HMUARTLGW: Modul für HomeMatic UART-Modul (RPi) und HomeMatic LAN Gateway
Begonnen von mgernoth, 11 Juni 2016, 20:10:46
timmyfromspace
Moin moin nochmal,
Hab wieder ein kleines Problem, also Verschlüsselung ist nun aus und Lan Gateway ist in FHEM drinnen.
Wollte dann wie beschrieben den CoProzessor upgraden:
wget https://github.com/eq-3/occu/blob/master/firmware/coprocessor_update_hm_only.eq3
set meinLGW updateCoPro /usr/local/fhem/opt/FHEM/firmware/coprocessor_update_hm_only.eq3
Zitat2016.11.15 13:56:13 1 : nothing to do...
2016.11.15 13:56:19 3 : meinLGW device closed
2016.11.15 13:56:19 3 : Opening meinLGW:keepAlive device 192.168.2.35:2001
2016.11.15 13:56:19 1 : 192.168.2.35:2000 reappeared (meinLGW)
2016.11.15 13:56:19 3 : HMUARTLGW meinLGW BidCoS-port opened
2016.11.15 13:56:19 3 : meinLGW:keepAlive device opened
2016.11.15 13:56:19 3 : HMUARTLGW meinLGW:keepAlive KeepAlive-port opened
2016.11.15 13:56:20 3 : HMUARTLGW meinLGW currently running Co_CPU_BL
2016.11.15 13:56:20 1 : HMUARTLGW meinLGW starting firmware upgrade
2016.11.15 13:56:30 3 : meinLGW device closed
2016.11.15 13:56:30 3 : Opening meinLGW:keepAlive device 192.168.2.35:2001
2016.11.15 13:56:30 1 : 192.168.2.35:2000 reappeared (meinLGW)
2016.11.15 13:56:30 3 : meinLGW:keepAlive device opened
2016.11.15 13:56:30 3 : HMUARTLGW meinLGW BidCoS-port opened
2016.11.15 13:56:30 3 : HMUARTLGW meinLGW:keepAlive KeepAlive-port opened
2016.11.15 13:56:31 3 : HMUARTLGW meinLGW currently running Co_CPU_BL
2016.11.15 13:56:31 1 : HMUARTLGW meinLGW starting firmware upgrade
2016.11.15 13:56:41 3 : meinLGW device closed
2016.11.15 13:56:41 3 : Opening meinLGW:keepAlive device 192.168.2.35:2001
2016.11.15 13:56:41 1 : 192.168.2.35:2000 reappeared (meinLGW)
2016.11.15 13:56:41 3 : HMUARTLGW meinLGW BidCoS-port opened
2016.11.15 13:56:41 3 : meinLGW:keepAlive device opened
2016.11.15 13:56:41 3 : HMUARTLGW meinLGW:keepAlive KeepAlive-port opened
2016.11.15 13:56:42 3 : HMUARTLGW meinLGW currently running Co_CPU_BL
2016.11.15 13:56:42 1 : HMUARTLGW meinLGW starting firmware upgrade
2016.11.15 13:56:53 3 : meinLGW device closed
Im Device steht:
FirmwareFile
D-LANfirmware
1.1.5
2016-11-15 14:04:40
D-firmware
1.2.3
2016-11-15 13:55:12
Lan-Firmware / NetFinder 1.1.5 weiß ich ja, dass das die aktuellste ist.
Laut Wiki wäre/sollte dann 1.4.1 die neueste D-Firmware sein oder?
(aktuell: Applikation: 1.4.1, LAN: 1.1.5)
Dauerschleife ab reappeared bis close. Was könnte das Problem sein?
Klaus.A
Hat der GET wirklich die richtige Firmware-Version erwischt? Ich kenne als Download nur dies:
wget https://raw.githubusercontent.com/eq-3/occu/28045df83480122f90ab92f7c6e625f9bf3b61aa/firmware/coprocessor_update_hm_only.eq3
Wenn der Firmware-Update sofort wieder beendet wird dann könnte es sein das eine identische Version erkannt wurde.
Gruß, Klaus
2 x CubieTruck mit 1) FHEM 5.9 und 2) HomeBridge für Homekit-/Siri-Integration. 3 x HM-LGW-O-TW-W-EU-2, mehr als 90 HomeMatic Sensoren und Aktoren, Velux-Fenster-IF, Fibaro ZWave-Sensoren und Aktoren, Philips Hue Bridge v2 und v3 (im Test), IRTrans IR-Konverter, AutoMower via API
timmyfromspace
#587
Meine ist vom Occu / EQ3 Master auf Github, sollte also die aktuellste sein. EQ3-Tools unter Linux cloned auch den Branch occu von Github.
Hab jetzt auch mal deine bzw. die ältere probiert, ebenso Endlosschleife.
Kann mir jemand sagen, bei dem das Upgrade durchlief, welche Firmware-Attribute bei ihm in FHEM unter meinLGW stehen? Dankö.
Jetzt lief irgendwann nach ner kleinen Schleife durch, hatte aber vorher endlich Perl geupgraded auf 5.22 + viele Module installiert, kA. wodran es lag.
Oder ggf. ist der Master Commit im Github zu neu? Who knows.
D-Firmware = 1.4.1 wie im Wiki beschrieben. Juhu, jetzt ist endlich alles aufm guten Stand und ich kann mit Heizthermostaten beginnen :D
automatisierer
ich habe AES Probleme, mit einer HM-RC-Key4-2, in Verbindung mit dem HMLGW.
Zur Lage: Ich habe 3 IO's, 2 x HMLAN und 1 x HMLGW. Ich habe der Fernbedienung keinen preff IO zugewiesen. Wenn die Fernbedienung eine der HMLAN als IO hat funktioniert AES, LED leuchtet grün, wenn der HMLGW IO ist dann leuchtet die LED rot.
Ich habe mal mit geloggt, hier das LOG wenn HMLGW der IO ist:
2016.11.23 09:04:11.372 0: HMLAN_Parse: HMLANingo2 R:E355867   stat:0000 t:0AB9AE03 d:FF r:FFAE     m:6A 8002 355867 24C003 00
2016.11.23 09:04:11.264 0: HMLAN_Parse: HMLANingo2 R:E24C003   stat:0000 t:0AB9AD87 d:FF r:FFBB     m:6A A240 24C003 355867 0143
2016.11.23 09:04:11.257 0: HMLAN_Parse: HMLANingo2 R:E355867   stat:0000 t:0AB9AD08 d:FF r:FFAF     m:69 8002 355867 24C003 00
2016.11.23 09:04:11.148 0: HMLAN_Parse: HMLANingo2 R:E24C003   stat:0000 t:0AB9AC8C d:FF r:FFBC     m:69 A240 24C003 355867 0143
2016.11.23 09:04:11.141 0: HMLAN_Parse: HMLANingo2 R:E355867   stat:0000 t:0AB9AC0D d:FF r:FFAE     m:68 8002 355867 24C003 00
2016.11.23 09:04:11.032 0: HMLAN_Parse: HMLANingo2 R:E24C003   stat:0000 t:0AB9AB92 d:FF r:FFBA     m:68 A640 24C003 355867 0143
2016.11.23 09:04:11.024 0: HMLAN_Parse: HMLANingo1 R:E355867   stat:0000 t:0025A36B d:FF r:FFBD     m:6A 8002 355867 24C003 00
2016.11.23 09:04:10.916 0: HMLAN_Parse: HMLANingo1 R:E24C003   stat:0000 t:0025A2EE d:FF r:FFB5     m:6A A240 24C003 355867 0143
2016.11.23 09:04:10.908 0: HMLAN_Parse: HMLANingo1 R:E355867   stat:0000 t:0025A270 d:FF r:FFBD     m:69 8002 355867 24C003 00
2016.11.23 09:04:10.799 0: HMLAN_Parse: HMLANingo1 R:E24C003   stat:0000 t:0025A1F4 d:FF r:FFB5     m:69 A240 24C003 355867 0143
2016.11.23 09:04:10.790 0: HMLAN_Parse: HMLANingo1 R:E355867   stat:0000 t:0025A175 d:FF r:FFBD     m:68 8002 355867 24C003 00
2016.11.23 09:04:10.680 0: HMLAN_Parse: HMLANingo1 R:E24C003   stat:0000 t:0025A0FA d:FF r:FFB5     m:68 A640 24C003 355867 0143
2016.11.23 09:04:10.568 0: HMUARTLGW HMLGW_1 recv: 01 05 01 02 4E msg: 6A A2 40 24C003 355867 0143
2016.11.23 09:04:10.458 0: HMUARTLGW HMLGW_1 recv: 01 05 01 02 4E msg: 69 A2 40 24C003 355867 0143
2016.11.23 09:04:09.896 0: HMUARTLGW HMLGW_1 recv: 01 05 01 02 4E msg: 68 A6 40 24C003 355867 0143
Und hier wenn ein HMLAN IO ist.
2016.11.23 09:02:30.590 0: HMLAN_Parse: HMLANingo2 R:R90351F61 stat:0002 t:00000000 d:FF r:7FFF     m:63 8002 355867 24C003 00
2016.11.23 09:02:30.584 0: HMLAN_Parse: HMLANingo2 R:E355867   stat:0000 t:0AB825BF d:FF r:FFAE     m:63 8002 355867 24C003 00
2016.11.23 09:02:30.578 0: HMLAN_Parse: HMLANingo1 R:E355867   stat:0000 t:00241B94 d:FF r:FFBE     m:63 8002 355867 24C003 00
2016.11.23 09:02:30.573 0: HMLAN_Parse: HMLANingo1 R:E355867   stat:0000 t:00241B27 d:FF r:FFBD     m:63 8002 355867 24C003 00
2016.11.23 09:02:30.565 0: HMUARTLGW HMLGW_1 recv: 01 05 00 02 4F msg: 63 80 02 355867 24C003 00
2016.11.23 09:02:30.554 0: HMLAN_Parse: HMLANingo2 R:E355867   stat:0000 t:0AB82534 d:FF r:FFB8     m:63 8002 355867 24C003 00
2016.11.23 09:02:30.127 0: HMLAN_Send:  HMLANingo2 S:S90351F61 stat:  00 t:00000000 d:01 r:90351F61 m:63 8002 355867 24C003 00
2016.11.23 09:02:30.126 0: HMLAN_Send:  HMLANingo2 S:+24C003,01,02,1E
2016.11.23 09:02:30.017 0: HMLAN_Parse: HMLANingo2 R:E24C003   stat:0040 t:0AB823A3 d:02 r:FFBF     m:63 A640 24C003 355867 0140
2016.11.23 09:02:30.014 0: HMLAN_Parse: HMLANingo1 R:R90351EA8 stat:0002 t:00000000 d:FF r:7FFF     m:63 8002 355867 24C003 00
2016.11.23 09:02:30.007 0: HMUARTLGW HMLGW_1 recv: 01 05 00 02 43 msg: 63 80 02 355867 24C003 00
2016.11.23 09:02:30.000 0: HMUARTLGW HMLGW_1 send: 01 02 00 00 00 msg: 63 80 02 355867 24C003 00
2016.11.23 09:02:29.942 0: HMLAN_Send:  HMLANingo1 S:S90351EA8 stat:  00 t:00000000 d:01 r:90351EA8 m:63 8002 355867 24C003 00
2016.11.23 09:02:29.941 0: HMLAN_Send:  HMLANingo1 S:+24C003,01,02,1E
2016.11.23 09:02:29.835 0: HMUARTLGW HMLGW_1 recv: 01 05 01 02 4D msg: 63 A0 03 24C003 355867 2FEC12EEE554C4CA0271F916E1431351
2016.11.23 09:02:29.769 0: HMLAN_Parse: HMLANingo2 R:E24C003   stat:0100 t:0AB823A3 d:FF r:FFBF     m:63 A640 24C003 355867 0140
2016.11.23 09:02:29.763 0: HMLAN_Parse: HMLANingo1 R:E355867   stat:0000 t:0024198D d:FF r:FFBE     m:63 A002 355867 24C003 0447D17739586504
2016.11.23 09:02:29.756 0: HMLAN_Parse: HMLANingo1 R:E24C003   stat:0000 t:0024190C d:FF r:FFB8     m:63 A640 24C003 355867 0140
2016.11.23 09:02:29.748 0: HMUARTLGW HMLGW_1 recv: 01 05 00 02 4F msg: 63 A0 02 355867 24C003 0447D17739586504
2016.11.23 09:02:29.573 0: HMUARTLGW HMLGW_1 recv: 01 05 00 02 4D msg: 63 A6 40 24C003 355867 0140
Sind noch weitere Informationen nötig?
Ingo
Hallo Ingo,
nur der Vollständigkeit halber gefragt:  das Perl-Modul Crypt::Rijndael (Debian: libcrypt-rijndael-perl) hast Du installiert?
mgernoth
Ja, bitte logge mit, was passiert, wenn Du das preferred IO auf das HMLGW legst. Da muss das Gerät dem HMLGW bekannt gemacht werden, ansonsten antwortet das GW nicht. Bitte vorher auf die aktuelle Version updaten (12606), damit die relevanten Log-Nachrichten auch mit dem richtigen Log-Level generiert werden.
Also:
  • Log starten
  • Preferred IO ändern
  • Taste drücken
Und bitte ein List der Fernbedienung und des GW (ohne AES-Keys) einfügen.
Äh, dumme Frage: Wozu?
Die Kommunikation mit dem GW steht, das wäre das einzige, wofür evtl. Crypt::Rijndael gebraucht wird (Hm-SEC-SD2 mal aussen vor). Die HM-IOs sind (gottseidank) keine CULs!
  Michael
  Michael
Hallo Michael,
ich dachte ich habe gelernt, das für AES mit HMUART Crypt::Rijndael  gebraucht wird. Stimmt das nicht?
mgernoth
Hallo Otto,
Nein, nur für CULs. Alle anderen IOs können das selbst (bis auf AES-CBC bei HM-SEC-SD2).
  Michael
mgernoth
Zitat von: Otto123 am 23 November 2016, 09:57:06
also auch das RPI Modul?
Ja, nur die CULs brauchen Crypt::Rijndael.
  Michael
Hallo Michael,
Sorry, dann habe ich das falsch aufgefasst/verstanden. Da habe an ein paar Stellen im Wiki glaube ich was falsches/"zu viel" rein geschrieben. Das muss ich korrigieren  :-[
Aber schaden tut es ja nicht  ;)
automatisierer
So...
1. Update gemacht...
2. HMLGW auf verbose 5
3. preffered IO der Fernbedienung auf HMLGW gesetzt
4. Taste an der Fernbedienung gedrückt. (nach dem setzen des preff IO, muss ich erst einmal drücken, damit der HMLGW als IO in den Internals steht.
5. Ich habe dem HMLGW keinen AES Key zugewiesen, nur in der vccu zu der er gehört - richtig/falsch?
Hier das log.
2016.11.23 09:59:57.430 5: SW: Kbd
2016.11.23 09:59:57.429 5: HMUARTLGW HMLGW_1:keepAlive send (3): Kbd
2016.11.23 09:59:56.883 5: HMUARTLGW HMLGW_1 roundtrip delay: 0.0061
2016.11.23 09:59:56.882 5: HMUARTLGW HMLGW_1 GetSet Ack: 02, state 98
2016.11.23 09:59:56.880 5: HMUARTLGW HMLGW_1 recv: 00 040208, state 98
2016.11.23 09:59:56.880 5: HMUARTLGW HMLGW_1 read (9): fd000500f6040208f44e crc OK
2016.11.23 09:59:56.878 5: HMUARTLGW HMLGW_1 read raw (10): fd000500f6040208f44e
2016.11.23 09:59:56.872 5: SW: fd000300f6082c3c
2016.11.23 09:59:56.871 5: HMUARTLGW HMLGW_1 send: (8): fd000300f6082c3c
2016.11.23 09:59:56.870 5: HMUARTLGW HMLGW_1 send: 00 08
2016.11.23 09:59:56.868 5: HMUARTLGW HMLGW_1 checking credits (from timer)
2016.11.23 09:59:52.300 5: HMLGW_1 dispatch A0E6B84102D335F0000000BA0C90E00::-54:HMLGW_1
2016.11.23 09:59:52.300 5: HMUARTLGW HMLGW_1 Dispatch: A0E6B84102D335F0000000BA0C90E00::-54:HMLGW_1
2016.11.23 09:59:52.299 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 36 msg: 6B 84 10 2D335F 000000 0BA0C90E00
2016.11.23 09:59:52.299 5: HMUARTLGW HMLGW_1 read (24): fd001401d3050000366b84102d335f0000000ba0c90e00b952 crc OK
2016.11.23 09:59:52.297 5: HMUARTLGW HMLGW_1 read raw (25): fd001401d3050000366b84102d335f0000000ba0c90e00b952
2016.11.23 09:59:50.853 5: HMUARTLGW HMLGW_1: Skip ACK
2016.11.23 09:59:50.845 5: HMLGW_1 dispatch A0D82A6104C102035586706010000::-72:HMLGW_1
2016.11.23 09:59:50.844 5: HMUARTLGW HMLGW_1 Dispatch: A0D82A6104C102035586706010000::-72:HMLGW_1
2016.11.23 09:59:50.844 5: HMUARTLGW HMLGW_1 recv: 01 05 01 00 48 msg: 82 A6 10 4C1020 355867 06010000
2016.11.23 09:59:50.843 5: HMUARTLGW HMLGW_1 read (23): fd001301d20501004882a6104c102035586706010000d25a crc OK
2016.11.23 09:59:50.841 5: HMUARTLGW HMLGW_1 read raw (24): fd001301d20501004882a6104c102035586706010000d25a
2016.11.23 09:59:47.422 5: HMUARTLGW HMLGW_1:keepAlive read (4): >Kbc
2016.11.23 09:59:47.421 5: HMUARTLGW HMLGW_1:keepAlive read raw (6): 3e4b62630d0a
2016.11.23 09:59:47.417 5: SW: Kbc
2016.11.23 09:59:47.416 5: HMUARTLGW HMLGW_1:keepAlive send (3): Kbc
2016.11.23 09:59:46.599 5: HMLGW_1 dispatch A0C28865A458AAA00000090B543::-65:HMLGW_1
2016.11.23 09:59:46.598 5: HMUARTLGW HMLGW_1 Dispatch: A0C28865A458AAA00000090B543::-65:HMLGW_1
2016.11.23 09:59:46.598 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 41 msg: 28 86 5A 458AAA 000000 90B543
2016.11.23 09:59:46.597 5: HMUARTLGW HMLGW_1 read (22): fd001201d10500004128865a458aaa00000090b5431182 crc OK
2016.11.23 09:59:46.595 5: HMUARTLGW HMLGW_1 read raw (23): fd001201d10500004128865a458aaa00000090b5431182
2016.11.23 09:59:44.206 5: HMLGW_1 dispatch A0C458470458AB600000000C43C::-66:HMLGW_1
2016.11.23 09:59:44.205 5: HMUARTLGW HMLGW_1 Dispatch: A0C458470458AB600000000C43C::-66:HMLGW_1
2016.11.23 09:59:44.205 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 42 msg: 45 84 70 458AB6 000000 00C43C
2016.11.23 09:59:44.204 5: HMUARTLGW HMLGW_1 read (22): fd001201d005000042458470458ab600000000c43c1c54 crc OK
2016.11.23 09:59:44.202 5: HMUARTLGW HMLGW_1 read raw (23): fd001201d005000042458470458ab600000000c43c1c54
2016.11.23 09:59:42.306 5: HMLGW_1 dispatch A0CDF865A2D335F000000A0C946::-54:HMLGW_1
2016.11.23 09:59:42.305 5: HMUARTLGW HMLGW_1 Dispatch: A0CDF865A2D335F000000A0C946::-54:HMLGW_1
2016.11.23 09:59:42.303 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 36 msg: DF 86 5A 2D335F 000000 A0C946
2016.11.23 09:59:42.300 5: HMUARTLGW HMLGW_1 read (22): fd001201cf05000036df865a2d335f000000a0c946ae9b crc OK
2016.11.23 09:59:42.296 5: HMUARTLGW HMLGW_1 read raw (23): fd001201cf05000036df865a2d335f000000a0c946ae9b
2016.11.23 09:59:41.871 5: HMUARTLGW HMLGW_1 roundtrip delay: 0.0060
2016.11.23 09:59:41.871 5: HMUARTLGW HMLGW_1 GetSet Ack: 02, state 98
2016.11.23 09:59:41.869 5: HMUARTLGW HMLGW_1 recv: 00 040208, state 98
2016.11.23 09:59:41.868 5: HMUARTLGW HMLGW_1 read (9): fd000500f5040208c84e crc OK
2016.11.23 09:59:41.867 5: HMUARTLGW HMLGW_1 read raw (10): fd000500f5040208c84e
2016.11.23 09:59:41.861 5: SW: fd000300f508263c
2016.11.23 09:59:41.860 5: HMUARTLGW HMLGW_1 send: (8): fd000300f508263c
2016.11.23 09:59:41.860 5: HMUARTLGW HMLGW_1 send: 00 08
2016.11.23 09:59:41.858 5: HMUARTLGW HMLGW_1 checking credits (from timer)
2016.11.23 09:59:37.409 5: HMUARTLGW HMLGW_1:keepAlive read (4): >Kbb
2016.11.23 09:59:37.408 5: HMUARTLGW HMLGW_1:keepAlive read raw (6): 3e4b62620d0a
2016.11.23 09:59:37.404 5: SW: Kbb
2016.11.23 09:59:37.403 5: HMUARTLGW HMLGW_1:keepAlive send (3): Kbb
2016.11.23 09:59:28.501 5: HMLGW_1 dispatch A0FC2861028B79E0000000AA0CA0F0000::-89:HMLGW_1
2016.11.23 09:59:28.501 5: HMUARTLGW HMLGW_1 Dispatch: A0FC2861028B79E0000000AA0CA0F0000::-89:HMLGW_1
2016.11.23 09:59:28.500 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 59 msg: C2 86 10 28B79E 000000 0AA0CA0F0000
2016.11.23 09:59:28.495 5: HMUARTLGW HMLGW_1 read (25): fd001501ce05000059c2861028b79e0000000aa0ca0f00004999 crc OK
2016.11.23 09:59:28.493 5: HMUARTLGW HMLGW_1 read raw (26): fd001501ce05000059c2861028b79e0000000aa0ca0f00004999
2016.11.23 09:59:27.395 5: HMUARTLGW HMLGW_1:keepAlive read (4): >Kba
2016.11.23 09:59:27.395 5: HMUARTLGW HMLGW_1:keepAlive read raw (6): 3e4b62610d0a
2016.11.23 09:59:27.390 5: SW: Kba
2016.11.23 09:59:27.390 5: HMUARTLGW HMLGW_1:keepAlive send (3): Kba
2016.11.23 09:59:26.856 5: HMUARTLGW HMLGW_1 roundtrip delay: 0.0052
2016.11.23 09:59:26.855 5: HMUARTLGW HMLGW_1 GetSet Ack: 02, state 98
2016.11.23 09:59:26.854 5: HMUARTLGW HMLGW_1 recv: 00 040208, state 98
2016.11.23 09:59:26.853 5: HMUARTLGW HMLGW_1 read (9): fd000500f40402085c4d crc OK
2016.11.23 09:59:26.852 5: HMUARTLGW HMLGW_1 read raw (10): fd000500f40402085c4d
2016.11.23 09:59:26.847 5: SW: fd000300f408a03f
2016.11.23 09:59:26.846 5: HMUARTLGW HMLGW_1 send: (8): fd000300f408a03f
2016.11.23 09:59:26.845 5: HMUARTLGW HMLGW_1 send: 00 08
2016.11.23 09:59:26.843 5: HMUARTLGW HMLGW_1 checking credits (from timer)
2016.11.23 09:59:24.205 5: HMLGW_1 dispatch A0C45865A458AB600000098C43C::-66:HMLGW_1
2016.11.23 09:59:24.205 5: HMUARTLGW HMLGW_1 Dispatch: A0C45865A458AB600000098C43C::-66:HMLGW_1
2016.11.23 09:59:24.204 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 42 msg: 45 86 5A 458AB6 000000 98C43C
2016.11.23 09:59:24.203 5: HMUARTLGW HMLGW_1 read (22): fd001201cd0500004245865a458ab600000098c43c30b9 crc OK
2016.11.23 09:59:24.202 5: HMUARTLGW HMLGW_1 read raw (23): fd001201cd0500004245865a458ab600000098c43c30b9
2016.11.23 09:59:23.241 5: HMLGW_1 dispatch A14AD845E2A825400000088CAF300000500000917FD::-76:HMLGW_1
2016.11.23 09:59:23.241 5: HMUARTLGW HMLGW_1 Dispatch: A14AD845E2A825400000088CAF300000500000917FD::-76:HMLGW_1
2016.11.23 09:59:23.240 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 4C msg: AD 84 5E 2A8254 000000 88CAF300000500000917FD
2016.11.23 09:59:23.239 5: HMUARTLGW HMLGW_1 read (30): fd001a01cc0500004cad845e2a825400000088caf300000500000917fdb184 crc OK
2016.11.23 09:59:23.238 5: HMUARTLGW HMLGW_1 read raw (32): fd001a01cc0500004cad845e2a825400000088caf300000500000917fc7db184
2016.11.23 09:59:19.758 5: HMLGW_1 dispatch A0F3C861028B9730000000AA0CC0D0000::-69:HMLGW_1
2016.11.23 09:59:19.757 5: HMUARTLGW HMLGW_1 Dispatch: A0F3C861028B9730000000AA0CC0D0000::-69:HMLGW_1
2016.11.23 09:59:19.756 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 45 msg: 3C 86 10 28B973 000000 0AA0CC0D0000
2016.11.23 09:59:19.754 5: HMUARTLGW HMLGW_1 read (25): fd001501cb050000453c861028b9730000000aa0cc0d0000a450 crc OK
2016.11.23 09:59:19.751 5: HMUARTLGW HMLGW_1 read raw (26): fd001501cb050000453c861028b9730000000aa0cc0d0000a450
2016.11.23 09:59:18.768 5: HMLGW_1 dispatch A140F845E2AB5EF00000082F5E400000000000915FE::-62:HMLGW_1
2016.11.23 09:59:18.767 5: HMUARTLGW HMLGW_1 Dispatch: A140F845E2AB5EF00000082F5E400000000000915FE::-62:HMLGW_1
2016.11.23 09:59:18.766 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 3E msg: 0F 84 5E 2AB5EF 000000 82F5E400000000000915FE
2016.11.23 09:59:18.765 5: HMUARTLGW HMLGW_1 read (30): fd001a01ca0500003e0f845e2ab5ef00000082f5e400000000000915fe80cf crc OK
2016.11.23 09:59:18.763 5: HMUARTLGW HMLGW_1 read raw (31): fd001a01ca0500003e0f845e2ab5ef00000082f5e400000000000915fe80cf
2016.11.23 09:59:17.383 5: HMUARTLGW HMLGW_1:keepAlive read (4): >Kb9
2016.11.23 09:59:17.382 5: HMUARTLGW HMLGW_1:keepAlive read raw (6): 3e4b62390d0a
2016.11.23 09:59:17.378 5: SW: Kb9
2016.11.23 09:59:17.377 5: HMUARTLGW HMLGW_1:keepAlive send (3): Kb9
2016.11.23 09:59:16.138 5: HMLGW_1 dispatch A0F15865E3DFBC600000016427200CBE8::-74:HMLGW_1
2016.11.23 09:59:16.138 5: HMUARTLGW HMLGW_1 Dispatch: A0F15865E3DFBC600000016427200CBE8::-74:HMLGW_1
2016.11.23 09:59:16.137 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 4A msg: 15 86 5E 3DFBC6 000000 16427200CBE8
2016.11.23 09:59:16.136 5: HMUARTLGW HMLGW_1 read (25): fd001501c90500004a15865e3dfbc600000016427200cbe83a81 crc OK
2016.11.23 09:59:16.135 5: HMUARTLGW HMLGW_1 read raw (26): fd001501c90500004a15865e3dfbc600000016427200cbe83a81
2016.11.23 09:59:14.233 5: HMLGW_1 dispatch A0C178470458A9200000000C43C::-54:HMLGW_1
2016.11.23 09:59:14.233 5: HMUARTLGW HMLGW_1 Dispatch: A0C178470458A9200000000C43C::-54:HMLGW_1
2016.11.23 09:59:14.232 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 36 msg: 17 84 70 458A92 000000 00C43C
2016.11.23 09:59:14.232 5: HMUARTLGW HMLGW_1 read (22): fd001201c805000036178470458a9200000000c43c6567 crc OK
2016.11.23 09:59:14.230 5: HMUARTLGW HMLGW_1 read raw (23): fd001201c805000036178470458a9200000000c43c6567
2016.11.23 09:59:14.156 5: HMLGW_1 dispatch A0F388610354B740000000A98C40A0000::-66:HMLGW_1
2016.11.23 09:59:14.156 5: HMUARTLGW HMLGW_1 Dispatch: A0F388610354B740000000A98C40A0000::-66:HMLGW_1
2016.11.23 09:59:14.155 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 42 msg: 38 86 10 354B74 000000 0A98C40A0000
2016.11.23 09:59:14.154 5: HMUARTLGW HMLGW_1 read (25): fd001501c705000042388610354b740000000a98c40a0000f81f crc OK
2016.11.23 09:59:14.152 5: HMUARTLGW HMLGW_1 read raw (26): fd001501c705000042388610354b740000000a98c40a0000f81f
2016.11.23 09:59:13.565 5: HMLGW_1 dispatch A0CE884702D33F900000000C03C::-67:HMLGW_1
2016.11.23 09:59:13.565 5: HMUARTLGW HMLGW_1 Dispatch: A0CE884702D33F900000000C03C::-67:HMLGW_1
2016.11.23 09:59:13.564 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 43 msg: E8 84 70 2D33F9 000000 00C03C
2016.11.23 09:59:13.563 5: HMUARTLGW HMLGW_1 read (22): fd001201c605000043e884702d33f900000000c03c43f9 crc OK
2016.11.23 09:59:13.562 5: HMUARTLGW HMLGW_1 read raw (23): fd001201c605000043e884702d33f900000000c03c43f9
2016.11.23 09:59:12.114 0: HMLAN_Parse: HMLANingo2 R:E355867   stat:0000 t:0AEC10D0 d:FF r:FFAD     m:8B 8002 355867 24C003 00
2016.11.23 09:59:12.107 0: HMLAN_Parse: HMLANingo1 R:E355867   stat:0000 t:0058061C d:FF r:FFBD     m:8B 8002 355867 24C003 00
2016.11.23 09:59:12.091 0: HMLAN_Parse: HMLANingo2 R:E24C003   stat:0000 t:0AEC1054 d:FF r:FFC1     m:8B A240 24C003 355867 0153
2016.11.23 09:59:12.083 0: HMLAN_Parse: HMLANingo1 R:E24C003   stat:0000 t:005805A0 d:FF r:FFB5     m:8B A240 24C003 355867 0153
2016.11.23 09:59:11.975 5: HMUARTLGW HMLGW_1: Skip ACK
2016.11.23 09:59:11.969 5: HMLGW_1 dispatch A0B8BA24024C0033558670153::-75:HMLGW_1
2016.11.23 09:59:11.968 5: HMUARTLGW HMLGW_1 Dispatch: A0B8BA24024C0033558670153::-75:HMLGW_1
2016.11.23 09:59:11.968 0: HMUARTLGW HMLGW_1 recv: 01 05 01 00 4B msg: 8B A2 40 24C003 355867 0153
2016.11.23 09:59:11.967 5: HMUARTLGW HMLGW_1 read (21): fd001101c50501004b8ba24024c0033558670153bb79 crc OK
2016.11.23 09:59:11.965 5: HMUARTLGW HMLGW_1 read raw (22): fd001101c50501004b8ba24024c0033558670153bb79
2016.11.23 09:59:11.865 0: HMLAN_Parse: HMLANingo2 R:E355867   stat:0000 t:0AEC0FD6 d:FF r:FFAD     m:8A 8002 355867 24C003 00
2016.11.23 09:59:11.857 0: HMLAN_Parse: HMLANingo1 R:E355867   stat:0000 t:00580522 d:FF r:FFBD     m:8A 8002 355867 24C003 00
2016.11.23 09:59:11.855 5: HMUARTLGW HMLGW_1 roundtrip delay: 0.0198
2016.11.23 09:59:11.854 5: HMUARTLGW HMLGW_1 GetSet Ack: 02, state 98
2016.11.23 09:59:11.853 5: HMUARTLGW HMLGW_1 recv: 00 040208, state 98
2016.11.23 09:59:11.852 5: HMUARTLGW HMLGW_1 read (9): fd000500f3040208b04e crc OK
2016.11.23 09:59:11.851 5: HMUARTLGW HMLGW_1 read raw (10): fd000500f3040208b04e
2016.11.23 09:59:11.845 0: HMLAN_Parse: HMLANingo2 R:E24C003   stat:0000 t:0AEC0F5A d:FF r:FFC1     m:8A A240 24C003 355867 0153
2016.11.23 09:59:11.838 0: HMLAN_Parse: HMLANingo1 R:E24C003   stat:0000 t:005804A6 d:FF r:FFB5     m:8A A240 24C003 355867 0153
2016.11.23 09:59:11.831 5: SW: fd000300f308323c
2016.11.23 09:59:11.831 5: HMUARTLGW HMLGW_1 send: (8): fd000300f308323c
2016.11.23 09:59:11.830 5: HMUARTLGW HMLGW_1 send: 00 08
2016.11.23 09:59:11.828 5: HMUARTLGW HMLGW_1 checking credits (from timer)
2016.11.23 09:59:11.724 5: HMUARTLGW HMLGW_1: Skip ACK
2016.11.23 09:59:11.718 5: HMLGW_1 dispatch A0B8AA24024C0033558670153::-75:HMLGW_1
2016.11.23 09:59:11.718 5: HMUARTLGW HMLGW_1 Dispatch: A0B8AA24024C0033558670153::-75:HMLGW_1
2016.11.23 09:59:11.717 0: HMUARTLGW HMLGW_1 recv: 01 05 01 00 4B msg: 8A A2 40 24C003 355867 0153
2016.11.23 09:59:11.716 5: HMUARTLGW HMLGW_1 read (21): fd001101c40501004b8aa24024c0033558670153a83f crc OK
2016.11.23 09:59:11.715 5: HMUARTLGW HMLGW_1 read raw (22): fd001101c40501004b8aa24024c0033558670153a83f
2016.11.23 09:59:11.636 0: HMLAN_Parse: HMLANingo2 R:E355867   stat:0000 t:0AEC0EDB d:FF r:FFAE     m:89 8002 355867 24C003 00
2016.11.23 09:59:11.630 0: HMLAN_Parse: HMLANingo2 R:E24C003   stat:0000 t:0AEC0E5F d:FF r:FFC1     m:89 A640 24C003 355867 0153
2016.11.23 09:59:11.622 0: HMLAN_Parse: HMLANingo1 R:E355867   stat:0000 t:00580427 d:FF r:FFBD     m:89 8002 355867 24C003 00
2016.11.23 09:59:11.617 0: HMLAN_Parse: HMLANingo1 R:E24C003   stat:0000 t:005803AA d:FF r:FFB4     m:89 A640 24C003 355867 0153
2016.11.23 09:59:11.474 5: HMUARTLGW HMLGW_1: Skip ACK
2016.11.23 09:59:11.468 5: HMLGW_1 dispatch A0B89A64024C0033558670153::-75:HMLGW_1
2016.11.23 09:59:11.468 5: HMUARTLGW HMLGW_1 Dispatch: A0B89A64024C0033558670153::-75:HMLGW_1
2016.11.23 09:59:11.467 0: HMUARTLGW HMLGW_1 recv: 01 05 01 00 4B msg: 89 A6 40 24C003 355867 0153
2016.11.23 09:59:11.466 5: HMUARTLGW HMLGW_1 read (21): fd001101c30501004b89a64024c003355867015385b8 crc OK
2016.11.23 09:59:11.465 5: HMUARTLGW HMLGW_1 read raw (22): fd001101c30501004b89a64024c003355867015385b8
2016.11.23 09:59:09.368 5: HMLGW_1 dispatch A13078670338A55000000002A620AB30000085824::-58:HMLGW_1
2016.11.23 09:59:09.367 5: HMUARTLGW HMLGW_1 Dispatch: A13078670338A55000000002A620AB30000085824::-58:HMLGW_1
2016.11.23 09:59:09.367 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 3A msg: 07 86 70 338A55 000000 002A620AB30000085824
2016.11.23 09:59:09.366 5: HMUARTLGW HMLGW_1 read (29): fd001901c20500003a078670338a55000000002a620ab300000858246c4b crc OK
2016.11.23 09:59:09.364 5: HMUARTLGW HMLGW_1 read raw (30): fd001901c20500003a078670338a55000000002a620ab300000858246c4b
2016.11.23 09:59:07.370 5: HMUARTLGW HMLGW_1:keepAlive read (4): >Kb8
2016.11.23 09:59:07.369 5: HMUARTLGW HMLGW_1:keepAlive read raw (6): 3e4b62380d0a
2016.11.23 09:59:07.365 5: SW: Kb8
2016.11.23 09:59:07.364 5: HMUARTLGW HMLGW_1:keepAlive send (3): Kb8
2016.11.23 09:59:05.033 5: HMLGW_1 dispatch A1204800223DD3D355867010101002C54E9859A::-67:HMLGW_1
2016.11.23 09:59:05.033 5: HMUARTLGW HMLGW_1 Dispatch: A1204800223DD3D355867010101002C54E9859A::-67:HMLGW_1
2016.11.23 09:59:05.032 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 43 msg: 04 80 02 23DD3D 355867 010101002C54E9859A
2016.11.23 09:59:05.031 5: HMUARTLGW HMLGW_1 read (28): fd001801c10500004304800223dd3d355867010101002c54e9859a1322 crc OK
2016.11.23 09:59:05.030 5: HMUARTLGW HMLGW_1 read raw (29): fd001801c10500004304800223dd3d355867010101002c54e9859a1322
2016.11.23 09:59:04.913 5: HMLGW_1 dispatch A1904A00335586723DD3D4B5644A532FCAFF5FF5E487A4B5A6054::-80:HMLGW_1
2016.11.23 09:59:04.913 5: HMUARTLGW HMLGW_1 Dispatch: A1904A00335586723DD3D4B5644A532FCAFF5FF5E487A4B5A6054::-80:HMLGW_1
2016.11.23 09:59:04.913 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 50 msg: 04 A0 03 355867 23DD3D 4B5644A532FCAFF5FF5E487A4B5A6054
2016.11.23 09:59:04.912 5: HMUARTLGW HMLGW_1 read (35): fd001f01c00500005004a00335586723dd3d4b5644a532fcaff5ff5e487a4b5a6054c629 crc OK
2016.11.23 09:59:04.910 5: HMUARTLGW HMLGW_1 read raw (37): fd001f01c00500005004a00335586723dd3d4b5644a532fc7caff5ff5e487a4b5a6054c629
2016.11.23 09:59:04.776 5: HMLGW_1 dispatch A1104A00223DD3D35586704181C12DC88FB04::-67:HMLGW_1
2016.11.23 09:59:04.776 5: HMUARTLGW HMLGW_1 Dispatch: A1104A00223DD3D35586704181C12DC88FB04::-67:HMLGW_1
2016.11.23 09:59:04.775 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 43 msg: 04 A0 02 23DD3D 355867 04181C12DC88FB04
2016.11.23 09:59:04.774 5: HMUARTLGW HMLGW_1 read (27): fd001701bf0500004304a00223dd3d35586704181c12dc88fb047bb8 crc OK
2016.11.23 09:59:04.773 5: HMUARTLGW HMLGW_1 read raw (28): fd001701bf0500004304a00223dd3d35586704181c12dc88fb047bb8
2016.11.23 09:59:04.646 5: HMLGW_1 dispatch A0D04B01135586723DD3D800101FF::-79:HMLGW_1
2016.11.23 09:59:04.645 5: HMUARTLGW HMLGW_1 Dispatch: A0D04B01135586723DD3D800101FF::-79:HMLGW_1
2016.11.23 09:59:04.645 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 4F msg: 04 B0 11 355867 23DD3D 800101FF
2016.11.23 09:59:04.644 5: HMUARTLGW HMLGW_1 read (23): fd001301be0500004f04b01135586723dd3d800101ffa3f9 crc OK
2016.11.23 09:59:04.642 5: HMUARTLGW HMLGW_1 read raw (24): fd001301be0500004f04b01135586723dd3d800101ffa3f9
2016.11.23 09:59:04.558 5: SW: fd001001f20200000088800235586724c00300b22b
2016.11.23 09:59:04.557 5: HMUARTLGW HMLGW_1 send: (21): fd001001f20200000088800235586724c00300b22b
2016.11.23 09:59:04.556 0: HMUARTLGW HMLGW_1 send: 01 02 00 00 00 msg: 88 80 02 355867 24C003 00
2016.11.23 09:59:04.555 5: HMUARTLGW HMLGW_1 !BIDI
2016.11.23 09:59:04.554 0: HMUARTLGW HMLGW_1 added peer: 24C003, aesChannels: FFFFFFFFFFFFFFFF
2016.11.23 09:59:04.553 5: HMUARTLGW HMLGW_1 GetSet Ack: 07, state 93
2016.11.23 09:59:04.551 5: HMUARTLGW HMLGW_1 recv: 01 04070101000DFFFFFFFFFFFFFFFF, state 93
2016.11.23 09:59:04.551 5: HMUARTLGW HMLGW_1 read (20): fd001001f104070101000dffffffffffffffff1b39 crc OK
2016.11.23 09:59:04.550 5: HMUARTLGW HMLGW_1 read raw (21): fd001001f104070101000dffffffffffffffff1b39
2016.11.23 09:59:04.543 5: SW: fd000901f10624c003000000ecb9
2016.11.23 09:59:04.542 5: HMUARTLGW HMLGW_1 send: (14): fd000901f10624c003000000ecb9
2016.11.23 09:59:04.535 0: HMUARTLGW HMLGW_1 send: 01 0624C003000000
2016.11.23 09:59:04.534 4: HMUARTLGW HMLGW_1 UpdatePeerReq: 24C003, state 93
2016.11.23 09:59:04.074 5: HMUARTLGW HMLGW_1: Skip ACK
2016.11.23 09:59:04.067 0: HMLAN_Parse: HMLANingo2 R:E24C003   stat:0040 t:0AEBEFFB d:02 r:FFC0     m:88 A640 24C003 355867 0152
2016.11.23 09:59:04.029 5: HMUARTLGW HMLGW_1 GetSet Ack: 08, state 93
2016.11.23 09:59:04.027 5: HMUARTLGW HMLGW_1 recv: 01 0408, state 93
2016.11.23 09:59:04.027 5: HMUARTLGW HMLGW_1 read (8): fd000401f0040801c8 crc OK
2016.11.23 09:59:03.978 5: HMUARTLGW HMLGW_1: Skip ACK
2016.11.23 09:59:03.974 5: HMLGW_1 dispatch A1988A00324C0033558675C08E05EFEF3C8A13168EF910A5054E5::-75:HMLGW_1
2016.11.23 09:59:03.973 5: HMUARTLGW HMLGW_1 Dispatch: A1988A00324C0033558675C08E05EFEF3C8A13168EF910A5054E5::-75:HMLGW_1
2016.11.23 09:59:03.973 0: HMUARTLGW HMLGW_1 recv: 01 05 01 00 4B msg: 88 A0 03 24C003 355867 5C08E05EFEF3C8A13168EF910A5054E5
2016.11.23 09:59:03.972 5: HMUARTLGW HMLGW_1 read (35): fd001f01bd0501004b88a00324c0033558675c08e05efef3c8a13168ef910a5054e5d3eb crc OK
2016.11.23 09:59:03.970 5: HMUARTLGW HMLGW_1 read raw (45): fd001f01bd0501004b88a00324c0033558675c08e05efef3c8a13168ef910a5054e5d3ebfd000401f0040801c8
2016.11.23 09:59:03.947 5: HMLGW_1 dispatch A1188A00235586724C00304D94FE9A7C6FB04::-79:HMLGW_1
2016.11.23 09:59:03.946 5: HMUARTLGW HMLGW_1 Dispatch: A1188A00235586724C00304D94FE9A7C6FB04::-79:HMLGW_1
2016.11.23 09:59:03.946 0: HMUARTLGW HMLGW_1 recv: 01 05 00 00 4F msg: 88 A0 02 355867 24C003 04D94FE9A7C6FB04
2016.11.23 09:59:03.945 5: HMUARTLGW HMLGW_1 read (27): fd001701bc0500004f88a00235586724c00304d94fe9a7c6fb04e45e crc OK
2016.11.23 09:59:03.941 5: SW: fd000901f00624c003000000fc7cbf
2016.11.23 09:59:03.940 5: HMUARTLGW HMLGW_1 send: (14): fd000901f00624c003000000fcbf
2016.11.23 09:59:03.940 0: HMUARTLGW HMLGW_1 send: 01 0624C003000000
2016.11.23 09:59:03.939 4: HMUARTLGW HMLGW_1 UpdatePeerReq: 24C003, state 93
2016.11.23 09:59:03.937 4: HMUARTLGW HMLGW_1 UpdatePeerReq: 24C003, state 92
2016.11.23 09:59:03.934 4: HMUARTLGW HMLGW_1 UpdatePeerReq: 24C003, state 91
2016.11.23 09:59:03.933 0: HMUARTLGW HMLGW_1 added peer: 24C003, aesChannels: FFFFFFFFFFFFFFFF
2016.11.23 09:59:03.932 5: HMUARTLGW HMLGW_1 GetSet Ack: 07, state 90
2016.11.23 09:59:03.931 5: HMUARTLGW HMLGW_1 recv: 01 04070101000DFFFFFFFFFFFFFFFF, state 90
2016.11.23 09:59:03.930 5: HMUARTLGW HMLGW_1 read (20): fd001001ef04070101000dffffffffffffffff057d crc OK
2016.11.23 09:59:03.929 5: HMUARTLGW HMLGW_1 read raw (49): fd001001ef04070101000dffffffffffffffff057dfd001701bc0500004f88a00235586724c00304d94fe9a7c6fb04e45e
2016.11.23 09:59:03.867 0: HMLAN_Parse: HMLANingo2 R:E24C003   stat:0100 t:0AEBEFFB d:FF r:FFC0     m:88 A640 24C003 355867 0152
2016.11.23 09:59:03.857 0: HMLAN_Parse: HMLANingo1 R:E355867   stat:0000 t:0057E5C7 d:FF r:FFBD     m:88 A002 355867 24C003 04D94FE9A7C6FB04
2016.11.23 09:59:03.851 0: HMLAN_Parse: HMLANingo1 R:E24C003   stat:0000 t:0057E547 d:FF r:FFB4     m:88 A640 24C003 355867 0152
2016.11.23 09:59:03.699 5: SW: fd000901ef0624c0030000008cf8
2016.11.23 09:59:03.698 5: HMUARTLGW HMLGW_1 send: (14): fd000901ef0624c0030000008cf8
2016.11.23 09:59:03.697 0: HMUARTLGW HMLGW_1 send: 01 0624C003000000
2016.11.23 09:59:03.697 4: HMUARTLGW HMLGW_1 UpdatePeerReq: 24C003, state 90
2016.11.23 09:59:03.689 5: HMLGW_1 dispatch A0B88A64024C0033558670152::-75:HMLGW_1
2016.11.23 09:59:03.689 5: HMUARTLGW HMLGW_1 Dispatch: A0B88A64024C0033558670152::-75:HMLGW_1
2016.11.23 09:59:03.688 0: HMUARTLGW HMLGW_1 recv: 01 05 00 00 4B msg: 88 A6 40 24C003 355867 0152
2016.11.23 09:59:03.687 5: HMUARTLGW HMLGW_1 read (21): fd001101bb0500004b88a64024c003355867015280e9 crc OK
2016.11.23 09:59:03.686 5: HMUARTLGW HMLGW_1 read raw (22): fd001101bb0500004b88a64024c003355867015280e9
2016.11.23 09:59:02.123 5: HMLGW_1 dispatch A0CEC86703EEC44000000009545::-57:HMLGW_1
2016.11.23 09:59:02.122 5: HMUARTLGW HMLGW_1 Dispatch: A0CEC86703EEC44000000009545::-57:HMLGW_1
2016.11.23 09:59:02.122 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 39 msg: EC 86 70 3EEC44 000000 009545
2016.11.23 09:59:02.121 5: HMUARTLGW HMLGW_1 read (22): fd001201ba05000039ec86703eec44000000009545da46 crc OK
2016.11.23 09:59:02.119 5: HMUARTLGW HMLGW_1 read raw (23): fd001201ba05000039ec86703eec44000000009545da46
2016.11.23 09:58:57.358 5: HMUARTLGW HMLGW_1:keepAlive read (4): >Kb7
2016.11.23 09:58:57.357 5: HMUARTLGW HMLGW_1:keepAlive read raw (6): 3e4b62370d0a
2016.11.23 09:58:57.353 5: SW: Kb7
2016.11.23 09:58:57.352 5: HMUARTLGW HMLGW_1:keepAlive send (3): Kb7
2016.11.23 09:58:56.836 5: HMUARTLGW HMLGW_1 roundtrip delay: 0.0051
2016.11.23 09:58:56.835 5: HMUARTLGW HMLGW_1 GetSet Ack: 02, state 98
2016.11.23 09:58:56.833 5: HMUARTLGW HMLGW_1 recv: 00 040207, state 98
2016.11.23 09:58:56.833 5: HMUARTLGW HMLGW_1 read (9): fd000500ee0402079469 crc OK
2016.11.23 09:58:56.832 5: HMUARTLGW HMLGW_1 read raw (10): fd000500ee0402079469
2016.11.23 09:58:56.826 5: SW: fd000300ee087c3c
2016.11.23 09:58:56.826 5: HMUARTLGW HMLGW_1 send: (8): fd000300ee087c3c
2016.11.23 09:58:56.825 5: HMUARTLGW HMLGW_1 send: 00 08
2016.11.23 09:58:56.823 5: HMUARTLGW HMLGW_1 checking credits (from timer)
2016.11.23 09:58:54.414 5: HMLGW_1 dispatch A0C17865A458A9200000098C43C::-54:HMLGW_1
2016.11.23 09:58:54.414 5: HMUARTLGW HMLGW_1 Dispatch: A0C17865A458A9200000098C43C::-54:HMLGW_1
2016.11.23 09:58:54.413 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 36 msg: 17 86 5A 458A92 000000 98C43C
2016.11.23 09:58:54.413 5: HMUARTLGW HMLGW_1 read (22): fd001201b90500003617865a458a9200000098c43ca6ff crc OK
2016.11.23 09:58:54.411 5: HMUARTLGW HMLGW_1 read raw (23): fd001201b90500003617865a458a9200000098c43ca6ff
2016.11.23 09:58:53.566 5: HMLGW_1 dispatch A0CE8865A2D33F900000098C03C::-66:HMLGW_1
2016.11.23 09:58:53.565 5: HMUARTLGW HMLGW_1 Dispatch: A0CE8865A2D33F900000098C03C::-66:HMLGW_1
2016.11.23 09:58:53.565 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 42 msg: E8 86 5A 2D33F9 000000 98C03C
2016.11.23 09:58:53.564 5: HMUARTLGW HMLGW_1 read (22): fd001201b805000042e8865a2d33f900000098c03c5d2e crc OK
2016.11.23 09:58:53.562 5: HMUARTLGW HMLGW_1 read raw (23): fd001201b805000042e8865a2d33f900000098c03c5d2e
2016.11.23 09:58:48.075 5: HMLGW_1 dispatch A0C0C847030330E00000080BF3D::-56:HMLGW_1
2016.11.23 09:58:48.075 5: HMUARTLGW HMLGW_1 Dispatch: A0C0C847030330E00000080BF3D::-56:HMLGW_1
2016.11.23 09:58:48.074 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 38 msg: 0C 84 70 30330E 000000 80BF3D
2016.11.23 09:58:48.073 5: HMUARTLGW HMLGW_1 read (22): fd001201b7050000380c847030330e00000080bf3d636d crc OK
2016.11.23 09:58:48.072 5: HMUARTLGW HMLGW_1 read raw (23): fd001201b7050000380c847030330e00000080bf3d636d
2016.11.23 09:58:47.345 5: HMUARTLGW HMLGW_1:keepAlive read (4): >Kb6
2016.11.23 09:58:47.345 5: HMUARTLGW HMLGW_1:keepAlive read raw (6): 3e4b62360d0a
2016.11.23 09:58:47.340 5: SW: Kb6
2016.11.23 09:58:47.340 5: HMUARTLGW HMLGW_1:keepAlive send (3): Kb6
2016.11.23 09:58:41.826 5: HMUARTLGW HMLGW_1 roundtrip delay: 0.0053
2016.11.23 09:58:41.826 5: HMUARTLGW HMLGW_1 GetSet Ack: 02, state 98
2016.11.23 09:58:41.824 5: HMUARTLGW HMLGW_1 recv: 00 040207, state 98
2016.11.23 09:58:41.824 5: HMUARTLGW HMLGW_1 read (9): fd000500ed040207a869 crc OK
2016.11.23 09:58:41.823 5: HMUARTLGW HMLGW_1 read raw (10): fd000500ed040207a869
2016.11.23 09:58:41.817 5: SW: fd000300ed08763c
2016.11.23 09:58:41.817 5: HMUARTLGW HMLGW_1 send: (8): fd000300ed08763c
2016.11.23 09:58:41.816 5: HMUARTLGW HMLGW_1 send: 00 08
2016.11.23 09:58:41.814 5: HMUARTLGW HMLGW_1 checking credits (from timer)
2016.11.23 09:58:39.911 5: HMLGW_1 dispatch A0C8584703A78D700000000CC39::-82:HMLGW_1
2016.11.23 09:58:39.911 5: HMUARTLGW HMLGW_1 Dispatch: A0C8584703A78D700000000CC39::-82:HMLGW_1
2016.11.23 09:58:39.910 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 52 msg: 85 84 70 3A78D7 000000 00CC39
2016.11.23 09:58:39.910 5: HMUARTLGW HMLGW_1 read (22): fd001201b6050000528584703a78d700000000cc3970bd crc OK
2016.11.23 09:58:39.908 5: HMUARTLGW HMLGW_1 read raw (23): fd001201b6050000528584703a78d700000000cc3970bd
2016.11.23 09:58:37.333 5: HMUARTLGW HMLGW_1:keepAlive read (4): >Kb5
2016.11.23 09:58:37.332 5: HMUARTLGW HMLGW_1:keepAlive read raw (6): 3e4b62350d0a
2016.11.23 09:58:37.328 5: SW: Kb5
2016.11.23 09:58:37.327 5: HMUARTLGW HMLGW_1:keepAlive send (3): Kb5
2016.11.23 09:58:34.836 5: HMLGW_1 dispatch A0F3486102C72270000000A98C0080000::-52:HMLGW_1
2016.11.23 09:58:34.835 5: HMUARTLGW HMLGW_1 Dispatch: A0F3486102C72270000000A98C0080000::-52:HMLGW_1
2016.11.23 09:58:34.835 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 34 msg: 34 86 10 2C7227 000000 0A98C0080000
2016.11.23 09:58:34.834 5: HMUARTLGW HMLGW_1 read (25): fd001501b5050000343486102c72270000000a98c0080000d422 crc OK
2016.11.23 09:58:34.832 5: HMUARTLGW HMLGW_1 read raw (26): fd001501b5050000343486102c72270000000a98c0080000d422
2016.11.23 09:58:33.380 5: HMLGW_1 dispatch A1422845E283A7C000000803D690017DF021C0910FD::-74:HMLGW_1
2016.11.23 09:58:33.380 5: HMUARTLGW HMLGW_1 Dispatch: A1422845E283A7C000000803D690017DF021C0910FD::-74:HMLGW_1
2016.11.23 09:58:33.379 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 4A msg: 22 84 5E 283A7C 000000 803D690017DF021C0910FD
2016.11.23 09:58:33.378 5: HMUARTLGW HMLGW_1 read (30): fd001a01b40500004a22845e283a7c000000803d690017df021c0910fded63 crc OK
2016.11.23 09:58:33.375 5: HMUARTLGW HMLGW_1 read raw (32): fd001a01b40500004a22845e283a7c000000803d690017df021c0910fc7ded63
2016.11.23 09:58:29.915 5: HMLGW_1 dispatch A0EC684103A78D70000000BA0CC0A00::-81:HMLGW_1
2016.11.23 09:58:29.914 5: HMUARTLGW HMLGW_1 Dispatch: A0EC684103A78D70000000BA0CC0A00::-81:HMLGW_1
2016.11.23 09:58:29.914 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 51 msg: C6 84 10 3A78D7 000000 0BA0CC0A00
2016.11.23 09:58:29.913 5: HMUARTLGW HMLGW_1 read (24): fd001401b305000051c684103a78d70000000ba0cc0a0063f1 crc OK
2016.11.23 09:58:29.911 5: HMUARTLGW HMLGW_1 read raw (25): fd001401b305000051c684103a78d70000000ba0cc0a0063f1
2016.11.23 09:58:28.877 5: HMLGW_1 dispatch A0F4886534F54EE00000000C1000A3F0C::-81:HMLGW_1
2016.11.23 09:58:28.877 5: HMUARTLGW HMLGW_1 Dispatch: A0F4886534F54EE00000000C1000A3F0C::-81:HMLGW_1
2016.11.23 09:58:28.876 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 51 msg: 48 86 53 4F54EE 000000 00C1000A3F0C
2016.11.23 09:58:28.875 5: HMUARTLGW HMLGW_1 read (25): fd001501b2050000514886534f54ee00000000c1000a3f0c3f9e crc OK
2016.11.23 09:58:28.873 5: HMUARTLGW HMLGW_1 read raw (26): fd001501b2050000514886534f54ee00000000c1000a3f0c3f9e
2016.11.23 09:58:28.081 5: HMLGW_1 dispatch A0C0C865A30330E00000098BF3D::-56:HMLGW_1
2016.11.23 09:58:28.081 5: HMUARTLGW HMLGW_1 Dispatch: A0C0C865A30330E00000098BF3D::-56:HMLGW_1
2016.11.23 09:58:28.080 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 38 msg: 0C 86 5A 30330E 000000 98BF3D
2016.11.23 09:58:28.074 5: HMUARTLGW HMLGW_1 read (22): fd001201b1050000380c865a30330e00000098bf3d9e5f crc OK
2016.11.23 09:58:28.072 5: HMUARTLGW HMLGW_1 read raw (23): fd001201b1050000380c865a30330e00000098bf3d9e5f
2016.11.23 09:58:27.320 5: HMUARTLGW HMLGW_1:keepAlive read (4): >Kb4
2016.11.23 09:58:27.319 5: HMUARTLGW HMLGW_1:keepAlive read raw (6): 3e4b62340d0a
2016.11.23 09:58:27.251 5: SW: Kb4
2016.11.23 09:58:27.250 5: HMUARTLGW HMLGW_1:keepAlive send (3): Kb4
2016.11.23 09:58:27.105 5: HMLGW_1 dispatch A1203800223DD3D355867010101002D511CF83A::-67:HMLGW_1
2016.11.23 09:58:27.105 5: HMUARTLGW HMLGW_1 Dispatch: A1203800223DD3D355867010101002D511CF83A::-67:HMLGW_1
2016.11.23 09:58:27.104 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 43 msg: 03 80 02 23DD3D 355867 010101002D511CF83A
2016.11.23 09:58:27.103 5: HMUARTLGW HMLGW_1 read (28): fd001801b00500004303800223dd3d355867010101002d511cf83a9f25 crc OK
2016.11.23 09:58:27.101 5: HMUARTLGW HMLGW_1 read raw (29): fd001801b00500004303800223dd3d355867010101002d511cf83a9f25
2016.11.23 09:58:26.985 5: HMLGW_1 dispatch A1903A00335586723DD3D2ECF57361CB304C525E3BFAB7097C091::-79:HMLGW_1
2016.11.23 09:58:26.985 5: HMUARTLGW HMLGW_1 Dispatch: A1903A00335586723DD3D2ECF57361CB304C525E3BFAB7097C091::-79:HMLGW_1
2016.11.23 09:58:26.984 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 4F msg: 03 A0 03 355867 23DD3D 2ECF57361CB304C525E3BFAB7097C091
2016.11.23 09:58:26.983 5: HMUARTLGW HMLGW_1 read (35): fd001f01af0500004f03a00335586723dd3d2ecf57361cb304c525e3bfab7097c0916921 crc OK
2016.11.23 09:58:26.981 5: HMUARTLGW HMLGW_1 read raw (36): fd001f01af0500004f03a00335586723dd3d2ecf57361cb304c525e3bfab7097c0916921
2016.11.23 09:58:26.849 5: HMLGW_1 dispatch A1103A00223DD3D35586704570041C3F2FB04::-67:HMLGW_1
2016.11.23 09:58:26.848 5: HMUARTLGW HMLGW_1 Dispatch: A1103A00223DD3D35586704570041C3F2FB04::-67:HMLGW_1
2016.11.23 09:58:26.848 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 43 msg: 03 A0 02 23DD3D 355867 04570041C3F2FB04
2016.11.23 09:58:26.847 5: HMUARTLGW HMLGW_1 read (27): fd001701ae0500004303a00223dd3d35586704570041c3f2fb04910f crc OK
2016.11.23 09:58:26.845 5: HMUARTLGW HMLGW_1 read raw (28): fd001701ae0500004303a00223dd3d35586704570041c3f2fb04910f
2016.11.23 09:58:26.815 5: HMUARTLGW HMLGW_1 roundtrip delay: 0.0053
2016.11.23 09:58:26.814 5: HMUARTLGW HMLGW_1 GetSet Ack: 02, state 98
2016.11.23 09:58:26.813 5: HMUARTLGW HMLGW_1 recv: 00 040207, state 98
2016.11.23 09:58:26.812 5: HMUARTLGW HMLGW_1 read (9): fd000500ec0402073c6a crc OK
2016.11.23 09:58:26.811 5: HMUARTLGW HMLGW_1 read raw (10): fd000500ec0402073c6a
2016.11.23 09:58:26.806 5: SW: fd000300ec08f03f
2016.11.23 09:58:26.805 5: HMUARTLGW HMLGW_1 send: (8): fd000300ec08f03f
2016.11.23 09:58:26.805 5: HMUARTLGW HMLGW_1 send: 00 08
2016.11.23 09:58:26.803 5: HMUARTLGW HMLGW_1 checking credits (from timer)
2016.11.23 09:58:26.719 5: HMLGW_1 dispatch A0D03B01135586723DD3D800101FF::-79:HMLGW_1
2016.11.23 09:58:26.719 5: HMUARTLGW HMLGW_1 Dispatch: A0D03B01135586723DD3D800101FF::-79:HMLGW_1
2016.11.23 09:58:26.718 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 4F msg: 03 B0 11 355867 23DD3D 800101FF
2016.11.23 09:58:26.717 5: HMUARTLGW HMLGW_1 read (23): fd001301ad0500004f03b01135586723dd3d800101ffa005 crc OK
2016.11.23 09:58:26.716 5: HMUARTLGW HMLGW_1 read raw (24): fd001301ad0500004f03b01135586723dd3d800101ffa005
2016.11.23 09:58:26.709 5: HMLGW_1 dispatch A0C0584703A78E600000000CA3B::-80:HMLGW_1
2016.11.23 09:58:26.709 5: HMUARTLGW HMLGW_1 Dispatch: A0C0584703A78E600000000CA3B::-80:HMLGW_1
2016.11.23 09:58:26.709 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 50 msg: 05 84 70 3A78E6 000000 00CA3B
2016.11.23 09:58:26.708 5: HMUARTLGW HMLGW_1 read (22): fd001201ac050000500584703a78e600000000ca3b4baa crc OK
2016.11.23 09:58:26.702 5: HMLGW_1 dispatch A0F6E86103B05FD0000000A90B50B1000::-45:HMLGW_1
2016.11.23 09:58:26.702 5: HMUARTLGW HMLGW_1 Dispatch: A0F6E86103B05FD0000000A90B50B1000::-45:HMLGW_1
2016.11.23 09:58:26.702 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 2D msg: 6E 86 10 3B05FD 000000 0A90B50B1000
2016.11.23 09:58:26.701 5: HMUARTLGW HMLGW_1 read (25): fd001501ab0500002d6e86103b05fd0000000a90b50b1000257b crc OK
2016.11.23 09:58:26.695 5: HMLGW_1 dispatch A0A87800235586724C00300::-80:HMLGW_1
2016.11.23 09:58:26.695 5: HMUARTLGW HMLGW_1 Dispatch: A0A87800235586724C00300::-80:HMLGW_1
2016.11.23 09:58:26.694 0: HMUARTLGW HMLGW_1 recv: 01 05 00 00 50 msg: 87 80 02 355867 24C003 00
2016.11.23 09:58:26.693 5: HMUARTLGW HMLGW_1 read (20): fd001001aa0500005087800235586724c003004827 crc OK
2016.11.23 09:58:26.692 5: HMUARTLGW HMLGW_1 read raw (71): fd001001aa0500005087800235586724c003004827fd001501ab0500002d6e86103b05fc7d0000000a90b50b1000257bfd001201ac050000500584703a78e600000000ca3b4baa
2016.11.23 09:58:26.676 0: HMLAN_Parse: HMLANingo2 R:R906852BC stat:0002 t:00000000 d:FF r:7FFF     m:87 8002 355867 24C003 00
2016.11.23 09:58:26.487 0: HMLAN_Parse: HMLANingo1 R:E355867   stat:0000 t:00575297 d:FF r:FFBD     m:87 8002 355867 24C003 00
2016.11.23 09:58:26.139 0: HMLAN_Parse: HMLANingo2 R:E24C003   stat:0040 t:0AEB5AC9 d:02 r:FFBF     m:87 A640 24C003 355867 0151
2016.11.23 09:58:26.017 0: HMLAN_Parse: HMLANingo1 R:E355867   stat:0000 t:0057518C d:FF r:FFBD     m:87 8002 355867 24C003 00EF97FE51
2016.11.23 09:58:26.009 5: HMLGW_1 dispatch A0E87800235586724C00300EF97FE51::-79:HMLGW_1
2016.11.23 09:58:26.008 5: HMUARTLGW HMLGW_1 Dispatch: A0E87800235586724C00300EF97FE51::-79:HMLGW_1
2016.11.23 09:58:26.008 0: HMUARTLGW HMLGW_1 recv: 01 05 00 00 4F msg: 87 80 02 355867 24C003 00EF97FE51
2016.11.23 09:58:26.007 5: HMUARTLGW HMLGW_1 read (24): fd001401a90500004f87800235586724c00300ef97fe512796 crc OK
2016.11.23 09:58:26.005 5: HMUARTLGW HMLGW_1 read raw (25): fd001401a90500004f87800235586724c00300ef97fe512796
2016.11.23 09:58:25.878 0: HMLAN_Parse: HMLANingo1 R:E24C003   stat:0050 t:00575015 d:02 r:FFB8     m:87 A640 24C003 355867 0151
2016.11.23 09:58:25.826 5: HMLGW_1 dispatch A1987A00324C00335586786AE471934DF59CF56B51439273DD2A9::-76:HMLGW_1
2016.11.23 09:58:25.826 5: HMUARTLGW HMLGW_1 Dispatch: A1987A00324C00335586786AE471934DF59CF56B51439273DD2A9::-76:HMLGW_1
2016.11.23 09:58:25.825 0: HMUARTLGW HMLGW_1 recv: 01 05 00 00 4C msg: 87 A0 03 24C003 355867 86AE471934DF59CF56B51439273DD2A9
2016.11.23 09:58:25.824 5: HMUARTLGW HMLGW_1 read (35): fd001f01a80500004c87a00324c00335586786ae471934df59cf56b51439273dd2a98d52 crc OK
2016.11.23 09:58:25.817 5: HMLGW_1 dispatch A1187A00235586724C00304D345E3ADCCF104::-66:HMLGW_1
2016.11.23 09:58:25.817 5: HMUARTLGW HMLGW_1 Dispatch: A1187A00235586724C00304D345E3ADCCF104::-66:HMLGW_1
2016.11.23 09:58:25.816 0: HMUARTLGW HMLGW_1 recv: 01 05 00 00 42 msg: 87 A0 02 355867 24C003 04D345E3ADCCF104
2016.11.23 09:58:25.815 5: HMUARTLGW HMLGW_1 read (27): fd001701a70500004287a00235586724c00304d345e3adccf1040588 crc OK
2016.11.23 09:58:25.814 5: HMUARTLGW HMLGW_1 read raw (64): fd001701a70500004287a00235586724c00304d345e3adccf1040588fd001f01a80500004c87a00324c00335586786ae471934df59cf56b51439273dd2a98d52
2016.11.23 09:58:25.809 0: HMLAN_Parse: HMLANingo2 R:E24C003   stat:0100 t:0AEB5AC9 d:FF r:FFBF     m:87 A640 24C003 355867 0151
2016.11.23 09:58:25.755 0: HMLAN_Parse: HMLANingo1 R:E24C003   stat:0100 t:00575015 d:FF r:FFB8     m:87 A640 24C003 355867 0151
2016.11.23 09:58:25.610 0: HMLAN_Send:  HMLANingo2 S:S906852BC stat:  00 t:00000000 d:01 r:906852BC m:87 8002 355867 24C003 00
2016.11.23 09:58:25.609 0: HMLAN_Send:  HMLANingo2 S:+24C003,01,02,1E
2016.11.23 09:58:25.500 5: HMLGW_1 dispatch A0B87A64024C0033558670151::-76:HMLGW_1
2016.11.23 09:58:25.500 5: HMUARTLGW HMLGW_1 Dispatch: A0B87A64024C0033558670151::-76:HMLGW_1
2016.11.23 09:58:25.500 0: HMUARTLGW HMLGW_1 recv: 01 05 00 00 4C msg: 87 A6 40 24C003 355867 0151
2016.11.23 09:58:25.499 5: HMUARTLGW HMLGW_1 read (21): fd001101a60500004c87a64024c00335586701514f12 crc OK
2016.11.23 09:58:25.497 5: HMUARTLGW HMLGW_1 read raw (22): fd001101a60500004c87a64024c00335586701514f12
2016.11.23 09:58:23.232 5: HMLGW_1 dispatch A0C9086703EEC76000000007E45::-71:HMLGW_1
2016.11.23 09:58:23.232 5: HMUARTLGW HMLGW_1 Dispatch: A0C9086703EEC76000000007E45::-71:HMLGW_1
2016.11.23 09:58:23.231 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 47 msg: 90 86 70 3EEC76 000000 007E45
2016.11.23 09:58:23.230 5: HMUARTLGW HMLGW_1 read (22): fd001201a5050000479086703eec76000000007e455271 crc OK
2016.11.23 09:58:23.229 5: HMUARTLGW HMLGW_1 read raw (23): fd001201a5050000479086703eec76000000007e455271
2016.11.23 09:58:23.023 5: HMLGW_1 dispatch A0F3986103B04DB0000000AA0CA0A0900::-71:HMLGW_1
2016.11.23 09:58:23.023 5: HMUARTLGW HMLGW_1 Dispatch: A0F3986103B04DB0000000AA0CA0A0900::-71:HMLGW_1
2016.11.23 09:58:23.022 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 47 msg: 39 86 10 3B04DB 000000 0AA0CA0A0900
2016.11.23 09:58:23.021 5: HMUARTLGW HMLGW_1 read (25): fd001501a4050000473986103b04db0000000aa0ca0a0900a141 crc OK
2016.11.23 09:58:23.020 5: HMUARTLGW HMLGW_1 read raw (26): fd001501a4050000473986103b04db0000000aa0ca0a0900a141
2016.11.23 09:58:22.435 5: HMLGW_1 dispatch A0CF88470303D1400000000BF3E::-52:HMLGW_1
2016.11.23 09:58:22.434 5: HMUARTLGW HMLGW_1 Dispatch: A0CF88470303D1400000000BF3E::-52:HMLGW_1
2016.11.23 09:58:22.434 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 34 msg: F8 84 70 303D14 000000 00BF3E
2016.11.23 09:58:22.433 5: HMUARTLGW HMLGW_1 read (22): fd001201a305000034f88470303d1400000000bf3ec029 crc OK
2016.11.23 09:58:22.431 5: HMUARTLGW HMLGW_1 read raw (23): fd001201a305000034f88470303d1400000000bf3ec029
2016.11.23 09:58:19.912 5: HMLGW_1 dispatch A0C85865A3A78D7000000A0CC3A::-81:HMLGW_1
2016.11.23 09:58:19.911 5: HMUARTLGW HMLGW_1 Dispatch: A0C85865A3A78D7000000A0CC3A::-81:HMLGW_1
2016.11.23 09:58:19.911 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 51 msg: 85 86 5A 3A78D7 000000 A0CC3A
2016.11.23 09:58:19.910 5: HMUARTLGW HMLGW_1 read (22): fd001201a20500005185865a3a78d7000000a0cc3a690d crc OK
2016.11.23 09:58:19.908 5: HMUARTLGW HMLGW_1 read raw (23): fd001201a20500005185865a3a78d7000000a0cc3a690d
2016.11.23 09:58:17.146 5: HMUARTLGW HMLGW_1:keepAlive read (4): >Kb3
2016.11.23 09:58:17.145 5: HMUARTLGW HMLGW_1:keepAlive read raw (6): 3e4b62330d0a
2016.11.23 09:58:17.136 5: SW: Kb3
2016.11.23 09:58:17.135 5: HMUARTLGW HMLGW_1:keepAlive send (3): Kb3
2016.11.23 09:58:16.288 5: HMLGW_1 dispatch A0E0984103A78E60000000BA0CA0E00::-80:HMLGW_1
2016.11.23 09:58:16.288 5: HMUARTLGW HMLGW_1 Dispatch: A0E0984103A78E60000000BA0CA0E00::-80:HMLGW_1
2016.11.23 09:58:16.287 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 50 msg: 09 84 10 3A78E6 000000 0BA0CA0E00
2016.11.23 09:58:16.284 5: HMUARTLGW HMLGW_1 read (24): fd001401a1050000500984103a78e60000000ba0ca0e00f655 crc OK
2016.11.23 09:58:16.282 5: HMUARTLGW HMLGW_1 read raw (25): fd001401a1050000500984103a78e60000000ba0ca0e00f655
2016.11.23 09:58:12.363 5: HMLGW_1 dispatch A0CED84702D336C00000000CA3B::-75:HMLGW_1
2016.11.23 09:58:12.362 5: HMUARTLGW HMLGW_1 Dispatch: A0CED84702D336C00000000CA3B::-75:HMLGW_1
2016.11.23 09:58:12.362 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 4B msg: ED 84 70 2D336C 000000 00CA3B
2016.11.23 09:58:12.361 5: HMUARTLGW HMLGW_1 read (22): fd001201a00500004bed84702d336c00000000ca3b0dcf crc OK
2016.11.23 09:58:12.359 5: HMUARTLGW HMLGW_1 read raw (23): fd001201a00500004bed84702d336c00000000ca3b0dcf
2016.11.23 09:58:11.863 5: HMLGW_1 dispatch A0FFF86103B04D60000000A98C40C0000::-54:HMLGW_1
2016.11.23 09:58:11.862 5: HMUARTLGW HMLGW_1 Dispatch: A0FFF86103B04D60000000A98C40C0000::-54:HMLGW_1
2016.11.23 09:58:11.861 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 36 msg: FF 86 10 3B04D6 000000 0A98C40C0000
2016.11.23 09:58:11.859 5: HMUARTLGW HMLGW_1 read (25): fd0015019f05000036ff86103b04d60000000a98c40c000004d4 crc OK
2016.11.23 09:58:11.857 5: HMUARTLGW HMLGW_1 read raw (26): fd0015019f05000036ff86103b04d60000000a98c40c000004d4
2016.11.23 09:58:11.808 5: HMUARTLGW HMLGW_1 roundtrip delay: 0.0064
2016.11.23 09:58:11.807 5: HMUARTLGW HMLGW_1 GetSet Ack: 02, state 98
2016.11.23 09:58:11.805 5: HMUARTLGW HMLGW_1 recv: 00 040207, state 98
2016.11.23 09:58:11.804 5: HMUARTLGW HMLGW_1 read (9): fd000500eb040207d069 crc OK
2016.11.23 09:58:11.803 5: HMUARTLGW HMLGW_1 read raw (10): fd000500eb040207d069
2016.11.23 09:58:11.796 5: SW: fd000300eb08623c
2016.11.23 09:58:11.795 5: HMUARTLGW HMLGW_1 send: (8): fd000300eb08623c
2016.11.23 09:58:11.794 5: HMUARTLGW HMLGW_1 send: 00 08
2016.11.23 09:58:11.791 5: HMUARTLGW HMLGW_1 checking credits (from timer)
2016.11.23 09:58:07.129 5: HMUARTLGW HMLGW_1:keepAlive read (4): >Kb2
2016.11.23 09:58:07.128 5: HMUARTLGW HMLGW_1:keepAlive read raw (6): 3e4b62320d0a
2016.11.23 09:58:07.124 5: SW: Kb2
2016.11.23 09:58:07.123 5: HMUARTLGW HMLGW_1:keepAlive send (3): Kb2
2016.11.23 09:58:06.282 5: HMLGW_1 dispatch A0C05865A3A78E6000000A0CA3B::-79:HMLGW_1
2016.11.23 09:58:06.282 5: HMUARTLGW HMLGW_1 Dispatch: A0C05865A3A78E6000000A0CA3B::-79:HMLGW_1
2016.11.23 09:58:06.282 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 4F msg: 05 86 5A 3A78E6 000000 A0CA3B
2016.11.23 09:58:06.281 5: HMUARTLGW HMLGW_1 read (22): fd0012019e0500004f05865a3a78e6000000a0ca3b7ef6 crc OK
2016.11.23 09:58:06.279 5: HMUARTLGW HMLGW_1 read raw (23): fd0012019e0500004f05865a3a78e6000000a0ca3b7ef6
2016.11.23 09:58:05.314 5: HMLGW_1 dispatch A0FAA861028B37B0000000AA0C80E0E00::-70:HMLGW_1
2016.11.23 09:58:05.313 5: HMUARTLGW HMLGW_1 Dispatch: A0FAA861028B37B0000000AA0C80E0E00::-70:HMLGW_1
2016.11.23 09:58:05.313 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 46 msg: AA 86 10 28B37B 000000 0AA0C80E0E00
2016.11.23 09:58:05.312 5: HMUARTLGW HMLGW_1 read (25): fd0015019d05000046aa861028b37b0000000aa0c80e0e00c7fb crc OK
2016.11.23 09:58:05.310 5: HMUARTLGW HMLGW_1 read raw (26): fd0015019d05000046aa861028b37b0000000aa0c80e0e00c7fb
2016.11.23 09:58:03.599 5: HMLGW_1 dispatch A0C278470458AAA00000000B543::-65:HMLGW_1
2016.11.23 09:58:03.598 5: HMUARTLGW HMLGW_1 Dispatch: A0C278470458AAA00000000B543::-65:HMLGW_1
2016.11.23 09:58:03.598 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 41 msg: 27 84 70 458AAA 000000 00B543
2016.11.23 09:58:03.597 5: HMUARTLGW HMLGW_1 read (22): fd0012019c05000041278470458aaa00000000b5431b09 crc OK
2016.11.23 09:58:03.595 5: HMUARTLGW HMLGW_1 read raw (23): fd0012019c05000041278470458aaa00000000b5431b09
2016.11.23 09:58:02.434 5: HMLGW_1 dispatch A0CF8865A303D1400000098BF3E::-52:HMLGW_1
2016.11.23 09:58:02.434 5: HMUARTLGW HMLGW_1 Dispatch: A0CF8865A303D1400000098BF3E::-52:HMLGW_1
2016.11.23 09:58:02.433 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 34 msg: F8 86 5A 303D14 000000 98BF3E
2016.11.23 09:58:02.433 5: HMUARTLGW HMLGW_1 read (22): fd0012019b05000034f8865a303d1400000098bf3eb003 crc OK
2016.11.23 09:58:02.431 5: HMUARTLGW HMLGW_1 read raw (23): fd0012019b05000034f8865a303d1400000098bf3eb003
2016.11.23 09:57:59.807 5: HMLGW_1 dispatch A141B845E2AB5DA00000092F2760000010000091AFD::-69:HMLGW_1
2016.11.23 09:57:59.807 5: HMUARTLGW HMLGW_1 Dispatch: A141B845E2AB5DA00000092F2760000010000091AFD::-69:HMLGW_1
2016.11.23 09:57:59.806 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 45 msg: 1B 84 5E 2AB5DA 000000 92F2760000010000091AFD
2016.11.23 09:57:59.803 5: HMUARTLGW HMLGW_1 read (30): fd001a019a050000451b845e2ab5da00000092f2760000010000091afd137b crc OK
2016.11.23 09:57:59.800 5: HMUARTLGW HMLGW_1 read raw (32): fd001a019a050000451b845e2ab5da00000092f2760000010000091afc7d137b
2016.11.23 09:57:57.117 5: HMUARTLGW HMLGW_1:keepAlive read (4): >Kb1
2016.11.23 09:57:57.116 5: HMUARTLGW HMLGW_1:keepAlive read raw (6): 3e4b62310d0a
2016.11.23 09:57:57.112 5: SW: Kb1
2016.11.23 09:57:57.111 5: HMUARTLGW HMLGW_1:keepAlive send (3): Kb1
2016.11.23 09:57:56.809 5: HMUARTLGW HMLGW_1 GetSet Ack: 02, state 98
2016.11.23 09:57:56.808 5: HMUARTLGW HMLGW_1 recv: 00 040207, state 98
2016.11.23 09:57:56.807 5: HMUARTLGW HMLGW_1 read (9): fd000500ea040207446a crc OK
2016.11.23 09:57:56.803 5: HMLGW_1 dispatch A0C83847030336900000000C03C::-58:HMLGW_1
2016.11.23 09:57:56.802 5: HMUARTLGW HMLGW_1 Dispatch: A0C83847030336900000000C03C::-58:HMLGW_1
2016.11.23 09:57:56.802 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 3A msg: 83 84 70 303369 000000 00C03C
2016.11.23 09:57:56.801 5: HMUARTLGW HMLGW_1 read (22): fd001201990500003a83847030336900000000c03c6e06 crc OK
2016.11.23 09:57:56.800 5: HMUARTLGW HMLGW_1 read raw (33): fd001201990500003a83847030336900000000c03c6e06fd000500ea040207446a
2016.11.23 09:57:56.781 5: SW: fd000300ea08e43f
2016.11.23 09:57:56.780 5: HMUARTLGW HMLGW_1 send: (8): fd000300ea08e43f
2016.11.23 09:57:56.780 5: HMUARTLGW HMLGW_1 send: 00 08
2016.11.23 09:57:56.778 5: HMUARTLGW HMLGW_1 checking credits (from timer)
2016.11.23 09:57:53.601 5: HMLGW_1 dispatch A0EF08410458AAA0000000B90B50C00::-65:HMLGW_1
2016.11.23 09:57:53.601 5: HMUARTLGW HMLGW_1 Dispatch: A0EF08410458AAA0000000B90B50C00::-65:HMLGW_1
2016.11.23 09:57:53.600 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 41 msg: F0 84 10 458AAA 000000 0B90B50C00
2016.11.23 09:57:53.599 5: HMUARTLGW HMLGW_1 read (24): fd0014019805000041f08410458aaa0000000b90b50c00b988 crc OK
2016.11.23 09:57:53.598 5: HMUARTLGW HMLGW_1 read raw (25): fd0014019805000041f08410458aaa0000000b90b50c00b988
2016.11.23 09:57:52.362 5: HMLGW_1 dispatch A0CED865A2D336C000000A0CA3B::-75:HMLGW_1
2016.11.23 09:57:52.362 5: HMUARTLGW HMLGW_1 Dispatch: A0CED865A2D336C000000A0CA3B::-75:HMLGW_1
2016.11.23 09:57:52.361 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 4B msg: ED 86 5A 2D336C 000000 A0CA3B
2016.11.23 09:57:52.360 5: HMUARTLGW HMLGW_1 read (22): fd001201970500004bed865a2d336c000000a0ca3bdc4a crc OK
2016.11.23 09:57:52.359 5: HMUARTLGW HMLGW_1 read raw (23): fd001201970500004bed865a2d336c000000a0ca3bdc4a
2016.11.23 09:57:50.501 5: HMLGW_1 dispatch A14B1845E2B336B0000008955D800000A003B093C01::-68:HMLGW_1
2016.11.23 09:57:50.500 5: HMUARTLGW HMLGW_1 Dispatch: A14B1845E2B336B0000008955D800000A003B093C01::-68:HMLGW_1
2016.11.23 09:57:50.500 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 44 msg: B1 84 5E 2B336B 000000 8955D800000A003B093C01
2016.11.23 09:57:50.499 5: HMUARTLGW HMLGW_1 read (30): fd001a019605000044b1845e2b336b0000008955d800000a003b093c01c74e crc OK
2016.11.23 09:57:50.497 5: HMUARTLGW HMLGW_1 read raw (31): fd001a019605000044b1845e2b336b0000008955d800000a003b093c01c74e
2016.11.23 09:57:47.105 5: HMUARTLGW HMLGW_1:keepAlive read (4): >Kb0
2016.11.23 09:57:47.104 5: HMUARTLGW HMLGW_1:keepAlive read raw (6): 3e4b62300d0a
2016.11.23 09:57:47.100 5: SW: Kb0
2016.11.23 09:57:47.099 5: HMUARTLGW HMLGW_1:keepAlive send (3): Kb0
2016.11.23 09:57:43.599 5: HMLGW_1 dispatch A0C27865A458AAA00000090B543::-65:HMLGW_1
2016.11.23 09:57:43.598 5: HMUARTLGW HMLGW_1 Dispatch: A0C27865A458AAA00000090B543::-65:HMLGW_1
2016.11.23 09:57:43.598 5: HMUARTLGW HMLGW_1 recv: 01 05 00 00 41 msg: 27 86 5A 458AAA 000000 90B543
2016.11.23 09:57:43.597 5: HMUARTLGW HMLGW_1 read (22): fd001201950500004127865a458aaa00000090b543ce57 crc OK
2016.11.23 09:57:43.595 5: HMUARTLGW HMLGW_1 read raw (23): fd001201950500004127865a458aaa00000090b543ce57
2016.11.23 09:57:40.712 5: HMUARTLGW HMLGW_1 roundtrip delay: 0.0082
2016.11.23 09:57:40.711 5: HMUARTLGW HMLGW_1 GetSet Ack: 02, state 98
2016.11.23 09:57:40.709 5: HMUARTLGW HMLGW_1 recv: 00 040207, state 98
2016.11.23 09:57:40.709 5: HMUARTLGW HMLGW_1 read (9): fd000500e9040207786a crc OK
2016.11.23 09:57:40.708 5: HMUARTLGW HMLGW_1 read raw (10): fd000500e9040207786a
2016.11.23 09:57:40.699 5: SW: fd000300e908ee3f
2016.11.23 09:57:40.699 5: HMUARTLGW HMLGW_1 send: (8): fd000300e908ee3f
2016.11.23 09:57:40.698 5: HMUARTLGW HMLGW_1 send: 00 08
2016.11.23 09:57:40.697 5: HMUARTLGW HMLGW_1 checking credits (from timer)
hier List HMLGW:
   AssignedPeerCnt 17
   CNT        40
   DEF        192.168.171.188
   DEVCNT     134
   DevState   99
   DevType    LGW
   DeviceName 192.168.171.188:2000
   FD         54
   LastOpen   1479891360.39806
   NAME       HMLGW_1
   NR         1540
   PARTIAL
   RAWMSG     0500004CB1845E2A825400000088CAF30000050000091401
   RSSI       -76
   STATE      opened
   TYPE       HMUARTLGW
   XmitOpen   1
   msgLoadCurrent 6
   msgLoadHistory 0/5/-/-/-/-/-/-/-/-/-/-
   msgLoadHistoryAbs 5/5/0/-/-/-/-/-/-/-/-/-/-
   owner      355867
   owner_CCU  vccu
   Helper:
     CreditTimer 54
     FW         66561
     Initialized 1
     SendCnt    17
     Ackpending:
       1:
         cmd        020000000C800235586738154400
         dst        1
         frame      FD00100101020000000C80023558673815440065F0
         time       1479891683.6821
       200:
         cmd        020000000280023558674C6FC800
         dst        1
         frame      FD001001C8020000000280023558674C6FC80050C4
         time       1479891372.04326
       204:
         cmd        020000000A800235586738154400
         dst        1
         frame      FD001001CC020000000A8002355867381544006A23
         time       1479891375.7967
       213:
         cmd        020000000280023558673E844F00
         dst        1
         frame      FD001001D5020000000280023558673E844F00BA88
         time       1479891391.42457
       226:
         cmd        02000000028002355867384B7000
         dst        1
         frame      FD001001E202000000028002355867384B700078F6
         time       1479891407.4957
       229:
         cmd        020000000280023558674C6D1E00
         dst        1
         frame      FD001001E5020000000280023558674C6D1E00090D
         time       1479891408.23777
       253:
         cmd        02000000DF800235586740176000
         dst        1
         frame      FD001001FD02000000DF8002355867401760008D5C
         time       1479891668.33018
       34:
         cmd        020000008080023558674C102B00
         dst        1
         frame      FD00100122020000008080023558674C102B00BE33
         time       1479892130.03095
       40:
         cmd        020000002D80023558674015DF00
         dst        1
         frame      FD00100128020000002D80023558674015DF0094A7
         time       1479892170.24181
     Assignedpeers:
       24C003     FFFFFFFFFFFFFFFF
       329CF7     FFFFFFFFFFFFFFFF
       381544     FFFFFFFFFFFFFFFF
       384B70     FFFFFFFFFFFFFFFF
       3A5BBE     FFFFFFFFFFFFFFFF
       3E844F     FFFFFFFFFFFFFFFF
       4015DF     FFFFFFFFFFFFFFFF
       401760     FFFFFFFFFFFFFFFF
       4C1020     FFFFFFFFFFFFFFFF
       4C1028     FFFFFFFFFFFFFFFF
       4C102B     FFFFFFFFFFFFFFFF
       4C11DC     FFFFFFFFFFFFFFFF
       4C6D1E     FFFFFFFFFFFFFFFF
       4C6FC8     FFFFFFFFFFFFFFFF
       4DF58D     FFFFFFFFFFFFFFFF
       4F54EE     FFFFFFFFFFFFFFFF
       529E1E     FFFFFFFFFFFFFFFF
     LastSendLen:
       9
       16
     Log:
       IDs:
         24C003
     PeerQueue:
     PendingCMD:
     Roundtrip:
       Delay      0.0058140754699707
     Loadlvl:
       lastHistory 1479891968.17043
   Peers:
     24C003     assigned
     329CF7     assigned
     381544     assigned
     384B70     assigned
     3A5BBE     assigned
     3E844F     assigned
     4015DF     assigned
     401760     assigned
     4C1020     assigned
     4C1028     assigned
     4C102B     assigned
     4C11DC     assigned
     4C6D1E     assigned
     4C6FC8     assigned
     4DF58D     assigned
     4F54EE     assigned
     529E1E     assigned
   Readings:
     2016-11-23 09:56:08   D-HMIdAssigned  355867
     2016-11-23 09:56:08   D-HMIdOriginal  FFFFFF
     2016-11-23 09:56:00   D-LANfirmware   1.1.5
     2016-11-23 09:56:08   D-firmware      1.4.1
     2016-11-23 09:56:00   D-serialNr      NEQ0707752
     2016-11-23 09:56:00   D-type          eQ3-HM-LGW
     2016-11-23 09:56:08   cond            ok
     2016-11-23 10:08:57   load            6
     2016-11-23 09:56:08   loadLvl         low
     2016-11-23 09:56:00   state           opened
   Helper:
   Keepalive:
     CNT        247
     DEVCNT     246
     DevState   99
     DevType    LGW-KeepAlive
     DeviceName 192.168.171.188:2001
     FD         61
     LastOpen   1479891361.90751
     NAME       HMLGW_1:keepAlive
     NR         1592
     PARTIAL
     STATE      opened
     TEMPORARY  1
     TYPE       HMUARTLGW
     XmitOpen   0
     Helper:
       NextKeepAlive 1479892178.49423
       Log:
         Resolve    1
         IDs:
     Readings:
       2016-11-23 09:56:01   state           opened
     Lgwhash:
   event-on-change-reading .*
   group      HMLAN
   hmId       355867
   lgwPw      xxxxxx
   logIDs     Flur_fs_Hand
   room       __System
   verbose    5
und das List der Fernbedienung:
[code]Internals:
   CFGFN      ./FHEM/flur_eg.cfg
   DEF        24C003
   HMLANingo1_MSGCNT 8
   HMLANingo1_RAWMSG E24C003,0000,005805A0,FF,FFB5,8BA24024C0033558670153
   HMLANingo1_RSSI -75
   HMLANingo1_TIME 2016-11-23 09:59:12
   HMLANingo2_MSGCNT 9
   HMLANingo2_RAWMSG E24C003,0000,0AEC1054,FF,FFC1,8BA24024C0033558670153
   HMLANingo2_RSSI -63
   HMLANingo2_TIME 2016-11-23 09:59:12
   HMLGW_1_MSGCNT 7
   HMLGW_1_RAWMSG 0501004B8BA24024C0033558670153
   HMLGW_1_RSSI -75
   HMLGW_1_TIME 2016-11-23 09:59:11
   IODev      HMLGW_1
   LASTInputDev HMLANingo2
   MSGCNT     24
   NAME       Flur_fs_Hand
   NOTIFYDEV  global
   NR         303
   NTFY_ORDER 50-Flur_fs_Hand
   STATE      Flur_fs_Hand_Btn_01_unlock Short
   TYPE       CUL_HM
   channel_01 Flur_fs_Hand_Btn_01_unlock
   channel_02 Flur_fs_Hand_Btn_02_lock
   channel_03 Flur_fs_Hand_Btn_03_light
   channel_04 Flur_fs_Hand_Btn_04_open
   lastMsg    No:8B - t:40 s:24C003 d:355867 0153
   protEvt_AESCom-ok 2 last_at:2016-11-23 09:59:04
   protLastRcv 2016-11-23 09:59:12
   protSnd    9 last_at:2016-11-23 09:59:11
   protState  CMDs_done
   rssi_at_HMLANingo1 avg:-75.5 min:-76 max:-75 lst:-75 cnt:4
   rssi_at_HMLANingo2 avg:-63.6 min:-65 max:-63 lst:-63 cnt:5
   rssi_at_HMLGW_1 avg:-75.28 min:-76 max:-75 lst:-75 cnt:7
   Readings:
     2016-10-20 22:42:02   CommandAccepted yes
     2016-10-20 22:42:16   D-firmware      1.1
     2016-10-20 22:42:16   D-serialNr      KEQ0855628
     2016-10-20 22:42:17   PairedTo        0x355867
     2016-05-27 22:21:18   R-localResDis   off
     2016-10-19 16:20:52   R-pairCentral   0x355867
     2016-10-20 22:42:16   RegL_00.        02:01 0A:35 0B:58 0C:67 18:00 00:00
     2016-11-23 09:59:04   aesCommToDev    ok
     2016-10-20 22:42:02   aesKeyNbr       04
     2016-11-23 09:59:03   aesReqTo        vccu
     2016-10-21 20:00:04   alive           yes
     2016-11-23 09:59:11   battery         ok
     2016-10-21 20:00:04   powerOn         2016-10-21 20:00:04
     2016-10-21 20:00:04   recentStateType info
     2016-10-21 20:00:24   sabotageAttackId_ErrIoId_355355 cnt:37
     2016-10-21 20:00:24   sabotageAttack_ErrIoAttack cnt 37
     2016-11-23 09:59:11   state           Flur_fs_Hand_Btn_01_unlock Short
   Helper:
     HM_CMDNR   139
     mId        00A6
     rxType     20
     Ack:
     Expert:
       def        1
       det        1
       raw        1
       tpl        1
     Io:
       newChn     +24C003,01,02,1E
       nextSend   1479891552.2459
       rx
mgernoth
Hmm, das ist komisch. Angeblich ist in keinem Channel aesCommReq gesetzt (nicht-gesetzte Bits in aesChannels geben an, für welchen Kanal AES angefordert werden soll). (Und wieso ist das Log falschrum?)
Leider ist das List der Fernbedienung abgeschnitten. Kannst Du bitte nochmal das List des Buttons und der Fernbedienung (inklusive Attribute) anhängen?
Bitte wiederhole das Log nochmal mit folgender Änderung an 00_HMUARTLGW.pm:
Index: FHEM/00_HMUARTLGW.pm
--- FHEM/00_HMUARTLGW.pm
+++ FHEM/00_HMUARTLGW.pm
@@ -1423,6 +1423,8 @@
my ($hash, $fn, $msg) = @_;
my $name = $hash->{NAME};
+ Log3($hash, 5, "HMUARTLGW ${name} HMUARTLGW_Write: ${msg}");
if($msg =~ m/init:(......)/) {
my $dst = $1;
if ($modules{CUL_HM}{defptr}{$dst} &&
  Michael
automatisierer
#598
sorry, nicht drauf geachtet...
list Fernbedienung
   DEF        24C003
   HMLANingo1_MSGCNT 34
   HMLANingo1_RAWMSG E24C003,0000,00800A49,FF,FFB0,ABA64024C0033558670159
   HMLANingo1_RSSI -80
   HMLANingo1_TIME 2016-11-23 10:42:54
   HMLANingo2_MSGCNT 90
   HMLANingo2_RAWMSG E24C003,0040,0B141516,02,FFBE,ABA64024C0033558670159
   HMLANingo2_RSSI -66
   HMLANingo2_TIME 2016-11-23 10:42:54
   HMLGW_1_MSGCNT 58
   HMLGW_1_RAWMSG 0500005BABA00324C003355867102DCE56A063D497926A3C6F01E312C3
   HMLGW_1_RSSI -91
   HMLGW_1_TIME 2016-11-23 10:42:54
   IODev      HMLANingo2
   MSGCNT     182
   NAME       Flur_fs_Hand
   NOTIFYDEV  global
   NR         303
   TYPE       CUL_HM
   lastMsg    No:AB - t:40 s:24C003 d:355867 0159
   protEvt_AESCom-ok 22 last_at:2016-11-23 10:42:54
   protLastRcv 2016-11-23 10:42:54
   protSnd    76 last_at:2016-11-23 10:42:54
   protState  CMDs_done
   rssi_at_HMLANingo1 avg:-76.79 min:-89 max:-72 lst:-80 cnt:30
   rssi_at_HMLANingo2 avg:-64.96 min:-75 max:-62 lst:-66 cnt:26
   rssi_at_HMLGW_1 avg:-76.72 min:-91 max:-74 lst:-91 cnt:58
   Readings:
     2016-11-23 10:42:54   aesCommToDev    ok
     2016-11-23 10:42:54   aesReqTo        vccu
     2016-11-23 10:42:54   battery         ok
     2016-11-23 10:42:54   state           Flur_fs_Hand_Btn_01_unlock Short
   Helper:
     HM_CMDNR   171
     mId        00A6
     rxType     20
     Ack:
     Expert:
       def        1
       det        1
       raw        1
       tpl        1
     Io:
       nextSend   1479894174.75462
       rxt        2
       vccu       vccu
       p:
         24C003
         01
         02
         1E
       prefIO:
         HHMLANingo1
         HMLANingo2
     Mrssi:
       mNo        AB
       Io:
         HMLANingo1 -80
         HMLANingo2 -64
         HMLGW_1    -91
     Prt:
       bErr       0
       sProc      0
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       dev        1
     Rpt:
       IO         HMLANingo2
       flg        A
       ts         1479894174.59233
       ack:
         HASH(0x2992930)
         AB800235586724C00300
     Rssi:
       At_hmlaningo1:
         avg        -76.8
         cnt        30
         lst        -80
         max        -72
         min        -89
       At_hmlaningo2:
         avg        -64.9615384615385
         cnt        26
         lst        -66
         max        -62
         min        -75
       At_hmlgw_1:
         avg        -76.7241379310345
         cnt        58
         lst        -91
         max        -74
         min        -91
     Shadowreg:
     Tmpl:
   Role:
   IODev      HMLANingo1
   IOgrp      vccu:HHMLANingo1,HMLANingo2
   aesCommReq 1
   autoReadReg 0_off
   event-min-interval battery:3600
   event-on-update-reading battery
   expert     251_anything
   firmware   1.1
   model      HM-RC-Key4-2
   msgRepeat  1
   room       __Geraete
   serialNr   KEQ0855628
   subType    remote
   verbose    1
   webCmd     getConfig:clear msgEvents
edit:
log falschrum,hab ich mal so eingestellt, damit ich nicht immer bis zum ende scrollen muss wenn ich was snachgucken will...
automatisierer
hier die von den einzelnen Chanels:
   DEF        24C00301
   HMLANingo1_MSGCNT 1
   HMLANingo1_RAWMSG E24C003,0050,00575015,02,FFB8,87A64024C0033558670151
   HMLANingo1_RSSI -72
   HMLANingo1_TIME 2016-11-23 09:58:25
   HMLANingo2_MSGCNT 2
   HMLANingo2_RAWMSG E24C003,0050,0AFECB58,02,FFC2,90A64024C0033558670156
   HMLANingo2_RSSI -62
   HMLANingo2_TIME 2016-11-23 10:19:39
   MSGCNT     3
   NAME       Flur_fs_Hand_Btn_01_unlock
   NOTIFYDEV  global
   NR         305
   NTFY_ORDER 50-Flur_fs_Hand_Btn_01_unlock
   STATE      Short (to vccu)
   TYPE       CUL_HM
   chanNo     01
   device     Flur_fs_Hand
   peerList   vccu_Btn5,
   Readings:
     2016-10-20 21:06:25   R-dblPress      0 s
     2016-10-20 21:06:25   R-longPress     0.4 s
     2016-10-20 21:21:41   R-sign          on
     2016-10-20 21:30:37   R-vccu_Btn5-expectAES on
     2016-10-20 21:30:37   R-vccu_Btn5-peerNeedsBurst on
     2016-10-20 22:42:17   RegL_01.        04:10 08:01 09:00 00:00
     2016-10-20 22:42:21   RegL_04.vccu_Btn5 01:81 00:00
     2016-11-23 09:55:45   peerList        vccu_Btn5,
     2016-11-23 10:42:54   state           Short (to vccu)
     2016-11-23 10:42:54   trig_aes_vccu   ok:89
     2016-11-23 10:42:54   trigger         Short_89
     2016-11-23 10:42:54   trigger_cnt     89
   Helper:
     BNO        89
     BNOCNT     2
     Expert:
       def        1
       det        1
       raw        1
       tpl        1
     Role:
       chn        1
     Shadowreg:
     Tmpl:
   Role:
   aesCommReq 1
   model      HM-RC-Key4-2
   peerIDs    00000000,35586705,
   room       hidden
   verbose    1
   DEF        24C00302
   HMLANingo2_MSGCNT 3
   HMLANingo2_RAWMSG E24C003,0050,0B04E81B,02,FFB7,A8A64024C0033558670291
   HMLANingo2_RSSI -73
   HMLANingo2_TIME 2016-11-23 10:26:20
   MSGCNT     3
   NAME       Flur_fs_Hand_Btn_02_lock
   NOTIFYDEV  global
   NR         307
   NTFY_ORDER 50-Flur_fs_Hand_Btn_02_lock
   TYPE       CUL_HM
   chanNo     02
   device     Flur_fs_Hand
   peerList   vccu_Btn6,
   CHANGED:
     trig_aes_vccu: ok:145
   Readings:
     2016-05-27 22:21:20   R-dblPress      0 s
     2016-10-18 18:59:49   R-longPress     0.4 s
     2016-10-20 22:15:50   R-sign          on
     2016-10-20 22:15:54   R-vccu_Btn6-expectAES on
     2016-10-20 22:15:54   R-vccu_Btn6-peerNeedsBurst on
     2016-10-20 22:42:18   RegL_01.        04:10 08:01 09:00 00:00
     2016-10-20 22:42:21   RegL_04.vccu_Btn6 01:81 00:00
     2016-11-23 09:55:45   peerList        vccu_Btn6,
     2016-11-23 10:26:20   state           Short (to vccu)
     2016-08-19 15:53:27   trigDst_vccu    noConfig
     2016-11-23 10:26:21   trig_aes_vccu   ok:145
     2016-11-23 10:26:20   trigger         Short_145
     2016-11-23 10:26:20   trigger_cnt     145
   Helper:
     BNO        145
     BNOCNT     3
     Expert:
       def        1
       det        1
       raw        1
       tpl        1
     Role:
       chn        1
     Shadowreg:
     Tmpl:
   Role:
   aesCommReq 1
   model      HM-RC-Key4-2
   peerIDs    00000000,35586706,
   room       hidden
   DEF        24C00303
   NAME       Flur_fs_Hand_Btn_03_light
   NOTIFYDEV  global
   NR         309
   NTFY_ORDER 50-Flur_fs_Hand_Btn_03_light
   TYPE       CUL_HM
   chanNo     03
   device     Flur_fs_Hand
   peerList   vccu_Btn7,
   Readings:
     2016-05-27 22:21:21   R-dblPress      0 s
     2016-10-18 18:59:50   R-longPress     0.4 s
     2016-10-20 22:33:15   R-sign          on
     2016-10-20 22:33:17   R-vccu_Btn7-expectAES on
     2016-10-20 22:33:17   R-vccu_Btn7-peerNeedsBurst on
     2016-10-20 22:42:19   RegL_01.        04:10 08:01 09:00 00:00
     2016-10-20 22:42:22   RegL_04.vccu_Btn7 01:81 00:00
     2016-11-23 09:55:45   peerList        vccu_Btn7,
     2016-10-21 20:00:01   state           Short (to vccu)
     2016-08-19 15:53:56   trigDst_vccu    noConfig
     2016-10-21 20:00:01   trig_aes_vccu   ok:17
     2016-10-21 20:00:01   trigger         Short_17
     2016-10-21 20:00:01   trigger_cnt     17
   Helper:
     Expert:
       def        1
       det        1
       raw        1
       tpl        1
     Role:
       chn        1
     Shadowreg:
     Tmpl:
   Role:
   aesCommReq 1
   model      HM-RC-Key4-2
   peerIDs    00000000,35586707,
   room       hidden
   DEF        24C00304
   NAME       Flur_fs_Hand_Btn_04_open
   NOTIFYDEV  global
   NR         311
   NTFY_ORDER 50-Flur_fs_Hand_Btn_04_open
   STATE      LongRelease 2_9 (to vccu)
   TYPE       CUL_HM
   chanNo     04
   device     Flur_fs_Hand
   peerList   vccu_Btn8,
   Readings:
     2016-05-27 22:21:22   R-dblPress      0 s
     2016-10-18 18:59:51   R-longPress     0.4 s
     2016-10-20 22:40:52   R-sign          on
     2016-10-20 22:42:22   R-vccu_Btn8-expectAES on
     2016-10-20 22:42:22   R-vccu_Btn8-peerNeedsBurst on
     2016-10-20 22:42:20   RegL_01.        04:10 08:01 09:00 00:00
     2016-10-20 22:42:22   RegL_04.vccu_Btn8 01:81 00:00
     2016-11-23 09:55:45   peerList        vccu_Btn8,
     2016-11-23 10:25:35   state           LongRelease 2_9 (to vccu)
     2016-11-23 10:25:35   trig_aes_vccu   ok:9
     2016-11-23 10:25:35   trigger         Long_9
     2016-11-23 10:25:35   trigger_cnt     9
   Helper:
     BNO        9
     BNOCNT     2
     Expert:
       def        1
       det        1
       raw        1
       tpl        1
     Role:
       chn        1
     Shadowreg:
     Tmpl:
   Role:
   aesCommReq 1
   model      HM-RC-Key4-2
   peerIDs    00000000,35586708,
   room       hidden
log folgt...
