httpmod.template: bugs, Fragen, Anregungen
Begonnen von Beta-User, 21 Februar 2019, 12:04:17
Tueftler1983
Zitat von: Beta-User am 03 Dezember 2019, 12:24:52Na ja, viele Fragezeichen sind es nicht mehr...
Wenn "wir" das mit der firmware nicht in denselben HTTPMOD bekommen, würde ich vorschlagen, den Namen um "daemon" zu erweitern, das ganze ergäbe dann:
#Contributed by OdfFHEM, see https://forum.fhem.de/index.php/topic,97694.msg998835.html#msg998835
filter:TYPE=HTTPMOD
desc: Check zigbee2mqtt homepage for new versions of the deamon software.<br>Define a HTTPMOD device like <br>define zigbee2mqtt_updates HTTPMOD https://github.com/Koenkk/zigbee2mqtt/tags 604800<br>
<a href="https://forum.fhem.de/index.php/topic,97694.msg998835.html#msg998835">Source: Forum</a>.
order:X_01f
par:WHICHROOM;Actual room of the device, defaults to HTTPMOD; {AttrVal("DEVICE","room","HTTPMOD" )}
par:INTERVAL;Actual interval for updating, defaults to one day; {InternalVal("DEVICE","Interval",604800)}
par:UPDATABLEDEVICESMODE;Actual mode for updatableDevices, defaults to onlyUpdatable; {AttrVal("DEVICE","updatableDevicesMode","onlyUpdatable")}
defmod DEVICE HTTPMOD https://github.com/Koenkk/zigbee2mqtt/tags INTERVAL
attr DEVICE userattr reading01Name reading01Regex reading02Name reading02OExpr reading02Regex updatableDevicesMode:onlyUpdatable,all
attr DEVICE enableControlSet 1
attr DEVICE event-on-change-reading .*
attr DEVICE event-on-update-reading LAST_ERROR,MATCHED_READINGS
attr DEVICE handleRedirects 0
attr DEVICE reading01Name latestVersion
attr DEVICE reading01Regex commit-title">[\w\W]*?<a href=".*">[\w\W]*?(\d*\.\d*\.\d*)[\w\W]*?</a>
attr DEVICE reading02Name latestDate
attr DEVICE reading02OExpr $val =~ m/^(.{4})-(.{2})-(.{2})$/ ;; "$3.$2.$1"
attr DEVICE reading02Regex relative-time[\w\W]*?datetime="(\d*-\d*-\d*)T\d*:\d*:\d*Z"
attr DEVICE showError 1
attr DEVICE showMatched 1
attr DEVICE stateFormat {   my $ret ="";;\
    my $lastCheck = ReadingsTimestamp($name,"MATCHED_READINGS","???");;\
    $ret .= '<div style="text-align:left">';;\
    $ret .= 'last <a title="versions" href="'.InternalVal($name,"MainURL","unknown").'">ZigBee</a>-check => '.$lastCheck;;\
    $ret .= '<br><br><pre>';;\
    $ret .= "| device                           | current |   new   |  released  |<br>";;\
    $ret .= "---------------------------------------------------------------------<br>";;\
    my $check = ReadingsVal($name,"updatableDevices","error => no or wrong data from server!");;\
    if($check eq "no updates needed!") {\
      $ret .= '| <b style="color:green">';;\
      $ret .= sprintf("%-65s",$check);;\
      $ret .= '</b> |';;\
    } elsif($check eq "error => no or wrong data from server!") {\
      $ret .= '| <b style="color:red">';;\
      $ret .= '</b> |';;\
    } else {\
      my @devices = split(',',$check);;\
      foreach my $devStr (@devices) {\
        my ($dev,$old,$new,$date) = $devStr =~ m/^([^\s]+)\s\(([^\s]+)\s\|\s([^\s]+)\s\|\s([^\)]+)\)$/;;\
        $ret .= '| <a href="/fhem?detail='.$dev.'"><b>';;\
        $ret .= sprintf("%-32s",$dev);;\
        $ret .= '</b></a> | ';;\
        $ret .= '<b style="color:lightgray">';;\
        $ret .= sprintf("%7s",$old);;\
        $ret .= '</b> | ';;\
        $ret .= '<a href="https://github.com/Koenkk/zigbee2mqtt/releases/tag/'.$new.'">';;\
        $ret .= '<b style="color:'.(($new eq $old)?'black':'red').'">';;\
        $ret .= sprintf("%7s",$new);;\
        $ret .= '<b style="color:black">';;\
        $ret .= sprintf("%-10s",$date);;\
        $ret .= '</b></a>';;\
        $ret .= " |<br>";;\
    $ret .= '</pre></div>';;\
  return $ret;;\
attr DEVICE updatableDevicesMode UPDATABLEDEVICESMODE
attr DEVICE timestamp-on-change-reading .*
attr DEVICE userReadings updatableDevices:MATCHED_READINGS.* {\
  my $ret = "";;\
  if (ReadingsVal($name,"MATCHED_READINGS","") eq "") {\
    $ret = "error => no or wrong data from server!";;\
  } else {\
    my $VERSION = ReadingsVal($name,"latestVersion","unknown");;\
    my $DATE = ReadingsVal($name,"latestDate","unknown");;\
    foreach my $dev (devspec2array("TYPE=MQTT[2]?_[D]EVICE:FILTER=permit_join!=")) {\
      my $version = ReadingsVal($dev,"version","0.0.0");;\
      $version =~ m/([0-9.]*).*/;;\
      $version = $1;;\
      if (AttrVal($name,"updatableDevicesMode","onlyUpdatable") eq "all" || $version ne $VERSION) {\
        $ret .= "," if($ret ne "");;\
        $ret .= $dev." (".$version." | ".$VERSION." | ".$DATE.")";;\
  return ($ret eq "")?"no updates needed!":$ret;;\
attr DEVICE webCmd reread
attr DEVICE room WHICHROOM
attr DEVICE model zigbee2mqtt_daemon_updates
In die mqtt2.template-file würde ich dann zu zigbee2mqtt_bridge noch folgendes anfügen?
attr DEVICE comment To check for new updates of the deamon software, you might want to use a separate HTTPMOD device. See HTTPMOD template zigbee2mqtt_daemon_updates for further details.
Leider bekomme ich das Device nicht angelegt, bzw angelegt wird es aber mit einem fehler habe es mit dem Template:
Unknown command <a, try help.
Es wird zwar das Datum des letzten Release angescheigt aber weder die aktuelle installierte Version noch die zuletzt verfügbare.
Tueftler1983
#241
Zitat von: 50watt am 30 Juni 2023, 12:50:22Ich schlage folgende Änderung für das HTTPMOD template "zigbee2mqtt_daemon_updates" vor:
Statt (templateVersion: 20201129)
attr DEVICE reading01Regex commit-title">[\w\W]*?[\w\W]*?(\d*\.\d*\.\d*)[\w\W]*?
das:
attr DEVICE reading01Regex <a href=\"\/Koenkk\/zigbee2mqtt\/releases\/tag\/*?(\d*\.\d*\.\d*)[\w\W]*?</a>
Damit funktioniert (für mich) die Abfrage für die "latestVersion" von zigbee2mqtt wieder.
Dank diesem Post funktioniert zumindest die Anzeige der aktuellsten Verfügbaren Version
Aber die aktuell installierte Version wird immer noch nicht angezeigt bzw steht bei mir auf 0.0.0 in Grau
oelidoc
das:
Leider ist das Template bei mir derzeit funktionslos: es wird weder die aktuelle noch eine neue Version angezeigt und LAST_ERROR read from https://github.com:443 timed out.Gibt es irgendwelche Veränderungen, die mir entgangen sind? Was müsste ich ändern?
oelidoc
satprofi
hallo.
frage zu alignTime, seit uhrzeitumstellung klappt das nicht mehr.
habe 00:03 definiert, aber es startet jetzt immer um 23:03, warum ?
systemzeit etc. passt aber. wie schaffe ich es jetzt wieder um 00:03h zu starten ?
Tasmota,LD382A,Telegram
amenomade
Zitat von: satprofi am 01 November 2025, 09:49:07systemzeit etc. passt aber. wie schaffe ich es jetzt wieder um 00:03h zu starten ?
Was sagt
{localtime()} ?
satprofi
amenomade
#246
Und
{qx(date)}auch? Steht da auch CEST?
Und liefert {$isdst} null?
Wenn alles richtig, würde ich die Frage im HTTPMOD Forum stellen.
Tueftler1983
Hallo ich nochmal
Ich habe jetzt die Version 2.7.2 installiert, diese wird auch als aktuellste angezeigt
ABER
In der aktuell installierten Version wird noch version 2.0.1 angezeigt.
Wo bekommt der die Infos über die aktuelle Version her??
DeeSPe
Zitat von: Tueftler1983 am 15 Januar 2026, 21:36:04Hallo ich nochmal
ABER
Ich sitze auch gerade an dem Thema!
Allerdings bekomme ich die Version von zigbee2mqtt überhaupt nicht ausgelesen.
Wie habt ihr das hinbekommen? Habe schon das Forum durchsucht, leider erfolglos.
Dan
Tueftler1983
Es wird ja die Version aus dem Device "MQTT2_zigbee_pi" ausgelesen, die version die da angezeigt wird, wird bei mir ja auch richtig angezeigt.
Aber das Device "MQTT2_zigbee_pi" liest nicht die richtige version von Zigbee2Mqtt aus. denn da habe ich die version: 2.7.2 Installiert
Lg Holger
Tueftler1983
Ich finde in der def des Template leider nichts wie die Version ausgelesen wird.
# zigbee2mqtt
# The zigbee2mqtt bridge device (entire hex id of devices as bridgeRegexp)
desc:The zigbee2mqtt bridge device
filter:TYPE=MQTT2_DEVICE
order:L_01
farewell:template has been applied successfully. Note: In case you not exclusively use FHEM to send MQTT commands to your devices, it's highly recommended to extend the ignoreRegexp of your IO device! Could be something like |zigbee2mqtt/[A-Za-z0-9._]+/set.
par:BASE_TOPIC;base topic as set in configuration.yaml of the zigbee2mqtt bridge;{ AttrVal("DEVICE","devicetopic","") =~ m,[\b]?([^/:]+)(/.+)?, ? $1 : AttrVal("DEVICE","readingList","") =~ m,[\b]?([^/:]+)/bridge/.+, ? $1 : undef }
par:ICON;ICON as set, defaults to mqtt;{ AttrVal("DEVICE","icon","mqtt") }
attr DEVICE icon ICON
attr DEVICE devicetopic BASE_TOPIC
attr DEVICE bridgeRegexp\
  BASE_TOPIC/((?!bridge)[A-Za-z0-9._]+)/?.*:.* "zigbee_$1"
attr DEVICE getList\
  networkmap_raw:noArg raw $\DEVICETOPIC/bridge/request/networkmap raw\
  networkmap_graphviz:noArg graphviz $\DEVICETOPIC/bridge/request/networkmap graphviz
attr DEVICE readingList\
  $\DEVICETOPIC/bridge/state:.* state\
  $\DEVICETOPIC/bridge/config/devices:.* {}\
  $\DEVICETOPIC/bridge/config/log_level:.* log_level\
  $\DEVICETOPIC/bridge/config/permit_join:.* permit_join\
  $\DEVICETOPIC/bridge/config/rename:.* { json2nameValue($EVENT, 'rename_') }\
  $\DEVICETOPIC/bridge/config:.* { json2nameValue($EVENT) }\
  $\DEVICETOPIC/bridge/log:.*\"type\".\"devices\".\"message\".* devices\
  $\DEVICETOPIC/bridge/log:.* log\
  $\DEVICETOPIC/bridge/logging:.* { json2nameValue($EVENT,'log_') }\
  $\DEVICETOPIC/bridge/response/networkmap:.* { my $type = $EVENT =~ m/.*,"type":"(raw|graphviz)",.*/ ? $1 : 'networkmap'; $EVENT =~ m/{"data":\{.*"value":"?(.*[^"])"?\},"status":"ok"\}/ ? { $type=>$1 } : {} }\
  $\DEVICETOPIC/bridge/devices:.* devices\
  $\DEVICETOPIC/bridge/info:.* info\
  $\DEVICETOPIC/bridge/groups:.* groups\
  $\DEVICETOPIC/bridge/event:.* { json2nameValue($EVENT) }\
  $\DEVICETOPIC/bridge/extensions:.* extensions\
  $\DEVICETOPIC/bridge/response/permit_join:.* { json2nameValue($EVENT) }\
  $\DEVICETOPIC/bridge/definitions:.* {}
attr DEVICE setList\
  log_level:debug,info,warn,error $\DEVICETOPIC/bridge/config/log_level $EVTPART1\
  permit_join:true,false $\DEVICETOPIC/bridge/request/permit_join $EVTPART1\
  remove:textField $\DEVICETOPIC/bridge/config/remove $EVTPART1\
  ota_update:textField $\DEVICETOPIC/bridge/ota_update/update $EVTPART1\
  ota_update_check:textField $\DEVICETOPIC/bridge/ota_update/check $EVTPART1\
  y_device_setting:textField $\DEVICETOPIC/$EVTPART1/set {"$EVTPART2": "$EVTPART3"}\
  x_bind:textField $\DEVICETOPIC/bridge/bind/$EVTPART1 $EVTPART2\
  x_bind_unbind:textField $\DEVICETOPIC/bridge/unbind/$EVTPART1 $EVTPART2\
  x_device_options:textField $\DEVICETOPIC/bridge/config/device_options {"friendly_name":"$EVTPART1","options": {"$EVTPART2": "$EVTPART3"}}\
  x_group_add_to:textField $\DEVICETOPIC/bridge/group/$EVTPART1/add $EVTPART2\
  x_group_rm_from:textField $\DEVICETOPIC/bridge/group/$EVTPART1/remove $EVTPART2\
  x_group_rm_from_all:textField $\DEVICETOPIC/bridge/group/$EVTPART1/remove_all $EVTPART2\
  x_group_add_group:textField $\DEVICETOPIC/bridge/config/add_group $EVTPART1\
  x_group_rm_group:textField $\DEVICETOPIC/bridge/config/remove_group $EVTPART1\
  z_elapsed:textField $\DEVICETOPIC/bridge/config/elapsed $EVTPART1\
  z_last_seen:disable,ISO_8601,epoch,ISO_8601_local $\DEVICETOPIC/bridge/config/last_seen $EVTPART1\
  z_ban:textField $\DEVICETOPIC/bridge/config/ban $EVTPART1\
  z_rename:textField $\DEVICETOPIC/bridge/config/rename  {"old":"$EVTPART1","new":"$EVTPART2"}\
  z_reset_CC:noArg $\DEVICETOPIC/bridge/config/reset
attr DEVICE setStateList on off
#set DEVICE attrTemplate do_general_mqtt_cleanup ADD_TO_IO_IGNOREREGEXP=BASE_TOPIC/[A-Za-z0-9._]+/set
attr DEVICE model zigbee2mqtt_bridge
setreading DEVICE attrTemplateVersion 20240628
# Based on https://forum.fhem.de/index.php/topic,94060.msg872371.html#msg872371
vielleicht kann einer der Gurus uns dabei helfen??
Hans Franz
Kein Guru, aber
readingList $DEVICETOPIC/bridge/info:.* { json2nameValue($EVENT) }liefert bei mir ein Reading "version"
Raspi
CUL, Nano-CUL
FHT8V, FHT80B, S300TH
WM1000WZ, ELRO
LW12, LD382,DS18B20
Tueftler1983
Ahh okay bei mir exestiert dieses Readingslist garnicht diese sehen bei mir so aus, und in dem Reading info steht die aktuelle version auch drin:
$DEVICETOPIC/bridge/state:.* state
  $DEVICETOPIC/bridge/config/devices:.* {}
  $DEVICETOPIC/bridge/config/log_level:.* log_level
  $DEVICETOPIC/bridge/config/permit_join:.* permit_join
  $DEVICETOPIC/bridge/config/rename:.* { json2nameValue($EVENT, 'rename_') }
  $DEVICETOPIC/bridge/config:.* { json2nameValue($EVENT) }
  $DEVICETOPIC/bridge/log:.*\"type\".\"devices\".\"message\".* devices
  $DEVICETOPIC/bridge/log:.* log
  $DEVICETOPIC/bridge/logging:.* { json2nameValue($EVENT,'log_') }
  $DEVICETOPIC/bridge/response/networkmap:.* { my $type = $EVENT =~ m/.*,"type":"(raw|graphviz)",.*/ ? $1 : 'networkmap'; $EVENT =~ m/{"data":\{.*"value":"?(.*[^"])"?\},"status":"ok"\}/ ? { $type=>$1 } : {} }
  $DEVICETOPIC/bridge/devices:.* devices
  $DEVICETOPIC/bridge/info:.* info
  $DEVICETOPIC/bridge/groups:.* groups
  $DEVICETOPIC/bridge/event:.* { json2nameValue($EVENT) }
  $DEVICETOPIC/bridge/extensions:.* extensions
zigbee_pi:zigbee2mqtt/bridge/response/device/ota_update/check:.* { json2nameValue($EVENT) }
zigbee_pi:zigbee2mqtt/bridge/response/device/generate_external_definition:.* { json2nameValue($EVENT) }
zimlich am ende von Info:
memory_mb":4050,"node_version":"v24.13.0","version":"#1 SMP PREEMPT Debian 1:6.12.47-1+rpt1~bookworm (2025-09-16) - 6.12.47+rpt-rpi-2712 - arm64"},"permit_join":false,"restart_required":false,"version":"2.7.2","zigbee_herdsman":{"version":"8.0.1"},"zigbee_herdsman_converters":{"version":"25.98.0"}}
aber dank deines readinglist wird nun auch die Version als reading aktualisiert. hast du dies selbst angelegt?? weil ich auch nur das fertige template damals angelegt habe.
LG Holger
DeeSPe
Zitat von: Hans Franz am 26 Januar 2026, 16:16:19readingList $DEVICETOPIC/bridge/info:.* { json2nameValue($EVENT) }liefert bei mir ein Reading "version"
Das hatte ich leider auch schon erfolglos getestet.
Jetzt weiß ich auch warum! Diese Message kommt offensichtlich nur verstümmelt an.
Habe das mal mit dem MQTT Explorer getestet. Das enthaltene JSON ist nicht valide weil ein Teil am Ende fehlt. Nun ist nur die Frage warum?
Hat jemand eine Idee?
Dan
TomLee
#254
Nur am Tablet und nebenbei. Ich kann das nicht nachvollziehen mit der aktuellen Version 2.7.2.
json2namevalue macht bei mir das daraus:
defmod z2m_bridge_test MQTT2_DEVICE zigbee_pi
attr z2m_bridge_test IODev MQTT2_Server
attr z2m_bridge_test readingList zigbee2mqtt/bridge/info:.* { json2nameValue($EVENT) }
attr z2m_bridge_test room MQTT2_DEVICE
setstate z2m_bridge_test 2026-01-26 22:51:19 version 2.7.2
setstate z2m_bridge_test 2026-01-26 22:51:19 zigbee_herdsman_converters_version 25.98.0
setstate z2m_bridge_test 2026-01-26 22:51:19 zigbee_herdsman_version 8.0.1
