98_WOL.pm-Patch für State-Änderung
Begonnen von Risiko, 09 November 2014, 18:56:01
Tommy82
#30
Also ich hab jetzt am Server nochmal folgendes deaktiviert in den Netzwerkeinstellungen
ARP Reguests im Standby beantworten
Allerdings zeigt mir das list immer noch on an
   DEF        bc:5f:f4:fb:7f:de 192.168.188.26
   INTERVAL   90
   IP         192.168.188.26
   MAC        bc:5f:f4:fb:7f:de
   MODE       BOTH
   NAME       WinServer
   NR         211
   REPEAT     000
   STATE      on
   TYPE       WOL
   Readings:
     2014-11-24 09:58:08   active          off
     2014-11-24 10:11:45   isRunning       true
     2014-11-24 09:58:08   packet_via_EW   none
     2014-11-24 09:58:08   packet_via_UDP  none
     2014-11-24 10:11:45   state           on
   devStateIcon on:it_pc@green off:it_pc@red
   fp_Home    399,1828,0,
   fp_Server  602,414,0,
   icon       it_pc
   interval   90
   verbose    5
   webCmd     on:off
und auch im Log kommt immer noch ein ping an........
2014.11.24 10:13:08.567 5: [WinServer] executing: ping -c 1 -w 2 192.168.188.26
2014.11.24 10:13:08.569 5: [WinServer] result of ping:PING 192.168.188.26 (192.168.188.26): 56 data bytes
2014.11.24 10:13:08.571 5: [WinServer] ping succesful - state = on
ping: permission denied (are you root?)
2014.11.24 10:13:16.058 5: [WinServer] executing: ping -c 1 -w 2 192.168.188.26
2014.11.24 10:13:16.061 5: [WinServer] result of ping:PING 192.168.188.26 (192.168.188.26): 56 data bytes
2014.11.24 10:13:16.062 5: [WinServer] ping succesful - state = on
Im Log gibts aber auch noch diese Meldung:
2014.11.24 09:35:19.087 5: [WinServer] ping succesful - state = on
2014.11.24 09:36:40.834 1: PERL WARNING: Possible unintended interpolation of @green in string at (eval 8893) line 1.
2014.11.24 09:36:40.841 1: PERL WARNING: Possible unintended interpolation of @green in string at (eval 8895) line 1.
2014.11.24 09:36:40.847 1: PERL WARNING: Possible unintended interpolation of @green in string at (eval 8897) line 1.
2014.11.24 09:36:40.853 1: PERL WARNING: Possible unintended interpolation of @green in string at (eval 8899) line 1.
2014.11.24 09:36:42.013 1: PERL WARNING: Possible unintended interpolation of @green in string at (eval 8901) line 1.
2014.11.24 09:36:42.019 1: PERL WARNING: Possible unintended interpolation of @green in string at (eval 8903) line 1.
2014.11.24 09:36:42.026 1: PERL WARNING: Possible unintended interpolation of @green in string at (eval 8905) line 1.
2014.11.24 09:36:42.032 1: PERL WARNING: Possible unintended interpolation of @green in string at (eval 8907) line 1.
2014.11.24 09:36:42.038 1: PERL WARNING: Possible unintended interpolation of @green in string at (eval 8909) line 1.
2014.11.24 09:36:42.044 1: PERL WARNING: Possible unintended interpolation of @green in string at (eval 8911) line 1.
2014.11.24 09:36:49.174 5: [WinServer] executing: ping -c 1 -w 2 192.168.188.26
2014.11.24 09:36:49.177 5: [WinServer] result of ping:PING 192.168.188.26 (192.168.188.26): 56 data bytes
Allnetl Wandtablett mit FTUI
Tommy82
Hab aber auch noch ein neues WOL problem, beim versuchen den Server über das WOL Modul zustarten bekomme ich im Log diesen Fehler, und der Server läuft nicht
2014.11.24 20:05:17.986 3: [WinServer] set WinServer on
2014.11.24 20:05:18.023 3: [WinServer] waking  WinServer with MAC bc:5f:f4:fb:7f:de IP 192.168.188.26
2014.11.24 20:05:18.068 5: [WinServer] executing: ping -c 1 -w 2 192.168.188.26
2014.11.24 20:05:18.071 5: [WinServer] result of ping:PING 192.168.188.26 (192.168.188.26): 56 data bytes
2014.11.24 20:05:18.072 5: [WinServer] ping succesful - state = on
2014.11.24 20:05:18.120 4: [WinServer] keeping WinServer with MAC bc:5f:f4:fb:7f:de IP 192.168.188.26 busy
2014.11.24 20:05:18.126 5: [WinServer] standard wol command: no WOL found - use '/usr/bin/ether-wake' or '/usr/bin/wakeonlan' or define Attribut sysCmd
2014.11.24 20:05:18.127 5: [WinServer] user wol command(sysCmd): ''
2014.11.24 20:05:18.128 1: [WinServer] system command 'no WOL found - use '/usr/bin/ether-wake' or '/usr/bin/wakeonlan' or define Attribut sysCmd' not found
Dietmar63
Bei dir scheint ja gar nichts zu funktionieren.
Wenn die Meldung kommt, findet WOL das standardmäßig installierte Systemprogramm
nicht.
Entweder suchen und auf deiner Maschine installieren, oder ein anderes Programm suchen und dem WOL über syscmd bekannt machen.
Da du eine Fritzbox hast, kann es sein, dass nur die UDP Variante im WOL funktioniert - siehe Dokumentation.
Gruß Dietmar
FB7390, CUL, 2 FHT, FS20
Tommy82
Hallo Dietmar, doch der WOL klappe immer, geht erst seit heute nicht mehr. Denke es liegt irgendwo an Perl, hab da heut was wegen einem anderen Module versucht, vieleicht hab ich da as durcheinander gebracht. Aber mit dem Status ist schon komisch.
Naja ich werd jetzt morgen oder übermorgen erstmal von der FB( ist zu ausgelastet) auf einen cubie umziehen und dann mal sehn ob sich das ein oder andere nicht von selbst löst.
Dietmar63
Gruß Dietmar
Tommy82
Hallo Dietmar,
so hab Fhem nun auf dem Cubie am laufen und migriert, und siehe da, nun aktualisiert sich das State.
Scheint also irgendwo an der FB gelegen zu haben, wieso auch immer. Jetzt sieht es super aus und funktioniert.
Danke für dein Hilfe
Tommy82
hab heute diese Meldung im Log, als ich den Server wecken will
2014.12.10 20:17:53.686 3: [WHS_2011] set WHS_2011 on
2014.12.10 20:17:53.702 3: [WHS_2011] waking  WHS_2011 with MAC c8:61:50:36:bd:fd IP 192.168.188.22
Can't ignore signal CHLD, forcing to default.
Was bedeutet das?
Das wecken hat funktioniert
Dietmar63
keine Ahnung - hast du mal gegoogelt?
Gruß Dietmar
Tommy82
Tommy82
hab immer noch wenn ich den WOL Button betätige diese Meldung im Log
2015.03.12 19:59:13.312 3: [WHS_2011] set WHS_2011 on
2015.03.12 19:59:13.332 3: [WHS_2011] waking  WHS_2011 with MAC c8:70:00:36:bd:fd IP 192.168.188.22
2015.03.12 19:59:14.016 3: [WHS_2011] set WHS_2011 on
2015.03.12 19:59:14.041 3: [WHS_2011] waking  WHS_2011 with MAC c8:70:00:36:bd:fd IP 192.168.188.22
Hat das sonst keiner? Woran könnte es liegen? Find bei google leider nichts
Dietmar63
#40
hier steht was dazu:
http://osdir.com/ml/linux.openwall.user/2003-01/msg00008.html
Ich denke das hängt irgendwie mit der Installation auf dem cubie zusammen.
Gruß Dietmar
Tommy82
Ja das hatte ich auch bei google gefunden, aber ohne das es mich richtig weiter bringt...
