[73_AutoShuttersControl.pm] Neues Modul zum automatisierten steuern von Rolläden
Begonnen von CoolTux, 30 Oktober 2018, 17:29:46
majestro84
Hi
Lass mal am Ende den \ weg.
Der wird benötigt wenn du es in der fhem.cfg editierst.
Wenn du es unter dem attr commands in der Weboberfläche machst benötigst du den  \ nicht.
Hier mal meine:
{position => 'dim:0,10,20,30,35,40,45,50,55,60,65,70,75,80,85,90,95,100',
ASC_Mode_Down => 'ASC_Mode_Down:always,absent,off',
ASC_Mode_Up => 'ASC_Mode_Up:always,absent,off',
ASC_Partymode => 'ASC_Partymode:on,off',
ASC_LockOut => 'ASC_LockOut:soft,hard,off',
ASC_Time_Down_Early => 'ASC_Time_Down_Early:15:00,15:15,15:30,15:45,16:00,16:15,16:30,16:45,17:00,17:15,17:30,17:45,18:00,18:15,18:30,18:45,19:00,19:15,19:30,19:45,20:00,20:15,20:30,20:45,21:00,21:15,21:30,21:45,22:00',
ASC_Time_Down_Late  => 'ASC_Time_Down_Late:20:15,20:30,20:45,21:00,21:15,21:30,21:45,22:00,22:15,22:30,22:45,23:00,23:15,23:30',
ASC_Time_Up_Early => 'ASC_Time_Up_Early:05:00,05:05,05:30,05:45,06:00,06:15,06:30,06:45,07:00,07:15,07:30,07:45,08:00,08:15,08:30,08:45,09:00,09:15,09:30,09:45,10:00',
ASC_Time_Up_Late =>'ASC_Time_Up_Late:06:00,06:15,06:30,06:45,07:00,07:15,07:30,07:45,08:00,08:15,08:30,08:45,09:00,09:15,09:30,09:45,10:00',
ASC_Time_Up_WE_Holiday => 'ASC_Time_Up_WE_Holiday:06:00,06:15,06:30,06:45,07:00,07:15,07:30,07:45,08:00,08:15,08:30,08:45,09:00,09:15,09:30,09:45,10:00'}
und zum Level einstellen
{ ASC_Closed_Pos => 'ASC_Closed_Pos:0,10,20,30,35,40,45,50,55,60,65,70,75,80,85,90,95,100',
ASC_Open_Pos => 'ASC_Open_Pos:0,10,20,30,35,40,45,50,55,60,65,70,75,80,85,90,95,100',
ASC_ComfortOpen_Pos => 'ASC_ComfortOpen_Pos:0,10,20,30,35,40,45,50,55,60,65,70,75,80,85,90,95,100',
ASC_Ventilate_Pos => 'ASC_Ventilate_Pos:0,10,20,30,35,40,45,50,55,60,65,70,75,80,85,90,95,100',
ASC_PrivacyDown_Pos => 'ASC_PrivacyDown_Pos:0,10,20,30,35,40,45,50,55,60,65,70,75,80,85,90,95,100',
ASC_Shading_Pos => 'ASC_Shading_Pos:0,10,20,30,35,40,45,50,55,60,65,70,75,80,85,90,95,100'}
Gruß Alex
Server: Fujitsu ESPRIMO Q920 - aktuellen FHEM-Docker Image:Z-Wave (RollerShutter,DoorWindow,Socket,PIR,....) | ENIGMA2 | EGPM2LAN | BLE-Tag(PRESENCE) | HUE | alexa-fhem | Shelly | MQTT2
1.Pi-Zero:Viessmann(optolink) mit 89_VCONTROL300.pm
2.Pi3 Dongle Server: Zigbee2MQTT(CC1352P-2), Z-Wave(UZB1), BT
stonev
Danke, aber das hat leider nichts verändert.
In der fhem.cfg sieht bei das Ganze wie folgt aus:
define rg_ASC_Rollaeden_Times readingsGroup <Gerät>,<Stand>,<Time_Up_Early>,<Time_Up_WE>,<Time_Up_Late>,<Time_Down_Early>,<Time_Down_Late>,<Mode_Down>,<Mode_Up> (Rolladen_.*|Jalousie_.*)..:level,?ASC_Time_Up_Early,?ASC_Time_Up_WE_Holiday,?ASC_Time_Up_Late,?ASC_Time_Down_Early,?ASC_Time_Down_Late,?ASC_Mode_Down,?ASC_Mode_Up attr rg_ASC_Rollaeden_Times commands
setuuid rg_ASC_Rollaeden_Times 5c499acc-f33f-d066-da6e-18c78518334aa719
attr rg_ASC_Rollaeden_Times alias Rolladen Fahrzeiten
attr rg_ASC_Rollaeden_Times mapping {position => 'dim:0,10,20,30,35,40,45,50,55,60,65,70,75,80,85,90,95,100',\
ASC_Mode_Down => 'ASC_Mode_Down:always,absent,off',\
ASC_Mode_Up => 'ASC_Mode_Up:always,absent,off',\
ASC_Partymode => 'ASC_Partymode:on,off',\
ASC_LockOut => 'ASC_LockOut:soft,hard,off',\
ASC_Time_Down_Early => 'ASC_Time_Down_Early:15:00,15:15,15:30,15:45,16:00,16:15,16:30,16:45,17:00,17:15,17:30,17:45,18:00,18:15,18:30,18:45,19:00,19:15,19:30,19:45,20:00,20:15,20:30,20:45,21:00,21:15,21:30,21:45,22:00', \
ASC_Time_Down_Late  => 'ASC_Time_Down_Late:20:15,20:30,20:45,21:00,21:15,21:30,21:45,22:00,22:15,22:30,22:45,23:00,23:15,23:30',\
ASC_Time_Up_Early => 'ASC_Time_Up_Early:05:00,05:05,05:30,05:45,06:00,06:15,06:30,06:45,07:00,07:15,07:30,07:45,08:00,08:15,08:30,08:45,09:00,09:15,09:30,09:45,10:00',\
ASC_Time_Up_Late =>'ASC_Time_Up_Late:06:00,06:15,06:30,06:45,07:00,07:15,07:30,07:45,08:00,08:15,08:30,08:45,09:00,09:15,09:30,09:45,10:00',\
attr rg_ASC_Rollaeden_Times room Rolladenautomatik
majestro84
Was mir auffällt du hast das alles unter attr Mapping und nicht unter attr commands
Zitatattr rg_ASC_Rollaeden_Times mapping {position => 'dim:0,10,20,30,35,40,45,50,55,60,65,70,75,80,85,90,95,100',\    usw.............
Normalerweise sollte es gehen
Zitatattr rg_ASC_Rollaeden_Times commands{pct => 'dim:0,10,20,30,35,40,45,50,55,60,65,70,75,80,85,90,95,100',\
no_Legend
Ich hab zwei Readinggroups gemacht, hier direkt aus dem FHEM Config kopiert.:
define rg_ASC_Rollaeden_Level readingsGroup <Gerät>,<ASC>,<Antifreeze>,<Antifreeze_Pos>,<Closed_Pos>,<Open_Pos>,<ASC_Ventilate_Pos> \
(.*Rollladen.*|.*Rollladen|Jalousie_.*):?ASC,?ASC_Antifreeze,?ASC_Antifreeze_Pos,?ASC_Closed_Pos,?ASC_Open_Pos,?ASC_Ventilate_Pos
setuuid rg_ASC_Rollaeden_Level 5c4308e1-f33f-abd1-167d-cc1b5f137cf793c8
attr rg_ASC_Rollaeden_Level commands {ASC => 'ASC:0,1,2',\
ASC_Antifreeze => 'ASC_Antifreeze:off,soft,hard,am,pm',\
ASC_Antifreeze_Pos =>'ASC_Antifreeze_Pos:0,10,20,30,35,40,45,50,55,60,65,70,75,80,85,90,95,100', \
ASC_Closed_Pos => 'ASC_Closed_Pos:0,10,20,30,35,40,45,50,55,60,65,70,75,80,85,90,95,100', \
ASC_Open_Pos => 'ASC_Open_Pos:0,10,20,30,35,40,45,50,55,60,65,70,75,80,85,90,95,100', \
ASC_Ventilate_Pos => 'ASC_Ventilate_Pos:0,10,20,30,35,40,45,50,55,60,65,70,75,80,85,90,95,100'}
attr rg_ASC_Rollaeden_Level room 9.72_Rolladen
define rg_ASC_Rollaeden_Times readingsGroup <Gerät>,<Position>,<Time_Up_Early>,<Time_Up_Late>,<Time_Up_WE/Hol>,<Time_Down_Early>,<Time_Down_Late>,<Mode_Down>,<Mode_Up> \
(.*Rollladen.*|.*Rollladen|Jalousie_.*):level,?ASC_Time_Up_Early,?ASC_Time_Up_Late,?ASC_Time_Up_WE_Holiday,?ASC_Time_Down_Early,?ASC_Time_Down_Late,?ASC_Mode_Down,?ASC_Mode_Up
setuuid rg_ASC_Rollaeden_Times 5c4308e1-f33f-abd1-94a7-fbf717635760f863
attr rg_ASC_Rollaeden_Times commands {level => 'pct:0,10,20,30,35,40,45,50,55,60,65,70,75,80,85,90,95,100', \
ASC_Time_Down_Late  => 'ASC_Time_Down_Late:19:00,19:15,19:30,19:45,20:00,20:15,20:30,20:45,21:00,21:15,21:30,21:45,22:00,22:15,22:30,22:45,23:00,23:15,23:30', \
ASC_Time_Up_WE_Holiday => 'ASC_Time_Up_WE_Holiday:06:00,06:15,06:30,06:45,07:00,07:15,07:30,07:45,08:00,08:15,08:30,08:45,09:00,09:15,09:30,09:45,10:00',\
ASC_Time_Up_Early => 'ASC_Time_Up_Early:05:00,05:05,05:30,05:45,06:00,06:15,06:30,06:45,07:00,07:15,07:30,07:45,08:00,08:15,08:30,08:45,09:00,09:15,09:30,09:45,10:00',  \
ASC_Time_Up_Late => 'ASC_Time_Up_Late:06:00,06:15,06:30,06:45,07:00,07:15,07:30,07:45,08:00,08:15,08:30,08:45,09:00,09:15,09:30,09:45,10:00', \
ASC_Mode_Down => 'ASC_Mode_Down:always,absent,off', \
ASC_Mode_Up => 'ASC_Mode_Up:always,absent,off' }
attr rg_ASC_Rollaeden_Times room 9.72_Rolladen
Docker FHEM immer aktuell,4x HMLAN, CUL443, CUL868 -homekit/siri -tablet ui -homebridge
Device, diverse:
Homematic, Shelly, Tasmota, MQTT, Unifi Network usw.
stonev
coolice
Sehe gerade das mein Log hiermit zugefüllt wird. AutoShuttersControl (AutoShuttersControl) - Shading Processing, Rollladen: Rol.OG.ku Azimuth: 245.32 Elevation: -4.1 Brightness: 87 OutTemp: -1.5 soll das so sein?
CoolTux
Das TuxNet Wiki:
https://www.cooltux.net
majestro84
Hallo
Kurze Frage habe die Version 0.4.0 aus dem git. Was mir aufgefallen ist normal werden doch Fahrten nachgeholt oder? Aktueller Fall Fenster offen night close fährt alle runter bis auf das geöffnete. Jetzt war es meine ich immer so wenn dann das Fenster geschlossen wird die Fahrt nach geholt. Was aber nicht passiert ist. Kannst du da Mal gucken oder hast du das so geändert?
Gruß Alex
CoolTux
Das ist das was ein paar Posts vorher angesprochen wurde. Wir können da gerne noch mal drüber reden, nur halt irgendwann uns einigen.
Das TuxNet Wiki:
majestro84
Ah okay hatte ich nicht mehr auf dem Schirm. Ich persönlich fande es besser wenn die Fahrt dann nachgeholt wird. Sollten vielleicht Mal ne Umfrage starten.
CoolTux
Eigentlich hätte er dennoch schließen müssen. Nicht als nachgeholt sondern als reguläre Fenster Event Fahrt. Nachts, Fenster schließen, Rollo fährt runter.
Aber während ich das hier schreibe weiß ich schon warum das nicht ging. Es geht nur wenn die Fenster offen Position erreicht war. Nicht bei komplett offen. Das schaue ich mir an.
Das TuxNet Wiki:
coolice
Finde ich auch besser
CoolTux
Also es hätte eigentlich klappen müssen. Sobald die Sunset Zeit erreicht ist wird geprüft ob Fenster offen ist oder nicht und dann wird ganz geschlossen oder auf Lüften.
Aber du hattest threestate und auf offen nicht gekippt. Daher hat es nicht geklappt.
Da muss ich mir noch mal was überlegen.
Das TuxNet Wiki:
majestro84
Genau threestate der offen war und nicht gekippt. Mach dir kein Stress bis jetzt läuft es dich ziemlich rund schon für die kurze Zeit
CoolTux
Eine neue Version liegt im master des Gits zum Download und testen bereit. Würde mich freuen wenn zwei drei Leute sich das einmal anschauen würden. Wenn das ein wenig getestet ist gebe ich das dann erstmal frei ins SVN von FHEM
Das TuxNet Wiki:
