Autor Thema: Neues Modul readingsChange  (Gelesen 4876 mal)
Offline rudolfkoenig
  • Administrator
« am: 05 November 2016, 16:12:54 »
Das ist ein Hilfsmodul, um existierende Readings umformatieren zu koennen. Der Commandref Eintrag:
Define
  • define <name> readingsChange <device> <readingName> <toReplace> <replaceWith>"
     Change the content of a reading if it changes, with the perl string substitute mechanism. Note: As some modules rely on the known format of some readings, changing such readings may cause these modules to stop working.
     <device>, <readingName> and <toReplace> are regular expressions, and are not allowed to contain whitespace. If replaceWith is enclosed in {}, then the content will be executed as a perl expression for each match.
     Examples:
    • # shorten the reading power 0.5 W previous: 0 delta_time: 300
       # to just power 0.5 W
       define pShort readingsChange pm power (.*W).* $1
       # format each decimal number in the power reading to 2 decimal places
       define p2dec readingsChange pm power (\d+\.\d+) {sprintf("%02.f", $1)}
Set
  • N/A
Get
  • N/A
Attributes
  • disable
  • disabledForIntervals
Gefällt mir Gefällt mir x 6 Liste anzeigen
Offline DeeSPe
  • Wer anderen eine Bratwurst brät...
    • Buy me a coffee
Antw:Neues Modul readingsChange
« Antwort #1 am: 10 Januar 2017, 20:02:06 »
Entweder funktioniert es nicht wie gedacht oder ich komme damit nicht klar!
Habe fast 1:1 übernommen aber das Reading bleibt das Gleiche.
   CFGFN
   DEF        ku_SD6 power (.*W).* $1
   NAME       pShort
   NOTIFYDEV  ku_SD6
   NR         1134
   NTFY_ORDER 00-pShort
   STATE      active
   TYPE       readingsChange
   Readings:
     2017-01-10 19:53:17   state           active
   Readings:
     2016-10-29 19:40:08   SEND_DATA       failed:00
     2016-10-29 19:40:05   assocGroup_1    Max 5 Nodes ZWaveBridge
     2016-10-29 19:40:07   assocGroup_2    Max 5 Nodes
     2016-10-29 19:40:08   assocGroup_3    Max 5 Nodes
     2016-10-29 19:40:05   assocGroups     3
     2016-10-29 19:39:57   configButtonOnOff Enable
     2016-10-29 19:39:58   configConfigureMaximumOverLoadCurrent 150
     2016-10-29 19:39:58   configConfigurePlugTimeSwitchFunction Disable
     2016-10-29 19:39:59   configLedDisplay Enable
     2016-10-29 19:39:59   configMeterReportInterval 300
     2016-10-29 19:39:59   configRememberRelayONOFFStatus Enable
     2016-10-29 19:40:00   configSendMeterReport Enable
     2017-01-10 20:00:21   current          0.1 A previous: 0.09 delta_time: 31 s
     2017-01-10 20:00:18   energy           1.36 kWh previous: 1.36 delta_time: 31 s
     2016-10-29 19:31:20   model           Neo CoolCam Power plug 12A
     2016-10-29 19:31:20   modelConfig     shenzen_neo/nas-wr01z.xml
     2016-10-29 19:31:20   modelId         0258-0003-1087
     2017-01-10 20:00:19   power            14.99 W previous: 13.55 delta_time: 31 s
     2017-01-01 14:51:50   state           on
     2017-01-01 14:36:07   timeToAck       3.898
     2017-01-01 14:36:07   transmit        OK
     2017-01-10 20:00:20   voltage          246.35 V previous: 246.36 delta_time: 31 s
Kann bei <device> devspec angegeben werden oder tatsächlich nur der Device Name?
Wollte das für energy, current und voltage auch umsetzen, funktioniert leider auch nicht.
Danke.
Dan
