unpeer?
Begonnen von stgeran, 21 März 2016, 16:44:18
JayP
#15
list Kz.Heizung:
   CUL868_MSGCNT 3
   CUL868_RAWMSG A0F3C86103BD8200000000A94CF0E0000::-39:CUL868
   CUL868_RSSI -39
   CUL868_TIME 2016-11-09 11:39:09
   DEF        3BD820
   IODev      CUL868
   LASTInputDev CUL868
   MSGCNT     3
   NAME       Kz.Heizung
   NOTIFYDEV  global
   NR         61
   NTFY_ORDER 50-Kz.Heizung
   STATE      CMDs_done
   TYPE       CUL_HM
   channel_01 Kz.Heizung_Weather
   channel_02 Kz.Heizung_Climate
   channel_03 Kz.Heizung_WindowRec
   channel_04 Kz.Heizung_Clima
   channel_05 Kz.Heizung_ClimaTeam
   channel_06 Kz.Heizung_remote
   lastMsg    No:3C - t:10 s:3BD820 d:000000 0A94CF0E0000
   protLastRcv 2016-11-09 11:39:09
   rssi_at_CUL868 cnt:3 max:-38.5 min:-39 avg:-38.66 lst:-39
   Readings:
     2016-11-09 11:33:15   Activity        alive
     2016-11-09 11:28:46   CommandAccepted yes
     2016-10-07 13:29:53   D-firmware      1.4
     2016-10-07 13:29:53   D-serialNr      BLUBB
     2016-10-07 13:34:53   PairedTo        0xB89B12
     2016-10-07 13:34:53   R-backOnTime    10 s
     2016-10-07 13:34:53   R-burstRx       on
     2016-10-07 13:34:53   R-cyclicInfoMsg on
     2016-10-07 13:34:53   R-cyclicInfoMsgDis 0
     2016-10-07 13:34:53   R-pairCentral   0xB89B12
     2016-10-07 13:34:53   RegL_00.        01:01 02:01 09:01 0A:B8 0B:9B 0C:12 0E:0A 0F:00  11:00 12:15 16:00 18:00 19:00 1A:00 00:00
     2016-11-09 09:12:28   RegL_07.
     2016-11-09 11:39:09   actuator        0
     2016-11-09 11:39:09   battery         ok
     2016-11-09 11:39:09   batteryLevel    2.9
     2016-11-09 11:39:09   desired-temp    18.5
     2016-11-09 11:39:09   measured-temp   20.7
     2016-11-09 11:39:09   motorErr        ok
     2016-11-09 11:28:47   state           CMDs_done
     2016-11-08 18:11:55   time-request    -
   Helper:
     HM_CMDNR   60
     mId        0095
     rxType     140
     Expert:
       def        1
       det        0
       raw        1
       tpl        0
     Io:
       newChn     +3BD820,00,01,00
       nextSend   1478687949.88602
       rxt        2
       vccu       VCCU
       p:
         3BD820
         00
         01
         00
       prefIO:
         CUL868
     Mrssi:
       mNo        3C
       Io:
         CUL868     -37
     Prt:
       bErr       0
       sProc      0
     Q:
       qReqConf
       qReqStat
     Role:
       dev        1
       prs        1
     Rssi:
       At_cul868:
         avg        -38.6666666666667
         cnt        3
         lst        -39
         max        -38.5
         min        -39
     Shregw:
       07         04
     Tmpl:
   IODev      CUL868
   IOgrp      VCCU:CUL868
   actCycle   000:10
   actStatus  alive
   autoReadReg 4_reqStatus
   expert     2_raw
   firmware   1.4
   model      HM-CC-RT-DN
   room       Kinderzimmer,Heizung
   serialNr   BLUBB
   subType    thermostat
   webCmd     getConfig:clear msgEvents:burstXmit
Danke schon mal für Eure Hilfe.
Jay
FHEM 5.7 auf ODROID C2, CUL868, MaxCube mit culfw auf 433Mhz, Jeelink 868Mhz, 4x HM-CC-RT-DN, 1x HM-LC-Bl1-FM, 7x IT-Steckdosen, 5x LaCrosse Sensoren, 3x Revolt NC-5462, 1x SD_WS07, 2x G-Tag, Logitech Media Server auf Zyxel, ASUS TF300t mit Android 6 und TabletUI, u.v.m.
Zitat von: JayP am 09 November 2016, 11:39:37
Vielleicht versteh ich auch nicht, was Ihr von mir möchtet....
Jay
In der set Zeile, dort wo burstxmit steht, sollte es peerChan geben...
JayP
Leider nein.
kein peerChan.
Jay
Komisch, aber dann nimm peerBulk
dahinter die PeerID aus dem list -->B89B1202 unset
JayP
Auch da passiert leider nichts.
Der Befehl wird entgegen genommen. Hat aber keine Auswirkungen.
set Kz.Heizung_Weather peerBulk B89B1202 unset
Jay
Naja muss eventuell erst übertragen werden. Ich habe leider die Thermostate nicht, ich kenne deren Verhallten nicht.
Ich glaube die senden und empfangen nur im 3 min Abstand? Kannst Du ansatzweise überwachen im Hauptdevice Kz.Heizung.
Und in dem virtuellen Kanal musst Du das auch noch machen. Natürlich umgekehrt.
JayP
Dies hat wohl geholfen. :-)
Vielen vielen Dank.
Es dauert wohl etwas länger bis das Peering verschwindet.
Jay
Ja, oberster Grundsatz bei vielen Dingen und vor allem bei Homematic und deren Konfiguration ist --> Ruhe bewahren!
Hektisches wiederholen, löschen und resetten ist absolut kontraproduktiv!
arne.dien
peerChan gibt's beim Sensor...
Wenn's den nicht mehr gibt, dann hilft ein virtueller Sensor...
Das ganze ist in Einsteiger-PDF sehr gut beschrieben. Das Homematic-Kapitel ist sehr gut und zeigt die Möglichkeiten, die in dem System stecken.
FHEM 5.9, RasPi 3 B, HM-LAN, RFXtrx433, Harmony
Homematic, Licht, Rolladen, Heizkörper, Rauchmelder...
ESP RGBWW, LD316...
Es ist selten zu spät aber immer höchste Zeit...
martinp876
Wie wäre mit peerbulk xxxxxxxx unset?
Hat er doch gemacht und hat funkioniert.  ;)
