HM-MOD-EM-8Bit anlernen
Begonnen von wendeling, 18 Februar 2017, 13:14:25
rabehd
#30
Anlerntaste hat geholfen. Danke
Jetzt sieht es etwas anders aus.
Das CMDs_pending bleibt aber.
list list HM_519034
   CFGFN
   DEF        519034
   IODev      SCC
   LASTInputDev SCC
   MSGCNT     19
   NAME       HM_519034
   NOTIFYDEV  global
   NR         2076
   SCC_MSGCNT 19
   SCC_RAWMSG A0C07A2415190341503130305FF::-61.5:SCC
   SCC_RSSI   -61.5
   SCC_TIME   2017-02-20 18:51:21
   STATE      CMDs_pending
   TYPE       CUL_HM
   channel_01 HM_519034_Btn_01
   channel_02 HM_519034_Btn_02
   channel_03 HM_519034_Tr
   lastMsg    No:07 - t:41 s:519034 d:150313 0305FF
   protCmdPend 10 CMDs pending
   protLastRcv 2017-02-20 18:51:21
   protSnd    26 last_at:2017-02-20 18:51:21
   protState  CMDs_pending
   rssi_at_SCC min:-65.5 cnt:19 avg:-60.57 lst:-61.5 max:-56.5
   Readings:
     2017-02-20 17:56:09   CommandAccepted yes
     2017-02-20 18:48:53   D-firmware      1.0
     2017-02-20 18:48:53   D-serialNr      NEQ1546982
     2017-02-20 18:48:54   PairedTo        0x150313
     2017-02-20 18:48:54   R-pairCentral   0x150313
     2017-02-20 18:48:54   RegL_00.          02:01 05:00 0A:15 0B:03 0C:13 12:00 14:03 18:00  00:00
     2017-02-20 18:51:21   battery         ok
     2017-02-20 18:49:34   state           CMDs_pending
   cmdStack:
     ++A0011503135190340303
     ++A00115031351903403040000000001
     ++A00115031351903400040000000000
     ++A00115031351903401040000000001
     ++A0011503135190340103
     ++A00115031351903402040000000001
     ++A0011503135190340203
   Helper:
     HM_CMDNR   7
     cSnd       0115031351903403040000000001,011503135190340303
     mId        0106
     rxType     28
     supp_Pair_Rep 0
     Expert:
       def        1
       det        1
       raw        1
       tpl        1
     Io:
       newChn     +519034,02,00,00
       nextSend   1487613081.66357
       prefIO
       rxt        2
       vccu
       p:
         519034
         00
         00
         00
     Mrssi:
       mNo        07
       Io:
         SCC        -59.5
     Prt:
       bErr       0
       sProc      2
     Q:
       qReqConf
       qReqStat
     Role:
       dev        1
     Rpt:
       IO         SCC
       flg        A
       ts         1487613081.56839
       ack:
         HASH(0x53a3720)
         07800215031351903400
     Rssi:
       At_scc:
         avg        -60.5789473684211
         cnt        19
         lst        -61.5
         max        -56.5
         min        -65.5
     Shadowreg:
     Tmpl:
   IODev      SCC
   IOgrp      VCCU:SCC
   autoReadReg 4_reqStatus
   expert     251_anything
   firmware   1.0
   model      HM-MOD-EM-8Bit
   room       CUL_HM
   serialNr   NEQ1546982
   subType    pushButton
   webCmd     getConfig:clear msgEvents
list HM_519034_Tr
   CFGFN
   DEF        51903403
   NAME       HM_519034_Tr
   NOTIFYDEV  global
   NR         2080
   STATE      unknown:FF
   TYPE       CUL_HM
   chanNo     03
   device     HM_519034
   Readings:
     2017-02-20 18:48:55   R-dInProp0      off
     2017-02-20 18:48:55   R-dInProp1      off
     2017-02-20 18:48:55   R-dInProp2      off
     2017-02-20 18:48:55   R-dInProp3      off
     2017-02-20 18:48:55   R-dInProp4      off
     2017-02-20 18:48:55   R-dInProp5      off
     2017-02-20 18:48:55   R-dInProp6      off
     2017-02-20 18:48:55   R-dInProp7      off
     2017-02-20 18:48:55   R-dataTransCond lvlChng_H_L
     2017-02-20 18:48:55   R-sign          off
     2017-02-20 18:48:55   R-stabFltTime   1 s
     2017-02-20 18:51:21   contact         unknown:FF (to VCCU)
     2017-02-20 18:51:21   state           unknown:FF
     2017-02-20 18:51:21   trigger_cnt     5
   Helper:
     getCfgList all
     getCfgListNo ,4
     Expert:
       def        1
       det        1
       raw        1
       tpl        1
     Role:
       chn        1
     Shadowreg:
     Tmpl:
   expert     251_anything
   peerIDs
Thorsten Pferdekaemper
das sieht doch schonmal gar nicht schlecht aus.
Ich denke mal, dass diese Parameter interessant sind:
R-dInProp0      off
Könntest Du damit mal rumspielen? Also sowas wie "set HM_519034_Tr regSet blabla", damit man mal erfährt, was da geht? Dann auf etwas umstellen, was vielleicht NEW_DATA_SEND_IMMEDIATELY_DEFAULT_ENABLE entsprechen könnte.
...und einen Taster anschließen (wahrscheinlich gegen GND), damit rumspielen und dabei den Event Monitor beobachten. Ich glaube, man muss die Taste mindestens 1 Sekunde drücken.
   Thorsten
FUIP
Pfriemler
#32
Sagt mal ... da das doch der erste Thread zu dem Teil ist, der wieder nach Kennenlernen und Ausprobieren aussieht, gehört das doch eigentlich direkt nach Homematic verschoben, oder?
Schließe mich da Ottos erstem Post an!
Admins? Wendeling? (Der Threadersteller kann das machen).
Den ELV-Artikel zu dem Ding habe ich gelesen, ihr seid auf der richtigen Fährte. (Die Besitzer des Bausatzes müssten den Artikel ja als Papier vorliegen haben).
Im Artikel wird von ingesamt 7 Übertragungsmodi gesprochen:
Modus 1-3: Sendung bei Änderung des Pegels an DU30 (Taster-Eingang, ist low-aktiv) bzw. Spannungseingang DUI30 (high-aktiv):
Modus 1: Senden bei Änderung H->L (könnte dem zitierten "lvlChng_H_L" entsprechen)
Modus 2: dito bei L->H
Modus 3: Senden bei H->L und L->H
Modus 4 und 6: Senden bei bestimmten Zuständen am Dateneingang (bei Änderung der Bits sozusagen), wenn diese länger als die "Datenstabilitätsfilterzeit" anliegen (bei kurzen Änderungen erfolgt keine Sendung) - ähnlich wie eventFilterTime bei Sensoren: Sendung erst x Sekunden nachdem es eine Änderung gab)
Modus 4: Sendung erfolgt wenn Datenübertragungseingang HIGH (bei low erfolgt keine Sendung)
Modus 6: Dito, aber bei Datenübertragungseingang LOW
Modus 5 und 7: Senden sofort bei Änderung, danach Wartezeit (ähnlich minInterval bei Bewegungsmeldern - Wartezeit nach Meldung einer Bewegung)
Modus 5: Sendung erfolgt wenn Datenübertragungseingang HIGH (bei low erfolgt keine Sendung)
Modus 7: Dito, aber bei Datenübertragungseingang LOW
Jetzt müsste man herausbekommen wie die Register und Modi nach martins Definition heißen.
dInPropX? Sind das die einzelnen Bits oder soll das eine Maske sein für die Triggerung? Davon ist aber nirgends die Rede.
Was liefert regList des Kanal 3? Da stehen doch sonst die möglichen Werte drin.
"stabFltTime" müsste diese "Datenstabilitätsfilterzeit" sein, die dann je nach Modus eine Wartezeit bis zu -oder- nach einer Sendung darstellt.
Jm2c.
rabehd
mach ich, aber nicht mehr heute abend. morgen hat die bessere Hälfte Spätschicht...
Wenn man einen Taster an den Kanal 3 anschliesst und betätigt (zweifel mal das mindestens an), dann wird anhand der geschlossenen Dateneingänge/Pegel eine Binärzahl gesendet. Soweit der Werkszustand.
Der Modus wird wahrscheinlich im R-dataTransCond stehen? Die Frage ist dann, wie werden die Modi verschlüsselt? Das müsste eigentlich bei HM-MOD-EM-8 genauso sein. Kann da jemand nachschauen?
Pfriemler
Der HM-Mod-EM-8 sendet (wie wohl auch das 8bit in den beiden ersten Kanälen) je nach eingestelltem Modus bei kurz/lang-Betätiung (remote) oder Zustandswechsel (im Modus switch ein unbewertetes short, im Modus sensor einen Zustand 200 oder 0 (closed, open - oder umgekehrt). Das wird je nach Kanal im Register "triggerMode" festgelegt.
ZitatDer Modus wird wahrscheinlich im R-dataTransCond stehen?
Sehe ich auch so. Deswegen ja meine Frage nach dem regList, vielleicht stehen dort schon die erlaubten Werte. Bei den condition- und jumptables der Aktoren ist es ja so, und beim EM-8 für den Triggermode steht dort auch "1: triggerMode      |     literal        |          | define type of event report  options:sensor,switch,button,off ".
rabehd
#35
reglist Kanal 3:
list:         register | range              | peer     | description
   1: dInProp0         |     literal        |          | Data Input Propertie options:off,on
   1: dInProp1         |     literal        |          | Data Input Propertie options:on,off
   1: dInProp2         |     literal        |          | Data Input Propertie options:off,on
   1: dInProp3         |     literal        |          | Data Input Propertie options:off,on
   1: dInProp4         |     literal        |          | Data Input Propertie options:on,off
   1: dInProp5         |     literal        |          | Data Input Propertie options:off,on
   1: dInProp6         |     literal        |          | Data Input Propertie options:off,on
   1: dInProp7         |     literal        |          | Data Input Propertie options:on,off
   1: dataTransCond    |     literal        |          | dataTransmitCondition options:sndImmediateEnable,stbl4TimeEnable,lvlChng_L_H,sndImmediateDisable,lvlChng_any,stbl4TimeDisable,lvlChng_H_L
   1: dblPress         |   0 to 1.5s        |          | time to detect double press
   1: longPress        | 0.3 to 1.8s        |          | time to detect key long press
   1: sign             |     literal        |          | signature (AES) options:on,off
   1: stabFltTime      |  10 to 111600s     |          | stability filter time
   4: expectAES        |     literal        | required | expect AES options:on,off
   4: peerNeedsBurst   |     literal        | required | peer expects burst options:off,on
Ich vermute Modus 1 ist eingestellt. Sendung erfolgt, wenn DU30 geschlossen wird. Ich vermute DUI30 analog. Das Öffnen führt nicht zu einer Sendung.
Ich werde morgen abend mal alles für dataTransCond durchprobieren.
Pfriemler
#36
Cool. Die Modi sind doch fast selbstsprechend.
Edit: hab mich verwechselt, korrigiert:
sndImmediateEnable = Modus 5 (oder 7 je nach Pegel - das ist doch unklar und je nach Sichtweise (Taster- bzw. Spannungseingang) unterschiedlich)
sndImmediateDisable wäre das Pendant dazu
"sende sofort" entspricht den Modi 5 und 7, der Datenübertragungseingang gilt dann als ENABLE, entweder H oder L-Aktiv
stbl4TimeEnable = Modus 4 (oder 6, s.o.)
stbl4TimeDisable wäre das Pendant
"sende wenn Zustand stabil für ... (Sekunden)" entspricht den Modi 4 und 6, der Datenübertragungseingang gilt dann als ENABLE, entweder H oder L-Aktiv
lvlChng_L_H = Modus 2 (oder 1)
lvlChng_H_L = Modus 1 (oder 2)
lvlChng_any = Modus 3
Wenn DU30 geschlossen wird und Modus 1 ab Werk aktiv ist (und er dann also sendet), wären die Pegel wohl aus Sicht des Tastereingangs zu verstehen, d.h. H ist offen und L ist geschlossen.
Für diese Theorie spricht auch der übermittelte Wert von 255 (&HFF) - offene Taster = H.
Nachtrag:
im Foto von den CCU-Einstellungen ist vom Modus 0 die Rede. Vielleicht sind die da alle eins nach unten verschoben.
Da gibt es übrigens noch den Wert "Sender für 8-Bit-Entscheidungswert" mit der Erläuterung "Dateineingang invertieren", je Bit anhakbar.
Da kann man wohl je Bit festlegen, ob es L- oder H-aktiv ist - das könnte das fragliche "dInProp..." sein - stehen ab Werk alle auf off, also keine Invertierung.
wendeling
#37
Hallo, habe gerade mal mal etwas gespielt , und den Kanal3 beobachtet
wenn ich zB. INL0 auf gnd lege dann kommt "FE"
                   INL1                                       "FD"
aber bei       INL1+INL3   = auch FD
   CFGFN
   DEF        518F0A03
   IODev
   NAME       HM_518F0A_Tr
   NOTIFYDEV  global
   NR         1206
   STATE      unknown:FD
   TYPE       CUL_HM
   chanNo     03
   device     HM_518F0A
   protState  Info_Cleared
   Readings:
     2017-02-20 22:05:25   contact         unknown:FD (to CUL868)
     2017-02-20 22:05:25   state           unknown:FD
     2017-02-20 22:05:25   trigDst_F11234  noConfig
     2017-02-20 22:05:25   trigger_cnt     27
   Helper:
     getCfgList all
     getCfgListNo ,4
     Expert:
       def        1
       det        0
       raw        1
       tpl        0
     Prt:
       bErr       0
       sProc      0
     Role:
       chn        1
     Shadowreg:
Pfriemler
Zitataber bei       INL1+INL3   = auch FD
War bestimmt ein Wackler.
Lieber wendeling, verschiebst Du den Thread bitte nach "FHEM Forum » FHEM - Hausautomations-Systeme » Homematic"? Da gehört er m.E. hin.
Das müsste beim Edit des Erstbeitrages möglich sein.
wendeling
würde ich gerne mache, bekomm es aber nicht gebacken
wendeling
                   INL1                                       "FD"
Kannst Du dazu mal zeigen, was im Event Monitor ankommt?
   Thorsten
FUIP
rabehd
hier das Ergebnis aus dem Eventmonitor
kein Eingang geschlossen, DU3 per Taster gegen GND
2017-02-21 19:38:17 CUL_HM HM_519034 battery: ok
2017-02-21 19:38:17 CUL_HM HM_519034_Tr contact: unknown:FF (to VCCU)
2017-02-21 19:38:17 CUL_HM HM_519034_Tr unknown:FF
2017-02-21 19:38:17 CUL_HM HM_519034_Tr trigger_cnt: 19
Eingang INL4 bis INL7 gegen GND geschlossen, DU3 per Taster gegen GND
2017-02-21 19:39:04 CUL_HM HM_519034 battery: ok
2017-02-21 19:39:04 CUL_HM HM_519034_Tr contact: unknown:0F (to VCCU)
2017-02-21 19:39:04 CUL_HM HM_519034_Tr unknown:0F
2017-02-21 19:39:04 CUL_HM HM_519034_Tr trigger_cnt: 22
Der Rest ist sicher analog.
rabehd
Ich habe jetzt mit  "set HM_519034_Tr regset dataTransCond sndImmediateEnable" das Register für den Modus verändert.
Ergebnis: Jede Änderung an einem Eingang INL wird sofort gesendet und erzeugt ein Event.
Genau das was ich wollte.
Danke an die Unterstüzung von Pfriemler und Thorsten Pferdekaemper.
Was sollte man jetzt noch tun? Einen Gerätetyp anlegen für die Nächsten? Wie kann ich unterstützen?
Zitat von: rabehd am 21 Februar 2017, 20:11:27Was sollte man jetzt noch tun? Einen Gerätetyp anlegen für die Nächsten? Wie kann ich unterstützen?
Wieso neuer Gerätetyp? Das Ding funktioniert doch wunderbar, oder?
Was man jetzt machen sollte:
1. Wiki-Eintrag zu dem Ding anlegen mit den Erkenntnissen aus diesem Thread.
2. Eine kleine Routine schreiben, die das state oder contact Reading in einzelne on/off oder so Readings übersetzt.
Viel Spaß.
  Thorsten
FUIP
