FHEM mit configDB startet nach Neuinstallation nicht - Diverse Probleme
Begonnen von Spezialtrick, 15 Juni 2016, 12:07:34
papa
Spezialtrick
Meinst du das Fhem Logfile? Da wimmelt es von Fehlern:
2016.06.18 14:05:22 1: PERL WARNING: Subroutine Utils_Initialize redefined at ./FHEM/99_myUtils.pm line 11.
2016.06.18 14:05:22 1: PERL WARNING: Subroutine time_str2num redefined at ./FHEM/99_myUtils.pm line 17.
2016.06.18 14:05:22 1: PERL WARNING: Subroutine min redefined at ./FHEM/99_myUtils.pm line 31.
2016.06.18 14:05:22 1: PERL WARNING: Subroutine max redefined at ./FHEM/99_myUtils.pm line 41.
2016.06.18 14:05:22 1: PERL WARNING: Subroutine minNum redefined at ./FHEM/99_myUtils.pm line 51.
2016.06.18 14:05:22 1: PERL WARNING: Subroutine maxNum redefined at ./FHEM/99_myUtils.pm line 61.
2016.06.18 14:05:22 1: PERL WARNING: Subroutine abstime2rel redefined at ./FHEM/99_myUtils.pm line 72.
2016.06.18 14:05:22 1: PERL WARNING: Subroutine defInfo redefined at ./FHEM/99_myUtils.pm line 88.
2016.06.18 14:05:22 1: PERL WARNING: Subroutine SVG_time_to_sec redefined at ./FHEM/99_myUtils.pm line 103.
2016.06.18 14:05:22 1: PERL WARNING: Subroutine trim redefined at ./FHEM/99_myUtils.pm line 129.
2016.06.18 14:05:22 1: PERL WARNING: Subroutine ltrim redefined at ./FHEM/99_myUtils.pm line 142.
2016.06.18 14:05:22 1: PERL WARNING: Subroutine rtrim redefined at ./FHEM/99_myUtils.pm line 154.
2016.06.18 14:05:22 1: PERL WARNING: Subroutine UntoggleDirect redefined at ./FHEM/99_myUtils.pm line 166.
2016.06.18 14:05:22 1: PERL WARNING: Subroutine UntoggleIndirect redefined at ./FHEM/99_myUtils.pm line 189.
2016.06.18 14:05:22 1: PERL WARNING: Subroutine IsInt redefined at ./FHEM/99_myUtils.pm line 216.
2016.06.18 14:05:22 1: PERL WARNING: Subroutine fhemNc redefined at ./FHEM/99_myUtils.pm line 223.
2016.06.18 14:05:22 1: PERL WARNING: Subroutine round redefined at ./FHEM/99_myUtils.pm line 242.
2016.06.18 14:05:22 2: Perfmon: ready to watch out for delays greater than one second
2016.06.18 14:05:23 1: PERL WARNING: Subroutine myUtils_Initialize redefined at ./FHEM/99_WifiLED_Utils.pm line 15.
2016.06.18 14:05:23 1: PERL WARNING: Subroutine wakeUp redefined at ./FHEM/99_WifiLED_Utils.pm line 25.
2016.06.18 14:05:23 3: telnetPort: port 7072 opened
2016.06.18 14:05:23 3: WEB: port 8083 opened
2016.06.18 14:05:23 3: WEBphone: port 8084 opened
2016.06.18 14:05:23 3: WEBtablet: port 8085 opened
2016.06.18 14:05:23 2: eventTypes: loaded 1889 events from ./log/eventTypes.txt
2016.06.18 14:05:24 3: Opening nanoCUL868 device /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A4035XBY-if00-port0
2016.06.18 14:05:24 3: Can't open /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A4035XBY-if00-port0: No such file or directory
2016.06.18 14:05:24 2: Switched nanoCUL868 rfmode to MAX
2016.06.18 14:05:24 1: CUL_MAX_Check: No IODev has no VERSION
2016.06.18 14:05:24 3: CUL_MAX_Check: Detected firmware version 0 of the CUL-compatible IODev
2016.06.18 14:05:25 3: additional HM config file loaded: ./FHEM/HMConfig_SenTHPL.pm
2016.06.18 14:05:25 3: vccu: unknown IODev hmusb specified
2016.06.18 14:05:25 3: Opening nanoCUL433 device /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A4035XGY-if00-port0
2016.06.18 14:05:25 3: Can't open /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A4035XGY-if00-port0: No such file or directory
2016.06.18 14:05:26 1: reload: Error:Modul 37_harmony deactivated:
Can't locate JSON.pm in @INC (you may need to install the JSON module) (@INC contains: /etc/perl /usr/local/lib/arm-linux-gnueabihf/perl/5.20.2 /usr/local/share/perl/5.20.2 /usr/lib/arm-linux-gnueabihf/perl5/5.20 /usr/share/perl5 /usr/lib/arm-linux-gnueabihf/perl/5.20 /usr/share/perl/5.20 /usr/local/lib/site_perl . ./FHEM) at ./FHEM/37_harmony.pm line 11.
BEGIN failed--compilation aborted at ./FHEM/37_harmony.pm line 11.
2016.06.18 14:05:26 0: Can't locate JSON.pm in @INC (you may need to install the JSON module) (@INC contains: /etc/perl /usr/local/lib/arm-linux-gnueabihf/perl/5.20.2 /usr/local/share/perl/5.20.2 /usr/lib/arm-linux-gnueabihf/perl5/5.20 /usr/share/perl5 /usr/lib/arm-linux-gnueabihf/perl/5.20 /usr/share/perl/5.20 /usr/local/lib/site_perl . ./FHEM) at ./FHEM/37_harmony.pm line 11.
2016.06.18 14:05:27 1: reload: Error:Modul 70_Fhemapppush deactivated:
Can't locate JSON.pm in @INC (you may need to install the JSON module) (@INC contains: /etc/perl /usr/local/lib/arm-linux-gnueabihf/perl/5.20.2 /usr/local/share/perl/5.20.2 /usr/lib/arm-linux-gnueabihf/perl5/5.20 /usr/share/perl5 /usr/lib/arm-linux-gnueabihf/perl/5.20 /usr/share/perl/5.20 /usr/local/lib/site_perl . ./FHEM) at ./FHEM/70_Fhemapppush.pm line 17.
BEGIN failed--compilation aborted at ./FHEM/70_Fhemapppush.pm line 17.
2016.06.18 14:05:27 0: Can't locate JSON.pm in @INC (you may need to install the JSON module) (@INC contains: /etc/perl /usr/local/lib/arm-linux-gnueabihf/perl/5.20.2 /usr/local/share/perl/5.20.2 /usr/lib/arm-linux-gnueabihf/perl5/5.20 /usr/share/perl5 /usr/lib/arm-linux-gnueabihf/perl/5.20 /usr/share/perl/5.20 /usr/local/lib/site_perl . ./FHEM) at ./FHEM/70_Fhemapppush.pm line 17.
2016.06.18 14:05:27 3: LCD_I2C_Cubie: file /dev/i2c-1 not accessible try to use gpio utility to fix it
2016.06.18 14:05:27 1: LCD_I2C_Cubie: file /usr/local/bin/gpio doesnt exist
2016.06.18 14:05:27 1: define LCD_I2C_Cubie RPII2C 1: LCD_I2C_Cubie: Error! I2C device not readable: /dev/i2c-1. Please install wiringpi or change access rights for fhem user
2016.06.18 14:05:27 3: LCD_I2C: unknown IODev LCD_I2C_Cubie specified
2016.06.18 14:05:27 3: DLCD LCD has been defined
2016.06.18 14:05:32 3: DLCD LCD: Line1 (22) is longer than display (20), ignoring some data
2016.06.18 14:05:32 3: DLCD LCD: Line1: attr dlcdLine1 %time1%
2016.06.18 14:05:32 3: DLCD LCD: Line2 (22) is longer than display (20), ignoring some data
2016.06.18 14:05:32 3: DLCD LCD: Line2: attr dlcdLine2 %time1%
2016.06.18 14:05:32 3: DLCD LCD: Line3 (22) is longer than display (20), ignoring some data
2016.06.18 14:05:32 3: DLCD LCD: Line3: attr dlcdLine3 %time1%
2016.06.18 14:05:32 3: DLCD LCD: Line4 (22) is longer than display (20), ignoring some data
2016.06.18 14:05:32 3: DLCD LCD: Line4: attr dlcdLine4 %time1%
2016.06.18 14:05:32 3: DLCD LCD: Line1 (24) is longer than display (20), ignoring some data
2016.06.18 14:05:32 3: DLCD LCD: Line1: attr dlcdVal1 unreadable
2016.06.18 14:05:32 3: DLCD LCD: Line2 (24) is longer than display (20), ignoring some data
2016.06.18 14:05:32 3: DLCD LCD: Line2: attr dlcdVal5 unreadable
2016.06.18 14:05:32 3: DLCD LCD: Line3 (24) is longer than display (20), ignoring some data
2016.06.18 14:05:32 3: DLCD LCD: Line3: attr dlcdVal4 unreadable
2016.06.18 14:05:32 3: DLCD LCD: Line4 (24) is longer than display (20), ignoring some data
2016.06.18 14:05:32 3: DLCD LCD: Line4: attr dlcdVal3 unreadable
2016.06.18 14:05:32 1: PERL WARNING: Useless use of numeric eq (==) in void context at ./FHEM/74_StreamRadio.pm line 112.
sudo: smartctl: command not found
2016.06.18 14:05:33 3: Opening nanoCUL868hm device /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A600CZUB-if00-port0
2016.06.18 14:05:33 3: Can't open /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A600CZUB-if00-port0: No such file or directory
2016.06.18 14:05:33 2: Switched nanoCUL868hm rfmode to HomeMatic
2016.06.18 14:05:34 1: reload: Error:Modul 37_harmony deactivated:
Can't locate JSON.pm in @INC (you may need to install the JSON module) (@INC contains: /etc/perl /usr/local/lib/arm-linux-gnueabihf/perl/5.20.2 /usr/local/share/perl/5.20.2 /usr/lib/arm-linux-gnueabihf/perl5/5.20 /usr/share/perl5 /usr/lib/arm-linux-gnueabihf/perl/5.20 /usr/share/perl/5.20 /usr/local/lib/site_perl . ./FHEM ./FHEM/lib) at ./FHEM/37_harmony.pm line 11.
2016.06.18 14:05:34 0: Can't locate JSON.pm in @INC (you may need to install the JSON module) (@INC contains: /etc/perl /usr/local/lib/arm-linux-gnueabihf/perl/5.20.2 /usr/local/share/perl/5.20.2 /usr/lib/arm-linux-gnueabihf/perl5/5.20 /usr/share/perl5 /usr/lib/arm-linux-gnueabihf/perl/5.20 /usr/share/perl/5.20 /usr/local/lib/site_perl . ./FHEM ./FHEM/lib) at ./FHEM/37_harmony.pm line 11.
2016.06.18 14:05:34 1: reload: Error:Modul 00_SONOS deactivated:
Can't locate HTTP/Daemon.pm in @INC (you may need to install the HTTP::Daemon module) (@INC contains: fhem.p/lib fhem.p/FHEM/lib ./FHEM/lib ./lib ./FHEM ./ /usr/local/FHEM/share/fhem/FHEM/lib /etc/perl /usr/local/lib/arm-linux-gnueabihf/perl/5.20.2 /usr/local/share/perl/5.20.2 /usr/lib/arm-linux-gnueabihf/perl5/5.20 /usr/share/perl5 /usr/lib/arm-linux-gnueabihf/perl/5.20 /usr/share/perl/5.20 /usr/local/lib/site_perl .) at FHEM/lib/UPnP/ControlPoint.pm line 35.
BEGIN failed--compilation aborted at FHEM/lib/UPnP/ControlPoint.pm line 35.
Compilation failed in require at ./FHEM/00_SONOS.pm line 179.
BEGIN failed--compilation aborted at ./FHEM/00_SONOS.pm line 179.
2016.06.18 14:05:34 0: Can't locate HTTP/Daemon.pm in @INC (you may need to install the HTTP::Daemon module) (@INC contains: fhem.p/lib fhem.p/FHEM/lib ./FHEM/lib ./lib ./FHEM ./ /usr/local/FHEM/share/fhem/FHEM/lib /etc/perl /usr/local/lib/arm-linux-gnueabihf/perl/5.20.2 /usr/local/share/perl/5.20.2 /usr/lib/arm-linux-gnueabihf/perl5/5.20 /usr/share/perl5 /usr/lib/arm-linux-gnueabihf/perl/5.20 /usr/share/perl/5.20 /usr/local/lib/site_perl .) at FHEM/lib/UPnP/ControlPoint.pm line 35.
2016.06.18 14:05:34 3: WifiLight: requested bridge bridge-V3 at 192.187.188.30 already in use by Farbkugel, copy llCmdQueue
2016.06.18 14:05:34 1: HMLAN_Parse: hmusb new condition disconnected
2016.06.18 14:05:34 3: Opening hmusb device 127.0.0.1:1234
2016.06.18 14:05:34 3: hmusb device opened
2016.06.18 14:05:34 1: HMLAN_Parse: hmusb new condition init
Undefined subroutine &main::SONOS_getDeviceDefHash called at ./FHEM/21_SONOSPLAYER.pm line 227.
FHEM - Debmatic - Zigbee2MQTT - Homekit
papa
Na da haben wir ja nen ganzen Schwung von Fehlern:
Der nanCUL868 ist nicht auffindbar.
Fehlendes Perlmodul JSON.pm nachinstallieren#
Da fehlt das Display oder der Treiber für i2c.
Bitte nachinstallieren
Der nanoCUL868hm fehlt auch. Kann es sein, dass sich da was Grundlegendes im Linuxsystem geändert hat ?
Da fehlt noch ein Perl Modul
Und dann bleibt alles am Ende stehen, weil das SONOS Modul nicht geladen wurde und nun ne Funktion fehlt.
Da musst Du aber noch ordentlich nachinstallieren. Sieh auch mla nach, was aus den Serial-Devices geworden ist.
Spezialtrick
Hallo Holger!
Vielen Dank für die ausführliche Hilfe. :) Nachdem ich einiges nachinstalliert habe, springt mein Fhem wieder an.  :)
Das Log sieht nun so aus:
2016.06.18 16:40:47 1: PERL WARNING: Subroutine Utils_Initialize redefined at ./FHEM/99_myUtils.pm line 11.
2016.06.18 16:40:47 1: PERL WARNING: Subroutine time_str2num redefined at ./FHEM/99_myUtils.pm line 17.
2016.06.18 16:40:47 1: PERL WARNING: Subroutine min redefined at ./FHEM/99_myUtils.pm line 31.
2016.06.18 16:40:47 1: PERL WARNING: Subroutine max redefined at ./FHEM/99_myUtils.pm line 41.
2016.06.18 16:40:47 1: PERL WARNING: Subroutine minNum redefined at ./FHEM/99_myUtils.pm line 51.
2016.06.18 16:40:47 1: PERL WARNING: Subroutine maxNum redefined at ./FHEM/99_myUtils.pm line 61.
2016.06.18 16:40:47 1: PERL WARNING: Subroutine abstime2rel redefined at ./FHEM/99_myUtils.pm line 72.
2016.06.18 16:40:47 1: PERL WARNING: Subroutine defInfo redefined at ./FHEM/99_myUtils.pm line 88.
2016.06.18 16:40:47 1: PERL WARNING: Subroutine SVG_time_to_sec redefined at ./FHEM/99_myUtils.pm line 103.
2016.06.18 16:40:47 1: PERL WARNING: Subroutine trim redefined at ./FHEM/99_myUtils.pm line 129.
2016.06.18 16:40:47 1: PERL WARNING: Subroutine ltrim redefined at ./FHEM/99_myUtils.pm line 142.
2016.06.18 16:40:47 1: PERL WARNING: Subroutine rtrim redefined at ./FHEM/99_myUtils.pm line 154.
2016.06.18 16:40:47 1: PERL WARNING: Subroutine UntoggleDirect redefined at ./FHEM/99_myUtils.pm line 166.
2016.06.18 16:40:47 1: PERL WARNING: Subroutine UntoggleIndirect redefined at ./FHEM/99_myUtils.pm line 189.
2016.06.18 16:40:47 1: PERL WARNING: Subroutine IsInt redefined at ./FHEM/99_myUtils.pm line 216.
2016.06.18 16:40:47 1: PERL WARNING: Subroutine fhemNc redefined at ./FHEM/99_myUtils.pm line 223.
2016.06.18 16:40:47 1: PERL WARNING: Subroutine round redefined at ./FHEM/99_myUtils.pm line 242.
2016.06.18 16:40:47 2: Perfmon: ready to watch out for delays greater than one second
2016.06.18 16:40:48 1: PERL WARNING: Subroutine myUtils_Initialize redefined at ./FHEM/99_WifiLED_Utils.pm line 15.
2016.06.18 16:40:48 1: PERL WARNING: Subroutine wakeUp redefined at ./FHEM/99_WifiLED_Utils.pm line 25.
2016.06.18 16:40:48 3: telnetPort: port 7072 opened
2016.06.18 16:40:48 3: WEB: port 8083 opened
2016.06.18 16:40:48 3: WEBphone: port 8084 opened
2016.06.18 16:40:48 3: WEBtablet: port 8085 opened
2016.06.18 16:40:49 2: eventTypes: loaded 1933 events from ./log/eventTypes.txt
2016.06.18 16:40:49 3: Opening nanoCUL868 device /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A4035XBY-if00-port0
2016.06.18 16:40:49 3: Can't open /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A4035XBY-if00-port0: No such file or directory
2016.06.18 16:40:49 2: Switched nanoCUL868 rfmode to MAX
2016.06.18 16:40:49 1: CUL_MAX_Check: No IODev has no VERSION
2016.06.18 16:40:49 3: CUL_MAX_Check: Detected firmware version 0 of the CUL-compatible IODev
2016.06.18 16:40:50 3: additional HM config file loaded: ./FHEM/HMConfig_SenTHPL.pm
2016.06.18 16:40:50 3: vccu: unknown IODev hmusb specified
2016.06.18 16:40:51 3: Opening nanoCUL433 device /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A4035XGY-if00-port0
2016.06.18 16:40:51 3: Can't open /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A4035XGY-if00-port0: No such file or directory
2016.06.18 16:40:53 3: DLCD LCD has been defined
2016.06.18 16:40:58 3: DLCD LCD: Line1 (22) is longer than display (20), ignoring some data
2016.06.18 16:40:58 3: DLCD LCD: Line1: attr dlcdLine1 %time1%
2016.06.18 16:40:58 3: DLCD LCD: Line2 (22) is longer than display (20), ignoring some data
2016.06.18 16:40:58 3: DLCD LCD: Line2: attr dlcdLine2 %time1%
2016.06.18 16:40:58 3: DLCD LCD: Line3 (22) is longer than display (20), ignoring some data
2016.06.18 16:40:58 3: DLCD LCD: Line3: attr dlcdLine3 %time1%
2016.06.18 16:40:58 3: DLCD LCD: Line4 (22) is longer than display (20), ignoring some data
2016.06.18 16:40:58 3: DLCD LCD: Line4: attr dlcdLine4 %time1%
2016.06.18 16:40:58 3: DLCD LCD: Line1 (24) is longer than display (20), ignoring some data
2016.06.18 16:40:58 3: DLCD LCD: Line1: attr dlcdVal1 unreadable
2016.06.18 16:40:58 3: DLCD LCD: Line2 (24) is longer than display (20), ignoring some data
2016.06.18 16:40:58 3: DLCD LCD: Line2: attr dlcdVal5 unreadable
2016.06.18 16:40:58 3: DLCD LCD: Line3 (24) is longer than display (20), ignoring some data
2016.06.18 16:40:58 3: DLCD LCD: Line3: attr dlcdVal4 unreadable
2016.06.18 16:40:58 3: DLCD LCD: Line4 (24) is longer than display (20), ignoring some data
2016.06.18 16:40:58 3: DLCD LCD: Line4: attr dlcdVal3 unreadable
2016.06.18 16:40:58 1: PERL WARNING: Useless use of numeric eq (==) in void context at ./FHEM/74_StreamRadio.pm line 112.
2016.06.18 16:40:59 3: Opening nanoCUL868hm device /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A600CZUB-if00-port0
2016.06.18 16:40:59 3: Can't open /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A600CZUB-if00-port0: No such file or directory
2016.06.18 16:40:59 2: Switched nanoCUL868hm rfmode to HomeMatic
Current: "fhem.pl", gPath: "./FHEM"
2016.06.18 16:41:01 3: WifiLight: requested bridge bridge-V3 at 192.187.188.30 already in use by Farbkugel, copy llCmdQueue
2016.06.18 16:41:01 1: HMLAN_Parse: hmusb new condition disconnected
2016.06.18 16:41:01 3: Opening hmusb device 127.0.0.1:1234
2016.06.18 16:41:01 3: hmusb device opened
2016.06.18 16:41:01 1: HMLAN_Parse: hmusb new condition init
2016.06.18 16:41:02 1: configDB: vccu: unknown IODev hmusb specified
2016.06.18 16:41:02 3: No I/O device found for UM.Klimasensor
2016.06.18 16:41:02 3: No I/O device found for WZ.Klimasensor
2016.06.18 16:41:02 3: No I/O device found for vccu
2016.06.18 16:41:02 3: Device FL.Klimasensor.Aussen added to ActionDetector with 000:10 time
2016.06.18 16:41:02 3: Device FL.Klimasensor.Innen added to ActionDetector with 000:10 time
2016.06.18 16:41:02 3: Device HM_AFBC10 added to ActionDetector with 000:10 time
2016.06.18 16:41:03 3: Device HM_AFBC11 added to ActionDetector with 000:10 time
2016.06.18 16:41:03 3: Device SZ.Klimasensor added to ActionDetector with 000:10 time
2016.06.18 16:41:03 3: Device UM.Klimasensor added to ActionDetector with 000:10 time
2016.06.18 16:41:03 3: Device WZ.Klimasensor added to ActionDetector with 000:10 time
2016.06.18 16:41:03 3: HarmonyHub: connected
2016.06.18 16:41:03 3: DLCD LCD initialized
2016.06.18 16:41:03 3: DLCD LCD: Line1 (21) is longer than display (20), ignoring some data
2016.06.18 16:41:03 3: DLCD LCD: Line1: 16:41  AC  CPU: 63.40
2016.06.18 16:41:03 3: Opening MySensors device /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A603V98P-if00-port0
2016.06.18 16:41:03 3: Can't open /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A603V98P-if00-port0: No such file or directory
2016.06.18 16:41:03 3: Opening MySensorsWIFI device 192.187.188.43:5003
2016.06.18 16:41:06 3: Can't connect to 192.187.188.43:5003: No route to host
2016.06.18 16:41:06 1: usb create starting
2016.06.18 16:41:07 1: usb create end
2016.06.18 16:41:07 2: Messages collected while initializing FHEM: configDB: vccu: unknown IODev hmusb specified
2016.06.18 16:41:07 0: Featurelevel: 5.7
2016.06.18 16:41:07 0: Server started with 230 defined entities (fhem.pl:11545/2016-05-29 perl:5.020002 os:linux user:fhem pid:849)
2016.06.18 16:41:07 1: Perfmon: possible freeze starting at 16:40:48, delay is 19.588
2016.06.18 16:41:07 3: telnetForBlockingFn_1466260867: port 38901 opened
2016.06.18 16:41:08 3: CUL_HM set HM_0A0101 statusRequest
2016.06.18 16:41:08 1: SONOS0: Kein UPnP-Server gefunden... Starte selber einen und warte 1 Sekunde(n) darauf...
2016.06.18 16:41:10 3: CUL_HM set FL.Klimasensor.Innen statusRequest
2016.06.18 16:41:10 3: CUL_HM set FL.Klimasensor.Innen getConfig
2016.06.18 16:41:10 1: HMLAN_Parse: hmusb new condition ok
2016.06.18 16:41:10 1: Perfmon: possible freeze starting at 16:41:08, delay is 2.463
2016.06.18 16:41:10 3: CUL_HM set HM_0A0302_Sw_01 statusRequest
2016.06.18 16:41:10 3: Opening Sonos device localhost:4711
2016.06.18 16:41:10 3: Can't connect to localhost:4711: Connection refused
2016.06.18 16:41:11 2: IT set Wz.Drucker on
2016.06.18 16:41:11 2: IT IODev device didn't answer is command correctly:   raw => No answer
Current: "./FHEM/00_SONOS.pm", gPath: ""
2016.06.18 16:41:11 1: SONOS0: ./FHEM/00_SONOS.pm is listening to Port 4711
2016.06.18 16:41:11 3: CUL_HM set HM_0A0302_Sw_02 statusRequest
2016.06.18 16:41:12 3: HarmonyHub: new config
2016.06.18 16:41:20 3: CUL_HM set FL.Klimasensor.Aussen statusRequest
2016.06.18 16:41:20 3: CUL_HM set FL.Klimasensor.Aussen getConfig
2016.06.18 16:41:28 1: PERL WARNING: Use of uninitialized value in hash element at ./FHEM/10_CUL_HM.pm line 2767.
2016.06.18 16:41:28 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/10_CUL_HM.pm line 2767.
2016.06.18 16:41:31 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4518.
2016.06.18 16:41:41 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4518.
2016.06.18 16:41:43 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4518.
Sämtliche USB-Geräte wie CULs funktionieren erst, nach einer Neuverbindung.
Zudem ändert sich immer wieder Besitzer der fhem-2016-06.log Datei zu root:
root@cubietruck:/opt/fhem/log# ls -l
total 64
-rw-rw-rw- 1 fhem dialout     0 Jun 18 16:34 -2016.log
-rw-rw-rw- 1 fhem dialout     0 Jun 18 16:34 BZ.Fenster-2016.log
-rw-rw-rw- 1 root root    18047 Jun 18 16:41 fhem-2016-06.log
-rw-r--r-- 1 fhem dialout     0 Jun 18 16:44 fhem.heartbeat
Lässt sich das dauerhaft auf fhem:dialout ändern?
die "redefined" Meldungen sind an sich kein Fehler, trotzdem solltest Du herausfinden, das so ist.
Auffallend ist, dass da viele Funktionen in der 99_myUtils.pm neu definiert werden, die normalerweise in der 99_Utils.pm vorhanden sind.
Dass das Logfile root gehört, liegt vermutlich daran, dass Du Dein fhem manuell als root von der Konsole startest. Wenn fhem über das Startskript beim Booten gestartet wird, sollte auch die Logdatei von fhem angelegt werden und nicht von root. Vorausgesetzt, Du hast den Benutzer fhem korrekt angelegt.
Spezialtrick
Tatsache. Nach einem Löschen des Logs mit anschließendem Reboot wird alles korrekt als fhem:dialout angelegt.
Zitatdie "redefined" Meldungen sind an sich kein Fehler, trotzdem solltest Du herausfinden, das so ist.
Liegt das möglicherweise daran, das ich komischerweise keine 99_Utils.pm habe? (Fotoanhang)
Kannst du dir erklären, warum ich die Gateways einmal trennen und wieder anstecken muss, damit Fhem sie erkennt? Im System unter /dev/serial tauchen sie auch erst nach dem manuellen Neuverbunden auf.
Nur weil die Datei in dieser Liste nicht angezeigt wird, heißt das noch lange nicht, dass die Datei bei Dir nicht vorhanden ist. Schau mal in s Dateisystem nach
ls -al /opt/fhem/FHEM/99_Utils.pm
Und verwechsle bitte 99_Utils.pm nicht mit 99_myUtils.pm!
Spezialtrick
Du hast Recht. Die Datei ist da:
root@cubietruck:/# ls -al /opt/fhem/FHEM/99_Utils.pm
-rw-rw-rw- 1 fhem dialout 9212 Jun 18 15:40 /opt/fhem/FHEM/99_Utils.pm
Und hat folgenden Inhalt:
# $Id: 99_Utils.pm 10570 2016-01-19 06:39:23Z rudolfkoenig $
package main;
use strict;
use warnings;
use POSIX;
sub
Utils_Initialize($$)
  my ($hash) = @_;
sub
time_str2num($)
  my ($str) = @_;
  my @a;
  if($str) {
    @a = split("[T: -]", $str);
    return mktime($a[5],$a[4],$a[3],$a[2],$a[1]-1,$a[0]-1900,0,0,-1);
  } else {
    my ($sec,$min,$hour,$mday,$mon,$year,$wday,$yday,$isdst) = localtime(time);
    return mktime($sec, $min, $hour, $mday, $mon, $year, 0, 0, -1);
sub
min($@)
  my ($min, @vars) = @_;
  for (@vars) {
    $min = $_ if $_ lt $min;
  return $min;
sub
max($@)
  my ($max, @vars) = @_;
  for (@vars) {
    $max = $_ if $_ gt $max;
  return $max;
sub
minNum($@)
  for (@vars) {
    $min = $_ if $_ < $min;
  return $min;
sub
maxNum($@)
  for (@vars) {
    $max = $_ if $_ > $max;
  return $max;
sub
abstime2rel($)
  my ($h,$m,$s) = split(":", shift);
  $m = 0 if(!$m);
  $s = 0 if(!$s);
  my $t1 = 3600*$h+60*$m+$s;
  my @now = localtime;
  my $t2 = 3600*$now[2]+60*$now[1]+$now[0];
  my $diff = $t1-$t2;
  $diff += 86400 if($diff <= 0);
  return sprintf("%02d:%02d:%02d", $diff/3600, ($diff/60)%60, $diff%60);
sub
defInfo($;$)
  my ($search,$internal) = @_;
  $internal = 'DEF' unless defined($internal);
  my @ret;
  my @etDev = devspec2array($search);
  foreach my $d (@etDev) {
    next unless $d;
    push @ret, $defs{$d}{$internal};
  return @ret;
my ($SVG_lt, $SVG_ltstr);
sub
SVG_time_to_sec($)
  my ($str) = @_;
  if(!$str) {
    return 0;
  my ($y,$m,$d,$h,$mi,$s) = split("[-_:]", $str);
  $s = 0 if(!$s);
  $mi= 0 if(!$mi);
  $h = 0 if(!$h);
  $d = 1 if(!$d);
  $m = 1 if(!$m);
  if(!$SVG_ltstr || $SVG_ltstr ne "$y-$m-$d-$h") { # 2.5x faster
    $SVG_lt = mktime(0,0,$h,$d,$m-1,$y-1900,0,0,-1);
    $SVG_ltstr = "$y-$m-$d-$h";
  return $s+$mi*60+$SVG_lt;
######## trim #####################################################
# What  : cuts blankspaces from the beginning and end of a string
# Call  : { trim(" Hello ") }
# Source: http://www.somacon.com/p114.php ,
#         http://www.fhemwiki.de/wiki/TRIM-Funktion-Anfangs/EndLeerzeichen_aus_Strings_entfernen
sub trim($)
   my $string = shift;
   $string =~ s/^\s+//;
   $string =~ s/\s+$//;
   return $string;
######## ltrim ####################################################
# What  : cuts blankspaces from the beginning of a string
# Call  : { ltrim(" Hello") }
#         http://www.fhemwiki.de/wiki/TRIM-Funktion-Anfangs/EndLeerzeichen_aus_Strings_entfernensub ltrim($)
sub ltrim($)
   my $string = shift;
   return $string;
######## rtrim ####################################################
# What  : cuts blankspaces from the end of a string
# Call  : { rtrim("Hello ") }
sub rtrim($)
   my $string = shift;
   return $string;
######## UntoggleDirect ###########################################
# What  : For devices paired directly, converts state 'toggle' into 'on' or 'off'
# Call  : { UntoggleDirect("myDevice") }
#         define untoggle_myDevice notify myDevice { UntoggleDirect("myDevice") }
# Source: http://www.fhemwiki.de/wiki/FS20_Toggle_Events_auf_On/Off_umsetzen
sub UntoggleDirect($)
my ($obj) = shift;
Log 4, "UntoggleDirect($obj)";
if (Value($obj) eq "toggle"){
   if (OldValue($obj) eq "off") {
     {fhem ("setstate ".$obj." on")}
   else {
     {fhem ("setstate ".$obj." off")}
else {
   {fhem "setstate ".$obj." ".Value($obj)}
######## UntoggleIndirect #########################################
# What  : For devices paired indirectly, switches the target device 'on' or 'off' also when a 'toggle' was sent from the source device
# Call  : { UntoggleIndirect("mySensorDevice","myActorDevice","50%") }
#         define untoggle_mySensorDevice_myActorDevice notify mySensorDevice { UntoggleIndirect("mySensorDevice","myActorDevice","50%%") }
sub UntoggleIndirect($$$)
  my ($sender, $actor, $dimvalue) = @_;
  Log 4, "UntoggleIndirect($sender, $actor, $dimvalue)";
  if (Value($sender) eq "toggle")
    if (Value($actor) eq "off") {fhem ("set ".$actor." on")}
    else {fhem ("set ".$actor." off")}
  ## workaround for dimming currently not working with indirect pairing
  ## (http://culfw.de/commandref.html: "TODO/Known BUGS - FS20 dim commands should not repeat.")
  elsif (Value($sender) eq "dimup") {fhem ("set ".$actor." dim100%")}
  elsif (Value($sender) eq "dimdown") {fhem ("set ".$actor." ".$dimvalue)}
  elsif (Value($sender) eq "dimupdown")
    if (Value($actor) eq $dimvalue) {fhem ("set ".$actor." dim100%")}
       ## Heuristic above doesn't work if lamp was dimmed, then switched off, then switched on, because state is "on", but the lamp is actually dimmed.
    else {fhem ("set ".$actor." ".$dimvalue)}
    sleep 1;
  ## end of workaround
  else {fhem ("set ".$actor." ".Value($sender))}
  return;
sub
IsInt($)
  defined $_[0] && $_[0] =~ /^[+-]?\d+$/;
# Small NC replacement: fhemNc("ip:port", "text", waitForReturn);
sub
fhemNc($$$)
  my ($addr, $txt, $waitForReturn) = @_;
  my $client = IO::Socket::INET->new(PeerAddr => $addr);
  return "Can't connect to $addr\n" if(!$client);
  syswrite($client, $txt);
  return "" if(!$waitForReturn);
  my ($ret, $buf) = ("", "");
  shutdown($client, 1);
  alarm(5);
  while(sysread($client, $buf, 256) > 0) {
    $ret .= $buf;
  alarm(0);
  close($client);
  return $ret;
sub
round($$)
  my($v,$n) = @_;
  return sprintf("%.${n}f",$v);
1;
=pod
=item helper
=begin html
<a name="Utils"></a>
<h3>Utils</h3>
<ul>
  This is a collection of functions that can be used module-independant
  in all your own development<br/>
  </br>
  <b>Defined functions</b><br/><br/>
  <ul>
    <li><b>abstime2rel("HH:MM:SS")</b><br>tells you the difference as HH:MM:SS
      between now and the argument</li><br/>
    <li><b>ltrim("string")</b><br>returns string without leading
      spaces</li><br/>
    <li><b>max(str1, str2, ...)</b><br>returns the highest value from a given
      list (sorted alphanumeric)</li><br/>
    <li><b>maxNum(num1, num2, ...)</b><br>returns the highest value from a
      given list (sorted numeric)</li><br/>
    <li><b>min(str1, str2, ...)</b><br>returns the lowest value from a given
    <li><b>minNum(num1, num2, ...)</b><br>returns the lowest value from a given
    <li><b>rtrim("string")</b><br>returns string without trailing
      spaces</li><br/>
    <li><b>time_str2num("YYYY-MM-DD HH:MM:SS")</b><br>convert a time string to
      number of seconds since 1970</li><br/>
    <li><b>trim("string")</b><br>returns string without leading and without
      trailing spaces</li><br/>
    <li><b>UntoggleDirect("deviceName")</b><br>For devices paired directly,
       converts state 'toggle' into 'on' or 'off'</li><br/>
    <li><b>UntoggleIndirect()</b><br>For devices paired indirectly, switches
      the target device 'on' or 'off', also when a 'toggle' was sent from the
      source device</li><br/>
    <li><b>defInfo("devspec", "internal")</b><br>return an array with the
      internal values of all devices found with devspec, e.g.
      defInfo("TYPE=SVG", "GPLOTFILE").</li><br/>
    <li><b>SVG_time_to_sec("YYYY-MM-DD_HH:MM:SS")</b><br>converts the argument
      to the number of seconds since 1970. Optimized for repeated use of similar
      timestamps.</li></br>
    <li><b>fhemNc("host:port", "textToSend", waitForReturn)</b><br>
      sends textToSend to host:port, and if waitForReturn is set, then read
      the answer (wait up to 5 seconds) and return it. Intended as small
      nc replacement.
      </li></br>
    <li><b>round(value, digits)</b><br>
      round &lt;value&gt; to given digits behind comma
      </li></br>
    <li><b>getUniqueId()</b><br>
      return the FHEM uniqueID used by the fheminfo command. Uses the
      getKeyValue / setKeyValue functions.
      </li></br>
    <li><b>setKeyValue(keyName, value)</b><br>
      store the value in the file $modpath/FHEM/FhemUtils/uniqueID (the name is
      used for backward compatibility), or in the database, if using configDB.
      value may not contain newlines, and only one value per key is stored.
      The file/database entry will be written immediately, no explicit save is
      required.  If the value is undef, the entry will be deleted.
      Returns an error-string or undef.
      </li></br>
    <li><b>getKeyValue(keyName)</b><br>
      return ($error, $value), stored previously by setKeyValue.
      $error is set if there was an error.  Both are undef, if there is no
      value yet for this key.
      </li></br>
  </ul>
</ul>
=end html
=cut
Hatte gerade nochmals neugestartet und das Log/Root Problem ist wieder da. Dadurch startet Fhem auch nicht mehr:
total 56
-rw-r--r-- 1 fhem dialout    0 Jun 18 17:04 -2016.log
-rw-r--r-- 1 fhem dialout    0 Jun 18 17:04 BZ.Fenster-2016.log
-rw-r--r-- 1 root root    9251 Jun 18 17:05 fhem-2016-06.log
-rw-r--r-- 1 fhem dialout    0 Jun 18 17:15 fhem.heartbeat
Du postest schon wieder Dinge, nach denen niemand gefragt hat. Was soll ich mit dem Inhalt der 99_Utils.pm anfangen? Das ist eine Datei, die in jedem fhem gleich aussieht, weil sie standarmäßig ausgeliefert wird.
Du solltest mit deinen Spielereien auf der Konsole aufhören, solange Dir nicht klar ist, was Du da eigentlich tust.
Vor allem solltest Du Dein fhem nicht manuell starten und Dich dann wundern, dass es knallt.
chown -R fhem:dialout /opt/fhem
reboot
Und dann die Finger von der Betriebssystemkonsole lassen. Oder zumindest nur das tun, wozu man Dich während der Hilfeleistung auch auffordert.
Spezialtrick
In Ordnung.
Befehl auf der Konsole ausgeführt. Fhem läuft nach dem Neustart.
Wie gehts weiter?
was denn noch? Dein fhem läuft doch jetzt erstmal?
  • Dein Problem mit den seriellen Schnittstellen ist ein Problem Deiner Linux-Neuinstallation. Das hat mit fhem primär nix zu tun.
  • Die redefined Meldungen kommen daher, dass in Deiner 99_myUtils.pm die gleichen Funktionen enthalten sind wie in der 99_Utils.pm. Warum das so ist, kannst nur Du alleine wissen, da kann Dir niemand helfen
Spezialtrick
Vollkommen richtig - Fhem läuft, aber ohne Gateways ist es wohl kaum nutzbar. Sobald der Cubie aus irgendeinem Grund neu startet, sind die Gateways ja wieder weg. Kannst du mir vllt. auch hierbei helfen? Vor der Neuinstallation hat es ja auch funktioniert.
ZitatDie redefined Meldungen kommen daher, dass in Deiner 99_myUtils.pm die gleichen Funktionen enthalten sind wie in der 99_Utils.pm. Warum das so ist, kannst nur Du alleine wissen, da kann Dir niemand helfen
Warum das so ist, kann ich dir selbst nicht sagen. Ich habe die beiden Dateien nun verglichen und meine Funktionen in die 99_myUtils.pm verlagert. Alle redefined Meldungen sind nun weg. Danke für den Tipp!  :)
papa
Kannst Du bitte mal neu starten und danach die Ausgaben von "dmesg" posten.
Spezialtrick
Na klar doch:
root@cubietruck:~# dmesg
[    0.000000] Booting Linux on physical CPU 0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 3.4.112-sun7i (root@pluton) (gcc version 5.3.1 20160413 (Ubuntu/Linaro 5.3.1-14ubuntu2) ) #7 SMP PREEMPT Mon May 23 22:09:19 CEST 2016
[    0.000000] CPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: sun7i
[    0.000000] Memory Reserved:
[    0.000000] SYS  : 0x43000000 - 0x4300ffff  (  64 kB)
[    0.000000] LCD  : 0x44000000 - 0x44ffffff  (  16 MB)
[    0.000000] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] sunxi: Allwinner A20 (AW1651/sun7i) detected.
[    0.000000] On node 0 totalpages: 524288
[    0.000000] free_area_init_node: node 0, pgdat c0a89440, node_mem_map d0000000
[    0.000000]   DMA zone: 512 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 65024 pages, LIFO batch:15
[    0.000000]   Normal zone: 1008 pages used for memmap
[    0.000000]   Normal zone: 128016 pages, LIFO batch:31
[    0.000000]   HighMem zone: 2576 pages used for memmap
[    0.000000]   HighMem zone: 327152 pages, LIFO batch:31
[    0.000000] PERCPU: Embedded 8 pages/cpu @d100e000 s8256 r8192 d16320 u32768
[    0.000000] pcpu-alloc: s8256 r8192 d16320 u32768 alloc=8*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 520192
[    0.000000] Kernel command line: console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 cgroup_enable=memory swapaccount=1 sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_no_mali_mem_reserve sunxi_fb_mem_reserve=16 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 enforcing=0 loglevel=1
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] allocated 4194304 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Memory: 2048MB = 2048MB total
[    0.000000] Memory: 2043020k/2043020k available, 54132k reserved, 1318912K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xef800000   ( 760 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc09dfe98   (10080 kB)
[    0.000000]       .init : 0xc09e0000 - 0xc0a18040   ( 225 kB)
[    0.000000]       .data : 0xc0a1a000 - 0xc0a91d68   ( 480 kB)
[    0.000000]        .bss : 0xc0a91d8c - 0xc0c66f78   (1877 kB)
[    0.000000] SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[    0.000000] Additional per-CPU info printed with stalls.
[    0.000000] NR_IRQS:192
[    0.000000] Architected local timer running at 24.00MHz.
[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[    0.000000] start_kernel(): bug: interrupts were enabled early
[    0.000000] Console: colour dummy device 80x30
[    0.000000] console [tty1] enabled
[    0.013303] Calibrating delay loop... 1816.98 BogoMIPS (lpj=9084928)
[    0.076001] pid_max: default: 32768 minimum: 301
[    0.079659] Mount-cache hash table entries: 512
[    0.083866] Initializing cgroup subsys cpuacct
[    0.087185] Initializing cgroup subsys memory
[    0.090608] Initializing cgroup subsys devices
[    0.094048] Initializing cgroup subsys freezer
[    0.097274] Initializing cgroup subsys blkio
[    0.100949] Initializing cgroup subsys perf_event
[    0.104527] CPU: Testing write buffer coherency: ok
[    0.109734] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.116842] hw perfevents: enabled with ARMv7 Cortex-A7 PMU driver, 5 counters available
[    0.122381] Setting up static identity map for 0x40724a18 - 0x40724a70
[    0.239113] CPU1: Booted secondary processor
[    0.297278] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.299285] Brought up 2 CPUs
[    0.304596] SMP: Total of 2 processors activated (3640.52 BogoMIPS).
[    0.307837] devtmpfs: initialized
[    0.313869] dummy:
[    0.317555] NET: Registered protocol family 16
[    0.323985] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.331911] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.336727] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.339881] [ccu-inf] aw clock manager init
[    0.342153] [ccu-inf] aw_ccu_init
[    0.346127] [ccu-inf] script config pll3 to 297MHz
[    0.349879] [ccu-inf] script config pll4 to 300MHz
[    0.353627] [ccu-inf] script config pll6 to 600MHz
[    0.357390] [ccu-inf] script config pll7 to 297MHz
[    0.361136] [ccu-inf] script config pll8 to 336MHz
[    0.363895] Init eGon pin module V2.0
[    0.373503] bio: create slab <bio-0> at 0
[    0.377099] sunxi_gpio driver init ver 1.3
[    0.383411] sunxi_gpio_probe script_parser_fetch '[gpio_para]' 'gpio_pin_3' err
[    0.389019] gpiochip_add: registered GPIOs 1 to 4 on device: A1X_GPIO
[    0.392209] SCSI subsystem initialized
[    0.395062] libata version 3.00 loaded.
[    0.399720] usbcore: registered new interface driver usbfs
[    0.404090] usbcore: registered new interface driver hub
[    0.408252] usbcore: registered new device driver usb
[    0.411367] Linux media interface: v0.10
[    0.414977] Linux video capture interface: v2.00
[    0.420589] Advanced Linux Sound Architecture Driver Version 1.0.25.
[    0.426136] Switching to clocksource arch_sys_counter
[    0.428239] FS-Cache: Loaded
[    0.430455] CacheFiles: Loaded
[    0.441532] cfg80211: Calling CRDA to update world regulatory domain
[    0.442853] [usb_manager]: CONFIG_USB_SW_SUNXI_USB0_OTG
[    0.446655] [sw_hcd0]: usb host driver initialize........
[    0.450885] [sw_hcd0]: open_usb_clock
[    0.475143] [sw_hcd0]: host_init_state = 1
[    0.476114] [sw_hcd0]: platform is usb host
[    0.479038] [sw_hcd0]: sw_hcd_host0: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx (X), HB-ISO Tx (X), SoftConn)
[    0.490226] [sw_hcd0]: sw_hcd_init_controller: sw_hcd_host0: USB Host mode controller at f1c13000 using PIO, IRQ 70
[    0.502766] sw_hcd_host0 sw_hcd_host0: sw_hcd host driver
[    0.509468] sw_hcd_host0 sw_hcd_host0: new USB bus registered, assigned bus number 1
[    0.512926] hub 1-0:1.0: USB hub found
[    0.515820] hub 1-0:1.0: 1 port detected
[    0.519673] wrn: hcd is not enable, need not start hcd
[    0.521070] [sw_hcd0]: sw_usb_host0_disable start
[    0.527082] -------sw_hcd0_soft_disconnect---------
[    0.530065] is_on = 0, hcd0_set_vbus_cnt = 0
[    0.533116] [sw_hcd_host0]: Set USB Power Off
[    0.536861] wrn: hcd is not enable, need not stop hcd
[    0.537933] [sw_hcd0]: close_usb_clock
[    0.540397] [sw_hcd0]: sw_usb_host0_disable end
[    0.543579] [sw_udc]: udc_init: version 20080411
[    0.550000] NET: Registered protocol family 2
[    0.566560] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.573494] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.580989] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
[    0.587751] TCP: Hash tables configured (established 131072 bind 65536)
[    0.589953] TCP: reno registered
[    0.594831] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.600167] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.603777] NET: Registered protocol family 1
[    0.609040] RPC: Registered named UNIX socket transport module.
[    0.612751] RPC: Registered udp transport module.
[    0.616410] RPC: Registered tcp transport module.
[    0.621812] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.626393] Trying to unpack rootfs image as initramfs...
[    0.876921] Freeing initrd memory: 3580K
[    0.882637] audit: initializing netlink socket (disabled)
[    0.886345] type=2000 audit(0.870:1): initialized
[    0.890858] highmem bounce pool size: 64 pages
[    0.902898] VFS: Disk quotas dquot_6.5.2
[    0.908366] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.915721] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.921295] NFS: Registering the id_resolver key type
[    0.925814] NTFS driver 2.1.30 [Flags: R/W].
[    0.929151] fuse init (API version 7.18)
[    0.933887] JFS: nTxBlock = 8192, nTxLock = 65536
[    0.953388] SGI XFS with ACLs, security attributes, large block/inode numbers, no debug enabled
[    0.957749] Btrfs loaded
[    0.960573] msgmni has been set to 1421
[    0.968180] alg: No test for stdrng (krng)
[    0.974950] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    0.977840] io scheduler noop registered
[    0.981123] io scheduler deadline registered
[    0.984820] io scheduler cfq registered (default)
[    0.989702] sunxi disp driver loaded (/dev/disp api 1.0)
[    0.995330] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    1.000121] [uart]: used uart info.: 0x05
[    1.004816] [uart]: serial probe 0 irq 33 mapbase 0x01c28000
[    1.031106] sunxi-uart.0: ttyS0 at MMIO 0x1c28000 (irq = 33) is a U6_16550A
[    1.036012] [uart]: serial probe 2 irq 35 mapbase 0x01c28800
[    1.062235] sunxi-uart.2: ttyS1 at MMIO 0x1c28800 (irq = 35) is a U6_16550A
[    1.064876] G2D: drv_g2d_init
[    1.068226] G2D: Module initialized.major:250
[    1.077415] brd: module loaded
[    1.083445] loop: module loaded
[    1.086800] [NAND] nand driver version: 0x2 0x9
[    1.151189] Dev Sunxi softw311 nand magic does not match for MBR 1: softw411
[    1.157258] Dev Sunxi softw311 nand magic does not match for MBR 2:
[    1.163280] Dev Sunxi softw311 nand magic does not match for MBR 3:
[    1.169282] Dev Sunxi softw311 nand magic does not match for MBR 4:
[    1.177031] Dev Sunxi softw311 nand header bad for all MBR copies, MBR corrupted or not present.
[    1.184255] Dev Sunxi softw411 nand mbr number does not match for MBR 2: 0
[    1.189268] Dev Sunxi softw411 nand header: CRC bad for MBR 2
[    1.196198] Dev Sunxi softw411 nand mbr number does not match for MBR 3: 0
[    1.201228] Dev Sunxi softw411 nand header: CRC bad for MBR 3
[    1.208045] Dev Sunxi softw411 nand mbr number does not match for MBR 4: 0
[    1.213076] Dev Sunxi softw411 nand header: CRC bad for MBR 4
[    1.218478] Dev Sunxi softw411 nand: part 1, start 32768, size 131072
[    1.224078] Dev Sunxi softw411 nand: part 2, start 163840, size 4194304
[    1.229820] Dev Sunxi softw411 nand: part 3, start 4358144, size 10682368
[    1.232369]  nand: nand1 nand2 nand3
[    1.235582] [NAND]nand driver, ok.
[    1.241785] pwm-sunxi: pwm0 configured - period: 20, duty_percent: 50, duty: 10
[    1.248193] sw_ahci sw_ahci.0: controller can't do PMP, turning off CAP_PMP
[    1.252703] ahci: SSS flag set, parallel bus scan disabled
[    1.260114] sw_ahci sw_ahci.0: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[    1.267007] sw_ahci sw_ahci.0: flags: ncq sntf stag pm led clo only pio slum part ccc
[    1.270462] scsi0 : sw_ahci_platform
[    1.277707] ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 88
[    1.281739] [spi-err] Get spi devices number failed
[    1.286439] [spi-err] register spi devices board info failed
[    1.295933] spi: cannot find any using configuration for                     all 4 spi controllers, return directly!
[    1.302025] bonding: Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
[    1.306867] Fixed MDIO Bus: probed
[    1.311467] emac_init fetch emac using configuration failed
[    1.313912] emac driver is disabled
[    1.317434] gmac: use mac address from chipid
[    1.321563] gmac: device MAC address 02:04:07:40:c1:5c
[    1.327216] [gmac]: sun6i_gmac platform driver registration completed
[    1.330519] PPP generic driver version 2.4.2
[    1.334450] PPP BSD Compression module registered
[    1.338458] PPP Deflate Compression module registered
[    1.345724] PPP MPPE Compression module registered
[    1.349136] NET: Registered protocol family 24
[    1.355265] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.360471] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.362987] [sw-ehci1]: open clock
[    1.385671] [sw-ehci1]: Set USB Power ON
[    1.392110] sw-ehci sw-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.398404] sw-ehci sw-ehci.1: new USB bus registered, assigned bus number 2
[    1.402826] sw-ehci sw-ehci.1: irq 71, io mem 0x01c14000
[    1.420560] sw-ehci sw-ehci.1: USB 2.0 started, EHCI 1.00
[    1.423183] ehci_irq: port change detect
[    1.426591] hub 2-0:1.0: USB hub found
[    1.429524] hub 2-0:1.0: 1 port detected
[    1.432172] [sw-ohci1]: open clock
[    1.458319] sw-ohci sw-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.464587] sw-ohci sw-ohci.1: new USB bus registered, assigned bus number 3
[    1.468890] sw-ohci sw-ohci.1: irq 96, io mem 0x01c14400
[    1.533549] hub 3-0:1.0: USB hub found
[    1.536443] hub 3-0:1.0: 1 port detected
[    1.539129] [sw-ehci2]: open clock
[    1.561814] [sw-ehci2]: Set USB Power ON
[    1.568252] sw-ehci sw-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.574492] sw-ehci sw-ehci.2: new USB bus registered, assigned bus number 4
[    1.578864] sw-ehci sw-ehci.2: irq 72, io mem 0x01c1c000
[    1.600552] sw-ehci sw-ehci.2: USB 2.0 started, EHCI 1.00
[    1.603896] hub 4-0:1.0: USB hub found
[    1.606791] hub 4-0:1.0: 1 port detected
[    1.609470] [sw-ohci2]: open clock
[    1.617464] ehci_irq: port change detect
[    1.631446] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    1.637533] sw-ohci sw-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.643847] sw-ohci sw-ohci.2: new USB bus registered, assigned bus number 5
[    1.648461] ata1.00: ATA-7: ST9160821AS, 3.ALB, max UDMA/133
[    1.654142] ata1.00: 312581808 sectors, multi 0: LBA48 NCQ (depth 31/32)
[    1.658409] sw-ohci sw-ohci.2: irq 97, io mem 0x01c1c400
[    1.662728] ata1.00: configured for UDMA/133
[    1.670307] scsi 0:0:0:0: Direct-Access     ATA      ST9160821AS      3.AL PQ: 0 ANSI: 5
[    1.677531] sd 0:0:0:0: [sda] 312581808 512-byte logical blocks: (160 GB/149 GiB)
[    1.681603] sd 0:0:0:0: [sda] Write Protect is off
[    1.685617] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.693706] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.696398] ehci_irq: port change detect
[    1.723695] hub 5-0:1.0: USB hub found
[    1.726596] hub 5-0:1.0: 1 port detected
[    1.730872] Initializing USB Mass Storage driver...
[    1.736015] usbcore: registered new interface driver usb-storage
[    1.738636]  sda: sda1 sda2 sda3 sda4
[    1.742254] USB Mass Storage support registered.
[    1.745842] sd 0:0:0:0: [sda] Attached SCSI disk
[    1.750808] usbcore: registered new interface driver ums-alauda
[    1.755875] usbcore: registered new interface driver ums-cypress
[    1.758492] The port change to OHCI now!
[    1.763543] usbcore: registered new interface driver ums-datafab
[    1.768718] usbcore: registered new interface driver ums_eneub6250
[    1.773741] usbcore: registered new interface driver ums-freecom
[    1.778663] usbcore: registered new interface driver ums-isd200
[    1.783767] usbcore: registered new interface driver ums-jumpshot
[    1.788592] usbcore: registered new interface driver ums-karma
[    1.793694] usbcore: registered new interface driver ums-onetouch
[    1.798728] usbcore: registered new interface driver ums-realtek
[    1.803661] usbcore: registered new interface driver ums-sddr09
[    1.808573] usbcore: registered new interface driver ums-sddr55
[    1.813465] usbcore: registered new interface driver ums-usbat
[    1.818247] mousedev: PS/2 mouse device common for all mice
[    1.823933] ===========================hv_keypad_init=====================
[    1.827333] ========HV Inital ===================
[    1.831319] tkey_fetch_sysconfig_para: tkey_unused.
[    1.838534] hv_keypad_init: after fetch_sysconfig_para:  normal_i2c: 0x0. normal_i2c[1]: 0x0
[    1.844334] sunxi-rtc sunxi-rtc: rtc core: registered rtc as rtc0
[    1.846836] i2c /dev entries driver
[    1.850457] config i2c gpio with gpio_config api
[    1.856110] axp_mfd 0-0034: AXP (CHIP ID: 0x41) detected
[    1.861952] axp_mfd 0-0034: AXP internal temperature monitoring enabled
[    1.866644] i2c i2c-0: Invalid probe address 0x00
[    1.869738] I2C: i2c-0: AW16XX I2C adapter
[    1.873784] [cedar dev]: not installed! ve_mem_reserve=0
[    1.877182] [tt]----- avs_dev driver load... ----
[    1.880786] [tt]-----      register iomem      ----
[    1.883581] Cannot reserve region for ccmu
[    1.887282] [tt]--- avs_dev driver load ok!! -----
[    1.889061] [ace_drv] start!!!
[    1.891472] [ace_drv] init end!!!
[    1.893140] [pa_drv] start!!!
[    1.895399] [pa_drv] init end!!!
[    1.897786] axp20_ldo1: 1300 mV
[    1.903054] axp20_ldo2: 1800 <--> 3300 mV at 3000 mV
[    1.908341] axp20_ldo3: 700 <--> 3500 mV at 2800 mV
[    1.913738] axp20_ldo4: 1250 <--> 3300 mV at 2800 mV
[    1.919092] axp20_buck2: 700 <--> 2275 mV at 1450 mV
[    1.925688] somebody is trying to set dcdc3 range to (1300000, 1300000) uV
[    1.930713] but we keep dcdc3 = 1250000 uV from the bootloader
[    1.935010] axp20_buck3: 700 <--> 3500 mV at 1250 mV
[    1.939896] axp20_ldoio0: 1800 <--> 3300 mV at 2800 mV
[    1.949505] input: axp20-supplyer as /devices/platform/sunxi-i2c.0/i2c-0/0-0034/axp20-supplyer.28/input/input0
[    1.967862] axp20_ldo2: Failed to create debugfs directory
[    1.971066] incomplete xfer (0x20)
[    1.973324] incomplete xfer (0x20)
[    1.975576] incomplete xfer (0x20)
[    1.977825] incomplete xfer (0x20)
[    1.980095] incomplete xfer (0x20)
[    1.982345] incomplete xfer (0x20)
[    1.984595] incomplete xfer (0x20)
[    1.986844] incomplete xfer (0x20)
[    1.989108] incomplete xfer (0x20)
[    1.993103] device-mapper: uevent: version 1.0.3
[    2.000899] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[    2.005876] device-mapper: multipath: version 1.3.2 loaded
[    2.011360] device-mapper: multipath round-robin: version 1.0.0 loaded
[    2.016961] device-mapper: multipath queue-length: version 0.1.0 loaded
[    2.022583] device-mapper: multipath service-time: version 0.2.0 loaded
[    2.026078] cpuidle: using governor ladder
[    2.028958] cpuidle: using governor menu
[    2.031316] [mmc-msg] sw_mci_init
[    2.037076] [mmc-msg] MMC host used card: 0x9, boot card: 0x0, io_card 8
[    2.042441] [mmc-msg] sdc0 set round clock 400000, src 24000000
[    2.050705] [mmc-msg] sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.058973] [mmc-msg] sdc0 Probe: base:0xf0618000 irq:64 sg_cpu:f061a000(4fc00000) ret 0.
[    2.063988] [mmc-msg] sdc3 set round clock 400000, src 24000000
[    2.072191] [mmc-msg] sdc3 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.080386] [mmc-msg] sdc3 Probe: base:0xf061c000 irq:67 sg_cpu:f061e000(4fc01000) ret 0.
[    2.084974] [mmc_pm]: failed to fetch sdio card configuration!
[    2.087405] sunxi_leds driver init
[    2.091465] Registered led device: blue:ph21:led1
[    2.095387] Registered led device: orange:ph20:led2
[    2.099228] Registered led device: white:ph11:led3
[    2.104626] usb 3-1: new full-speed USB device number 2 using sw-ohci
[    2.108513] Registered led device: green:ph07:led4
[    2.113624] ledtrig-cpu: registered to indicate activity on CPUs
[    2.118877] usbcore: registered new interface driver usbhid
[    2.121701] usbhid: USB HID core driver
[    2.124445] ashmem: initialized
[    2.128103] logger: created 256K log 'log_main'
[    2.131954] logger: created 256K log 'log_events'
[    2.135660] logger: created 256K log 'log_radio'
[    2.139467] logger: created 256K log 'log_system'
[    2.147337] asoc: sndspdif <-> sunxi-spdif.0 mapping ok
[    2.151197] [I2S-0] Entered sunxi_i2s_init
[    2.155386] [I2S-0] sunxi_i2s_init I2S used in master mode
[    2.158823] [I2S-0] Entered sunxi_i2s_dev_probe
[    2.163647] [I2S-0] sndi2s_codec_init I2S used in master mode
[    2.168319] [I2S-0] sndi2s_codec_probe I2S used in master mode
[    2.171443] [I2S-0] Entered sunxi_sndi2s_init
[    2.175887] [I2S-0] sunxi_sndi2s_init I2S used in master mode
[    2.180613] asoc: sndi2s <-> sunxi-i2s.0 mapping ok
[    2.184937] IPv4 over IPv4 tunneling driver
[    2.187732] TCP: bic registered
[    2.190064] TCP: cubic registered
[    2.192595] TCP: westwood registered
[    2.195211] TCP: highspeed registered
[    2.197481] TCP: hybla registered
[    2.199677] TCP: htcp registered
[    2.201947] TCP: vegas registered
[    2.204130] TCP: veno registered
[    2.206659] TCP: scalable registered
[    2.208681] TCP: lp registered
[    2.210864] TCP: yeah registered
[    2.213393] TCP: illinois registered
[    2.216616] Initializing XFRM netlink socket
[    2.220702] NET: Registered protocol family 10
[    2.225323] NET: Registered protocol family 17
[    2.228757] NET: Registered protocol family 15
[    2.233474] [mmc_pm]: No sdio card, please check your config !!
[    2.237145] Registering the dns_resolver key type
[    2.239410] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 4
[    2.247966] Registering SWP/SWPB emulation handler
[    2.252612] axp20_buck2: Failed to create debugfs directory
[    2.258778] [cpu_freq] INF:-------------------V-F Table-------------------
[    2.263854] [cpu_freq] INF: voltage = 1450mv frequency = 1008MHz
[    2.268900] [cpu_freq] INF: voltage = 1425mv frequency =  912MHz
[    2.273969] [cpu_freq] INF: voltage = 1350mv frequency =  864MHz
[    2.279014] [cpu_freq] INF: voltage = 1250mv frequency =  720MHz
[    2.284071] [cpu_freq] INF: voltage = 1150mv frequency =  528MHz
[    2.289116] [cpu_freq] INF: voltage = 1100mv frequency =  312MHz
[    2.294221] [cpu_freq] INF: voltage = 1050mv frequency =  144MHz
[    2.299276] [cpu_freq] INF: voltage = 1000mv frequency =    0MHz
[    2.305120] [cpu_freq] INF:-----------------------------------------------
[    2.314858] [cpu_freq] INF:sunxi_cpufreq_initcall, get cpu frequency from sysconfig, max freq: 912MHz, min freq: 720MHz
[    2.318830] registered taskstats version 1
[    2.323757] I2C: i2c-1: HDMI I2C adapter
[    2.341131] hub 3-1:1.0: USB hub found
[    2.345224] hub 3-1:1.0: 4 ports detected
[    2.352898] disp clks: lcd 148500000 pre_scale 1 hdmi 148500000 pll 297000000 2x 0
[    2.481621] usb 4-1: new high-speed USB device number 2 using sw-ehci
[    2.631461] hub 4-1:1.0: USB hub found
[    2.634776] hub 4-1:1.0: 4 ports detected
[    2.721784] usb 3-1.4: new full-speed USB device number 3 using sw-ohci
[    2.931797] usb 4-1.2: new full-speed USB device number 3 using sw-ehci
[    3.010726] usb 4-1.2: device descriptor read/64, error -32
[    3.045108] [mmc-msg] mmc 0 detect change, present 1
[    3.200750] usb 4-1.2: device descriptor read/64, error -32
[    3.391791] usb 4-1.2: new full-speed USB device number 4 using sw-ehci
[    3.470744] usb 4-1.2: device descriptor read/64, error -32
[    3.544145] [mmc-msg] sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.546604] [mmc-msg] sdc0 power on
[    3.574571] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.579497] [mmc-msg] sdc0 set round clock 400000, src 24000000
[    3.617169] Console: switching to colour frame buffer device 240x67
[    3.651874] [mmc-err] smc 0 err, cmd 52,  RTO
[    3.656020] [mmc-err] smc 0 err, cmd 52,  RTO
[    3.664387] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.668959] usb 4-1.2: device descriptor read/64, error -32
[    3.674258] axp20_buck3: incomplete constraints, leaving on
[    3.682605] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.687400] axp20_buck2: incomplete constraints, leaving on
[    3.690631] [mmc-err] smc 0 err, cmd 5,  RTO
[    3.695344] axp20_ldo4: incomplete constraints, leaving on
[    3.698582] [mmc-err] smc 0 err, cmd 5,  RTO
[    3.703315] axp20_ldo3: incomplete constraints, leaving on
[    3.706557] [mmc-err] smc 0 err, cmd 5,  RTO
[    3.711291] axp20_ldo2: incomplete constraints, leaving on
[    3.714528] [mmc-err] smc 0 err, cmd 5,  RTO
[    3.719224] axp20_ldo1: incomplete constraints, leaving on
[    3.727958] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.730592] console [netcon0] enabled
[    3.738935] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.742444] netconsole: network logging started
[    3.750787] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.754988] otg_wakelock_init: No USB transceiver found
[    3.757038] ALSA device list:
[    3.760115]   #0: sunxi-CODEC  Audio Codec
[    3.762301]   #1: sunxi-sndspdif
[    3.764312]   #2: sunxi-sndi2s
[    3.767534] Freeing init memory: 224K
[    3.827449] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[    3.835989] [mmc-msg] sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[    3.841187] [mmc-msg] sdc0 set round clock 42857143, src 600000000
[    3.845117] systemd-udevd[90]: starting version 215
[    3.861886] usb 4-1.2: new full-speed USB device number 5 using sw-ehci
[    3.904887] [mmc-msg] sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B
[    3.909384] mmc0: new high speed SDHC card at address aaaa
[    3.937028] mmcblk0: mmc0:aaaa SU32G 29.7 GiB
[    3.940529]  mmcblk0: p1
[    4.049250] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    4.281264] usb 4-1.2: device not accepting address 5, error -32
[    4.362029] usb 4-1.2: new full-speed USB device number 6 using sw-ehci
[    4.781189] usb 4-1.2: device not accepting address 6, error -32
[    4.786863] hub 4-1:1.0: unable to enumerate USB device on port 2
[    4.871772] usb 4-1.3: new full-speed USB device number 7 using sw-ehci
[    4.950728] usb 4-1.3: device descriptor read/64, error -32
[    5.140743] usb 4-1.3: device descriptor read/64, error -32
[    5.331774] usb 4-1.3: new full-speed USB device number 8 using sw-ehci
[    5.410728] usb 4-1.3: device descriptor read/64, error -32
[    5.600733] usb 4-1.3: device descriptor read/64, error -32
[    5.791775] usb 4-1.3: new full-speed USB device number 9 using sw-ehci
[    6.211173] usb 4-1.3: device not accepting address 9, error -32
[    6.291863] usb 4-1.3: new full-speed USB device number 10 using sw-ehci
[    6.711254] usb 4-1.3: device not accepting address 10, error -32
[    6.716629] hub 4-1:1.0: unable to enumerate USB device on port 3
[    6.801856] usb 4-1.4: new full-speed USB device number 11 using sw-ehci
[    6.880726] usb 4-1.4: device descriptor read/64, error -32
[    7.070739] usb 4-1.4: device descriptor read/64, error -32
[    7.261861] usb 4-1.4: new full-speed USB device number 12 using sw-ehci
[    7.340733] usb 4-1.4: device descriptor read/64, error -32
[    7.530732] usb 4-1.4: device descriptor read/64, error -32
[    7.721866] usb 4-1.4: new full-speed USB device number 13 using sw-ehci
[    8.141261] usb 4-1.4: device not accepting address 13, error -32
[    8.221863] usb 4-1.4: new full-speed USB device number 14 using sw-ehci
[    8.641256] usb 4-1.4: device not accepting address 14, error -32
[    8.646878] hub 4-1:1.0: unable to enumerate USB device on port 4
[    8.891875] usb 4-1.1: new full-speed USB device number 15 using sw-ehci
[    9.013590] generic-usb 0003:1B1F:C00F.0001: hiddev0,hidraw0: USB HID v1.10 Device [eQ-3 HM-CFG-USB] on usb-sw-ehci-1.1/input0
[    9.841498] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[   10.320503] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[   10.325087] systemd[1]: Detected architecture 'arm'.
[   10.352844] systemd[1]: Set hostname to <cubietruck>.
[   10.844614] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[   10.855581] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[   10.862773] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   10.867669] systemd[1]: Expecting device dev-ttyS0.device...
[   10.873154] systemd[1]: Starting Remote File Systems (Pre).
[   10.878877] systemd[1]: Reached target Remote File Systems (Pre).
[   10.886930] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[   10.896783] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   10.900911] systemd[1]: Starting Encrypted Volumes.
[   10.905939] systemd[1]: Reached target Encrypted Volumes.
[   10.913119] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
[   10.920452] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   10.923911] systemd[1]: Starting Root Slice.
[   10.928373] systemd[1]: Created slice Root Slice.
[   10.932874] systemd[1]: Starting User and Session Slice.
[   10.938455] systemd[1]: Created slice User and Session Slice.
[   10.944282] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[   10.951162] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[   10.955754] systemd[1]: Starting Delayed Shutdown Socket.
[   10.961336] systemd[1]: Listening on Delayed Shutdown Socket.
[   10.966046] systemd[1]: Starting Journal Socket (/dev/log).
[   10.971858] systemd[1]: Listening on Journal Socket (/dev/log).
[   10.976092] systemd[1]: Starting udev Control Socket.
[   10.981289] systemd[1]: Listening on udev Control Socket.
[   10.985412] systemd[1]: Starting udev Kernel Socket.
[   10.990385] systemd[1]: Listening on udev Kernel Socket.
[   10.994231] systemd[1]: Starting Journal Socket.
[   10.998965] systemd[1]: Listening on Journal Socket.
[   11.002717] systemd[1]: Starting System Slice.
[   11.007506] systemd[1]: Created slice System Slice.
[   11.012904] systemd[1]: Started File System Check on Root Device.
[   11.016985] systemd[1]: Starting system-getty.slice.
[   11.022514] systemd[1]: Created slice system-getty.slice.
[   11.027489] systemd[1]: Starting system-serial\x2dgetty.slice.
[   11.033778] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   11.039263] systemd[1]: Starting Increase datagram queue length...
[   11.122766] systemd[1]: Starting Restore / save the current clock...
[   11.142410] systemd[1]: Mounting Debug File System...
[   11.174883] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   11.191775] systemd[1]: Mounted Huge Pages File System.
[   11.202947] systemd[1]: Started Set Up Additional Binary Formats.
[   11.209052] systemd[1]: Starting udev Coldplug all Devices...
[   11.244101] systemd[1]: Starting Load Kernel Modules...
[   11.258406] systemd[1]: Mounting POSIX Message Queue File System...
[   11.290958] systemd[1]: Starting LSB: Set keymap...
[   11.329120] lp: driver loaded but no devices found
[   11.334307] systemd[1]: Starting Slices.
[   11.338934] systemd[1]: Reached target Slices.
[   11.348334] systemd[1]: Mounted POSIX Message Queue File System.
[   11.352086] ppdev: user-space parallel port driver
[   11.357125] systemd[1]: Mounted Debug File System.
[   11.372483] systemd[1]: Started Increase datagram queue length.
[   11.382603] systemd[1]: Started Restore / save the current clock.
[   11.391933] Bluetooth: Core ver 2.16
[   11.395430] NET: Registered protocol family 31
[   11.400738] Bluetooth: HCI device and connection manager initialized
[   11.404650] Bluetooth: HCI socket layer initialized
[   11.408660] Bluetooth: L2CAP socket layer initialized
[   11.412554] Bluetooth: SCO socket layer initialized
[   11.421514] systemd[1]: Started Create list of required static device nodes for the current kernel.
[   11.437733] Bluetooth: HCI UART driver ver 2.2
[   11.441574] Bluetooth: HCI H4 protocol initialized
[   11.445523] Bluetooth: HCI BCSP protocol initialized
[   11.449207] Bluetooth: HCILL protocol initialized
[   11.453171] Bluetooth: HCIATH3K protocol initialized
[   11.468464] Bluetooth: RFCOMM TTY layer initialized
[   11.472684] Bluetooth: RFCOMM socket layer initialized
[   11.475403] Bluetooth: RFCOMM ver 1.11
[   11.486808] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[   11.491176] systemd[1]: Started LSB: Set keymap.
[   11.500026] input: sunxi-ir as /devices/virtual/input/input1
[   11.503435] systemd[1]: Time has been changed
[   11.505165] IR Initial OK
[   11.513377] systemd[1]: Starting Create Static Device Nodes in /dev...
[   11.541011] systemd[1]: Starting Syslog Socket.
[   11.546442] systemd[1]: Listening on Syslog Socket.
[   11.550685] systemd[1]: Starting Journal Service...
[   11.563906] systemd[1]: Started Journal Service.
[   11.582064] [ap6210] select wifi ap6210
[   11.587693] [ap6210] Initializing ap6210.
[   11.593022] [ap6210] platform device registered successfully.
[   11.597000] [ap6210] Using ap6210 configuration.
[   11.708681] [mmc-msg] sdc3 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   11.718660] [mmc-msg] sdc3 power on
[   11.744620] [mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   11.749559] [mmc-msg] sdc3 set round clock 400000, src 24000000
[   11.805539] [ap6210] WLAN placed in POWER ON
[   11.826476] systemd-udevd[174]: starting version 215
[   11.842023] [mmc-err] smc 3 err, cmd 52,  RTO
[   11.846227] [mmc-err] smc 3 err, cmd 52,  RTO
[   11.854688] [mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   11.866119] [mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   11.876914] [mmc-err] smc 3 err, cmd 8,  RTO
[   11.890184] [mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   11.904486] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[   11.915830] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[   11.929244] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[   11.939356] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[   11.971504] [mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[   11.980275] [mmc-msg] sdc3 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[   11.987635] [mmc-msg] sdc3 set round clock 42857143, src 600000000
[   12.051544] [mmc-msg] sdc3 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B
[   12.072139] mmc1: new high speed SDIO card at address 0001
[   12.077926] [ap6210] Linux Kernel SDIO/MMC Driver
[   12.107831] [ap6210] Broadcom Dongle Host Driver: register interface [wlan0] MAC: 00:90:4c:11:22:33
[   12.503861] [ap6210] WLAN placed in RESET
[   12.534668] [ap6210] wl_event_handler was terminated
[   12.833827] usbcore: registered new interface driver btusb
[   13.109076] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[   13.635416] ap6211: exports duplicate symbol bcmsdh_probe (owned by ap6210)
[   13.654565] ap6211: exports duplicate symbol bcmsdh_probe (owned by ap6210)
[   13.757410] Adding 131068k swap on /var/swap.  Priority:-1 extents:2 across:139260k SS
[   13.981335] [ap6210] Using ap6210 configuration.
[   14.410732] systemd-journald[173]: Received request to flush runtime journal from PID 1
[   14.926794] sunxi_gmac: probed
[   14.932343] eth0: PHY ID 001cc915 at 0 IRQ 0 (sunxi_gmac-0:00) active
[   14.937140] eth0: PHY ID 001cc915 at 1 IRQ 0 (sunxi_gmac-0:01)
[   17.951552] PHY: sunxi_gmac-0:00 - Link is Up - 1000/Full
[   24.635093] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   24.639284] Bluetooth: BNEP filters: protocol multicast
[   25.359224] eth0: no IPv6 routers present
papa
Hier geht irgendwas auf dem USB-Bus schief. Bitte mal alle USB-Geräte abziehen und booten. Dann immer nur ein USB-Gerät anstecken und wieder booten. Prüfen ob es funktioniert. Und immer so weiter, bis rauskommt, was hier am Bus Probleme macht.
