Platine für nanoLGW (LaCrosse Gateway): Platinenbestellung
Begonnen von PeMue, 25 März 2016, 13:35:58
juergs
#195
Irgendwie passt das mit meiner Arduino-Version nicht mehr zusammen.
Dafür geht es jetzt mit einem Terminal Programm! Tja!  >:( ::)
Do you want to delete settings in EEPROM (Y/N)?
Settings deleted.
Node-ID raw data from EEPROM:
0: 0xFF (255)
Altitude raw data from EEPROM:
1: 0xFF (255)
2: 0xFF (255)
3: 0xFF (255)
Temperature Offset raw data from EEPROM:
4: 0xFF (255)
5: 0xFF (255)
Node-ID is: 255 (0xFF)
New value (1-254):
Node-ID set to: 129 (0x81)
Save permanently (Y/N)?
OK.
Altitude is: 65560.5m
new value (0.0-8848.9):
Altitude set to: 120.0m
Altitude set to: 0.0m
OK.
Temperature offset: -1.1 degrees celsius
new value (+-10.0):
Temperature offset set to: 0.0 degrees celsius
new value (+-10.0):
OK.
Save settings ...
Raw data saved in eeprom:
0: 0x81 (129)
1: 0x00 (0)
2: 0x00 (0)
3: 0x00 (0)
4: 0x00 (0)
5: 0x00 (0)
Node-ID           : 129 (0x81)
Altitude          : 0.0m
Temperature offset: 0.0 degrees celsius
activated components:
BH1750 - lightsensor
measuring of battery voltage activ
BME680 init ... done
BH1750 init ... done
Ready, start measuring ...
[35844.00] P: 996.9| T: 21.75| rH: 38.52| IAQ: 25.00 (0)| Static IAQ: 25.00| CO2e: 0.00| bVOC: 0.00
| Gas: 6774.00| UBat: 3.3V| Light: 55.42lx
Zykluszeit (ms): 149
[38844.00] P: 996.9| T: 21.74| rH: 38.49| IAQ: 25.00 (0)| Static IAQ: 25.00| CO2e: 0.00| bVOC: 0.00
| Gas: 25590.00| UBat: 3.3V| Light: 55.42lx
Zykluszeit (ms): 153
[41844.00] P: 996.9| T: 21.81| rH: 38.21| IAQ: 25.00 (0)| Static IAQ: 25.00| CO2e: 0.00| bVOC: 0.00
| Gas: 46215.00| UBat: 3.3V| Light: 55.83lx
Zykluszeit (ms): 154
[44844.00] P: 996.9| T: 21.86| rH: 38.00| IAQ: 25.00 (0)| Static IAQ: 25.00| CO2e: 0.00| bVOC: 0.00
| Gas: 63004.00| UBat: 3.3V| Light: 55.83lx
[47844.00] P: 996.9| T: 21.90| rH: 37.83| IAQ: 25.00 (0)| Static IAQ: 25.00| CO2e: 0.00| bVOC: 0.00
| Gas: 76886.00| UBat: 3.3V| Light: 55.83lx
Es geht nur über Terminal, ohne Return einzugeben...  !!!
Compiled: Thu May 02 18:05:12 2019
Protocol: UniversalSensor
BSEC version: 1.4.7.1
ESP Core Version: 2_5_0
ESP SDK Version: 3.0.0-dev(c0f7b44)
Settings deleted.
0: 0xFF (255)
1: 0xFF (255)
2: 0xFF (255)
3: 0xFF (255)
4: 0xFF (255)
5: 0xFF (255)
New value (1-254):
Node-ID set to: 123 (0x7B)
OK.
OK.
new value (+-10.0):
OK.
Save settings ...
0: 0x7B (123)
1: 0x00 (0)
2: 0x78 (120)
3: 0x00 (0)
4: 0x00 (0)
5: 0x00 (0)
Node-ID           : 123 (0x7B)
Altitude          : 120.0m
RFM69 - 433/868/915MHz transmitter
Hardware-SPI fuer RFM69 aktiviert
NSS an GPIO-Pin 15
RFM69 not found, no wireless transmission !
[38184.00] P: 1011.3| T: 21.82| rH: 38.42| IAQ: 25.00 (0)| Static IAQ: 25.00| CO2e: 0.00| bVOC: 0.00
| Gas: 30005.00| UBat: 3.3V| Light: 61.25lx
[41184.00] P: 1011.3| T: 21.80| rH: 38.42| IAQ: 25.00 (0)| Static IAQ: 25.00| CO2e: 0.00| bVOC: 0.00
| Gas: 101762.00| UBat: 3.3V| Light: 61.25lx
[44184.00] P: 1011.3| T: 21.86| rH: 38.20| IAQ: 25.00 (0)| Static IAQ: 25.00| CO2e: 0.00| bVOC: 0.00
| Gas: 135081.00| UBat: 3.3V| Light: 61.25lx
[47184.00] P: 1011.3| T: 21.90| rH: 37.98| IAQ: 25.00 (0)| Static IAQ: 25.00| CO2e: 0.00| bVOC: 0.00
| Gas: 153388.00| UBat: 3.3V| Light: 61.25lx
Zykluszeit (ms): 155
