Autor Thema: MAX_Parse: Unknown message WallThermostatState  (Gelesen 15151 mal)
ne20002
  • Gast
Aw: MAX_Parse: Unknown message WallThermostatState
« Antwort #45 am: 15 Januar 2013, 17:38:02 »
Hallo Matthias,
der plot sieht jetzt richtig gut aus. Aber ein paar Fehlermeldungen bekomme ich noch im log:
1)
2013.01.14 23:57:15 5: CUL_0: Z0FE90503022A8C02A3A0000D0E56394C -31
2013.01.14 23:57:15 5: CUL_0 dispatch Z0FE90503022A8C02A3A0000D0E56394C
2013.01.14 23:57:15 5: CUL_MAX_Parse: len 15, msgcnt E9, msgflag 05, msgTypeRaw TimeInformation, src 022a8c, dst 02a3a0, groupid 0, payload 0D0E56394C
2013.01.14 23:57:15 5: CUL_MAX_Parse: Got TimeInformation: (in GMT) year 2013, mon 1, day 14, hour 22, min 57, sec 12, unk (2, 0, 1)
Use of uninitialized value $found[0] in string eq at /usr/bin/fhem.pl line 2520.
2013.01.14 23:57:15 5: CUL/RAW: /Z11E9020202A3A0022A8C00011A041C108D0C2D
2013.01.14 23:57:15 5: CUL_0: Z11E9020202A3A0022A8C00011A041C108D0C -51.5
2013.01.14 23:57:15 5: CUL_0 dispatch Z11E9020202A3A0022A8C00011A041C108D0C
2013.01.14 23:57:15 5: CUL_MAX_Parse: len 17, msgcnt E9, msgflag 02, msgTypeRaw Ack, src 02a3a0, dst 022a8c, groupid 0, payload 011A041C108D0C
2013.01.14 23:57:15 5: MAXCUL0 dispatch MAX,0,Ack,02a3a0,011A041C108D0C
2013.01.14 23:57:15 5: MAX_Parse MAX,0,Ack,02a3a0,011A041C108D0C
2013.01.14 23:57:15 5: MAX_Parse MAX,0,WallThermostatState,02a3a0,1A041C108D0C
2013.01.14 23:57:15 2: Invalid WallThermostatState packet
Use of uninitialized value $desiredTemperature in division (/) at /usr/share/fhem/FHEM/10_MAX.pm line 537.
2013.01.14 23:57:15 5: desiredTemperature 0
2013.01.14 23:57:15 5: Triggering MAX_Wohnzimmer_Wandthermostat (2 changes)
2013.01.14 23:57:15 5: Notify loop for MAX_Wohnzimmer_Wandthermostat desiredTemperature: 0.0
2)
Und dieses. Da hatte ich gerade die eco temperature per MAX von 14 auf 15 erhöht.
2013.01.15 08:58:48 5: CUL/RAW: /Z11EB0011022A8C02A3A0002B1E3D0907180356
2013.01.15 08:58:48 5: CUL_0: Z11EB0011022A8C02A3A0002B1E3D09071803 -31
2013.01.15 08:58:48 5: CUL_0 dispatch Z11EB0011022A8C02A3A0002B1E3D09071803
2013.01.15 08:58:48 5: CUL_MAX_Parse: len 17, msgcnt EB, msgflag 00, msgTypeRaw ConfigTemperatures, src 022a8c, dst 02a3a0, groupid 0, payload 2B1E3D09071803
2013.01.15 08:58:48 5: Unhandled message ConfigTemperatures
2013.01.15 08:58:48 5: CUL/RAW: /Z11EB020202A3A0022A8C00011A041C108D0C2C
2013.01.15 08:58:48 5: CUL_0: Z11EB020202A3A0022A8C00011A041C108D0C -52
2013.01.15 08:58:48 5: CUL_0 dispatch Z11EB020202A3A0022A8C00011A041C108D0C
2013.01.15 08:58:48 5: CUL_MAX_Parse: len 17, msgcnt EB, msgflag 02, msgTypeRaw Ack, src 02a3a0, dst 022a8c, groupid 0, payload 011A041C108D0C
2013.01.15 08:58:48 5: MAXCUL0 dispatch MAX,0,Ack,02a3a0,011A041C108D0C
2013.01.15 08:58:48 5: MAX_Parse MAX,0,Ack,02a3a0,011A041C108D0C
2013.01.15 08:58:48 5: MAX_Parse MAX,0,WallThermostatState,02a3a0,1A041C108D0C
2013.01.15 08:58:48 2: Invalid WallThermostatState packet
2013.01.15 08:58:48 5: desiredTemperature 0
2013.01.15 08:58:48 5: Triggering MAX_Wohnzimmer_Wandthermostat (2 changes)
2013.01.15 08:58:48 5: Notify loop for MAX_Wohnzimmer_Wandthermostat desiredTemperature: 0.0
Und:
2013.01.15 09:00:48 5: CUL/RAW: /Z0EEC0540022A8C02A3A0019E108D1255
2013.01.15 09:00:48 5: CUL_0: Z0EEC0540022A8C02A3A0019E108D12 -31.5
2013.01.15 09:00:48 5: CUL_0 dispatch Z0EEC0540022A8C02A3A0019E108D12
2013.01.15 09:00:48 5: CUL_MAX_Parse: len 14, msgcnt EC, msgflag 05, msgTypeRaw SetTemperature, src 022a8c, dst 02a3a0, groupid 1, payload 9E108D12
2013.01.15 09:00:48 5: Unhandled message SetTemperature
2013.01.15 09:00:48 5: CUL/RAW: /Z11EC020202A3A0022A8C00011A041E108D122D
2013.01.15 09:00:48 5: CUL_0: Z11EC020202A3A0022A8C00011A041E108D12 -51.5
2013.01.15 09:00:48 5: CUL_0 dispatch Z11EC020202A3A0022A8C00011A041E108D12
2013.01.15 09:00:48 5: CUL_MAX_Parse: len 17, msgcnt EC, msgflag 02, msgTypeRaw Ack, src 02a3a0, dst 022a8c, groupid 0, payload 011A041E108D12
2013.01.15 09:00:48 5: MAXCUL0 dispatch MAX,0,Ack,02a3a0,011A041E108D12
2013.01.15 09:00:48 5: MAX_Parse MAX,0,Ack,02a3a0,011A041E108D12
2013.01.15 09:00:48 5: MAX_Parse MAX,0,WallThermostatState,02a3a0,1A041E108D12
2013.01.15 09:00:48 2: Invalid WallThermostatState packet
2013.01.15 09:00:48 5: desiredTemperature 0
2013.01.15 09:00:48 5: Triggering MAX_Wohnzimmer_Wandthermostat (2 changes)
2013.01.15 09:00:48 5: Notify loop for MAX_Wohnzimmer_Wandthermostat desiredTemperature: 0.0
Gruss,
 S.
Offline Matthias Gehre
  • Sr. Member
« Antwort #46 am: 15 Januar 2013, 23:51:05 »
Hey,
das erste habe ich gefixt, das andere beiden sind eher Infos, dass wir mit den bestimmten Paketen nichts tun, keine Fehler.
Viele Grüße,
Matthias
Offline svenkoethe
  • New Member
« Antwort #47 am: 25 März 2013, 08:55:44 »
Ich ziehe den Thread nochmal hoch,
die Frage nach der Temperatur über 25,5° ist ja noch offen.
Also bei mir geht die Temperatur ab 25.5° am Wandthermostat auf 0.0° in FHEM.
Alles darüber wird in FHEM als Offset von 25.5° angezeigt Beispiel:
Thermostat 27.2° Anzeige FHEM 1.7°
2013.03.24 20:33:07 5: ml dispatch MAX,1,WallThermostatState,057ded,1904a801040011
2013.03.24 20:33:07 5: MAX_Parse MAX,1,WallThermostatState,057ded,1904a801040011
2013.03.24 20:33:07 5: battery 0, rferror 0, panel 0, langateway 1, dstsetting 1, mode 1, displayActualTemperature 4, heaterTemperature , untilStr 1.0.4 0:00
2013.03.24 20:33:07 5: desiredTemperature 20, temperature 1.7
2013.03.24 20:33:07 5: Triggering Wand_Wohn (6 changes)
2013.03.24 20:33:07 5: Notify loop for Wand_Wohn mode: manual
2013.03.24 20:33:07 5: len 6, addr 051c88, initialized 0, valid 0, rferror 0, errframetype 9, answer 0, unkbit (0,0,0)
2013.03.24 20:33:07 5: len 6, addr 0614be, initialized 1, valid 1, rferror 0, errframetype 9, answer 0, unkbit (0,0,0)
Ich habe lange verzeifelt in sämtlichen Einstellungen und im Forum gesucht bis ich hier gefunden habe,
das diese Problem evtl. bekannt ist...
Gibt es hierzu bereits Neuigkeiten ?
  • Sr. Member
« Antwort #48 am: 26 März 2013, 05:48:41 »
Fix ist committed, bitte testen.
