Neues Modul: ElectricityCalculator
Begonnen von Sailor, 26 August 2016, 21:05:35
Mellowback
Ja das würde mich auch mal interessieren, habe auch ab und zu negative Werte.
roelb
I have run into negative values from time to time. In my case, it happens when the reporting device erroneously reports 0 instead of the actual value, which is then used as Day1stValue, resulting in corrupted data for 2 days, or even longer if this happens on the first of the month or year.
Unfortunately, there is no way to filter out these anomalies in the calculator modules. A simple filter, controlled by an attribute such as "value_always_increases" or similar, which, if set, ignore values lower than the current reading will fix that.
Also, it might be a good idea to merge the three Calculator modules into a single generic module, there is a lot of code duplication right now, which is completely unneccessary. And the option to disable generation of certain readings would be great as well. For example, I have no need for all the cost calculations and corresponding readings, but there is no way to turn those off.
@Sailor: if you don't have time for this, I'd be willing to have a look at merging the functionality into a single generic module.
R1F800
ibt es aktuell bekannte bugs im o.g. Modul die ggf mit dem letzten update gekommen sind? Ich habe keine validen Werte mehr für die täglichen Werte, und einige Variablen kommen mir von der Benennung her "unbekannt" vor
es geht um die Kaskade Device_Counter_CounterVariablenname
Und so werden die beiden Readings GPIO26_Counter_EnergyDay 0.00700 und GPIO26_Counter_EnergyDayLast 0.01600
nicht mehr mit plaudiblen Werten gefüllt.
[code]define WPVerbrauch ElectricityCalculator GPIO26.*
attr WPVerbrauch BasicPricePerAnnum 0
attr WPVerbrauch Currency €
attr WPVerbrauch DecimalPlace 5
attr WPVerbrauch ElectricityCounterOffset 0
attr WPVerbrauch ElectricityKwhPerCounts 0.001
attr WPVerbrauch ElectricityPricePerKWh 0.2863
attr WPVerbrauch MonthOfAnnualReading 7
attr WPVerbrauch MonthlyPayment 0
attr WPVerbrauch ReadingDestination CalculatorDevice
attr WPVerbrauch SiPrefixPower W
attr WPVerbrauch alias Stromverbrauch Heizung
attr WPVerbrauch group Verbrauch
attr WPVerbrauch icon measure_power@orange
attr WPVerbrauch room HOME
attr WPVerbrauch stateFormat {sprintf("%.1f kWh",ReadingsVal("WPVerbrauch","GPIO26_Counter_CounterCurrent",99.9))}
#   DEF        GPIO26.*
#   FUUID      5c48ae88-f33f-0b1b-05ac-55db2a3fb6957fca
#   NAME       WPVerbrauch
#   NOTIFYDEV  GPIO26.*
#   NR         88
#   NTFY_ORDER 10-WPVerbrauch
#   REGEXP     GPIO26.*
#   STATE      33638.3 kWh
#   TYPE       ElectricityCalculator
#   eventCount 18
#   READINGS:
#     2025-01-16 07:50:58   GPIO26_Counter_CounterCurrent 33638.30000
#     2025-01-16 00:39:31   GPIO26_Counter_CounterDay1st 33638.29300
#     2025-01-16 00:39:31   GPIO26_Counter_CounterDayLast 33638.29200
#     2024-07-07 21:19:10   GPIO26_Counter_CounterMeter1st 31900.78300
#     2024-07-07 21:19:10   GPIO26_Counter_CounterMeterLast 31900.78200
#     2025-01-01 00:30:06   GPIO26_Counter_CounterMonth1st 33638.03400
#     2025-01-01 00:30:06   GPIO26_Counter_CounterMonthLast 33638.03300
#     2025-01-01 00:30:06   GPIO26_Counter_CounterYear1st 33638.03400
#     2025-01-01 00:30:06   GPIO26_Counter_CounterYearLast 33638.03300
#     2025-01-16 07:50:58   GPIO26_Counter_EnergyCostDay 0.00200
#     2025-01-16 00:39:31   GPIO26_Counter_EnergyCostDayLast 0.00458
#     2025-01-16 07:50:58   GPIO26_Counter_EnergyCostMeter 497.45112
#     2024-07-07 21:19:10   GPIO26_Counter_EnergyCostMeterLast 1191.66635
#     2025-01-16 07:50:58   GPIO26_Counter_EnergyCostMonth 0.07616
#     2025-01-01 00:30:06   GPIO26_Counter_EnergyCostMonthLast 234.50948
#     2025-01-16 07:50:58   GPIO26_Counter_EnergyCostYear 0.07616
#     2025-01-01 00:30:06   GPIO26_Counter_EnergyCostYearLast 1097.42569
#     2025-01-16 07:50:58   GPIO26_Counter_EnergyDay 0.00700
#     2025-01-16 00:39:31   GPIO26_Counter_EnergyDayLast 0.01600
#     2025-01-16 07:50:58   GPIO26_Counter_EnergyMeter 1737.51700
#     2024-07-07 21:19:10   GPIO26_Counter_EnergyMeterLast 3844.08500
#     2025-01-16 07:50:58   GPIO26_Counter_EnergyMonth 0.26600
#     2025-01-01 00:30:06   GPIO26_Counter_EnergyMonthLast 819.10400
#     2025-01-16 07:50:58   GPIO26_Counter_EnergyYear 0.26600
#     2025-01-01 00:30:06   GPIO26_Counter_EnergyYearLast 3833.13200
#     2025-01-16 07:50:58   GPIO26_Counter_FinanceReserve -497.45112
#     2025-01-16 07:50:58   GPIO26_Counter_MonthMeterReading 7
#     2025-01-16 07:50:58   GPIO26_Counter_PowerCurrent 13.33333
#     2025-01-16 07:50:58   GPIO26_Counter_PowerDayAver 6.31853
#     2025-01-16 06:32:02   GPIO26_Counter_PowerDayMax 22.64151
#     2025-01-16 04:22:13   GPIO26_Counter_PowerDayMin 0
#   helper:
#     gets:
#     sets:
#   system:
#     DecimalPlace %.5f
#     SecondsToday 86400
#     SiPrefixPowerFactor 1
setstate WPVerbrauch 33638.3 kWh
setstate WPVerbrauch 2025-01-16 07:50:58 .GPIO26_Counter_LastDV 0.00100
setstate WPVerbrauch 2025-01-16 07:50:58 .GPIO26_Counter_LastDt 270
setstate WPVerbrauch 2025-01-16 07:50:58 .GPIO26_Counter_LastUpdateTimestampUnix 1737010258
setstate WPVerbrauch 2025-01-16 07:50:58 .GPIO26_Counter_PowerDayCount 6
setstate WPVerbrauch 2025-01-16 07:50:58 .GPIO26_Counter_PowerDaySum 37.91115
setstate WPVerbrauch 2025-01-16 07:50:58 .GPIO26_Counter_PrevRead 33638.30000
setstate WPVerbrauch 2025-01-16 07:50:58 .ReadingDestinationDeviceName WPVerbrauch
setstate WPVerbrauch 2025-01-16 07:50:58 GPIO26_Counter_CounterCurrent 33638.30000
setstate WPVerbrauch 2025-01-16 00:39:31 GPIO26_Counter_CounterDay1st 33638.29300
setstate WPVerbrauch 2025-01-16 00:39:31 GPIO26_Counter_CounterDayLast 33638.29200
setstate WPVerbrauch 2024-07-07 21:19:10 GPIO26_Counter_CounterMeter1st 31900.78300
setstate WPVerbrauch 2024-07-07 21:19:10 GPIO26_Counter_CounterMeterLast 31900.78200
setstate WPVerbrauch 2025-01-01 00:30:06 GPIO26_Counter_CounterMonth1st 33638.03400
setstate WPVerbrauch 2025-01-01 00:30:06 GPIO26_Counter_CounterMonthLast 33638.03300
setstate WPVerbrauch 2025-01-01 00:30:06 GPIO26_Counter_CounterYear1st 33638.03400
setstate WPVerbrauch 2025-01-01 00:30:06 GPIO26_Counter_CounterYearLast 33638.03300
setstate WPVerbrauch 2025-01-16 07:50:58 GPIO26_Counter_EnergyCostDay 0.00200
setstate WPVerbrauch 2025-01-16 00:39:31 GPIO26_Counter_EnergyCostDayLast 0.00458
setstate WPVerbrauch 2025-01-16 07:50:58 GPIO26_Counter_EnergyCostMeter 497.45112
setstate WPVerbrauch 2024-07-07 21:19:10 GPIO26_Counter_EnergyCostMeterLast 1191.66635
setstate WPVerbrauch 2025-01-16 07:50:58 GPIO26_Counter_EnergyCostMonth 0.07616
setstate WPVerbrauch 2025-01-01 00:30:06 GPIO26_Counter_EnergyCostMonthLast 234.50948
setstate WPVerbrauch 2025-01-16 07:50:58 GPIO26_Counter_EnergyCostYear 0.07616
setstate WPVerbrauch 2025-01-01 00:30:06 GPIO26_Counter_EnergyCostYearLast 1097.42569
setstate WPVerbrauch 2025-01-16 07:50:58 GPIO26_Counter_EnergyDay 0.00700
setstate WPVerbrauch 2025-01-16 00:39:31 GPIO26_Counter_EnergyDayLast 0.01600
setstate WPVerbrauch 2025-01-16 07:50:58 GPIO26_Counter_EnergyMeter 1737.51700
setstate WPVerbrauch 2024-07-07 21:19:10 GPIO26_Counter_EnergyMeterLast 3844.08500
setstate WPVerbrauch 2025-01-16 07:50:58 GPIO26_Counter_EnergyMonth 0.26600
setstate WPVerbrauch 2025-01-01 00:30:06 GPIO26_Counter_EnergyMonthLast 819.10400
setstate WPVerbrauch 2025-01-16 07:50:58 GPIO26_Counter_EnergyYear 0.26600
setstate WPVerbrauch 2025-01-01 00:30:06 GPIO26_Counter_EnergyYearLast 3833.13200
setstate WPVerbrauch 2025-01-16 07:50:58 GPIO26_Counter_FinanceReserve -497.45112
setstate WPVerbrauch 2025-01-16 07:50:58 GPIO26_Counter_MonthMeterReading 7
setstate WPVerbrauch 2025-01-16 07:50:58 GPIO26_Counter_PowerCurrent 13.33333
setstate WPVerbrauch 2025-01-16 07:50:58 GPIO26_Counter_PowerDayAver 6.31853
setstate WPVerbrauch 2025-01-16 06:32:02 GPIO26_Counter_PowerDayMax 22.64151
setstate WPVerbrauch 2025-01-16 04:22:13 GPIO26_Counter_PowerDayMin 0
[/code]
Summende Grüße
Ingo
Sailor
Hallo R1F800 (Ist das ein integrierter Schaltkreis? ;) )
Zitat von: R1F800 am 17 Januar 2025, 07:39:55Gibt es aktuell bekannte bugs im o.g. Modul die ggf mit dem letzten update gekommen sind?
Ich habe schon seit Ewigkeiten kein Update mehr an dies XCalculator Modulen vorgenommen.
Zitat von: R1F800 am 17 Januar 2025, 07:39:55Ich habe keine validen Werte mehr für die täglichen Werte, und einige Variablen kommen mir von der Benennung her "unbekannt" vor
Auf den ersten Blick sehe ich auch nichts.
Eine wirklich aussagefähige Beurteilung kann ich nur machen, wenn ich einen Graph des GPIO26_Counter_CounterCurrent sehe, seit dem Zeitpunkt wo der Fehler aufgetreten ist.
    Sailor
Man wird immer besser...
R1F800
just zum 01.01.25 hat sich die Datenlage pulverisiert
Summende Grüße
Ingo
Sailor
Moin
Zitat von: R1F800 am 17 Januar 2025, 09:43:10just zum 01.01.25 hat sich die Datenlage pulverisiert
Prima - Einen Schritt weiter...
Dann bitte auch noch einen Graphen der Quelle: GPIO26
    Sailor
R1F800
#801
    Sailor
Was für nen Graphen?
Du siehst im obigen Bild Tages und Monatswerte. Den GPIO26 habe ich nicht einzeln gelogged. Macht ja auch keinen Sinn (ImpulSE)
Habe gestern mal die Impulse gelogged. Wenn ich jetzt nicht ganz blind bin sehe ich kaum Impulse im Log.
2025-01-19_12:41:34 GPIO26 Pinlevel: low
2025-01-19_12:41:34 GPIO26 off
2025-01-19_12:41:34 GPIO26 Toggle: on
2025-01-19_12:41:34 GPIO26 Counter: 33638340
2025-01-20_07:37:04 GPIO26 Pinlevel: low
2025-01-20_07:37:04 GPIO26 off
2025-01-20_07:37:04 GPIO26 Toggle: off
2025-01-20_07:37:04 GPIO26 Counter: 33638369
Summende Grüße
Ingo
Sailor
Wieviel kWh repräsentiert die kleinste Stelle in deinem Counter?
Nur zur Sicherheit - Den Calculator hast du mit GPIO26:Counter:.* definiert? Das muss ein stetig steigender Zähler sein.
Generell ist natürlich eines klar wie Kloßbrühre: Liefert der Counter nix, rechnet auch der Calculator nix.
Nochmal: Mache mal einen Graphen von GPIO26:Counter.
Gruss
    Sailor
R1F800
Gruss
    Sailor
100 Impulse 1 kWh
je tag aktuel round about 70kWh > 7000 Impulse
Summende Grüße
Ingo
Sailor
Du verbrauchst 25,55 MWh Strom im Jahr?????????  :o
Das wären bei 26,64ct-kWh glatte 6806,52€ pro Jahr - Alter Schwede - Das kann doch nicht stimmen!
Nichts desto trotz, wenn 100 Pulse pro 1kWh richtig sind, dann muss
attr WPVerbrauch ElectricityKwhPerCounts 1/100 = 0.01
stehen und nicht 0.001.
   Sailor
R1F800
Ja, die 70kWh sind nur im Winter und nur bei dieser aktuellen Kälte > Wärmepumpe eben.
Nene .. habe mich vertippt ... fehlt eine 0 es sind 1000 Impulse je kWh (Ist ein DSZE15 von Eltako)
Summende Grüße
Ingo
Sailor
Moin
Zitat von: R1F800 am 20 Januar 2025, 12:08:45Ja, die 70kWh sind nur im Winter und nur bei dieser aktuellen Kälte > Wärmepumpe eben.
Ok dann kommen mir bei
sowie
Zitat von: R1F800 am 19 Januar 2025, 12:02:552025-01-19_12:41:34 GPIO26 Counter: 33638340
29Wh in 5h viel zu wenig vor. Hier liegt der Wurm eindeutig beim GPIO26 - device.
Verdacht: Kann es sein, dass der GPIO:Counter bereits in kWh und nicht in Wh hochgezählt hat?
29kWh sind mir da schon viel wahrscheinlicher...
    Sailor
uxtuner
bei mir ist nach einem Zählerwechsel Chaos angesagt  >:(
Kann ich irgendwie alle readings auf 0 resetten und von vorne beginnen?
  Uwe
Intel NUC (VDR & FHEM & HA & AgentDVR), QNAP TS-453, Esera OneWire (8-fach Schalter, Hub, Controller II), EDS 1-Wire Server, Mosquitto Server, Wolf CGW-2 m. ISM7MQTT, Shelly (Plug S, H&T, 2.5, 1 PM, Floodsensor/Rauchmelder), Tado (Thermostat V3+) etc.
uxtuner
   DEF        EVUCounter:EVU_in:.*
   FUUID      5f032cb1-f33f-55bb-ef52-f33b8cbf95d116d3
   NAME       myPVBezugCalculator
   NOTIFYDEV  EVUCounter
   NR         312
   NTFY_ORDER 10-myPVBezugCalculator
   REGEXP     EVUCounter:EVU_in:.*
   STATE      5.940 kWh
   eventCount 2
     2025-02-12 15:28:00   EVUCounter_EVU_in_CounterCurrent 5.940
     2025-02-12 00:01:07   EVUCounter_EVU_in_CounterDay1st 1.480
     2025-02-12 00:01:07   EVUCounter_EVU_in_CounterDayLast 1.480
     2024-05-01 00:04:38   EVUCounter_EVU_in_CounterMeter1st 9362.980
     2024-05-01 00:04:38   EVUCounter_EVU_in_CounterMeterLast 9362.980
     2025-02-01 00:02:55   EVUCounter_EVU_in_CounterMonth1st 10626.420
     2025-02-01 00:02:55   EVUCounter_EVU_in_CounterMonthLast 10626.390
     2025-01-01 00:01:49   EVUCounter_EVU_in_CounterYear1st 10368.550
     2025-01-01 00:01:49   EVUCounter_EVU_in_CounterYearLast 10368.500
     2025-02-12 15:28:00   EVUCounter_EVU_in_EnergyCostDay 1.472
     2025-02-12 00:01:07   EVUCounter_EVU_in_EnergyCostDayLast 0.053
     2025-02-12 15:28:00   EVUCounter_EVU_in_EnergyCostMeter -3087.823
     2024-05-01 00:04:38   EVUCounter_EVU_in_EnergyCostMeterLast 50.404
     2025-02-12 15:28:00   EVUCounter_EVU_in_EnergyCostMonth -3504.758
     2025-02-01 00:02:55   EVUCounter_EVU_in_EnergyCostMonthLast 85.087
     2025-02-12 15:28:00   EVUCounter_EVU_in_EnergyCostYear -3419.661
     2025-01-01 00:01:49   EVUCounter_EVU_in_EnergyCostYearLast 382.226
     2025-02-12 15:28:00   EVUCounter_EVU_in_EnergyDay 4.460
     2025-02-12 00:01:07   EVUCounter_EVU_in_EnergyDayLast 0.160
     2025-02-12 15:28:00   EVUCounter_EVU_in_EnergyMeter -9357.040
     2024-05-01 00:04:38   EVUCounter_EVU_in_EnergyMeterLast 152.740
     2025-02-12 15:28:00   EVUCounter_EVU_in_EnergyMonth -10620.480
     2025-02-01 00:02:55   EVUCounter_EVU_in_EnergyMonthLast 257.840
     2025-02-12 15:28:00   EVUCounter_EVU_in_EnergyYear -10362.610
     2025-01-01 00:01:49   EVUCounter_EVU_in_EnergyYearLast 1158.260
     2025-02-12 15:28:00   EVUCounter_EVU_in_FinanceReserve 3087.823
     2025-02-12 15:28:00   EVUCounter_EVU_in_MonthMeterReading 10
     2025-02-12 15:28:00   EVUCounter_EVU_in_PowerCurrent 0.000
     2025-02-12 15:28:00   EVUCounter_EVU_in_PowerDayAver 815531.941
     2025-02-12 12:01:06   EVUCounter_EVU_in_PowerDayMax 222967741.935
     2025-02-12 11:59:33   EVUCounter_EVU_in_PowerDayMin -68888691
   helper:
     gets:
     sets:
   system:
     DecimalPlace %.3f
     SecondsToday 86400
   Currency   €
   DecimalPlace 3
   ElectricityPricePerKWh 0.33
   MonthOfAnnualReading 5
   MonthlyPayment 0
   SiPrefixPower W
   alias      Strom Bezug
   group      PV
   room       System->Calculator
   stateFormat EVUCounter_EVU_in_CounterCurrent kWh
   DEF        EVUCounter:EVU_out:.*
   FUUID      5f032c6f-f33f-55bb-6501-915aed641164f1a5
   NAME       myPVLieferungCalculator
   NR         311
   NTFY_ORDER 10-myPVLieferungCalculator
   REGEXP     EVUCounter:EVU_out:.*
   STATE      1.6000 kWh
   eventCount 2
     2025-02-12 15:28:00   EVUCounter_EVU_out_CounterCurrent 1.6000
     2025-02-12 00:01:07   EVUCounter_EVU_out_CounterDay1st 0.2400
     2025-02-12 00:01:07   EVUCounter_EVU_out_CounterDayLast 0.2400
     2024-05-01 00:02:22   EVUCounter_EVU_out_CounterMeter1st 25496.5200
     2024-05-01 00:02:22   EVUCounter_EVU_out_CounterMeterLast 25496.5200
     2025-02-01 00:03:01   EVUCounter_EVU_out_CounterMonth1st 29439.6800
     2025-02-01 00:03:01   EVUCounter_EVU_out_CounterMonthLast 29439.6800
     2025-01-01 00:01:49   EVUCounter_EVU_out_CounterYear1st 29304.5100
     2025-01-01 00:01:49   EVUCounter_EVU_out_CounterYearLast 29304.5100
     2025-02-12 15:28:00   EVUCounter_EVU_out_EnergyCostDay 0.1303
     2025-02-12 00:01:07   EVUCounter_EVU_out_EnergyCostDayLast 0.0211
     2025-02-12 15:28:00   EVUCounter_EVU_out_EnergyCostMeter -2442.4133
     2024-05-01 00:02:22   EVUCounter_EVU_out_EnergyCostMeterLast 573.2777
     2025-02-12 15:28:00   EVUCounter_EVU_out_EnergyCostMonth -2820.1681
     2025-02-01 00:03:01   EVUCounter_EVU_out_EnergyCostMonthLast 12.9493
     2025-02-12 15:28:00   EVUCounter_EVU_out_EnergyCostYear -2807.2188
     2025-01-01 00:01:49   EVUCounter_EVU_out_EnergyCostYearLast 497.9282
     2025-02-12 15:28:00   EVUCounter_EVU_out_EnergyDay 1.3600
     2025-02-12 00:01:07   EVUCounter_EVU_out_EnergyDayLast 0.2200
     2025-02-12 15:28:00   EVUCounter_EVU_out_EnergyMeter -25494.9200
     2024-05-01 00:02:22   EVUCounter_EVU_out_EnergyMeterLast 5984.1100
     2025-02-12 15:28:00   EVUCounter_EVU_out_EnergyMonth -29438.0800
     2025-02-01 00:03:01   EVUCounter_EVU_out_EnergyMonthLast 135.1700
     2025-02-12 15:28:00   EVUCounter_EVU_out_EnergyYear -29302.9100
     2025-01-01 00:01:49   EVUCounter_EVU_out_EnergyYearLast 5197.5800
     2025-02-12 15:28:00   EVUCounter_EVU_out_FinanceReserve 2442.4133
     2025-02-12 15:28:00   EVUCounter_EVU_out_MonthMeterReading 10
     2025-02-12 15:28:00   EVUCounter_EVU_out_PowerCurrent 0.0000
     2025-02-12 15:28:00   EVUCounter_EVU_out_PowerDayAver 94.6606
     2025-02-12 12:51:14   EVUCounter_EVU_out_PowerDayMax 2392.0266
     2025-02-12 00:01:07   EVUCounter_EVU_out_PowerDayMin 0.0000
     2021-07-23 19:54:05   EVUCounter_EVU_out_WFRDayMax 0
     2021-07-23 19:54:05   EVUCounter_EVU_out_WFRDayMin 0
   helper:
     gets:
     sets:
   system:
     DecimalPlace %.4f
     SecondsToday 86400
   Currency   €
   DecimalPlace 4
   ElectricityPricePerKWh 0.0958
   MonthlyPayment 0
   SiPrefixPower W
   alias      PV Lieferung
   group      PV
   stateFormat EVUCounter_EVU_out_CounterCurrent kWh
  Uwe
Gisbert
Hallo Sailor,
ich nutze deine Module sehr gerne für diverse Energieauswertungen. Alle meine Devices funktionieren wie sie sollen, bis auf eins, was alle paar Tage bis Wochen negative Verbräuche anzeigt.
Das Reading, das ich überwache heißt Engergy_WH und stammt von einem PZEM-004Tv30-Multiple, der an einem ESP8266 hängt und mit ESPEasy ausgelesen wird. Der Wert von Energy_WH im ESP als auch im MQTT-Device in Fhem steigt kontinuierlich an, bis es zu einem Fehler kommt und der Wert plötzlich deutlich kleiner wird.
Als Resultat wird im ElectricityCalculator-Device ein kleinerer Wert (meistens dann negativ, da die Tagesverbräuche so um 1~2 kWh liegen) angezeigt. Die Spannungs- und Stromwerte im PZEM-004Tv30-Multiple sind unauffällig und passen auch zur angezeigten Leistung.
Die Ursache liegt also ganz eindeutig im fehlerhaften Reading Energy_WH im MQTT-Device. Gibt es eine Idee, wie ich damit umgehen kann (außer händischer Korrektur)?
Im Anhang ist ein Bild zu sehen, wie sicher der Readingswert Energy_WH sprunghaft ändert.
Viele Grüße Gisbert
Proxmox | UniFiRHASSPY | DEYE | JK-BMS | ESPHome | Panasonic Heishamon | Homematic, VCCU, HMUART | ESP8266 | ATtiny85 | Wasser-, Stromzähler | tuya local | Wlan-Kamera | SIGNALduino, Rauchmelder FA21/22RF
