Autor Thema: Home Connect: Tausende Logeinträge  (Gelesen 6181 mal)
Offline moskito
  • Full Member
  • No RISC - no fun
Antw:Home Connect: Tausende Logeinträge
« Antwort #15 am: 11 Mai 2018, 13:44:49 »
Hab´s erst seit gestern wieder aktiviert, aber um 01:16 bin ich auch dabei:
2018.05.11 01:16:30 2: WAYHxxxx event channel read failed, len:"0", received:""
FHEM auf Intel NUC/Proxmox & Debian 10 + HM-CFG-USB + deconz/Conbee + Zwave + Enocean
Offline Pf@nne
  • Moderator
  • Sr. Member
    • tech_LogBuch
« Antwort #16 am: 12 Mai 2018, 14:25:06 »
Moin, hier mein LOG von heute:
2018.05.11 18:28:52 3: ENIGMA2 set VU_WZ msg info 2 GS%5fAUF
2018.05.11 18:28:57 3: ENIGMA2 set VU_WZ msg info 2 GS%5fZU
2018.05.11 21:04:38 3: ENIGMA2 set VU_WZ msg info 2 GS%5fAUF
2018.05.11 21:04:48 3: ENIGMA2 set VU_WZ msg info 2 GS%5fZU
2018.05.11 23:34:38 3: ENIGMA2 set VU_WZ msg info 2 GS%5fAUF
2018.05.11 23:34:48 3: ENIGMA2 set VU_WZ msg info 2 GS%5fZU
2018.05.12 00:16:26 2: SN878D26PE event channel read failed, len:"0", received:""
2018.05.12 00:16:26 2: HN878G4B6 event channel read failed, len:"0", received:""
2018.05.12 01:16:30 2: SN878D26PE event channel read failed, len:"0", received:""
2018.05.12 01:16:30 2: CS858GRB6 event channel read failed, len:"0", received:""
2018.05.12 01:16:30 2: EX907KXX1E event channel read failed, len:"0", received:""
2018.05.12 01:16:30 2: HN878G4B6 event channel read failed, len:"0", received:""
2018.05.12 04:10:26 2: SN878D26PE event channel timeout, two keep alive messages missing
2018.05.12 04:10:26 2: CS858GRB6 event channel timeout, two keep alive messages missing
2018.05.12 04:10:26 2: EX907KXX1E event channel timeout, two keep alive messages missing
2018.05.12 04:10:26 2: HN878G4B6 event channel timeout, two keep alive messages missing
2018.05.12 08:05:09 3: hcconn refreshing token
2018.05.12 08:59:09 3: ENIGMA2 set VU_WZ msg info 2 GS%5fAUF
2018.05.12 09:07:34 3: ENIGMA2 set VU_WZ msg info 2 GS%5fZU
2018.05.12 10:25:59 3: ENIGMA2 set VU_WZ msg info 2 GS%5fAUF
2018.05.12 10:26:09 3: ENIGMA2 set VU_WZ msg info 2 GS%5fZU
2018.05.12 10:54:21 3: ENIGMA2 set VU_WZ msg info 2 GS%5fAUF
2018.05.12 10:54:46 3: ENIGMA2 set VU_WZ msg info 2 GS%5fZU
2018.05.12 12:44:08 3: ENIGMA2 set VU_WZ msg info 2 GS%5fAUF
2018.05.12 12:44:18 3: ENIGMA2 set VU_WZ msg info 2 GS%5fZU
2018.05.12 13:04:45 3: ENIGMA2 set VU_WZ msg info 2 GS%5fAUF
2018.05.12 13:04:55 3: ENIGMA2 set VU_WZ msg info 2 GS%5fZU
2018.05.12 14:06:19 2: SN878D26PE event channel read failed, len:"0", received:""
2018.05.12 14:06:19 2: CS858GRB6 event channel read failed, len:"0", received:""
2018.05.12 14:06:19 2: EX907KXX1E event channel read failed, len:"0", received:""
2018.05.12 14:06:19 2: HN878G4B6 event channel read failed, len:"0", received:""
Bisher keine Abstürze!!  8)
FHEM auf: DS415+ (Master), Raspberry Pi 2
Offline Schlimbo
  • Sr. Member
« Antwort #17 am: 12 Mai 2018, 19:36:43 »
Also, was alle gemeinsam haben ist der Eintrag um 01:16Uhr die anderen Einträge decken sich nur vereinzelt.
Sieht für mich irgendwie so aus, als würde der HomeConnect Server die Event Channels ab und an selbst beenden, richtig erklären kann ich mir das aber auch nicht.
Da die Version ja bei allen ohne Abstürze läuft, würde ich vorschlagen diese offiziell einzuchecken.
Das Loglevel für "event channel read failed" sollte vorher wieder auf 5 gesetzt werden, damit das Logfile "sauber" bleibt.
@swhome: könntest du das bitte einchecken?
Offline Pf@nne
  • Moderator
  • Sr. Member
    • tech_LogBuch
« Antwort #18 am: 12 Mai 2018, 20:39:48 »
Ich habe Stefan angeschrieben,  weiß aber nicht wie zeitnah er dazu kommt.
Wie schaut es denn mit den Verzögerungen der Events aus, kann man diese Verzögerung noch wegbekommen oder muss man damit leben?
Gruß und vielen Dank für deine Unterstützung!
Pf@nne
Offline Schlimbo
  • Sr. Member
« Antwort #19 am: 12 Mai 2018, 20:48:05 »
Hast du mit der Version noch immer Verzögerungen bei den Events? Ich hatte mit Stefan's letzten Version damit keine Probleme mehr.
Offline Pf@nne
  • Moderator
  • Sr. Member
    • tech_LogBuch
« Antwort #20 am: 12 Mai 2018, 23:15:32 »
Wie schnell reagiert das Modul den bei dir?
Hast du etwas mit Tür?
Bei mir liegen immer noch gut 3-6 Sekunden zwischen dem Öffnen/Schließen der Ofentür und dem Eventuell im Modul.
Zum Ableiten einer direkten Reaktion z.B. anschalten der Küchenbeleuchtung ist das eher ungeeignet.
Was  bei laufendem Programm passiert habe ich noch nicht getestet.
Das ging bisher garniert, das Event ist Teilweise 10 Minuten später gekommen.
Leider kommen wir nicht lokal auf die Geräte.....
Die HomeConnect App greift auch lokal zu, das ist dann auch ohne merkliche Verzögerung.
Pf@nne
Offline Schlimbo
  • Sr. Member
« Antwort #21 am: 13 Mai 2018, 12:43:07 »
@all:
Habe die Version in meinem Beitrag noch mal aktualisiert. Habe noch einen Fehler gefunden, der zum Absturz bei "set SelectedProgram" führen konnte.
@Pf@nne:
Habe leider kein Gerät mit Tür, bei meiner Kaffeemaschine kommen die Events ohne spürbare Verzögerung an, allerdings kann es sein, dass mir hier die 3-6 Sekunden auch bloß nicht auffallen.
Vielleicht kann Stefan hierzu noch was sagen, habe mir die Event Geschichte noch nicht im Detail angesehen.
Offline Pf@nne
  • Moderator
  • Sr. Member
    • tech_LogBuch
« Antwort #22 am: 13 Mai 2018, 16:57:16 »
Kannst du bitte für die geänderte Version einen PullRequest erstellen.
Stefan Check das dann ein.
Vielen Dank für deinen Einsatz!
Pf@nne
Offline swhome
  • Moderator
  • Full Member
« Antwort #23 am: 13 Mai 2018, 17:44:51 »
Ich teste es noch kurz und checke es dann ein. Pull Request machen wir nächstes Mal  ;)
...Update: Die Änderungen von Schlimbo sind in der master Version eingecheckt. VIELEN DANK!
Das mit der Tür probiere ich aus sobald die Sonne untergegangen ist. Erst dann ist meine Küchenbeleuchtung mit der Spülertür synchronisiert  :D
« Letzte Änderung: 13 Mai 2018, 18:17:04 von swhome »
Im Einsatz: FHEM auf Raspberry Pi mit 350 devices, hauptsächlich Homematic Wired und HM-Heizungsregler, dazu diverse Eigenbauten für Fussbodenheizung und LED Beleuchtung. Und jetzt mit Alexa!
Offline Schlimbo
  • Sr. Member
« Antwort #24 am: 13 Mai 2018, 18:30:13 »
super, Danke!
Freut mich, dass ich helfen konnte  :)
Offline swhome
  • Moderator
  • Full Member
« Antwort #25 am: 13 Mai 2018, 18:38:53 »
Hab gerade noch eine Mini-Änderung nachgeschossen, damit das Attribut "updateTimer" wieder setzbar ist.
Für das Thema mit der Tür noch folgende Anmerkung:
Die letzten Änderungen von Schlimbo und mir hatten zum Ziel, bei Geräten mit sehr vielen Updates zeitnah und schnell genug verarbeiten zu können. Beispiele waren der Backofen oder die Kaffeemaschine mit laufendem Programm. Eine geringere Verzögerung bei einzelnen Updates hingegen kann durch das Setzen des Attributs updateTimer bei der betreffenden Maschine erzielt werden. Hier steht der Standardwert auf 5 Sekunden um in FHEM Ressourcen für wichtigere Dinge freizuhalten. Wenn schneller reagiert werden soll, ist auch der Wert 1 ok.
Offline Schlimbo
  • Sr. Member
« Antwort #26 am: 13 Mai 2018, 18:55:03 »
Der gleiche Fehler hat sich auch bei "accessScope" in der 48_HomeConnectConnection.pm eingeschlichen.
Offline swhome
  • Moderator
  • Full Member
« Antwort #27 am: 13 Mai 2018, 20:17:32 »
Stimmt. Hab ich nun auch behoben. Merci!
decade-submarginal
