FHEM startet nicht mit aktueller Blocking.pm
Begonnen von djatebbi, 08 November 2017, 09:51:09
djatebbi
#15
Perfmon: possible freeze starting at 10:29:56, delay is 42.483
Kommen die aus dem main oder fork ?
Wie kann ich dies herausfinden?
Ich habe heute das update vom neuen Modul eingespielt und ausgiebig getestet.
Leider habe ich noch immer folgende zusätzliche Einträge in dem Log:
Start FHEM
2017.11.10 09:29:04 2: Perfmon: ready to watch out for delays greater than one second
(2017.11.10 09:29:10 3: telnetForBlockingFn_1510302550: port 56224 opened)
2017.11.10 09:29:21 1: FRITZBOX 1750E: Readout_Aborted.1865 Error: Timeout when reading Fritz!Box data.
2017.11.10 09:29:33 1: FRITZBOX 7390: Readout_Aborted.1865 Error: Timeout when reading Fritz!Box data.
2017.11.10 09:29:45 1: FRITZBOX 7490: Readout_Aborted.1865 Error: Timeout when reading Fritz!Box data.
2017.11.10 09:29:45 1: Perfmon: possible freeze starting at 09:29:11, delay is 34.887
2017.11.10 09:29:47 2: PRESENCE (NB_Garage_presence) - device could not be checked (retrying in 10 seconds): Process died prematurely
2017.11.10 09:29:52 3: BlockingCall for NB_Garage was aborted
2017.11.10 09:29:54 1: FRITZBOX 1750E: Readout_Aborted.1865 Error: Timeout when reading Fritz!Box data.
2017.11.10 09:29:57 1: FRITZBOX 7390: Readout_Aborted.1865 Error: Timeout when reading Fritz!Box data.
2017.11.10 09:30:00 1: FRITZBOX 7490: Readout_Aborted.1865 Error: Timeout when reading Fritz!Box data.
2017.11.10 09:30:00 1: Perfmon: possible freeze starting at 09:29:46, delay is 14.689
2017.11.10 09:30:03 2: PRESENCE (NB_Garage_presence) - device could not be checked after 1 retry (retrying in 10 seconds): Process died prematurely
2017.11.10 09:30:06 1: FRITZBOX 1750E: Readout_Aborted.1865 Error: Timeout when reading Fritz!Box data.
2017.11.10 09:30:06 1: Perfmon: possible freeze starting at 09:30:01, delay is 5.439
2017.11.10 09:30:09 1: FRITZBOX 7390: Readout_Aborted.1865 Error: Timeout when reading Fritz!Box data.
2017.11.10 09:30:12 1: FRITZBOX 7490: Readout_Aborted.1865 Error: Timeout when reading Fritz!Box data.
2017.11.10 09:30:12 1: Perfmon: possible freeze starting at 09:30:07, delay is 5.131
2017.11.10 09:30:13 1: FRITZBOX 1750E: Readout_Aborted.1865 Error: Timeout when reading Fritz!Box data.
2017.11.10 09:30:13 2: PRESENCE (NB_Garage_presence) - check returned a valid result after 2 unsuccesful retries
2017.11.10 09:30:18 1: FRITZBOX 7390: Readout_Aborted.1865 Error: Timeout when reading Fritz!Box data.
2017.11.10 09:30:18 1: Perfmon: possible freeze starting at 09:30:17, delay is 1.849
2017.11.10 09:30:20 1: FRITZBOX 7490: Readout_Aborted.1865 Error: Timeout when reading Fritz!Box data.
2017.11.10 09:30:20 1: Perfmon: possible freeze starting at 09:30:19, delay is 1.717
Letzte Meldung nach 20 min.
2017.11.10 09:35:19 2: HMCCU: Received no events from CCU since 300 seconds
Diese Meldungen werden in diversen anderen Threads behandelt.
Überall scheint es auf das Blocking.pm Modul seit dem 02.10.2017 zurück zu führen.
Dies soll seit der Version vom 05.10. gefixt worden zu sein, aber bei mir tauchen diese Meldungen trotz dessen auf.
Gibt es hierzu noch eine Idee?
FHEM auf Raspberry Pi 4B.
