Homematic Pairing und Peering, Reihenfolge
Begonnen von CatWeazle, 18 November 2017, 23:27:36
CatWeazle
#15
FHEM habe ich heute noch ein Update laufen lassen.
Das list ....
   DEF        56AD6C
   IODev      nanoCUL
   LASTInputDev nanoCUL
   MSGCNT     3
   NAME       HM_56AD6C
   NOTIFYDEV  global
   NR         584
   NTFY_ORDER 50-HM_56AD6C
   STATE      MISSING ACK
   TYPE       CUL_HM
   lastMsg    No:70 - t:10 s:56AD6C d:000000 06010000
   nanoCUL_MSGCNT 3
   nanoCUL_RAWMSG A0D70861056AD6C00000006010000::-70:nanoCUL
   nanoCUL_RSSI -70
   nanoCUL_TIME 2017-11-19 21:19:35
   protCmdPend 3 CMDs pending
   protLastRcv 2017-11-19 21:19:35
   protResnd  3 last_at:2017-11-19 21:19:37
   protSnd    3 last_at:2017-11-19 21:19:35
   protState  CMDs_pending
   rssi_at_nanoCUL lst:-70 cnt:3 max:-70 min:-73.5 avg:-71.16
     2017-11-19 18:50:01   Activity        alive
     2017-11-19 16:49:05   D-firmware      1.0
     2017-11-19 16:49:05   D-serialNr      OEQ0222076
     2017-11-19 16:42:38   R-pairCentral   set_0xF11234
     2017-11-19 16:49:06   aesKeyNbr       00
     2017-11-19 16:46:54   alive           yes
     2017-11-19 16:54:27   battery         ok
     2017-11-19 16:54:27   contact         closed (to broadcast)
     2017-11-19 16:46:54   powerOn         2017-11-19 16:46:54
     2017-11-19 21:19:35   recentStateType info
     2017-11-19 16:46:54   sabotageError   off
     2017-11-19 18:08:11   state           MISSING ACK
     2017-11-19 18:16:50   trigDst_broadcast noConfig
     2017-11-19 18:16:50   trigger_cnt     21
   cmdStack:
     ++A001F1123456AD6C00040000000000
     ++A001F1123456AD6C01040000000001
     ++A001F1123456AD6C0103
   helper:
     HM_CMDNR   113
     getCfgList all
     getCfgListNo ,4
     mId        00C7
     rxType     28
     supp_Pair_Rep 0
     expert:
       def        1
       det        0
       raw        1
       tpl        0
     io:
       newChn     +56AD6C,02,00,00
       nextSend   1511122775.17421
       prefIO
       rxt        2
       vccu
       p:
         56AD6C
         00
         00
         00
     mRssi:
       mNo        70
       io:
         nanoCUL    -68
     prt:
       bErr       0
       sProc      2
       wuReSent   4
     q:
       qReqConf
       qReqStat
     role:
       chn        1
       dev        1
     rssi:
       at_nanoCUL:
         avg        -71.1666666666667
         cnt        3
         lst        -70
         max        -70
         min        -73.5
     tmpl:
   IODev      nanoCUL
   actCycle   002:50
   actStatus  alive
   autoReadReg 4_reqStatus
   expert     2_raw
   firmware   1.0
   model      HM-SEC-SCo
   room       CUL_HM,Wohnzimmer
   serialNr   OEQ0222076
Grüße, Mike
 *******  Wird Zeit für besser Wetter !  ********
Knapp daneben, das sind Zitate. Code Tags findest Du über dem  :-X  Smily, die # Taste. Kannst Du auch nachträglich ändern.
Mach jetzt noch bitte ein list nanoCUL
Der HM-SEC-SCo  ist nicht gepairt, zumindest nicht fertig. Du musst zur Datenübertragung den Configtaster drücken ohne den Sensor auszulösen!!!
CatWeazle
Hallo Otto,
hier ist es ......
   CMDS       ABCEeFfGhiKklMmRTtUVWXxYZz
   Clients    :CUL_HM:HMS:CUL_IR:STACKABLE_CC:TSSTACKED:STACKABLE:
   DEF        /dev/serial/by-path/platform-3f980000.usb-usb-0:1.5:1.0-port0@38400 1234
   DeviceName /dev/serial/by-path/platform-3f980000.usb-usb-0:1.5:1.0-port0@38400
   FD         17
   FHTID      1234
   NAME       nanoCUL
   NR         519
   NR_CMD_LAST_H 5
   PARTIAL
   RAWMSG     A0F2C861051B1F60000000A80CD8C0040F3
   RSSI       -80.5
   STATE      Initialized
   TYPE       CUL
   VERSION    V 1.67 nanoCUL868
   initString X21
Ar
   nanoCUL_MSGCNT 343
   nanoCUL_TIME 2017-11-19 22:15:40
   MatchList:
     1:CUL_HM   ^A....................
     8:HMS      ^810e04....(1|5|9).a001
     D:CUL_IR   ^I............
     H:STACKABLE_CC ^\*
     M:TSSTACKED ^\*
     N:STACKABLE ^\*
     2017-02-25 18:19:03   ccconf          freq:0.000MHz bWidth:58KHz rAmpl:42dB sens:8dB
     2017-11-19 18:50:00   cmds             A B C E e F f G h i K k l M m R T t U V W X x Y Z z
     2017-02-25 18:18:46   credit10ms      598
     2017-02-25 18:19:34   fhtbuf          AE
     2017-03-01 18:10:05   raw             isF00F00FFFFF0
     2017-11-19 22:15:40   state           Initialized
   XMIT_TIME:
     1511122775.22298
     1511123176.64028
     1511125111.0811
     1511125111.35412
     1511125111.54651
   helper:
     51B1F6:
       QUEUE:
     56AD6C:
       QUEUE:
     56AD88:
       QUEUE:
   rfmode     HomeMatic
Grüße, Mike
CatWeazle
Wenn man zu schnell ist .... sorry ...
ich hatte doch Fragen!
ZitatDer HM-SEC-SCo  ist nicht gepairt, zumindest nicht fertig.
Woran erkennt man das?
Dann:
ZitatDu musst zur Datenübertragung den Configtaster drücken ohne den Sensor auszulösen!!!
Kann das aus versehen passieren? denn weder Fenster noch Sensor bewegen sich wenn ich den Pairknopf am Fesnstersensor drücke.
Oder ist etwas anderes gemeint ?
Grüße, Mike
#19
ZitatR-pairCentral   set_0xF11234
Hier darf kein set_ davor stehen
Es muss so aussehen R-pairCentral   0xF11234
Der Fenstersensor überträgt auch Daten wenn man ihn auslöst (Fenster aufmacht, oder mit der Hand die Lichschranke auslöst) , aber diese werden aus Sicherheitsgründen nicht für Konfigurationsänderungen verwendet.
Du erkennst die Datenübertragung am Blinkrythmus. Eventuell brauchst Du nur noch einmal ein getConfig abzusetzen und dann 1 bis zweimal (mit Ruhe und mit Pause) den configtaster drücken.
Diese Verhalten ist nicht bei allen Sensoren so. Bei Bewegungsmeldern werden die Konfigurationsdaten auch übertragen wenn man ihn auslöst.
Diese Zahl F11234 ist die HMID Deiner Zentrale. Eine Eigenheit des CUL, er nimmt den Hauscode (1234) aus Deiner DEF und macht ihn mit F1 davor zur HMID. Normalerweise muss man ein attribute setzen.
CatWeazle
Hallo Otto,
nach getConfig hat sich das listing geändert.
   DEF        56AD6C
   IODev      nanoCUL
   MSGCNT     17
   NAME       HM_56AD6C
   NOTIFYDEV  global
   NR         584
   STATE      closed
   TYPE       CUL_HM
   lastMsg    No:CC - t:41 s:56AD6C d:000000 011D00
   nanoCUL_MSGCNT 17
   nanoCUL_RAWMSG A0CCC844156AD6C000000011D00::-70.5:nanoCUL
   nanoCUL_RSSI -70.5
   nanoCUL_TIME 2017-11-19 23:19:12
   protCmdDel 4
   protCmdPend 10 CMDs_pending
   protLastRcv 2017-11-19 23:19:12
   protResndFail 1 last_at:2017-11-19 22:17:59
   protSnd    16 last_at:2017-11-19 23:16:50
   rssi_at_nanoCUL avg:-69.11 max:-65.5 min:-73.5 lst:-70.5 cnt:17
     2017-11-19 23:16:49   Activity        alive
     2017-11-19 23:16:49   D-firmware      1.0
     2017-11-19 23:16:49   D-serialNr      OEQ0222076
     2017-11-19 23:16:49   PairedTo        0x000000
     2017-11-19 23:17:55   R-HM_587E68_WindowRec-expectAES set_off
     2017-11-19 23:17:55   R-HM_587E68_WindowRec-peerNeedsBurst set_on
     2017-11-19 23:16:28   R-cyclicInfoMsg on
     2017-11-19 23:16:28   R-eventDlyTime  0 s
     2017-11-19 23:16:28   R-pairCentral   0x000000
     2017-11-19 23:16:28   R-sabotageMsg   on
     2017-11-19 23:16:28   R-sign          on
     2017-11-19 23:16:49   RegL_00.          02:00 09:01 0A:00 0B:00 0C:00 10:01 14:06 00:00
     2017-11-19 23:16:49   RegL_01.          08:01 20:9C 21:00 30:06 00:00
     2017-11-19 23:19:12   battery         ok
     2017-11-19 23:19:12   contact         closed (to broadcast)
     2017-11-19 23:13:12   recentStateType info
     2017-11-19 23:19:12   state           closed
     2017-11-19 23:19:12   trigger_cnt     29
   cmdStack:
     ++A001F1123456AD6C0101587E680300
     ++A001F1123456AD6C0105587E680304
     ++A001F1123456AD6C01080101
     ++A001F1123456AD6C0106
     ++A001F1123456AD6C0102587E680300
   helper:
     HM_CMDNR   204
     cSnd       01F1123456AD6C01040000000001,01F1123456AD6C0103
     mId        00C7
     peerIDsRaw ,00000000
     rxType     28
     supp_Pair_Rep 0
     expert:
       def        1
       det        0
       raw        1
       tpl        0
     io:
       nextSend   1511129952.71081
       prefIO
       rxt        2
       vccu
       p:
         56AD6C
         00
         00
         00
     mRssi:
       mNo        CC
       io:
         nanoCUL    -68.5
     prt:
       bErr       0
       sProc      2
       rspWait:
     q:
       qReqConf   00
       qReqStat
     role:
       chn        1
       dev        1
     rssi:
       at_nanoCUL:
         avg        -69.1176470588235
         cnt        17
         lst        -70.5
         max        -65.5
         min        -73.5
     shadowReg:
       RegL_04.HM_587E68_WindowRec  01:01
     tmpl:
   IODev      nanoCUL
   actCycle   002:50
   actStatus  alive
   expert     2_raw
   firmware   1.0
   model      HM-SEC-SCo
   peerIDs    00000000,
   serialNr   OEQ0222076
   subType    threeStateSensor
jetzt steht da: R-pairCentral   0x000000
hmmm ist scheinbar auch nicht richtig, wenn es doch 0xF11234 heißen sollte ?!?!?
mir fehlt leider komplett das Verständnis für die meisten dieser Parameter :-(
Mike
Grüße, Mike
CatWeazle
Hi leutz,
nur um die liste fürs Wohnzimmer komplett zu machen.
Wandthermostat:
   DEF        587E68
   IODev      nanoCUL
   MSGCNT     253
   NAME       HM_587E68
   NOTIFYDEV  global
   NR         562
   NTFY_ORDER 50-HM_587E68
   STATE      Nack
   TYPE       CUL_HM
   channel_01 HM_587E68_Weather
   channel_02 HM_587E68_Climate
   channel_03 HM_587E68_WindowRec
   channel_06 HM_587E68_remote
   channel_07 HM_587E68_SwitchTr
   lastMsg    No:03 - t:70 s:587E68 d:000000 00E130
   nanoCUL_MSGCNT 253
   nanoCUL_RAWMSG A0C038470587E6800000000E130::-47:nanoCUL
   nanoCUL_RSSI -47
   nanoCUL_TIME 2017-11-19 23:40:13
   protCmdDel 1
   protLastRcv 2017-11-19 23:40:13
   protNack   1 last_at:2017-11-19 23:23:49
   protSnd    4 last_at:2017-11-19 23:23:48
   protState  CMDs_done_Errors:1
   rssi_at_nanoCUL avg:-47.52 lst:-47 cnt:253 min:-49.5 max:-46.5
     2017-11-19 23:23:49   CommandAccepted no
     2017-10-07 12:16:57   D-firmware      1.3
     2017-10-07 12:16:57   D-serialNr      OEQ0298561
     2017-04-27 17:59:50   PairedTo        0xF11234
     2017-04-27 17:58:26   R-burstRx       on
     2017-04-27 17:58:26   R-cyclicInfoMsg on
     2017-04-27 17:58:26   R-cyclicInfoMsgDis 0
     2017-04-27 17:58:26   R-pairCentral   0xF11234
     2017-04-27 17:59:50   RegL_00.        01:01 02:01 09:01 0A:F1 0B:12 0C:34 0F:00 11:00  12:16 16:01 18:00 19:00 1A:00 00:00
     2017-11-19 17:06:06   RegL_07.
     2017-11-19 23:31:06   battery         ok
     2017-11-19 23:31:06   batteryLevel    2.8
     2017-11-19 23:31:06   desired-temp    22.0
     2017-11-19 23:31:06   measured-temp   22.5
     2017-09-08 18:00:51   powerOn         2017-09-08 18:00:51
     2017-09-08 18:00:51   recentStateType info
     2017-11-19 23:23:49   state           Nack
     2017-11-19 02:06:36   time-request    -
   helper:
     HM_CMDNR   3
     cSnd       01F11234587E68030256AD6C0101,01F11234587E68030256AD6C0101
     mId        00AD
     rxType     6
     supp_Pair_Rep 0
     expert:
       def        1
       det        0
       raw        1
       tpl        0
     io:
       newChn     +587E68,00,00,00
       nextSend   1511131213.34536
       prefIO
       rxt        0
       vccu
       p:
         587E68
         00
         00
         00
     mRssi:
       mNo        03
       io:
         nanoCUL    -45
     prt:
       bErr       0
       sProc      0
       rspWait:
     q:
       qReqConf   02,03
       qReqStat
     role:
       dev        1
     rssi:
       at_nanoCUL:
         avg        -47.5217391304348
         cnt        253
         lst        -47
         max        -46.5
         min        -49.5
     shRegW:
       07         02
     tmpl:
   IODev      nanoCUL
   actCycle   000:10
   actStatus  alive
   expert     2_raw
   firmware   1.3
   model      HM-TC-IT-WM-W-EU
   msgRepeat  1
   serialNr   OEQ0298561
   subType    thermostat
   webCmd     getConfig:clear msgEvents
Heizköperthermostat:
   DEF        51A418
   IODev      nanoCUL
   MSGCNT     112
   NAME       HM_51A418
   NOTIFYDEV  global
   NR         531
   NTFY_ORDER 50-HM_51A418
   STATE      CMDs_done
   TYPE       CUL_HM
   channel_01 HM_51A418_Weather
   channel_02 HM_51A418_Climate
   channel_03 HM_51A418_WindowRec
   channel_04 HM_51A418_Clima
   channel_05 HM_51A418_ClimaTeam
   channel_06 HM_51A418_remote
   lastMsg    No:C0 - t:10 s:51A418 d:000000 0AB0E10E0040
   nanoCUL_MSGCNT 112
   nanoCUL_RAWMSG A0FC0861051A4180000000AB0E10E0040::-53.5:nanoCUL
   nanoCUL_RSSI -53.5
   nanoCUL_TIME 2017-11-19 23:41:09
   protLastRcv 2017-11-19 23:41:09
   rssi_at_nanoCUL avg:-53.66 min:-55 max:-52.5 lst:-53.5 cnt:112
     2017-11-19 18:47:30   CommandAccepted yes
     2017-05-11 16:30:53   D-firmware      1.4
     2017-05-11 16:30:53   D-serialNr      NEQ1491261
     2017-09-08 18:01:31   PairedTo        0xF11234
     2017-04-27 17:49:07   R-backOnTime    10 s
     2017-04-27 17:49:07   R-burstRx       on
     2017-04-27 17:49:07   R-cyclicInfoMsg on
     2017-04-27 17:49:07   R-cyclicInfoMsgDis 0
     2017-04-27 17:49:07   R-pairCentral   0xF11234
     2017-09-08 18:01:31   RegL_00.        01:01 02:01 09:01 0A:F1 0B:12 0C:34 0E:0A 0F:00  11:00 12:15 16:01 18:00 19:00 1A:00 00:00
     2017-11-19 18:49:47   RegL_07.
     2017-11-19 23:41:09   actuator        0
     2017-11-19 23:41:09   battery         ok
     2017-11-19 23:41:09   batteryLevel    2.9
     2017-11-15 11:55:02   controlMode     manual
     2017-11-19 23:41:09   desired-temp    22.0
     2017-11-19 23:41:09   measured-temp   22.5
     2017-11-19 23:41:09   motorErr        ok
     2017-09-08 17:58:27   powerOn         2017-09-08 17:58:27
     2017-09-08 17:58:27   recentStateType info
     2017-11-19 18:47:36   state           CMDs_done
     2017-11-18 19:39:12   time-request    -
   helper:
     HM_CMDNR   192
     mId        0095
     rxType     140
     supp_Pair_Rep 0
     expert:
       def        1
       det        0
       raw        1
       tpl        0
     io:
       newChn     +51A418,00,00,00
       nextSend   1511131269.01363
       prefIO
       rxt        2
       vccu
       p:
         51A418
         00
         00
         00
     mRssi:
       mNo        C0
       io:
         nanoCUL    -51.5
     prt:
       bErr       0
       sProc      0
     q:
       qReqConf
       qReqStat
     role:
       dev        1
       prs        1
     rssi:
       at_nanoCUL:
         avg        -53.6696428571429
         cnt        112
         lst        -53.5
         max        -52.5
         min        -55
     shRegW:
       07         04
     tmpl:
   IODev      nanoCUL
   actCycle   000:10
   actStatus  alive
   expert     2_raw
   firmware   1.4
   model      HM-CC-RT-DN
   room       CUL_HM
   serialNr   NEQ1491261
   subType    thermostat
   webCmd     getConfig:clear msgEvents:burstXmit
und vielen Dank für eure Geduld mit mir :-)
Grüße, Mike
Hallo Mike,
Du musst beim HM_56AD6C  nochmal die Datenübertragung anschupsen - configtaste drücken und warten.
Die hier protCmdPend 10 CMDs_pending müssen abgearbeitet werden.
Das wird schon.
CatWeazle
Hallo Otto,
über Nacht hat sich das Listing ohne mein Zutun verändert.
   DEF        56AD6C
   IODev      nanoCUL
   NAME       HM_56AD6C
   NOTIFYDEV  global
   NR         584
   STATE      closed
   TYPE       CUL_HM
     2017-11-20 17:52:03   Activity        alive
     2017-11-20 17:41:49   alive           yes
     2017-11-20 17:41:49   battery         ok
     2017-11-20 17:41:49   contact         closed (to broadcast)
     2017-11-20 17:41:49   recentStateType info
     2017-11-20 17:41:49   sabotageError   off
     2017-11-20 17:41:49   state           closed
     2017-11-20 17:11:44   trigger_cnt     35
   helper:
     HM_CMDNR   177
     mId        00C7
     rxType     28
     expert:
       def        1
       det        0
       raw        1
       tpl        0
     io:
       newChn     +56AD6C,00,00,00
       prefIO
       rxt        2
       vccu
       p:
         56AD6C
         00
         00
         00
     mRssi:
       mNo
     prt:
       bErr       0
       sProc      0
     q:
       qReqConf   00
       qReqStat
     role:
       chn        1
       dev        1
     tmpl:
   IODev      nanoCUL
   actCycle   002:50
   actStatus  alive
   expert     2_raw
   firmware   1.0
   model      HM-SEC-SCo
   serialNr   OEQ0222076
Aber Pair zu 0x000000 nicht zu 0xF11234 wie die Anderen.
Mike
Grüße, Mike
Pfriemler
Ich heiß zwar nicht Otto, aber...
1. glaube ich kaum. Höchstens der Zustand des Fensterkontaktes. Dadurch sieht auch ein erneutes Listing anders aus. Aber ein vorhandenes kann sich nicht mehr ändern.  ;D ;D ;D ;D
2. Fensterkontakt ist ungepairt. Also nachholen: Befehl in FHEM absetzen und zeitnah (!) 's Gnöbbsche am Fensterkontakt drücken. Dann muss der hektisch gelb blinken und am Ende kurz grün leuchten.
CatWeazle
#25
ZitatBefehl in FHEM absetzen und zeitnah (!) 's Gnöbbsche am Fensterkontakt drücken. Dann muss der hektisch gelb blinken und am Ende kurz grün leuchten.
Befehl: set nanoCUL hmPairForSec 30, LED wird nach dem Gnöbbsche am Fensterkontakt drücken kurz Rot oder orange und ist dann sofort grün und aus.
Ich habe diesen Fensterkontakt wiederholt resettet und versucht neu zu Pairen, immer das gleiche, kurz orange dann grün und aus.
Ich versuche es weiter, auch set / getConfig hat nicht geholfen .....
Grüße, Mike
CatWeazle
Hi Leutz,
ich glaube ich habe da etwas gefunden.
Kann es sein, das sich der Fensterschalter (HM_56AD6C) nicht richtig mit dem NanoCul pairen lässt weil noch ein altes Peering mit dem Heizkörperthermostat (HM_51A418) besteht?
   DEF        51A41803
   NAME       HM_51A418_WindowRec
   NOTIFYDEV  global
   NR         534
   STATE      last:HM_56AD6C:0
   TYPE       CUL_HM
   chanNo     03
   device     HM_51A418
   peerList   HM_56AD6C,
     2017-04-27 17:49:09   R-sign          off
     2017-11-20 21:34:41   RegL_01.          08:00 00:00
     2017-11-20 21:34:46   RegL_03.HM_56AD6C_chn-01   04:32 00:00
     2017-11-20 21:34:46   RegL_07.HM_56AD6C_chn-01   05:18 00:00
     2017-11-20 21:34:41   peerList        HM_56AD6C,
     2017-11-20 21:34:41   state           unknown
     2017-10-07 11:47:08   trigLast        HM_56AD6C:0
     2017-10-07 11:47:08   trig_HM_56AD6C  0_4
   helper:
     peerIDsRaw ,56AD6C01,00000000
     expert:
       def        1
       det        0
       raw        1
       tpl        0
     role:
       chn        1
     shadowReg:
     tmpl:
   model      HM-CC-RT-DN
   peerIDs    00000000,56AD6C01,
   stateFormat last:trigLast
wie war noch gleich  der Befehl, dem Heizkörperthermostat den Fensterschalter vergessen zu lassen, also unpeeren
mike
Grüße, Mike
Pfriemler
Nö. Peerings stören beim Pairen nicht.
Ja ich weiß auch nicht mehr, rssi ist ok (-70). Würde zum Entpeeren
set HM_56AD6C peerChan 0 HM_51A418_WindowRec single unset actor
versuchen (überträgt nur an den Partner, also WindowsRec). Aber wie gesagt eigentlich unnötig, wenn das ohnehin wieder geplant ist.
Noch jemand ne Idee warum es wiederholt nicht klappt? Außer dass vll. der Fensterkontakt defekt ist (nur noch sendet, nicht mehr empfängt)?
CatWeazle
okay, wenn ein bestehendes peer beim pairen nicht stört, dann mach es keinen Sinn es aufzulösen, zumal es später auch wieder etabliert werden soll.
Nach unzähligen pair-Versuchen, habe ich jetzt mal wieder:
2017-11-20 22:39:27   R-pairCentral   set_0xF11234
aber mit set_ ist es ja wohl nutzlos.
grüße
mike
Grüße, Mike
Hii,
die Fensterkontakte sind zickig. Und  Du hast einen CUL das macht die Sache nicht einfacher.
Ich denke der funktioniert, sonst würde er nicht so weit kommen.
Du darfst beim Knopf drücken nicht den Sensor auslösen! Also Fenster bewegen oder mit der Hand in die Lichtschranke kommen.
Du kannst auch ein set HM_56AD6C clear msgEvents absetzen und dann ein getConfig. CMDs abarbeiten, Ruhe bewahren, Zeit lassen.
Du kannst auch ein set HM_56AD6C clear all machen und das Pairing nochmal versuchen.
