Modul für Yamaha Musiccast
Begonnen von Leugi, 10 März 2019, 16:07:57
Invers
Danke, ich denke, es hat sich erledigt.
Hab es mit dem Befehl
{system("curl http://192.168.178.68/YamahaExtendedControl/v1/main/recallScene?num=4")}
und einem DOIF erledigt.
Invers
Ich erhalte Meldungen im Logfile beim Einschalten.
[pre]2024.07.21 08:10:40.083 1: stacktrace:
2024.07.21 08:10:40.084 1:     main::__ANON__                      called by ./FHEM/71_YAMAHA_MC.pm (2721)
2024.07.21 08:10:40.085 1:     main::YAMAHA_MC_httpRequestQueue    called by ./FHEM/71_YAMAHA_MC.pm (789)
2024.07.21 08:10:40.086 1:     main::YAMAHA_MC_getInputs           called by ./FHEM/71_YAMAHA_MC.pm (686)
2024.07.21 08:10:40.086 1:     main::YAMAHA_MC_GetStatus           called by fhem.pl (3508)
2024.07.21 08:10:40.087 1:     main::HandleTimeout                 called by fhem.pl (707)
2024.07.21 08:10:40.088 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/71_YAMAHA_MC.pm line 2721.
2024.07.21 08:10:40.088 1: stacktrace:
2024.07.21 08:10:40.089 1:     main::__ANON__                      called by ./FHEM/71_YAMAHA_MC.pm (2721)
2024.07.21 08:10:40.090 1:     main::YAMAHA_MC_httpRequestQueue    called by ./FHEM/71_YAMAHA_MC.pm (789)
2024.07.21 08:10:40.090 1:     main::YAMAHA_MC_getInputs           called by ./FHEM/71_YAMAHA_MC.pm (686)
2024.07.21 08:10:40.091 1:     main::YAMAHA_MC_GetStatus           called by fhem.pl (3508)
2024.07.21 08:10:40.092 1:     main::HandleTimeout                 called by fhem.pl (707)
2024.07.21 08:10:40.094 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/71_YAMAHA_MC.pm line 2721.
2024.07.21 08:10:40.095 1: stacktrace:
2024.07.21 08:10:40.096 1:     main::__ANON__                      called by ./FHEM/71_YAMAHA_MC.pm (2721)
2024.07.21 08:10:40.097 1:     main::YAMAHA_MC_httpRequestQueue    called by ./FHEM/71_YAMAHA_MC.pm (816)
2024.07.21 08:10:40.097 1:     main::YAMAHA_MC_getMenu             called by ./FHEM/71_YAMAHA_MC.pm (692)
2024.07.21 08:10:40.098 1:     main::YAMAHA_MC_GetStatus           called by fhem.pl (3508)
2024.07.21 08:10:40.099 1:     main::HandleTimeout                 called by fhem.pl (707)
2024.07.21 08:10:40.099 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/71_YAMAHA_MC.pm line 2721.
2024.07.21 08:10:40.100 1: stacktrace:
2024.07.21 08:10:40.101 1:     main::__ANON__                      called by ./FHEM/71_YAMAHA_MC.pm (2721)
2024.07.21 08:10:40.101 1:     main::YAMAHA_MC_httpRequestQueue    called by ./FHEM/71_YAMAHA_MC.pm (816)
2024.07.21 08:10:40.102 1:     main::YAMAHA_MC_getMenu             called by ./FHEM/71_YAMAHA_MC.pm (692)
2024.07.21 08:10:40.103 1:     main::YAMAHA_MC_GetStatus           called by fhem.pl (3508)
2024.07.21 08:10:40.103 1:     main::HandleTimeout                 called by fhem.pl (707)
2024.07.21 08:10:40.106 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/71_YAMAHA_MC.pm line 2721.
2024.07.21 08:10:40.107 1: stacktrace:
2024.07.21 08:10:40.108 1:     main::__ANON__                      called by ./FHEM/71_YAMAHA_MC.pm (2721)
2024.07.21 08:10:40.108 1:     main::YAMAHA_MC_httpRequestQueue    called by ./FHEM/71_YAMAHA_MC.pm (843)
2024.07.21 08:10:40.109 1:     main::YAMAHA_MC_getPlaybackStatus   called by ./FHEM/71_YAMAHA_MC.pm (696)
2024.07.21 08:10:40.110 1:     main::YAMAHA_MC_GetStatus           called by fhem.pl (3508)
2024.07.21 08:10:40.110 1:     main::HandleTimeout                 called by fhem.pl (707)
2024.07.21 08:10:40.111 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/71_YAMAHA_MC.pm line 2721.
2024.07.21 08:10:40.112 1: stacktrace:
2024.07.21 08:10:40.112 1:     main::__ANON__                      called by ./FHEM/71_YAMAHA_MC.pm (2721)
2024.07.21 08:10:40.113 1:     main::YAMAHA_MC_httpRequestQueue    called by ./FHEM/71_YAMAHA_MC.pm (843)
2024.07.21 08:10:40.114 1:     main::YAMAHA_MC_getPlaybackStatus   called by ./FHEM/71_YAMAHA_MC.pm (696)
2024.07.21 08:10:40.114 1:     main::YAMAHA_MC_GetStatus           called by fhem.pl (3508)
2024.07.21 08:10:40.115 1:     main::HandleTimeout                 called by fhem.pl (707)
2024.07.21 08:10:40.123 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/71_YAMAHA_MC.pm line 2721.
2024.07.21 08:10:40.124 1: stacktrace:
2024.07.21 08:10:40.125 1:     main::__ANON__                      called by ./FHEM/71_YAMAHA_MC.pm (2721)
2024.07.21 08:10:40.125 1:     main::YAMAHA_MC_httpRequestQueue    called by ./FHEM/71_YAMAHA_MC.pm (937)
2024.07.21 08:10:40.126 1:     main::YAMAHA_MC_getDistributionInfo called by ./FHEM/71_YAMAHA_MC.pm (703)
2024.07.21 08:10:40.127 1:     main::YAMAHA_MC_GetStatus           called by fhem.pl (3508)
2024.07.21 08:10:40.127 1:     main::HandleTimeout                 called by fhem.pl (707)
2024.07.21 08:10:40.128 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/71_YAMAHA_MC.pm line 2721.
2024.07.21 08:10:40.129 1: stacktrace:
2024.07.21 08:10:40.129 1:     main::__ANON__                      called by ./FHEM/71_YAMAHA_MC.pm (2721)
2024.07.21 08:10:40.130 1:     main::YAMAHA_MC_httpRequestQueue    called by ./FHEM/71_YAMAHA_MC.pm (937)
2024.07.21 08:10:40.131 1:     main::YAMAHA_MC_getDistributionInfo called by ./FHEM/71_YAMAHA_MC.pm (703)
2024.07.21 08:10:40.131 1:     main::YAMAHA_MC_GetStatus           called by fhem.pl (3508)
2024.07.21 08:10:40.132 1:     main::HandleTimeout                 called by fhem.pl (707)
2024.07.21 08:10:40.135 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/71_YAMAHA_MC.pm line 2721.
2024.07.21 08:10:40.136 1: stacktrace:
2024.07.21 08:10:40.136 1:     main::__ANON__                      called by ./FHEM/71_YAMAHA_MC.pm (2721)
2024.07.21 08:10:40.137 1:     main::YAMAHA_MC_httpRequestQueue    called by ./FHEM/71_YAMAHA_MC.pm (707)
2024.07.21 08:10:40.138 1:     main::YAMAHA_MC_GetStatus           called by fhem.pl (3508)
2024.07.21 08:10:40.138 1:     main::HandleTimeout                 called by fhem.pl (707)
2024.07.21 08:10:40.139 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/71_YAMAHA_MC.pm line 2721.
2024.07.21 08:10:40.140 1: stacktrace:
2024.07.21 08:10:40.140 1:     main::__ANON__                      called by ./FHEM/71_YAMAHA_MC.pm (2721)
2024.07.21 08:10:40.141 1:     main::YAMAHA_MC_httpRequestQueue    called by ./FHEM/71_YAMAHA_MC.pm (707)
2024.07.21 08:10:40.142 1:     main::YAMAHA_MC_GetStatus           called by fhem.pl (3508)
2024.07.21 08:10:40.142 1:     main::HandleTimeout                 called by fhem.pl (707)[/pre]
Wie kann ich das vermeiden?
Danke im Voraus für Antwort und Hilfe.
Wolfgang Lachmann
Hallo Leugi,
ich betreibe einen Yamaha RX-V4A Receiver über das device YAMAHA_MC und alternativ über die Fernbedienung. Meinen ganzen Audiovisions-Kram, also auch dieser Receiver, schalte ich bei Nichtbenutzung spannungsfrei, also auch kein stand-by mehr. Mit einer FHEM notify Ablaufkette wird aus "Netzspannung aus" heraus der Receiver hochgefahren zum gewünschten Betriebsmodus. Das funktioniert gut, solange man den Receiver vor Abschaltung der Netzspannung mit z.B. "set off" ausgeschaltet hat. Wird die Netzspannung gekappt und das device ist noch "on", erfolgt bei Rückkehr der Netzspannung keine Synchronisierung zwischen Reveiver und FHEM device mehr. Der Receiver hat sich seinen letzten Zustand "on" gemerkt und macht weiter, als ob nichts gewesen wäre. Anders jedoch das FHEM device: Jede periodische Abfrage liefert nur diese events:
2024-09-06 17:26:59 YAMAHA_MC RCV last_error: Initializing in progress
2024-09-06 17:26:59 YAMAHA_MC RCV response_code: 1
Genauso reagiert das device auf "set on" oder "set off". Kurzum, ich kriegs nur wieder synchron, wenn ich den Receiver mit der Fernbedienung ausschalte, dann die Netzspannung aus- und wieder einschalte.
Hast Du eine Idee, wie aus FHEM heraus (ohne Eingriff am Receiver) diese Situation aufgelöst werden kann?
Gruß Wolfgang
RPi4, Maple-Cul, EnOcean, Homebridge, ca. 30 Shellys, div. Frontends mit ESP8266
rs
Männer,
habt Ihr einen Link für mich, wie ich eine mp3 aus dem fhem auf dem Yamaha_mc abspielen kann.
Leider haben die Leute von Amazon das Echo umgestellt, so dass der speak darauf nicht mehr geht.
Darum will ich meine Sprachausgaben via vorher erstelltem mp3 an die YAS360 senden.
Gruss&Dank
RS
rpi3+ & RaspBee | Phillips, Osram, IKEA, SIlvercrest Devices | FHEM 6.3 | Echo Show 15 | Yamaha YAS| LG TV | Ubuntu 24.10 - NextCloud 30 - OpemVPN - Wordpress - NAS - ...
sprudelverduenner
#154
Zitat von: sprudelverduenner am 19 November 2022, 20:31:21
Zitat von: Leugi am 16 Januar 2021, 18:47:56Ich habe nun toggleShuffle und die Readings für Repeat und Shuffle implementiert.
Hallo Leugi,
für mich hätte es einen großen Nutzen, wenn ich den Shuffle explizit mit einem Befehl an oder aus und nicht nur toggeln könnte.
Wäre es möglich das zu implementieren?
Über das Webinterface meines MusicCast Gerätes kann ich den Shuffle auch direkt schalten...
Beste Grüße,
Sprudelverduenner
Hallo Leugi,
nachdem ich nun - durch die Yamaha-Holtine bestätigt - feststellen muss, dass Yamaha die Alexa Integration/Skills abgeschaltet hat ist mein Wunsch nach einem dezidiertem Einschalten bzw. Ausschalten des Random-Mode grösser denn je.
Bisher habe ich das über den Alexa-Skill  in Verbindung mit dem Echo-Modul lösen können.
Genau so hatte ich bisher das Abspielen einer Playlist gestartet.
Du wärst einer meiner großen Helden, wenn Du Random-Mode und Abspielen einer Playlist in das MusicCast-Modul integrieren könntest.
Beste Grüße,
Sprudelverduenner
FHEM @ RaspberryPi 3, HMLAN, HMUART + HMRS485, Homematic, ESPEasy @ Sonoff / Shelly / ESP8266, ZigBee @ CC2531
Echo Dot, Dreambox, Yamaha MusicCast, Logitech Hub, LW-12, LD382
FRITZ!Box 7590 AX, Mesh @ FRITZ!Repeater 6000, FRITZ!Fon, iPhone 16 pro, iPad Air 5, AppleWatch 8
sprudelverduenner
#155
@Leugi
ich habe zwischenzeitlich für meinen Wunsch die HTTP-Befehle herausfinden können.
Playlisten abspielen:
http://[YamahaIP]/YamahaExtendedControl/v1/netusb/manageMcPlaylist?bank=1&type=play&index=0Wobei Bank der der Playlistennummer entspricht [beginnend mit 1] und Index dem Titel der Abgespielt werden soll [beginnend mit 0 entspricht dann dem 1. Titel]
Diskretes Einschalten des Shuffle:
http://[YamahaIP]/YamahaExtendedControl/v1/netusb/setShuffle?mode=on
Diskretes Ausschalten des Shuffle:
http://[YamahaIP]/YamahaExtendedControl/v1/netusb/setShuffle?mode=off
Alternativ könnte ich mir auch helfen indem ich diese Befehle hardcoded mit CURL sende.
Besten Dank vorab.
LG, Sprudelverduenner
EDIT: PS: Alle 3 Befehle sind auch verifiziert und funktionieren bei mir.
