Sonoff 4CH mit Fhem
Begonnen von Reinhart, 11 Januar 2017, 11:59:00
TomLee
Wie gesagt es funktioniert alles.
Geflasht ist ja 5.2.0. Hab jetzt einfach mal interessehalber MQTT deaktiviert. (IP und Port  entfernt).
Ein Auszug aus der Konsole (ohne MQTT und mit  Command + Unknown Meldung 😀):
19:08:19 MQTT: Connect FAILED to domus1:1883, rc -2. Retry in 10 seconds
19:08:19 CMND: 1919:08:01 CMND: 19:07:55 mDNS: Query done with 0 mqtt 19:08:12 MQTT: Attempting connection...
19:08:19 RSLT: stat/sonoffch4/RESULT = {"Command":"Unknown"}
19:08:19 CMND: 19:08:13 mDNS: Query done with 0 mqtt services found
19:08:19 CMND: 19:08:19 MQTT: Connect FAILED to domus1:1883, rc -2. Retry in 10 seconds
19:08:30 MQTT: Attempting connection...
19:08:31 mDNS: Query done with 0 mqtt services found
19:08:37 MQTT: Connect FAILED to domus1:1883, rc -2. Retry in 10 seconds
19:08:37 CMND: 1919:08:30 MQTT: Attempting connection...
19:08:37 RSLT: stat/sonoffch4/RESULT = {"Command":"Unknown"}
19:08:37 CMND: 19:08:31 mDNS: Query done with 0 mqtt services found
19:08:37 CMND: 19:08:37 MQTT: Connect FAILED to domus1:1883, rc -2. Retry in 10 seconds
19:08:48 MQTT: Attempting connection...
19:08:49 mDNS: Query done with 0 mqtt services found
19:08:55 MQTT: Connect FAILED to domus1:1883, rc -2. Retry in 10 seconds
19:08:55 CMND: 19:08:48 MQTT: Attempting connection...
19:08:55 RSLT: stat/sonoffch4/RESULT = {"Command":"Unknown"}
19:08:55 CMND: 19:08:49 mDNS: Query done with 0 mqtt services found
19:08:55 CMND: 19:08:55 MQTT: Connect FAILED to domus1:1883, rc -2. Retry in 10 seconds
19:09:06 MQTT: Attempting connection...
19:09:07 mDNS: Query done with 0 mqtt services found
19:09:13 MQTT: Connect FAILED to domus1:1883, rc -2. Retry in 10 seconds
19:09:13 CMND: 1919:09:06 MQTT: Attempting connection...
19:09:13 RSLT: stat/sonoffch4/RESULT = {"Command":"Unknown"}
19:09:13 CMND: 19:09:07 mDNS: Query done with 0 mqtt services found
19:09:13 CMND: 19:09:13 MQTT: Connect FAILED to domus1:1883, rc -2. Retry in 10 seconds
19:09:24 MQTT: Attempting connection...
19:09:25 mDNS: Query done with 0 mqtt services found
19:09:31 MQTT: Connect FAILED to domus1:1883, rc -2. Retry in 10 seconds
19:09:31 CMND: 19:09:24 MQTT: Attempting connection...
19:09:31 RSLT: stat/sonoffch4/RESULT = {"Command":"Unknown"}
19:09:32 CMND: 19:09:25 mDNS: Query done with 0 mqtt services found
19:09:32 RSLT: stat/sonoffch4/RESULT = {"Command":"Unknown"}
19:09:32 CMND: 19:09:31 MQTT: Connect FAILED to domus1:1883, rc -2. Retry in 10 seconds
19:09:42 MQTT: Attempting connection...
19:09:43 mDNS: Query done with 0 mqtt services found
19:09:50 MQTT: Connect FAILED to domus1:1883, rc -2. Retry in 10 seconds
19:09:50 CMND: 19:09:42 MQTT: Attempting connection...
19:09:50 RSLT: stat/sonoffch4/RESULT = {"Command":"Unknown"}
19:09:50 CMND: 19:09:43 mDNS: Query done with 0 mqtt services found
19:09:50 CMND: 19:09:50 MQTT: Connect FAILED to domus1:1883, rc -2. Retry in 10 seconds
19:10:01 MQTT: Attempting connection...
19:10:02 mDNS: Query done with 0 mqtt services found
19:10:08 MQTT: Connect FAILED to domus1:1883, rc -2. Retry in 10 seconds
19:10:08 CMND: 1919:10:01 MQTT: Attempting connection...
19:10:08 RSLT: stat/sonoffch4/RESULT = {"Command":"Unknown"}
19:10:08 CMND: 19:10:02 mDNS: Query done with 0 mqtt services found
19:10:08 CMND: 19:10:08 MQTT: Connect FAILED to domus1:1883, rc -2. Retry in 10 seconds
19:10:19 MQTT: Attempting connection...
19:10:20 mDNS: Query done with 0 mqtt services found
19:10:26 MQTT: Connect FAILED to domus1:1883, rc -2. Retry in 10 seconds
19:10:26 CMND: 19:10:19 MQTT: Attempting connection...
19:10:26 RSLT: stat/sonoffch4/RESULT = {"Command":"Unknown"}
19:10:26 CMND: 19:10:20 mDNS: Query done with 0 mqtt services found
19:10:26 CMND: 19:10:26 MQTT: Connect FAILED to domus1:1883, rc -2. Retry in 10 seconds
19:10:37 MQTT: Attempting connection...
19:10:38 mDNS: Query done with 0 mqtt services found
19:10:44 MQTT: Connect FAILED to domus1:1883, rc -2. Retry in 10 seconds
19:10:44 CMND: 19:10:37 MQTT: Attempting connection...
19:10:44 RSLT: stat/sonoffch4/RESULT = {"Command":"Unknown"}
19:10:44 CMND: 19:10:38 mDNS: Query done with 0 mqtt services found
19:10:44 CMND: 19:10:44 MQTT: Connect FAILED to domus1:1883, rc -2. Retry in 10 seconds
19:10:55 MQTT: Attempting connection...
19:10:56 mDNS: Query done with 0 mqtt services found
19:11:02 MQTT: Connect FAILED to domus1:1883, rc -2. Retry in 10 seconds
19:11:02 CMND: 19:10:55 MQTT: Attempting connection...
19:11:02 RSLT: stat/sonoffch4/RESULT = {"Command":"Unknown"}
19:11:02 CMND: 19:10:56 mDNS: Query done with 0 mqtt services found
19:11:02 CMND: 19:11:02 MQTT: Connect FAILED to domus1:1883, rc -2. Retry in 10 seconds
19:11:02 CMND: 1919:11:02 CMND: 19:11:02 MQTT: Connect FAILED to domus1:1883, rc -2. Retry in 10 seconds
19:11:13 MQTT: Attempting connection...
19:11:14 mDNS: Query done with 0 mqtt services found
19:11:20 MQTT: Connect FAILED to domus1:1883, rc -2. Retry in 10 seconds
19:11:20 CMND: 19:11:02 CMND: 1919:11:02 CMND: 19:11:02 S19:11:13 MQTT: Attempting connection...
19:11:20 RSLT: stat/sonoffch4/RESULT = {"Command":"Unknown"}
19:11:20 CMND: 19:11:14 mDNS: Query done with 0 mqtt services found
19:11:20 CMND: 19:11:20 MQTT: Connect FAILED to domus1:1883, rc -2. Retry in 10 seconds
19:11:31 MQTT: Attempting connection...
19:11:32 mDNS: Query done with 0 mqtt services found
19:11:38 MQTT: Connect FAILED to domus1:1883, rc -2. Retry in 10 seconds
19:11:38 CMND: 1919:11:31 MQTT: Attempting connection...
19:11:38 RSLT: stat/sonoffch4/RESULT = {"Command":"Unknown"}
19:11:38 CMND: 19:11:32 mDNS: Query done with 0 mqtt services found
19:11:38 RSLT: stat/sonoffch4/RESULT = {"SetOption32":"40"}
19:11:38 CMND: 19:11:38 MQTT: Connect FAILED to domus1:1883, rc -2. Retry in 10 seconds
19:11:49 MQTT: Attempting connection...
19:11:50 mDNS: Query done with 0 mqtt services found
19:11:58 MQTT: Connect FAILED to domus1:1883, rc -2. Retry in 10 seconds
19:11:58 CMND: 1919:11:49 MQTT: Attempting connection...
19:11:58 RSLT: stat/sonoffch4/RESULT = {"Command":"Unknown"}
19:11:58 CMND: 19:11:50 mDNS: Query done with 0 mqtt services found
19:11:58 CMND: 19:11:58 MQTT: Connect FAILED to domus1:1883, rc -2. Retry in 10 seconds
19:12:09 MQTT: Attempting connection...
19:12:10 mDNS: Query done with 0 mqtt services found
19:12:16 MQTT: Connect FAILED to domus1:1883, rc -2. Retry in 10 seconds
19:12:16 CMND: 1919:12:09 MQTT: Attempting connection...
19:12:16 RSLT: stat/sonoffch4/RESULT = {"Command":"Unknown"}
19:12:16 CMND: 19:12:10 mDNS: Query done with 0 mqtt services found
19:12:16 CMND: 19:12:16 MQTT: Connect FAILED to domus1:1883, rc -2. Retry in 10 seconds
Reinhart
#31
du hast ja die IP-Adresse deines MQTT Servers gar nicht eingetragen, wie soll das funktionieren?
PS: ok ich weiß was du damit bezwecken willst.
Aber von irgendwoher muss ja das falsche Kommando kommen? Hast du schon direkt in der Konsole getestet?
Ich vermute, das "unkown" kommt gar nicht vom Schaltbefehl.
FHEM auf Raspy5 mit Bullseye + SSD, Homematic, ESP8266, ESP32, Sonoff, eBus, NanoCUL, MapleCUL, , MQTT2, Alexa
TomLee
Hätte es vlt. auch gleich dazu schreiben können. Ich mach ja gar nix. Das ist ein Konsolenauszug nach dem deaktivieren von MQTT. Weder am Modul oder in Fhem hab ich da was gemacht.
Reinhart
da habe ich mich vielleicht nicht genau ausgedrückt, ich meinte, das du das Kommando direkt in der Konsole absetzt (nicht den Button drücken)und schaust ob da ebenfalls das "unknown" kommt. Du musst ja schrittweise suchen beginnen, damit man weis wo das herkommt. Ein Fehler ist das auf jeden Fall, nicht das dann irgendwann andere Funktionen stört. In der Software (Sketch) liegt es nicht, sonst hätte ich das auch.
Bei mir sieht das wie im Bild aus, also alles korrekt.
"Unknown Command" deutet ja darauf hin, das vom Modul ein Kommando empfangen wird das es nicht versteht. Jetzt geht es darum zu finden wer da was sendet. Da du ja die Kommunikation via MQTT schon unterbrochen hast, kann es kann es kein anderes Gerät mit gleicher Topic sein. Ich hoffe Friendly Name 1-4 sind ebenfalls alles unterschiedliche Namen.
Ich versuche solche Fehler immer zu finden, schon alleine weil es mich "technisch" stört auch wenn es den Anschein hat die Funktion sei deswegen nicht gestört.
Reinhart
wenn du ein Kommando absetzt das falsch ist, dann kommt ja ebenfalls diese Meldung, auch wenn es ein Blank ist.
Wenn das Gerät nun das von sich selber tut, dann würde ich mal checken bei NTP oder auch die korrekte Sommerzeit (timezone 99).
Es gibt mehrere Möglichkeiten die zu solchen Selbstgesprächen führen könnten.
CMND: tralala
10:20:01 MQTT: stat/sonoff_electrodragon2/RESULT = {"Command":"Unknown"}
10:21:15 CMND:
10:21:15 MQTT: stat/sonoff_electrodragon2/RESULT = {"Command":"Unknown"}
TomLee
#35
Und wieder was dazugelernt, Danke.
Mit
Timezone 99
bekomm ich nun auch die richtige Uhrzeit angezeigt. Aber keine Änderung beim  "unknown" Problemchen.
Und auch ein
NtpServer
mit den Werten 0,1,2 oder 3 bringt keine Änderung diesbezüglich.
Blauhorn
tolles Thema, es funktioniert alles auf Anhieb.
Kann mir trotzdem jemand einen Tipp geben, wie ich bei den 4CH die WLAN-Reichweite etwas erhöhen kann? Mit den Sonoff-DUAL komm ich problemlos bis in den Keller runter, der 4CH ist schon neben dem Router sehr mau - 1 Balken.
Danke für einige Tipps
Gruß blauhorn
1xBananaPi; 1x FB7490; 1xCUL433; 1x CC2530+CC2591; OpenMiLight-Gateway; 1xHMUART; HM-LC-Sw4-DR; Sonoff* mit TASMOTA, LEDController; MySensors; zigbee2mqtt;
Hornsk001
kann mir jemand erklären wie man die fehlenden Power Buttons in Fhem integrieren kann? Kann nur ein schalten. In Fhem kann ich den 4chPro auch nicht mehrfach anlegen zb. mit POWER1 POWER2 POWER3 usw.
der 4CH hat tasmota. Fhem und MQTT läuft auf raspberry.
Gruß Daniel
Reinhart
wo liegt da das Problem?
Einfach 4 Schalter anlegen und du kannst jeden bedienen!
define Sonoff_ch1 MQTT_DEVICE
attr Sonoff_ch1 IODev myBroker
attr Sonoff_ch1 alias Sonoff CH1
attr Sonoff_ch1 devStateIcon ON:rc_GREEN:OFF OFF:rc_RED:ON
attr Sonoff_ch1 group Toröffner
attr Sonoff_ch1 icon light_ceiling
attr Sonoff_ch1 publishSet ON OFF cmnd/sonoffch4/POWER1
attr Sonoff_ch1 room Entwicklung
attr Sonoff_ch1 stateFormat state
attr Sonoff_ch1 subscribeReading_Power tele/sonoffch4/POWER1
attr Sonoff_ch1 subscribeReading_state cmnd/sonoffch4/POWER1
attr Sonoff_ch1 webCmd ON:OFF
define Sonoff_ch2 MQTT_DEVICE
attr Sonoff_ch2 IODev myBroker
attr Sonoff_ch2 alias Sonoff CH2
attr Sonoff_ch2 devStateIcon ON:rc_GREEN:OFF OFF:rc_RED:ON
attr Sonoff_ch2 group Toröffner
attr Sonoff_ch2 icon light_ceiling
attr Sonoff_ch2 publishSet ON OFF cmnd/sonoffch4/POWER2
attr Sonoff_ch2 room Entwicklung
attr Sonoff_ch2 stateFormat state
attr Sonoff_ch2 subscribeReading_Power tele/sonoffch4/POWER2
attr Sonoff_ch2 subscribeReading_state cmnd/sonoffch4/POWER2
attr Sonoff_ch2 webCmd ON:OFF
define Sonoff_ch3 MQTT_DEVICE
attr Sonoff_ch3 IODev myBroker
attr Sonoff_ch3 alias Sonoff CH3
attr Sonoff_ch3 devStateIcon ON:rc_GREEN:OFF OFF:rc_RED:ON
attr Sonoff_ch3 group Toröffner
attr Sonoff_ch3 icon light_ceiling
attr Sonoff_ch3 publishSet ON OFF cmnd/sonoffch4/POWER3
attr Sonoff_ch3 room Entwicklung
attr Sonoff_ch3 stateFormat state
attr Sonoff_ch3 subscribeReading_Power tele/sonoffch4/POWER3
attr Sonoff_ch3 subscribeReading_state cmnd/sonoffch4/POWER3
attr Sonoff_ch3 webCmd ON:OFF
define Sonoff_ch4 MQTT_DEVICE
attr Sonoff_ch4 IODev myBroker
attr Sonoff_ch4 alias Sonoff CH4
attr Sonoff_ch4 devStateIcon ON:rc_GREEN:OFF OFF:rc_RED:ON
attr Sonoff_ch4 group Toröffner
attr Sonoff_ch4 icon light_ceiling
attr Sonoff_ch4 publishSet ON OFF cmnd/sonoffch4/POWER4
attr Sonoff_ch4 room Entwicklung
attr Sonoff_ch4 stateFormat state
attr Sonoff_ch4 subscribeReading_Power tele/sonoffch4/POWER4
attr Sonoff_ch4 subscribeReading_state cmnd/sonoffch4/POWER4
attr Sonoff_ch4 webCmd ON:OFF
Reinhart
Hornsk001
Hallo Reinhart, ich möchte das ganze mit nodeMCU und Relaismodul betreiben. den kann ich leider nicht 4 mal anlegen. Das ich die als einzelne Schalter habe gibt es da eine möglichkeit. Habe nodeMCU als Tasmota wemos eingestellt.
define nodeMCU MQTT_DEVICE
attr nodeMCU IODev myBroker
attr nodeMCU autoSubscribeReadings +/nodeMCU/+
attr nodeMCU devStateIcon ON:rc_GREEN:OFF OFF:rc_RED:ON
attr nodeMCU icon temperature_humidity
attr nodeMCU publishSet ON OFF cmnd/nodeMCU/POWER1
attr nodeMCU room MQTT
attr nodeMCU stateFormat transmission-state
attr nodeMCU subscribeReading_LWT tele/nodeMCU/LWT
attr nodeMCU subscribeReading_Licht stat/nodeMCU/POWER
attr nodeMCU subscribeReading_POWER cmnd/nodeMCU/POWER
attr nodeMCU subscribeReading_POWER1 stat/nodeMCU/POWER1
attr nodeMCU subscribeReading_POWER2 stat/nodeMCU/POWER2
attr nodeMCU subscribeReading_POWER3 stat/nodeMCU/POWER3
attr nodeMCU subscribeReading_POWER4 stat/nodeMCU/POWER4
attr nodeMCU subscribeReading_RESULT stat/nodeMCU/RESULT
attr nodeMCU subscribeReading_STATE tele/nodeMCU/STATE
attr nodeMCU subscribeReading_Sensor tele/nodeMCU/SENSOR
attr nodeMCU subscribeReading_Status stat/nodeMCU/STATUS
attr nodeMCU subscribeReading_UPTIME tele/nodeMCU/UPTIME
attr nodeMCU webCmd ON:OFF
so sieht das ganze jetzt mit ein schalter aus.
LG Daniel
Reinhart
das versteh ich jetzt nicht, du willst 4 einzelne Schalter haben, willst die aber nicht anlegen, warum nicht?
So wie ich es gepostet habe funktioniert es doch, du hast Power 1-4 darin unterscheiden sich die einzelnen Schalter. Du musst nur die Topic an deine anpassen!
Und lösche den autoSubscribeReadings weg.
Hornsk001
Hallo Reinhart, Ich bin neu was fhem betrifft bin froh das ich die ganzen sonoffs drin habe. nur das mit nodeMCU funktioniert nicht weil ich die nicht nochmal definieren kann. und wie das mit topic anpassen geht weiß ich leider nicht.
LG Daniel
Reinhart
ich glaube wir reden voneinander vorbei!
Mit dieser Konfiguration hast du 4 einzelne Schalter die alle ein Gerät mit der Topic /nodeMCU bedienen, aber jedes schaltet einen eigenen Kanal (1-4). Und baue bitte nicht diesen "autoSubscribeReadings" dazu, der versucht bei jedem Device wieder alles automatisch anzulegen und das brauchen wir in diesem Fall absolut nicht.
define nodeMCU1 MQTT_DEVICE
attr nodeMCU1 IODev myBroker
attr nodeMCU1 devStateIcon ON:rc_GREEN:OFF OFF:rc_RED:ON
attr nodeMCU1 icon temperature_humidity
attr nodeMCU1 publishSet ON OFF cmnd/nodeMCU/POWER1
attr nodeMCU1 room MQTT
attr nodeMCU1 subscribeReading_Power tele/nodeMCU/POWER1
attr nodeMCU1 subscribeReading_state cmnd/nodeMCU/POWER1
attr nodeMCU1 webCmd ON:OFF
define nodeMCU2 MQTT_DEVICE
attr nodeMCU2 IODev myBroker
attr nodeMCU2 devStateIcon ON:rc_GREEN:OFF OFF:rc_RED:ON
attr nodeMCU2 icon temperature_humidity
attr nodeMCU2 publishSet ON OFF cmnd/nodeMCU/POWER2
attr nodeMCU2 room MQTT
attr nodeMCU2 subscribeReading_Power tele/nodeMCU/POWER2
attr nodeMCU2 subscribeReading_state cmnd/nodeMCU/POWER2
attr nodeMCU2 webCmd ON:OFF
define nodeMCU3 MQTT_DEVICE
attr nodeMCU3 IODev myBroker
attr nodeMCU3 devStateIcon ON:rc_GREEN:OFF OFF:rc_RED:ON
attr nodeMCU3 icon temperature_humidity
attr nodeMCU3 publishSet ON OFF cmnd/nodeMCU/POWER3
attr nodeMCU3 room MQTT
attr nodeMCU3 subscribeReading_Power tele/nodeMCU/POWER3
attr nodeMCU3 subscribeReading_state cmnd/nodeMCU/POWER3
attr nodeMCU3 webCmd ON:OFF
define nodeMCU4 MQTT_DEVICE
attr nodeMCU4 IODev myBroker
attr nodeMCU4 devStateIcon ON:rc_GREEN:OFF OFF:rc_RED:ON
attr nodeMCU4 icon temperature_humidity
attr nodeMCU4 publishSet ON OFF cmnd/nodeMCU/POWER4
attr nodeMCU4 room MQTT
attr nodeMCU4 subscribeReading_Power tele/nodeMCU/POWER4
attr nodeMCU4 subscribeReading_state cmnd/nodeMCU/POWER4
attr nodeMCU4 webCmd ON:OFF
Du kannst ja das Testweise dazu bauen und deine Konfig stehen lassen, dann siehst du den Unterschied!
Hornsk001
Hallo Reinhart,
Vielen Dank so funktioniert das. Ich habe nicht begriffen das ich einfach den Name bei define nodeMcu1 2 und so weiter einfach nehmen kann ich dachte der kennt nur nodeMCU. Einfach super.
LG Daniel
satprofi
Hallo.
habe einen 4CH erstanden, der sich auch mit Tasmota flashen lässt, und auch danach über 192.168.4.1 erreichbear ist. Aber nach einstellung meines WLAN finde ich das ding einfach nicht mehr.
Selbes bei TH16.
Bin am verzweifeln, oder ist das Ding kaputt?
Tasmota,LD382A,Telegram
