Seit einigen Tagen Probleme mit weekdaytimer
Begonnen von kabakakao, 25 März 2016, 10:26:58
Dietmar63
Gruß Dietmar
FB7390, CUL, 2 FHT, FS20
DerTom
#16
Hallo Dietmar,
nächstes Update, wieder Probleme. Habe heute ein Update gemacht und wieder bleibt FHEM nach dem Neustart mit der Meldung im Log hängen:
2016.10.16 15:01:21.075 3: [HC_FLU_FT_HO] switch of FLU_FHT80B delayed - sensor 'FLU_TFK_STR' Reading/Attribute 'Window' is 'Open'
2016.10.16 15:01:21.159 3: [HC_KUE_FT] switch of KUE_FHT80B delayed - sensor 'KUE_TFK' Reading/Attribute 'Window' is 'Open'
2016.10.16 15:01:21.266 1: PERL WARNING: Use of uninitialized value $timToSwitch in subtraction (-) at ./FHEM/98_WeekdayTimer.pm line 570.
Can't use an undefined value as an ARRAY reference at ./FHEM/98_WeekdayTimer.pm line 996.
Nachdem ich nun wieder die vorher funktionierende und auch schon beim letzten Update zurückgesicherte 98_WeekdayTimer.pm zurückgesichert habe, startet FHEM aber nun tauchen im Log (Verbose 5) gehäuft Einträge dieser Art auf:
2016.10.16 16:35:24.341 1: [HC_KUE_FT] possible overwriting of timer HC_KUE_FT_2 - please delete first
2016.10.16 16:35:24.341 3: stacktrace:
2016.10.16 16:35:24.342 3:     main::myInternalTimer               called by ./FHEM/98_WeekdayTimer.pm (556)
2016.10.16 16:35:24.342 3:     main::WeekdayTimer_SetTimer         called by ./FHEM/98_WeekdayTimer.pm (492)
2016.10.16 16:35:24.342 3:     main::WeekdayTimer_SetTimerOfDay    called by ./FHEM/98_WeekdayTimer.pm (919)
2016.10.16 16:35:24.343 3:     main::WeekdayTimer_Attr             called by ./FHEM/98_Heating_Control.pm (96)
2016.10.16 16:35:24.343 3:     main::Heating_Control_Attr          called by fhem.pl (3222)
2016.10.16 16:35:24.343 3:     main::CallFn                        called by fhem.pl (2582)
2016.10.16 16:35:24.343 3:     main::CommandAttr                   called by fhem.pl (1085)
2016.10.16 16:35:24.344 3:     main::AnalyzeCommand                called by ./FHEM/01_FHEMWEB.pm (2263)
2016.10.16 16:35:24.344 3:     main::FW_fC                         called by ./FHEM/01_FHEMWEB.pm (765)
2016.10.16 16:35:24.344 3:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (456)
2016.10.16 16:35:24.345 3:     main::FW_Read                       called by fhem.pl (3222)
2016.10.16 16:35:24.345 3:     main::CallFn                        called by fhem.pl (672)
Diese Einträge werden immer erstellt, bevor das dazugehörige HC-Modul ein "open window" meldet.
Vielleicht ist ja diese Meldung auch nur ein Problem mit der doch nun älteren Version der 98_WeekdayTimer.pm, welche nicht mehr zur aktuellen Verion von FHEM passt. Da habe ich aber wieder das Problem, daß FHEM nicht startet. Wie kann ich das beheben. Meine WD oder HC sind ja nun nicht gerade kompliziert gestrickt, wie schon das Bsp. im Thread zeigte...
Gruß Thomas
DerTom
#17
mittlerweile habe ich festgestellt, daß die definierten HC und WD zwar so tun, als sollten sie eine Aktion auslösen:
2016-10-18 19:05:00.070 WeekdayTimer HC_Heizung_Woche nextUpdate: 2016-10-19 05:00:00
2016-10-18 19:05:00.070 WeekdayTimer HC_Heizung_Woche nextValue: on
2016-10-18 19:05:00.070 WeekdayTimer HC_Heizung_Woche off
machen es aber nicht. Es wird nur schön mit der Meldung
2016.10.18 19:05:00.047 3: Please define @ first
quittiert.
Edit: Wenn ich die aktuelle 98_WeekdayTimer.pm  (vom 22.05.2016) nach dem Neustart auf meinen Cubie lade und mit reload aktiviere, funktioniert das Schalten wieder. Wahrscheinlich bis zum nächsten Reboot, weil FHEM dann wieder abstürzt.
Ich bekomme aber weiterhin noch einige Einträge im Log:
2016.10.18 21:00:00.014 1: PERL WARNING: Use of uninitialized value in string gt at ./FHEM/98_WeekdayTimer.pm line 955.
2016.10.18 21:00:00.015 3: stacktrace:
2016.10.18 21:00:00.015 3:     main::__ANON__                      called by ./FHEM/98_WeekdayTimer.pm (955)
2016.10.18 21:00:00.016 3:     main::WeekdayTimer_Device_Schalten  called by ./FHEM/98_WeekdayTimer.pm (745)
2016.10.18 21:00:00.016 3:     main::WeekdayTimer_Update           called by ./FHEM/98_Heating_Control.pm (85)
2016.10.18 21:00:00.016 3:     main::Heating_Control_Update        called by fhem.pl (2825)
2016.10.18 21:00:00.017 3:     main::HandleTimeout                 called by fhem.pl (604)
2016.10.18 21:00:00.020 2: FHT set SZO_FHT80B desired-temp 17.0
2016.10.18 21:00:00.090 1: PERL WARNING: Use of uninitialized value in string gt at ./FHEM/98_WeekdayTimer.pm line 955.
2016.10.18 21:00:00.091 3: stacktrace:
2016.10.18 21:00:00.091 3:     main::__ANON__                      called by ./FHEM/98_WeekdayTimer.pm (955)
2016.10.18 21:00:00.091 3:     main::WeekdayTimer_Device_Schalten  called by ./FHEM/98_WeekdayTimer.pm (745)
2016.10.18 21:00:00.092 3:     main::WeekdayTimer_Update           called by ./FHEM/98_Heating_Control.pm (85)
2016.10.18 21:00:00.092 3:     main::Heating_Control_Update        called by fhem.pl (2825)
2016.10.18 21:00:00.092 3:     main::HandleTimeout                 called by fhem.pl (604)
2016.10.18 21:00:00.096 2: FHT set KUE_FHT80B desired-temp 17.0
2016.10.18 21:00:00.166 1: PERL WARNING: Use of uninitialized value in string gt at ./FHEM/98_WeekdayTimer.pm line 955.
2016.10.18 21:00:00.166 3: stacktrace:
2016.10.18 21:00:00.167 3:     main::__ANON__                      called by ./FHEM/98_WeekdayTimer.pm (955)
2016.10.18 21:00:00.167 3:     main::WeekdayTimer_Device_Schalten  called by ./FHEM/98_WeekdayTimer.pm (745)
2016.10.18 21:00:00.167 3:     main::WeekdayTimer_Update           called by ./FHEM/98_Heating_Control.pm (85)
2016.10.18 21:00:00.168 3:     main::Heating_Control_Update        called by fhem.pl (2825)
2016.10.18 21:00:00.168 3:     main::HandleTimeout                 called by fhem.pl (604)
Würde mich über Hilfe freuen...
Dietmar63
Gruß Dietmar
Dietmar63
mein Code(aktuelle Version) passt nicht zu deinen FMs.
Wir sollten versuchen die neueste Version zum Laufen zu bringen.
kannst du bitte mal deine Definition des WDT oder HC,  der das Problem verursacht hier posten. Ich kann die Variante  dann bei mir prüfen.
Deine Fehlerbeschreibungen(verbose 5) enthalten leider nicht die entscheidenden Stellen, an denen ich herausfinden kann warum deine Definition nicht geht.
Bei mir gibt es seit vielen Monaten keine Probleme.
Gruß Dietmar
DerTom
Vielen Dank für die Antwort!
Na, dann such Dir mal was aus, im Endeffekt sind es alle WD und HC, die Einträge im Log verursachen:
define HC_AZO_FT Heating_Control AZO_FHT80B  12345|10:00|21.0 12345|22:00|17.0 (Value("Feiertag") eq "ja")
attr HC_AZO_FT disable 0
attr HC_AZO_FT room Heizung
attr HC_AZO_FT switchInThePast 1
attr HC_AZO_FT windowSensor AZO_TFK
define HC_BDO_FT Heating_Control BDO_FHT80B  12345|07:05|21.0 12345|22:00|18.0 (Value("Feiertag") eq "ja")
attr HC_BDO_FT disable 0
attr HC_BDO_FT room Heizung
attr HC_BDO_FT switchInThePast 1
attr HC_BDO_FT windowSensor BDO_TFK_HOFLI BDO_TFK_HOFRE
define HC_BDU_FT_HO Heating_Control BDU_FHT80B  12345|07:05|18.0 12345|22:00|18.0 (Value("Feiertag") eq "ja") || (Value("Homeoffice") eq "ja")
attr HC_BDU_FT_HO disable 0
attr HC_BDU_FT_HO room Heizung
attr HC_BDU_FT_HO switchInThePast 1
attr HC_BDU_FT_HO windowSensor BDU_TFK
define HC_WZU_FT_HO Heating_Control WZU_FHT80B  12345|09:00|21.0 1234|22:00|18.0 5|23:00|18.0 (Value("Feiertag") eq "ja") || (Value("Homeoffice") eq "ja")
attr HC_WZU_FT_HO disable 0
attr HC_WZU_FT_HO room Heizung
attr HC_WZU_FT_HO switchInThePast 1
attr HC_WZU_FT_HO windowSensor WZ_TFK_HOF WZ_TFK_STRLI WZ_TFK_STRRE
define HC_Heizung_Woche WeekdayTimer KEL_HM_ACT_2_Sw_04 12345|05:00|on 12345|07:00|off 12345|15:00|on 12345|22:00|off (Value("Feiertag") eq "nein") && (Value("Homeoffice") eq "nein")
attr HC_Heizung_Woche disable 0
attr HC_Heizung_Woche room Heizung
attr HC_Heizung_Woche switchInThePast 1
define HC_Heizung_WE WeekdayTimer KEL_HM_ACT_2_Sw_04 06|07:00|on 06|22:00|off
attr HC_Heizung_WE disable 0
attr HC_Heizung_WE room Heizung
attr HC_Heizung_WE switchInThePast 1
define HC_Heizung_HO WeekdayTimer KEL_HM_ACT_2_Sw_04 8|05:00|on 8|22:00|off (Value("Homeoffice") eq "ja")
attr HC_Heizung_HO disable 0
attr HC_Heizung_HO room Heizung
attr HC_Heizung_HO switchInThePast 1
define HC_AZO_normal Heating_Control AZO_FHT80B 12345|16:00|21.0 06|08:00|21.0 12345|22:00|17.0 06|21:00|17.0 (Value("Feiertag") eq "nein") && (Value("Homeoffice") eq "nein")
attr HC_AZO_normal disable 0
attr HC_AZO_normal room Heizung
attr HC_AZO_normal switchInThePast 1
attr HC_AZO_normal windowSensor AZO_TFK
define HC_BDO_normal Heating_Control BDO_FHT80B 12345|05:00|21.0 12345|07:00|18.0 12345|14:00|21.0 12345|21:00|18.0 06|07:00|21.0 06|22:00|18.0 (Value("Feiertag") eq "nein") && (Value("Homeoffice") eq "nein") && (Value("ZuHause_Stat") eq "on")
attr HC_BDO_normal disable 0
attr HC_BDO_normal room Heizung
attr HC_BDO_normal switchInThePast 1
attr HC_BDO_normal windowSensor BDO_TFK_HOFLI BDO_TFK_HOFRE
define HC_BDU_normal Heating_Control BDU_FHT80B 12345|05:00|21.0 12345|07:00|18.0 12345|16:00|21.0 12345|22:00|18.0 06|07:00|21.0 06|22:00|18.0 (Value("Feiertag") eq "nein") && (Value("Homeoffice") eq "nein")
attr HC_BDU_normal disable 0
attr HC_BDU_normal room Heizung
attr HC_BDU_normal switchInThePast 1
attr HC_BDU_normal windowSensor BDU_TFK
define HC_FLU_normal Heating_Control FLU_FHT80B 12345|05:30|18.0 12345|07:00|16.0 12345|14:00|18.0 12345|22:00|16.0 06|07:00|18.0 06|22:00|16.0 (Value("Feiertag") eq "nein") && (Value("Homeoffice") eq "nein") && (Value("ZuHause_Stat") eq "on")
attr HC_FLU_normal disable 0
attr HC_FLU_normal room Heizung
attr HC_FLU_normal switchInThePast 1
attr HC_FLU_normal windowSensor FLU_TFK_HOF FLU_TFK_TUER FLU_TFK_STR
define HC_KUE_normal Heating_Control KUE_FHT80B 12345|05:00|20.0 12345|07:00|17.0 12345|15:00|20.0 12345|21:00|17.0 06|07:00|20.0 06|21:00|17.0 (Value("Feiertag") eq "nein") && (Value("Homeoffice") eq "nein")
attr HC_KUE_normal disable 0
attr HC_KUE_normal room Heizung
attr HC_KUE_normal switchInThePast 1
attr HC_KUE_normal windowSensor KUE_TFK
define HC_WZU_normal Heating_Control WZU_FHT80B 12345|16:00|21.0 12345|22:00|18.0 06|11:00|21.0 06|22:00|18.0 (Value("Feiertag") eq "nein") && (Value("Homeoffice") eq "nein")
attr HC_WZU_normal disable 0
attr HC_WZU_normal room Heizung
attr HC_WZU_normal switchInThePast 1
attr HC_WZU_normal windowSensor WZ_TFK_HOF WZ_TFK_STRLI WZ_TFK_STRRE
define HC_SZO_normal Heating_Control SZO_FHT80B 12345|14:00|18.5 12345|21:00|17.0 06|11:00|18.5 06|22:00|17.0 (Value("ZuHause_Stat") eq "on")
attr HC_SZO_normal disable 0
attr HC_SZO_normal room Heizung
attr HC_SZO_normal switchInThePast 1
attr HC_SZO_normal windowSensor SZO_TFK_HOF SZO_TFK_STR
define HC_SZU_normal Heating_Control SZU_FHT80B 12345|05:30|18.0 12345|07:00|16.5 12345|14:00|18.0 12345|22:00|16.5 06|08:00|18.0 06|22:00|16.5 (Value("ZuHause_Stat") eq "on")
attr HC_SZU_normal disable 0
attr HC_SZU_normal room Heizung
attr HC_SZU_normal switchInThePast 1
attr HC_SZU_normal windowSensor SZU_TFK
define HC_Heizung_FT WeekdayTimer KEL_HM_ACT_2_Sw_04 8|07:00|on 8|22:00|off (Value("Feiertag") eq "ja")
attr HC_Heizung_FT disable 0
attr HC_Heizung_FT room Heizung
attr HC_Heizung_FT switchInThePast 1
Gibt noch einige mehr... aber alle sind gleich gestrickt. Die Values, die als Bedingung gelten sind allesamt Dummies.
Viel interessanter wäre aber die Frage nach dem Absturz beim Start von FHEM. Wie bekomme ich heraus, warum dies geschieht? Und warum es nicht geschieht, wenn ich das aktuelle Modul nachträglich lade...
Dietmar63
Kannst du bitte auch von einem HC auch das Logging mit eingeschaltetem verbose 5 liefern
Gruß Dietmar
DerTom
aber ja:
2016.10.21 07:15:00.042 4: [HC_BDO_normal] time=07:15/1477026900 delay=0, nextDelay=60, nextRetry=1477026960
2016.10.21 07:15:00.044 4: [HC_BDO_normal] delayedExecutionCond:0
2016.10.21 07:15:00.044 4: [HC_BDO_normal] result of delayedExecutionCond:0
2016.10.21 07:15:00.045 4: [HC_BDO_normal] list of window sensors found: 'BDO_TFK_HOFLI BDO_TFK_HOFRE HC_BDO_normal'
2016.10.21 07:15:00.045 5: [HC_BDO_normal] sensor 'BDO_TFK_HOFLI' Reading/Attribute 'Window' is 'Closed'
2016.10.21 07:15:00.046 5: [HC_BDO_normal] sensor 'BDO_TFK_HOFRE' Reading/Attribute 'Window' is 'Closed'
2016.10.21 07:15:00.046 4: [HC_BDO_normal] condition:(Value("Feiertag") eq "nein") && (Value("Homeoffice") eq "nein") && (Value("ZuHause_Stat") eq "on") - Tage:5
2016.10.21 07:15:00.047 5: [HC_BDO_normal] condition: {my $days={};;map{$days->{$_}=1}(5);;;;( (Value("Feiertag") eq "nein") && (Value("Homeoffice") eq "nein") && (Value("ZuHause_Stat") eq "on") && (defined $days->{$wday}))}
2016.10.21 07:15:00.049 5: [HC_BDO_normal] result of condition:1
2016.10.21 07:15:00.050 4: [HC_BDO_normal] Update   - timer seems to be active today: 5|07:15|21.0
2016.10.21 07:15:00.058 4: [HC_BDO_normal] device type FHT: recognized, setModifier:desired-temp
2016.10.21 07:15:00.058 4: [HC_BDO_normal] aktParam:18.0 newParam:21.0 - is  not disabled
2016.10.21 07:15:00.059 4: [HC_BDO_normal] command: 'set $NAME desired-temp $EVENT' executed with %EVENT=>21.0,%NAME=>BDO_FHT80B
2016.10.21 07:15:00.061 2: FHT set BDO_FHT80B desired-temp 21.0
2016.10.21 07:17:00.038 4: [HC_BDO_normal] time=07:17/1477027020 delay=0, nextDelay=60, nextRetry=1477027080
2016.10.21 07:17:00.039 4: [HC_BDO_normal] delayedExecutionCond:0
2016.10.21 07:17:00.040 4: [HC_BDO_normal] result of delayedExecutionCond:0
2016.10.21 07:17:00.040 4: [HC_BDO_normal] list of window sensors found: 'BDO_TFK_HOFLI BDO_TFK_HOFRE HC_BDO_normal'
2016.10.21 07:17:00.041 5: [HC_BDO_normal] sensor 'BDO_TFK_HOFLI' Reading/Attribute 'Window' is 'Closed'
2016.10.21 07:17:00.042 5: [HC_BDO_normal] sensor 'BDO_TFK_HOFRE' Reading/Attribute 'Window' is 'Closed'
2016.10.21 07:17:00.042 4: [HC_BDO_normal] condition:(Value("Feiertag") eq "nein") && (Value("Homeoffice") eq "nein") && (Value("ZuHause_Stat") eq "on") - Tage:5
2016.10.21 07:17:00.043 5: [HC_BDO_normal] condition: {my $days={};;map{$days->{$_}=1}(5);;;;( (Value("Feiertag") eq "nein") && (Value("Homeoffice") eq "nein") && (Value("ZuHause_Stat") eq "on") && (defined $days->{$wday}))}
2016.10.21 07:17:00.045 5: [HC_BDO_normal] result of condition:1
2016.10.21 07:17:00.045 4: [HC_BDO_normal] Update   - timer seems to be active today: 5|07:17|18.0
2016.10.21 07:17:00.054 4: [HC_BDO_normal] device type FHT: recognized, setModifier:desired-temp
2016.10.21 07:17:00.055 4: [HC_BDO_normal] aktParam:21.0 newParam:18.0 - is  not disabled
2016.10.21 07:17:00.056 4: [HC_BDO_normal] command: 'set $NAME desired-temp $EVENT' executed with %NAME=>BDO_FHT80B,%EVENT=>18.0
2016.10.21 07:17:00.058 2: FHT set BDO_FHT80B desired-temp 18.0
Also jetzt bin ich aber verwirrt. Ich hab das eben simuliert. Jetzt kommen keine derartigen Einträge im Log. Ich habe nun bei allen heutigen HC und WD, welche sonst diese Einträge im Log generierten auf verbose 5 gestellt und werden schauen...
Thomas
Dietmar63
Ich würde sagen es lüppt:
Diese Zeile erzeugt das Modul zur Steuerung der FHT - damit hat HC alles richtig gemacht.
Gruß Dietmar
DerTom
#24
Na, nee. Nix lüppt...
Heute abend um 18:37 Uhr als meine Frau nach Hause kam und den Homestatus eingeschaltet hat...ohne jede Vorwarnung kommen ca. 7000 Zeilen Fehler im Log. (siehe Anhang)
und danach ist die Karre gestorben. Bin frustriert und Frau noch mehr. Da ist doch was grundsätzlich im Argen. Werde morgen wohl erst mal neu aufsetzen. Mal sehen obs hilft...
DerTom
habe jetzt mal auf einem anderen Cubie neu aufgesetzt. Danach lief FHEM auf Basis der neuesten Module. Wenn ich aber meine alte Config wieder einspiele stürzt FHEM wieder ab. >:(
Dies ist die letzte Meldung:
2016.10.26 07:39:42.513 1: PERL WARNING: Use of uninitialized value $timToSwitch in subtraction (-) at ./FHEM/98_WeekdayTimer.pm line 570.
2016.10.26 07:39:42.513 3: stacktrace:
2016.10.26 07:39:42.514 3:     main::__ANON__                      called by ./FHEM/98_WeekdayTimer.pm (570)
2016.10.26 07:39:42.514 3:     main::WeekdayTimer_SetTimer         called by fhem.pl (2825)
2016.10.26 07:39:42.514 3:     main::HandleTimeout                 called by fhem.pl (604)
Was ist in diesen Zeilen 98_WeekdayTimer.pm? ???
Dietmar63
Erst man stacktrace ausschalten.
Das nutzt man nur in Ausnahemsituationen.
Den Rest sehe ich mir heute Abend an.
kannst du die Versionen der verwendeten Module liefern - ich glaube es geht mit version.
Gruß Dietmar
DerTom
Die Ausgabe des Befehls "version" kann ich ja nicht liefern, wenn FHEM abstürzt.  Also mit der Version:
# $Id: 98_WeekdayTimer.pm 11504 2016-05-22 20:01:08Z dietmar63 $
kommt die Meldung:
Mit der Version:
# $Id: 98_WeekdayTimer.pm 11041 2016-03-10 18:25:34Z dietmar63 $
die Meldung:
2016.10.26 10:36:14.551 1: PERL WARNING: Use of uninitialized value $timToSwitch in subtraction (-) at ./FHEM/98_WeekdayTimer.pm line 567.
Can't use an undefined value as an ARRAY reference at ./FHEM/98_WeekdayTimer.pm line 974.
Mit der Version:
# $Id: 98_WeekdayTimer.pm 10983 2016-03-02 21:00:12Z dietmar63 $
die Meldung:
2016.10.26 10:54:01.779 1: PERL WARNING: Use of uninitialized value $timToSwitch in subtraction (-) at ./FHEM/98_WeekdayTimer.pm line 566.
Can't use an undefined value as an ARRAY reference at ./FHEM/98_WeekdayTimer.pm line 973.
Mit der Version:
# $Id: 98_WeekdayTimer.pm 10691 2016-01-31 19:23:01Z dietmar63 $
und allen vorherigen läuft es...
Vielleicht grenzt das alles ein wenig ein.
Dietmar63
schaue heute Abend nach.
schon merkwürdig - ich habe seit Monaten mit dem Starten von fhem kein Problem bei den WDT oder HC
Gruß Dietmar
Dietmar63
#29
Ich habe jetzt drei deiner HC in meiner Oberfäche eingegeben.
Abgesehen von einigen Warnungen kein Fehler.
Ich lasse sie mal mit laufen.
In meiner Version schlummert allerdings eine Änderung, die dein Problem eventuell lösen kann.
Version hängt am posting.
define HC_AZO_FT Heating_Control AZO_FHT80B  12345|10:00|21.0 12345|22:00|17.0 (Value("Feiertag") eq "ja");
attr HC_AZO_FT disable 0;
attr HC_AZO_FT room Heizung;
attr HC_AZO_FT switchInThePast 1;
attr HC_AZO_FT windowSensor AZO_TFK;
define HC_AZO_normal Heating_Control AZO_FHT80B 12345|16:00|21.0 06|08:00|21.0 12345|22:00|17.0 06|21:00|17.0 (Value("Feiertag") eq "nein") && (Value("Homeoffice") eq "nein");
attr HC_AZO_normal disable 0           ;
attr HC_AZO_normal room Heizung        ;
attr HC_AZO_normal switchInThePast 1   ;
attr HC_AZO_normal windowSensor AZO_TFK;
define HC_BDO_normal Heating_Control BDO_FHT80B 12345|05:00|21.0 12345|07:00|18.0 12345|14:00|21.0 12345|21:00|18.0 06|07:00|21.0 06|22:00|18.0 (Value("Feiertag") eq "nein") && (Value("Homeoffice") eq "nein") && (Value("ZuHause_Stat") eq "on");
attr HC_BDO_normal disable 0                                ;
attr HC_BDO_normal room Heizung                             ;
attr HC_BDO_normal switchInThePast 1                        ;
attr HC_BDO_normal windowSensor BDO_TFK_HOFLI BDO_TFK_HOFRE;
Gruß Dietmar
