DOIF Batterieüberwachung
Begonnen von weini, 02 Juni 2016, 23:35:59
Ellert
Zitat von: weini am 06 September 2016, 23:21:22
Ellert meint vermutlich "lt" als Ersatz für ">". Nach meinem Verständnis müsste das aber "gt" sein, also:
[?$SELF:$DEVICE] gt "0" and [?$SELF:$DEVICE]
Wie gesagt, ich kann es selbst nicht testen, weil der Fehler bei mir nicht reproduzierbar ist.
Ja, gt ist natürlich richtig.
moonsorrox
OK, dann werde ich das mal testen...
moonsorrox
das war es nicht, es geht munter weiter hier die letzten Auszüge
2016.09.07 17:50:44 1: PERL WARNING: Argument "low" isn't numeric in numeric le (<=) at (eval 3494886) line 1.
2016.09.07 17:47:27 1: PERL WARNING: Argument "low" isn't numeric in numeric le (<=) at (eval 3491872) line 1.
2016.09.07 17:45:04 1: PERL WARNING: Argument "low" isn't numeric in numeric le (<=) at (eval 3490462) line 1.
2016.09.07 17:42:26 1: PERL WARNING: Argument "low" isn't numeric in numeric le (<=) at (eval 3488324) line 1.
2016.09.07 17:39:31 1: PERL WARNING: Argument "low" isn't numeric in numeric le (<=) at (eval 3486844) line 1.
2016.09.07 17:36:21 1: PERL WARNING: Argument "low" isn't numeric in numeric le (<=) at (eval 3484626) line 1.
2016.09.07 17:34:05 1: PERL WARNING: Argument "low" isn't numeric in numeric le (<=) at (eval 3482645) line 1.
hier nochmal das DEF:
( ([":^battery:.*low"] or [":^battery:.*0"]) and [?$SELF:$DEVICE] eq "0") ( {DebianMail('xxxxxxxxxxxx@gmx.de', 'FHEM Batteriewarnung', "$DEVICE: $EVENT")}, {Log 3,"$DEVICE: Batteriewarnung $EVENT"}, setreading $SELF $DEVICE low) DOELSEIF ( ([":^battery:.*low"] or [":^battery:.*0"]) and ([?$SELF:$DEVICE] eq "ok" or [?$SELF:$DEVICE] eq "novalue")) (setreading $SELF $DEVICE [$SELF:delayCounter]) DOELSEIF ( ([":^battery:.*low"] or [":^battery:.*0"]) and [?$SELF:$DEVICE] gt "0" and [?$SELF:$DEVICE] <= [?$SELF:delayCounter]) (setreading $SELF $DEVICE {([$SELF:$DEVICE])-1}) DOELSEIF ( ([":^battery:.*ok"] or [":^battery:.*1"]) and [?$SELF:$DEVICE] ne "ok") (setreading $SELF $DEVICE ok)
Ellert
Der aufmerksame Leser sieht, das es eine andere Warnung ist und die ist nach dem gleichen Prinzip zu beheben  ;)
moonsorrox
#19
echt...  ;) ich habe jetzt wirklich nicht gesehen das es eine andere Meldung ist (<=)
Da ich aber Perl überhaupt nicht verstehe, fehlt mir da jede Beziehung und kann somit auch nichts dazu beitragen  :-\
wäre diese Variante jetzt richtig..?
[?$SELF:$DEVICE] gt "<=" [?$SELF:delayCounter]
weini
nicht ganz...   ;)
Versuch bitte:
[?$SELF:$DEVICE] le [?$SELF:delayCounter]
Morgennebel
Nur als Zusammenfassung und für den nächsten, der dies implementieren möchte - das DOIF mit einer Pushbullet-Notification und allen Korrekturen:
( set PBNotification message 'Intelligentes Wohnen' | 'Batteriewarnung $DEVICE: $EVENT', setreading $SELF $DEVICE low)
DOELSEIF ( ([":^battery:.*low"] or [":^battery:.*0"]) and [?$SELF:$DEVICE] gt 0 and [?$SELF:$DEVICE] le [?$SELF:delayCounter])
Die Attribute sind noch zusätzlich zu setzen.
Ciao, -MN
Einziger Spender an FHEM e.V. mit Dauerauftrag seit >= 24 Monaten
FHEM: MacMini/ESXi, 2-3 FHEM Instanzen produktiv
In-Use: STELLMOTOR, VALVES, PWM-PWMR, Xiaomi, Allergy, Proplanta, UWZ, MQTT,  Homematic, Luftsensor.info, ESP8266, ESERA
satprofi
hallo.
Gutes neues Jahr vorerst.
Aber jetzt zur Frage, kann mir jemand die Funktion ausdeutschen?
[?Battery:$DEVICE]
m.f.g.
HMLAN, HM-CC-RT-DN,Homematic Actoren,Zigbee,Shelly,
Tasmota,LD382A,Telegram
Morgennebel
Das steht aber nirgends im DOIF...
Ciao, -MN
satprofi
in deinem nicht, aber im DOIF manual bzgl. batterieabfrage
Morgennebel
Steht doch alles in der COMMANDREF.
Battery ist ein Dummy. setreading erzeugt künstliche Readings mit dem Namen des $DEVICE.
Dann ist [?Battery:DEVICE] eine nicht-triggerende DOIF-Abfrage, ob dieses Reading bereits existiert.
Das DOIF hier im Thread kommt ohne den Dummy aus, da die künstlichen Readings im DOIF selbst (via $SELF) erzeugt werden.
Ciao, -MN
satprofi
aha,
dann würde das ja auch genügen ?
define di_battery DOIF ([":battery: low"])
    ({DebianMail('yourname@gmail.com', 'FHEM - battery warning from device: $DEVICE'})
weini
Ja, das sollte auch passen.
Ich habe die kompliziertere Logik mit den Readings aufgebaut, weil ich bei mir ein paar Batteriegeräte habe, die manchmal einen Fehlalarm bzgl. des Batteriezustands provozieren. Deshalb löst ein DOIF erst aus, wenn der Alarm eine konfigurierbare Anzahl mal wiederholt aufgetreten ist.
satprofi
Hallo.Ich verzweifle mal wieder mit der fiesen Batterieüberwachung.
habe DOIF
DOIF (["^:battery:low"] or ["^:Battery:low"] ) (set Telegram message @xxxxxxxx send 'Battery warnung $DEVICE' low)
DOELSEIF (["^:batteryLevel"] > 2.2) (set Telegram message @xxxxxxx send 'Batteryspannung $DEVICE' unter 2.2V)
DOELSE
in den Readings steht auch
Device HZ_Schlafzimmer  2017-01-23 06:41:40
cmd 3 2017-01-23 06:48:24
cmd_event HZ_Buero 2017-01-23 06:48:24
cmd_nr 3 2017-01-23 06:48:24
matched_event_c2_1 batteryLevel: 2 2017-01-23 06:41:40
state cmd_3 2017-01-23 06:48:24
Warum wird cmd2 nicht ausgeführt?
Gibts nicht besseres um die Batterien zu checken?
weini
...weil du auf >2.2 V und nicht auf <2.2 V abfrägst?
