Netatmo Modul - 38_netatmo.pm (Support)
Begonnen von Markus M., 17 Mai 2016, 12:37:34
tomcat.x
FHEM: 6.4 auf Raspi 4B, Raspbian (noch Buster), Perl v5.28.1 mit Sender/Empfänger: 3 x CULv3, Duofern Stick
Gateways: FRITZ!Box 6591 (OS: 8.25), Trädfri, ConBee 2,  piVCCU (HM-MOD-RPI-PCB), OpenMQTTGateway
Sensoren/Aktoren: FRITZ!DECT, FS20, FHT, HMS, HomeMatic, Trädfri, DuoFern, NetAtmo, UNIRoll
Dirk070
Neustart von FHEM, jetzt läuft auch Netatmo wieder.
grappa24
#1712
Mein netatmo ist gerade am Durchdrehen .... und müllt mir das Logfile zu   ... wenn das so weitergeht hole ich meine alten FS20 Thermometer wieder raus  ::)
2026.05.03 09:25:04 2: netatmo_D70_ee_50_04_82_be: dataTypes missing, re-initializing device
2026.05.03 09:25:09 2: Netatmo: token request failed: https://api.netatmo.com/oauth2/token: Select timeout/error:
2026.05.03 09:25:09 1: Netatmo: No access token was found! (getDevices)
2026.05.03 09:25:09 1: Netatmo: No access token was found! (getHomecoachs)
2026.05.03 09:25:09 1: netatmo_D70_ee_50_04_82_be: No access token was found! (requestDeviceReadings)
2026.05.03 09:25:25 2: netatmo_M05_00_00_05_83_20: dataTypes missing, re-initializing device
2026.05.03 09:25:25 1: Netatmo: No access token was found! (getDevices)
2026.05.03 09:25:25 1: Netatmo: No access token was found! (getHomecoachs)
2026.05.03 09:25:25 1: netatmo_M05_00_00_05_83_20: No access token was found! (requestDeviceReadings)
2026.05.03 09:25:32 2: Netatmo: token request failed: https://api.netatmo.com/oauth2/token: Select timeout/error:
2026.05.03 09:25:33 2: netatmo_M06_00_00_05_03_b6: dataTypes missing, re-initializing device
2026.05.03 09:25:33 1: Netatmo: No access token was found! (getDevices)
2026.05.03 09:25:33 1: Netatmo: No access token was found! (getHomecoachs)
2026.05.03 09:25:33 1: netatmo_M06_00_00_05_03_b6: No access token was found! (requestDeviceReadings)
2026.05.03 09:26:33 2: netatmo_D70_ee_50_04_82_be: dataTypes missing, re-initializing device
2026.05.03 09:26:38 2: Netatmo: token request failed: https://api.netatmo.com/oauth2/token: Select timeout/error:
2026.05.03 09:26:38 1: Netatmo: No access token was found! (getDevices)
2026.05.03 09:26:38 1: Netatmo: No access token was found! (getHomecoachs)
2026.05.03 09:26:38 1: netatmo_D70_ee_50_04_82_be: No access token was found! (requestDeviceReadings)
2026.05.03 09:26:43 2: netatmo_M05_00_00_05_83_20: dataTypes missing, re-initializing device
2026.05.03 09:26:43 1: Netatmo: No access token was found! (getDevices)
2026.05.03 09:26:43 1: Netatmo: No access token was found! (getHomecoachs)
2026.05.03 09:26:43 1: netatmo_M05_00_00_05_83_20: No access token was found! (requestDeviceReadings)
2026.05.03 09:27:06 2: netatmo_M06_00_00_05_03_b6: dataTypes missing, re-initializing device
2026.05.03 09:27:11 2: Netatmo: token request failed: https://api.netatmo.com/oauth2/token: Select timeout/error:
2026.05.03 09:27:11 1: Netatmo: No access token was found! (getDevices)
2026.05.03 09:27:11 1: Netatmo: No access token was found! (getHomecoachs)
2026.05.03 09:27:11 1: netatmo_M06_00_00_05_03_b6: No access token was found! (requestDeviceReadings)
2026.05.03 09:28:16 2: netatmo_M05_00_00_05_83_20: dataTypes missing, re-initializing device
2026.05.03 09:28:21 2: Netatmo: token request failed: https://api.netatmo.com/oauth2/token: Select timeout/error:
2026.05.03 09:28:21 1: Netatmo: No access token was found! (getDevices)
2026.05.03 09:28:21 1: Netatmo: No access token was found! (getHomecoachs)
2026.05.03 09:28:21 1: netatmo_M05_00_00_05_83_20: No access token was found! (requestDeviceReadings)
2026.05.03 09:28:21 2: netatmo_M06_00_00_05_03_b6: dataTypes missing, re-initializing device
2026.05.03 09:28:21 1: netatmo_M06_00_00_05_03_b6: No access token was found! (requestDeviceReadings)
2026.05.03 09:28:33 2: netatmo_D70_ee_50_04_82_be: dataTypes missing, re-initializing device
2026.05.03 09:28:33 1: Netatmo: No access token was found! (getDevices)
2026.05.03 09:28:33 1: Netatmo: No access token was found! (getHomecoachs)
2026.05.03 09:28:33 1: netatmo_D70_ee_50_04_82_be: No access token was found! (requestDeviceReadings)
2026.05.03 09:29:37 2: netatmo_M05_00_00_05_83_20: dataTypes missing, re-initializing device
2026.05.03 09:29:42 2: Netatmo: invalid json detected
2026.05.03 09:29:42 1: Netatmo: No access token was found! (getDevices)
2026.05.03 09:29:42 1: Netatmo: No access token was found! (getHomecoachs)
2026.05.03 09:29:42 1: netatmo_M05_00_00_05_83_20: No access token was found! (requestDeviceReadings)
2026.05.03 09:29:58 2: netatmo_M06_00_00_05_03_b6: dataTypes missing, re-initializing device
2026.05.03 09:29:58 1: Netatmo: No access token was found! (getDevices)
2026.05.03 09:29:58 1: Netatmo: No access token was found! (getHomecoachs)
2026.05.03 09:29:58 1: netatmo_M06_00_00_05_03_b6: No access token was found! (requestDeviceReadings)
2026.05.03 09:30:20 2: netatmo_D70_ee_50_04_82_be: dataTypes missing, re-initializing device
2026.05.03 09:30:25 2: Netatmo: token request failed: https://api.netatmo.com/oauth2/token: Select timeout/error:
2026.05.03 09:30:25 1: Netatmo: No access token was found! (getDevices)
2026.05.03 09:30:25 1: Netatmo: No access token was found! (getHomecoachs)
2026.05.03 09:30:25 1: netatmo_D70_ee_50_04_82_be: No access token was found! (requestDeviceReadings)
2026.05.03 09:30:42 2: netatmo_M05_00_00_05_83_20: dataTypes missing, re-initializing device
2026.05.03 09:30:42 1: Netatmo: No access token was found! (getDevices)
2026.05.03 09:30:42 1: Netatmo: No access token was found! (getHomecoachs)
2026.05.03 09:30:42 1: netatmo_M05_00_00_05_83_20: No access token was found! (requestDeviceReadings)
Gebäudesicherheit/-komfort, PV-Prognose/Verbrauchssteuerung, Heizungssteuerung, Multimedia, ...
KNX, FS20, HM, HUE, Tradfri, Shellies, KLF200, Netatmo, Nuki, SolarForecast, HEOS, Alexa-FHEM, ...
FHEM 6.4, 2 x RasPi 3B+, Debian Bullseye
Hanjo
Guten Morgen,
gleiches bei mir - heute Nacht ist mir das Modul wieder um die Ohren geflogen:
2026.05.03 03:47:32 1: Netatmo: No access token was found! (getDevices)
2026.05.03 03:47:32 1: Netatmo: No access token was found! (getHomecoachs)
Beim Check gerade habe ich dann herausgefunden, dass meine App bei Netatmo verschwunden ist und ich auch keine neue Anlegen kann, da es eine Fehlermeldung auf der Netatmo-Webseite gibt ("TypeError: t.t0.text is not a function").
Vermutlich ein Problem bei denen...
tomhead
#1714
Bei mir das gleiche: in FHEM "No access token was found", bei Netatmo ist meine App verschwunden und ich kann auch keine neue anlegen. Habe auch gerade gesehen, dass über die offizielle iOS App auch keine Verbindung zustande kommt. Vermutlich dann ein aktuelles Serverproblem bei Netatmo...
BroPi
Das Gleiche heute Nacht auch bei mir. Das Log lief voll und FHEM reagierte sehr träge. ( Da wäre vielleicht noch ein Abschalt-Timer nötig?) Das Problem liegt bei Netatmo. Auch die Android App zeigt Serverfehler. Ich denke, wir müssen erst mal abwarten bis der Netatmo-Server wieder läuft.
tomhead
OK, scheint nun wieder zu laufen, sowohl in App als auch FHEM
Toto1973
Raspberry PI2, Rademacher DuoFern Stick, CUL, 2 x SCC,  JeeLink 868 Mhz, JeeLink 433 Mhz, 3x Magic UFO LED WiFi Controller, 4x MAX BC-RT-TRX-CyG, 2x MAX Fensterkontakt, 5x Rademacher Gurtwickler, 6x TX29DTH-it, 2x TX25-it als Helligkeitssensor, 1X HM-ES-PM, 6x Sonoff, 7x G-Homa, PIR-1000
maci
#1718
Zitat von: Hanjo am 03 Mai 2026, 09:34:54...heute Nacht ist mir das Modul wieder um die Ohren geflogen:
Ich hoffe das Teil hat dich verfehlt! ;)
Nachdem auf der App auch nichts war, tippte ich gleich auf Server.
Ich hatte danach allerdings das Problem, dass sich meine Aussenstation und auch der Regenmesser nicht verbinden wollten. Erst nach einem Neustart der Basisstation verbindete sich der Regenmesser wieder. Die Aussnstation brauchte eine extra Einladung, in Form von Batterie entfernen und wieder einsetzen.
Fhem auf Dell Thinclient, Fhem auf Raspebrry Pi4,
UniPi Vers. 1.1 mit Raspberry Pi3, 1wire USB Adapter mit OWX
Netatmo Wetterstation + Regenmesser + Netatmo Thermostat
Homematic mit HMLan
flydd
So eine Logfile-Explosion sollte zukünftig nicht mehr vorkommen. Ist im Zeitalter von Codex eine Sache von 5 Minuten, das zu fixen. Da war der Fix letztes Jahr noch richtig aufwändig im Vergleich...
BroPi
Danke für die schnelle Korrektur. Die Logfile-Explosion hatte ganz FHEM lahmgelegt.
BroPi
@flydd an dich hier die Frage, ob du dieses Modul als Maintainer übernehmen wolltest/könntest?
Du hast hier immer sehr schnell und kompetent die aktuell auftretenden Fehler beseitigt. Das hat sicherlich alle, die dieses Modul nutzen, sehr positiv überrascht. Wichtig ist ja für uns alle, dass das Modul ins offizielle SVN übernommen wird.
Ich hatte auch an MarkusM (der eingetragene Maintainer) am 08.04.2026 eine PM geschickt, aber bisher keine Antwort bekommen. Wir können also davon ausgehen, hier keine weitere Unterstützung zu bekommen.
Also wenn du einverstanden bist, müssten wir uns an Rudolf Köning wenden, um dich als Maintainer einzutragen.
grappa24
#1722
Habt ihr aktuell auch Probleme mit der API bzw dem Server?
erledigt, war nicht netarmo, war mein echo Amazon.Account
flydd
Ich hatte tatsächlich mit der letzten Version auch Probleme. Ich habe Codex etwas an der Stabilität des Plugins arbeiten lassen. Läuft bei mir bislang zuverlässig, aber wie immer: Benutzung erfolgt auf eigene Gefahr. Und nein, ich möchte kein Maintainer des Pakets werden, ich weiß nicht, wie lange ich FHEM tatsächlich noch die Stange halten kann, manches ist halt einfach in die Jahre gekommen.
m.zielinski
#1724
Ich habe deine Version von heute installiert und bekomme seitdem stündlich solche logeinträge:
Netatmo: unknown 'homecoachsdata' {
  'time_server' => 1780858503,
  'status' => 'ok',
  'body' => {
              'user' => {
              'administrative' => {                                'pressureunit' => 0,
                                                'windunit' => 0,
                                                'unit' => 0,
                                                'feel_like_algo' => 0,
                                                'reg_locale' => 'de-DE',
                                                'lang' => 'de',
                                                'country' => 'DE'
                          'mail' => 'mmi@gmx.de'
              'devices' => []
  'time_exec' => '0.0322029590606689'
