Warnungen von warnung.bund.de in FHEM einbinden
Begonnen von oesi, 02 Februar 2016, 19:32:26
dennisk
#405
Ich habe mir mal angesehen, wie ich unter Perl 5.40 die Warnungen hinsichtlich Smartmatch und given/when loswerden kann.
2024.09.01 14:04:25 1: PERL WARNING: Smartmatch is deprecated at /usr/share/fhem/FHEM/77_Nina.pm line 125, <$fh> line 1619.
2024.09.01 14:04:25 1: PERL WARNING: given is deprecated at /usr/share/fhem/FHEM/77_Nina.pm line 174, <$fh> line 1619.
2024.09.01 14:04:25 1: PERL WARNING: when is deprecated at /usr/share/fhem/FHEM/77_Nina.pm line 176, <$fh> line 1619.
2024.09.01 14:04:25 1: PERL WARNING: when is deprecated at /usr/share/fhem/FHEM/77_Nina.pm line 181, <$fh> line 1619.
2024.09.01 14:04:25 1: PERL WARNING: Smartmatch is deprecated at /usr/share/fhem/FHEM/77_Nina.pm line 231, <$fh> line 1619.
2024.09.01 14:04:25 1: PERL WARNING: Smartmatch is deprecated at /usr/share/fhem/FHEM/77_Nina.pm line 538, <$fh> line 1619.
2024.09.01 14:04:25 1: PERL WARNING: Smartmatch is deprecated at /usr/share/fhem/FHEM/77_Nina.pm line 786, <$fh> line 1619.
2024.09.01 14:04:25 1: PERL WARNING: Smartmatch is deprecated at /usr/share/fhem/FHEM/77_Nina.pm line 971, <$fh> line 1619.
2024.09.01 14:04:25 1: PERL WARNING: Smartmatch is deprecated at /usr/share/fhem/FHEM/77_Nina.pm line 974, <$fh> line 1619.
2024.09.01 14:04:25 1: PERL WARNING: Smartmatch is deprecated at /usr/share/fhem/FHEM/77_Nina.pm line 977, <$fh> line 1619.
2024.09.01 14:04:25 1: PERL WARNING: Smartmatch is deprecated at /usr/share/fhem/FHEM/77_Nina.pm line 1060, <$fh> line 1619.
2024.09.01 14:04:25 1: PERL WARNING: Smartmatch is deprecated at /usr/share/fhem/FHEM/77_Nina.pm line 1063, <$fh> line 1619.
2024.09.01 14:04:25 1: PERL WARNING: Smartmatch is deprecated at /usr/share/fhem/FHEM/77_Nina.pm line 1066, <$fh> line 1619.
2024.09.01 14:04:25 1: PERL WARNING: Smartmatch is deprecated at /usr/share/fhem/FHEM/77_Nina.pm line 1151, <$fh> line 1619.
2024.09.01 14:04:25 1: PERL WARNING: Smartmatch is deprecated at /usr/share/fhem/FHEM/77_Nina.pm line 1155, <$fh> line 1619.
2024.09.01 14:04:25 1: PERL WARNING: Smartmatch is deprecated at /usr/share/fhem/FHEM/77_Nina.pm line 1159, <$fh> line 1619.
Rausgekommen ist der angehängte Patch. Ich hoffe, der Lösungsansatz ist adäquat - ich bin absolut kein Perl-Experte. Wenn das übernommen werden könnte, gerne auch angepasst, falls erforderlich, wäre super.
Ich hoffe, es ist in Ordnung, dass ich den Patch hier poste, da sich dieser Thread angeboten hat.
Edit 06.01.2025: Auf Hinweis von KölnSolar habe ich auch die gepatchte Version des Moduls hier angehängt.
dennisk
Zitat von: dennisk am 29 September 2024, 12:44:48Ich hoffe, es ist in Ordnung, dass ich den Patch hier poste, da sich dieser Thread angeboten hat.
Ich wollte noch einmal nachfragen, ob die Einreichung des Patches so in Ordnung ist und ob dieser übernommen werden kann?
Sailor
Zur Info
Ich habe ein NINA - Icon mit in das fhem - repository aufnehmen lassen.
Ihr könnt dies jetzt mit dem attr NinaDevice icon nina - Befehl zuordnen.
   Sailor
Man wird immer besser...
dennisk
Zitat von: dennisk am 15 Oktober 2024, 14:49:47Ich wollte noch einmal nachfragen, ob die Einreichung des Patches so in Ordnung ist und ob dieser übernommen werden kann?
@KölnSolar Passt der Patch aus Deiner Sicht, könntest Du diesen übernehmen?
dennisk
Auf Vorschlag von KölnSolar habe ich die gepatchte Version des Moduls im Beitrag 405 angehängt. Funktioniert bei mir bisher ohne Probleme.
KölnSolar
In Osterholz ist man schlauerweise auf die Idee gekommen ein "|" in den Warntext einzubauen, welches im Modul aber auch "technisch" benutzt wird.
Ich hab die letzte Version von dennisk entsprechend angepasst und nun als aktuellste Version im Dokuthread eingestellt.
Grüße Markus
