Autor Thema: Neues Modul readingsChange  (Gelesen 2518 mal)
Offline rudolfkoenig
  • Administrator
« am: 05 November 2016, 16:12:54 »
Das ist ein Hilfsmodul, um existierende Readings umformatieren zu koennen. Der Commandref Eintrag:
Define
  • define <name> readingsChange <device> <readingName> <toReplace> <replaceWith>"
     Change the content of a reading if it changes, with the perl string substitute mechanism. Note: As some modules rely on the known format of some readings, changing such readings may cause these modules to stop working.
     <device>, <readingName> and <toReplace> are regular expressions, and are not allowed to contain whitespace. If replaceWith is enclosed in {}, then the content will be executed as a perl expression for each match.
     Examples:
    • # shorten the reading power 0.5 W previous: 0 delta_time: 300
       # to just power 0.5 W
       define pShort readingsChange pm power (.*W).* $1
       # format each decimal number in the power reading to 2 decimal places
       define p2dec readingsChange pm power (\d+\.\d+) {sprintf("%02.f", $1)}
Set
  • N/A
Get
  • N/A
Attributes
  • disable
  • disabledForIntervals
Gefällt mir Gefällt mir x 6 Liste anzeigen
Online DeeSPe
  • Wer anderen eine Bratwurst brät...
Antw:Neues Modul readingsChange
« Antwort #1 am: 10 Januar 2017, 20:02:06 »
Entweder funktioniert es nicht wie gedacht oder ich komme damit nicht klar!
Habe fast 1:1 übernommen aber das Reading bleibt das Gleiche.
   CFGFN
   DEF        ku_SD6 power (.*W).* $1
   NAME       pShort
   NOTIFYDEV  ku_SD6
   NR         1134
   NTFY_ORDER 00-pShort
   STATE      active
   TYPE       readingsChange
   Readings:
     2017-01-10 19:53:17   state           active
   Readings:
     2016-10-29 19:40:08   SEND_DATA       failed:00
     2016-10-29 19:40:05   assocGroup_1    Max 5 Nodes ZWaveBridge
     2016-10-29 19:40:07   assocGroup_2    Max 5 Nodes
     2016-10-29 19:40:08   assocGroup_3    Max 5 Nodes
     2016-10-29 19:40:05   assocGroups     3
     2016-10-29 19:39:57   configButtonOnOff Enable
     2016-10-29 19:39:58   configConfigureMaximumOverLoadCurrent 150
     2016-10-29 19:39:58   configConfigurePlugTimeSwitchFunction Disable
     2016-10-29 19:39:59   configLedDisplay Enable
     2016-10-29 19:39:59   configMeterReportInterval 300
     2016-10-29 19:39:59   configRememberRelayONOFFStatus Enable
     2016-10-29 19:40:00   configSendMeterReport Enable
     2017-01-10 20:00:21   current          0.1 A previous: 0.09 delta_time: 31 s
     2017-01-10 20:00:18   energy           1.36 kWh previous: 1.36 delta_time: 31 s
     2016-10-29 19:31:20   model           Neo CoolCam Power plug 12A
     2016-10-29 19:31:20   modelConfig     shenzen_neo/nas-wr01z.xml
     2016-10-29 19:31:20   modelId         0258-0003-1087
     2017-01-10 20:00:19   power            14.99 W previous: 13.55 delta_time: 31 s
     2017-01-01 14:51:50   state           on
     2017-01-01 14:36:07   timeToAck       3.898
     2017-01-01 14:36:07   transmit        OK
     2017-01-10 20:00:20   voltage          246.35 V previous: 246.36 delta_time: 31 s
Kann bei <device> devspec angegeben werden oder tatsächlich nur der Device Name?
Wollte das für energy, current und voltage auch umsetzen, funktioniert leider auch nicht.
Danke.
Dan
FHEM 5.8, Brix, VIVO mini, RPi3, Debian Jessie, ZME_UZB1
HM-CFG-LAN, HM-MOD-UART-WIFI, HUE, HarmonyHub, JeeLink, CO20
Hyperion auf RPi Zero W, Sonos, viel Z-Wave und HM
alles per HomeKit steuerbar
MAINTAINER: 22_HOMEMODE, 98_Hyperion, 98_FileLogConvert
