httpmod.template: bugs, Fragen, Anregungen
Begonnen von Beta-User, 21 Februar 2019, 12:04:17
Tueftler1983
Zitat von: Beta-User am 03 Dezember 2019, 12:24:52Na ja, viele Fragezeichen sind es nicht mehr...
Wenn "wir" das mit der firmware nicht in denselben HTTPMOD bekommen, würde ich vorschlagen, den Namen um "daemon" zu erweitern, das ganze ergäbe dann:
#Contributed by OdfFHEM, see https://forum.fhem.de/index.php/topic,97694.msg998835.html#msg998835
filter:TYPE=HTTPMOD
desc: Check zigbee2mqtt homepage for new versions of the deamon software.<br>Define a HTTPMOD device like <br>define zigbee2mqtt_updates HTTPMOD https://github.com/Koenkk/zigbee2mqtt/tags 604800<br>
<a href="https://forum.fhem.de/index.php/topic,97694.msg998835.html#msg998835">Source: Forum</a>.
order:X_01f
par:WHICHROOM;Actual room of the device, defaults to HTTPMOD; {AttrVal("DEVICE","room","HTTPMOD" )}
par:INTERVAL;Actual interval for updating, defaults to one day; {InternalVal("DEVICE","Interval",604800)}
par:UPDATABLEDEVICESMODE;Actual mode for updatableDevices, defaults to onlyUpdatable; {AttrVal("DEVICE","updatableDevicesMode","onlyUpdatable")}
defmod DEVICE HTTPMOD https://github.com/Koenkk/zigbee2mqtt/tags INTERVAL
attr DEVICE userattr reading01Name reading01Regex reading02Name reading02OExpr reading02Regex updatableDevicesMode:onlyUpdatable,all
attr DEVICE enableControlSet 1
attr DEVICE event-on-change-reading .*
attr DEVICE event-on-update-reading LAST_ERROR,MATCHED_READINGS
attr DEVICE handleRedirects 0
attr DEVICE reading01Name latestVersion
attr DEVICE reading01Regex commit-title">[\w\W]*?<a href=".*">[\w\W]*?(\d*\.\d*\.\d*)[\w\W]*?</a>
attr DEVICE reading02Name latestDate
attr DEVICE reading02OExpr $val =~ m/^(.{4})-(.{2})-(.{2})$/ ;; "$3.$2.$1"
attr DEVICE reading02Regex relative-time[\w\W]*?datetime="(\d*-\d*-\d*)T\d*:\d*:\d*Z"
attr DEVICE showError 1
attr DEVICE showMatched 1
attr DEVICE stateFormat {   my $ret ="";;\
    my $lastCheck = ReadingsTimestamp($name,"MATCHED_READINGS","???");;\
    $ret .= '<div style="text-align:left">';;\
    $ret .= 'last <a title="versions" href="'.InternalVal($name,"MainURL","unknown").'">ZigBee</a>-check => '.$lastCheck;;\
    $ret .= '<br><br><pre>';;\
    $ret .= "| device                           | current |   new   |  released  |<br>";;\
    $ret .= "---------------------------------------------------------------------<br>";;\
    my $check = ReadingsVal($name,"updatableDevices","error => no or wrong data from server!");;\
    if($check eq "no updates needed!") {\
      $ret .= '| <b style="color:green">';;\
      $ret .= sprintf("%-65s",$check);;\
      $ret .= '</b> |';;\
    } elsif($check eq "error => no or wrong data from server!") {\
      $ret .= '| <b style="color:red">';;\
      $ret .= '</b> |';;\
    } else {\
      my @devices = split(',',$check);;\
      foreach my $devStr (@devices) {\
        my ($dev,$old,$new,$date) = $devStr =~ m/^([^\s]+)\s\(([^\s]+)\s\|\s([^\s]+)\s\|\s([^\)]+)\)$/;;\
        $ret .= '| <a href="/fhem?detail='.$dev.'"><b>';;\
        $ret .= sprintf("%-32s",$dev);;\
        $ret .= '</b></a> | ';;\
        $ret .= '<b style="color:lightgray">';;\
        $ret .= sprintf("%7s",$old);;\
        $ret .= '</b> | ';;\
        $ret .= '<a href="https://github.com/Koenkk/zigbee2mqtt/releases/tag/'.$new.'">';;\
        $ret .= '<b style="color:'.(($new eq $old)?'black':'red').'">';;\
        $ret .= sprintf("%7s",$new);;\
        $ret .= '<b style="color:black">';;\
        $ret .= sprintf("%-10s",$date);;\
        $ret .= '</b></a>';;\
        $ret .= " |<br>";;\
    $ret .= '</pre></div>';;\
  return $ret;;\
attr DEVICE updatableDevicesMode UPDATABLEDEVICESMODE
attr DEVICE timestamp-on-change-reading .*
attr DEVICE userReadings updatableDevices:MATCHED_READINGS.* {\
  my $ret = "";;\
  if (ReadingsVal($name,"MATCHED_READINGS","") eq "") {\
    $ret = "error => no or wrong data from server!";;\
  } else {\
    my $VERSION = ReadingsVal($name,"latestVersion","unknown");;\
    my $DATE = ReadingsVal($name,"latestDate","unknown");;\
    foreach my $dev (devspec2array("TYPE=MQTT[2]?_[D]EVICE:FILTER=permit_join!=")) {\
      my $version = ReadingsVal($dev,"version","0.0.0");;\
      $version =~ m/([0-9.]*).*/;;\
      $version = $1;;\
      if (AttrVal($name,"updatableDevicesMode","onlyUpdatable") eq "all" || $version ne $VERSION) {\
        $ret .= "," if($ret ne "");;\
        $ret .= $dev." (".$version." | ".$VERSION." | ".$DATE.")";;\
  return ($ret eq "")?"no updates needed!":$ret;;\
attr DEVICE webCmd reread
attr DEVICE room WHICHROOM
attr DEVICE model zigbee2mqtt_daemon_updates
In die mqtt2.template-file würde ich dann zu zigbee2mqtt_bridge noch folgendes anfügen?
attr DEVICE comment To check for new updates of the deamon software, you might want to use a separate HTTPMOD device. See HTTPMOD template zigbee2mqtt_daemon_updates for further details.
Leider bekomme ich das Device nicht angelegt, bzw angelegt wird es aber mit einem fehler habe es mit dem Template:
Unknown command <a, try help.
Es wird zwar das Datum des letzten Release angescheigt aber weder die aktuelle installierte Version noch die zuletzt verfügbare.
Tueftler1983
#241
Zitat von: 50watt am 30 Juni 2023, 12:50:22Ich schlage folgende Änderung für das HTTPMOD template "zigbee2mqtt_daemon_updates" vor:
Statt (templateVersion: 20201129)
attr DEVICE reading01Regex commit-title">[\w\W]*?[\w\W]*?(\d*\.\d*\.\d*)[\w\W]*?
das:
attr DEVICE reading01Regex <a href=\"\/Koenkk\/zigbee2mqtt\/releases\/tag\/*?(\d*\.\d*\.\d*)[\w\W]*?</a>
Damit funktioniert (für mich) die Abfrage für die "latestVersion" von zigbee2mqtt wieder.
Dank diesem Post funktioniert zumindest die Anzeige der aktuellsten Verfügbaren Version
Aber die aktuell installierte Version wird immer noch nicht angezeigt bzw steht bei mir auf 0.0.0 in Grau
oelidoc
das:
Leider ist das Template bei mir derzeit funktionslos: es wird weder die aktuelle noch eine neue Version angezeigt und LAST_ERROR read from https://github.com:443 timed out.Gibt es irgendwelche Veränderungen, die mir entgangen sind? Was müsste ich ändern?
oelidoc
satprofi
hallo.
frage zu alignTime, seit uhrzeitumstellung klappt das nicht mehr.
habe 00:03 definiert, aber es startet jetzt immer um 23:03, warum ?
systemzeit etc. passt aber. wie schaffe ich es jetzt wieder um 00:03h zu starten ?
HMLAN, HM-CC-RT-DN,Homematic Actoren,LD382A,Telegram
amenomade
Zitat von: satprofi am 01 November 2025, 09:49:07systemzeit etc. passt aber. wie schaffe ich es jetzt wieder um 00:03h zu starten ?
Was sagt
{localtime()} ?
