Fehlermeldung nach heutigem update...
Begonnen von Rampler, 12 Juli 2015, 16:21:18
Rampler
Direkt nach dem Start kommt:
PERL WARNING: Use of uninitialized value $cq in hash element at ./FHEM/10_CUL_HM.pm line 7670.
3 HMUART (2 via ESP8266), 1 DUOFERN, 12 ESP8266, SolvisBen, GoodWE WR, RPI2 (Trixie), ZWAVE, HM-Classic, Matter und hoch zufrieden ...
Danke an alle, die was dazu beigetragen haben !!
Rampler
Kann das Thema bitte jemand in den Homematic Bereich verschieben.... ?!
Mit Stand heute kommt nun:
PERL WARNING: Use of uninitialized value $cq in hash element at ./FHEM/10_CUL_HM.pm line 7671
dindihi
Hab genau das gleiche Problem:
2015.07.23 12:18:41.872 1: PERL WARNING: Use of uninitialized value $cq in hash element at ./FHEM/10_CUL_HM.pm line 7671.
2015.07.23 12:18:41.872 3: stacktrace:
2015.07.23 12:18:41.872 3:     main::__ANON__                      called by ./FHEM/10_CUL_HM.pm (7671)
2015.07.23 12:18:41.872 3:     main::CUL_HM_unQEntity              called by ./FHEM/10_CUL_HM.pm (2945)
2015.07.23 12:18:41.873 3:     main::CUL_HM_parseCommon            called by ./FHEM/10_CUL_HM.pm (1197)
2015.07.23 12:18:41.873 3:     main::CUL_HM_Parse                  called by fhem.pl (3178)
2015.07.23 12:18:41.873 3:     main::Dispatch                      called by ./FHEM/00_HMLAN.pm (738)
2015.07.23 12:18:41.873 3:     main::HMLAN_Parse                   called by ./FHEM/00_HMLAN.pm (561)
2015.07.23 12:18:41.873 3:     main::HMLAN_Read                    called by fhem.pl (3041)
2015.07.23 12:18:41.873 3:     main::CallFn                        called by fhem.pl (647)
2015.07.23 12:18:41.875 1: PERL WARNING: Use of uninitialized value $cq in hash element at ./FHEM/10_CUL_HM.pm line 7671.
2015.07.23 12:18:41.875 3: stacktrace:
2015.07.23 12:18:41.875 3:     main::__ANON__                      called by ./FHEM/10_CUL_HM.pm (7671)
2015.07.23 12:18:41.876 3:     main::CUL_HM_unQEntity              called by ./FHEM/10_CUL_HM.pm (1878)
2015.07.23 12:18:41.876 3:     main::CUL_HM_Parse                  called by fhem.pl (3178)
2015.07.23 12:18:41.876 3:     main::Dispatch                      called by ./FHEM/00_HMLAN.pm (738)
2015.07.23 12:18:41.876 3:     main::HMLAN_Parse                   called by ./FHEM/00_HMLAN.pm (561)
2015.07.23 12:18:41.876 3:     main::HMLAN_Read                    called by fhem.pl (3041)
2015.07.23 12:18:41.876 3:     main::CallFn                        called by fhem.pl (647)
2015.07.23 12:18:42.572 3: CUL_HM set EZ.LED.Front.Sw off
2015.07.23 12:18:43.144 1: PERL WARNING: Use of uninitialized value $cq in hash element at ./FHEM/10_CUL_HM.pm line 7671.
2015.07.23 12:18:43.145 3: stacktrace:
2015.07.23 12:18:43.145 3:     main::__ANON__                      called by ./FHEM/10_CUL_HM.pm (7671)
2015.07.23 12:18:43.145 3:     main::CUL_HM_unQEntity              called by ./FHEM/10_CUL_HM.pm (7629)
2015.07.23 12:18:43.145 3:     main::CUL_HM_stateUpdatDly          called by ./FHEM/10_CUL_HM.pm (1813)
2015.07.23 12:18:43.145 3:     main::CUL_HM_Parse                  called by fhem.pl (3178)
2015.07.23 12:18:43.146 3:     main::Dispatch                      called by ./FHEM/00_HMLAN.pm (738)
2015.07.23 12:18:43.146 3:     main::HMLAN_Parse                   called by ./FHEM/00_HMLAN.pm (561)
2015.07.23 12:18:43.146 3:     main::HMLAN_Read                    called by fhem.pl (3041)
2015.07.23 12:18:43.146 3:     main::CallFn                        called by fhem.pl (647)
2015.07.23 12:18:43.953 3: CUL_HM set EZ.LED.Side.Sw off
2015.07.23 12:18:44.177 1: PERL WARNING: Use of uninitialized value $cq in hash element at ./FHEM/10_CUL_HM.pm line 7671.
2015.07.23 12:18:44.177 3: stacktrace:
2015.07.23 12:18:44.177 3:     main::__ANON__                      called by ./FHEM/10_CUL_HM.pm (7671)
2015.07.23 12:18:44.178 3:     main::CUL_HM_unQEntity              called by ./FHEM/10_CUL_HM.pm (7629)
2015.07.23 12:18:44.178 3:     main::CUL_HM_stateUpdatDly          called by ./FHEM/10_CUL_HM.pm (1813)
2015.07.23 12:18:44.178 3:     main::CUL_HM_Parse                  called by fhem.pl (3178)
2015.07.23 12:18:44.178 3:     main::Dispatch                      called by ./FHEM/00_HMLAN.pm (738)
2015.07.23 12:18:44.179 3:     main::HMLAN_Parse                   called by ./FHEM/00_HMLAN.pm (561)
Puschel74
#3
Rampler als Beitragsersteller kann den Beitrag nach Homematic verschieben.
Oder man bittet den Admin/GlobalModerator den Beitrag zu verschieben.
Generell sollten solche "Probleme" auch im richtigen Forenbereich gepostet werden.
