FHEM crash on FHT80b-3 modules (re-syncing)
Begonnen von Guest, 16 Januar 2011, 13:44:32
> The two devices paired before the upgrade (kids-room and playroom)
> they were working perfectly the whole time. Sending out both actuator
> and temperature messages.
Could you please activate FHT protocol messages by issuing "set CUNO raw X61"?
Then look at the "inform timer " output or raise the verbose level and
look into the log.
I think it is a reception issue.
> Perhaps I should split this issue off into a new mail?
Yes, perhaps the next time :)
Sie haben diese Nachricht erhalten, da Sie der Google Groups-Gruppe FHEM users beigetreten sind.
Wenn Sie Nachrichten in dieser Gruppe posten möchten, senden Sie eine E-Mail an fhem-users@googlegroups.com.
Wenn Sie aus dieser Gruppe austreten möchten, senden Sie eine E-Mail an fhem-users+unsubscribe@googlegroups.com.
Besuchen Sie die Gruppe unter http://groups.google.com/group/fhem-users?hl=de, um weitere Optionen zu erhalten.
Guest
> look into the log.
The verbose level of my log is currently running on 5 permanently.
I've only switched off all logging of WEB and WEBS by raising it's
loglevel to 6.
I can confirm it's a  reception issue. I've moved my FHZ1000pc a bit
and now the reception is ok again. I will test it extensively with the
CUNO as well as soon as I have the device back from busware. It's
still in shipping.
Kind regards,
Jelle Kalf
Living on earth is expensive, but it does include a free trip around the sun.
