[gelöst] ASC, Weatherman und ">WM_Log:licht< has no TYPE, but following keys:><"
Begonnen von caldir65, 05 Juni 2021, 13:01:45
caldir65
ich habe hier eine Wetterstation Weatherman laufen (Einbindung nach dieser Unterhaltung), von der ich auch fleißig Daten geliefert bekomme...
   CONNECTS   4449
   FD         49
   FUUID      5f0092c0-f33f-378b-5c61-7f99da4f64318d46
   FVERSION   93_Log2Syslog.pm:v5.12.4-s23875/2021-03-01
   INTERFACE  global
   MODEL      Collector v5.12.4
   MYFQDN     raspi-fhem.fritz.box
   MYHOST     raspi-fhem
   NAME       WM_Log
   NR         1482
   NTFY_ORDER 50-WM_Log
   PORT       19721
   PROFILE    raw
   PROTOCOL   tcp
   SEQNO      4449
   STATE      active
   TYPE       Log2Syslog
   stacktrace  TcpServer_Close:1357 FHEM::Log2Syslog::downServer:1430 FHEM::Log2Syslog::Set:3888 CallFn:1939 DoSet:1971 CommandSet:1266 AnalyzeCommand:2773 FW_fC:1006 FW_answerCall:598 FW_Read:3893 CallFn:774
   HELPER:
     LTIME      1622889710
     OLDSEQNO   4449
     OLDSTATE   active
     PACKAGE    FHEM::Log2Syslog
     TCPPADDR   192.168.1.71
     VERSION    5.12.4
   HIPCACHE:
     192.168.1.71 Wetherman.fritz.box
   Helper:
     DBLOG:
       helligkeit:
         DBLogging:
           TIME       1622886377.48582
           VALUE       3838
   OLDREADINGS:
     2021-06-05 12:41:23   MSG_Wetherman.fritz.box {"modultyp":"weatherman","vars":[{"name":"0","homematic_name":"w_ip","desc":"weatherman_ip","type":"string","unit":"","value":"192.168.1.71"},{"name":"1","homematic_name":"w_temperatur","desc":"aussentemperatur","type":"number","unit":"gradC","value":"23.3"},{"name":"21","homematic_name":"w_windchill","desc":"gefuehlte_temperatur","type":"number","unit":"gradC","value":"23.3"},{"name":"9","homematic_name":"w_taupunkt","desc":"taupunkt_temperatur","type":"number","unit":"gradC","value":"16.1"},{"name":"14","homematic_name":"w_himmeltemperatur","desc":"himmel_temperatur","type":"number","unit":"gradC","value":"0.0"},{"name":"2","homematic_name":"w_feuchte_rel","desc":"rel_feuchte","type":"number","unit":"%","value":"64.0"},{"name":"17","homematic_name":"w_feuchte_abs","desc":"abs_feuchte","type":"number","unit":"g/m3","value":"13.3"},{"name":"18","homematic_name":"w_regensensor_wert","desc":"regenmelderwert","type":"number","unit":"","value":"0"},{"name":"7","homematic_name":"w_regenmelder","desc":"regenstatus","type":"boolean","unit":"","value":"false"},{"name":"19","homematic_name":"w_regen_letzte_h","desc":"regen_pro_h","type":"number","unit":"mm","value":"0.0"},{"name":"20","homematic_name":"w_regen_mm_heute","desc":"regen_mm_heute","type":"number","unit":"mm","value":"0.0"},{"name":"29","homematic_name":"w_regen_stunden_heute","desc":"regenstunden_heute","type":"number","unit":"h","value":"1.6"},{"name":"27","homematic_name":"w_regen_mm_gestern","desc":"regen_mm_gestern","type":"number","unit":"mm","value":"0.7"},{"name":"3","homematic_name":"w_barometer","desc":"nn_luftdruck","type":"number","unit":"mb","value":"1032.57"},{"name":"11","homematic_name":"w_barotrend","desc":"luftdrucktrend","type":"string","unit":"","value":"stabil"},{"name":"5","homematic_name":"w_wind_1min","desc":"windgeschwindigkeit_1min","type":"number","unit":"km/h","value":"19.0"},{"name":"4","homematic_name":"w_wind_10min","desc":"windgeschwindigkeit_10min","type":"number","unit":"km/h","value":"14.4"},{"name":"24","homematic_name":"w_windstaerke","desc":"bft_windgeschwindigkeit","type":"number","unit":"bft","value":"3"},{"name":"23","homematic_name":"w_windrichtung","desc":"windrichtung","type":"string","unit":"","value":"WEST"},{"name":"6","homematic_name":"w_wind_dir","desc":"windwinkel","type":"number","unit":"grad","value":"261"},{"name":"10","homematic_name":"w_lux","desc":"helligkeit","type":"number","unit":"lux","value":"8359"},{"name":"28","homematic_name":"w_uv_index","desc":"uv-index","type":"number","unit":"uv_index","value":"2"},{"name":"16","homematic_name":"w_sonne_scheint","desc":"sonne_scheint","type":"boolean","unit":"","value":"true"},{"name":"26","homematic_name":"w_sonnenstunden_heute","desc":"Sonnenstunden_heute","type":"number","unit":"h","value":"6.4"},{"name":"12","homematic_name":"w_elevation","desc":"sonne_elevation","type":"number","unit":"grad","value":"60.1"},{"name":"13","homematic_name":"w_azimut","desc":"sonne_azimut","type":"number","unit":"grad","value":"157.3"},{"name":"30","homematic_name":"w_minuten_vor_sa","desc":"minuten_vor_sa","type":"number","unit":"min","value":"-438"},{"name":"31","homematic_name":"w_minuten_vor_su","desc":"minuten_vor_su","type":"number","unit":"min","value":"536"}],"Systeminfo":{"MAC-Adresse":"bc:dd:c2:b6:22:75","Homematic_CCU_ip":"192.168.1.144","WLAN_ssid":"Fritz-IoT","WLAN_Signal_dBm":"-77","sec_seit_reset":"175333","zeitpunkt":"2021.06.05 /12h41","firmware":"edition2_153"}}
     2021-06-03 12:06:23   Parse_Err_LastData n.a.
     2021-06-03 12:08:18   Parse_Err_No    0
     2021-06-03 10:11:36   SSL_Algorithm   n.a.
     2021-06-03 10:11:36   SSL_Version     n.a.
     2021-06-05 12:41:50   Sonnenstunden_heute 6.4
     2021-06-05 12:41:50   Transfered_logs_per_minute 1
     2021-06-05 12:41:50   abs_feuchte     13.3
     2021-06-05 12:41:50   aussentemperatur 23.3
     2021-06-05 12:41:50   avg_windgeschwindigkeit 14.4
     2021-06-05 12:41:50   bft_windgeschwindigkeit 3
     2021-06-05 12:41:50   gefuehlte_temperatur 23.3
     2021-06-05 12:41:50   licht           8359
     2021-06-05 12:41:50   luftdrucktrend  stabil
     2021-06-05 12:41:50   minuten_vor_sa  0
     2021-06-05 12:41:50   minuten_vor_su  536
     2021-06-05 12:41:50   nn_luftdruck    1032.57
     2021-06-05 12:41:50   peak_windgeschwindigkeit 19.0
     2021-06-05 12:41:50   regen_mm_gestern 0.7
     2021-06-05 12:41:50   regen_mm_heute  0.0
     2021-06-05 12:41:50   regen_pro_h     0.0
     2021-06-05 12:41:50   regenmelder     0
     2021-06-05 12:41:50   regensensor_wert 0
     2021-06-05 12:41:50   regenstunden_heute 1.6
     2021-06-05 12:41:50   rel_feuchte     64.0
     2021-06-05 12:41:50   sonne_azimut    157.3
     2021-06-05 12:41:50   sonne_elevation 60.1
     2021-06-05 12:41:50   sonne_scheint   1
     2021-06-05 12:41:23   state           active
     2021-06-05 12:41:50   taupunkt_temperatur 16.1
     2021-06-05 12:41:50   uv-index        2
     2020-09-10 07:23:24   vars_01_desc    weatherman_ip
     2020-09-10 07:23:24   vars_01_value   192.168.1.71
     2020-09-10 07:23:24   vars_02_desc    aussentemperatur
     2020-09-10 07:23:24   vars_02_value   10.2
     2020-09-10 07:23:24   vars_03_desc    gefuehlte_temperatur
     2020-09-10 07:23:24   vars_03_value   10.2
     2020-09-10 07:23:24   vars_04_desc    taupunkt_temperatur
     2020-09-10 07:23:24   vars_04_value   10.2
     2020-09-10 07:23:24   vars_05_desc    himmel_temperatur
     2020-09-10 07:23:24   vars_05_value   0.0
     2020-09-10 07:23:24   vars_06_desc    rel_feuchte
     2020-09-10 07:23:24   vars_06_value   100.0
     2020-09-10 07:23:24   vars_07_desc    abs_feuchte
     2020-09-10 07:23:24   vars_07_value   9.5
     2020-09-10 07:23:24   vars_08_desc    regenmelderwert
     2020-09-10 07:23:24   vars_08_value   0
     2020-09-10 07:23:24   vars_09_desc    regenstatus
     2020-09-10 07:23:24   vars_09_value   false
     2020-09-10 07:23:24   vars_10_desc    regenstaerke
     2020-09-10 07:23:24   vars_10_value   0.0
     2020-09-10 07:23:24   vars_11_desc    regen_pro_h
     2020-09-10 07:23:24   vars_11_value   0.0
     2020-09-10 07:23:24   vars_12_desc    regen_mm_heute
     2020-09-10 07:23:24   vars_12_value   0.0
     2020-09-10 07:23:24   vars_13_desc    regenstunden_heute
     2020-09-10 07:23:24   vars_13_value   0.0
     2020-09-10 07:23:24   vars_14_desc    regen_mm_gestern
     2020-09-10 07:23:24   vars_14_value   0.7
     2020-09-10 07:23:24   vars_15_desc    nn_luftdruck
     2020-09-10 07:23:24   vars_15_value   1023.38
     2020-09-10 07:23:24   vars_16_desc    luftdrucktrend
     2020-09-10 07:23:24   vars_16_value   stabil
     2020-09-10 07:23:24   vars_17_desc    windgeschwindigkeit_1min
     2020-09-10 07:23:24   vars_17_value   0.0
     2020-09-10 07:23:24   vars_18_desc    windgeschwindigkeit_10min
     2020-09-10 07:23:24   vars_18_value   0.0
     2020-09-10 07:23:24   vars_19_desc    bft_windgeschwindigkeit
     2020-09-10 07:23:24   vars_19_value   0
     2020-09-10 07:23:24   vars_20_desc    windrichtung
     2020-09-10 07:23:24   vars_20_value   WEST
     2020-09-10 07:23:24   vars_21_desc    windwinkel
     2020-09-10 07:23:24   vars_21_value   272
     2020-09-10 07:23:24   vars_22_desc    helligkeit
     2020-09-10 07:23:24   vars_22_value   41
     2020-09-10 07:23:24   vars_23_desc    uv-index
     2020-09-10 07:23:24   vars_23_value   0
     2020-09-10 07:23:24   vars_24_desc    sonne_scheint
     2020-09-10 07:23:24   vars_24_value   false
     2020-09-10 07:23:24   vars_25_desc    Sonnenstunden_heute
     2020-09-10 07:23:24   vars_25_value   0.0
     2020-09-10 07:23:24   vars_26_desc    sonne_elevation
     2020-09-10 07:23:24   vars_26_value   3.1
     2020-09-10 07:23:24   vars_27_desc    sonne_azimut
     2020-09-10 07:23:24   vars_27_value   87.5
     2020-09-10 07:23:24   vars_28_desc    minuten_vor_sa
     2020-09-10 07:23:24   vars_28_value   -26
     2020-09-10 07:23:24   vars_29_desc    minuten_vor_su
     2020-09-10 07:23:24   vars_29_value   747
     2021-06-05 12:41:50   weatherman_ip   192.168.1.71
     2021-06-05 12:41:50   windrichtung    WEST
     2021-06-05 12:41:50   windrichtung_grad 261
   DbLogExclude .*
   alias      Daten von Wetterstation Weatherman auf dem Gartenhaus
   event-on-change-reading weatherman_ip,peak_windgeschwindigkeit,licht,regenmelder,state
   group      Wetter
   makeEvent  reading
   parseProfile raw
   port       19721
   protocol   TCP
   room       Arbeitszimmer,Draussen->Wetter
   useEOF     1
   useParsefilter 1
   userReadings aussentemperatur { my $w=ReadingsVal($name,"MSG_Wetherman.fritz.box",0) ;; $w =~ s/.*"w_temperatur".*?"value":"([+-]?\d*[\.\d]\d*)".*/$1/ ;; $w },
gefuehlte_temperatur { my $w=ReadingsVal($name,"MSG_Wetherman.fritz.box",0) ;; $w =~ s/.*"w_windchill".*?"value":"([+-]?\d*[\.\d]\d*)".*/$1/ ;; $w },
taupunkt_temperatur { my $w=ReadingsVal($name,"MSG_Wetherman.fritz.box",0) ;; $w =~ s/.*"w_taupunkt".*?"value":"([+-]?\d*[\.\d]\d*)".*/$1/ ;; $w },
rel_feuchte { my $w=ReadingsVal($name,"MSG_Wetherman.fritz.box",0) ;; $w =~ s/.*"w_feuchte_rel".*?"value":"([+-]?\d*[\.\d]\d*)".*/$1/ ;; $w },
abs_feuchte { my $w=ReadingsVal($name,"MSG_Wetherman.fritz.box",0) ;; $w =~ s/.*"w_feuchte_abs".*?"value":"([+-]?\d*[\.\d]\d*)".*/$1/ ;; $w },
regensensor_wert { my $w=ReadingsVal($name,"MSG_Wetherman.fritz.box",0) ;; $w =~ s/.*"w_regensensor_wert".*?"value":"([+-]?\d*[\.\d]\d*)".*/$1/ ;; $w },
regenmelder { my $w=ReadingsVal($name,"MSG_Wetherman.fritz.box",0) ;; $w =~ s/.*"w_regenmelder".*?"value":"(true|false)".*/$1/ ;; $w =~ s/true/1/g ;;$w =~ s/false/0/g ;; $w },
regen_pro_h { my $w=ReadingsVal($name,"MSG_Wetherman.fritz.box",0) ;; $w =~ s/.*"w_regen_letzte_h".*?"value":"([+-]?\d*[\.\d]\d*)".*/$1/ ;; $w },
regen_mm_heute { my $w=ReadingsVal($name,"MSG_Wetherman.fritz.box",0) ;; $w =~ s/.*"w_regen_mm_heute".*?"value":"([+-]?\d*[\.\d]\d*)".*/$1/ ;; $w },
regenstunden_heute { my $w=ReadingsVal($name,"MSG_Wetherman.fritz.box",0) ;; $w =~ s/.*"w_regen_stunden_heute".*?"value":"([+-]?\d*[\.\d]\d*)".*/$1/ ;; $w },
regen_mm_gestern { my $w=ReadingsVal($name,"MSG_Wetherman.fritz.box",0) ;; $w =~ s/.*"w_regen_mm_gestern".*?"value":"([+-]?\d*[\.\d]\d*)".*/$1/ ;; $w },
nn_luftdruck { my $w=ReadingsVal($name,"MSG_Wetherman.fritz.box",0) ;; $w =~ s/.*"w_barometer".*?"value":"([+-]?\d*[\.\d]\d*)".*/$1/ ;; $w },
luftdrucktrend { my $w=ReadingsVal($name,"MSG_Wetherman.fritz.box",0) ;; $w =~ s/.*"w_barotrend".*?"value":"(fallend|stabil|steigend)".*/$1/ ;; $w },
avg_windgeschwindigkeit { my $w=ReadingsVal($name,"MSG_Wetherman.fritz.box",0) ;; $w =~ s/.*"w_wind_10min".*?"value":"([+-]?\d*[\.\d]\d*)".*/$1/ ;; $w },
peak_windgeschwindigkeit { my $w=ReadingsVal($name,"MSG_Wetherman.fritz.box",0) ;; $w =~ s/.*"w_wind_1min".*?"value":"([+-]?\d*[\.\d]\d*)".*/$1/ ;; $w },
bft_windgeschwindigkeit { my $w=ReadingsVal($name,"MSG_Wetherman.fritz.box",0) ;; $w =~ s/.*"w_windstaerke".*?"value":"([+-]?\d*[\.\d]\d*)".*/$1/ ;; $w },
windrichtung { my $w=ReadingsVal($name,"MSG_Wetherman.fritz.box",0) ;; $w =~ s/.*"w_windrichtung".*?"value":"(WEST|NORDWEST|NORD|NORDOST|OST|SUEDOST|SUED|SUEDWEST)".*/$1/ ;; $w },
windrichtung_grad { my $w=ReadingsVal($name,"MSG_Wetherman.fritz.box",0) ;; $w =~ s/.*"w_wind_dir".*?"value":"([+-]?\d*[\.\d]\d*)".*/$1/ ;; $w },
licht { my $w=ReadingsVal($name,"MSG_Wetherman.fritz.box",0) ;; $w =~ s/.*"w_lux".*?"value":"([+-]?\d*[\.\d]\d*)".*/$1/ ;; $w },
uv-index { my $w=ReadingsVal($name,"MSG_Wetherman.fritz.box",0) ;; $w =~ s/.*"w_uv_index".*?"value":"([+-]?\d*[\.\d]\d*)".*/$1/ ;; $w },
sonne_scheint { my $w=ReadingsVal($name,"MSG_Wetherman.fritz.box",0) ;; $w =~ s/.*"w_sonne_scheint".*?"value":"(true|false)".*/$1/ ;; $w =~ s/true/1/g ;;$w =~ s/false/0/g ;; $w },
Sonnenstunden_heute { my $w=ReadingsVal($name,"MSG_Wetherman.fritz.box",0) ;; $w =~ s/.*"w_sonnenstunden_heute".*?"value":"([+-]?\d*[\.\d]\d*)".*/$1/ ;; $w },
sonne_elevation { my $w=ReadingsVal($name,"MSG_Wetherman.fritz.box",0) ;; $w =~ s/.*"w_elevation".*?"value":"([+-]?\d*[\.\d]\d*)".*/$1/ ;; $w },
sonne_azimut { my $w=ReadingsVal($name,"MSG_Wetherman.fritz.box",0) ;; $w =~ s/.*"w_azimut".*?"value":"([+-]?\d*[\.\d]\d*)".*/$1/ ;; $w },
minuten_vor_sa { my $w=ReadingsVal($name,"MSGMSG_Wetherman.fritz.box",0) ;; $w =~ s/.*"w_minuten_vor_sa".*?"value":"([+-]?\d*[\.\d]\d*)".*/$1/ ;; $w },
minuten_vor_su { my $w=ReadingsVal($name,"MSG_Wetherman.fritz.box",0) ;; $w =~ s/.*"w_minuten_vor_su".*?"value":"([+-]?\d*[\.\d]\d*)".*/$1/ ;; $w },
weatherman_ip { my $w=ReadingsVal($name,"MSG_Wetherman.fritz.box",0) ;; $w =~ s/.*"w_ip".*?"value":"((\d|\d\d|[0-1]\d\d|2[0-4]\d|25[0-5])\.(\d|\d\d|[0-1]\d\d|2[0-4]\d|25[0-5])\.(\d|\d\d|[0-1]\d\d|2[0-4]\d|25[0-5])\.(\d|\d\d|[0-1]\d\d|2[0-4]\d|25[0-5]))".*/$1/ ;; $w }
Die Daten werden vom WM als JSON eigendlich für eine CCU geliefert, lassen sich aber über die beschriebene Definitionen der Userreadings in lesbare Werte umwandeln.
Weiterhin habe ich mehrere Rollos mittels dem AutoShuttersControl-Modul eingebunden.
Wenn ich jetzt hergehe, und binde den Helligkeitssensor der Station (aktuell als userreading licht definiert), bekomme ich häufiger die Meldung
2021.06.05 12:25:05.931 1: Error: >WM_Log:licht< has no TYPE, but following keys: ><
Ich konnte es inzwischen auf das Wechselspiel WM_Log und ASC zurückführen, da ich das Reading vorher mit "helligkeit" bezeichnet hatte sowie im ASC als Twilight-Reading WN_Log:helligkeit eingebunden war - und erst nach dem Anpassen der Bezeichnung auf "licht" im ASC änderte sich der Log-Eintrag zu dem hier beschriebenen.
Ich habe jetzt bereits einiges im Forum zu diesem Thema gelesen, so z.B. findet sich mit
{my $all="";; foreach my $k (keys(%defs)) { $all .=":$k:  length:".length($k)."\n" } return $all}
sehr viel, aber nichts mit der Länge 0
Hier auch noch einmal meine ASC-Definition:
   FUUID      5f51dcec-f33f-378b-a0e0-2b155d13c50ad53f
   FVERSION   73_AutoShuttersControl.pm:v0.10.14-s24470/2021-05-18
   MID        da39a3ee5e6b4b0d3255bfef95601890afd80709
   NAME       AutoRoll.ASC
   NOTIFYDEV  AutoRoll.ASC,Fenster.Buero,Fenster.Joschua,OUT_Twilight,Rollo.Arbeitszimmer,Rollo.HWR,Rollo.Joschua,Rollo.Schlafzimmer,WM_Log,global,hwr_Tuerkontakt_Carport,kz2_JoschuaFenster,rgr_Bewohner,sz_FensterKontaktSchlafzimmer
   NR         1514
   NTFY_ORDER 51-AutoRoll.ASC
   STATE      day open
   TYPE       AutoShuttersControl
   VERSION    v0.10.14
   OLDREADINGS:
     2020-09-30 18:59:07   Rollo.Arbeitszimmer Rollo.Arbeitszimmer_lastPosValue 0
     2021-06-05 09:00:27   Rollo.Arbeitszimmer_PosValue 0
     2021-01-06 07:52:38   Rollo.Arbeitszimmer_lastDelayPosValue 70
     2021-06-05 09:00:02   Rollo.Arbeitszimmer_lastPosValue 96
     2021-06-05 09:00:02   Rollo.Arbeitszimmer_nextAstroTimeEvent 05.06.2021 - 19:30
     2021-06-05 09:31:00   Rollo.HWR_PosValue 0
     2021-06-05 09:30:02   Rollo.HWR_lastPosValue 0
     2021-06-05 09:30:02   Rollo.HWR_nextAstroTimeEvent 05.06.2021 - 21:45
     2021-06-05 09:31:26   Rollo.Joschua_PosValue 0
     2021-01-04 07:11:13   Rollo.Joschua_lastDelayPosValue 90
     2021-06-05 09:30:02   Rollo.Joschua_lastPosValue 93
     2021-06-05 09:30:02   Rollo.Joschua_nextAstroTimeEvent 05.06.2021 - 19:30
     2021-06-05 09:31:50   Rollo.Schlafzimmer_PosValue 0
     2021-06-05 09:30:02   Rollo.Schlafzimmer_lastPosValue 90
     2021-06-05 09:30:02   Rollo.Schlafzimmer_nextAstroTimeEvent 05.06.2021 - 21:00
     2020-09-06 14:43:13   ascEnable       on
     2021-05-30 14:00:38   controlShading  on
     2020-09-05 12:00:23   hardLockOut     off
     2021-05-30 14:00:33   room_ASC_Arbeitszimmer_Fenster Rollo.Arbeitszimmer
     2021-05-30 14:00:33   room_ASC_Fenster_HWR Rollo.HWR
     2021-05-30 14:00:33   room_ASC_Fenster_Joschua Rollo.Joschua
     2021-05-30 14:00:33   room_ASC_Fenster_Schlafzimmer Rollo.Schlafzimmer
     2020-09-06 14:47:37   selfDefense     on
     2021-06-05 09:31:50   state           day open
     2020-09-12 19:53:28   sunriseTimeWeHoliday on
     2021-05-30 14:00:33   userAttrList    rolled out
   helper:
     shuttersList:
       Rollo.Arbeitszimmer
       Rollo.HWR
       Rollo.Joschua
       Rollo.Schlafzimmer
   monitoredDevs:
     Fenster.Buero:
       Rollo.Arbeitszimmer ASC_WindowRec
     Fenster.Joschua:
       Rollo.Joschua ASC_WindowRec
     OUT_Twilight:
       AutoRoll.ASC ASC_twilightDevice
     Rollo.Arbeitszimmer:
     Rollo.HWR:
     Rollo.Joschua:
     Rollo.Schlafzimmer:
     WM_Log:
       Rollo.Arbeitszimmer ASC_BrightnessSensor
       Rollo.HWR  ASC_BrightnessSensor
       Rollo.Joschua ASC_BrightnessSensor
       Rollo.Schlafzimmer ASC_BrightnessSensor
     hwr_Tuerkontakt_Carport:
       Rollo.HWR  ASC_WindowRec
     kz2_JoschuaFenster:
     rgr_Bewohner:
       AutoRoll.ASC ASC_residentsDev
     sz_FensterKontaktSchlafzimmer:
       Rollo.Schlafzimmer ASC_WindowRec
   ASC_autoAstroModeEvening REAL
   ASC_autoAstroModeMorning REAL
   ASC_autoShuttersControlComfort on
   ASC_autoShuttersControlEvening on
   ASC_autoShuttersControlMorning on
   ASC_blockAscDrivesAfterManual 0
   ASC_expert 1
   ASC_residentsDev rgr_Bewohner
   ASC_tempSensor tr_ThermometerTerasse:temperature
   ASC_twilightDevice WM_Log:licht
   DbLogExclude .*
   devStateIcon { ShuttersControl_DevStateIcon($name) }
   icon       fts_shutter_automatic
   room       ASC
Ich habe eine Zeit lang mal verbose 5 für das ASC-Device laufen lassen - im Anhang das entsprechende Log
Ich hoffe, Ihr könnt mir helfen, die Ursache zu finden und zu beseitigen.
Danke.
Christoph
Edit: Fehler ist beseitigt - ich hatte versehentlich in ASC das Twilight-Modul auf den Weatherman-Helligkeitssensor verbogen ...
Alte Techniker-Regel: "kaum macht man es richtig, funktioniert es auch"
Dell Wyse5070 ThinClient 16GBRam, 128GB SSD, Debian 13 Trixie, fhem (aktuell), debmatic, Homematic-Devs, ConBee III und deConz, viele Shellys, Rademacher DuoFern, NextCloud-Anbindung, FullyKioskBrowser+FUIP uvm.
