallox_cloud reading127JSON data_65599_modbus
attr vallox_cloud reading127Name data_65599_modbus
attr vallox_cloud reading128JSON data_4364_modbus
attr vallox_cloud reading128Name data_4364_modbus
attr vallox_cloud reading129JSON data_65565_0
attr vallox_cloud reading129Name data_65565_0
attr vallox_cloud reading130JSON data_65603_modbus
attr vallox_cloud reading130Name data_65603_modbus
attr vallox_cloud reading131JSON data_4615_modbus
attr vallox_cloud reading131Name data_4615_modbus
attr vallox_cloud reading132JSON data_20499_modbus
attr vallox_cloud reading132Name data_20499_modbus
attr vallox_cloud reading133JSON data_65594_modbus
attr vallox_cloud reading133Name data_65594_modbus
attr vallox_cloud reading134JSON data_65565_5
attr vallox_cloud reading134Name data_65565_5
attr vallox_cloud reading135JSON data_65537_modbus
attr vallox_cloud reading135Name data_65537_modbus
attr vallox_cloud reading136JSON data_65604_modbus
attr vallox_cloud reading136Name data_65604_modbus
attr vallox_cloud reading137JSON data_200980_modbus
attr vallox_cloud reading137Name data_200980_modbus
attr vallox_cloud reading138JSON data_65593_modbus
attr vallox_cloud reading138Name data_65593_modbus
attr vallox_cloud reading139JSON data_200980_value
attr vallox_cloud reading139Name data_200980_value
attr vallox_cloud reading140JSON data_65615_modbus
attr vallox_cloud reading140Name data_65615_modbus
attr vallox_cloud reading141JSON data_20542_modbus
attr vallox_cloud reading141Name data_20542_modbus
attr vallox_cloud reading142JSON data_65598_modbus
attr vallox_cloud reading142Name data_65598_modbus
attr vallox_cloud reading143JSON data_65592_modbus
attr vallox_cloud reading143Name data_65592_modbus
attr vallox_cloud reading144JSON devices_01_limpMode_emailCount
attr vallox_cloud reading144Name devices_01_limpMode_emailCount
attr vallox_cloud reading145JSON data_65568_amount
attr vallox_cloud reading145Name data_65568_amount
attr vallox_cloud reading146JSON data_65565_2
attr vallox_cloud reading146Name data_65565_2
attr vallox_cloud reading147JSON data_32773_modbus
attr vallox_cloud reading147Name data_32773_modbus
attr vallox_cloud reading148JSON data_20517_modbus
attr vallox_cloud reading148Name data_20517_modbus
attr vallox_cloud reading149JSON data_65557_value
attr vallox_cloud reading149Name data_65557_value
attr vallox_cloud reading150JSON data_65548_modbus
attr vallox_cloud reading150Name data_65548_modbus
attr vallox_cloud reading151JSON data_20487_modbus
attr vallox_cloud reading151Name data_20487_modbus
attr vallox_cloud reading152JSON data_32772_modbus
attr vallox_cloud reading152Name data_32772_modbus
attr vallox_cloud reading153JSON data_20545_modbus
attr vallox_cloud reading153Name data_20545_modbus
attr vallox_cloud reading154JSON data_65559_modbus
attr vallox_cloud reading154Name data_65559_modbus
attr vallox_cloud reading155JSON data_65580_modbus
attr vallox_cloud reading155Name data_65580_modbus
attr vallox_cloud reading156JSON data_65601_modbus
attr vallox_cloud reading156Name data_65601_modbus
attr vallox_cloud reading157JSON data_5126_modbus
attr vallox_cloud reading157Name data_5126_modbus
attr vallox_cloud reading158JSON data_65572_modbus
attr vallox_cloud reading158Name data_65572_modbus
attr vallox_cloud reading159JSON data_20490_modbus
attr vallox_cloud reading159Name data_20490_modbus
attr vallox_cloud reading160JSON data_32771_modbus
attr vallox_cloud reading160Name data_32771_modbus
attr vallox_cloud reading161JSON data_65591_modbus
attr vallox_cloud reading161Name data_65591_modbus
attr vallox_cloud reading162JSON data_65540_modbus
attr vallox_cloud reading162Name data_65540_modbus
attr vallox_cloud reading163JSON data_65579_modbus
attr vallox_cloud reading163Name data_65579_modbus
attr vallox_cloud reading164JSON data_65609_modbus
attr vallox_cloud reading164Name data_65609_modbus
attr vallox_cloud reading165JSON data_20553_modbus
attr vallox_cloud reading165Name data_20553_modbus
attr vallox_cloud reading166JSON data_4359_modbus
attr vallox_cloud reading166Name data_4359_modbus
attr vallox_cloud reading167JSON data_65539_modbus
attr vallox_cloud reading167Name data_65539_modbus
attr vallox_cloud reading168JSON data_65569_amount
attr vallox_cloud reading168Name data_65569_amount
attr vallox_cloud reading169JSON data_65565_4
attr vallox_cloud reading169Name data_65565_4
attr vallox_cloud reading170JSON data_4357_modbus
attr vallox_cloud reading170Name data_4357_modbus
attr vallox_cloud reading171JSON data_65541_modbus
attr vallox_cloud reading171Name data_65541_modbus
attr vallox_cloud reading172JSON data_65581_modbus
attr vallox_cloud reading172Name data_65581_modbus
attr vallox_cloud reading173JSON data_20524_modbus
attr vallox_cloud reading173Name data_20524_modbus
attr vallox_cloud reading174JSON data_4353_modbus
attr vallox_cloud reading174Name data_4353_modbus
attr vallox_cloud reading175JSON data_4616_modbus
attr vallox_cloud reading175Name data_4616_modbus
attr vallox_cloud reading176JSON data_5121_modbus
attr vallox_cloud reading176Name data_5121_modbus
attr vallox_cloud reading177JSON data_4360_modbus
attr vallox_cloud reading177Name data_4360_modbus
attr vallox_cloud reading178JSON data_5125_modbus
attr vallox_cloud reading178Name data_5125_modbus
attr vallox_cloud reading179JSON data_5122_modbus
attr vallox_cloud reading179Name data_5122_modbus
attr vallox_cloud reading180JSON data_20505_modbus
attr vallox_cloud reading180Name data_20505_modbus
attr vallox_cloud reading181JSON data_21765_modbus
attr vallox_cloud reading181Name data_21765_modbus
attr vallox_cloud reading182JSON data_65607_modbus
attr vallox_cloud reading182Name data_65607_modbus
attr vallox_cloud reading183JSON data_65550_modbus
attr vallox_cloud reading183Name data_65550_modbus
attr vallox_cloud reading184JSON data_65600_modbus
attr vallox_cloud reading184Name data_65600_modbus
attr vallox_cloud reading185JSON data_20512_modbus
attr vallox_cloud reading185Name data_20512_modbus
attr vallox_cloud reading186JSON data_65565_3
attr vallox_cloud reading186Name data_65565_3
attr vallox_cloud reading187JSON data_65560_modbus
attr vallox_cloud reading187Name data_65560_modbus
attr vallox_cloud reading188JSON data_65602_modbus
attr vallox_cloud reading188Name data_65602_modbus
attr vallox_cloud reading189JSON data_65538_modbus
attr vallox_cloud reading189Name data_65538_modbus
attr vallox_cloud reading190JSON data_21767_modbus
attr vallox_cloud reading190Name data_21767_modbus
attr vallox_cloud reading191JSON data_20506_modbus
attr vallox_cloud reading191Name data_20506_modbus
attr vallox_cloud reading192JSON data_32774_modbus
attr vallox_cloud reading192Name data_32774_modbus
attr vallox_cloud reading193JSON data_65605_modbus
attr vallox_cloud reading193Name data_65605_modbus
attr vallox_cloud reading194JSON data_20500_modbus
attr vallox_cloud reading194Name data_20500_modbus
attr vallox_cloud reading195JSON devices_01_online
attr vallox_cloud reading195Name devices_01_online
attr vallox_cloud reading196JSON data_20488_modbus
attr vallox_cloud reading196Name data_20488_modbus
attr vallox_cloud reading197JSON data_4609_modbus
attr vallox_cloud reading197Name data_4609_modbus
attr vallox_cloud reading198JSON data_4363_modbus
attr vallox_cloud reading198Name data_4363_modbus
attr vallox_cloud reading199JSON data_65595_modbus
attr vallox_cloud reading199Name data_65595_modbus
attr vallox_cloud reading200JSON data_65596_modbus
attr vallox_cloud reading200Name data_65596_modbus
attr vallox_cloud reading201JSON data_65544_modbus
attr vallox_cloud reading201Name data_65544_modbus
attr vallox_cloud reading202JSON data_20549_modbus
attr vallox_cloud reading202Name data_20549_modbus
attr vallox_cloud reading203JSON data_65565_6
attr vallox_cloud reading203Name data_65565_6
     Christian
StefanStrobel
Hallo Christian,
da muss bei Deinem Test etwas schief gelaufen sein.
Hast Du eventuell noch alte Attribute für Objekte drin gehabt?
HTTPMOD erzeugt keine neuen Attribute, wenn es schon ein Attribut gibt, das den gleichen JSON-Namen referenziert. Bei Verbose 5 siehst Du das dann auch im Log.
Ich habe gerade Deine Testdaten in eine Datei kopiert und dann mit file:// als URL darauf zugegriffen.
Bei mir erzeugt er Attribute mit Nummern von 100 bis 414 und es sind sehr viele Values dabei.
Falls es doch nicht an bestehenden Attributen liegt, wäre ein Log mit verbose 5 sehr hilfreich.
Gruss / vielen Dank
   Stefan
ch.eick
Okay, sorry,
ich habe es an meinem bestehenden device getestet und Du hast recht, ich hatte natürlich sehr viele bereits definiert.
Dann sehe ich ja jetzt was eventuell noch fehlt ;-) Die data_*****_modbus brauche ich erstmal nicht, da ich ja die modbus Adresse bereits im reading Namen mit aufgenommen habe. Für die Analyse spart das jedoch jetzt eine Menge Arbeit.
Kann man ein reading eigentlich auch umbenennen? Das habe ich in der Doku noch nicht gefunden.
An wen könnte ich denn ein Template schicken? Das finde ich für die Verbreitung in der FHEM Gemeine und den Einstieg von neuen Mitstreitern echt eine Tolle Idee. Gemeinsam sind wir stark :-)
   Christian
det.
@ all -Anfrage zu ResMed,
gibt es einen wissenden Mitbürger, der an der Anzeige der Schlafdaten von https://myair.resmed.eu/
Interesse und die nötigen Kenntnisse hat? Scheitere leider schon bei der Authentifizierung....
HTTP/1.1 200 OK
Date: Fri, 18 Jan 2019 10:36:59 GMT
Server: Microsoft-IIS/8.5
Cache-Control: no-cache, no-store, must-revalidate
Pragma: no-cache
Content-Type: text/html; charset=utf-8
Expires: -1
Vary: Accept-Encoding
X-AspNet-Version: 4.0.30319
X-Powered-By: ASP.NET
X-FRAME-OPTIONS: SAMEORIGIN
Set-Cookie: ASP.NET_SessionId=ulm50nlmpkqpn54berpqdjkp; path=/; secure; HttpOnly
Set-Cookie: LocalizationSettings=CurrentMyAirLocale=en-GB; expires=Thu, 11-Dec-2155 10:36:59 GMT; path=/; secure; HttpOnly
Set-Cookie: resmed-myair-country=resmed-myair-country=12; expires=Sun, 26-Sep-2032 09:36:59 GMT; path=/; secure; HttpOnly
Set-Cookie: resmed-myair-instance=resmed-myair-instance=2; expires=Sun, 26-Sep-2032 09:36:59 GMT; path=/; secure; HttpOnly
Set-Cookie: LB_persistent_member_cookie=302222858.20480.0000; path=/; Httponly
Content-Encoding: gzip
Connection: close
det.
