Signalduino Version 3.3.1 / 3.3.2 / 3.3.3-dev
Begonnen von Sidey, 02 Oktober 2016, 23:39:11
gandi1791
Zitat von: HomeAuto_User am 03 Januar 2019, 00:49:43
@gandi1791
Deine Nachrichten werden in der aktuellen DEV-r33 decodiert.
2019.01.03 00:45:31 4: sduino_dummy/msg get raw: MS;P1=1138;P2=-723;P3=583;P4=-1285;P5=-7166;D=351234341234341212341212123412343412341234341234343434343434343434;CP=3;SP=5;R=247;O;m2;
2019.01.03 00:45:31 4: sduino_dummy: Matched MS Protocol id 1 -> Conrad RSL v1
2019.01.03 00:45:31 4: sduino_dummy: Decoded MS Protocol id 1 dmsg P1#9374A400 length 32 RSSI = -78.5
2019.01.03 00:45:31 4: sduino_dummy RSL_Parse Message: 9374A400
2019.01.03 00:45:31 4: SD_RSL Message parsed Devicecode: 74A400 Buttoncode: 19
2019.01.03 00:45:31 4: RSL button return/result: ID: 74A400 93 DEVICE: 74A400 4 4 ACTION: on
2019.01.03 00:45:31 4: sduino_dummy Parse: Device: 74A400_4_4  Action: on
2019.01.03 00:45:31 3: sduino_dummy RSL_Parse UNDEFINED Remotebutton send to define: 74A400_4_4
2019.01.03 00:46:10 4: sduino_dummy/msg get raw: MS;P1=1154;P2=-697;P3=559;P4=-1303;P5=-7173;D=351234341234341212341212123412343412341234341234343434343434343434;CP=3;SP=5;R=247;O;
2019.01.03 00:46:10 4: sduino_dummy: Matched MS Protocol id 1 -> Conrad RSL v1
2019.01.03 00:46:10 4: sduino_dummy: Decoded MS Protocol id 1 dmsg P1#9374A400 length 32 RSSI = -78.5
2019.01.03 00:46:10 4: sduino_dummy RSL_Parse Message: 9374A400
2019.01.03 00:46:10 4: SD_RSL Message parsed Devicecode: 74A400 Buttoncode: 19
2019.01.03 00:46:10 4: RSL button return/result: ID: 74A400 93 DEVICE: 74A400 4 4 ACTION: on
2019.01.03 00:46:10 4: sduino_dummy Parse: Device: 74A400_4_4  Action: on
2019.01.03 00:46:10 3: sduino_dummy RSL_Parse UNDEFINED Remotebutton send to define: 74A400_4_4
2019.01.03 00:46:47 4: sduino_dummy/msg get raw: MS;P0=561;P1=-1291;P2=-7158;P3=1174;P4=-688;D=023401013401013434013434340134010134013401013401010101010101010101;CP=0;SP=2;R=248;m1;
2019.01.03 00:46:47 4: sduino_dummy: Matched MS Protocol id 1 -> Conrad RSL v1
2019.01.03 00:46:47 4: sduino_dummy: Decoded MS Protocol id 1 dmsg P1#9374A400 length 32 RSSI = -78
2019.01.03 00:46:47 4: sduino_dummy RSL_Parse Message: 9374A400
2019.01.03 00:46:47 4: SD_RSL Message parsed Devicecode: 74A400 Buttoncode: 19
2019.01.03 00:46:47 4: RSL button return/result: ID: 74A400 93 DEVICE: 74A400 4 4 ACTION: on
2019.01.03 00:46:47 4: sduino_dummy Parse: Device: 74A400_4_4  Action: on
2019.01.03 00:46:47 3: sduino_dummy RSL_Parse UNDEFINED Remotebutton send to define: 74A400_4_4
Hast du eine Black oder Withelist aktiv?
Wiederum kann ich bestätigen wenn ich aus dem Device 74A400_4_4 sende, so wird ein neues Device E94800_4_4 angelegt und dies nimmt auch den Status bzw. die Befehle von 74A400_4_4 an.
--> muss genauer geprüft werden.
MfG
Ich habe eine Whitelist aktiv (ID=75).
fhem auf proxmox container
minicul>ESP-01>868>MAX!; minicul>ESP-01>433>SignalDuino>RSL/Jaro/IT
ESP-01>HM-MOD-RPI-PCB>HM
MySensorsGW>NodeMCU>Sensoren, Aktoren, div.
Broadlink RM Pro+ >433 Steckdosen, IR TV/Receiver; Hue, Alexa Echo Plus, div.Dot 2/3/4;DVB-T Stick>mqtt>TFA 30.3180
Sidey
Bitte aktiviere auch die ID 1.
Grüße Sidey
Gesendet von meinem Moto Z (2) mit Tapatalk
Signalduino, Homematic, Raspberry Pi, Mysensors, MQTT, Alexa, Docker, AlexaFhem,zigbee2mqtt
Maintainer von: SIGNALduino, fhem-docker, alexa-fhem-docker, fhempy-docker
dmq
#1127
ich habe schon viel Zeit in die Wiki und Forum Suche gesteckt, bin aber bisher nicht fündig geworden.
Ich habe SignalESP in der aktuellen stable Version im Einsatz - zurzeit aufgrund IT. Damit ist alles gut. Nun würde ich gerne einen weiteren Sensor auf dieses Gateway abbilden (ich muss meine USB Anbindungen leider los werden): OWL +USB (induktiver Strommesser im Zählerkasten - siehe unten (1) und (2), 433,XX MHZ). Zurzeit habe ich die gesamte Station (Empfänger) und die Sendeeinheit im Zählerkasten im Einsatz. In meiner Recherche habe ich gefunden, dass OWL +USB auch von RFXCom bspw. RFXTRX unterstützt (3) wird und somit auch von dem "Clone" RF Link (4).
Nun würde ich natürlich viel lieber den SignalESP verwenden. Hat jemand schon mal einen OWL angebunden? Wäre das ansonsten mit viel Aufwand verbunden? Ich habe eine RTLSDR zur Hand (den wird es aber wahrscheinlich gar nicht brauchen, da das Protokoll ja bereits in öffentlichen Quellen einsehbar ist oder auch der Signal das übernehmen könnte (?), ...) - habe aber bisher kein Protokoll abgebildet (wird wahrscheinlich eine ordentliche Einstiegshürde sein). Ansonsten würde ich den RF Link wahrscheinlich nachbauen - der RFXTRX ist mir a) zu teuer und b) bietet er auch keine WLAN-Umwandlung.
Hoffe das ist hier im richtigen Thread, ansonsten mache ich einen neuen auf.
Danke vorab,
dmq
(1): http://www.theowl.com/index.php/energy-monitors/standalone-monitors/owl-usb/
(2): https://www.meintechblog.de/2014/01/update-smart-metering-mit-fhem-und-owl-usb/
(3): https://wiki.fhem.de/wiki/RFXtrx
(4): http://www.rflink.nl/blog2/devlist
HomeAuto_User
Hallo dmq,
verstehe ich es richtig, das du dein Vorhaben beim SIGNALesp integrieren würdest um nur die SendeEinheit abzugreifen weil du keine direkte USB-Anschlussmöglichkeiten mehr besitzt?
Wenn ja, dann eröffne bitte in Github
https://github.com/RFD-FHEM/RFFHEM/issues ein passendes Issues. Hierüber im Forum wird es zu unübersichtlich.
Liebe Grüße
"Developer" heißt nicht, das man alles wissen kann!
- FHEM v5.9 | Rasberry PI 3
- radino CC1101 433Mhz (SIGNALduino)| - radino CC1101 868Mhz (CUL) | nano 433Mhz (SIGNALduino) - Sensoren: purer Dschungel querbeet
Ralf9
@HomeAuto_User
möchtest Du die ID 91.1 als ergänzung zur ID 91 commiten, oder soll ich es machen?
https://forum.fhem.de/index.php/topic,58397.msg878684.html#msg878684
Gruß Ralf
HomeAuto_User
@Ralf9
Zitat von: Ralf9 am 03 Januar 2019, 13:30:54
@HomeAuto_User
ich werde es heute Abend vornehmen und ggf demnächst auch die Auswertung mit einbinden in das Modul.
Mfg Marco
dmq
Hi HomeAuto_User,
ja, das ist richtig. Ich schreib dann später etwas dazu ins github.
Lieben Dank,
dmq
Doublefant
Zitat von: Sidey am 02 Januar 2019, 21:01:14
Was wurde da angepasst, hast Du details?
Es sieht so aus, als ob alle 5 Minuten etwas von deinem Sensor erfasst wurde.
Für Autocreate haben wir aktuell eine Schwellwert von 2 Nachrichten im Zeitraum von 3 Minuten angegeben.
Wenn Du das autocreate Attribut (https://fhem.de/commandref_DE.html#autocreate) auf 6 Minuten anpasst, sollte es klappen. Habe selbst nie mit dem Attribut gearbeitet, aber mit SD_WS:2:360 sollte dein Sensor angelegt werden.
Weisst Du ob der Sensor eventuell öfters sendet?
Details zur Anpassung habe ich, ist aber nicht nötig,
das passende Protokoll ist beim Signalduino schon vorhanden, beim CUL musste ich es mir basteln.
Der Sensor sendet konstant alle 5min, eine Lerntaste für manuelles Senden gibt es nicht am Sensor.
Vielen Dank für den Hinweis mit dem autocreate Attribut!
Das war es  :D  THX@Sidey
gesetzt, 10min gewartet, alles wurde automatisch angelegt und die Daten kommen, perfekt.
dmq
Ist nun im github unter:
Protokoll für OWL USB (CM1XX) - Oregon Scientific v3(?) #472
https://github.com/RFD-FHEM/RFFHEM/issues/472
Scheinbar wird Oregon Scientific v3 (?) eingesetzt. Alles weitere dann aber gerne im github.
Danke euch schon einmal.
gandi1791
Grüße Sidey
ID 1 aktiviert, erfolglos.
Whitelist komplett deaktiviert, erfolglos.
Habe aber ein Phänomen beobachtet:
Die über die Fernbedienung automatisch angelegten Devices werden von der Broadlink (mit der ich die Aktoren derzeit schalte - aber eben nicht sehr stabil) geschaltet.
Also Broadlink schaltet Schalter 1 ein => SD_RSL Device 1 wird in fhem eingeschaltet.
MfG
Würde es was bringen ein Device mit E94800_4_4 anzulegen?
HomeAuto_User
Bitte gib uns ein paar RAWMSG sobald du verbose 4 aktiv hast.
Es kann sein, das deine angelegten Devices nicht geschalten werden weil der Code anders gesendet wird als emfpangen.
---> siehe
gandi1791
set RSL_74A400_1_1 on
Log:
2019.01.03 20:17:58 4: SignalDuinoV1/set: sending via SendMsg: SR;R=6;P0=560;P1=-6160;P2=1120;P3=-560;P4=-1120;D=0123040404232323042323230423040423042304042304040404040404040404;
2019.01.03 20:17:59 4: SignalDuinoV1 SendrawFromQueue: msg=SR;R=6;P0=560;P1=-6160;P2=1120;P3=-560;P4=-1120;D=0123040404232323042323230423040423042304042304040404040404040404;
2019.01.03 20:17:59 4: SignalDuinoV1/msg READ: SR;FF uart log6�>R=6;P0=560;P1=-6160;P2=1120;P3=-560;P4=-1120;D=0123040404232323042323230423040423042304042304040404040404040404;
2019.01.03 20:17:59 4: SignalDuinoV1/read sendraw answer: SR;FF uart log6�>R=6;P0=560;P1=-6160;P2=1120;P3=-560;P4=-1120;D=0123040404232323042323230423040423042304042304040404040404040404;
2019.01.03 20:17:59 4: SignalDuinoV1/HandleWriteQueue: nothing to send, stopping timer
2019.01.03 20:18:03 4: SignalDuinoV1/msg READredu: MS;P3=488;P5=-1930;P6=-3886;P7=-9166;D=37353635363636353635353535363536353535353535353536353636363535353635363636;CP=3;SP=7;R=243;O;m2;
2019.01.03 20:18:03 4: SignalDuinoV1/msg READredu: MS;P3=474;P5=-1925;P6=-3883;P7=-9166;D=37353635363636353635353535363536353535353535353536353636363535353635363636;CP=3;SP=7;R=243;m1;
2019.01.03 20:18:03 4: SignalDuinoV1/msg READredu: MS;P1=468;P2=-1949;P3=-3878;P4=-9104;D=14121312131313121312121212131213121212121212121213121313131212121312131313;CP=1;SP=4;R=0;O;m2;
2019.01.03 20:18:03 4: SignalDuinoV1/msg READredu: MS;P1=468;P2=-1949;P3=-3878;P4=-9104;D=14121312131313121312121212131213121212121212121213121313131212121312131313;CP=1;SP=4;R=0;m1;
set RSL_74A400_1_1 off
Log:
2019.01.03 20:18:08 4: SignalDuinoV1/set: sending via SendMsg: SR;R=6;P0=560;P1=-6160;P2=1120;P3=-560;P4=-1120;D=0123040404040404232323230423040423042304042304040404040404040404;
2019.01.03 20:18:08 4: SignalDuinoV1 SendrawFromQueue: msg=SR;R=6;P0=560;P1=-6160;P2=1120;P3=-560;P4=-1120;D=0123040404040404232323230423040423042304042304040404040404040404;
2019.01.03 20:18:09 4: SignalDuinoV1/msg READ: SR;FF uart log6�>R=6;P0=560;P1=-6160;P2=1120;P3=-560;P4=-1120;D=0123040404040404232323230423040423042304042304040404040404040404;
2019.01.03 20:18:09 4: SignalDuinoV1/read sendraw answer: SR;FF uart log6�>R=6;P0=560;P1=-6160;P2=1120;P3=-560;P4=-1120;D=0123040404040404232323230423040423042304042304040404040404040404;
2019.01.03 20:18:09 4: SignalDuinoV1/HandleWriteQueue: nothing to send, stopping timer
Ralf9
@gandi1791
Du kannst mal versuchen ob Du die empfangene dmsg mit sendMsg wieder senden kannst
die dmsg P1#9374A400 ergibt dann
set sduino sendMsg P1#0x9374A400#R6
So wies aussieht passen die Tastencodes, die momentan im RSL Modul drin sind, nicht.
Ich würde gern die Tastencodes der 12 Kanal Fernbedienung in das  RSL Modul eintragen, dazu benötige ich Deine Hilfe
Der Tastencode sind die ersten beiden Hexziffern der dmsg. Hier z.B. P1#9374A400 ist es 93
Z.B. bei Kanal (Schiebeschalter) 4 auf Taste 3 "on"
dann kommt Hex 0x93 nach
$RSLCodes[4][3][1] =  0x93;   # IV   3 / on
    # Schiebeschalter/Kanal [I - IV] , Tastenpaar [1 - 3 u 4=All] , an-aus [1 - 0]
    $RSLCodes[1][1][0] =  0x;   # I    1 / off
    $RSLCodes[1][1][1] =  0x;   # I    1 / on
    $RSLCodes[1][2][0] =  0x;   # I    2 / off
    $RSLCodes[1][2][1] =  0x;   # I    2 / on
    $RSLCodes[1][3][0] =  0x;   # I    3 / off
    $RSLCodes[1][3][1] =  0x;   # I    3 / on
    $RSLCodes[1][4][0] =  0x;   # I    4 / off  All
    $RSLCodes[1][4][1] =  0x;   # I    4 / on   All
    $RSLCodes[2][1][0] =  0x;   # II   1 / off
    $RSLCodes[2][1][1] =  0x;   # II   1 / on
    $RSLCodes[2][2][0] =  0x;   # II   2 / off
    $RSLCodes[2][2][1] =  0x;   # II   2 / on
    $RSLCodes[2][3][0] =  0x;   # II   3 / off
    $RSLCodes[2][3][1] =  0x;   # II   3 / on
    $RSLCodes[2][4][0] =  0x;   # II   4 / off All
    $RSLCodes[2][4][1] =  0x;   # II   4 / on  All
    $RSLCodes[3][1][0] =  0x;   # III  1 / off
    $RSLCodes[3][1][1] =  0x;   # III  1 / on
    $RSLCodes[3][2][0] =  0x;   # III  2 / off
    $RSLCodes[3][2][1] =  0x;   # III  2 / on
    $RSLCodes[3][3][0] =  0x;   # III  3 / off
    $RSLCodes[3][3][1] =  0x;   # III  3 / on
    $RSLCodes[3][4][0] =  0x;   # III  4 / off All
    $RSLCodes[3][4][1] =  0x;   # III  4 / on  All
    $RSLCodes[4][1][0] =  0x;   # IV   1 / off
    $RSLCodes[4][1][1] =  0x;   # IV   1 / on
    $RSLCodes[4][2][0] =  0x;   # IV   2 / off
    $RSLCodes[4][2][1] =  0x;   # IV   2 / on
    $RSLCodes[4][3][0] =  0x;   # IV   3 / off
    $RSLCodes[4][4][0] =  0x;   # IV   4 / off All
    $RSLCodes[4][4][1] =  0x;   # IV   4 / on All
Gruß Ralf
gandi1791
#1138
    $RSLCodes[1][1][0] =  0x81;   # I    1 / off
    $RSLCodes[1][1][1] =  0x8E;   # I    1 / on
    $RSLCodes[1][2][0] =  0xAE;   # I    2 / off
    $RSLCodes[1][2][1] =  0xA6;   # I    2 / on
    $RSLCodes[1][3][0] =  0x9E;   # I    3 / off
    $RSLCodes[1][3][1] =  0x96;   # I    3 / on
    $RSLCodes[1][4][0] =  0xA3;   # I    4 / off  All
    $RSLCodes[1][4][1] =  0x93;   # I    4 / on   All
    $RSLCodes[2][1][0] =  0x8D;   # II   1 / off
    $RSLCodes[2][1][1] =  0x85;   # II   1 / on
    $RSLCodes[2][2][0] =  0xA5;   # II   2 / off
    $RSLCodes[2][2][1] =  0xA9;   # II   2 / on
    $RSLCodes[2][3][0] =  0x95;   # II   3 / off
    $RSLCodes[2][3][1] =  0x99;   # II   3 / on
    $RSLCodes[2][4][0] =  0xA3;   # II   4 / off All
    $RSLCodes[2][4][1] =  0x93;   # II   4 / on  All
    $RSLCodes[3][1][0] =  0x84;   # III  1 / off
    $RSLCodes[3][1][1] =  0x88;   # III  1 / on
    $RSLCodes[3][2][0] =  0xA8;   # III  2 / off
    $RSLCodes[3][2][1] =  0xA0;   # III  2 / on
    $RSLCodes[3][3][0] =  0x98;   # III  3 / off
    $RSLCodes[3][3][1] =  0x90;   # III  3 / on
    $RSLCodes[3][4][0] =  0xA3;   # III  4 / off All
    $RSLCodes[3][4][1] =  0x93;   # III  4 / on  All
    $RSLCodes[4][1][0] =  0x8A;   # IV   1 / off
    $RSLCodes[4][1][1] =  0x82;   # IV   1 / on
    $RSLCodes[4][2][0] =  0xA2;   # IV   2 / off
    $RSLCodes[4][2][1] =  0xAC;   # IV   2 / on
    $RSLCodes[4][3][0] =  0x92;   # IV   3 / off
    $RSLCodes[4][3][1] =  0x9C;   # IV   3 / on
    $RSLCodes[4][4][0] =  0xA3;   # IV   4 / off All
    $RSLCodes[4][4][1] =  0x93;   # IV   4 / on All
Die 93 ist "I/II/III/IV   4 / on", nicht "IV   3 / on".
Die "all" schalter sind in allen Schiebeschalter Positionen identisch.
Ralf9
Danke das hilft mir weiter.
Funktioniert das Senden mit sendMsg?
