Global verbose 5
2020.06.15 15:07:51.981 5: POST /fhem HTTP/1.1
Host: t-fhem01.tuxnet.lan:8083
Connection: keep-alive
Content-Length: 75
Cache-Control: max-age=0
Origin: http://t-fhem01.tuxnet.lan:8083
Upgrade-Insecure-Requests: 1
DNT: 1
Content-Type: application/x-www-form-urlencoded
User-Agent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/80.0.3987.162 Safari/537.36
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9
Referer: http://t-fhem01.tuxnet.lan:8083/fhem?room=System&fw_id=245
Accept-Encoding: gzip, deflate
Accept-Language: de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7
2020.06.15 15:07:51.982 4: WEB_10.6.9.3_45726 POST /fhem&fw_id=245&room=System&fwcsrf=csrf_613174510879661&cmd=%7B+markoNC%28%29+%7D; BUFLEN:0
2020.06.15 15:07:51.982 5: Cmd: >{ markoNC() }<
2020.06.15 15:07:51.982 5: HttpUtils url=https://cloud.cooltux.net/remote.php/dav/files/marko/FHEM-Backup/FHEM-20200609_Marko_140250.tar.gz
2020.06.15 15:07:51.983 4: IP: cloud.cooltux.net -> 192.168.240.241
2020.06.15 15:07:51.995 5: HttpUtils request header:
PUT /remote.php/dav/files/marko/FHEM-Backup/FHEM-20200609_Marko_140250.tar.gz HTTP/1.0
Host: cloud.cooltux.net
User-Agent: fhem
Accept-Encoding: gzip,deflate
Authorization: Basic bWFya286YXh4VG0tcE1TZ1ItR2tlM04ta3E5YkMtSmZUUzM=
Content-Length: 44
2020.06.15 15:07:52.008 5: GET /fhem?room=System&fw_id=245 HTTP/1.1
DNT: 1
2020.06.15 15:07:52.008 4: WEB_10.6.9.3_45726 GET /fhem?room=System&fw_id=245; BUFLEN:0
2020.06.15 15:07:52.063 4: WEB: /fhem?room=System&fw_id=245 / RL:5840 / text/html; charset=UTF-8 / Content-Encoding: gzip
/ Cache-Control: no-cache, no-store, must-revalidate
2020.06.15 15:07:52.082 5: GET /fhem/pgm2/jquery.min.js HTTP/1.1
DNT: 1
If-None-Match: "1550933951"
Accept: */*
2020.06.15 15:07:52.082 4: WEB_10.6.9.3_45726 GET /fhem/pgm2/jquery.min.js; BUFLEN:0
2020.06.15 15:07:52.082 4: WEB_10.6.9.3_45726 => 304 Not Modified
2020.06.15 15:07:52.083 5: GET /fhem/pgm2/doif.js HTTP/1.1
DNT: 1
Accept: */*
2020.06.15 15:07:52.083 4: WEB_10.6.9.3_45732 GET /fhem/pgm2/doif.js; BUFLEN:0
2020.06.15 15:07:52.083 4: WEB_10.6.9.3_45732 => 304 Not Modified
2020.06.15 15:07:52.083 5: GET /fhem/codemirror/fhem_codemirror.js HTTP/1.1
DNT: 1
Accept: */*
2020.06.15 15:07:52.083 4: WEB_10.6.9.3_45736 GET /fhem/codemirror/fhem_codemirror.js; BUFLEN:0
2020.06.15 15:07:52.084 4: WEB_10.6.9.3_45736 => 304 Not Modified
2020.06.15 15:07:52.084 5: GET /fhem/pgm2/fhemweb.js HTTP/1.1
DNT: 1
If-None-Match: "1591181989"
Accept: */*
2020.06.15 15:07:52.084 4: WEB_10.6.9.3_45734 GET /fhem/pgm2/fhemweb.js; BUFLEN:0
2020.06.15 15:07:52.084 4: WEB_10.6.9.3_45734 => 304 Not Modified
2020.06.15 15:07:52.084 5: GET /fhem/pgm2/jquery-ui.min.js HTTP/1.1
DNT: 1
Accept: */*
2020.06.15 15:07:52.084 4: WEB_10.6.9.3_45730 GET /fhem/pgm2/jquery-ui.min.js; BUFLEN:0
2020.06.15 15:07:52.084 4: WEB_10.6.9.3_45730 => 304 Not Modified
2020.06.15 15:07:52.085 5: GET /fhem/images/default/icoEverything.png HTTP/1.1
DNT: 1
If-None-Match: "1550933953"
Accept: image/webp,image/apng,image/*,*/*;q=0.8
2020.06.15 15:07:52.085 4: WEB_10.6.9.3_45728 GET /fhem/images/default/icoEverything.png; BUFLEN:0
2020.06.15 15:07:52.085 4: WEB_10.6.9.3_45728 => 304 Not Modified
2020.06.15 15:07:52.089 5: GET /fhem/pgm2/darkCommon.css HTTP/1.1
DNT: 1
If-None-Match: "1580714083"
Accept: text/css,*/*;q=0.1
2020.06.15 15:07:52.089 4: WEB_10.6.9.3_45732 GET /fhem/pgm2/darkCommon.css; BUFLEN:0
2020.06.15 15:07:52.089 4: WEB_10.6.9.3_45732 => 304 Not Modified
2020.06.15 15:07:52.098 5: GET /fhem/pgm2/dashboard_darkstyle.css HTTP/1.1
DNT: 1
2020.06.15 15:07:52.098 4: WEB_10.6.9.3_45732 GET /fhem/pgm2/dashboard_darkstyle.css; BUFLEN:0
2020.06.15 15:07:52.098 4: WEB_10.6.9.3_45732 => 304 Not Modified
2020.06.15 15:07:52.121 4: https://cloud.cooltux.net/remote.php/dav/files/marko/FHEM-Backup/FHEM-20200609_Marko_140250.tar.gz: HTTP response code 204
2020.06.15 15:07:52.121 5: HttpUtils https://cloud.cooltux.net/remote.php/dav/files/marko/FHEM-Backup/FHEM-20200609_Marko_140250.tar.gz: Got data, length: 0
2020.06.15 15:07:52.122 5: HttpUtils response header:
HTTP/1.0 204 No Content
date: Mon, 15 Jun 2020 13:07:51 GMT
server: Apache
referrer-policy: no-referrer
x-content-type-options: nosniff
x-download-options: noopen
x-frame-options: SAMEORIGIN
x-permitted-cross-domain-policies: none
x-robots-tag: none
x-xss-protection: 1; mode=block
set-cookie: 0d6b13b01c9d6=6pb3f16g4c4pv8b1hdbaqlnvu0; path=/; secure; HttpOnly
expires: Thu, 19 Nov 1981 08:52:00 GMT
cache-control: no-store, no-cache, must-revalidate
pragma: no-cache
set-cookie: oc_sessionPassphrase=meXPTxLhTf1RtF2m5np0J%2FLI6OR8WmJr4y%2F8yULvTlKkHAfucNRqGSST%2BGncAOhvWpjNhNgSsDA%2Fw4Efp7knocDU%2BZRlbegy3c7TisgAXLLoBhy4kfcVoTsw34oT9XKo; path=/; secure; HttpOnly
content-security-policy: default-src 'none';
set-cookie: __Host-nc_sameSiteCookielax=true; path=/; httponly;secure; expires=Fri, 31-Dec-2100 23:59:59 GMT; SameSite=lax
set-cookie: __Host-nc_sameSiteCookiestrict=true; path=/; httponly;secure; expires=Fri, 31-Dec-2100 23:59:59 GMT; SameSite=strict
set-cookie: 0d6b13b01c9d6=2hlqnlj041t2bhsvfqddpipfsq; path=/; secure; HttpOnly
oc-fileid: 001301900d6b13b01c9d6
etag: "6db89b0d683b897049c315be1782d946"
oc-etag: "6db89b0d683b897049c315be1782d946"
strict-transport-security: max-age=15768000; preload
NC - Error:
NC - Data:
2020.06.15 15:07:52.131 5: GET /fhem/images/default/fhemicon_dark.png HTTP/1.1
DNT: 1
Referer: http://t-fhem01.tuxnet.lan:8083/fhem/pgm2/style.css?v=1592183815
2020.06.15 15:07:52.131 4: WEB_10.6.9.3_45732 GET /fhem/images/default/fhemicon_dark.png; BUFLEN:0
2020.06.15 15:07:52.131 4: WEB_10.6.9.3_45732 => 304 Not Modified
2020.06.15 15:07:52.242 4: Connection accepted from WEB_10.6.9.3_45750
2020.06.15 15:07:52.243 5: GET /fhem?XHR=1&inform=type=status;filter=room=System;since=1592226471;fmt=JSON&fw_id=245×tamp=1592226472230 HTTP/1.1
Connection: Upgrade
Pragma: no-cache
Upgrade: websocket
Sec-WebSocket-Version: 13
Sec-WebSocket-Key: 5mFwOSDxdThf9n8lVGwJ6w==
Sec-WebSocket-Extensions: permessage-deflate; client_max_window_bits
