Fehlermeldungen von HM_Info
Begonnen von Hightower62, 07 August 2014, 23:06:23
frank
2015-02-07 20:11:58   R-cyclicInfoMsg set_on
auf alle fälle vermisst fhem noch infos. also mache ein getconfig.
meine fk (1st generation) sind gar nicht gepeert, nur gepairt und senden ebenfalls direkt an die zentrale (vccu)
    2015-02-11 10:34:25   contact         closed (to VCCU)
aber bei mir gibt es trotzdem kein reading
     2015-02-08 11:01:19   trigDst_VCCU    noConfig
zeig noch ein list von der vccu.
FHEM: 6.0(SVN) => Pi3(buster)
Mitch
getconfig habe ich eigentlich schon ein paar mal gemacht.
list VCCU:
   .triggerUsed 1
   CFGFN
   DEF        26E9A0
   HMLan_MSGCNT 9931
   HMLan_RAWMSG E289D9E,0000,03A8967B,FF,FFA6,698670289D9E000000007C49
   HMLan_RSSI -90
   HMLan_TIME 2015-02-11 13:43:44
   IODev      HMLan
   LASTInputDev HMLan
   MSGCNT     9931
   NAME       VCCU
   NR         476
   STATE      HMLan:ok,
   TYPE       CUL_HM
   assignedIOs HMLan
   Readings:
     2015-01-28 23:00:01   unknown_19C66E  received
     2015-01-29 20:00:01   unknown_1C7127  received
     2015-01-29 19:08:20   unknown_1EB5CC  received
     2015-02-10 23:48:20   unknown_24E5C1  received
     2015-02-11 06:21:07   unknown_257CCA  received
     2015-02-10 21:59:58   unknown_263B7A  received
     2014-12-24 12:54:09   unknown_26D93E  received
     2015-02-10 23:16:44   unknown_282FA0  received
     2015-02-11 13:43:27   unknown_28400E  received
     2015-02-11 13:43:44   unknown_289D9E  received
     2015-01-07 22:49:47   unknown_28A7F3  received
     2015-02-10 12:46:03   unknown_29DA84  received
     2015-02-06 21:57:32   unknown_2AD20C  received
     2015-02-10 18:22:55   unknown_2AD24F  received
     2015-02-03 18:30:05   unknown_2AD6AE  received
     2015-02-11 12:39:32   unknown_2AEBF1  received
     2015-02-10 22:40:19   unknown_2B8EBA  received
     2015-02-10 22:40:18   unknown_2BA55E  received
     2015-02-11 13:39:53   unknown_2BC14D  received
     2015-02-11 13:43:35   unknown_2C9002  received
     2014-12-17 19:45:02   unknown_2C94D8  received
     2015-02-11 05:21:14   unknown_2DDC43  received
     2015-02-01 23:39:19   unknown_2E196F  received
     2015-02-03 18:26:49   unknown_2E2CF8  received
     2015-02-10 18:16:59   unknown_2E63BE  received
     2015-02-06 21:55:21   unknown_2E6706  received
     2015-02-06 19:14:49   unknown_2E6730  received
     2015-02-11 13:06:12   unknown_31D922  received
     2014-12-30 23:51:18   unknown_31F1DA  received
     2015-02-11 13:15:42   unknown_31FDC9  received
     2015-01-29 22:12:19   unknown_31FE8C  received
   Helper:
     mId        FFF0
     rxType     1
     Io:
       prefIO
       vccu
       ioList:
         HMLan
     Mrssi:
       mNo
     Prt:
       bErr       0
       sProc      0
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       chn        1
       dev        1
       vrt        1
     Rssi:
     Shadowreg:
   DbLogExclude .*
   IODev      HMLan
   IOList     HMLan
   expert     2_full
   group      Zentrale
   icon       hm_lan@black
   model      CCU-FHEM
   room       Zentrale
   subType    virtual
   verbose    0
   webCmd     virtual:update
FHEM im Proxmox Container
frank
vor kurzem war der fk noch unbekannt.
hast du den zu diesem zeitpunkt neu integriert? vieleicht macht das reading auch ärger. sind da noch mehr von deinen devices enthalten? die nachbar devices würde ich jedenfalls auf ignore setzen. du kannst die unknown-readings separat löschen mit clear unknownDev. die werden dann mit neuen empfangenen messages wieder angelegt. wenn du sicher bist, dass alle unknown readings vom nachbarn erzeugt wurden, kannst du mit set defIgnUnknown alle erkannten unknown devices automatisch definieren und mit attr ignore ausstatten. anschliessend sind die readings weg.
Zitatgetconfig habe ich eigentlich schon ein paar mal gemacht.
solange ein register mit "set_" gekennzeichnet ist, fehlt fhem die bestätigung des wertes. bisher ist nur das setzen gesendet, aber der wert wurde noch nicht aus dem device ausgelesen. ein getconfig zum fk musst (solltest) du am fk durch drücken des configtasters abarbeiten. manche können wohl theoretisch auch lazyconfig.
Mitch
Nein, habe nichts neu intergriert.
habe gerade auch nochmal den Sync-knopf gedrückt, jetzt sind alles CMDs done.
Nach wie vor habe ich aber diesen Hinweis in HMinfo:
warning: sensor triggers but no config found
    Fenster_Bad triggers 26E9A0
    Fenster_Flur_oben triggers 26E9A0
    Fenster_Klo triggers 26E9A0
martinp876
die 3 Fensterkontakte triggern den 26E9A0.
a) ist das Korrekt?
b) ist der 26E9A0 gepeert? Welcher Kanal? stehen die Fenster in der PeerId?
octek0815
ich habe das selbe Problem:
    Badezimmer_OG_Fenstersensor triggers 987123
    Flur_EG_Haustuer_Sensor triggers 987123
    Kinderzimmer2_OG_Fenstersensor triggers 987123
Egal ob mit oder ohne VCCU, ich bekomme die Meldungen kommen immer wieder.
Ich habe zwei unterschiedliche Fensterkontakte: HM-Sec-SCo & HM-Sec-RHS.
Oliver
Bennemannc
Das habe ich auch:
trigger sent to unpeered device
    triggerUnpeered: Bewegungsmelder_01:23A821
    triggerUnpeered: Fensterkontakt_01:23A821
    triggerUnpeered: Fensterkontakt_02:23A821
    triggerUnpeered: Funktaster_02_Btn_01:23A821
    triggerUnpeered: Funktaster_02_Btn_02:23A821
trigger sent to undefined device
    triggerUndefined: Bewegungsmelder_01:23A821
    triggerUndefined: Fensterkontakt_01:23A821
    triggerUndefined: Fensterkontakt_02:23A821
    triggerUndefined: Fensterkontakt_05:23A821
    triggerUndefined: Funktaster_02_Btn_01:23A821
    triggerUndefined: Funktaster_02_Btn_02:23A821
Der Bewegungsmelder ist mit einem Schalter gepeert und funktioniert. Die Fensterkontakte sind mit RD's oder TC's gepeert. Der Funktaster ist mit einem Schalter gepeert und die ID die angemeckert wird ist der HMLAN. Eine VCCU nutze ich nicht, da ich bis jetzt mit einem IO ausgekommen bin.
Gruß Christoph
Cubietruck, Fhem 5.8
martinp876
mit einer VCCU könnte man Channels mit der ID des HMLAN einrichten und diesen Peer eintragen. Dann wäre die Meldung voraussichtlich weg.
VCCU kann mehr als multi-IO  ;)
Bennemannc
Hallo Martin,
kann sein, das die Warnungen dann weg sind, nur warum soll ich die Geräte mit meiner Zentrale peeren ? Ich sehe da irgendwie keinen Sinn darin. Die sind gepairt - also angemeldet, und fhem bekommt ja auch alles was die machen mit.
Kann das sein, das es daran liegt, dass diese Komponenten eigentlich AES machen - oder machen wollen ? Die Fensterkontakte die aufgeführt werden sind alle SC-2. Und angemeckert wird die 23A821 das ist den HMLAN - und, wenn ich eine VCCU nutze ja auch meine Zentrale.
Gruß Christoph
martinp876
Ein kanal sendte primaer an seinen peer. Hminfo prueft die stimmigkeit der daten... versucht es zumindest. Wenn ein kanal einen trigger an eine adresse sendet wird geprueft ob auch ein peer eingetragen ist.
Das peeren von kanaelen der zentrale ist auch moeglich... und gelegentlich sinnvoll.
Ich pruefe einmal, ob man das mit der zentrale ignorieren kann..... beim sc kann man es wohl schlecht unterbinden.
Ist dein sc auch gepeert und kannst du einen lig schicken?
Bennemannc
Hallo Martin,
einmal ein List von dem Bewegungsmelder
   DEF        2B6220
   HMLAN1_MSGCNT 81
   HMLAN1_RAWMSG E2B6220,0000,0E81882A,FF,FFB7,2FA0412B62202A32EC013E0050
   HMLAN1_RSSI -73
   HMLAN1_TIME 2015-03-02 19:01:22
   IODev      HMLAN1
   LASTInputDev HMLAN1
   MSGCNT     81
   NAME       Bewegungsmelder_01
   NR         439
   STATE      .
   TYPE       CUL_HM
   lastMsg    No:2F - t:41 s:2B6220 d:2A32EC 013E0050
   peerList   Lichtschalter_03,
   protLastRcv 2015-03-02 19:01:22
   rssi_at_HMLAN1 avg:-72.65 min:-76 max:-71 lst:-73 cnt:81
   Readings:
     2014-12-16 14:28:31   CommandAccepted yes
     from archive          D-firmware      1.6
     from archive          D-serialNr      LEQ0573504
     2014-12-16 14:29:54   PairedTo        0x23A821
     2014-12-16 14:29:55   R-Lichtschalter_03_chn-01-peerNeedsBurst off
     2014-12-27 21:28:48   R-brightFilter  set_1
     2014-12-27 21:28:48   R-captInInterval set_off
     2014-12-27 21:28:48   R-evtFltrNum    1
     2014-12-11 16:06:07   R-evtFltrPeriod 0.5 s
     2014-12-27 21:28:48   R-minInterval   set_60
     2014-12-16 14:29:52   R-pairCentral   0x23A821
     2014-12-16 14:28:31   aesKeyNbr       00
     2014-12-12 15:07:51   battery         ok
     2015-03-02 19:01:22   brightness      0
     2014-12-12 15:07:51   cover           closed
     2015-03-02 19:01:22   motion          on (to Lichtschalter_03)
     2015-03-02 19:01:22   motionCount     62_next:14s
     2015-02-27 15:46:52   peerList        Lichtschalter_03,
     2014-12-12 15:07:51   recentStateType info
     2014-12-16 14:28:31   sabotageAttack  ErrIoAttack cnt:20
     2015-03-02 19:01:22   state           motion
     2014-12-11 14:51:22   trigDst_23A821  noConfig
     2015-03-02 19:01:22   trigger_cnt     62
   Helper:
     mId        004F
     rxType     28
     Io:
       newChn     +2B6220,00,01,1E
       nextSend   1425319282.83835
       prefIO
       rxt        2
       vccu
       p:
         2B6220
         00
         01
         1E
     Mrssi:
       mNo        2F
       Io:
         HMLAN1     -71
     Prt:
       bErr       0
       sProc      0
       sleeping   1
     Q:
       qReqConf
       qReqStat
     Role:
       chn        1
       dev        1
     Rssi:
       At_hmlan1:
         avg        -72.6543209876544
         cnt        81
         lst        -73
         max        -71
         min        -76
     Shadowreg:
   IODev      HMLAN1
   alias      Bewegungsmelder Haustüre
   autoReadReg 5_readMissing
   expert     0_off
   firmware   1.6
   icon       people_sensor
   model      HM-SEN-MDIR-SM
   peerIDs    00000000,2A32EC01,
   room       Garten-Garage
   serialNr   LEQ0573504
   stateFormat .
   subType    motionDetector
und der List von dem Fensterkontakt
   CFGFN      Fensterkontakte.cfg
   DEF        24D73D
   HMLAN1_MSGCNT 38
   HMLAN1_RAWMSG E24D73D,0000,0D8E6416,FF,FFC6,08A24124D73D23A821818200
   HMLAN1_RSSI -58
   HMLAN1_TIME 2015-03-02 14:35:50
   IODev      HMLAN1
   LASTInputDev HMLAN1
   MSGCNT     38
   NAME       Fensterkontakt_01
   NR         249
   STATE      closed
   TYPE       CUL_HM
   lastMsg    No:08 - t:41 s:24D73D d:23A821 818200
   peerList   Thermostat_4_WindowRec,
   protLastRcv 2015-03-02 14:35:50
   protSnd    18 last_at:2015-03-02 14:35:50
   protState  CMDs_done
   rssi_at_HMLAN1 avg:-65.92 min:-75 max:-57 lst:-58 cnt:38
   Readings:
     2015-02-27 15:46:53   Activity        alive
     2015-02-26 18:30:22   CommandAccepted yes
     from archive          D-firmware      2.2
     from archive          D-serialNr      KEQ0950100
     2015-02-26 18:30:22   PairedTo        0x23A821
     2014-12-03 15:53:50   R-Thermostat_4_WindowRec-expectAES off
     2014-12-03 15:53:50   R-Thermostat_4_WindowRec-peerNeedsBurst on
     2015-02-26 18:30:22   R-cyclicInfoMsg on
     2015-02-26 18:30:23   R-eventDlyTime  8 s
     2014-12-03 15:42:02   R-pairCentral   0x23A821
     2014-12-03 15:42:02   R-sabotageMsg   on
     2014-12-03 15:53:49   R-sign          off
     2015-02-26 18:30:52   alive           yes
     2015-03-02 14:35:50   battery         low
     2015-03-02 14:35:50   contact         closed (to HMLAN1)
     2015-02-27 15:46:53   peerList        Thermostat_4_WindowRec,
     2015-02-26 18:30:52   recentStateType info
     2015-02-26 18:30:52   sabotageError   off
     2015-03-02 14:35:50   state           closed
     2015-03-02 14:35:50   trigDst_23A821  noConfig
     2015-03-02 14:35:50   trigger_cnt     130
   Helper:
     mId        00B1
     rxType     12
     Io:
       newChn     +24D73D,00,01,00
       nextSend   1425303350.7303
       prefIO
       rxt        2
       vccu
       p:
         24D73D
         00
         01
         00
     Mrssi:
       mNo        08
       Io:
         HMLAN1     -56
     Prt:
       bErr       0
       sProc      0
       sleeping   1
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       chn        1
       dev        1
     Rpt:
       IO         HMLAN1
       flg        A
       ts         1425303350.64955
       ack:
         HASH(0x11843c8)
         08800223A82124D73D0101C800
     Rssi:
       At_hmlan1:
         avg        -65.9210526315789
         cnt        38
         lst        -58
         max        -57
         min        -75
     Shadowreg:
   IODev      HMLAN1
   actCycle   028:00
   actStatus  alive
   alias      Tür zum Wintergarten
   devStateIcon closed:fts_door_right@green open:fts_door_right_open@red
   event-on-change-reading .*
   expert     0_off
   firmware   2.2
   group      Fenster
   icon       fts_door_right
   model      HM-SEC-SC-2
   peerIDs    00000000,22ADFD03,
   room       Fitness
   serialNr   KEQ0950100
   sortby     13
   subType    threeStateSensor
Gruß Christoph
martinp876
Die sensoren scheinen trigger an den peer UND die zentrale zu senden. Koennte man im log sehen
Bennemannc
Hallo Martin,
mit den "normalen" Einstellungen ist nichts im Log zu sehen. Wie schon erwähnt vermute ich, das es mit AES zusammenhängt und der Sensor eine Bestätigung der Zentrale erwartet.
Gruß Christoph
martinp876
Der eintrag kommt bei einem trigger an diese adresse.
Kannst du ein ereigniss mit und ohne aes loggen...
Bennemannc
Hallo Martin,
nur ohne - mit AES habe ich schon mal Probleme gehabt, das möchte ich nicht noch einmal. Weder die Tage mal nachsehen ... BTW ein List vom Fensterkontakt
   DEF        24D73D
   HMLAN1_MSGCNT 44
   HMLAN1_RAWMSG E24D73D,0000,044EEC2F,FF,FFC1,3DA24124D73D23A821819C00
   HMLAN1_RSSI -63
   HMLAN1_TIME 2015-03-05 20:06:21
   IODev      HMLAN1
   LASTInputDev HMLAN1
   MSGCNT     44
   NR         249
   STATE      closed
   TYPE       CUL_HM
   lastMsg    No:3D - t:41 s:24D73D d:23A821 819C00
   protLastRcv 2015-03-05 20:06:21
   protSnd    21 last_at:2015-03-05 20:06:21
   protState  CMDs_done
   rssi_at_HMLAN1 avg:-66.11 min:-85 max:-56 lst:-63 cnt:44
   Readings:
     2015-03-04 09:14:35   Activity        alive
     2015-03-05 07:10:52   alive           yes
     2015-03-05 20:06:21   battery         low
     2015-03-05 20:06:21   contact         closed (to HMLAN1)
     2015-03-04 09:14:35   peerList        Thermostat_4_WindowRec,
     2015-03-05 07:10:52   recentStateType info
     2015-03-05 07:10:52   sabotageError   off
     2015-03-05 20:06:21   state           closed
     2015-03-05 20:06:21   trigDst_23A821  noConfig
     2015-03-05 20:06:21   trigger_cnt     156
   Helper:
     mId        00B1
     rxType     12
     Io:
       nextSend   1425582381.98031
       prefIO
       rxt        2
       vccu
       p:
         24D73D
         00
         01
         00
     Mrssi:
       mNo        3D
       Io:
         HMLAN1     -61
     Prt:
       bErr       0
       sProc      0
       sleeping   1
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       chn        1
       dev        1
     Rpt:
       IO         HMLAN1
       flg        A
       ts         1425582381.89949
       ack:
         HASH(0x118e028)
         3D800223A82124D73D0101C800
     Rssi:
       At_hmlan1:
         avg        -66.1136363636364
         cnt        44
         lst        -63
         max        -56
         min        -85
     Shadowreg:
   IODev      HMLAN1
   actCycle   028:00
   actStatus  alive
   expert     0_off
   firmware   2.2
   group      Fenster
   icon       fts_door_right
   model      HM-SEC-SC-2
   room       Fitness
   serialNr   KEQ0950100
   sortby     14
Da steht was von "  trigDst_23A821  noConfig" drin. Der dürfte das Auslösen- warum der so da steht weiß ich nicht, das würde automatisch angelegt.
Gruß Christoph
