eBus Schaltung in Betrieb nehmen
Begonnen von Reinhart, 23 Dezember 2015, 15:19:45
cs-online
Hello,
as far as I remember, you have to clone the CSVs from the github as John wrote a few days ago. In These files you can see if the Messages are "r" => read only or "rw" => read- and writeable.
greetings Christian
FHEM auf DELL Thinclient, HM-WLAN-Gateway, einige HM-Aktoren,2x EBUSD an Heizung+Solar, ESP8266/32 am Strom-,Gas-,Wasserzähler, in WLAN-Steckdosen und Relaisleisten, Sonoff S20+S26,Shelly1/2/2.5, Lacrosse-Gateway+Sensoren,Sduino,Alexa-Fhem,Huawei PV+Speicher, alles auf einem TC und da geht noch mehr
Reinhart
example: please look in your 15.700.csv file and you can see the writabel reading beginn with "r;w" and so on.
FHEM auf Raspy5 mit Bullseye + SSD, Homematic, ESP8266, ESP32, Sonoff, eBus, NanoCUL, MapleCUL, , MQTT2, Alexa
juanjoqg
Ok, according to my logs SetMode should be in the hmu csv file, but  I've been loocking on Git the csv files and I can not find the SetMode message.
I'm getting something wrong but I do not find what.
john30
in order to get the message definition, just use "ebusctl find -f setmode" and you'll see it.
the definition resides in one of the included "*.inc" files
author of ebusd
Trainer
ich bekomme bei meinem openhab log file folgende Information:
17:54:17.197 [DEBUG] [inding.ebus.handler.EBusBridgeHandler] - eBUS telegram error; Master CRC invalid! IS:C1 SHOULD:00 [ERROR: MASTER_CRC_INVALID, DATA: 10 08 B5 09 00 00]
17:54:21.325 [DEBUG] [inding.ebus.handler.EBusBridgeHandler] - eBUS telegram error; Received SYN byte while receiving telegram! [ERROR: INVALID_SYN, DATA: 10 08 11 01 89 00 40 80 00 FF AA]
17:54:23.306 [DEBUG] [inding.ebus.handler.EBusBridgeHandler] - eBUS telegram error; Telegram starts with an invalid source address! 08 [ERROR: INVALID_SOURCE_ADDRESS, DATA: 10 08 11 01 89 00 40 80 00 FF AA 00 FF 00 AA 10 B5 02 03 00 AA FF FF A0 01 AA 78 60 00 10 B5 09 00 FF 05 00 00 9A AA 05 00 00 01 00 AA 16 10 B4 12 00]
Woran könnte das Problem liegen?
john30
sieht aus als wären ein paar Bits gekippt. Kommt jetzt drauf an, was für ein Interface du hast.
author of ebusd
Trainer
danke für deine Rückmeldung.
ich nutze den ebus Adapter 2.2 (aktuell noch ohne DC/DC Konverter) + UART (FT232RL) + PRI 3+.
Die Spannung 5V und 3,3V nutze ich vom UART Adapter.
john30
hast du noch ein anderes Interface zum gegenchecken?
Oder hängt noch ein weiteres Interface am Bus, das sich nicht ans Protokoll hält?
Kannst Du openhab so einstellen, dass garantiert nichts auf den Bus geschrieben wird? Falls ja, würde ich das mal ausprobieren.
author of ebusd
Trainer
ich habe noch einen zweiten UART Adapter wenn du das meinst. Leider tritt dabei das selbe Problem auf.
Ich habe am eBus noch ein VRT 392 (Raumbediengerät von Vaillant).
Ich weiß leider nicht wie man das einstellen sollte dass nichts auf den Bus geschrieben wird.
Aktuell sollte ich auch nur Daten lesen und nicht schreiben.
john30
ich meinte ein weiteres Hardware Interface.
Du könntest mal den VRT abklemmen und schauen, ob sich alles gleich verhält.
meine Vermutung ist aber, dass du auf dem RPi noch einen Dienst laufen hast (z.B. fhem), der falsch konfiguriert ist und somit das Device ebenfalls nutzt
author of ebusd
Trainer
Vielen Dank für deine Hilfe.
Ich nutze lediglich openhab mit dem ebus addon und den ebusd.
Sonst läuft keine zusätzliche Homeautomation Software.
Werde ich probieren.
Gesendet von meinem SM-G930F mit Tapatalk
Trainer
#1556
Wenn ich keine Verbindung zu meinem USB Anschluss bzw Adapter erhalte könnte das daran liegen dass ein anderen Dienst auf meinen USB Anschluss /Adapter zugreift?
pi@raspberrypi:~ $ sudo ebusd --scanconfig -f
2019-10-29 18:34:41.815 [main notice] ebusd 3.3.v3.3 started with auto scan
2019-10-29 18:34:42.059 [bus error] unable to open /dev/ttyUSB0: ERR: generic device error
2019-10-29 18:34:42.060 [bus notice] bus started with own address 31/36
2019-10-29 18:34:42.060 [bus notice] device invalid
^X^C2019-10-29 18:34:46.301 [main notice] SIGINT received
ich habe mein Raumtheromostat entfernt und jetzt erhalte ich zwar weniger Daten aber noch immer der selber Fehler.
19:11:32.216 [DEBUG] [inding.ebus.handler.EBusBridgeHandler] - eBUS telegram error; Telegram starts with an invalid source address! FE [ERROR: INVALID_SOURCE_ADDRESS, DATA: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00]
19:11:33.845 [DEBUG] [inding.ebus.handler.EBusBridgeHandler] - eBUS telegram error; Telegram starts with an invalid source address! 08 [ERROR: INVALID_SOURCE_ADDRESS, DATA: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00]
anscheinend greift auch ein Dienst auf den USB Ausgang zu
2019-10-29 19:13:59.633 [main notice] ebusd 3.3.v3.3 started with auto scan
2019-10-29 19:13:59.888 [bus error] unable to open /dev/ttyUSB0: ERR: generic device error
2019-10-29 19:13:59.888 [bus notice] bus started with own address 31/36
2019-10-29 19:13:59.889 [bus notice] device invalid
john30
wenn du ebusd im Vordergrund startest, musst du natürlich dafür sorgen dass er nicht auch gleichzeitig als Dienst läuft. Hast du?
was mit openhab schief läuft, kann ich dir nicht sagen.
author of ebusd
Trainer
Vielen Dank.
Ich habe ebusd neu installiert und den dc/dc Wandler eingebaut. Jetzt erhalte ich Daten mit einer relativ kleinen Fehlübertragung.
Ist es möglich das raumbediengerät von Vaillant handlich über die SW zu Übersteuern so dass man aus der Ferne die Heizung steuern kann?
martin8310
Hallo John30,
kannst Du mir sagen welche Version ich vom eBusD installiert habe?
ebusctl -p 8889 info zeigt folgendes an:
version: ebusd 3.4.v3.3-51-g57eae05
update check: revision v3.4 available
eigentlich sollte das die neuste Version (heute installiert) sein, warum steht dann dort "revision v3.4 available"?
Gruß und Dank
Martin
