[ NUKI Smartlock ] 73_NUKIBridge.pm und 74_NUKDevice.pm
Begonnen von CoolTux, 18 Juli 2016, 23:50:11
markukug
Der Status wird leider nicht aktualisiert. Erst mit set nukiHaustuer statusRequest wir der Status aktualisiert. Läuft irgendwie noch nicht so rund.
Ich habe bei der Bridge folgenden Fehler. Die hier angeführte IP ist die, der Bridge.
lastError 192.168.178.233: No route to host 2017-01-24 10:59:13
LOG verbose 5 Bridge und Schloss
2017.01.24 11:17:15 5: NUKIDevice (nukiHaustuer) - Parse with result: {"name":"Nuki_06201309","rssi":-77,"paired":true}
2017.01.24 11:17:15 5: NUKIDevice (nukiHaustuer) - parse status message for nukiHaustuer
2017.01.24 11:17:15 5: NUKIDevice (nukiHaustuer) - readings set for nukiHaustuer
2017.01.24 11:17:41 5: NUKIDevice (nukiHaustuer) - Parse with result: {"rssi":-77,"name":"Nuki_06201309","paired":true}
2017.01.24 11:17:41 5: NUKIDevice (nukiHaustuer) - parse status message for nukiHaustuer
2017.01.24 11:17:41 5: NUKIDevice (nukiHaustuer) - readings set for nukiHaustuer
2017.01.24 11:18:04 5: NUKIDevice (nukiHaustuer) - Parse with result: {"rssi":-77,"name":"Nuki_06201309","paired":true}
2017.01.24 11:18:04 5: NUKIDevice (nukiHaustuer) - parse status message for nukiHaustuer
2017.01.24 11:18:04 5: NUKIDevice (nukiHaustuer) - readings set for nukiHaustuer
2017.01.24 11:18:21 5: NUKIDevice (nukiHaustuer) - Parse with result: {"rssi":-79,"name":"Nuki_06201309","paired":true}
2017.01.24 11:18:21 5: NUKIDevice (nukiHaustuer) - parse status message for nukiHaustuer
2017.01.24 11:18:21 5: NUKIDevice (nukiHaustuer) - readings set for nukiHaustuer
2017.01.24 11:18:30 1: PERL WARNING: Use of uninitialized value in hash element at ./FHEM/72_FRITZBOX.pm line 1419.
2017.01.24 11:18:30 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/72_FRITZBOX.pm line 1424.
2017.01.24 11:18:30 1: PERL WARNING: Use of uninitialized value in hash element at ./FHEM/72_FRITZBOX.pm line 1460.
2017.01.24 11:18:30 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/72_FRITZBOX.pm line 1460.
2017.01.24 11:18:30 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/72_FRITZBOX.pm line 1453.
2017.01.24 11:18:44 5: NUKIDevice (nukiHaustuer) - Parse with result: {"name":"Nuki_06201309","rssi":-79,"paired":true}
2017.01.24 11:18:44 5: NUKIDevice (nukiHaustuer) - parse status message for nukiHaustuer
2017.01.24 11:18:44 5: NUKIDevice (nukiHaustuer) - readings set for nukiHaustuer
2017.01.24 11:19:12 4: NUKIBridge (nuki01) - NUKIBridge_GetCheckBridgeAlive
2017.01.24 11:19:12 4: NUKIBridge (nuki01) - Send HTTP POST with URL http://192.168.178.233:8080/info?token=ge5b7e
2017.01.24 11:19:12 4: NUKIBridge (nuki01) - run NUKIBridge_Call
2017.01.24 11:19:12 4: NUKIBridge (nuki01) - Call InternalTimer for NUKIBridge_GetCheckBridgeAlive
2017.01.24 11:19:12 5: NUKIBridge (nuki01) - Response JSON: {"bridgeType": 1, "ids": {"hardwareId": 98598929, "serverId": 287592143}, "versions": {"firmwareVersion": "1.4.20", "wifiFirmwareVersion": "1.0.1"}, "uptime": 72975, "currentTime": "2017-01-24T10:19:13+00:00", "serverConnected": true, "scanResults": [{"nukiId": 102765321, "name": "Nuki_06201309", "rssi": -77, "paired": true}]}
2017.01.24 11:19:12 5: NUKIBridge (nuki01) - Response ERROR:
2017.01.24 11:19:12 5: NUKIBridge (nuki01) - Response CODE: 200
2017.01.24 11:19:12 5: NUKIBridge (nuki01) - Bridge ist online
2017.01.24 11:19:12 4: NUKIDevice (nukiHaustuer) - Received scanResults for matching NukiID 102765321 at device nukiHaustuer
2017.01.24 11:19:12 5: NUKIDevice (nukiHaustuer) - Parse with result: {"rssi":-77,"name":"Nuki_06201309","paired":true}
2017.01.24 11:19:12 5: NUKIDevice (nukiHaustuer) - parse status message for nukiHaustuer
2017.01.24 11:19:12 5: NUKIDevice (nukiHaustuer) - readings set for nukiHaustuer
2017.01.24 11:19:37 4: NUKIBridge (nuki01) - NUKIBridge_GetCheckBridgeAlive
2017.01.24 11:19:37 4: NUKIBridge (nuki01) - Send HTTP POST with URL http://192.168.178.233:8080/info?token=ge5b7e
2017.01.24 11:19:37 4: NUKIBridge (nuki01) - run NUKIBridge_Call
2017.01.24 11:19:37 4: NUKIBridge (nuki01) - Call InternalTimer for NUKIBridge_GetCheckBridgeAlive
2017.01.24 11:19:37 5: NUKIBridge (nuki01) - Response JSON: {"bridgeType": 1, "ids": {"hardwareId": 98598929, "serverId": 287592143}, "versions": {"firmwareVersion": "1.4.20", "wifiFirmwareVersion": "1.0.1"}, "uptime": 73000, "currentTime": "2017-01-24T10:19:38+00:00", "serverConnected": true, "scanResults": [{"nukiId": 102765321, "name": "Nuki_06201309", "rssi": -79, "paired": true}]}
2017.01.24 11:19:37 5: NUKIBridge (nuki01) - Response ERROR:
2017.01.24 11:19:37 5: NUKIBridge (nuki01) - Response CODE: 200
2017.01.24 11:19:37 5: NUKIBridge (nuki01) - Bridge ist online
2017.01.24 11:19:37 4: NUKIDevice (nukiHaustuer) - Received scanResults for matching NukiID 102765321 at device nukiHaustuer
2017.01.24 11:19:37 5: NUKIDevice (nukiHaustuer) - Parse with result: {"paired":true,"rssi":-79,"name":"Nuki_06201309"}
2017.01.24 11:19:37 5: NUKIDevice (nukiHaustuer) - parse status message for nukiHaustuer
2017.01.24 11:19:37 5: NUKIDevice (nukiHaustuer) - readings set for nukiHaustuer
CoolTux
Schau mal ins Log der Bridge. Also richtig das von der Bridge nicht fhem.
Das TuxNet Wiki:
https://www.cooltux.net
CoolTux
Ich habe Version 0.6.0 ins FHEM SVN geladen. Wird morgen als update zur Verfügung stehen.
Das TuxNet Wiki:
Stephan1965
nur ein kurzes Feedback zu meiner Frage:
Zitat von: Stephan1965 am 23 Januar 2017, 19:13:00
- Wenn ich auf den Knopf am Smartlock drücke, schließt das Schloß. Ich hätte gerne, dass beim erneuten Drücken (also wenn das Schloß zugesperrt ist) das Schloß wieder geöffnet wird.
Nach dem heutigen Nuki Software-Update des Smartlocks funktioniert es wieder.
Stephan
CoolTux
Kurz zur Info.
Das Nuki Modul war mein erstes 2 stufiges Modul. Da es von der Funktion her der Hue Bridge ähnelte habe ich mich daran gehalten.
Da ich aktuell an einem Danon HEOS Modul arbeite was auch 2 stufig ist und ich daher nun genau weiß wie sowas FHEM Konform arbeiten soll, werde ich in baldiger Zukunft das Nuki Modul ebenfalls FHEM Konform umbauen.
Das TuxNet Wiki:
danillo
mir ist noch nicht klar, was ich machen muss, um bei der Bridge auch den logFile lesen zu können. Bei get kann ich nur callbackList auswählen?
Cobra
Ist dein Modul auf dem neusten Stand?
Bei mir gibt es auch den Befehl get  logfile
FHEM in Docker auf Synology, CCU3,
Diverse HM-Komponenten, Netatmo, Hue, Sonos, Nuki
danillo
CoolTux
Berichte mal wenn es klappt und natürlich auch wenn es nicht klappt
Das TuxNet Wiki:
danillo
klappt nicht. Ist eine Softwarebridge, falls das etwas ausmacht
CoolTux
Ja das macht es. Die hat kein Log daher auch kein get zur Auswahl.
Mist ich muss die Doku anpassen.
Das TuxNet Wiki:
danillo
#701
ok, das erklärt's dann. Aber in der App kann ich das Protokoll auch über die Bridge aus der Ferne abrufen.
Wenn du die Doku anpasst, da hätte ich dann noch etwas. mit dem Lesen dieses Thread hab ich es ja jetzt hinbekommen, dass der Status automatisch aktualisiert wird. Aber in der Doku hatte ich das nicht gefunden. ich denke, dass das Feature jeder nutzen will. Daher sollte es in der Doku bei der Einrichtung gleich dabei stehen.
CoolTux
Mir war als wenn webhook/callback in der Doku steht. Ich schaue mir das noch mal an. Danke Dir
PS: Zur Info, es gibt nur eine offizielle Doku und das ist die Commandref. Alles andere ist optional.
Das TuxNet Wiki:
fred_feuerstein
was meinst du damit genau? ist es aktuell nicht FHEM konform?
Gruß, Fred
NEU: FHEM auf Raspberry PI 5, OS: Bookworm, mit Z-Wave RaZberry-Modul, 868CUL (WMBUS), LaCrosseCUL (Temp) und knapp 300 Devices aller Art
CoolTux
Nein. Es ist nicht wild. Es ist genau so aufgebaut wie das Hue Modul.
Aber wenn will ich es gerne richtig richtig machen. Jetzt wo ich weiß wie es geht. Mit sauberen autocreat und automatischen anlegen von Logfiles.
Das TuxNet Wiki:
