Telefongerät stumm schalten oder Klingelsperre
Begonnen von FunkOdyssey, 01 März 2017, 14:43:45
andies
Bist du dir sicher, das da nicht irgend ein Anführungszeichen fehlt,
Wrong number of arguments, usage: get FritzBox argName1 argValue1 [argName2 argValue2] ...
FHEM 6.1 auf RaspPi4 (Raspbian:  6.6.28+; Perl: v5.36.0)
andies
Ich habe ein wenig herumgespielt:
Result of data = 'edit_dect_ring_block' => 'xhr=1&page=edit_dect_ring_block&idx=2&lockmode=0&nightsetting=1&lockday=everyday&starthh=07&startmm=00&endhh=19&endmm=00&apply='
Unexpected result: $VAR1 = {
          'data' => {
                      'dsl' => {
                                 'led' => 'led_green',
                                 'up' => "\x{e2}\x{86}\x{91} 7,5 Mbit/s",
                                 'txt' => 'verbunden',
                                 'diag_stop_pid' => 'dsldiagstop',
                                 'diag_active' => '0',
                                 'down' => "\x{e2}\x{86}\x{93} 25,0 Mbit/s",
                                 'link' => 'dslOv',
                                 'title' => 'DSL',
                                 'addDiag' => ''
                      'AVM_URL' => 'http://www.avm.de',
                      'dect' => {
                                  'txt' => 'an, 4 Schnurlostelefone angemeldet',
                                  'link' => 'dectSet',
                                  'title' => 'DECT'
                      'language' => 'de',
                      'lan' => {
                                 'txt' => 'verbunden (LAN 1, LAN 2, LAN 3)',
                                 'title' => 'LAN',
                                 'link' => 'netDev'
                      'tamcalls' => {
                                      'any_tam_active' => bless( do{\(my $o = 1)}, 'JSON::PP::Boolean' ),
                                      'callsToday' => '0',
                                      'calls' => '',
                                      'count' => 0,
                                      'tam_configured' => $VAR1->{'data'}{'tamcalls'}{'any_tam_active'}
                      'webdav' => '0',
                      'fonnum' => {
                                    'txt' => '3 Rufnummern aktiv: ...',
                                    'link' => 'numLi',
                                    'title' => 'Telefonie'
                      'net' => {
                                 'count' => 40,
                                 'active_count' => 40,
                                 'otherAVMUpdates' => 0,
                                 'anyUnmeshedDevices' => bless( do{\(my $o = 0)}, 'JSON::PP::Boolean' ),
                                 'more_link' => 'homeNet',
                                 'devices' => [
                                                  'type' => 'LAN',
                                                  'classes' => 'globe_online',
                                                  'url' => '',
                                                  'name' => '...'
                                                  'classes' => 'led_green',
                                                  'type' => 'LAN',
                                                  'url' => 'http://192.168.2...',
                                                  'name' => '...'
...ganz viel weggelassen...
                                                  'name' => 'FRITZ!Fon C5, BadOben',  <=== der soll ausgeschaltet werden
                                                  'url' => '',
                                                  'type' => 'DECT',
                                                  'classes' => ''
                      'NEWSLETTER_URL' => 'https://www.avm.de/newsletter?hardware=226&oem=avm&language=de&country=049&version=154.07.21&subversion=',
                      'internet' => {
                                      'down' => "\x{e2}\x{86}\x{93} 24,2 Mbit/s",
                                      'txt' => [
                                                 'Anbieter: Telekom',
                                                 'verbunden seit 09.12.2020, 12:05 Uhr'
                                      'link' => 'mNetMoni',
                                      'title' => 'Internet',
                                      'link2' => 'mobile',
                                      'up' => "\x{e2}\x{86}\x{91} 7,3 Mbit/s",
                                      'led' => 'globe_online'
                      'SERVICEPORTAL_URL' => 'https://www.avm.de/fritzbox-service-portal.php?hardware=226&oem=avm&language=de&country=049&version=154.07.21&subversion=',
                      'wan' => {
                                 'led' => 'led_gray',
                                 'title' => 'WAN',
                                 'link' => 'mCred',
                                 'txt' => 'nicht verbunden'
                      'fritzos' => {
                                     'twofactor_disabled' => $VAR1->{'data'}{'tamcalls'}{'any_tam_active'},
                                     'expert_mode' => '1',
                                     'nspver' => '07.21',
                                     'FirmwareSigned' => $VAR1->{'data'}{'tamcalls'}{'any_tam_active'},
                                     'boxDate' => '17:51:45 22.12.2020',
                                     'NoPwd' => $VAR1->{'data'}{'net'}{'anyUnmeshedDevices'},
                                     'ShowDefaults' => $VAR1->{'data'}{'net'}{'anyUnmeshedDevices'},
                                     'fb_name' => '',
                                     'isUpdateAvail' => $VAR1->{'data'}{'net'}{'anyUnmeshedDevices'},
                                     'Productname' => 'FRITZ!Box 7590',
                                     'isLabor' => $VAR1->{'data'}{'net'}{'anyUnmeshedDevices'},
                                     'energy' => '22',
                                     'showUpdate' => $VAR1->{'data'}{'tamcalls'}{'any_tam_active'}
                      'usbconnect' => 'nousbstore',
                      'comfort' => {
                                     'func' => [
                                                   'link' => 'bookLi',
                                                   'details' => '1 Telefonbuch vorhanden',
                                                   'linktxt' => 'Telefonbuch'
                                                   'details' => '2 verbunden ',
                                                   'linktxt' => 'Smart Home',
                                                   'link' => 'sh_dev'
                                                   'details' => 'aktiv',
                                                   'linktxt' => 'Anrufe sperren',
                                                   'link' => 'callLock'
                                                   'details' => '6 MB genutzt, 350 MB frei',
                                                   'linktxt' => 'Speicher (NAS)',
                                                   'link' => 'usbOv'
                                                   'linktxt' => 'Faxfunktion',
                                                   'details' => 'Integriertes Fax aktiv',
                                                   'link' => 'fax'
                                                   'details' => 'bereit',
                                                   'linktxt' => 'Kindersicherung',
                                                   'link' => 'kidLis'
                                                   'link' => 'remoteHttps',
                                                   'linktxt' => 'FRITZ!Box-Dienste',
                                                   'details' => 'erreichbar aus dem Internet (HTTPS)'
                                                   'details' => 'aktiviert, ....selfhost.bz, IPv4-Status: erfolgreich angemeldet, IPv6-Status: unbekannt',
                                                   'linktxt' => 'DynDNS',
                                                   'link' => 'dyndns'
                                     'anyComfort' => $VAR1->{'data'}{'tamcalls'}{'any_tam_active'}
                      'naslink' => 'nas',
                      'wlan' => {
                                  'title' => 'WLAN',
                                  'link' => 'wSet',
                                  'txt' => 'aus, Funknetz (2,4/5 GHz): FRITZ!Box 7590 MW',
                                  'tooltip' => 'aus, Funknetz (2,4/5 GHz): FRITZ!Box 7590 MW',
                                  'led' => 'led_gray'
                      'MANUAL_URL' => 'https://assets.avm.de/manual/?hardware=226&oem=avm&language=de&country=049&version=154.07.21&subversion=',
                      'foncalls' => {
                                      'count_all' => 400,
                                      'calls' => [
...weggelassen...
                                      'count_today' => 1,
                                      'activecalls' => '',
                                      'callsToday' => '1'
                      'vpn' => {
                                 'elements' => [
                                                   'led' => '0',
                                                   'name' => '.....'
                                 'title' => 'Fernzugang',
                                 'link' => '...'
                      'changelog' => {
                                       'connectionStatus' => $VAR1->{'data'}{'tamcalls'}{'any_tam_active'},
                                       'deviceName' => '',
                                       'fritzOsVersion' => '07.21',
                                       'iframeUrl' => 'https://help.avm.de/fritzbox.php?hardware=226&oem=avm&language=de&country=049&version=154.07.21&subversion=&set=019&action=feature',
                                       'productName' => 'FRITZ!Box 7590'
                      'usb' => {
                                 'txt' => "kein Ger\x{c3}\x{a4}t angeschlossen",
                                 'link' => 'usbOv',
                                 'title' => 'USB',
                                 'led' => 'led_gray'
          'pid' => 'overview',
          'hide' => {
                      'mobile' => $VAR1->{'data'}{'tamcalls'}{'any_tam_active'},
                      'wps' => $VAR1->{'data'}{'tamcalls'}{'any_tam_active'},
                      'wlanmesh' => $VAR1->{'data'}{'tamcalls'}{'any_tam_active'},
                      'liveTv' => $VAR1->{'data'}{'tamcalls'}{'any_tam_active'},
                      'ssoSet' => $VAR1->{'data'}{'tamcalls'}{'any_tam_active'},
                      'shareUsb' => $VAR1->{'data'}{'tamcalls'}{'any_tam_active'},
                      'chan' => $VAR1->{'data'}{'tamcalls'}{'any_tam_active'},
                      'wKey' => $VAR1->{'data'}{'tamcalls'}{'any_tam_active'},
                      'wGuest' => $VAR1->{'data'}{'tamcalls'}{'any_tam_active'}
          'time' => [],
          'sid' => '...'
