Anbindung der ersten HM Komponenten leider ohne Erfolg
Begonnen von NemisisSB, 25 November 2016, 11:15:33
frank
FHEM: 6.0(SVN) => Pi3(buster)
NemisisSB
Nach dem Clear direkt:
   DEF        3D837E
   IODev      meinLGW
   LASTInputDev meinLGW
   MSGCNT     54
   NAME       Thermostat01
   NOTIFYDEV  global
   NR         31
   NTFY_ORDER 50-Thermostat01
   STATE      Info_Cleared
   TYPE       CUL_HM
   channel_01 Thermostat01_Weather
   channel_02 Thermostat01_Climate
   channel_03 Thermostat01_WindowRec
   channel_04 Thermostat01_Clima
   channel_05 Thermostat01_ClimaTeam
   channel_06 Thermostat01_remote
   meinLGW_MSGCNT 54
   meinLGW_RAWMSG 050000280184003D837E0000001400954D4551303537313836385900FFFF
   meinLGW_RSSI -40
   meinLGW_TIME 2016-11-25 18:04:35
   protState  Info_Cleared
   rssi_at_meinLGW max:-18 avg:-30.33 lst:-40 min:-58 cnt:54
   Readings:
     2016-11-25 18:02:26   Activity        alive
     2016-11-25 18:02:26   D-firmware      1.4
     2016-11-25 18:02:26   D-serialNr      MEQ0571868
     2016-11-25 02:56:02   R-burstRx       set_on
     2016-11-25 18:05:01   state           Info_Cleared
     Regl_00.:
       VAL
   Helper:
     HM_CMDNR   22
     cSnd       01F100003D837E00040000000000,01F100003D837E00040000000000
     mId        0095
     rxType     140
     Expert:
       def        1
       det        0
       raw        1
       tpl        0
     Io:
       newChn     +3D837E,00,00,00
       nextSend   1480093475.75192
       prefIO
       rxt        2
       vccu
       p:
         3D837E
         00
         00
         00
     Mrssi:
       mNo        01
       Io:
         meinLGW    -38
     Prt:
       awake      0
       bErr       0
       brstWu     0
       sProc      0
     Q:
       qReqConf
       qReqStat
     Role:
       dev        1
       prs        1
     Rssi:
       At_meinlgw:
         avg        -30.3333333333333
         cnt        54
         lst        -40
         max        -18
         min        -58
     Shregw:
       07         04
   IODev      meinLGW
   actCycle   000:10
   actStatus  alive
   autoReadReg 4_reqStatus
   expert     2_raw
   firmware   1.4
   model      HM-CC-RT-DN
   room       Schlafzimmer
   serialNr   MEQ0571868
   subType    thermostat
   webCmd     getConfig:clear msgEvents:burstXmit
Nach einem erneuten drücken der Anmeldung ma Thermo:
   DEF        3D837E
   IODev      meinLGW
   MSGCNT     59
   NAME       Thermostat01
   NOTIFYDEV  global
   NR         31
   STATE      Info_Cleared
   TYPE       CUL_HM
   lastMsg    No:01 - t:00 s:3D837E d:000000 1400954D4551303537313836385900FFFF
   meinLGW_MSGCNT 59
   meinLGW_RAWMSG 050000440184003D837E0000001400954D4551303537313836385900FFFF
   meinLGW_RSSI -68
   meinLGW_TIME 2016-11-25 18:12:49
   protLastRcv 2016-11-25 18:12:49
   rssi_at_meinLGW min:-68 max:-18 avg:-32.3 lst:-68 cnt:59
   Readings:
     2016-11-25 18:06:19   Activity        alive
     2016-11-25 18:06:19   D-firmware      1.4
     2016-11-25 18:06:19   D-serialNr      MEQ0571868
     Regl_00.:
       VAL
   Helper:
     HM_CMDNR   21
     mId        0095
     rxType     140
     Expert:
       def        1
       det        0
       raw        1
       tpl        0
     Io:
       nextSend   1480093969.44148
       prefIO
       rxt        2
       vccu
       p:
         3D837E
         00
         00
         00
     Mrssi:
       mNo        01
       Io:
         meinLGW    -66
     Prt:
       awake      0
       bErr       0
       brstWu     0
       sProc      0
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       dev        1
       prs        1
     Rssi:
       At_meinlgw:
         avg        -32.3050847457627
         cnt        59
         lst        -68
         max        -18
         min        -68
     Shregw:
       07         04
   IODev      meinLGW
   actCycle   000:10
   actStatus  alive
   expert     2_raw
   firmware   1.4
   model      HM-CC-RT-DN
   room       Schlafzimmer
   serialNr   MEQ0571868
   subType    thermostat
Ist aber auch wieder die ganzen 30 sec. durchgelaufe. In derÜbersicht bekomme ich weiterhin keine Inofs: Siehe Anhang
@ Frank: Ja hatte ihn die kurz abgemacht wegen dem offt anklicken, dann musste ich nicht an der Heizugn stehen bleiben. Ist jetzt wieder dran.
CoolTux
Kannst mal ein Auszug vom Logfile mitgeben. Irgendwie ist das selzsam
Das TuxNet Wiki:
https://www.cooltux.net
NemisisSB
#18
Allgemeines LOG:
2016.11.25 17:23:17 3: CUL_HM set Thermostat01 getConfig
2016.11.25 17:24:07 3: CUL_HM set Thermostat01 getConfig
2016.11.25 17:24:09 3: CUL_HM set Thermostat01 getConfig
2016.11.25 17:43:57 3: CUL_HM set Thermostat01 getConfig
2016.11.25 18:01:48 3: CUL_HM set Thermostat01 clear msgEvents
2016.11.25 18:02:09 3: CUL_HM set Thermostat01 getConfig
2016.11.25 18:02:26 3: Device Thermostat01 added to ActionDetector with 000:10 time
2016.11.25 18:05:01 3: CUL_HM set Thermostat01 clear msgEvents
2016.11.25 18:06:19 3: Device Thermostat01 added to ActionDetector with 000:10 time
2016.11.25 18:16:59 3: CUL_HM set Thermostat01 getConfig
2016.11.25 18:23:22 3: CUL_HM set Thermostat01 clear msgEvents
2016.11.25 18:23:26 3: CUL_HM set Thermostat01 burstXmit
2016.11.25 18:23:43 3: CUL_HM set Thermostat01 burstXmit
2016.11.25 18:25:37 3: Device Thermostat01 added to ActionDetector with 000:10 time
2016.11.25 18:27:19 3: CUL_HM set Thermostat01 burstXmit
2016.11.25 18:27:46 3: CUL_HM set Thermostat01 regSet burstRx on
2016.11.25 18:32:32 3: CUL_HM set Thermostat01 clear msgEvents
2016.11.25 18:32:57 3: Device Thermostat01 added to ActionDetector with 000:10 time
Thermostat01-2016.log
2016-11-25_11:26:30 Thermostat01 CMDs_pending
2016-11-25_11:26:37 Thermostat01 CMDs_pending
2016-11-25_11:26:38 Thermostat01 CMDs_pending
2016-11-25_11:26:50 Thermostat01 Activity: alive
2016-11-25_11:26:50 Thermostat01 D-firmware: 1.4
2016-11-25_11:26:50 Thermostat01 D-serialNr: MEQ0571868
2016-11-25_11:26:54 Thermostat01 CMDs_pending
2016-11-25_11:46:50 Thermostat01 Activity: dead
2016-11-25_17:23:17 Thermostat01 CMDs_pending
2016-11-25_17:24:07 Thermostat01 CMDs_pending
2016-11-25_17:24:08 Thermostat01 CMDs_pending
2016-11-25_17:24:09 Thermostat01 CMDs_pending
2016-11-25_17:26:50 Thermostat01 Activity: alive
2016-11-25_17:43:57 Thermostat01 CMDs_pending
2016-11-25_18:01:48 Thermostat01 Info_Cleared
2016-11-25_18:02:09 Thermostat01 CMDs_pending
2016-11-25_18:02:26 Thermostat01 Activity: alive
2016-11-25_18:02:26 Thermostat01 D-firmware: 1.4
2016-11-25_18:02:26 Thermostat01 D-serialNr: MEQ0571868
2016-11-25_18:02:32 Thermostat01 CMDs_pending
2016-11-25_18:05:01 Thermostat01 Info_Cleared
2016-11-25_18:06:19 Thermostat01 Activity: alive
2016-11-25_18:06:19 Thermostat01 D-firmware: 1.4
2016-11-25_18:06:19 Thermostat01 D-serialNr: MEQ0571868
2016-11-25_18:16:59 Thermostat01 CMDs_pending
2016-11-25_18:23:22 Thermostat01 Info_Cleared
2016-11-25_18:23:28 Thermostat01 CMDs_pending
2016-11-25_18:23:45 Thermostat01 CMDs_pending
2016-11-25_18:25:37 Thermostat01 Activity: alive
2016-11-25_18:25:37 Thermostat01 D-firmware: 1.4
2016-11-25_18:25:37 Thermostat01 D-serialNr: MEQ0571868
2016-11-25_18:25:37 Thermostat01 CMDs_done
2016-11-25_18:27:24 Thermostat01 CMDs_pending
2016-11-25_18:27:46 Thermostat01 CMDs_pending
2016-11-25_18:32:32 Thermostat01 Info_Cleared
2016-11-25_18:32:57 Thermostat01 Activity: alive
2016-11-25_18:32:57 Thermostat01 D-firmware: 1.4
2016-11-25_18:32:57 Thermostat01 D-serialNr: MEQ0571868
Übrigens hat der Thermostat gerade kurzzeitig 12° und ein "Fenster Offen" Symbol angezeigt obwohl das Fenster zu war und der Kontakt "Colsed" angezeigt hat. Mitlerweile nach 2-3 Sync ist es wieder bei 20° im auto Modus (laut display)
Hi Jungs,
ich habe heute morgen gelernt Heizungsthermostate muss man anbauen! Die geben sonst offenbar kein getConfig zurück!?
Bzw erst nach der Initialisierungsfahrt.
frank
NemisisSB
@ Frank: hier der List vom LGW:
   AssignedPeerCnt 2
   CNT        67
   DEF        192.168.1.81
   DEVCNT     67
   DevState   99
   DevType    LGW
   DeviceName 192.168.1.81:2000
   FD         9
   LastOpen   1480095633.4503
   NAME       meinLGW
   NR         12
   PARTIAL
   RAWMSG     040202
   STATE      opened
   TYPE       HMUARTLGW
   XmitOpen   1
   msgLoadCurrent 1
   msgLoadHistory 0/1/-/-/-/-/-/-/-/-/-/-
   msgLoadHistoryAbs 1/1/0/-/-/-/-/-/-/-/-/-/-
   owner      4EB7F6
   Helper:
     CreditTimer 43
     FW         65542
     Initialized 1
     Ackpending:
     Assignedpeers:
       3D837E     FFFFFFFFFFFFFFFF
       474ACA     FFFFFFFFFFFFFFFF
     LastSendLen:
       3
       3
     Log:
       IDs:
     PeerQueue:
     Roundtrip:
       Delay      0.00446009635925293
     Loadlvl:
       lastHistory 1480096238.45971
   Peers:
     3D837E     assigned
     474ACA     assigned
   Readings:
     2016-11-25 18:40:38   D-HMIdAssigned  4EB7F6
     2016-11-25 18:40:38   D-HMIdOriginal  FFFFFF
     2016-11-25 18:40:33   D-LANfirmware   1.1.5
     2016-11-25 18:40:38   D-firmware      1.0.6
     2016-11-25 18:40:33   D-serialNr      NEQ0708354
     2016-11-25 18:40:33   D-type          eQ3-HM-LGW
     2016-11-25 18:40:38   cond            ok
     2016-11-25 18:45:39   load            1
     2016-11-25 18:40:38   loadLvl         low
     2016-11-25 18:40:33   state           opened
   Keepalive:
     CNT        71
     DEVCNT     70
     DevState   99
     DevType    LGW-KeepAlive
     DeviceName 192.168.1.81:2001
     FD         4
     LastOpen   1480095633.45923
     NAME       meinLGW:keepAlive
     NR         39
     PARTIAL
     STATE      opened
     TEMPORARY  1
     TYPE       HMUARTLGW
     XmitOpen   0
     Helper:
       NextKeepAlive 1480096285.10529
       Log:
         Resolve    1
         IDs:
     Readings:
     Lgwhash:
Otto: Ist wieder alles angebaut und die Initialfahrt hatte ich auch schon länger hinter mir.
Vielleicht sollte ich mal versuchen einen 2. Thermostat anzubauen um zu sehen ob er sich genau so verhält ?
Aber ich sehe in keiner list, dass der Thermostat gepairt wäre?
Pairing schon versucht?
CoolTux
Würde ich auch sagen. Noch mal ein pairForSec machen und Anlerntaste
Das TuxNet Wiki:
NemisisSB
Vielleicht mache ich beim Pairing was falsch. Wie sollte ich richtig pairen ?
Wo genau soll ich den pairForSec machen ?
HMUARTLGW
meinLGW                                               opened
meinLGW:keepAlive                               opened
Ich hab bei meinLGW den pairForSec gemacht und noch mal gedrückt.
set meinLGW hmPairForSec 60
Und dann Configtaste! Ich weiß nicht wie die beim Thermostaten ist? Boostknopf so lange drücken bis 30 erscheint und runterzählt?
NemisisSB
Habe ich gemacht (und so habe ichs auch die ganze Zeit gemacht und ja der mittlere Knopf lange halten dann zählt er runter) und hier ein LOG Auszug:
2016.11.25 18:40:25 0: Server shutdown
2016.11.25 18:40:28 1: Including fhem.cfg
2016.11.25 18:40:29 3: telnetPort: port 7072 opened
2016.11.25 18:40:29 3: WEB: port 8083 opened
2016.11.25 18:40:29 3: WEBphone: port 8084 opened
2016.11.25 18:40:29 3: WEBtablet: port 8085 opened
2016.11.25 18:40:30 3: Opening meinLGW device 192.168.1.81:2000
2016.11.25 18:40:30 2: eventTypes: loaded 49 events from ./log/eventTypes.txt
2016.11.25 18:40:33 1: Including ./log/fhem.save
2016.11.25 18:40:33 3: Device Fenstersensor01 added to ActionDetector with 002:50 time
2016.11.25 18:40:33 3: Device Thermostat01 added to ActionDetector with 000:10 time
2016.11.25 18:40:33 0: Featurelevel: 5.7
2016.11.25 18:40:33 0: Server started with 26 defined entities (fhem.pl:12596/2016-11-17 perl:5.020002 os:linux user:fhem pid:3592)
2016.11.25 18:40:33 3: Opening meinLGW:keepAlive device 192.168.1.81:2001
2016.11.25 18:40:33 3: meinLGW device opened
2016.11.25 18:40:33 3: meinLGW:keepAlive device opened
2016.11.25 18:40:33 3: HMUARTLGW meinLGW BidCoS-port opened
2016.11.25 18:40:34 3: HMUARTLGW meinLGW:keepAlive KeepAlive-port opened
2016.11.25 18:52:12 3: CUL_HM set Fenstersensor01 getConfig
2016.11.25 18:53:15 3: CUL_HM set Thermostat01 getConfig
2016.11.25 19:02:00 3: Device Thermostat01 added to ActionDetector with 000:10 time
2016.11.25 19:14:12 3: CUL_HM set Thermostat01 clear msgEvents
2016.11.25 19:22:44 3: HMUARTLGW meinLGW:keepAlive entered pairing-mode
2016.11.25 19:22:55 3: Device Thermostat01 added to ActionDetector with 000:10 time
2016.11.25 19:23:38 3: HMUARTLGW meinLGW entered pairing-mode
2016.11.25 19:23:44 3: HMUARTLGW meinLGW left pairing-mode
2016.11.25 19:27:33 3: HMUARTLGW meinLGW entered pairing-mode
2016.11.25 19:28:33 3: HMUARTLGW meinLGW left pairing-mode
2016.11.25 19:31:02 3: HMUARTLGW meinLGW entered pairing-mode
2016.11.25 19:32:02 3: HMUARTLGW meinLGW left pairing-mode
NemisisSB
Wie auch F***ing immer das geklappt hat, ich habe erneut gepaired mit :
set meinLGW hmPairForSec 30
und weil ich mich vertippt hatte direkt noch ein:
set meinLGW hmPairForSec 300
Und dann kam plötzlich die Anzeige "AC" im Display des Thermostats und folgendes im Log:
2016.11.25 20:17:05 3: HMUARTLGW meinLGW entered pairing-mode
2016.11.25 20:17:10 3: HMUARTLGW meinLGW left pairing-mode
2016.11.25 20:17:10 3: HMUARTLGW meinLGW entered pairing-mode
2016.11.25 20:17:26 3: Device Thermostat01 added to ActionDetector with 000:10 time
2016.11.25 20:17:26 3: CUL_HM pair: Thermostat01 thermostat, model HM-CC-RT-DN serialNr MEQ0571868
NemisisSB
Leider hat ein erneutes getConfig nicht funktioniert ABER es gibt wenigstens eine neue LOG Ausgabe:
2016.11.25 20:16:11 3: HMUARTLGW meinLGW BidCoS-port opened
2016.11.25 20:16:11 3: HMUARTLGW meinLGW:keepAlive KeepAlive-port opened
2016.11.25 20:21:37 3: CUL_HM set Thermostat01 burstXmit
2016.11.25 20:27:22 3: CUL_HM set Thermostat01 clear msgEvents
2016.11.25 20:27:27 3: CUL_HM set Thermostat01 getConfig
2016.11.25 20:27:33 1: HMUARTLGW meinLGW Adding peer 3D837E failed! You have probably forced an unknown aesKey for this device.
2016.11.25 20:27:35 1: HMUARTLGW meinLGW unexpected info about Co_CPU_BL received (module crashed?), reopening
2016.11.25 20:27:35 3: meinLGW device closed
2016.11.25 20:27:35 3: Opening meinLGW:keepAlive device 192.168.1.81:2001
2016.11.25 20:27:35 1: 192.168.1.81:2000 reappeared (meinLGW)
2016.11.25 20:27:35 3: meinLGW:keepAlive device opened
2016.11.25 20:27:35 3: HMUARTLGW meinLGW BidCoS-port opened
2016.11.25 20:27:35 3: HMUARTLGW meinLGW:keepAlive KeepAlive-port opened
2016.11.25 20:33:20 3: CUL_HM set Thermostat01 clear msgEvents
2016.11.25 20:33:22 3: CUL_HM set Thermostat01 getConfig
CoolTux
Das TuxNet Wiki:
